Change gearbox oil on 2017 manual 5 speed dfsd engine.
trebor
C?ID=531493
Hello. Im gathering tools and researching a procedure to change the gearbox oil.
The gearbox family is 0A4 mq250.
The oil is w75 /80 castrol transmax
There seems to be a procedure to remove the pivot pin/detent and lock out the selector to drain out the last 100ml or so of old gearbox oil.
Just wondered if anyone had changed the gearbox oil on a vw 2017 5 speed gearbox.
The did the same with the 020, causing numerous 5th gear failures after an oil change because the last 0.5 litre had to be added via the speedo drive plug and quite often, the drive gear fell off the cable and into the box.
lucasthompson
Disabled Bot
Birmingham, AL, USA
The fill-level detail is the part people underestimate on these 0A4/MQ250 cases. Since the fill plug sits low, treating it as the level check will leave you short, so it pays to confirm the specified fill volume and add through the correct upper point rather than going until it dribbles. The selector lockout and pivot pin step is only for getting the last bit out, so I'd weigh whether that's worth the risk on a regular service. Do you have a measured quantity for your exact code?
trebor
C?ID=531493
Well ive purchased 2 litres, ive not got an exact figure for quatity of oil.. Im not 100% sure which gearbox ive got if the casing has been used on early 2000 models. The service book give a gearbox PR code of RTH. Which should be 5speed manual, 0A4/MQ250. Im hoping its stamped on the gearbox somewhere when I check.
RGH0
Australia
C?ID=433612
https://www.myturbodiesel.com/d2/images/pdf/a5translevel.pdf?
I think this covers the basics.
They can't be refilled to the "fill plug", because it's too low... I can't believe VW ran that same case for decades, without moving the plug to the right place :confused: My 02S 6 speed is the same.
I believe the fill plug was designed for vertical installations. If the engine is tilted back as for some 4 cylinder TDI the fill plug is to low. If the engine is tilted forward as in my R32 then the fill plug is to high. Just my understanding
NZDubNurd
New Zealand
C?ID=230482
Your R32 should be 02M (I have one in my R32 Touran too) and they had the bellhousing angled differently for 4 and 6 cylinders, but the trans was "level" as such. They did those ones properly.
It'd be better if they'd not even cast the fill plug hole and left it off entirely - less machining of a hole that doesn't even work :D
