IBIZA 1.2TDI SENSOR REFERENCE AND CAM SENSOR FAULTS
PantechAutoTechnicians
Guildford, UK
C?ID=221280
Hi all,
Having headaches, with this Ibiza 1.2 TDi CFWA. It has P0641 Sensor reference voltage 'A'-circuit open and P0341 Cam position sensor range/performance faults. The car has had a second hand ECU/Instrument panel and BCM replaced, cam sensor has been replaced and I have got the harness open from the back of the 60 pin ECU plug to the sensor plugs. Can't find anything wrong for looking. No open circuit wires to the cam sensor, no high resistances or obvious wire damage. If petrol was cheaper, I might consider a gallon and a match. Have any of you guys got any suggestions please?
Friday,30,October,2026,11:14:30:61459
VCDS Version: 25.3.3.0  HEX-NET2 CB: 0.4671.5
Data version: 20260227 DS365.0
Dealer/Shop Name: Pantech
VIN: VSSZZZ6JZBR126855   License Plate: SA61YJK
Mileage: 305600km-189891mi   Repair Order:
Chassis Type: 6J-SE25 (6R0)
Scan: 01 03 08 09 15 17 19 25 44 4B 56 61
VIN: VSSZZZ6JZBR126855   Mileage: 305600km-189891miles
Address 01: Engine (J000-CFWA)       Labels:. 03P-907-425-V1.clb
   Part No SW: 03P 906 021 AA    HW: 03P 906 021 BC
   Component: R3 1.2l TDI   H06 9978
   Revision: 12005001    Serial number:                Dataset Number: 4F0909444AA D001 CVN: 6EB85A39
   Coding: 00114014032501080000
   Shop #: WSC 48572 002 104857
   ASAM Dataset: EV_ECM12TDI03103P906021AA 001018
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 6780D324CFE2D5022F1-8032
   VINID: 9A38EAAAA19AA928810862051477B0E187
13181 - Camshaft Position Sensor (G40)
          P0341 00 [11101000] - Implausible Signal
                    Mileage: 305609 km
                    Date: 2026.10.30.
                    Time: 00:31:09
                    Engine speed: 831.00 /min
                    Normed load value: 17.6 %
                    Coolant temperature: 52 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 14.664 V
                    Unlearning counter according OBD: 0
                    Camshaft RPM: 832 /min
                    P_L_Aps_camless_active: OFF
                    Engine start: start synchronization: 00
                    P_L_Aps_crankless_active: OFF
                    P_L_Aps_injection_speed-Engine_rotational_speed: 830.686 /min
                    P_L_Aps_no_sync_speed-Engine_rotational_speed: 813.963 /min
                    P_L_Aps_sync_cnt_total-Value: 3
                    P_L_Aps_sync_lost: OFF
                    P_L_Aps_sync_lost_origin-Sync_lost_status: P_L_APS_SYNC_LOST_CAM_EDGE
                    P_L_Aps_sync_tasks_enabled: On
                    P_L_Aps_synchronised: On
                    P_L_Aps_synchronised_origin-Sync_origin: P_L_APS_SYNC_GAP_CAM
                    P_L_Aps_tdc_to_tooth_1_angle-Engine_timing_value: 353.991 °
                    P_L_Aps_timeout_detected: OFF
                    System status for the start/stop function master: 62
13180 - Camshaft Position Sensor (G40)
                    Mileage: 305609 km
                    Date: 2026.10.30.
                    Time: 00:31:09
                    Engine speed: 792.25 /min
                    Normed load value: 18.8 %
                    Voltage terminal 30: 14.695 V
                    P_L_Aps_injection_speed-Engine_rotational_speed: 794.92 /min
                    P_L_Aps_no_sync_speed-Engine_rotational_speed: 844.969 /min
16244 - Sensor Reference Voltage A
          P0641 00 [10101000] - Open Circuit
                    Mileage: 305609 km
                    Date: 2026.10.30.
                    Time: 00:31:10
                    Engine speed: 1020.50 /min
                    Voltage terminal 30: 14.585 V
                    Exhaust gas temperature sensor 1: 108 °C
                    Sensor for engine block temperature: raw value: 52 °C
                    Exhaust gas temperature sensor 3: 84 °C
                    Exhaust gas temperature sensor 4: 60 °C
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 130224DB816F00B8C82D24E781D600921300
   Shop #: WSC 04941 123 12345
   VCID: 0740F3A4EF623502CF1-8052
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6J0 820 043 C    HW: 6J0 820 043 C
   Component: Climatronic   H07 0606
   Revision: S0000000
   VCID: 241A84287ED4FE1ACA3-8070
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 131
                    Mileage: 146544 km
                    Date: 2021.03.22.
                    Time: 05:48:18
01272 - Positioning Motor for Central Flap (V70)
                    Reset counter: 131
                    Mileage: 146605 km
                    Date: 2021.03.22.
                    Time: 05:44:50
                    Reset counter: 171
                    Mileage: 147806 km
                    Date: 2021.03.22.
                    Time: 14:37:38
   Part No SW: 6R0 937 088 D    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H46 0322
   Revision: BU046001    Serial number: 0379 014110743
   Coding: 24882BE888612500933005F07ECB9EC8CF80600F7E8C2009200000000000
   Shop #: WSC 64564 324 38760
   VCID: 3FD02B44F772BDC2B71-806A
   Component: RLS 220311 05  54  0403
   Coding: 02242D
   Subsystem 2 - Part No SW: 6R0 959 802 N    HW: 6R0 959 802 N  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 3110
   Coding: 430000
   Subsystem 3 - Part No SW: 6R0 959 801 Q    HW: 6R0 959 801 Q  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 3110
   Coding: 420000
   Subsystem 4 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3110
   Subsystem 7 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3110
                    Fault Status: 00100001
                    Reset counter: 171
                    Mileage: 305609 km
                    Date: 2021.03.22.
                    Time: 00:30:18
                    Reset counter: 131
                    Mileage: 305609 km
                    Date: 2021.03.22.
                    Time: 19:47:20
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagA0D H09 0020
   Revision: --------    Serial number: 003GX00HU5P0 Dataset Number: s00303416J0 0009
   Coding: 003044
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4AC60A90BC30086A10F-801E
   Serial number: 3495RRB405P0H4DQ7GUI
   Serial number: 3505RRB40650ESC6E050
   Part No SW: 6J0 920 802 J    HW: 6J0 920 802 J
   Component: KOMBI         H05 0404
   Coding: 410A00
   Shop #: WSC 131071 102 209715
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 2F307B0427924D42271-807A
Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H38 0025
   Revision:   H38       Serial number: 050311F1003321
   Coding: 2502C3
   VCID: 33387774CB3A69A2439-8066
   Component: IMMO          H05 0404
   VCID: 6A86AA10DCF0E86A30F-803E
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 11240
   Shop #: WSC 00788
   VCID: 6FB0BB04EED20D42671-803A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Coding: 0000001
   Shop #: WSC 77005 000 00000
   VCID: 70B2B878F6AC12BA7EB-8024
Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
   Part No SW: 6J2 035 153 G    HW: 6J2 035 153 G
   Component: Radio         H14 0203
   Revision: R0000000    Serial number: SEZAZ2L1945065
   Coding: 0503040002
   Shop #: WSC 04941 000 00000
   VCID: 2A066A101CF0286AF0F-807E
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0025
   Coding: 0303185A
   VCID: 74BAB4688EB42E9A9A3-8020
   Subsystem 1 - Part No SW: 6R0 915 181 B    HW: 6R0 915 181
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370710529
02252 - Generator
                    Fault Status: 00100011
                    Reset counter: 171
                    Mileage: 305609 km
                    Date: 2021.03.22.
                    Time: 01:51:28
02256 - Quiescent Current
                    Fault Status: 00110001
                    Reset counter: 136
                    Date: 2021.03.22.
                    Time: 15:44:41
End----------(Elapsed Time: 01:34, VBatt start/end: 12.4V/12.2V)-----------
------------------------------10 Faults Found------------------------------
So you fitted a new genuine sensor, 03L 957 147 A?
Guildford, UK
C?ID=221280
Hi Crasher, right now I'm wishing I had. Just gone through everything again, to find the aftermaket sensor is no bloody good. Will sort that out, and update afterwards. Cheers.
Sensor reference voltage is a 5v supply from the ECU to the inlet manifold flap, EGR pot, camshaft sensor, throttle valve flap pot, charge pressure sensor pot and the fuel pressure sensor so disconnect the others in turn to see if one is pulling the reference voltage down to earth.
Ohh, OK, try that first.
TTT
C?ID=547002
But the error is open circuit, not short to GND.
Did a proper sensor fix it?
Guildford, UK
C?ID=221280
Right, I have now fitted the genuine sensor 03L957147A. Starts and runs better, still getting the P0641 sensor reference voltage OC fault, along with inlet manifold runner fault P2017. I'm wondering if there's a splice in the wiring somewhere I haven't found yet? The 5v wire from pin 10 at the ecu is Yellow/Blue, but at these two components it is Blue.
Yes, it is called D141
G40
Hall sender
G212
Exhaust gas recirculation potentiometer
G336
Intake manifold flap potentiometer
J623
Engine control unit
N18
Exhaust gas recirculation valve
T60
60-pin connector
V157
Intake manifold flap motor
328
Earth connection 2 (sender earth), in engine compartment wiring harness
D141
Connection (5V) in engine prewiring harness
G69
Throttle valve potentiometer
G247
Fuel pressure sender
G581
Position sender for charge pressure positioner
J338
Throttle valve module
J623
Engine control unit
T60
60-pin connector
V178
Coolant circulation pump 2
328
Guildford, UK
C?ID=221280
Aaah, am I right in thinking that's the one just a few inches down the harness, from the ecu plug? If so, that seems all good.
