VCDS with HEX+CAN on Win 11 AMR 64 laptop
ianrmckee96
New Zealand
C?ID=262882 (NRRT)
Hello - just new to the forum - trying to read codes on Audi S8 D4..... Had an old laptop which worked great but this has died, and had to buy new laptop which is Lenovo device running ARM Win 11 64 bit windows. Have tried many times to install the latest version of VCDS, but it always complains that drivers don't install. I've read many threads, and turned off the secure boot, and also downloaded and have available the Ross-tech USB driver package, and also the FTDI drivers. But the VCDS installation routine does NOT allow me to tick the box for installing legacy drivers. No amount of clicking on it produces the tick like the other options. And following other threads and going to device manager and trying to install drivers produces no results. It has been several days and tried every (but obviously not all) tricks. HELP !
That's because there is no ARM version of those drivers.
ianrmckee96
New Zealand
C?ID=262882 (NRRT)
Ok - thanks for that. Any chance an ARM driver may be available one day ? or did I waste my money on this laptop ?
Eric
HC800000
Those are excellent laptops for VCDS ;)
ianrmckee96
New Zealand
C?ID=262882 (NRRT)
Do you have a secret stash of drivers then ? Seriously - I would love to find a way of making this work - any clues ?
Westbury, UK
I think you'll need to take advantage of the upgrade program to a HEX-V2?
Eric
HC800000
Right, the newer interfaces are HID and do not need drivers.
ianrmckee96
New Zealand
C?ID=262882 (NRRT)
Yes - would love a new cable/interface, but having to ship the old one from New Zealand, and then wait for its replacement is unattractive.
Westbury, UK
I suspect your options are either an interface upgrade or a different PC which is Intel based not ARM - your choice.
golfi_vend
Tartu, Estonia
C?ID=195131
Has anyone tried the workaround with drivers and therfor for ARM drivers aswell?
Not supported by RossTech of course and under own responsibility.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The standard FTDI ARM64 drivers will recognize the old generation hardware (HEX+CAN, HEX/KII, KEY and Micro-CAN), but this isn't enough as the ARM64 version of VCDS simply won't recognize the hardware (it simply doesn't support it). The interfaces do get recognized with the x86 version installed and functionality appears to be all good (need to re-run the installer and force that 32 bit/x86 EXE to be installed AND make manual compatibility adjustments like forcing secure emulation).
There is absolutely no support from us for this setup, if it works, it works, but just because it seems to work, doesn't mean it's truly compatible for all scenarios. There are several possible caveats here which might cause troubles in communication. So use at your own risk.
