Saturday,31,October,2026,14:57:15:17890
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.4
VIN: WAUZZZFJ0T1081286 License Plate: BG3358CO
Mileage: 8359km-5194mi Repair Order:
Chassis Type: FJ-AU38P PA* (5QS)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 23 36 42 44 4B 52
5F 69 6C 6D 75 82 A5 A9 BB BC CA D6 D7 D8 D9 DE 8109 810A 810B 810C
811E 811F 8120 8121 8125 813F 8153 815A 81D0 C002 C003
VIN: WAUZZZFJ0T1081286 Mileage: 8359km-5194miles
CA-Sunroof -- Status: OK 0000
D8-LED HeadL. Pwr Left -- Status: OK 0000
D9-LED HeadL. Pwr Right -- Status: OK 0000
DE-Charger 1 for mobile dev -- Status: Malfunction 0010
8109-Close Rge Radar 1 -- Status: OK 0000
810A-Close Rge Radar 2 -- Status: OK 0000
810B-Close Rge Radar 3 -- Status: OK 0000
810C-Close Rge Radar 4 -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
813F-Main; cockpit system 1 sound -- Status: OK 0000
8153-Main; cockpit sys. 3 Android -- Status: OK 0000
815A-Multifunction Interior Camera -- Status: Malfunction 0010
81D0-Digit. Matrix Light -- Status: OK 0000
Address 01: Engine (J623-DNPB) Labels: None
Part No SW: 5QS 906 264 B HW: 06K 907 425 AA
Component: R4 2.0l TFS H80 0003
Dataset Number: 06Q909102BP 0007 CVN: 4006939503680900
Coding: 0A2540322576150B70080000001000000000000000000000
ASAM Dataset: EV_ECM20TFS0205QS906264B 001006
ROD: EV_ECM20TFS0205QS906264B_AU38P.rod
VCID: 56F57BB63883039AEDC-8002-R SFD+SFD2 [x]
VINID: 9D196AAAA59A024040201088184A92622E
Radiator shutter:
Subsystem 1 - Part No SW: 5QS 965 501 E HW: 5QS 965 501 E
Component: V544_SAB_XS_1 H03 0003
Serial number: 20260226060506061908
23079 - Control unit for information electronics 1
U1054 00 [00100000] - No Communication
Reset counter: 38
Mileage: 5765 km
Date: 2026.09.28
Time: 13:01:41
Engine speed: 1530.50 /min
Normed load value: 6.7 %
Coolant temperature: 38 C
Intake air temperature: 32 C
Voltage terminal 30: 11.406 V
LF_MVB_PDU_INTC_DIAG_8: 0
LF_MVB_PDU_INTC_DIAG_9: 0
LF_MVB_PDU_INTC_DIAG_10: 0
LF_MVB_PDU_INTC_DIAG_11: 0
LF_MVB_PDU_INTC_DIAG_13: 4
LF_MVB_BUS_INTC_DIAG: 256
43491 - Communication Authentication
U3035 00 [00100000] - Invalid Signal
[Communication Authentication Signal Invalid Data]
Reset counter: 14
Mileage: 5181 km
Date: 2026.09.21
Time: 12:49:03
Engine speed: 0.00 /min
Vehicle speed: 255 km/h
Coolant temperature: 89 C
Intake air temperature: 30 C
Ambient air pressure: 930 mbar
Voltage terminal 30: 12.402 V
Unlearning counter according OBD: 14
FAC_TPS_1_SAE: 16.8627454 %
FUP_H_SAE: 18910 kPa
MAP_MES_SAE: 93 kPa
Engine status: Stop
TAA: 15.000 C
T_AST_SAE: 9218 s
Oxygen sensor 1 bank 1: voltage raw value O2 signal: 1.914 V
47021 - Implausible Data Received from Control Module for Brake Booster
U04B5 00 [00100110] - -
[Brake electronics control module 2 Implausible signal]
Mileage: 3708 km
Date: 2026.09.09
Time: 09:20:03
Coolant temperature: 78 C
Intake air temperature: 61 C
Voltage terminal 30: 12.011 V
FUP_H_SAE: 16410 kPa
MAP_MES_SAE: 100 kPa
Engine status: Stop
TAA: 10.000 C
T_AST_SAE: 0 s
Oxygen sensor 1 bank 1: voltage raw value O2 signal: 1.997 V
Part No SW: 0GC 906 557 PK HW: 0GC 300 073 N
Component: GSG DQ381 H06 0860
CVN: EB92B0CB
ASAM Dataset: EV_TCMDQ381064 001012
ROD: EV_TCMDQ381064.rod
VCID: 15773CBAE505C882246-8040-R SFD [x]
Parking lock:
Subsystem 1 - Part No SW: 5QS 907 483 A HW: 5QS 907 483
Component: SB_Auto H03 0060
Serial number: 9922108000653012
MTF pump:
Subsystem 2 - Part No SW: 0GC 927 373 M HW: 0GC 927 373 M
Component: SMOP DQ381 H04 0001
Serial number: C7458810700008523210
Address 03: ABS Brakes (J104) Labels: 3WA-614-517-V1.clb
Part No SW: 3WA 614 517 AS HW: 3WA 614 517 D
Component: EBC470IESCH09 0391
Serial number: 0000000 Dataset Number: 83H909504AZ 0001 CVN: A50354
Coding: 2C885248A49A579E210599AC9EB7010405B39734B438
ASAM Dataset: EV_Brake1ZFESCEPBMQB48W 002059
ROD: EV_Brake1ZFESCEPBMQB48W_002.rod
VCID: 176B36B2FF09FA9236A-8042-R SFD+SFD2 [x]
82320 - Diagnostic Gateway Module
U0447 00 [00101000] - Implausible Signal
[MSG_MOTOR_55_TS_STATUS_MOMRAD_IST_QM_FEHLERFREI]
Mileage: 26 km
Date: 2026.05.22
Time: 18:49:11
70000 - No Communications with Parking Assist Control Module A
U0159 00 [00100000] - -
[MSG_PARKEN_01_TIMEOUT]
Reset counter: 29
Mileage: 7258 km
Date: 2026.10.07
Time: 07:43:29
16401 - Tire Pressure Warning
C102D 00 [01101100] - -
[RKA_DEM_MON_P_WARN]
Mileage: 2868 km
Date: 2026.08.23
Time: 18:52:56
590848 - Delay Function
C11EE 00 [00100000] - -
[VZM_INCONSISTENCY_PARKING_SYSTEMS]
Reset counter: 29
Mileage: 7258 km
Date: 2026.10.07
Time: 07:43:29
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 AD HW: 5WA 959 436 N
Component: Kessy IOBOX 122 0771
Serial number: --------------- Dataset Number: 8Y0909577D 0021
ASAM Dataset: EV_Kessy37w 005030
ROD: EV_Kessy37w_005_VW38.rod
VCID: 16753BB6F803C39A2DC-8042-R
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 3WA 907 007 F HW: 3WA 907 007
Component: Climatronic H01 5089
Serial number: 220112502301860 Dataset Number: 83H909862C 0046
Coding: 606000110011120010100010101111010000032100200000000000000000
ASAM Dataset: EV_ACClimaBHBE3ADV 002062
ROD: EV_ACClimaBHBE3ADV_002_VW41.rod
VCID: 48C9A5CEE237A56A6F0-801C-R SFD+SFD2 [x]
Interior temperature sensor:
Subsystem 1 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00003180326043503513
Air quality sensor:
Subsystem 2 - Part No SW: 5Q0 907 659 D HW: 5Q0 907 659 D
Component: G238 _AQS H02 0003
Serial number: 10000000000000656724
Subsystem 3 - Part No SW: 83H 919 158 HW: 83H 919 158
Component: E265 KPH B H23 0040
Serial number: G05S12.03.2601000597
524080 - Control Module for Emergency Call and Communications
U1421 00 [00100110] - No Communication
[Lost Communication With Telematic Control Module]
Fault Frequency: 8
Mileage: 1920 km
Date: 2026.06.10
Time: 22:25:25
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
B10F0 00 [01101000] - -
Reset counter: 38
Mileage: 8272 km
Date: 2026.10.21
Time: 11:51:04
Voltage terminal 30: 11.60 V
Compressor shut-off condition: Engine stop active in Start/Stop mode
524131 - Control Module for Emergency Call and Communications
U1421 00 [00100000] - No Communication
[Lost Communication With Telematic Control Module 4]
Fault Frequency: 9
Mileage: 1920 km
Date: 2026.06.10
Time: 22:25:25
524151 - Control Module for Emergency Call and Communications
[Lost Communication With Telematic Control Module DR 2]
Fault Frequency: 13
Mileage: 10 km
Date: 2026.05.20
Time: 11:57:52
524152 - Control Module for Emergency Call and Communications
[Lost Communication With Telematic Control Module DR 3]
Fault Frequency: 13
Mileage: 10 km
Date: 2026.05.20
Time: 11:57:52
524153 - Control Module for Emergency Call and Communications
[Lost Communication With Telematic Control Module DR 5]
Fault Frequency: 13
Mileage: 10 km
Date: 2026.05.20
Time: 11:57:52
