2023 Golf 8 hybrid, address 15 airbag light on: 5 stored B-codes + 1 active P-code read via raw UDS, can't find descriptions
frostflame96
Luxembourg
Hi all, I just joined, so apologies if I'm missing any forum etiquette.
CAR: VW Golf Mk8 hybrid ([eHybrid / eTSI - fill in]), built 2022-2023, Europe. Airbag module (address 15): part no. 5WA959655M, name "AirbagVW40".
PROBLEM: The airbag light came on by itself on 25 Oct 2026, after about 100 km of driving. The only recent work was a routine service on 15 Sep 2026. No seat work, no flat battery or jump start that I know of. Voltage at the OBD port with ignition on: 13.4 V.
IMPORTANT: I don't have VCDS (yet). I read the module with an OBDLink LX and my own Python script using UDS service 0x19. I have NOT cleared anything. So what follows are raw bytes plus my own SAE conversion of the 3 DTC bytes; VCDS may show different numbering/text.
DTCs (raw DTC bytes / status):
B104201 = 90 42 01 / 0x88
B104301 = 90 43 01 / 0x88
B104401 = 90 44 01 / 0x88
B102001 = 90 20 01 / 0x88
B102501 = 90 25 01 / 0x88
P108A00 = 10 8A 00 / 0x01
My reading of the status bytes: 0x88 = confirmed + warningIndicatorRequested, testFailed = 0 (stored, not failing now). 0x01 = testFailed only: active right now, not confirmed, no lamp request.
Extended data (19 06, record 01):
B-codes (all five identical): 59 06 90 42 01 88 01 02 01 02 FF 01 4B 6A 00 00 6A A3 6C 97
P108A00: 59 06 10 8A 00 01 01 06 01 02 F4 01 4B 82 00 00 6A B3 07 4C
Freeze frames (19 04) are refused by the module with NRC 0x12, so I have no date, mileage or voltage at the time of the fault.
MY QUESTIONS:
1. Can someone with VCDS on a Golf 8 / MQB-EVO tell me what B1042, B1043, B1044, B1020 and B1025 show up as (text and VCDS fault number)?
2. Same for P108A00. An active P-code inside the airbag module surprised me. What is it?
3. The digits of B1042/B1043/B1044 look like the old KWP numbers 01042/01044 ("not coded" / "incorrectly coded"). Is that a coincidence, or does VW's UDS numbering carry over in some cases?
4. Five codes with identical extended data: does that normally point to one common cause (supply, module reset, coding) rather than five separate hardware faults?
5. Anything useful I can check before the dealer reads it with ODIS? I'm not touching any airbag connectors.
I found no public source for these codes, so I'd rather ask than guess. Thanks a lot for any help!
Sebastian
Magdeburg, Germany
HN0-nnnnnn
This isn't how things work.
Before I'd trust this read, I'd really like to see a proper VCDS > Auto-Scan.
No, they do not. They have completely different meanings.
Let's see a full Auto-Scan with all details and proper context.
Sure, read DTC's on actual dealer level with VCDS. ;)
