2015 Golf SportWagen TDI AWD Need ABS coding
HohlfeldAuto
Wisconsin, USA
C?ID=53883
Retrofitted AWD to a 15 Golf TDI SportWagen. Getting errors saying the wrong rear abs sensors are installed and that the ABS is incorrectly coded. Looking for help to correct the coding for this module.
I should add that the rear AWD suspension subframe and brakes and front brakes are all from a 2019 Golf Alltrack. A VCDS scan from this car is available if needed (will have to find it on an old computer).
Thanks you
Wednesday,28,October,2026,23:12:49:55529
VCDS Version: 26.9.0.3 (x64)  HEX-NET CB: 0.4713.4
VIN: 3VWFA7AU9FM512702   License Plate:
Mileage: 147878mi   Repair Order: AWD Diesel
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 22 2B 42 44 52 5F 75
VIN: 3VWFA7AU9FM512702   Mileage: 237987km-147878miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 M    HW: 04L 907 309
   Component: R4 2.0l TDI   X23 9458
   Revision: 85X23---    CVN: 500D7A2038D3FF82B866C2AD
   Coding: 01190012032410081000
   Shop #: WSC 24165 444 00000
   ASAM Dataset: EV_ECM20TDI01104L997022M 004002
   ROD: EV_ECM20TDI01104L997022M.rod
   VCID: BA38A90E3D87F04DCE-80EE
   VINID: 0E69D64474652567450421C008D859326C
17158 - Databus
          U1123 00 [00100111] - Received Error Message
                    Mileage: 237987 km
                    Date: 2026.10.28
                    Time: 23:09:09
                    Engine speed: 0.00 /min
                    Coolant temperature: 19  C
                    Intake air temperature: 20  C
                    Voltage terminal 30: 11.660 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Acceleration: 0.000 m/s
Readiness: 0 0 0 1 1
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 50785000000830
   Coding: 04FA6AA12421096E007E020081C52520562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   VCID: C7DEC0FA7E759DA541-8092
8 Faults Found:
0071 - Rear Left Wheel Speed Sensor
          C101C 4A [00001000] - Incorrect Component(s) Installed
                    Reset counter: 117
                    Mileage: 229001 km
                    Date: 2026.03.14
                    Time: 14:18:07
0079 - Rear Left Wheel Speed Sensor
          C101C 29 [00001000] - Signal Implausible
                    Reset counter: 94
                    Mileage: 232338 km
                    Date: 2026.05.17
                    Time: 21:25:28
0087 - Rear Right Wheel Speed Sensor
          C101D 4A [10001001] - Incorrect Component(s) Installed
                    Reset counter: 39
                    Mileage: 229001 km
                    Date: 2026.03.14
                    Time: 14:18:06
0128 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [undervoltage]
                    Fault Frequency: 8
                    Reset counter: 77
                    Mileage: 229001 km
                    Date: 2026.03.14
                    Time: 14:58:35
4197 - Rear Left Wheel Speed Sensor
          C101C 14 [00001000] - Open or Short to Ground
                    Reset counter: 94
                    Mileage: 232338 km
                    Date: 2026.05.17
                    Time: 21:25:44
8292 - Control Module Incorrectly Coded
          U1014 00 [10001001] - -
          [FCAN: 4 wheel driven is not coded but Allrad_03 message is received]
                    Reset counter: 77
                    Mileage: 237987 km
                    Date: 2026.10.28
                    Time: 22:42:52
8356 - Databus
          U1122 00 [00001000] - Implausible Message
          [FCAN: Klima_11_alt veraltet bit is set]
                    Reset counter: 117
                    Mileage: 237987 km
                    Date: 2026.10.27
                    Time: 19:43:24
16417 - Display for Tire Pressure Monitoring
          C1146 02 [00001001] - Signal Failure
                    Reset counter: 39
                    Mileage: 229001 km
                    Date: 2026.03.14
                    Time: 14:18:16
   Revision: 00021000    Serial number: 0363103743 Dataset Number: V03935208L0003
   Coding: 130C0C
   Part No SW: 5GM 907 426 E    HW: 5GM 907 426 E
   Component: AC Manuell    H03 1801
   Revision: 00001K04
   Coding: 02020104202100000000000000000002
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: CAD8F9CE6D6760CD5E-809E
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 Q    HW: 5Q0 937 087 Q
   Revision: --------    Serial number: 86582503153046 Dataset Number: 5GM063v____ 0050
   Coding: 000108424041804169E44000000403001800000000000000000000000000
   Shop #: WSC 00066 790 00208
   ROD: EV_BCMBOSCH_014.rod
   VCID: C9DAC6C268616BD557-809C
   Component: WWS    150119  043 0581
   Serial number:         150425005803
   Coding: 0F4DD9
   Serial number: 003GCR01HX0N Dataset Number: 5GM003V____ 0044
   Serial number: IBH0000J150002JZDX01
   Coding: 303138
   Subsystem 2 - Part No SW: -----------    HW: 480 000 203 15
   Serial number: 357000000006B5F0431H
   Subsystem 3 - Part No SW: -----------    HW: 480 000 203 15
   Serial number: 358000000002CCE4131M
   Subsystem 4 - Part No SW: -----------    HW: 480 401 602 15
   Serial number: 3510002AB1993FB4A11A
   Subsystem 5 - Part No SW: -----------    HW: 480 401 602 15
   Serial number: 3520002C91993FB2639F
   Subsystem 6 - Part No SW: -----------    HW: 480 402 201 15
   Serial number: 355000299192BC741284
   Subsystem 7 - Part No SW: -----------    HW: 480 402 201 15
   Serial number: 35600029B192BC702284
9440539 - Driver's Safety Belt Tensioner Igniter 2
          B100D 1B [10001001] - Resistance Too High
                    Mileage: 237987 km
                    Date: 2026.10.28
                    Time: 22:56:40
          B1006 1B [10001001] - Resistance Too High
                    Mileage: 237987 km
                    Date: 2026.10.28
                    Time: 22:56:40
9438491 - Igniter for Driver head airbag
          B1005 1B [10001001] - Resistance Too High
                    Mileage: 237987 km
                    Date: 2026.10.28
                    Time: 22:56:40
9441051 - Front passenger's safety belt tensioner igniter 2
          B100F 1B [10001001] - Resistance Too High
                    Mileage: 237987 km
                    Date: 2026.10.28
                    Time: 22:56:40
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [10001001] - Resistance Too High
                    Mileage: 237987 km
                    Date: 2026.10.28
                    Time: 22:56:40
          B10B3 00 [10001001] - Function Restriction due to Implausible Message(s)
                    Reset counter: 77
                    Mileage: 237987 km
                    Date: 2026.10.28
                    Time: 22:56:55
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150322500780
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 844417F60FC376BDE4-80D0
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 03A512122180CF0502086A001000000000000000
   Shop #: WSC 00066 790 00202
   VCID: E5822A72E4B9AFB553-80B0
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 12041510002412 Dataset Number: 5G0067v____ 2011
   Coding: 0901000800087300EF000008080F00000001050000000000000000000000
   Shop #: WSC 00066 790 07029
   GVL: 01D03C0000000600400C00008000480000000000000000000000000000000000
   ROD: EV_GatewConti_011_VW37.rod
   VCID: F1AA4E22207173153F-80A4
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150000654220075143
   Coding: 30FFFF
   Inverter for socket:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0043278
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00019.07.19 Dataset Number: v1260x015G0 0000
   Coding: 0001
   Shop #: WSC 00066 790 00072
   VCID: CCD4FFD667137EFD6C-8098
16656 - Databus
          [Bremsensteuerger t - no speed signal]
                    Reset counter: 77
                    Mileage: 237987 km
                    Date: 2026.10.28
                    Time: 23:01:44
   Revision: 00000000    Serial number: 15000064798004
   Coding: 5500000000000000
   VCID: B42487361FE3063D14-80E0
13637378 - Databus
          [Errorvalue ESP_Wegimpulse]
                    Reset counter: 77
                    Mileage: 237987 km
                    Date: 2026.10.28
                    Time: 22:57:42
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: E0 01
                    WFS State: 17 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 64
                    AD-Value H-bridge: 31
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-DCD-V1.clb
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 200415060504SR Dataset Number: V03935206HY 0006
   Coding: 003013200000040000000000
   VCID: BE30A51E21AFDC6DF2-80EA
   Serial number: 00000000000001003470
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Dataset Number: 5GM074V____ 0515
   Coding: 0102
   VCID: C3C6D4EA4A4DB1859D-8096
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 10041506050FQX Dataset Number: V03935206HZ 0006
   VCID: BD32A2122CA9C775EB-80E8
   Serial number: 00000000000001010385
   Coding: 091000
   Part No SW: 5G0 035 878 A    HW: 5G0 035 878 A
   Component: MU-S-S-US     015 0655
   Serial number: V7B02103180076 Dataset Number: V03935238XP 0001
   Coding: 02730200FF00000021220001001800001F0100140100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: AC149F56C7D35EFD4C-80F8
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9RS501PK3
                    Reset counter: 77
                    Mileage: 237987 km
                    Date: 2026.10.28
                    Time: 22:58:54
                    Voltage terminal 30: 11.5 V
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Address 75: Telematics (J949)       Labels:| 5QE-035-28X-V1.clb
   Component: OCULowMQBUS   007 0564
   Dataset Number: 561098V____ 0408
   Coding: 02730202C2821A017F1E06000000
   Shop #: WSC 00066 790 00322
   ROD: EV_OCULowMQB_VW37.rod
End----(Elapsed Time: 01:22, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
------------------------------18 Faults Found------------------------------
Cuzoe
C?ID=279487
You need to code the proper rear wheel speed sensors. I didn't look at your coding to see what you have but typically this is just a mismatch where you're coded for bi-directional sensors and don't have them or vice versa. Probably just need to switch them in the coding to the opposite of whatever they are now. ABS also needs to be coded for AWD.
Edit: Voice to text likes to interpret coded/coding as coated/coating, haha.
76MavStallion
Rockland, WI, USA
C?ID=516179
Link above is of some help, but still have questions. 15 Golf SportWagen has shorter long coding than the donor Alltrack. do I just ignore the extra digits. The ones I have compared in the linked spreadsheet look right...
Cuzoe
C?ID=279487
I wouldn't worry about what's in the Alltrack coding, or the extra byte as it likely has a later ABS module. The spec (and thus ABS coding) will be different (brake size is different for one thing, but any non-matching packages will also impact ABS coding).
Just fix the coding in the GSW's ABS coding for the new configuration (AWD, and different speed sensors). See where that gets you and go from there. You don't want to start copying ABS coding over directly. Just take your time with the spreadsheet.
Change one thing at a time (and its corresponding mirror byte as/if applicable). If you enter something too incorrect or don't catch the mirror byte the ABS will reject the coding (out of range). At that point just double check your work. But you only want to make one change at a time, coding accepted, move on to the next thing to resolve.
HohlfeldAuto
Wisconsin, USA
C?ID=53883
Changed just the two things mentioned, added AWD and changed rear sensor type. Now we are gettinga new error code
4181 - Function Shut-Off Active
C10C8 00 [10001001] - -
[The function AYC+TCS were deactivated because single track modell is missing]
Reset counter: 77
Date: 2026.11.02
Time: 16:42:24
New auto scan follows
Monday,02,November,2026,17:11:23:55529
Mileage: 147880mi   Repair Order:
VIN: 3VWFA7AU9FM512702   Mileage: 237991km-147880miles
   Coding: 04FA6AA12421096E007E030081C5252056249000C081A4B200635050C002
   Shop #: WSC 12345 123 61029
                    Reset counter: 77
                    Date: 2026.11.02
                    Time: 16:42:24
   Coding: 130C0C
   Revision: 00001K04
   Coding: 0F4DD9
558100 - Databus
                    Reset counter: 78
                    Mileage: 237991 km
                    Date: 2026.11.02
                    Time: 18:08:25
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beams: Not operated
                    Voltage: 11.9 V
                    Outside temperature: 16.0  C
   Coding: 303138
7 Faults Found:
                    Mileage: 237988 km
                    Date: 2026.11.02
                    Time: 16:41:36
                    Mileage: 237988 km
                    Date: 2026.11.02
                    Time: 16:41:36
                    Mileage: 237988 km
                    Date: 2026.11.02
                    Time: 16:41:36
                    Mileage: 237988 km
                    Date: 2026.11.02
                    Time: 16:41:36
                    Mileage: 237988 km
                    Date: 2026.11.02
                    Time: 16:41:36
9446128 - Control Module for Seat Occupant Detection
          B1022 F0 [10001001] - No Basic Setting
                    Reset counter: 78
                    Mileage: 237991 km
                    Date: 2026.11.02
                    Time: 16:59:25
9445929 - Seat occupied recognition control module
          B1022 29 [10001001] - Signal Implausible
                    Reset counter: 78
                    Mileage: 237991 km
                    Date: 2026.11.02
                    Time: 16:59:30
   Coding: 0400
   Generator:
   Coding: 30FFFF
   Coding: 0001
   Coding: 011000
   Coding: 0102
   Coding: 091000
                    Reset counter: 77
                    Mileage: 237988 km
                    Date: 2026.11.02
                    Time: 16:37:44
                    Voltage terminal 30: 11.8 V
End----------(Elapsed Time: 01:23, VBatt start/end: 12.1V/12.1V)-----------
------------------------------10 Faults Found------------------------------
Cuzoe
C?ID=279487
Go through the whole spreadsheet. In your current coding two that stick out to me as wrong...
Byte 4 = 24... 288mm front brakes (should be updated if you put the 312mm from the Alltrack)
* this byte gets mirrored in byte 17
Byte 14 = 25... 272mm rear brakes with torsion beam
*this byte gets mirrored in byte 22
The coding as torsion beam is probably causing your fault, torsion beam being at odds with AWD.
HohlfeldAuto
Wisconsin, USA
C?ID=53883
Made these two changes to reflect the brake sizes from the donor Alltrack and now there are no codes for the ABS module. I still have the code in 09 Central Electronics "Received Error Message."
Cuzoe
C?ID=279487
Maybe clear faults and post another auto scan after. Typically a message like this means the module (BCM in this case) is coded for the presence of something but that something is not providing data as expected (or maybe at all).
Did you change any coding in the BCM?
I suppose, although the smart people at Ross Tech would have to confirm, that the BCM could be complaining because it is seeing messages from something that is not coded as present. But I don't know how such a fault would show up in the BCM, if at all.
The ABS module, for example, will complain about seeing unexpected messages. In my car I had DCC module installed but not properly coded in the ABS and the ABS fault code said (plain English paraphrasing) "suspension module messages received but suspension module not coded."
