Continuous disconnections from 01 Engine and 17 Instrument controllers on 4th series Golf, Passat, Bora, etc. models
Zagor
Italy
C?ID=96696
Hello everyone. The cause of this problem has probably already been explained in other threads, but I haven't been able to find anything specific. Can anyone explain why, once connected to the instrument panel (and also to the ECU) of, for example, a Golf 4, there are constant and annoying disconnections? Windows Seven 64 bit operating system. Thanks.
What interface? HEX-NET? If so, USB or WiFi?
Only on 01 and 17? How about other modules in that car? What about other cars?
Zagor
Italy
C?ID=96696
My interface is a HEX-NET which I always use in USB mode. The 4 series controllers I diagnose most often are the 01 and 17, but I haven't noticed the problem with the other controllers in this series. I never have this problem with the models with a CAN bus connection.
On Mk.4 cars, the diagnostic connection to 01-Engine always passes though the instrument cluster. This means a dodgy instrument cluster can cause communications problems with both 01 and 17.
So please be more scientific with your report and let us know if this problem is limited to 01 and 17, or if it happens with other control modules in these cars too.
Zagor
Italy
C?ID=96696
It only happens with the 01 and 17 modules, but when I work on Golf, Bora and Passat 4th series on these controllers it always happens. Maybe it's a baud rate issue?
