2012 VW Passat TDI SEL Electric Problem
HarisT
C?ID=644145
Hello, I am having an issue with my 2012 VW Passat TDI SEL. The car suddenly one day gave a Christmas dash with multiple errors whilst in the middle of a drive. When pulling the car over and turning off the car, the car was unable to start or even crank and the instrument cluster had no power whatsoever (black screen including the image of the car with doors open/closed or even mileage). After about 5 minutes the car turned on fine and drove with no problem. Not only does this happen randomly while driving, but there are also times when I try to start the car for the first time and there is also no power on the instrument cluster (black screen) and the car wont start, sometimes the red steering wheel icon will show up and the car will beep but nothing else is happening. The car unlocks and locks fine with no issues. When the screen is black and car refuses to crank, I tested the hazards to check for power and they work on the headlights but they don't display flashing turn signals on the dash. When the screen is black, I push the start button multiple times and sometimes after a couple minutes it'll give it contact but glitch and not start, and sometimes it'll just suddenly start working and running but then after some time all the warning lights come on again. I checked relay 15 and even swapped it and problem persists. Using the VCDS, I received the codes " restricted due to missing messages". When the car is on and the issue occurs, the car stays running fine, but the RPM and speedometer drop to 0 but the warning lights stay on and cluster displays errors (as seen in the video included)
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Hi @Ennis,
I might be able to tell, provided your friend posts the Auto Scan file.
Ask him to do that, I’m making this request right here. ;)
HarisT
C?ID=644145
Hi @Ennis,
Monday,26,October,2026,16:16:45:00117
VCDS Version: 25.3.2.0 (x64)  HEX-V2 CB: 0.4713.5
VIN: 1VWCN7A33CC067336   License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 77
52-Door Elect, Pass. -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Sporadic communication error 1000
   Component: R4 2.0l TDI   H21 9982
   Revision: 71H21---    Serial number: 00000000000000 CVN: D240C61FD45710C1
   Coding: 001D0012042400008000
   Shop #: WSC 22599 444 00000
   ROD: EV_ECM20TDI01103L997009H.rod
   VCID: 3B24D455D3E5A7829B1-806E
   VINID: 0669D37874430D34C01870C318EFA36F1D
4715 - No Communication with Instrument Cluster
          U0155 00 [00100100] - -
          [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
                    Mileage: 265243 km
                    Engine speed: 0.00 /min
                    Coolant temperature: 17 °C
                    Intake air temperature: 16 °C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 11.960 V
                    Limitation: accelerator pedal: 220.0 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 12
                    selected gear-Bits 0-7: 0
   Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9435
   Revision: 05551213    Serial number: 00001201121175
   Shop #: WSC 09003 957 00200
   VCID: 2612152134E70A6AD4F-8072
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Mileage: 265243 km
                    Date: 2063.14.31
                    Time: 18:21:56
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V3.clb
   Revision: 00H31001
   Coding: C54BC0F549280001A30E03E7921F0042A71000
   VCID: 7DA01A4D8DF169B2E55-8028
                    Reset counter: 206
                    Mileage: 265243 km
                    Date: 2063.14.31
                    Time: 18:21:56
                    Count: 12
                    Count: 20480
                    Count: 8208
                    Count: 42752
                    Count: 64768
                    Count: 257
                    Reset counter: 206
                    Mileage: 265261 km
                    Count: 12
                    Count: 20480
                    Count: 16390
                    Count: 43520
                    Count: 64768
                    Count: 257
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0163469023 Dataset Number: 5K0116v____ 560E
   Coding: 130C0C
   ROD: EV_KESSYPQ35G_A02_VW41.rod
   VCID: 3436FF69FEBB68FA5AB-8060
1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
          B116C 13 [00001000] - Open Circuit
                    Fault Frequency: 8
                    Reset counter: 246
                    Mileage: 265244 km
                    Date: 2127.14.31
                    Time: 23:32:59
1057291 - Antenna for Keyless Entry System; Passenger Side
          B1170 13 [00001000] - Open Circuit
                    Reset counter: 246
                    Mileage: 265244 km
                    Date: 2127.14.31
                    Time: 23:32:49
12713984 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
                    Reset counter: 246
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 19:21:38
12714496 - Function Restricted due to Missing Message(s)
                    Reset counter: 246
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 19:21:38
   Part No SW: 561 907 044 H    HW: 561 907 044 H
   Component: Climatronic   043 0202
   Revision: 00001001
   Coding: 0010001012
   VCID: 1C6637C9762BC0BA72B-8048
13701456 - Function Restricted due to Missing Message(s)
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Reset counter: 246
                    Mileage: 265261 km
                    Date: 2127.14.31
                    Time: 16:25:06
13701488 - Function Restricted due to Missing Message(s)
          [Türsteuergerät Fahrerseite - kein Signal/Kommunikation]
                    Reset counter: 245
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 18:42:15
13701504 - Function Restricted due to Missing Message(s)
          [Türsteuergerät Beifahrerseite - kein Signal/Kommunikation]
                    Fault Frequency: 8
                    Reset counter: 246
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 19:14:45
13701520 - Function Restricted due to Missing Message(s)
          [Türsteuergerät hinten links - kein Signal/Kommunikation]
                    Reset counter: 245
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 18:42:15
13701536 - Function Restricted due to Missing Message(s)
          [Türsteuergerät hinten rechts - kein Signal/Kommunikation]
                    Fault Frequency: 8
                    Reset counter: 246
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 19:14:45
9481748 - High Pressure Sensor
          B10AE 14 [00001000] - Open or Short to Ground
                    Reset counter: 245
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 18:40:33
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0164
   Revision: BL121001
   Coding: 6F200E1B982B08D408880201360085480071008645A005F0648060009C70
   VCID: 74B63F69BEBB28FA9AB-8020
   Component: RLS 160212 05  54  0403
   Coding: 22300A
                    Reset counter: 246
                    Mileage: 265243 km
                    Date: 2063.14.31
                    Time: 19:20:35
                    Voltage: 12.05 V
                    Reset counter: 246
                    Mileage: 265243 km
                    Date: 2063.14.31
                    Time: 19:20:35
                    Voltage: 12.05 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM01TPMA   Dataset Number: 560003v__A_ 0049
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FBC3005D71D0B22679-803A
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y120000B8T90R
   Coding: 303047
   Serial number: 3572MSME43394566ZZZX
   Serial number: 3516KSME0A245B17ZZZT
   Serial number: 3526KSME255E4A17ZZZ
   Subsystem 5 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Serial number: 3556LSME07685311ZZZP
   Serial number: 3566LSME06537E15ZZZ-
9451029 - Crash sensor side airbag; passenger side
          B1036 15 [10001000] - Open or Short to Plus
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 19:19:28
12670208 - No Communication with Instrument Cluster
          U0155 00 [00001000] - -
                    Reset counter: 246
                    Mileage: 265261 km
                    Date: 2127.14.31
                    Time: 16:25:06
12674816 - Immobilizer Control Module
          U0167 00 [00001000] - No Communications
          [Lost Comminication with Immobilizer]
                    Reset counter: 246
                    Mileage: 265261 km
                    Date: 2127.14.31
                    Time: 16:25:39
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20210409100229
   Coding: 100A140000
   Shop #: WSC 10479 005 1048576
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 025A69B1F48F164A987-8056
   Component: E221__MFL-YVJ  H06 0022
   Serial number: 00000000000000419238
   Coding: E20000
Address 17: Instruments
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 04031201290214
   Coding: 461000
   VCID: 3D20DA4DCD71A9B2A55-8068
                    Fault Status: 00110100
                    Reset counter: 246
                    Mileage: 265243 km
                    Date: 2063.14.31
                    Time: 19:15:03
                    Reset counter: 246
                    Mileage: 265243 km
                    Date: 2063.14.31
                    Time: 19:15:03
   Component: IMMO          H07 0507
   Coding: 000007
   Shop #: WSC 22585 444 131590
   VCID: 6A8A2111ECFFEE0A307-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000247547005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW41.rod
   VCID: 2E02ED011097422A2CF-807A
12666368 - Function Restricted due to Missing Message(s)
          [Timeout Message mGW_Breme_Getriebe]
                    Reset counter: 246
                    ELV State: 0A
                    Information Clamps: 00 00
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Vehicle speed: 655.35 km/h
                    Voltage: 6E
12666369 - Function Restricted due to Missing Message(s)
          [Timeout Message mGW_Motor]
                    Reset counter: 246
                    ELV State: 0A
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Voltage: 6E
12670208 - Function Restricted due to Missing Message(s)
          [Timeout Message mKombi_K1]
                    Reset counter: 246
                    Mileage: 265261 km
                    Date: 2127.14.31
                    Time: 16:25:06
                    ELV State: 0C
                    Information Clamps: 77 60
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Vehicle speed: 0.00 km/h
                    Voltage: 65
12666372 - Function Restricted due to Missing Message(s)
          [Timeout Message mGW_Kombi]
                    Fault Frequency: 8
                    Reset counter: 246
                    ELV State: 0A
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Voltage: 6E
   Revision: A1001003    Serial number: 7661599825
   VCID: 29081E1D29F92512F9D-807C
                    Reset counter: 245
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000024592663
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 609E43391A43A45AEE3-8034
                    Fault Frequency: 16
                    Reset counter: 246
   Part No SW: 3C8 035 684 E    HW: 3C8 035 684 E
   Component: RNS-MID       H61 3690
   Revision: AB001001    Serial number: VWZ6Z7M4033063
   Coding: 04090042010000A6000B
   VCID: 2D00EA0D1D113932155-8078
                    Fault Frequency: 12
                    Reset counter: 206
                    Mileage: 265240 km
01523 - Microphone for Telephone (R38)
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 11
                    Reset counter: 206
                    Mileage: 265243 km
                    Date: 2063.14.31
                    Time: 00:25:28
00001 - Brake Control Unit
                    Reset counter: 245
                    Mileage: 265243 km
                    Date: 2063.14.31
                    Time: 18:40:31
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0004089478
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
65537 - Function Restricted due to Missing Message(s)
          [Passenger DCU Time-out]
                    Reset counter: 246
                    Mileage: 265261 km
                    Date: 2127.14.31
                    Time: 01:35:32
131584 - Motor for Rear Window Regulator
          B11EE 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 206
                    Mileage: 265261 km
                    Date: 2127.14.31
                    Time: 01:35:31
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 290    3301
   Revision: 00H22000
   VCID: 3530C26DF94171F26D5-8060
                    Reset counter: 246
                    Mileage: 265261 km
                    Date: 2063.14.31
                    Time: 16:25:39
                    Voltage: 12.00 V
                        DD
                    Temperature: 17.0°C
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.5 V
                        PD
                    Temperature: 20.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 5C6 035 456     HW: 5C6 035 456
   Component: KonzernAmp10K H07 0468
   Revision: --------    Serial number: EAA083A0007348 Dataset Number: 560050v____ 5604
   ROD: EV_AudioVerst10KanalSTT3_VW41.rod
   VCID: 6590522D05E1C1721D5-8030
9651475 - Double Bass Speaker 1; Front Left
          B1345 13 [00001000] - Open Circuit
                    Reset counter: 245
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 18:40:25
9651987 - Double Bass Speaker 2; Front Left
          B1347 13 [00001000] - Open Circuit
                    Reset counter: 245
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 18:40:25
9651731 - Double Bass Speaker 1; Front Right
          B1346 13 [00001000] - Open Circuit
                    Reset counter: 246
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 19:14:42
9652243 - Double Bass Speaker 2; Front Right
          B1348 13 [00001000] - Open Circuit
                    Reset counter: 246
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 19:14:42
   Component: EZE_2         H40 1623
   Coding: 01030108
   VCID: 6FBC3005D79D0B22679-803A
   Serial number: 53388786011135600510
   Coding: 181100
   Component: Analoguhr  008 0004
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0004072495
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D603ACD6D31C9B2855-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
          [Driver DCU Time-out]
                    Reset counter: 246
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 18:34:11
68107 - Function Restricted due to Missing Message(s)
          [Front CAN AirBag]
                    Reset counter: 245
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 18:40:28
                    Reset counter: 204
                    Mileage: 265243 km
                    Date: 2127.14.31
                    Time: 00:25:20
                    Fault Frequency: 12
                    Reset counter: 206
                    Mileage: 265240 km
                    Fault Frequency: 11
                    Reset counter: 206
                    Mileage: 265243 km
                    Date: 2063.14.31
                    Time: 00:25:28
                    Reset counter: 245
                    Mileage: 265243 km
                    Date: 2063.14.31
                    Time: 18:40:31
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661577691 Dataset Number: 5K0035730E  0001
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 270C18253F6D1362EF9-8072
          [Kombiinstument: keine Kommunikation]
                    Reset counter: 246
                    Mileage: 265261 km
                    Date: 2127.14.31
                    Time: 16:25:38
End----------(Elapsed Time: 01:35, VBatt start/end: 12.4V/12.4V)-----------
------------------------------45 Faults Found------------------------------
Boki Ar
C?ID=57300
@HarisT,
The scan is fine, all that remains for you to do is:
If it were mine, the first thing I would do here is remove the instrument cluster, unplug any connectors behind it, and inspect them for corrosion. Then I would apply contact cleaner and contact conditioner to both the harness connectors and the pins on the mating connector on the cluster itself. I'm not real confident that this will fix the problem, but it doesn't cost much to try. Of course you need to do this with the ignition off. Do not turn the ignition on with the instrument cluster unplugged or you will open another can of worms.
If that doesn't fix it, my next guess is that the instrument cluster itself is failing.
HarisT
C?ID=644145
I undid the cluster and inspected the wiring, there is no corrosion. I also tested the actual cluster itself. I also replaced the start/stop ignition with no luck. The BCM was also tested with no issues. I have examined all cables and all seem in order. When the problem occurs and the car wont start, or when the car is on and the problem occurs, I cannot scan the car because there is no communication. The car will work one second with absolutely no issues with no dash lights, and the next everything is lit up.
