2015 Octavia - New to me car with dozens of faults
jaychen
Brisbane, Australia
Hi guys,
I recently purchased a 2015 MK3 Octavia. Almost all of these codes popped up at the same time, except for the airbag sensor code, which occurred randomly after the car was left to sit for a few weeks when the battery went flat.
I'm slowly working my way through fixing all the problems but need some guidance on where to start. The airbag codes popped up randomly and I have checked the airbag module (being that both a left and right airbag sensor fault occurred which i thought was strange) under the heater core, it appears fine with no signs of coolant leaking onto/into it.
Any help is greatly appreciated. Waiting for my verification process to be approved! Using a genuine HEX+CAN i bought many, many years ago!
Friday,30,October,2026,07:24:17:38833
VCDS Version: 25.3.1.2
Data version: 20250604 DS365.0
VIN: TMBKK9NE3F0222553   License Plate: SKODA
Mileage: 238051km-147918mi   Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 42 44 47 52 55 5F
          69 A9
VIN: TMBKK9NE3F0222553   Mileage: 238051km-147918miles
69-Trailer -- Status: Not registered 0001
Address 01: Engine (J623-CUPA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EM    HW: 04L 907 309 D
   Component: R4 2,0L EDC   X22 8151
   Revision: 83X22---    CVN: 33F84959
   Coding: 111D0032046501081000
   Shop #: WSC 73430 031 00120
   ASAM Dataset: EV_ECM20TDI01104L906021EM 002009
   ROD: EV_ECM20TDI01104L906021EM.rod
   VCID: 74ED29BEDF2C9E3BDD-8020
   VINID: 91D49B6C97950D60020821450C759696CF
17158 - Databus
          U1123 00 [00101100] - Received Error Message
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
                    Engine speed: 1558.00 /min
                    Normed load value: 76.1 %
                    Vehicle speed: 13 km/h
                    Coolant temperature: 43 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 14.040 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Acceleration: 1.100 m/s²
          U0428 00 [00100000] - -
Readiness: 0 0 0 0 X
   Part No SW: 0D9 300 041 Q    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4504
   Revision: 05853104    Serial number: TFK01503160330 CVN: 00008071
   Shop #: WSC 73430 031 00063
   ROD: EV_TCMDQ250021.rod
   VCID: 264903F65970BCAB93-8072
   Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
   Component: ESC           H42 0711
   Revision: 00000000    Serial number: 60835000001205
   Coding: 1C0793915422096E007C060541C62938C92A9000608294F416615032C009
   VCID: 4993A84AE82EB3D35E-801C
0073 - Rear Left Wheel Speed Sensor
          C101C 29 [00001000] - Signal Implausible
                    Reset counter: 47
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
0075 - Rear Left Wheel Speed Sensor
          C101C 07 [00001000] - Mechanical Failure
                    Reset counter: 47
                    Mileage: 238027 km
                    Date: 2026.10.29
                    Time: 18:19:21
16401 - Tire Pressure Warning
          C102D 00 [00001000] - -
                    Reset counter: 194
                    Date: 2026.05.28
                    Time: 13:29:43
16417 - Display for Tire Pressure Monitoring
          C1146 02 [10001001] - Signal Failure
                    Reset counter: 47
                    Mileage: 237971 km
                    Date: 2026.10.29
                    Time: 09:52:53
   Revision: 00021000    Serial number: 0363480105 Dataset Number: 5E0IJ1t____ 0001
   Coding: 030C0C
   Shop #: WSC 73430 790 00120
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3A71C786BDC8284BC7-806E
   Part No SW: 5E0 907 044 L    HW: 5E0 907 044 L
   Component: Climatronic   H03 0907
   Revision: 00001K06    Dataset Number: 0000
   Coding: 02110104000100011005000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   VCID: 2E59FBD67180F4EB6B-807A
   Air quality sensor:
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011508500073 Dataset Number: 5E0063t____ 0067
   Coding: 0F031A56C24722FB07A04082B10C07280800000000000000000000000000
   Shop #: WSC 13671 002 1048576
   ROD: EV_BCMBOSCH_013.rod
   VCID: 0005756E9B94B29BC9-8054
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150314  041 0570
   Serial number:         150319072442
   Coding: 065DDD
   Component: RLHS  037 0059
   Serial number: S3Y15M04D01H22M36S12
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1502804YU
   Serial number: 00000000000031673151
5898 - Bulb for Left Side Turn Signal
          B12D0 15 [00001001] - Open or Short to Plus
                    Fault Frequency: 28
                    Reset counter: 46
                    Mileage: 235028 km
                    Date: 2026.06.14
                    Time: 10:35:43
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 10.9 V
                    Outside temperature: 17.5 °C
6410 - Bulb for Right Side Turn Signal
          B12D1 15 [00001001] - Open or Short to Plus
                    Fault Frequency: 40
                    Reset counter: 46
                    Mileage: 235028 km
                    Date: 2026.06.14
                    Time: 10:35:42
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 10.9 V
18698 - Left LED Module for DRL and Parking Lights
          B12EC F2 [00001001] - Voltage Supply Open or Short to Plus
                    Reset counter: 30
                    Mileage: 237168 km
                    Date: 2026.10.10
                    Time: 12:36:40
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 12.0 V
                    Outside temperature: 29.0 °C
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39431507800492 Dataset Number: 5E0039t____ 0001
   Coding: 0131161151
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 4281BF66D518608B9F-8016
13637427 - Databus
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
13637409 - Databus
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
13637422 - Databus
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
13637426 - Databus
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
13679388 - Databus
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 05031503211448 Dataset Number: 5e0114t____ 0006
   Coding: 00081200FE0739
   VCID: 3875DD8E83C43A5B31-806C
9 Faults Found:
1067 - Brake Temperature
          C10DF 00 [00001000] - -
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
                    Control Module temperature: 38 °C
                    Voltage terminal 15: 12.8 V
                    Vehicle speed: 26.52 m/s
                    Acceleration: -0.34 m/s²
1056 - Databus
                    Reset counter: 89
                    Mileage: 237973 km
                    Date: 2026.10.29
                    Time: 09:54:45
                    Control Module temperature: 37 °C
                    Vehicle speed: 7.03 m/s
                    Acceleration: 1.58 m/s²
1058 - Databus
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
                    Voltage terminal 15: 12.9 V
                    Vehicle speed: 26.53 m/s
                    Acceleration: -0.28 m/s²
1059 - Databus
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
                    Vehicle speed: 26.54 m/s
                    Acceleration: -0.24 m/s²
1540 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [00001001] - -
                    Reset counter: 155
                    Mileage: 235026 km
                    Date: 2026.05.28
                    Time: 14:53:32
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 14.5 V
                    Vehicle speed: 14.64 m/s
                    Acceleration: -0.17 m/s²
1043 - Automatic Distance Control
          B10E7 F0 [00001000] - Disconnected
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
                    Vehicle speed: 26.50 m/s
                    Acceleration: -0.38 m/s²
1083 - Databus
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
                    Vehicle speed: 26.58 m/s
1118 - Databus
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
1081 - Databus
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
                    Vehicle speed: 26.56 m/s
   Part No SW: 3Q0 959 655 AA    HW: 3Q0 959 655 AA
   Component: Airbag VW20   012 0200
   Revision: --------    Serial number: 003NYP4AAQLR Dataset Number: 5E0003t____ 0055
   Coding: 98FCC000000000005C000000008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7DFB0C9AEC66DF73A2-8028
   Left seat belt tensioner:
   Serial number: 34169595B20031571279
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169594B23031540017
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: -----------
   Component: SideSensor_Df  --- ----
   Subsystem 4 - Part No SW: -----------    HW: -----------
   Component: SideSensor_Pf  --- ----
   Subsystem 5 - Part No SW: -----------    HW: 454 801 703 15
   Serial number: 3516R3F8728060000005
   Subsystem 6 - Part No SW: -----------    HW: 454 802 203 15
   Serial number: 3526R8CF36706000000E
   Subsystem 7 - Part No SW: -----------    HW: 454 802 502 15
   Serial number: 3556VBAB5CD05000000V
1053191 - Databus
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
9443093 - Driver's Side Airbag Crash Sensor
          B1017 15 [10001001] - Open or Short to Plus
                    Mileage: 235029 km
                    Date: 2026.08.10
                    Time: 12:09:18
9451029 - Crash sensor side airbag; passenger side
          B1036 15 [10001001] - Open or Short to Plus
                    Mileage: 235029 km
                    Date: 2026.08.10
                    Time: 12:09:19
          U1101 00 [00001000] - Active
                    Reset counter: 58
                    Mileage: 237355 km
                    Date: 2026.10.15
                    Time: 13:45:53
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 EJ    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 25031508490700
   Coding: 6C10
   ROD: EV_SMLSKLOMQB_017.rod
   VCID: 02017F669598A08BDF-8056
No ASAM data for: "EV_SMLSKLOMQB" (SK37)
   Part No SW: 5E0 920 757     HW: 5E0 920 757
   Component: KOMBI         310 4311
   Coding: 27A509182D90000801886A011000000000000000
   VCID: 68D54DCE93E46ADB61-803C
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0003308609 Dataset Number: 5E0067t____ 0023
   Coding: 030100340F087300EF00027E1C0F00010001050000000000000000000000
   GVL: 01543C1000000600401C90000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72E12FA6A538900BCF-8026
   Generator:
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H05 0130
   Serial number: 000000000A1800090315
   Subsystem 3 - Part No SW: 5Q0 915 181 F    HW: 5Q0 915 181 F
   Component: J367-BDM  H08 0223
   Serial number: 62068I50224291598589
66304 - Databus
          U1124 00 [00001001] - Additional Installations Detected
                    Reset counter: 49
                    Mileage: 235018 km
                    Date: 2026.05.27
                    Time: 17:40:52
                    Terminal 30 power supply: 14.4 V
                    Terminal 15: On
                    Reset counter: 58
                    Mileage: 237355 km
                    Date: 2026.10.15
                    Time: 13:45:54
                    Terminal 30 power supply: 14.2 V
                    Terminal 15: On
   Revision: 00000000    Serial number: 15000064411002
   Coding: 5D00000000000000
   VCID: 346DE9BE9FACDE3B1D-8060
13637378 - Databus
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: E0 01
                    WFS State: 1F 06
                    Vehicle speed: 92.57 km/h
                    Voltage: 71
                    AD-Value H-bridge: 37
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006OCD16461
   Coding: 001400000000010001A081808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_001.rod
   VCID: 3B7FC282B2F21143DC-806E
   Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
   Component: TSG FS        009 0015
   Serial number: 0000143561221  Dataset Number: 5E0222t____ 0014
   Coding: 001D0020DE01048000001100
   VCID: 458BA47AC43657B3BA-8010
   Serial number: 00000000000005681809
   Coding: 1D0200
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Dataset Number: 5E0074t____ 0206
   Coding: 8303
   VCID: 3777DEB28EDA352338-8062
20228 - Databus
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 13.25 V
                    Temperature: 60.0 °C
                    KFC: 4F
                    KFA: 00 04
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 13.47 V
                    uAdSensI_SwitchedKl30_xdu16: 13.49 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
19716 - Databus
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
                    Motor status: 02
                    KFC: 4D
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 13.61 V
                    uAdSensI_SwitchedKl30_xdu16: 13.61 V
   Part No SW: 8V0 035 223     HW: 8V0 035 223
   Component: MIBAMP1ALPINE H11 0300
   Serial number: SKZ8Z1F76019R9T Dataset Number: 5E0050t____ 0009
   Coding: 03730200AA002AAA00
   ASAM Dataset: EV_AMPMst16C2ALPI 004016
   ROD: EV_AMPMst16C2ALPI_SK37.rod
   VCID: 6DDB3CDABC064FF312-8038
   Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0015
   Serial number: 0000142607863  Dataset Number: 5E0157t____ 0014
   VCID: 448DB97ECF0C6EBBAD-8010
   Serial number: 00000000000005673232
   Coding: 050200
   Revision: --------    Serial number: -------------- Dataset Number: 5E0036t____ 0009
   Coding: 03DE00003F010000
   Shop #: WSC 73430 790 00063
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 4085B56EDB14729B89-8014
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
13705985 - Databus
                    Reset counter: 89
                    Mileage: 237970 km
                    Date: 2026.10.29
                    Time: 09:52:43
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-HGH1.clb
   Part No SW: 5E0 035 045 D    HW: 5E0 035 045 C
   Component: MU-H-N-RW     H44 0371
   Serial number: A314C0FB001718 Dataset Number: 5E0CV1t____ 0049
   Coding: 037352080000000011510002001100002F0001F601000100F6
   ASAM Dataset: EV_MUHig6C3HBAS 001041
   ROD: EV_MUHig6C3HBAS_VW37.rod
   VCID: 1F471612062A6D63D0-804A
   Subsystem 1 - Part No SW: 5E0 919 606     HW: 5E0 919 606
   Component: ABT_High  H61 0031
   Serial number: SKZ8Z9RW800568
   Subsystem 2 - Part No SW: V03 959 801 EN    HW: -----------
   Component: ROW 2015  --- 0039
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 8C001001    Serial number: 0351432673
   Coding: 0100000202000000
   Shop #: WSC 01286 386 08256
   VCID: 3973D88AB8CE2353CE-806C
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 150217201932
   VCID: 69D348CA88EE53D37E-803C
End-------------------------(Elapsed Time: 06:02)--------------------------
------------------------------33 Faults Found------------------------------
          69 A9
   Coding: 030C0C
   Air quality sensor:
   Coding: 065DDD
   Coding: 00885D
                    Reset counter: 49
                    Mileage: 238051 km
                    Date: 2026.10.30
                    Time: 07:30:40
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.0 V
                    Outside temperature: 26.0 °C
   Coding: 0131161151
                    Reset counter: 49
                    Mileage: 238051 km
                    Date: 2026.10.30
                    Time: 07:30:40
                    Control Module temperature: 41 °C
                    Voltage terminal 15: 11.9 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
   Coding: 333135
   Coding: 333135
                    Mileage: 238051 km
                    Date: 2026.10.30
                    Time: 07:30:42
                    Mileage: 238051 km
                    Date: 2026.10.30
                    Time: 07:30:42
   Coding: 6C10
   Generator:
66304 - Databus
                    Reset counter: 49
                    Mileage: 238051 km
                    Date: 2026.10.30
                    Time: 07:30:41
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
   Coding: 1D0200
   Coding: 8303
   Coding: 050200
   Coding: 3E0000
   Coding: 3E0000
End-------------------------(Elapsed Time: 05:32)--------------------------
------------------------------5 Faults Found-------------------------------
