Issue with my Audi A4 B9 to RS4 B9.5 (2022) conversion , Exhaust Pressure Control Valve 1&2 : Regulation Fault
Maarten ten Wolde
H12-2H
HI,
I have another issue with my Audi A4 B9 to RS4 B9.5 (2022) conversion, this time concerning the exhaust flap control system.
The original vehicle had a four-cylinder engine, which has been replaced with the 2.9 TFSI V6 from the RS4 donor vehicle, including its matching engine ECU.
The engine ECU repeatedly reports the following faults:
  • P047600 – Exhaust Pressure Control Valve 1: Regulation Fault
  • P04A000 – Exhaust Pressure Control Valve 2: Regulation Fault
What I have already checked:
  • Both exhaust flaps respond to the control system.
  • The exhaust sound clearly changes when switching between Comfort and RS mode.
  • VCDS displays position feedback values for both exhaust flaps, ranging approximately from 10% to 90%.
  • I performed the Basic Settings adaptation procedures for exhaust flap 1 and exhaust flap 2.
  • Both adaptations completed successfully with the result "OK".
  • After clearing the fault codes, both P047600 and P04A000 eventually return.
Since the original RS4 engine ECU was installed together with the V6 engine, I would not expect an ECU mismatch caused by the original four-cylinder configuration.
I also found Audi TSB 2058998/3 (26-21-45), which describes similar fault codes associated with mechanical issues in the exhaust flap system.
My questions:
  1. What conditions cause the ECU to register P047600 and P04A000 even though both exhaust flaps operate and their adaptations complete successfully?
  2. Are there specific VCDS measuring values that can help identify regulation deviations, such as requested versus actual flap position?
  3. Could mechanical play or excessive resistance in the flap mechanisms cause these faults despite apparently normal operation and position feedback?
  4. Are there known issues with the exhaust flap actuators or their mechanical couplings on the 2.9 TFSI V6?
  5. Is there an applicable Audi technical bulletin, ECU software update, or additional diagnostic procedure that could help identify the cause?
I would appreciate any advice on diagnosing these faults before replacing any components.
Thank you for your assistance!
