Having the same issue as quoted below in two different threads. Tried on three separate PCs.
Additionally, I cannot connect to any Wifi networks. Help!?
I also tried
But no change.
When I plug my hexnet in to the car ODB port or my PC via USB I get 3 beeps x 5 . Tried firmware update but just get USB error after the laptop has downloaded it.
Exactly the same as this thread except that mine does not beep at all if you do a factory reset.
Getting beep codes. 3 beeps X 5
All of a sudden When I plug my hexnet in to the car ODB port or my PC via USB I get 3 beeps x 5 . also not able to connect my phone in AP mode. I have tried doing resets. What do the beep codes mean? Does it indicate a problem?forums.ross-tech.com
I also tried
Yes there is a way to rebuild the SD card, it goes something like this:
SD card you want in interface, interface connected via USB, advanced tab in VCIConfig
Feat. code:0701020304
[Check Feat. Update]
Once successful, unplug and replug to powercycle interface
In VCIConfig Updates tab
[Check for Updates]
Make sure Skip VCDS-Mobile update is not checked
[Download & Update]
This should force redownload everything to the SD card.
But no change.
