Need help with ABS long coding, 2012 VW Golf TDI (MK60EC1)
ChrisSRT
Foxfire Village, NC, USA
C?ID=671669
changed the ABS module before realizing I needed to do coding. Hopefully I got the scan correct and I can get some help.
Saturday,24,October,2026,13:38:25:35835
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)
VCDS Version: 26.9.0.3 (arm64)  HEX-NET3 CB: 0.4713.5
VIN: WVWNM7AJ0CW197960   License Plate: RCD-5857
Mileage: 573440km-356319mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 52 55 56
          62 72
VIN: WVWNM7AJ0CW197960   Mileage: 573440km-356319miles
15-Airbags -- Status: Cannot be reached 1100
2E-Media Player 3 -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
   Part No SW: 03L 906 019 EE    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000SG  8177
   Revision: 12H14---    Serial number:
   Coding: 0050072
   Shop #: WSC 74291 008 00000
   VCID: 72B5849828A79E2AE14-8026
   VINID: 9E69DE74745A0139C1247246006F174C4C
049489 - No Communications with Airbag Control Module
               U0151 - 001 -
                    Fault Status: 01100001
                    Mileage: 571841 km
                    Date: 2021.03.16.
                    Time: 00:06:54
                    Voltage: 12.24 V
                    Temperature: 24.3 C
                    Temperature: 44.1 C
                    Bin. Bits: 00000000
                    Torque: 219.0 Nm
                    Temperature: 36.0 C
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 571841 km
                    Date: 2021.03.16.
                    Time: 00:06:56
                    (no units): 0.00
                    (no units): 0.00
                    (no units): 3.0
                    Bin. Bits: 00000100
                    (no units): 0.0
049682 - Steering Column Control Module
               U0212 - 001 - No Communications - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 255
                    Mileage: 571844 km
                    Date: 2021.03.16.
                    Time: 03:50:03
                    RPM: 1472 /min
                    Speed: 73.0 km/h
                    Temperature: 25.2 C
                    Voltage: 14.06 V
                    Bin. Bits: 00000000
                    Torque: 54.0 Nm
                    Temperature: 36.0 C
Readiness: 0 0 0 0 X
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V2.clb
   Revision: 00H31001
   VCID: 7BABA9BC73EDDF62B22-802E
01486 - System Function Test Activated
                    Fault Frequency: 11
                    Reset counter: 222
                    Mileage: 571841 km
                    Date: 2021.03.16.
                    Time: 00:06:58
                    Count: 7
                    Count: 2
                    Count: 16384
                    Count: 320
                    Count: 44288
                    Count: 512
00003 - Control Module
                    Fault Status: 01100101
                    Fault Frequency: 11
                    Reset counter: 222
                    Mileage: 571841 km
                    Date: 2021.03.16.
                    Time: 00:06:58
                    Count: 3
                    Count: 2
                    Count: 16384
                    Count: 143
                    Count: 44288
                    Count: 512
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.16.
                    Time: 00:06:58
                    Count: 7
                    Count: 2
                    Count: 16384
                    Count: 195
                    Count: 44288
                    Count: 512
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.16.
                    Time: 00:06:58
                    Count: 3
                    Count: 2
                    Count: 16384
                    Count: 295
                    Count: 44288
                    Count: 512
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 B
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0158932723 Dataset Number: 5K0116v____ 5K0B
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 343942801EB3D01A338-8060
1057035 - Antenna for Keyless Entry System; Drivers Side
          B116F 13 [00001000] - Open Circuit
                    Reset counter: 248
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001016
   Coding: 0000001002
   VCID: 0051DE501A8BBCBAE70-8054
   Part No SW: 1K0 937 086 P    HW: 1K0 937 086 P
   Component: BCM PQ35  M   110 0651
   Revision: 00110 AC
   Coding: 6F180A1A90272AC4108800C170008D4448052086574D85B0E48420248040
   VCID: 3D2F67A42D791152CC6-8068
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 18111  26  0512
   Coding: 009795
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.16.
                    Time: 00:07:34
                    Voltage: 12.20 V
                        Term 50 Off
Address 15: Airbags
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20151222101136
   Coding: 7982A00000
   Shop #: WSC 01286 386 08256
   VCID: 0255D4581487AEAAF14-8056
   Serial number: 40000000000000517962
   Coding: E20000
0516 - Databus
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.24.
                    Time: 00:07:45
147464 - Terminal 15
          B1148 29 [00001001] - Signal Implausible
                    Fault Frequency: 94
                    Reset counter: 223
                    Mileage: 571841 km
                    Date: 2026.10.24.
                    Time: 00:07:45
          B1149 13 [00001001] - Open Circuit
                    Reset counter: 223
                    Mileage: 571841 km
                    Date: 2026.10.24.
                    Time: 00:07:45
335876 - Powertrain Databus
          U0002 00 [00001001] - No Communications
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.24.
                    Time: 00:07:45
342030 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0010 00 [00001000] - Malfunction
                    Reset counter: 8
                    Mileage: 571844 km
                    Date: 2026.10.24.
                    Time: 03:50:01
1140738 - Steering angle sensor
          B1168 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.24.
                    Time: 00:07:45
                    UBat: 12.30 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
   Part No SW: 5K0 920 972 C    HW: 5K0 920 972 C
   Coding: 270F01
   VCID: 30314E90EAABEC3A570-8064
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Steuerger t f r Airbag: keine Kommunikation]
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.24.
                    Time: 00:08:02
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 211111F1003599
   Coding: 350002
   VCID: 3A256CB83C57266AE94-806E
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.16.
                    Time: 00:08:12
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.16.
                    Time: 00:08:16
03272 - Control Module for Audio Interface
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.16.
                    Time: 00:08:16
   Coding: 000007
   VCID: 6A859CF80CF756EA594-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000245628001
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 2E0D50E8F09FFACA45C-807A
Address 2E: Media Player 3
Address 37: Navigation
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2105
   Coding: 0008369
   VCID: 3723758C03453B0216A-8062
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   VCID: 343942801233D01A338-8060
   Part No SW: 5C6 035 456     HW: 5C6 035 456
   Component: KonzernAmp10K H07 0468
   Revision: --------    Serial number: EAA083A0079245 Dataset Number: 560050v____ 5604
   ROD: EV_AudioVerst10KanalSTT3_VW32.rod
   VCID: 659FEFC4E5E97992746-8030
9651987 - Double Bass Speaker 2; Front Left
          B1347 13 [00001001] - Open Circuit
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.24.
                    Time: 00:08:44
9652243 - Double Bass Speaker 2; Front Right
          B1348 13 [00001001] - Open Circuit
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.24.
                    Time: 00:08:44
9463315 - Rear Left Treble Speaker
          B1066 13 [00001001] - Open Circuit
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.24.
                    Time: 00:08:44
9463827 - Rear Right Treble Speaker
          B1068 13 [00001001] - Open Circuit
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.24.
                    Time: 00:08:44
9636883 - Loudspeaker 1 in Double-Subwoofer
          B130C 13 [00001001] - Open Circuit
                    Reset counter: 223
                    Mileage: 571841 km
                    Date: 2026.10.24.
                    Time: 00:08:44
9637139 - Loudspeaker 2 in Double-Subwoofer
          B130D 13 [00001001] - Open Circuit
                    Reset counter: 223
                    Mileage: 571841 km
                    Date: 2026.10.24.
                    Time: 00:08:44
   Part No SW: 5K0 959 702 H    HW: 5K0 959 702 H
   Coding: 0001204
   VCID: 382176B00E5B347A1F0-806C
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Coding: 1446940
   Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Subsystem 2 - Part No: ID-R fehlt    Labels: ID-55-02.CLB
   Component: AFS-Lst.-Modul r    ....
   Coding: 00000255
02233 - Left Headlight Power Output Stage (J667)
                    Fault Status: 11100100
                    Fault Frequency: 91
                    Reset counter: 223
                    Mileage: 571841 km
                    Date: 2021.03.16.
                    Time: 00:08:53
                    Voltage: 12.07 V
                        ABS 1
02234 - Right Headlight Power Output Stage (J668)
                    Fault Frequency: 91
                    Reset counter: 223
                    Mileage: 571841 km
                    Date: 2021.03.16.
                    Time: 00:08:53
                    Voltage: 12.07 V
                        ABS 1
            000 - - - MIL ON
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 - - - MIL ON
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 - - - MIL ON
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
                    Fault Status: 11100101
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
Address 56: Radio
   Coding: 0001168
   VCID: 353F7F841949C912046-8060
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 363D7888044FC20A0DC-8062
End----------(Elapsed Time: 01:08, VBatt start/end: 12.2V/12.2V)-----------
------------------------------32 Faults Found------------------------------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
You can try: 114B600C492B0001881406EA92190042B70800
But only for test purpose. Please wait for @Dana check this.
ChrisSRT
C?ID=671669
I was able to get it to accept the code, but still have all the flashing lights in the dash. Here is the scan afterwards.
Sunday,25,October,2026,15:36:22:35835
Mileage: 573600km-356418mi   Repair Order:
          62 72
VIN: WVWNM7AJ0CW197960   Mileage: 573600km-356418miles
   Coding: 0050072
               U0151 - 001 -
                    Mileage: 573604 km
                    Date: 2021.03.17.
                    Time: 22:12:20
                    Voltage: 12.24 V
                    Temperature: 13.5 C
                    Temperature: 24.3 C
                    Bin. Bits: 00000000
                    Torque: 219.0 Nm
                    Temperature: 33.3 C
                    Mileage: 573604 km
                    Date: 2021.03.17.
                    Time: 22:12:22
                    (no units): 0.00
                    (no units): 0.00
                    (no units): 3.0
                    Bin. Bits: 00000011
                    (no units): 0.0
                    Mileage: 573604 km
                    Date: 2021.03.17.
                    Time: 22:14:24
                    Temperature: 13.5 C
                    Voltage: 12.31 V
                    Bin. Bits: 00000000
                    Torque: 219.0 Nm
                    Temperature: 33.3 C
   Revision: 00H31001
   Coding: 114B600C492B0001881406EA92190042B70800
                    Reset counter: 224
                    Mileage: 573604 km
                    Date: 2021.03.17.
                    Time: 22:23:54
                    Count: 3
                    Count: 2
                    Count: 320
                    Count: 44544
                    Count: 256
                    Reset counter: 224
                    Mileage: 573604 km
                    Date: 2021.03.17.
                    Time: 22:23:54
                    Count: 3
                    Count: 2
                    Count: 143
                    Count: 44544
                    Count: 256
                    Reset counter: 224
                    Mileage: 573604 km
                    Date: 2021.03.17.
                    Time: 22:23:54
                    Count: 3
                    Count: 2
                    Count: 212
                    Count: 44544
                    Count: 256
                    Reset counter: 224
                    Mileage: 573604 km
                    Date: 2021.03.17.
                    Time: 22:23:54
                    Count: 3
                    Count: 2
                    Count: 295
                    Count: 44544
                    Count: 256
                    Reset counter: 224
                    Mileage: 573604 km
                    Date: 2021.03.17.
                    Time: 22:23:54
                    Count: 3
                    Count: 2
                    Count: 8226
                    Count: 44544
                    Count: 256
   Coding: 030C0C
                    Reset counter: 248
   Revision: 00001016
   Coding: 0000001002
   Revision: 00110 AC
   Coding: 009795
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.17.
                    Time: 00:07:34
                    Voltage: 12.20 V
                        Term 50 Off
Address 15: Airbags
   Coding: 7982A00000
   Coding: E20000
0516 - Databus
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.25.
                    Time: 00:07:45
                    Fault Frequency: 108
                    Reset counter: 224
                    Mileage: 571841 km
                    Date: 2026.10.25.
                    Time: 00:07:45
                    Reset counter: 224
                    Mileage: 571841 km
                    Date: 2026.10.25.
                    Time: 00:07:45
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.25.
                    Time: 00:07:45
                    Reset counter: 9
                    Mileage: 571844 km
                    Date: 2026.10.25.
                    Time: 03:50:01
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.25.
                    Time: 00:07:45
                    UBat: 12.30 V
   Coding: 270F01
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.25.
                    Time: 00:08:02
   Coding: 350002
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.17.
                    Time: 00:08:12
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.17.
                    Time: 00:08:16
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.17.
                    Time: 00:08:16
   Coding: 000007
   Coding: 0008369
   Revision: 00H20000
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.25.
                    Time: 00:08:44
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.25.
                    Time: 00:08:44
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.25.
                    Time: 00:08:44
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.25.
                    Time: 00:08:44
                    Reset counter: 223
                    Mileage: 571841 km
                    Date: 2026.10.25.
                    Time: 00:08:44
                    Reset counter: 223
                    Mileage: 571841 km
                    Date: 2026.10.25.
                    Time: 00:08:44
   Coding: 0001204
   Coding: 1446940
   Coding: 00000255
   Coding: 00000255
                    Fault Frequency: 105
                    Reset counter: 224
                    Mileage: 571841 km
                    Date: 2021.03.17.
                    Time: 00:08:53
                    Voltage: 12.07 V
                        ABS 1
                    Reset counter: 224
                    Mileage: 571841 km
                    Date: 2021.03.17.
                    Time: 00:08:53
                    Voltage: 12.07 V
                        ABS 1
            000 - - - MIL ON
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
Address 56: Radio
   Coding: 0001168
   Coding: 0001168
End----------(Elapsed Time: 01:06, VBatt start/end: 12.1V/12.1V)-----------
------------------------------33 Faults Found------------------------------
Boki Ar
C?ID=57300
Step by step.
01279 - Longitudinal Acceleration Sensor (G251) 005 - No or Incorrect Basic Setting / Adaptation
Longitudinal Acceleration Sensor (G251)​
Prerequisites:
  • System voltage at least 12.0 V.
[Select] [03 - Brake Electronics] [Measuring Blocks - 08] Group 006 [Go!] Check field 4, the value has to be between -1.5 and +1.5 m/s². [Done, Go Back] [Security Access - 16] Enter 40168, to enable the basic setting. [Do it!] [Basic Settings - 04] Group 069 [Go!] After a successful basic setting, field 2 should say "OK". [Done, Go Back] To make sure the basic setting was successful, check the sensor again. [Measuring Blocks - 08] Group 006 [Go!] Check field 1, the value has to be between -1.5 and +1.5 m/s². [Done, Go Back] [Close Controller, Go Back - 06]
00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation
Sensor for Steering Angle (G85)​
Prerequisites:
  • Start the vehicle.
  • Turn the steering wheel one turn to the right and one turn to the left.
  • Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
  • If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
  • Ensure that the steering wheel is not moved again.
  • Keep the engine running and do not switch off the ignition.
[Select] [03 - Brake Electronics] [Measuring Blocks - 08] Group 004 [Go!] Check field 1, the value has to be between -1.5 and +1.5 °. [Done, Go Back] [Security Access - 16] Enter 40168, to enable the basic setting. [Do it!] [Basic Settings - 04] Group 060 [Go!] After a successful basic setting, field 2 should say "OK". [Done, Go Back] [Close Controller, Go Back - 06]
After this two steps we can going on.
I came up with something close:
114B400C492B0001881402EA92190042B70000
@ChrisSRT, please give the above a shot.
In addition, the slip ring (Address 16-Steering wheel) is still coded to the out of the box new condition. If you don't have a saved scan prior to that replacement the factory condition coding was likely: 100A140000
That should resolve most of the issues but the missing 15-Airbag module will need to be corrected before you make any major progress.
P.S. I just noticed you have two G85 (Steering Angle) sensors enabled and that won't work. You may need to code address 16 before the 03 basic settings are possible.
ChrisSRT
C?ID=671669
that got most of the flashing lights to go out, just have solid ABS and traction control lights. I did notice that the traction control switch appears to be stuck pressed in. Here is the scan after going through these steps.
Monday,26,October,2026,17:55:38:35835
Mileage: 573640km-356443mi   Repair Order:
          62 72
VIN: WVWNM7AJ0CW197960   Mileage: 573640km-356443miles
   Coding: 0050072
               U0151 - 001 -
                    Mileage: 573643 km
                    Date: 2021.03.18.
                    Time: 07:27:59
                    Voltage: 12.69 V
                    Temperature: 19.8 C
                    Temperature: 54.0 C
                    Bin. Bits: 00000000
                    Torque: 219.0 Nm
                    Temperature: 38.7 C
               P1647 - 000 -  - Intermittent
                    Mileage: 573643 km
                    Date: 2021.03.18.
                    Time: 07:28:01
                    (no units): 0.00
                    (no units): 0.00
                    (no units): 3.0
                    Bin. Bits: 00000100
                    (no units): 0.0
050217 - Implausible Data Received from Steering Column Control Module
               U0429 - 003 -  - Intermittent
                    Fault Status: 00100011
                    Mileage: 573643 km
                    Date: 2021.03.18.
                    Time: 07:30:57
                    (no units): 255.0
                    (no units): 255.0
                    Bin. Bits: 00000000
   Revision: 00H31001
   Coding: 114B400C492B0001881402EA92190042B70000
                    Reset counter: 225
                    Mileage: 573643 km
                    Date: 2021.03.18.
                    Time: 07:49:55
                    Count: 3
                    Count: 2
                    Count: 143
                    Count: 45056
                    Count: 511
                    Reset counter: 225
                    Mileage: 573643 km
                    Date: 2021.03.18.
                    Time: 07:49:55
                    Count: 3
                    Count: 2
                    Count: 320
                    Count: 45056
                    Count: 511
                    Reset counter: 225
                    Mileage: 573643 km
                    Date: 2021.03.18.
                    Time: 07:49:55
                    Count: 3
                    Count: 2
                    Count: 8226
                    Count: 45056
                    Count: 511
   Coding: 030C0C
                    Reset counter: 248
   Revision: 00001016
   Coding: 0000001002
   Revision: 00110 AC
   Coding: 009795
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.18.
                    Time: 00:07:34
                    Voltage: 12.20 V
                        Term 50 Off
Address 15: Airbags
   Coding: 100A140000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWSXS.rod
   Coding: E20000
   Coding: 270F01
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.26.
                    Time: 00:08:02
   Coding: 350002
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.18.
                    Time: 00:08:12
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.18.
                    Time: 00:08:16
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.18.
                    Time: 00:08:16
   Coding: 000007
   Coding: 0008369
   Revision: 00H20000
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.26.
                    Time: 00:08:44
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.26.
                    Time: 00:08:44
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.26.
                    Time: 00:08:44
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.26.
                    Time: 00:08:44
                    Reset counter: 225
                    Mileage: 571841 km
                    Date: 2026.10.26.
                    Time: 00:08:44
                    Reset counter: 225
                    Mileage: 571841 km
                    Date: 2026.10.26.
                    Time: 00:08:44
   Coding: 0001204
   Coding: 1446940
   Coding: 00000255
   Coding: 00000255
                    Fault Frequency: 116
                    Reset counter: 225
                    Mileage: 571841 km
                    Date: 2021.03.18.
                    Time: 00:08:53
                    Voltage: 12.07 V
                        ABS 1
                    Reset counter: 225
                    Mileage: 571841 km
                    Date: 2021.03.18.
                    Time: 00:08:53
                    Voltage: 12.07 V
                        ABS 1
            000 - - - MIL ON
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
Address 56: Radio
   Coding: 0001168
   Coding: 0001168
End----------(Elapsed Time: 01:06, VBatt start/end: 12.3V/12.3V)-----------
------------------------------25 Faults Found------------------------------
Boki Ar
C?ID=57300
It's OK. Now proceed:
That can happen for a number of reason (control module temp, air in the system, etc) but I've never had anyone report feedback with the 15-Airbag module offline entirely so that may be a factor.
Did that error include a code? You want to see 005 = Basic Setting active followed by 003 = Basic Setting successful but there's a large list of error codes.
Also, it this a flood repair or crash damage?
ChrisSRT
C?ID=671669
I did initially then had to restart the car and forgot to re-enter it. Thx, I'll try again in the morning.
ChrisSRT
C?ID=671669
Yes, it was a flood car. Dealer replaced airbag module shortly after we got it over 10yrs ago.
ChrisSRT
C?ID=671669
It works much better when you remember to enter the security code. All lights are now out. Thanks for all the help.
Boki Ar
C?ID=57300
Give us feedback, post new, fresh Auto Scan please. :cool:
ChrisSRT
C?ID=671669
As requested
Wednesday,28,October,2026,04:54:24:35835
          62 72
VIN: WVWNM7AJ0CW197960   Mileage: 573800km-356542miles
   Coding: 0050072
               U0151 - 001 -
                    Mileage: 573643 km
                    Date: 2021.03.20.
                    Time: 07:27:59
                    Voltage: 12.69 V
                    Temperature: 19.8 C
                    Temperature: 54.0 C
                    Bin. Bits: 00000000
                    Torque: 219.0 Nm
                    Temperature: 38.7 C
                    Mileage: 573643 km
                    Date: 2021.03.20.
                    Time: 07:28:01
                    (no units): 0.00
                    (no units): 0.00
                    (no units): 3.0
                    Bin. Bits: 00000100
                    (no units): 0.0
                    Mileage: 573643 km
                    Date: 2021.03.20.
                    Time: 07:30:57
                    (no units): 255.0
                    (no units): 255.0
                    Bin. Bits: 00000000
   Revision: 00H31001
                    Reset counter: 227
                    Mileage: 573801 km
                    Date: 2021.03.20.
                    Time: 18:47:56
                    Count: 3
                    Count: 8704
                    Count: 8226
                    Count: 51456
                    Count: 256
   Coding: 030C0C
                    Reset counter: 248
   Revision: 00001016
   Coding: 0000001002
   Revision: 00110 AC
   Coding: 009795
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.20.
                    Time: 00:07:34
                    Voltage: 12.20 V
                        Term 50 Off
Address 15: Airbags
   Coding: 100A140000
   Coding: E20000
   Coding: 270F01
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.28.
                    Time: 00:08:02
   Coding: 350002
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.20.
                    Time: 00:08:12
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.20.
                    Time: 00:08:16
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2021.03.20.
                    Time: 00:08:16
   Coding: 000007
   Coding: 0008369
   Revision: 00H20000
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.28.
                    Time: 00:08:44
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.28.
                    Time: 00:08:44
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.28.
                    Time: 00:08:44
                    Reset counter: 199
                    Mileage: 571841 km
                    Date: 2026.10.28.
                    Time: 00:08:44
                    Reset counter: 225
                    Mileage: 571841 km
                    Date: 2026.10.28.
                    Time: 00:08:44
                    Reset counter: 225
                    Mileage: 571841 km
                    Date: 2026.10.28.
                    Time: 00:08:44
   Coding: 0001204
   Coding: 1446940
   Coding: 00000255
   Coding: 00000255
                    Fault Frequency: 129
                    Reset counter: 227
                    Mileage: 571841 km
                    Date: 2021.03.20.
                    Time: 00:08:53
                    Voltage: 12.07 V
                        ABS 1
                    Reset counter: 227
                    Mileage: 571841 km
                    Date: 2021.03.20.
                    Time: 00:08:53
                    Voltage: 12.07 V
                        ABS 1
            000 - - - MIL ON
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
                    Reset counter: 199
                        Invalid
                        Invalid
                        Invalid
Address 56: Radio
   Coding: 0001168
   Coding: 0001168
End----------(Elapsed Time: 01:06, VBatt start/end: 12.4V/12.4V)-----------
------------------------------23 Faults Found------------------------------
