VCIConfig & SFD_Helper issues
stevemc11
C?ID=549009
Hey Ross-Tech team!
Thanks for letting me in. I was doing my head in this Sunday trying to get SFD unlocks to run. I hope I can get more insights/help via this way.
I am encountering an issue where SFD integration and interface configuration binaries fail due to an OS-level memory access violation.
Specifically, VCIConfig.exe fails to open/start at all, and SFD_Helper.exe fails silently during an SFD session, returning exit code -1073741819 inside VCDS.
When checking Windows Reliability Monitor and Event Viewer, both executables log the exact same crash details originating from msvcrt.dll.
I reviewed the this forum thread regarding SFDHelper crash errors because the .dll pointed me towards C++ runtimes, but nothing discussed there did resolve my problems.
To not waste your time, here are the complete details, event logs, and troubleshooting steps performed:
1. Setup Details​
  • Primary Device: Microsoft Surface Pro (Intel Core Ultra Series 2 / Lunar Lake) w/ Windows 11 26H2 (Build 26300.9711)
  • Secondary Test Device: Desktop PC w/ Windows 11 26H2 (Build 26300.9550)
  • VCDS Distribution: VCDS-DRV (C:\Ross-Tech\VCDS-DRV\)
  • Interface Hardware: HEX-V2
  • Interface Status: Firmware up to date
  • SFD Status: Officially registered with active password set inside VCIConfig (I did get this to work on my work laptop, but I cannot use that for my purposes, in case you're asking).
2. Observations​
  • VCIConfig.exe: Fails to launch entirely (does not show a GUI window).
  • SFD_Helper.exe: Launched in the background when attempting an SFD session in VCDS, immediately aborts and returns exit code -1073741819 in the VCDS interface.
  • Log Status: No log.txt or SFDLog.csv file is generated in either C:\Ross-Tech\VCDS-DRV\ or the Debug directory. Both executables crash at the operating system level during process initialization before any internal logging or diagnostic file creation can take place.
Reliability Monitor / Event Viewer Fault Details (more or less identical for both executables):
Description
Faulting application name: VCIConfig.exe, version: 2.307.0.2, time stamp: 0x02000002
Faulting module name: msvcrt.dll, version: 7.0.26100.9711, time stamp: 0xacff24f7
Exception code: 0xc0000005
Fault offset: 0x0008e5c2
Faulting process id: 0x3890
Faulting application start time: 0x1DD64A7CBA876E8
Faulting application path: C:\Ross-Tech\VCDS-DRV\VCIConfig\VCIConfig.exe
Faulting module path: C:\Windows\System32\msvcrt.dll
Report Id: 79cb21fb-9ddf-41e7-8a4c-9fdae2bc7b06
3. What I already tried​
  1. Clean Windows 11 Reinstall:
    Performed a complete, clean reinstallation of Windows 11 on the Surface Pro to rule out OS image degradation or legacy registry remnants. The crash persisted immediately upon reinstall.
  2. Tested Across Multiple Windows 11 Build Revisions:
    Replicated on a secondary x86-64 PC running Windows 11 Build 26300.9550, as well as the main Surface Pro running Build 26300.9711.
    Both machines produce the exact same 0xC0000005 fault in msvcrt.dll, ruling out a single-device hardware fault or isolated patch revision.
  3. Visual C++ Runtimes (Thread #54694 Reference):
    Installed and repaired Microsoft Visual C++ 2015–2022 Redistributables (x86 and x64).
  4. Clean Background Environment (No Software/Driver Interference):
    Verified clean system state with no peripheral software, background utilities, or USB hooks running (e.g., Logitech crap or other HDI interference).
  5. Windows Security Configuration:
    Executed sfc /scannow and DISM /Online /Cleanup-Image /RestoreHealth (no remaining system file corruption).
    Disabled Memory Integrity / Core Isolation and Kernel-mode Hardware-enforced Stack Protection.
    Disabled Control Flow Guard (CFG) and Mandatory ASLR overrides for both VCIConfig.exe and SFD_Helper.exe under Windows Exploit Protection settings.
    Explicitly added Inbound/Outbound rules in Windows Defender Firewall for SFD_Helper.exe (Private and Public).
Old VCIConfig launches with no issues (VCIConfigV2.301)!
Since both executables fail at offset 0x0008e5c2 inside msvcrt.dll upon process initialization across Windows 11 26H2 builds (26300.9550 and 26300.9711), even on a fresh Windows 11 installation, I'm totally out of options and I know my way around a PC...
Because no log.txt can be generated due to the pre-init crash, please let me know if there is anything I can test to help diagnose this further.
Fingers crossed & thanks!
J
TTT
C?ID=547002
So much details, have you maybe forgot one?
This is quite strange ("eigenartig" in German) given how many people are using SFD without such problems on a daily basis. :confused:
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Not reproducible on multiple machines here, haven't heard any other/similar reports yet. 🤨
  • Agree
stevemc11
C?ID=549009
What windows versions are those? I kind of leaning towards some changes in 26h2
Sebastian
Magdeburg, Germany
HN0-nnnnnn
All on 26H2 here, so that ain't it. I'll have a freshly installed machine next week, will double check once that arrives.
stevemc11
C?ID=549009
Well then... is there a way to get a refund for the SFD license?
If we can't figure out what's going on there and you have never unlocked anything, then sure.
But you posted this thread on a Sunday afternoon, and right now it's 7:21 on a Monday morning at Ross-Tech, so please allow us some time to investigate this.
stevemc11
C?ID=549009
No worries, take your time!
In going to try something else through a virtual machine. Maybe that might work.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Please give us a week to gather some feedback from distributors etc., because as said so far we haven't seen this.
In addition, please run these updaters (for Release and/or Beta, whichever you got installed and want to test). They include a slightly newer VCIConfig revision.
English: Data Version Updater for Current Release
English: Data Version Updater for Current Beta
After you installed these updaters you will find a C:\Ross-Tech\VCDS[-Beta]\Debug\SystemInfo.TXT which I'd like you to send to us via email (support@ross-tech.com). Make sure to mentioned this thread in your email. Thanks.
stevemc11
C?ID=549009
Okay so I've quickly set up a Windows 10 VM on my Surface with the native Hyper-V manager.
That works right out of the box without any additional installs (like VC redistributables).
  • Informative
I wonder if the fact that you were using "Windows 11 Enterprise 64-bit" previously is somehow the cause of the problem? That is not a Windows edition that we normally test on because it is not one that is in common use. Could you step that one down to "Professional" to see if it solves the problem?
Zenerdiode
Newcastle, England
C?ID=24330
I use Windows 11 Enterprise 64-bit on my company laptop - which is heavily locked down in the corporate domain with many tens of thousands of end users. Admittedly it is version 24H2; but I've not had a problem so far.
stevemc11
C?ID=549009
I've updated both the release and the beta, nothing changed.
Currently my workaround seems to be the VM...
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I have tested on 2 more fresh Windows installs and the issue is not reproducible. The only difference I can see is still the Enterprise version and the log/systeminfo you sent us also shows no obvious points that would allow us to start looking into this issue further than we have so far. Sorry...
FWIW; if I find the time, I'll try an Enterprise install in a virtual environment to see if that helps locating this problem in any shape or form. If you haven't done that yet, please start either of the two problematic machines in Safe Mode and see if the issue persists then as well.
