- Apr 19, 2021
- 4
- 0
- Chicago, USA
- C?ID=316240
Hello all,
Looking forward to your advice, this is the third VW I have owned and Ross-Tech has been a critical tool to keep these cars on the road. This is a great community :-).
I am working with a 2013 VW Eos 2.0t. The autoscan is below:
Short history of my journey on this one...
- The car has an aftermarket stereo that was installed a year ago, fyi.
- I had a code for the knock sensor, the knock sensor was replaced, and then I started getting p2015 codes with MIL.
- I had a shop replace the intake manifold with a OE part, the problem wasn't resolved.
- The shop replaced the manifold with an OEM part and "cleaned" the vacuum line.
- They had issues running the adaption, when it finally passed, the car still raises P2015 after a few miles.
- I didn't get back to his for a few weeks, the car has been running well although the MIL is annoying.
Today, I am also unable to get the adaption to pass. I logged Group 142 from a road test. The actual value takes a couple of seconds to move when the specified value is 100. What is the "normal" response time? Is this likely a vacuum issue, an electrical issue, or something else?
After the road test, I have a P2004 and P2015.
Thanks for your advice!
CB
Friday,30,October,2026,20:01:18:15565
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.5
VIN: WVWBW8AH6DV001205 License Plate:
Mileage: 147410km-91596mi Repair Order:
Chassis Type: AH-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 26 2E 42 44 46 52 56 62 63
65 72 77
VIN: WVWBW8AH6DV001205 Mileage: 147410km-91596miles
2E-Media Player 3 -- Status: Cannot be reached 1100
63-Entry Assist,D -- Status: OK 0000
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 06J 906 027 FG HW: 06J 907 309 B
Component: MED17.5.2 TFSI 2 06 3954
Revision: PAH04--- Serial number:
Coding: 041C01081C070160
Shop #: WSC 00000 067 57207
VCID: 75B0036E69C2FA72C46-8020
VINID: 9E69D29C845819498000108014350ECB27
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - Intermittent - MIL ON
Fault Status: 10100000
Fault Frequency: 88
Mileage: 3684408 km
Date: 2014.00.28
Time: 03:33:48
RPM: 2525 /min
Load: 50.2 %
Speed: 56.0 km/h
Temperature: 96.0 C
Temperature: 30.0 C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
Mileage: 2960685 km
Date: 2011.04.22
Time: 18:53:26
RPM: 2061 /min
Load: 67.0 %
Speed: 45.0 km/h
Temperature: 32.0 C
Temperature: 9.0 C
Voltage: 14.351 V
Part No SW: 02E 300 058 N HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3515
Revision: 05551213 Serial number: 00001205221079
Shop #: WSC 00020 000 90108
VCID: 2510132E99E2CAF2B46-8070
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V3.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: 514B600A492200FB8A0D06E4921E0041310000
Shop #: WSC 00020 790 00000
VCID: 7DA01B4E5DF2A2328C6-8028
Part No SW: 3AA 907 044 AN HW: 3AA 907 044 AN
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0810001002
Shop #: WSC 00020 999 00000
VCID: 7CA6164A4668AB3ABB8-8028
Part No SW: 5K0 937 087 AA HW: 5K0 937 087 AA
Component: BCM PQ35 H+ 121 0168
Revision: BL121001
Coding: 6F000A3B82232A64808800C1700085444801600641000D60648060000040
VCID: 74B63E6A6EB8E37AF38-8020
Subsystem 1 - Part No: 1Q1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 16051 26 0512
Coding: 009795
Address 15: Airbags Labels: 1Q0-959-655.clb
Part No SW: 1Q0 959 655 B HW: 1Q0 959 655 B
Component: 24 Airbag VW8C 0210
Revision: 92011021 Serial number: 003G20016YEX
Coding: 0012852
VCID: 3B24D5560F666C02F22-806E
Subsystem 1 - Part No: 1Q0 959 339 C
Component: BF-Gewichtsens. 007 0001
Subsystem 2 - Serial number: 005SF
Subsystem 3 - Serial number: 0001.01.000000700000000000 63
Subsystem 4 - Serial number: 000000 6332SRB40871CEA29 63
Subsystem 5 - Serial number: 1CEA29 6342SRB407A905AB8 63
Subsystem 6 - Serial number: 905AB8 6372URB405D1F2A4B 63
Subsystem 7 - Serial number: 1F2A4B 6382URB405D1EC29I
Subsystem 8 - Serial number: 1EC29I
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20120612101124
Coding: 088A140000
ROD: EV_SMLSNGVOLWSXS.rod
VCID: 76B204627844F16ACDC-8022
Component: E221__MFL-TK6 H07 0022
Coding: E20000
Part No SW: 1Q0 920 976 B HW: 1Q0 920 976 B
Component: KOMBI H05 0705
Coding: 271F01
VCID: 3530C36E25C2BA72046-8060
Part No SW: 7N0 907 530 R HW: 7N0 907 530 H
Component: J533 Gateway H42 1632
Revision: H42 Serial number: 070612F1002718
Coding: 355000
VCID: 3FDCA146177E7022DEA-806A
01304 - Radio
Fault Frequency: 74
Reset counter: 84
Mileage: 146751 km
Date: 2021.03.22.
Time: 03:26:58
Reset counter: 8
Mileage: 146751 km
Date: 2021.03.22.
Time: 03:24:01
03272 - Control Module for Audio Interface
Reset counter: 8
Mileage: 146751 km
Date: 2021.03.22.
Time: 03:24:01
Part No SW: 1Q0 919 965 A HW: 1Q0 919 965 A
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1350208RLRNW04
Coding: 0000002
VCID: 3A2AD052005C550AE94-806E
Component: IMMO H05 0705
VCID: 6A8A20123CFC258A594-803E
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 F HW: 1Q0 959 255 F
Component: Verdecksteuergeraet 0854
Revision: 0033100Q Serial number: 121360394
Coding: 0655364
Address 2E: Media Player 3
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2151
Coding: 0017591
VCID: 3928CF5E055A5E12E0E-806C
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
VCID: 372CC966334E486216A-8062
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Coding: 0017590
Address 56: Radio
Part No SW: 1Q0 959 811 B HW: 1Q0 959 811 B
Component: Tuer-SG 004 0605
Coding: 0000144
Shop #: WSC 00020 790 1012544
VCID: 3530C36E2942BA72046-8060
Address 63: Entry Assist,D Labels: 1Q0-959-790.clb
Part No SW: 1Q0 959 790 A HW: 1Q0 959 790 A
Component: J572 EASYENTRY FS 0603
Revision: 00H04000 Serial number: 5DS008646-01--
Coding: 0000002
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 121 0821
Coding: 018705
02904 - Hard Warning 3
Mileage: 147054 km
Date: 2021.03.22.
Time: 23:29:29
Text: 3458521557
Pressure: 1.80 bar
Pressure: 2.30 bar
Temperature: 4.0 C
Text: 80
Part No SW: 1Q0 959 812 B HW: 1Q0 959 812 B
Coding: 0000144
VCID: 3632C4623444B16A0DC-8062
Address 77: Telephone
End----------(Elapsed Time: 01:17, VBatt start/end: 12.1V/12.1V)-----------
------------------------------6 Faults Found-------------------------------
Friday,30,October,2026,20:14:56:15565
VIN: WVWBW8AH6DV001205 License Plate: POST DRVE
Address 01: Engine Labels: 06J-907-115-CBF.CLB
Control Module Part Number: 06J 906 027 FG HW: 06J 907 309 B
Component and/or Version: MED17.5.2 TFSI 2 06 3954
Software Coding: 041C01081C070160
Work Shop Code: WSC 00000 067 57207
008196 - Intake Manifold Flap; Bank 1
P2004 - 000 - Stuck Open - Intermittent
RPM: 780 /min
Load: 18.4 %
Temperature: 46.0 C
Temperature: 18.0 C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
Mileage: 3487029 km
Date: 2013.04.26
Time: 19:21:42
RPM: 3695 /min
Load: 78.4 %
Speed: 53.0 km/h
Temperature: 66.0 C
Temperature: 18.0 C
Voltage: 14.224 V
Readiness: 0110 0101
CB
