- Apr 19, 2023
- 26
- 7
- Garland, TX, USA
- C?ID=550560
i had a problem updating my HEX-V2 firmware on a windows 10 laptop used for VCDS only. When you go to do the search for updates and find a firmware update, or have a firmware updatre required, the update software will throw up a browser window, maybe for only a split second, with no URL. Or it might not, but the transfer process to HEX-V2 will stall by just restarting the transfer of the update over and over again.
Since VCDS could see and identify the HEX-V2 and show version information, I knew that wasn't the problem, nor was the update a problem because that downloaded, prepared, but then could not transfer.
Duckduckgo blocks 2 way communication that might be required because it is a more private browser blocking 2 way communication.
As I was debugging the process, I remembered there are other sites that don't like duckduckgo - like banking ones that require this kind of communication.
Since I had duckduckgo set as default browser that is what would come up by default if only for a second and the plug the toilet.
SOLUTION: Go to default browser ap and set Chrome or Edge as the default. Un plug HEX-V2, reboot, plug in the HEX-V2, the follow the firmware instructions.
Rather than seeing transferring start over and over again, the update will go as expect.
This is the first time I have seen the problem in years of use of this fine product. The update went as planned and I could use VCDS as always.
Best of luck.
Best of luck.
