2015 Golf Mk7 - Front Air Distribution Flap Basic Settings
Cuzoe
C?ID=279487
I'm going to put this in Car Repair as I think that's more appropriate than retrofits (for the problem I'm having).
Background for info, not sure how relevant it is... I've got a 2015 Golf Mk7 that for all intents and purposes now has climatronic. Harness was replace, all temp sensors are present, sun sensor is present, motors have been replaced where needed. I have even mounted the passenger side temperature door motor onto the side of the box. There is no separate flap for passenger side temp (internal to the box) but mounting the motor there clears the fault and end stop calibration for this motor is good (albeit the motor is not connected to any flap/gear).
One part of the retrofit (which has been completed) is disconnecting an arm at what was the air distribution linkage and replacing the gear associated with that linkage. For more background information, a motor gets added to other side of the box. This allows separate/independent distribution of air to feet/vents/windshield. Climatronic allows this, while climatic only allowed two of the three to be selected at once. Anyway, all that is done.
I'm left with one fault that will not clear (full scan that includes this fault is at the end of the post)
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 17G 907 044 P    HW: 17G 907 044 P
   Component: AC Automat    H02 1202
   Revision: 20K07000    Serial number: 00000A00811510
   Coding: 000101041021000D0115004D1215584A
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ACTouchPrehVW37X 001010
   ROD: EV_ACTouchPrehVW37X_VW37.rod
   VCID: 372B24C31FC2EB5216A-8062
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
   Component: G935 MuFu  H05 0010
   Serial number: AC4086BA00PAG0MUFU05
   Micro particle content sensor:
328965 - Motor for Front Air Distribution Flap
          B1091 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 164
                    Mileage: 115294 km
                    Date: 2026.10.23
                    Time: 14:15:57
                    Voltage terminal 30: 13.2 V
                    Inside temperature: 26.6  C
                    Outside temperature: 23.0  C
                    Front air distribution flap: actual value: 0.0 %
                    Front air distribution flap: actual value: 646
                    Air distribution door front - Specified value: 310
So far I have tried three motors...
- Two were the part number originally in the car, 5Q0907511L
--- One of these from my car originally, the second from the donor climatronic box I used to steal parts
- The third, installed today, is PN 2Q0907511F which supersedes the 5Q0 PN.
I have checked the wiring between this motor and the climatronic panel, twice...
- Once while doing the retrofit, and again today
- Continuity is good, nothing shorted to ground, nothing shorted to each other
I have now had two different HVAC panels installed
- This was not done specifically to T/S this issue, but I would think rules out the panel.
I've run flap end stop basic settings with VCDS several times. It always completes with "Finished correctly" as expected. No weird sounds. With the foot vent and duct removed I can see the flap moving smoothly. I should also note that air is going where it should (tested all combinations). I also went though the Guided Function for this fault in ODIS. It recommended the flap end stop basic settings, which again completed correctly. Fault still doesn't clear, and ODIS recommends replacing the motor (which has been done) and wiring checks of course (which have also been done).
Anybody got ideas? At this point I'll try almost anything :p.
Full autoscan here...
Friday,23,October,2026,14:18:44:63230
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.4
VIN: 3VWRA7AU8FM089964   License Plate: PH1DONE
Mileage: 115294km-71640mi   Repair Order: A5-GolfModDataset
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 14 15 16 17 19 3C 42 44 52 5F 65 6C 75 A5
          A9 C0
VIN: 3VWRA7AU8FM089964   Mileage: 115294km-71640miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 C    HW: 04L 907 309
   Component: R4 2.0l TDI   X23 9282
   Revision: 85X23---    CVN: 4ACF405238D3FF82
   Coding: 01190032034410082000
   ASAM Dataset: EV_ECM20TDI01104L906021C 004014
   ROD: EV_ECM20TDI01104L906021C_004.rod
   VCID: 2517FE8BB56E69C2B46-8070
   VINID: 0E69E244746521674020924610A3CA1BB5
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 63045000003112
   Coding: 01FA62A1342809750780020641C72580462C90E04082A4B53462F080D6A9
   VCID: 79AFE2FB69563D22A0E-802C
   Air quality sensor:
                    Reset counter: 164
                    Mileage: 115294 km
                    Date: 2026.10.23
                    Time: 14:15:57
   Part No SW: 5Q0 937 085 CC    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H42 0312
   Serial number: 02002015400607 Dataset Number: V03935334VV 0001
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 7CA1FBEF6664080ABB8-8028
   Component: WWS    150131  043  0581
   Serial number:         150422094212
   Coding: 0F4DDD
   Component: RLHS  052  0107
   Serial number: SAY19M03D14H11M30S54
   Coding: 06A8DD
   Subsystem 3 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12  0300
   Serial number: 0000009600373Z025202
   Coding: 350000
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY1718331QX
   Component: Sirene, DWA  005  0314
   Serial number: 00002856223980613271
   Subsystem 6 - Part No SW: 3G0 947 105 C    HW: 3G0 947 105 C
   Component: J528 Dachelek  H08  0009
   Serial number: 20022000010068C
   Coding: F38380
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0073
   Serial number: 000308417618043 Dataset Number: V03935336AG 0002
   Coding: 0271263801
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   VCID: 58E9877FB29C042AFF0-800C
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 R    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0771
   Dataset Number: VagRetrofit K011
   Coding: 2D1D78E1DFEFCC28979F81A461400000000000000099400020
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003_VW37.rod
   VCID: 46D55907682882DA9DC-8012
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 12121641350313 Dataset Number: V03935274AH 0001
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 392F22FB29D6FD22E0E-806C
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM022VY4 Dataset Number: 5GM003V____ 0041
   Shop #: WSC 01383 790 50316
   VCID: 51FF7A5B9166556238E-8004
   Serial number: IBH0000J150002LIO90G
   Coding: 303138
   Subsystem 2 - Part No SW: -----------    HW: 480 000 303 15
   Serial number: 3570000000068B89231K
   Subsystem 3 - Part No SW: -----------    HW: 480 000 203 15
   Serial number: 3580000000029C3D531L
   Subsystem 4 - Part No SW: -----------    HW: 480 400 403 15
   Serial number: 3510002B51941314E32Q
   Subsystem 5 - Part No SW: -----------    HW: 480 401 602 15
   Serial number: 3520002A91993FC34179
   Subsystem 6 - Part No SW: -----------    HW: 480 400 603 15
   Serial number: 3550002B91941314423O
   Subsystem 7 - Part No SW: -----------    HW: 480 400 203 15
   Serial number: 3560002C319DB8A371EM
   Part No SW: 5Q0 953 569 C    HW: 5Q0 953 569 C
   Component: Lenks.Modul   100 0265
   Revision: --------    Serial number: 20220303500059
   Coding: 0800
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 3E2531E730F8DA1AD5C-806A
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 A
   Component: KOMBI         409 4191
   Coding: 03AD1182768CCF0502807F0F4801040000000000
   Shop #: WSC 00046 123 12345
   VCID: 2B0308B3D38A5FB2622-807E
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5502
   Serial number: 11102000840992 Dataset Number: SET_FPA_MOD 0001
   Coding: 0309000810087300DBEC92FDFF0F00000000050000000000000000000000
   GVL: 015C3C100000000040CC800090024C0000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5B0CE3777213129EA-802A
   Generator:
   Component: 4-01-03-01-04
   Subsystem 2 - Part No SW: 1EA 959 442 B    HW: 1EA 959 442 B
   Component: MFL  H03 0217
   Serial number: 17036218091972202784
   Coding: AE0300
   Serial number: 7588600000170512106B
   Serial number: 0429044488 Dataset Number: V03935217RX 0027
   Coding: 01021103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C213BEF26E4C80AFB8-8068
   Serial number: 0428038074
   Coding: 010211
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-DCD-V1.clb
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 4502134100127  Dataset Number: 5GG222v____ 0017
   Coding: 00150320DE00040000000000
   VCID: 44D1430F5E14B0CA838-8010
   Serial number: 00000000000001032600
   Coding: 011000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Dataset Number: 8V0909852AA 0001
   Coding: 975F0000
   Shop #: WSC 06325 790 00021
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 4605152520319  Dataset Number: 5GG157v____ 0017
   VCID: 43D340135B1AB7F2BA2-8016
   Serial number: 00000000000001037608
   Coding: 091000
   Part No SW: 5NA 035 026 D    HW: 5NA 035 026
   Component: MU-H-NS-US    H55 1418
   Serial number: A851D0MP000061 Dataset Number: 5G0CV1v____ 0001
   Coding: 027313020000000011220001001B00202F0002E501200004FE
   VCID: 382927FF12DCE42A1F0-806C
   Subsystem 1 - Part No SW: 5G6 919 606 B    HW: 5G6 919 606 B
   Component: ABT_High-2  H61 9214
   Serial number: VWZ6ZJX0573427
   Subsystem 2 - Part No SW: V03 959 821 DD    HW: -----------
   Component: NAR 2025  --- 0397
   Compact disc data bank:
   Component: Gracenote2  --- 3013
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H06 0011
   Serial number: 40000000530628 Dataset Number: 5Q0907273B
   ROD: EV_RDKBERU30_006_VW37.rod
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG040409 Dataset Number: V03935238ER 0001
   Coding: 01731202D60FA3004C716057
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
10489856 - No Basic Setting
          B2010 00 [00001001] - -
                    Reset counter: 164
                    Mileage: 115294 km
                    Date: 2026.10.23
                    Time: 14:15:57
9617993 - Rear Surroundings Camera
          B127D 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 164
                    Mileage: 115294 km
                    Date: 2026.10.23
                    Time: 14:15:57
9618001 - Right Surroundings Camera
          B127F 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 164
                    Mileage: 115294 km
                    Date: 2026.10.23
                    Time: 14:15:57
Address 75: Telematics (J949)       Labels:| 5QE-035-28X-V1.clb
   Component: OCULowMQBUS   007 0564
   Dataset Number: 561098V____ 0408
   Coding: 02730002C2821A017F1E06000000
   Shop #: WSC 00066 790 00322
   ROD: EV_OCULowMQB_VW37.rod
   Part No SW: 2Q0 980 653 J    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H13 1423
   Serial number: E57829511211370 Dataset Number: V03935436AM 0001
   Coding: 00000A9021CEC028889F04801000002000430000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   Part No SW: 8W0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0006
   Serial number: 150619202424
   VCID: 42DD45174400BEFAB14-8016
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8W0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0001
   Serial number: 150404200004
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS_VW37.rod
   VCID: 76B5E9C75848525ACDC-8022
End----------(Elapsed Time: 01:56, VBatt start/end: 13.1V/13.1V)-----------
------------------------------4 Faults Found-------------------------------
And adaptation map of 08-HVAC here...
;SW:17G-907-044-P   HW:17G-907-044-P ---  08: Auto HVAC
;Component:AC Automat    H02 1202     Coding:000101041021000D0115004D1215584A
;EV_ACTouchPrehVW37X    1010    EV_ACTouchPrehVW37X_VW37.rod
;Friday    23    October
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 372B24C31FC2EB5216A-8062
IDE00001-Production mode    Deactivating     3
IDE01067-Retention of driver's seat heater level    active     1
IDE01478-Ignore compressor switch-off by Engine Control Module    Do not ignore     1
IDE01479-Gear ratio of engine - A/C compressor    0    1
IDE01483-Blower voltage with voice control    not activated     1
IDE01488-Auxiliary heating retrofit without CAN    not installed     1
IDE01493-Sensitivity of air quality sensor    Maximum     1
IDE01503-Running time of basic setting for compressor break-in    120 s    1
IDE01536-Post heating of auxiliary heating    0 min    1
IDE02155-Reset all counters    not activated     1
IDE02332-Deactivate production mode    0    3
IDE03176-Duration of compressor run in    60 s    1
IDE03251-Stop enable for Start/Stop function    According to function requirements     1
IDE04159-Deactivation of start/stop function    not active     1
IDE06097-Target temperature of A/C - heater function via remote control    22.0 °C    1
IDE06544-Speed shut-off threshold for compressor break-in (engine speed)    1500 /min    1
IDE06545-Blower voltage for production routines    6.0 V    1
IDE06546-Interior specified temperature for production routines    22 °C    1
IDE06547-Air distribution for production routines    No effect     1
IDE06593-Air recirculation for production routines    No effect     1
IDE07108-A/C styles    Matching coding     1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module    20 min    2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus    30 min    2
IDE07301-Remote start function: activation of seat heating    Seat heating: front     1
IDE07302-Remote start function: interior climate control status    Remote start function with fixed rated temperature active     1
IDE07304-Remote start function: activation of seat ventilation    activated     1
IDE07305-Rem. start funct.: activat.temper. of seat heating    15 °C    1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation    20 °C    1
IDE07307-Remote start function: activation stage of seat heating    level 2     1
IDE07308-Remote start function: activation stage of seat ventilation    level 2     1
IDE07398-Blower logic with manual adjustment    Matching coding     1
IDE07585-Hand heater function during cold start    active     1
IDE07865-Automatic activation of front windshield defroster at MAX-Defrost    active     1
IDE07948-Retention of frt.pass. seat heater level    not active     1
IDE12229-Filtering of interior air: store    Service life-dependent store     1
IDE13676-Remote start function: rear window defogger    activated     1
IDE13677-Remote start function: seat climate control takeover    activated     1
MAS06405-Compressor switch-on reduction    Matching coding     1
MAS06564-Window condensation exterior reduction at high humidity    Matching coding     1
MAS14860-Remote start function: windshield defogger takeover    activated     1
MAS14861-Remote start function: windshield defogger    activated     1
MAS17226-Remote start function: windshield defogger can be activated    activated     1
ENG253366-22_degree_jump_temp_slider    not active     1
ENG253361-ENG259594-damping_dimming_characteristic_01-PWM_Daempfung_Abdimmen    0.1 s    2
ENG253361-ENG259617-damping_dimming_characteristic_01-PWM_Daempfung_Aufdimmen    0.2 s    2
ENG253227-ENG259594-damping_dimming_characteristic_02-PWM_Daempfung_Abdimmen    0.1 s    2
ENG253227-ENG259617-damping_dimming_characteristic_02-PWM_Daempfung_Aufdimmen    0.2 s    2
ENG253281-ENG259594-damping_dimming_characteristic_03-PWM_Daempfung_Abdimmen    0.1 s    2
ENG253281-ENG259617-damping_dimming_characteristic_03-PWM_Daempfung_Aufdimmen    0.2 s    2
ENG253266-ENG259594-damping_dimming_characteristic_04-PWM_Daempfung_Abdimmen    0.1 s    2
ENG253266-ENG259617-damping_dimming_characteristic_04-PWM_Daempfung_Aufdimmen    0.2 s    2
ENG252011-Detection_time_hold    600 ms    1
ENG252012-Detection_time_tap    600 ms    1
ENG122844-ENG101574-dimming_characteristic_1-X1    0    12
ENG122844-ENG99557-dimming_characteristic_1-X2    6    12
ENG122844-ENG102140-dimming_characteristic_1-X3    40    12
ENG122844-ENG102936-dimming_characteristic_1-X4    60    12
ENG122844-ENG103548-dimming_characteristic_1-X5    80    12
ENG122844-ENG113992-dimming_characteristic_1-X6    100    12
ENG122844-ENG99777-dimming_characteristic_1-Y1    0%    12
ENG122844-ENG100480-dimming_characteristic_1-Y2    6%    12
ENG122844-ENG100773-dimming_characteristic_1-Y3    40%    12
ENG122844-ENG100631-dimming_characteristic_1-Y4    60%    12
ENG122844-ENG102174-dimming_characteristic_1-Y5    80%    12
ENG122844-ENG113993-dimming_characteristic_1-Y6    100%    12
ENG122845-ENG101574-dimming_characteristic_2-X1    0    12
ENG122845-ENG99557-dimming_characteristic_2-X2    10    12
ENG122845-ENG102140-dimming_characteristic_2-X3    50    12
ENG122845-ENG102936-dimming_characteristic_2-X4    100    12
ENG122845-ENG103548-dimming_characteristic_2-X5    220    12
ENG122845-ENG113992-dimming_characteristic_2-X6    253    12
ENG122845-ENG99777-dimming_characteristic_2-Y1    2%    12
ENG122845-ENG100480-dimming_characteristic_2-Y2    2%    12
ENG122845-ENG100773-dimming_characteristic_2-Y3    10%    12
ENG122845-ENG100631-dimming_characteristic_2-Y4    21%    12
ENG122845-ENG102174-dimming_characteristic_2-Y5    85%    12
ENG122845-ENG113993-dimming_characteristic_2-Y6    100%    12
ENG122846-ENG101574-dimming_characteristic_3-X1    0    12
ENG122846-ENG99557-dimming_characteristic_3-X2    10    12
ENG122846-ENG102140-dimming_characteristic_3-X3    50    12
ENG122846-ENG102936-dimming_characteristic_3-X4    100    12
ENG122846-ENG103548-dimming_characteristic_3-X5    220    12
ENG122846-ENG113992-dimming_characteristic_3-X6    253    12
ENG122846-ENG99777-dimming_characteristic_3-Y1    2%    12
ENG122846-ENG100480-dimming_characteristic_3-Y2    2%    12
ENG122846-ENG100773-dimming_characteristic_3-Y3    5%    12
ENG122846-ENG100631-dimming_characteristic_3-Y4    10%    12
ENG122846-ENG102174-dimming_characteristic_3-Y5    85%    12
ENG122846-ENG113993-dimming_characteristic_3-Y6    100%    12
ENG122847-ENG101574-dimming_characteristic_4-X1    0    12
ENG122847-ENG99557-dimming_characteristic_4-X2    10    12
ENG122847-ENG102140-dimming_characteristic_4-X3    50    12
ENG122847-ENG102936-dimming_characteristic_4-X4    100    12
ENG122847-ENG103548-dimming_characteristic_4-X5    220    12
ENG122847-ENG113992-dimming_characteristic_4-X6    253    12
ENG122847-ENG99777-dimming_characteristic_4-Y1    2%    12
ENG122847-ENG100480-dimming_characteristic_4-Y2    2%    12
ENG122847-ENG100773-dimming_characteristic_4-Y3    5%    12
ENG122847-ENG100631-dimming_characteristic_4-Y4    10%    12
ENG122847-ENG102174-dimming_characteristic_4-Y5    85%    12
ENG122847-ENG113993-dimming_characteristic_4-Y6    100%    12
ENG122848-ENG101574-dimming_characteristic_5-X1    0    12
ENG122848-ENG99557-dimming_characteristic_5-X2    10    12
ENG122848-ENG102140-dimming_characteristic_5-X3    50    12
ENG122848-ENG102936-dimming_characteristic_5-X4    100    12
ENG122848-ENG103548-dimming_characteristic_5-X5    220    12
ENG122848-ENG113992-dimming_characteristic_5-X6    253    12
ENG122848-ENG99777-dimming_characteristic_5-Y1    2%    12
ENG122848-ENG100480-dimming_characteristic_5-Y2    2%    12
ENG122848-ENG100773-dimming_characteristic_5-Y3    5%    12
ENG122848-ENG100631-dimming_characteristic_5-Y4    10%    12
ENG122848-ENG102174-dimming_characteristic_5-Y5    85%    12
ENG122848-ENG113993-dimming_characteristic_5-Y6    100%    12
ENG253208-ENG101574-dimming_characteristic_new_1-X1    0    18
ENG253208-ENG99557-dimming_characteristic_new_1-X2    10    18
ENG253208-ENG102140-dimming_characteristic_new_1-X3    50    18
ENG253208-ENG102936-dimming_characteristic_new_1-X4    100    18
ENG253208-ENG103548-dimming_characteristic_new_1-X5    150    18
ENG253208-ENG113992-dimming_characteristic_new_1-X6    253    18
ENG253208-ENG99777-dimming_characteristic_new_1-Y1    16 ‰    18
ENG253208-ENG100480-dimming_characteristic_new_1-Y2    16 ‰    18
ENG253208-ENG100773-dimming_characteristic_new_1-Y3    60 ‰    18
ENG253208-ENG100631-dimming_characteristic_new_1-Y4    125 ‰    18
ENG253208-ENG102174-dimming_characteristic_new_1-Y5    500 ‰    18
ENG253208-ENG113993-dimming_characteristic_new_1-Y6    1000 ‰    18
ENG253101-ENG101574-dimming_characteristic_new_10-X1    0    18
ENG253101-ENG99557-dimming_characteristic_new_10-X2    10    18
ENG253101-ENG102140-dimming_characteristic_new_10-X3    50    18
ENG253101-ENG102936-dimming_characteristic_new_10-X4    100    18
ENG253101-ENG103548-dimming_characteristic_new_10-X5    150    18
ENG253101-ENG113992-dimming_characteristic_new_10-X6    253    18
ENG253101-ENG99777-dimming_characteristic_new_10-Y1    10 ‰    18
ENG253101-ENG100480-dimming_characteristic_new_10-Y2    10 ‰    18
ENG253101-ENG100773-dimming_characteristic_new_10-Y3    25 ‰    18
ENG253101-ENG100631-dimming_characteristic_new_10-Y4    50 ‰    18
ENG253101-ENG102174-dimming_characteristic_new_10-Y5    800 ‰    18
ENG253101-ENG113993-dimming_characteristic_new_10-Y6    1000 ‰    18
ENG253345-ENG101574-dimming_characteristic_new_2-X1    0    18
ENG253345-ENG99557-dimming_characteristic_new_2-X2    10    18
ENG253345-ENG102140-dimming_characteristic_new_2-X3    25    18
ENG253345-ENG102936-dimming_characteristic_new_2-X4    50    18
ENG253345-ENG103548-dimming_characteristic_new_2-X5    75    18
ENG253345-ENG113992-dimming_characteristic_new_2-X6    100    18
ENG253345-ENG99777-dimming_characteristic_new_2-Y1    0 ‰    18
ENG253345-ENG100480-dimming_characteristic_new_2-Y2    100 ‰    18
ENG253345-ENG100773-dimming_characteristic_new_2-Y3    250 ‰    18
ENG253345-ENG100631-dimming_characteristic_new_2-Y4    500 ‰    18
ENG253345-ENG102174-dimming_characteristic_new_2-Y5    750 ‰    18
ENG253345-ENG113993-dimming_characteristic_new_2-Y6    1000 ‰    18
ENG253211-ENG101574-dimming_characteristic_new_3-X1    0    18
ENG253211-ENG99557-dimming_characteristic_new_3-X2    10    18
ENG253211-ENG102140-dimming_characteristic_new_3-X3    50    18
ENG253211-ENG102936-dimming_characteristic_new_3-X4    100    18
ENG253211-ENG103548-dimming_characteristic_new_3-X5    150    18
ENG253211-ENG113992-dimming_characteristic_new_3-X6    253    18
ENG253211-ENG99777-dimming_characteristic_new_3-Y1    6 ‰    18
ENG253211-ENG100480-dimming_characteristic_new_3-Y2    6 ‰    18
ENG253211-ENG100773-dimming_characteristic_new_3-Y3    12 ‰    18
ENG253211-ENG100631-dimming_characteristic_new_3-Y4    25 ‰    18
ENG253211-ENG102174-dimming_characteristic_new_3-Y5    100 ‰    18
ENG253211-ENG113993-dimming_characteristic_new_3-Y6    300 ‰    18
ENG253234-ENG101574-dimming_characteristic_new_4-X1    0    18
ENG253234-ENG99557-dimming_characteristic_new_4-X2    10    18
ENG253234-ENG102140-dimming_characteristic_new_4-X3    50    18
ENG253234-ENG102936-dimming_characteristic_new_4-X4    100    18
ENG253234-ENG103548-dimming_characteristic_new_4-X5    150    18
ENG253234-ENG113992-dimming_characteristic_new_4-X6    253    18
ENG253234-ENG99777-dimming_characteristic_new_4-Y1    20 ‰    18
ENG253234-ENG100480-dimming_characteristic_new_4-Y2    20 ‰    18
ENG253234-ENG100773-dimming_characteristic_new_4-Y3    60 ‰    18
ENG253234-ENG100631-dimming_characteristic_new_4-Y4    120 ‰    18
ENG253234-ENG102174-dimming_characteristic_new_4-Y5    800 ‰    18
ENG253234-ENG113993-dimming_characteristic_new_4-Y6    1000 ‰    18
ENG253181-ENG101574-dimming_characteristic_new_5-X1    0    18
ENG253181-ENG99557-dimming_characteristic_new_5-X2    10    18
ENG253181-ENG102140-dimming_characteristic_new_5-X3    50    18
ENG253181-ENG102936-dimming_characteristic_new_5-X4    100    18
ENG253181-ENG103548-dimming_characteristic_new_5-X5    150    18
ENG253181-ENG113992-dimming_characteristic_new_5-X6    253    18
ENG253181-ENG99777-dimming_characteristic_new_5-Y1    10 ‰    18
ENG253181-ENG100480-dimming_characteristic_new_5-Y2    10 ‰    18
ENG253181-ENG100773-dimming_characteristic_new_5-Y3    50 ‰    18
ENG253181-ENG100631-dimming_characteristic_new_5-Y4    100 ‰    18
ENG253181-ENG102174-dimming_characteristic_new_5-Y5    1000 ‰    18
ENG253181-ENG113993-dimming_characteristic_new_5-Y6    1000 ‰    18
ENG253303-ENG101574-dimming_characteristic_new_6-X1    0    18
ENG253303-ENG99557-dimming_characteristic_new_6-X2    10    18
ENG253303-ENG102140-dimming_characteristic_new_6-X3    50    18
ENG253303-ENG102936-dimming_characteristic_new_6-X4    100    18
ENG253303-ENG103548-dimming_characteristic_new_6-X5    150    18
ENG253303-ENG113992-dimming_characteristic_new_6-X6    253    18
ENG253303-ENG99777-dimming_characteristic_new_6-Y1    4 ‰    18
ENG253303-ENG100480-dimming_characteristic_new_6-Y2    4 ‰    18
ENG253303-ENG100773-dimming_characteristic_new_6-Y3    15 ‰    18
ENG253303-ENG100631-dimming_characteristic_new_6-Y4    30 ‰    18
ENG253303-ENG102174-dimming_characteristic_new_6-Y5    600 ‰    18
ENG253303-ENG113993-dimming_characteristic_new_6-Y6    1000 ‰    18
ENG253035-ENG101574-dimming_characteristic_new_7-X1    0    18
ENG253035-ENG99557-dimming_characteristic_new_7-X2    10    18
ENG253035-ENG102140-dimming_characteristic_new_7-X3    50    18
ENG253035-ENG102936-dimming_characteristic_new_7-X4    100    18
ENG253035-ENG103548-dimming_characteristic_new_7-X5    150    18
ENG253035-ENG113992-dimming_characteristic_new_7-X6    253    18
ENG253035-ENG99777-dimming_characteristic_new_7-Y1    20 ‰    18
ENG253035-ENG100480-dimming_characteristic_new_7-Y2    20 ‰    18
ENG253035-ENG100773-dimming_characteristic_new_7-Y3    50 ‰    18
ENG253035-ENG100631-dimming_characteristic_new_7-Y4    100 ‰    18
ENG253035-ENG102174-dimming_characteristic_new_7-Y5    800 ‰    18
ENG253035-ENG113993-dimming_characteristic_new_7-Y6    1000 ‰    18
ENG253316-ENG101574-dimming_characteristic_new_8-X1    0    18
ENG253316-ENG99557-dimming_characteristic_new_8-X2    10    18
ENG253316-ENG102140-dimming_characteristic_new_8-X3    50    18
ENG253316-ENG102936-dimming_characteristic_new_8-X4    100    18
ENG253316-ENG103548-dimming_characteristic_new_8-X5    150    18
ENG253316-ENG113992-dimming_characteristic_new_8-X6    253    18
ENG253316-ENG99777-dimming_characteristic_new_8-Y1    8 ‰    18
ENG253316-ENG100480-dimming_characteristic_new_8-Y2    8 ‰    18
ENG253316-ENG100773-dimming_characteristic_new_8-Y3    20 ‰    18
ENG253316-ENG100631-dimming_characteristic_new_8-Y4    25 ‰    18
ENG253316-ENG102174-dimming_characteristic_new_8-Y5    600 ‰    18
ENG253316-ENG113993-dimming_characteristic_new_8-Y6    1000 ‰    18
ENG253075-ENG101574-dimming_characteristic_new_9-X1    0    18
ENG253075-ENG99557-dimming_characteristic_new_9-X2    10    18
ENG253075-ENG102140-dimming_characteristic_new_9-X3    50    18
ENG253075-ENG102936-dimming_characteristic_new_9-X4    100    18
ENG253075-ENG103548-dimming_characteristic_new_9-X5    150    18
ENG253075-ENG113992-dimming_characteristic_new_9-X6    253    18
ENG253075-ENG99777-dimming_characteristic_new_9-Y1    14 ‰    18
ENG253075-ENG100480-dimming_characteristic_new_9-Y2    14 ‰    18
ENG253075-ENG100773-dimming_characteristic_new_9-Y3    32 ‰    18
ENG253075-ENG100631-dimming_characteristic_new_9-Y4    41 ‰    18
ENG253075-ENG102174-dimming_characteristic_new_9-Y5    800 ‰    18
ENG253075-ENG113993-dimming_characteristic_new_9-Y6    1000 ‰    18
ENG253022-Flick_function_temp_slider    not active     1
ENG248446-HMI_View_Switch    No     1
ENG252027-Off_time_neighbor_key_during_sliding    400 ms    1
ENG253172-Profile_selection_touch    0    1
ENG153708-Remotestart_window_heating_temperature    4    1
ENG252031-Sensitivity_touch    0    1
ENG253135-Step_size_temp_slider    1°C     1
ENG253291-Steps_temp_slider    4    1
ENG264036-Sun_sensor_supplier_differentiation    none     1
ENG276151-Touch_sound_on_off    active     1
Elapsed Time: 00:21
TTT
C?ID=547002
It should not be too difficult. This is a motor and a feedback potentiometer.
Stuff an oscilloscope in the potentiometer signal wire, do the basic settings, compare your car with known good.
Then it should be very much clear why it fails.
Cuzoe
C?ID=279487
Do you have a known good car I can borrow? And an oscilloscope? I'm only kidding, sort of. That is one way to isolate the issue but not all that practical. I happen to have access an oscilloscope at work. But I don't have access to another Mk7.
At the moment I'm thinking maybe slave a wire in place of the blue/white wire. This is the schematic for the motor in question. Thoughts?
The splice point for the purple wire and brown wire are other potential problem spots. Although maybe a bit less likely since these are shared with all the other motors.
TTT
C?ID=547002
Isn't my Ateca a raised golf mk7? Can't imagine that the climate control differs. In my schematics is also G642 called and lands in T16c/5 as yours. You're in? I can record with Picoscope and you compare?
Purple must be 5V and brown 0V. Easy to check.
Cuzoe
C?ID=279487
I expect you're right that they have the same climate control.
I did check the brown (ground) for continuity to T16c/1, good.
I checked purple for continuity to T16c/14, good. But did not check for 5V.
If you have a chance to check yours I would appreciate it. No pressure or rush.
I won't be able to check anything until after the weekend anyway. Also in case I forget to say it later, I appreciate the help and thinking through it with me.
TTT
C?ID=547002
Tomorrow morning, about 10:00 AMS time. I've removed the climate control previously, easy peasy. I also used your knowledge from other posts you wrote.
Cuzoe
C?ID=279487
Yes, in the Golf the HVAC panel is easy too. The motor connector is not very difficult either. Just a bit tedious... Lower dash panel out, driver footwell duct. I think it was easier to lay on my back in the footwell when I was younger 😂.
TTT
C?ID=547002
I applied a low pass filter, original signal is a bit noisy. If you want the psdata file, can be opened for free with the picoscope software, let me know. Before hitting the Go button, climate control was set to Auto, engine running. Finished correctly. No faults. Signal at 2.6V prior and after adapt door end stops. Measured against the battery minus, as Bernie always advises. Measured at the climate control panel plug, as it should be. I think, if there is foam at door stops, that the one at the top side of the voltage, is gone, I would of expected 4.5V max, and possibly door traveled slightly more. At the bottom, you can see door pushing against the foam and slowly compressing it, as the voltage has a slow ramp down shape.
Failing that for you, I mean you see the same waveform, but still get faults, is then to measure against air distribution direction. If the voltage is not where it needs to be, then the brain box will see it as out of tolerances, and trigger Basic Settings fault code. I think this is more likely. And possibly caused by mechanical wear and tear.
But why would be the flap at 0% in the fault code freeze frame data, unless the brain box cleared the learned values... otherwise I don't expect the door to move when vehicle is turned off? Is the brain box supplied correctly with terminal 30 supply, for its memory?
Cuzoe
C?ID=279487
Thank you, that is very helpful. As far as the mesaured percentage showing 0% in the freeze frame data I'm not sure. Terminal 30 at 13.2 makes me think engine was off. My shop power supply with output at 13.6 usually shows somewhere around 13.2 in the car. But I guess that 0% is the reason the calibration fault still exists.
Should the mesaured flap and measured door positions match? They are off in the most recent freeze frame data.
This is freeze frame data from earlier in the week. Before I replaced the motor and HVAC panel. Still symmetric percent at 0, but flap and door are matched. Terminal 30 voltage ar 13.9 so probably engine running.
   Part No SW: 5NA 907 044 AJ    HW: 5NA 907 044 AJ
   Component: AC Automat    H50 1301
   Revision: 20K03000    Serial number: 00000A00401890
   Coding: 000101041021000D0115004D1214584A
   VCID: 074B94032FA25BD2A6A-8052
   Air quality sensor:
                    Reset counter: 155
                    Mileage: 115136 km
                    Date: 2026.10.15
                    Time: 16:30:25
                    Voltage terminal 30: 13.9 V
                    Inside temperature: 28.1 �C
                    Outside temperature: 34.5 �C
                    Front air distribution flap: actual value: 94
                    Air distribution door front - Specified value: 91
TTT
C?ID=547002
It could be a bad connection which flips the voltage quick and comes back, more like a pin fitment issue showing itself with car vibrations, or flap door just getting mechanically stuck.
Stay focused, get the waveform measured 1st, to eliminate the calibration process doubts.
Cuzoe
C?ID=279487
As luck would have it the oscilloscope at work is out for calibration so won't have access to it for at least another week.
I'm relatively sure the door is not stuck. When I removed the motor I was able to open and close the door (or at least the one that I can see) moving the gear by hand. And then with the motor installed I could see that door opening and closing during the calibration process (this is with the footwell duct and the little coupling with the temp sensor removed, both had to be removed to access the motor).
I suppose I could confirm the voltage is present (and about 2.6V) at that plug. Won't be able to confirm the waveform but could set the meter to show me the max value. And then to show the minimum. Suppose I could also watch those same values for one of the motors and see what it looks like.
TTT
C?ID=547002
Try, nothing to loose, the signal is slow moving. But to to trace a fast losing signal, later an oscilloscope is needed.
Aerofan
C?ID=647191
I know it sounds crazy but wouldn't be easier to check if there is a new SW for the HVAC module and flash it before you measure all the signals in the car? :D
I had some weird failure codes in the car which were gone after flashing the gateway. I am on MQB Evo but maybe it works for you as well.
TTT
C?ID=547002
You're mixing apples with pears. It might work for a fruit salad, but no more than that.
Cuzoe
C?ID=279487
I wonder if I do actually have something going on with the door. First this assumes that the specified (and therefore actual) value for all the doors should go from somewhere around 90 to somewhere around 900. That's what I see in measuring values for the other doors.
And measuring value for the stops for those doors seem to be somewhere in that range (some as low as in the 70s or as high as 920s) and when you run the calibration the stop values clear out momentarily. The system commands one direction and as soon as it hits the stop in that direction it commands the other. And then saves the actual value achieved as the stops and fills those values in again. For a given motor that I was watching the end stops are not always the same but they are always pretty close. And the actual value percentage will go from 0% to 100% while the calibration runs.
Now, for my problem motor when the specified value is commanded to the low value (91) it gets there. Actual value got down to 88 (with corresponding actual value of 100%). But when specified value is commanded to the high side (952) it consistently stops around 650 (with corresponding actual value of about 35%). At the end of the routine the stop values are not saved for this motor (hence the fault).
I'm going to assume since the basic settings is commanding this to 950 then it should reach something close to that value (and corresponding 0%). And since it doesn't reach that (stops are not saved) basic calibration it's never completed.
It still wouldn't hurt to see what the oscilloscope shows. But I can probably get the info I need with the min/max on a multimeter. I won't see the voltage curve but assuming my meter is sensitive enough I won't see the expected 2V deviation to both sides.
TTT
C?ID=547002
Do you need me to do any other tests? I didn't gave the substitute values any thoughts tbh. But say it and I see what I can do?
Cuzoe
C?ID=279487
If you could watch the values in the attached screenshots for the front distribution motor while running output test (or basic settings) that would confirm what I'm thinking. These are screenshots of the video that I don't know how to post...
The first is the min specified value, which it reached.
This looks okay I think, similar to other motors.
This one is the max specified value, which it does not reach.
Maybe this is the problem (assuming actual should get close to specified).
If I watch these values for another motor the last two values (the stops) are saved at the start. When you begin the basic settings it clears them out but they fill in as the routine ends.
Cuzoe
C?ID=279487
Thank you! I am able to see the animated gifs, and saved them for later.
Interesting the range for your front motor... About 25 > 235 for the stops and actual value (and assume the specified is pretty close to that)
While the range for my front motor (specified) is 91 > 952, and the actual values go from about 95 > 650.
I suppose the raw number is not so important, only that actual value gets close enough to specified value for end stops to be saved. In my case it is not close enough.
TTT
C?ID=547002
I will measure my potentiometer value, I am curious how many kohms it has, compared to yours.
