Trailer hitch ABS/ESP coding on my Audi A4 B9 to RS4 B9.5 (2022) conversion
Maarten ten Wolde
H12-2H
Hi ,
I am looking for assistance with the ABS/ESP coding on my Audi A4 B9 to RS4 B9.5 (2022) conversion.
Almost all control modules were replaced with units from the same 2022 RS4 donor vehicle. The engine ECU and airbag control module are the exceptions.
I have also retrofitted a trailer hitch and successfully activated the relevant functions in several control modules using VCDS.
However, I am still experiencing the following fault in the trailer control module (69):
Fault: U0415 00 – Implausible Data Received from ABS Control Module
Internal fault description: <span>ESP_v_signal</span>
Fault behavior:
  • The fault appears when switching on the ignition after the vehicle has been completely powered down.
  • The engine does not need to be started for the fault to appear.
  • After clearing the fault, it does not return while the ignition remains on.
  • The fault also remains absent during normal driving.
  • The ABS/ESP module itself reports no fault codes.
ABS/ESP Control Module (03)
  • Part number: <span>8W0 907 379 BA</span>
  • Component: ESP9 Premium
  • Hardware version: H16
  • Software version: 0300
  • ASAM: <span>EV_ESP9BOSCHCMP 001001</span>
  • Dataset: <span>8W0909504AE / 0001</span>
Current long coding:
<span>50AA6C9930A2AA9711A64892427F18A2E6A5DA0A360C55881242184567A55B</span>
Trailer Control Module (69)
  • Part number: <span>8W1 907 383 A</span>
  • Software version: 0039
  • Coding: <span>0100000202001100</span>
  • Dataset: <span>8Y0909527A / 0005</span>
Changes already performed
  • Module 09 – Central Electronics: Trailer hitch configuration completed.
  • Module 17 – Instrument Cluster: Trailer coding activated (Byte 14, Bit 5). The U1014 fault disappeared.
  • Module 19 – CAN Gateway: Trailer module installed and recognized.
  • Module 74 – Chassis Control: Trailer coding activated (Byte 0, Bit 7). The U1014 fault disappeared.
  • Module 69 – Trailer: Communicating correctly, apart from the recurring U0415 fault.
ABS/ESP coding question
I understand that the ABS/ESP module may require additional coding to enable trailer stabilization when retrofitting a trailer hitch.
I have found references suggesting the following coding changes for some Audi models:
  • Byte 8, Bit 6 – Trailer stabilization
  • Byte 23, Bit 1 – Trailer-related configuration
Both bits are currently disabled in my ABS long coding.
However, VCDS does not provide byte/bit descriptions for my specific ABS module, so I have not changed either bit.
Could someone confirm this:
  1. Does the ESP9 Premium module <span>8W0 907 379 BA</span>, software 0300, require additional coding for a retrofitted trailer hitch?
  2. Are Byte 8, Bit 6 and Byte 23, Bit 1 the correct coding positions for this particular module?
  3. Could the missing trailer configuration explain the recurring U0415 / <span>ESP_v_signal</span> fault in module 69?
  4. Is there any known compatibility or parameterization issue between the ABS module and trailer module <span>8W1 907 383 A</span>?
I can provide a complete VCDS Auto-Scan if required.
Thank you in advance for your assistance.
Best regards
Yes, please post a full car scan including the VIN and the VIN of the original car.
Maarten ten Wolde
H12-2H
Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: Release 26.9.0(x64) Data version: 20260828 DS378.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Monday,19,October,2026,18:09:04:02297
VIN: WUAZZZF46NA901812 License Plate: 12345 original car was WAUZZZF45GA042967
Mileage: 33031km-20524mi Repair Order:
Chassis Type: F4-AU49 (80C)
Scan: 01 02 03 08 09 13 15 16 17 19 1B 32 36 3C 42 44 46 52 5F 65
69 6C 6D 74 75 81 82 8B A5 A9 BB BC CA CF D6 D7 DE
VIN: WUAZZZF46NA901812 Mileage: 33031km-20524miles
74-Chassis Control -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Self-Diagnosis Log
Page 2
Address 01: Engine (J623-DECA) Labels:. 06M-907-309-V1.clb
Part No SW: 8W0 907 551 K HW: 06M 907 309 H
Component: V6 2.9l TFSI H11 0003
Revision: B9H11000 CVN: 5BE8C674
Coding: 122A403225660D0B34380000000000000000000000000000
Shop #: WSC 99999 999 2097151
ASAM Dataset: EV_ECM29TFS0118W0907551K 001003
ROD: EV_ECM29TFS0118W0907551K.rod
VCID: 45D6A123A52169B2946-8010
VINID: 9E546AAAA58419E44900120108121FC7F4
Readiness: 1110 0001
Part No SW: 8W0 927 158 AF HW: 0D5 927 156 N
Component: 0D5 29FSIRdW H06 0001
Revision: --H06--- CVN: 73FAD2B4
Coding: 100000
Shop #: WSC 06325 790 00001
ASAM Dataset: EV_TCMALX52011 002016
ROD: EV_TCMALX52011.rod
VCID: 0654662FD8A7A2AADDC-8052
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-V1.clb
Part No SW: 8W0 907 379 BA HW: 8W0 907 379 BA
Component: ESP9 Premium H16 0300
Dataset Number: 8W0909504AE 0001 CVN: 44A45285
Coding: 50AA6C9930A2AA9711A64892427F18A2E6A5DA0A360C55881242184567A55B
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 05566123E5A1A9B2D46-8050
Self-Diagnosis Log
Page 3
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8W0 820 043 BJ HW: 8W0 820 043 BJ
Component: Klima Zone 3 H60 0291
Dataset Number: 8W0909862D 0027
Coding: 2608000D5545010D020201000B0000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ASAM Dataset: EV_AirCondiBHTCAU491 001029
ROD: EV_AirCondiBHTCAU491.rod
VCID: 7CA004C7966BE87ABB8-8028
Subsystem 1 - Part No SW: 4M1 820 021 C HW: 4M1 820 021 C
Component: J126 FLuftV H09 0004
Serial number: 00000000000007636627
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 C HW: 4H0 907 658 C
Component: G935 MuFu H05 0010
Serial number: B2C5882300PAG0MUFU04
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Self-Diagnosis Log
Page 4
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W1 907 063 BG HW: 8W1 907 063 G
Component: BCM1 MLBevo H10 0728
Dataset Number: 8W1909514F 0019
Coding: 07001140C13900DD050D578998AF8CE9130B31040000009801010800600016810A4502BBA2B70A000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 018005
ROD: EV_BCM1BOSCHAU651_018.rod
VCID: 025C7A3FF48F9E8AF14-8056
Subsystem 1 - Part No SW: 8W1 955 119 B HW: 566 955 119
Component: J400FRWISCH 051 0822
Serial number: 887353F0402128610089
Coding: 7DC727
Subsystem 2 - Part No SW: 81A 955 555 B HW: 81A 955 555
Component: G397_RLFSS H06 0004
Serial number: 43680774X81A955555B0
Coding: 0200FF
Subsystem 3 - Part No SW: 4M0 941 531 AP HW: 4M0 941 531 AP
Component: E1 - LDS H07 0008
Serial number: 14 05 2022 03110214
Subsystem 4 - Part No SW: 8W0 857 511 F HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE122022223610930
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 AL HW: 4K0 947 135 AL
Component: Dachmodul H42 0416
Serial number: A00042870
Coding: 0D0104
Valve block 1 in front seat driver side:
Subsystem 6 - Part No SW: 8W0 907 182 B HW: 8W0 907 182 B
Component: J873 MKS_FSv H03 0010
Serial number: 7009137235A222672337
Coding: BF0500
Valve block 1 in front seat passenger side:
Subsystem 7 - Part No SW: 8W0 907 182 B HW: 8W0 907 182 B
Component: J872 MKS_BFSv H03 0010
Serial number: 7009137235A222673042
Coding: B30500
Self-Diagnosis Log
Page 5
Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail!
Part No SW: 8W0 907 561 H HW: 8W0 907 561
Component: LRR4 H13 0452
Dataset Number: 8W0909863Q 0003
Coding: 3565FFFB58FFEC06757B61A0
ASAM Dataset: EV_ACCBOSCHAU49X 003024
ROD: EV_ACCBOSCHAU49X_003_AU49.rod
VCID: 43D2BF3BAB155782BA2-8016
Self-Diagnosis Log
Page 6
Address 15: Airbags (J234) Labels:| 8W0-959-655-V1.clb
Part No SW: 8W0 959 655 Q HW: 8W0 959 655 Q
Component: Airbag10.44 H15 0122
Serial number: 0034Z000DZ15 Dataset Number: 8W0909602BE 0001
Coding: AACCF0C000800000985400F3D04C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006.rod
VCID: 57EA7B6B4F8DEB22F6A-8002
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 8W0857705A0013Q00610
Coding: 88001B
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 8W0857706A0014Q00527
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 442 062 911 15
Serial number: 3577Y00B71A82883C4FG
Subsystem 4 - Part No SW: ----------- HW: 442 060 706 22
Serial number: 3587Y00B5096FEB1845H
Subsystem 5 - Part No SW: ----------- HW: 442 0B2 511 15
Serial number: 35177002A29499B9162B
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 511 15
Serial number: 3527700C11E62356035$
Subsystem 7 - Part No SW: ----------- HW: 442 0C1 001 16
Component: FrontSensor_D 1C5 014A
Serial number: 3557500AB1E2F832408H
Self-Diagnosis Log
Page 7
Subsystem 8 - Part No SW: ----------- HW: 442 0C0 406 22
Component: FrontSensor_P 1C5 014A
Serial number: 3567500BB09BC485D3F%
Part No SW: 4N0 907 129 NC HW: 4N0 907 129 NC
Component: Lenks.Modul H03 0009
VCID: 7F5AF3CB877DF3629EA-802A
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8W5 920 790 M HW: 8W5 920 790 L
Component: FBenRDW------ H11 0217
Dataset Number: 8W1909525F 0020
Coding: 8D0D2DCE7EB800080090E7641000481008000800
ASAM Dataset: EV_DashBoardAU65X 002027
ROD: EV_DashBoardAU65X_002_AU49.rod
VCID: 4CC09407864B98FA4B8-8018
U1014 00 [00001001] - -
[ECU incorrectly coded]
Reset counter: 10
Mileage: 33031 km
Date: 2026.10.19
Time: 18:02:49
Self-Diagnosis Log
Page 8
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 80C 907 468 F HW: 80B 907 468 B
Component: Gateway H08 0613
Serial number: F0630813355721 Dataset Number: 8W0909515T 0042
Coding: 03010001004006405407000000590012FC980081920000000100008E02000000
GVL: 01587C5808000000C0DCC8008002C800110C0000000000000000000000006500
ASAM Dataset: EV_Gatew31xAU65x 003250
ROD: EV_Gatew31xAU65x_AU49.rod
VCID: 3332EFFBFBB5E7022A2-8066
Subsystem 1 - Part No SW: 8W0 951 523 AG HW: 8W0 951 523 AG
Component: J453 MFL H04 0005
Serial number: 20220623143922 20029
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Component: J367-BDMHella H11 9070
Serial number: 6833419705
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8W0 907 144 J HW: 8W0 907 144 C
Component: SCU_MLBevo H03 0710
Serial number: 30303030303030 Dataset Number: 8W0909848P 0002
ASAM Dataset: EV_SCUZFLSAU49X 002019
ROD: EV_SCUZFLSAU49X_002.rod
VCID: 42DCBA3FB40F5E8AB14-8016
Address 32: Differential Locks (J187) Labels: 8W0-907-163.clb
Part No SW: 8W0 907 163 A HW: 8W0 907 163
Component: QSP QCU Gen2 H08 0070
Revision: 5WK12701 Serial number: 605224706200907
Coding: 0003
ASAM Dataset: EV_TVDCQSP22 001008
ROD: EV_TVDCQSP22.rod
VCID: 3A2CC2DFDCDF164AE94-806E
Self-Diagnosis Log
Page 9
Part No SW: 4M6 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0064
Serial number: 2251701KA01986 Dataset Number: 8W0909856D 0015
Coding: 01581A000000B0010003010101010000000000000000000000000000004000
VCID: 7BA207DB9365EF42B22-802E
Address 3C: Lane Change (J769) Labels:| 4M0-907-566.clb
Part No SW: 4M0 907 566 G HW: 4M0 907 566
Component: MRR1Rear H24 0452
Revision: -------- Dataset Number: 8W0909535D 0003
Coding: 0EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
VCID: 392EDDD3D9D91D52E0E-806C
Part No SW: 4M8 959 793 N HW: 4M8 959 793 N
Component: TSG FS 001 0390
Serial number: 0000472509062 Dataset Number: 8W0909872H 0038
Coding: 005D8B205200008000011030
VCID: 51FE85736169B51238E-8004
Address 44: Steering Assist (J500) Labels:| 8W0-909-144-V1.clb
Part No SW: 8W0 909 144 J HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0411
Dataset Number: 8W0909852R 0044
Coding: 85888380008000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 44D0BC27AE1B50BA838-8010
Self-Diagnosis Log
Page 10
Part No SW: 8W1 907 064 CN HW: 8W1 907 064 N
Component: BCM2 MLBevo 044 0585
Dataset Number: 8W0909501S 0018
Coding: 01342100002000E06309A0006C00C80213004008804F06502F0400000504803F001F0601002F31
ASAM Dataset: EV_BCM2HellaAU736 019017
ROD: EV_BCM2HellaAU736_019.rod
VCID: 0B42571BC3C5DFC2822-805E
Left taillight 1:
Subsystem 1 - Part No SW: 8W9 945 423 B HW: 8W9 945 423 B
Component: T1 LH ECE H10 0710
Serial number: HAX3020FRL9Z000020H1
Power rear lid opening control module:
Subsystem 2 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: 12253752
Left taillight 2:
Subsystem 3 - Part No SW: 8W9 945 429 B HW: 8W9 945 429 B
Component: T2 LH ECE H10 0710
Serial number: HAX30009G64Y000020H8
Right taillight 1:
Subsystem 4 - Part No SW: 8W9 945 424 B HW: 8W9 945 424 B
Component: T1 RH ECE H10 0710
Serial number: HAX30203645Y000020H2
Right taillight 2:
Subsystem 5 - Part No SW: 8W9 945 430 B HW: 8W9 945 430 B
Component: T2 RH ECE H10 0710
Serial number: HAX3000DHJ5Y000020H7
Self-Diagnosis Log
Page 11
Part No SW: 4M8 959 792 N HW: 4M8 959 792 N
Component: TSG BFS 001 0390
Serial number: 0000472514802 Dataset Number: 8W0909873H 0038
Coding: 005D8B205E00008000011030
VCID: 50F880776A63BC1A370-8004
196896 - Control Panel for Window
B1876 29 [00001001] - Signal Implausible
Reset counter: 10
Mileage: 33031 km
Date: 2026.10.19
Time: 18:02:50
Self-Diagnosis Log
Page 12
Part No SW: 8W2 035 043 M HW: 8W2 035 043 A
Component: MU-TH-ND-EU 044 3695
Serial number: GRO-63330.06.22 Dataset Number: 8W1909545K 0047
Coding: 14920000804120000000000000000000000000000000000000
ASAM Dataset: EV_MUTI 001010
ROD: EV_MUTI_AU27.rod
VCID: 3D26C9C3CDF12172CC6-8068
Multimedia display unit 1:
Subsystem 1 - Part No SW: 8W1 919 620 A HW: 8W1 919 620
Component: CenterDisplay H42 0160
Serial number: AUZ8Z9N2H03LM6
Subsystem 2 - Part No: V03 959 822 GA
Component: MIB3_EU_ 1240
Compact disc data bank:
Component: Gracenote2 1008
Volume Control 1:
Subsystem 4 - Part No SW: 8W1 919 616 D HW: 8W1 919 616 D
Component: LSR-B9PA H20 0103
Serial number: ALJAL226052200020053
Media socket:
Subsystem 5 - Part No: 8W0 035 708 A
011 0010
Digital Sound System Control Module 2:
Subsystem 6 - Part No SW: 8Y0 035 465 A HW: 8Y0 035 465 A
Component: B_A_3_P_0_AU H11 0100
Serial number: HHA-07317.06.2242960
9721363 - Treble Speaker 2; Front Left
B1456 13 [00001001] - Open Circuit
Reset counter: 10
Mileage: 33031 km
Date: 2026.10.19
Time: 18:02:53
Voltage terminal 30: 11.6 V
0014 - Connection between Antenna Amp 1 for Digital Radio and Antenna
Self-Diagnosis Log
Page 13
Reset counter: 10
Mileage: 33031 km
Date: 2026.10.19
Time: 18:03:01
Connection between radio and antenna amplifier: electrically OK
Connection between antenna amplifier and antenna: Open circuit
Antenna current: 20 mA
Address 65: Tire Pressure (J502) Labels: 4M0-907-273.clb
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H06 0010
Serial number: 30000000118994 Dataset Number: 8WA909850A 0002
ROD: EV_RDKHUFAU736_AU37.rod
VCID: 2F3AE38B179DC3E24EA-807A
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 8W1 907 383 A HW: 8W1 907 383
Component: Anhaenger H07 0039
Serial number: 000000000005202 Dataset Number: 8Y0909527A 0005
Coding: 0100000202001100
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 3FDAB3CBC7FD3362DEA-806A
Part No SW: 8W0 907 428 C HW: 4M0 907 428
Component: Areaview 2 H18 0108
Serial number: C854611JA032589 Dataset Number: 8W1909460N 0031
Coding: 02940201BE0FA10008004004
ASAM Dataset: EV_CamSysRVAV2CE2MLBPA 002001
ROD: EV_CamSysRVAV2CE2MLBPA_002.rod
VCID: 40D8B037BA034C9AA70-8014
Self-Diagnosis Log
Page 14
Part No SW: 4M8 959 107 A HW: 4M8 959 107 A
Component: HDSG-Modul H06 0335
Revision: -------- Serial number: A2-C765-5001-2 Dataset Number: 8W0909541H 0032
Coding: 0570
ASAM Dataset: EV_DeckLidCONTIAU536 001002
ROD: EV_DeckLidCONTIAU536_001_VWE3.rod
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 8W0 907 777 AA HW: 8W0 907 777 C
Component: Fahrwerk-SG H38 1252
Serial number: 0207220395 Dataset Number: 8W0909576R 0004
Coding: 546040395A
ASAM Dataset: EV_ChassContrContiAU426 001004
ROD: EV_ChassContrContiAU426.rod
327793 - Control Module Incorrectly Coded
[Incorrectly_coded_mounting_coding_trailer]
Reset counter: 10
Mileage: 33031 km
Date: 2026.10.19
Time: 18:02:50
Internal DTC: 476
Self-Diagnosis Log
Page 15
Address 75: Telematics (J949) Labels:* Redir Fail!
Part No SW: 4KE 035 282 G HW: 4KE 035 282 B
Component: CB_H_ECE 042 0371
Serial number: A970F0N2604138 Dataset Number: 8W0909612K 0029
Coding: 01E0E0F8C04080F6E0
ASAM Dataset: EV_ConBoxHighAU49X 001004
ROD: EV_ConBoxHighAU49X_AU49.rod
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 P HW: 4M1 713 041 G
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 22030480739244
ROD: EV_GSMWaehlZFAU736.rod
Address 82: Head Up Display (J898) Labels:| 4M0-919-617-V1.clb
Part No SW: 8W5 919 617 H HW: 8W5 919 617 H
Component: HeadUpDisplay H24 1952
Coding: 4F01F0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736_AU49.rod
VCID: 4DC699037D5191F25C6-8018
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 8W0 907 541 H HW: 8W0 907 541
Dataset Number: 8W0909885H 0003
ASAM Dataset: EV_ACC2BOSCHAU49X 003024
ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
VCID: 41DEB533B1094592A8E-8014
Self-Diagnosis Log
Page 16
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W0 907 217 G HW: 8W0 907 217 F
Component: BVS H30 0070
Dataset Number: 8W0909466H 0057
Coding: 0404090200000403012023A6C50000FC90F0C020E280
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002028
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
Part No SW: 8W0 907 159 T HW: 4K0 907 159
Component: SAS-GEN 2.5 H08 0001
Serial number: 220409290839
VCID: 52FC8A7F646FCE0A014-8006
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V2.clb
Part No SW: 4M8 959 795 N HW: 4M8 959 795 N
Component: TSG HFS 001 0390
Serial number: 0000472521947 Dataset Number: 8W0909897J 0038
Coding: 000D89200000008000001020
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
VCID: 53F28F7B5B75C7020A2-8006
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V2.clb
Component: TSG HBFS 001 0390
Serial number: 0000472188654 Dataset Number: 8W0909896J 0038
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Self-Diagnosis Log
Page 17
Part No SW: 4K0 907 594 AA HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: 8W0909469G 0015
Coding: 428040049202
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 73B22FFBBB35A702EA2-8026
Address CF: Lane Chge Asst 2 (J770) Labels:. 4M0-907-566.clb
Part No SW: 4M0 907 590 G HW: 4M0 907 590
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
VCID: 3634D6EFE8C7F22A0DC-8062
Part No SW: 4K0 941 591 BD HW: 4K0 941 591 B
Component: LMS_MLBevo H11 0040
Dataset Number: 8W0909471F 0013
ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
ROD: EV_LMSLeftHELLAAU58X.rod
VCID: 72BC2AFFC42FAE0AE14-8026
Dataset Number: 8W0909472F 0013
ASAM Dataset: EV_LMSRightHELLAAU58X 001015
Self-Diagnosis Log
Page 18
Address DE: Charger 1 for mobile dev (J1146) Labels:| 4N0-035-502.clb
Part No SW: 4K0 035 502 B HW: 4K0 035 502 B
Component: WLC Front H14 0061
Dataset Number: 4N0909485A 0007
Coding: 800000
VCID: 201810B75A436C9AC70-8074
End----(Elapsed Time: 02:19, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
------------------------------5 Faults Found-------------------------------
Admin Note: Please do not use the [Print] function in VCDS to post data here. The formatting it produces is intended for a sheet-fed printer, but it's much harder to read here than the native text that VCDS produces. That native text can be had using the [Copy] button in VCDS, or by opening any of the .txt files in your Logs or Scans sub-folder with Notepad and then copying the data to paste here.
One of the clever chaps on here should be able to calculate your coding for you with that data
Maarten ten Wolde
H12-2H
Thank you very much for your help!
Just to be on the safe side, I'd like to confirm that I should set Byte 8, Bit 6 and Byte 23, Bit 1 to 1 (check both boxes).
Out of curiosity, could you explain what these two bits actually control and how they affect the ABS/ESP system?
Also, is there a complete long coding description or documentation available for module 03 (ESP9 Premium)?
Thanks again for your assistance!
No there isn't. VAG does not provide any public documentation for ABS coding in modern cars. In fact, they treat those as some kind of "state secret".
That must mean you are a spy, I knew there was something dodgy about your lot.
  • Haha
What we know about modern ABS codings has (mostly) been deduced from all the scans we've seen. If you compare enough of them, while knowing how the cars are equipped, you can start to figure out the meaning of some of the bits and bytes.
