2023 Atlas 2.0T 4Motion - ABS Long Coding Lost After Cluster Swap (Have Matching Donor Atlas)
Quantum11
New York, USA
Hello everyone,
I am trying to recover the ABS/ESC coding on my 2023 Volkswagen Atlas SE 2.0T 4Motion.
The issue started after I temporarily installed a different Digital Cockpit cluster. The replacement cluster was not adapted to the vehicle. I then reinstalled the original cluster and the Atlas starts and runs normally again.
However, Module 03 ABS Brakes now reports "Control Module Not Coded" and the long coding is all zeros.
ABS module information:
Software: 5Q0 614 517 GA
Software Version: 0114
Hardware: 5Q0 614 517 BN
Hardware Version: H35
ASAM: EV_Brake1UDSContiMK100IPB
ASAM Version: 049015
Vehicle configuration:
2023 Atlas SE
2.0T
4Motion
Electronic Parking Brake
Auto Hold
ACC / Front Assist
Blind Spot Monitoring
No Park Assist
No Factory Tow Package
245/60R18 tires
Current symptoms:
Transmission emergency mode
ABS/ESC warnings
Electronic parking brake warnings
Front Assist unavailable
Steering faults
Multiple modules reporting missing or invalid vehicle dynamics data
I do not have a backup of the original ABS coding and OBDeleven history does not contain the original value.
Your guys help would be amazing thank you.
Can the coding be reconstructed from a donar VIN and vehicle equipment, or is ODIS/SVM required to restore the original coding?
I can provide a complete scan if needed.
Thank you.
Can you post the full scan of the car you saved before you started work?
Quantum11
New York, USA
Date: 2026-10-23 13:04
VIN:
Car: Volkswagen Atlas
Year: 2023
Mileage: 134693 KM
History item: Full Scan
Time: 2026-10-23 13:02:43
Mileage: 134693 KM
Total control units: 20
Scanned control units: 20
Fault count: 50
  Control Unit: (3C) Lane Change Assistant Right
  ODX: EV_HREntryHellaGen3Kl15_002001
  System: HRE3_Kl15_Mst
  Protocol: CAN: UDS
  Serial number: 11230052968038
  Faults:
    U112300 - Data bus error value received
    U112200 - Data bus implausible message
  Control Unit: (19) Gateway
  ODX: EV_GatewNF_013026
  System: GW MQB High
  Protocol: CAN: UDS
  Serial number: 06122200841917
  Faults:
    U105200 - Generator
    U140600 - Static current
  Control Unit: (09) Central Electrics
  ODX: EV_BCMMQB_022001
  System: BCMMQBAB HNAO
  Protocol: CAN: UDS
  Serial number: 2290000902����
  Faults:
    No trouble codes found
  Control Unit: (01) Engine
  ODX: EV_ECM20TFS0203CN906259K_001003
  System: R4 2.0l TFS
  Protocol: CAN: UDS
  Serial number: -
  Faults:
    U041600 - Invalid Data Received From Vehicle Dynamics Control Module
    U012100 - Lost Communication With
  Control Unit: (75) Telematics
  ODX: EV_OCUGen3Low_003008
  System: OCUGen3Low
  Protocol: CAN: UDS
  Serial number: 0000000207NVPA211888
  Faults:
    B200500 - Data record invalid
    B105413 - GPS antenna
    B180B13 - LTE antenna 2
    B17FD13 - LTE antenna 1
  Control Unit: (D6) LED Module Left
  ODX: EV_LLPGen3LKEBODPO68X_001003
  System: LED1L
  Protocol: CAN: UDS
  Serial number: -
  Faults:
  Control Unit: (17) Dashboard
  ODX: EV_DashBoardJCIMQBAB_010007
  System: KOMBI
  Protocol: CAN: UDS
  Serial number: -
  Faults:
    U112100 - Data bus missing message
  Control Unit: (15) Airbag
  ODX: EV_AirbaVW21TS6VW48X_001014
  System: Airbag VW21
  Protocol: CAN: UDS
  Serial number: 003013VMC3J2
  Faults:
    B13BCF2 - multiple collision brake
  Control Unit: (42) Driver Door
  ODX: EV_DCU2DriveSideMAXHKLO_001018
  System: TSG FS
  Protocol: CAN: UDS
  Serial number: YB008VKR005FE
  Faults:
  Control Unit: (B7) Start System Interface
  ODX: EV_KessyHellaMQBAB_004055
  System: VWKESSYMQB
  Protocol: CAN: UDS
  Serial number: 0605334999
  Faults:
  Control Unit: (44) Steering Assistance
  ODX: EV_SteerAssisMQB_015157
  System: EPS_MQB_ZFLS
  Protocol: CAN: UDS
  Serial number: -
  Faults:
    B116854 - Steering angle sensor
  Control Unit: (5F) Multimedia
  ODX: EV_MUEnt4CGen2LGE_001044
  System: MU-E--ER
  Protocol: CAN: UDS
  Serial number: 26102300020259
  Faults:
    B126D13 - Connection between radio and antenna amplifier 1
    U111100 - Function restriction due to missing message
  Control Unit: (02) Transmission
  ODX: EV_TCMAQ450031_001001
  System: AISIN AQ8
  Protocol: CAN: UDS
  Serial number: -
  Faults:
    U012800 - Lost Communication With Brake System Control Module
  Control Unit: (D7) LED Module Right
  ODX: EV_LLPGen3RKEBODPO68X_001003
  System: LED1R
  Protocol: CAN: UDS
  Serial number: -
  Faults:
  Control Unit: (08) Air Conditioning
  ODX: EV_ACManueBHBVW416_001004
  System: AC Manuell
  Protocol: CAN: UDS
  Serial number: -
  Faults:
  Control Unit: (03) Brakes
  ODX: EV_Brake1UDSContiMK100IPB_049015
  System: ESC
  Protocol: CAN: UDS
  Serial number: 52682000000451
  Faults:
    U101300 - Control module not coded
    C101754 - Longitudinal acceleration sensor
    C107954 - Lateral acceleration sensor
    C107A54 - Brake pressure sensor 1
    U101400 - Control module incorrectly coded
    U10DA00 - Coding invalid
    P161200 - Engine/Motor Control Module
    C10E2F1 - Electromechanical parking brake control module
  Control Unit: (52) Passenger Door
  ODX: EV_DCU2PasseSideMAXHKLO_001018
  System: TSG BFS
  Protocol: CAN: UDS
  Serial number: YB008VKR00C45
  Faults:
  Control Unit: (4B) Multifunction Module
  ODX: EV_MultiModulContiVW48X_004006
  System: FCM MQB Low
  Protocol: CAN: UDS
  Serial number: 24122200840357
  Faults:
  Control Unit: (22) All Wheel Drive
  ODX: EV_AllWheelContrHA1VW37X_005001
  System: 4Motion
  Protocol: CAN: UDS
  Serial number: HA1-00008.10.2200060693
  Faults:
  Control Unit: (13) Adaptive Cruise Control
  ODX: EV_ACCMRRCONTIVW376_003018
  System: ACCCONTIMQB
  Protocol: CAN: UDS
  Serial number: -
  Faults:
Your going to need to purchase a Ross-Tech VCDS interface to obtain support on this (VCDS) forum (unless admin. decides differently).
Your Life line <------------- click
Sebastian
Magdeburg, Germany
HN0-nnnnnn
VCDS shows / documents several additional details in an Auto-Scan, some of which we'll use in order to assist in a case like this. That said, the work behind generating such codings isn't trivial and due to the existing case load we already have, this is not something we can justify for non-customers. So as others have pointed out, if you keep using a different tool and not VCDS, there is little we will do here.
Yup. @Quantum11 either needs to get and use VCDS, or seek assistance from the supplier of whatever tool he's using .
Quantum11
New York, USA
Hey I have a question. Is it okay for me to borrow the genuine tool from someone? Not in this form explicitly.
Quantum11
New York, USA
Sure, but the "genuine" is important.
Here’s the full log
Thursday,05,November,2026,07:03:13:45721
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 26.9.0.3 (x64)  HEX-NET CB: 0.4713.4
Data version: 20260828 DSa378.0
Mileage: 1048575km-651554mi   Repair Order:
Chassis Type: 3Q0
Scan: 01 02 03 05 08 09 13 15 17 19 22 3C 42 44 4B 52 5F 75
   Mileage: 1048575km-651554miles
01-Engine -- Status: Cannot be reached 0100
02-Auto Trans -- Status: Cannot be reached 0100
03-ABS Brakes -- Status: Cannot be reached 0100
05-Acc/Start Auth. -- Status: Cannot be reached 0100
08-Auto HVAC -- Status: Cannot be reached 0100
09-Cent. Elect. -- Status: Cannot be reached 0100
13-Auto Dist. Reg -- Status: Cannot be reached 0100
15-Airbags -- Status: Cannot be reached 0100
17-Instruments -- Status: Cannot be reached 0100
22-AWD -- Status: Cannot be reached 0100
3C-Lane Change -- Status: Cannot be reached 0100
42-Door Elect, Driver -- Status: Cannot be reached 0100
44-Steering Assist -- Status: Cannot be reached 0100
4B-Multifunc. Module -- Status: Cannot be reached 0100
52-Door Elect, Pass. -- Status: Cannot be reached 0100
75-Telematics -- Status: Cannot be reached 0100
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Address 05: Acc/Start Auth.
Address 08: Auto HVAC
Address 09: Cent. Elect.
Address 13: Auto Dist. Reg
Address 15: Airbags
Address 17: Instruments
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5502
   Serial number: 06122200841917 Dataset Number: V03935354LZ 0001
   Coding: 030500347F085B00FB0320481E0F00010000000000000000000000000000
   Shop #: WSC 06050 062 00200
   GVL: 01C23C0000000400404C80008000C80000000000000200000000000000000000
   ROD: EV_GatewNF_VW48.rod (VIN: N/A)
   VCID: 7F4E1DCFE64FE56539-802B
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [00001000] - -
          [Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
                    Reset counter: 83
                    Mileage: 135558 km
                    Date: 2026.10.28
                    Time: 22:37:39
                    Terminal 30 power supply: 12.4 V
                    Terminal 15: OFF
8531970 - Quiescent Current
          U1406 00 [00001000] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Fault Frequency: 12
                    Reset counter: 105
                    Mileage: 134678 km
                    Date: 2026.10.22
                    Time: 05:39:50
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: OFF
Address 22: AWD
Address 3C: Lane Change
Address 44: Steering Assist
Address 4B: Multifunc. Module
Address 52: Door Elect, Pass.
Address 75: Telematics
End----(Elapsed Time: 00:30, VBatt start/end: 12.4V/12.4V. VIgn 0.0V)------
------------------------------2 Faults Found-------------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The ignition wasn't switched on when you tried scanning the car...
Quantum11
New York, USA
Thursday,05,November,2026,07:15:55:45721
VIN: 1V2LP2CA8PC529583   License Plate:
Mileage: 136294km-84689mi   Repair Order:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 22 3C 42 44 4B 52 5F 75 D6 D7
VIN: 1V2LP2CA8PC529583   Mileage: 136294km-84689miles
Address 01: Engine (J623-DTFA)       Labels: None
   Part No SW: 3CN 906 259 K    HW: 06K 907 425 J
   Component: R4 2.0l TFS   H13 0002
   Revision: --H13---    CVN: E67CA1CA
   Coding: 092A00122426012E7000
   ASAM Dataset: EV_ECM20TFS0203CN906259K 001003
   ROD: EV_ECM20TFS020_VW41.rod
   VCID: 4ED0700B1165BCED82-801B
   VINID: 06609C8024D12204C50891480CE24EC0F4
17178 - Implausible Data Received from ESP Control Module
          U0416 00 [01101101] - -
                    Mileage: 134600 km
                    Date: 2026.10.21
                    Time: 13:51:30
                    Engine speed: 1242.75 /min
                    Normed load value: 27.8 %
                    Coolant temperature: 73 °C
                    Intake air temperature: 62 °C
                    Voltage terminal 30: 11.914 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system malfunction: No
19875 - No Communication with ABS Brake Control Module
          U0121 00 [10101111] - -
                    Fault Frequency: 32
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:23
                    Engine speed: 744.00 /min
                    Normed load value: 8.2 %
                    Coolant temperature: 103 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 14.355 V
                    Engine: operating status: IS
                    ECU_STATE: SYN_ENG_IGK_ON
                    Engine oil temperature: 105.0 °C
                    Time since engine start: 971.8 s
                    T_ES: 0 min
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: Not operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: Not operated
                    Cruise control switch actuation-Large increment: Not operated
                    T_AST_SAE: 0 s
Readiness: 0000 0100
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 09G 927 158 GK    HW: 09G 927 158
   Component: AISIN AQ8     206 3941
   CVN: 5941E76A
   Coding: 0000000100000000000000000000000000000000
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 0248943B95BD888D56-8057
22646 - No Communications with Parking Brake Control Module
          U0128 00 [10101011] - -
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:23
                    Engine speed: 746.0 /min
                    Transmission input speed: 723 /min
                    Engine torque: 0 Nm
                    ATF temperature: 77 °C
                    Accelerator pedal position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    Electrical Oil Pump target revolution: 65534 /min
                    Electrical Oil Pump actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
                    Electrical Oil Pump target current: 65278 mA
   Part No SW: 5Q0 614 517 GA    HW: 5Q0 614 517 BN
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 52682000000451
   Coding: 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 76A0F8EBC975A42D6A-8023
14 Faults Found:
0195 - Control module not coded
          U1013 00 [10001001] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 19
                    Mileage: 134772 km
          C1017 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 19
                    Mileage: 134772 km
          C1079 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 19
                    Mileage: 134772 km
0279 - Brake Pressure Sensor 1
          C107A 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 19
                    Mileage: 134772 km
0295 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 19
                    Mileage: 134772 km
0398 - Control Module Incorrectly Coded
          U1014 00 [10001001] - -
          [Vehicle equipped with vacuum sensor but no vacuum sensor coded]
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:26
8279 - Engine Control Module Incorrectly Coded
          P1612 00 [10001001] - -
                    Reset counter: 62
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:25
8280 - Engine Control Module Incorrectly Coded
                    Fault Frequency: 12
                    Reset counter: 63
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 10:08:10
8286 - Databus
          U1123 00 [10001001] - Received Error Message
          [FCAN: MO_Timeout_ESP signal is invalid]
                    Reset counter: 63
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 10:08:10
8292 - Control Module Incorrectly Coded
          [FCAN: 4 wheel driven is not coded but Allrad_03 message is received]
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:25
8299 - Databus
          [FCAN: Anhaenger_01_alt veraltet bit is set]
                    Fault Frequency: 197
                    Reset counter: 65
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:25
8306 - Databus
          U1122 00 [10001001] - Implausible Message
          [FCAN: Unplausible VIN number]
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:30
8308 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                    Fault Frequency: 12
                    Reset counter: 63
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 10:08:10
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [10001001] - Switches/Motors Detected
                    Reset counter: 19
                    Mileage: 134772 km
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0605334999 Dataset Number: V03935336QD 0001
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB_VW41.rod
   VCID: 48DC4613F30162DDC8-801D
12786210 - Databus
          U1122 00 [00001000] - Implausible Message
          [Errorvalue Messagecounter Klemmen_Status_01]
                    Reset counter: 66
                    Mileage: 134752 km
                    Date: 2026.10.23
                    Time: 17:33:16
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: Timeout
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: Timeout
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.512 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver´s door: Open
                    Passenger´s door: closed
                    Rear left door: closed
                    Rear right door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 3CN 907 426 G    HW: 3CN 907 426 G
   Component: AC Manuell    H04 2401
   Revision: 00001K01
   Coding: 1602000420001800100020404000C034
   ASAM Dataset: EV_ACManueBHBVW416 001004
   ROD: EV_ACManueBHBVW416.rod
   VCID: 47DE452FFE1F6DA5C1-8013
   Fresh air blower control module (rear):
197890 - Temperature Sensor for Evaporator Vent
          B108A 15 [00001000] - Open or Short to Plus
                    Reset counter: 83
                    Mileage: 135558 km
                    Date: 2026.10.28
                    Time: 22:37:29
                    Voltage terminal 30: 12.5 V
                    Outside temperature: 20.5 °C
                    Refrigerant pressure: 7.6 bar
                    Compressor current: specified value: 0.000 A
   Part No SW: 5Q1 937 085 A    HW: 5Q1 937 085 A
   Component: BCMMQBAB HNAO H44 0512
   Serial number: 2290000902ÿÿÿÿ Dataset Number: V03935368WV 0001
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW26.rod
   VCID: 383C36D383E1125DB8-806D
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  054 0206
   Serial number: S2Y22M09D02H07M51S51
   Coding: 00382D
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521 KF    HW: 5Q1 953 569 H
   Component: Lenks.Modul  H04 0190
   Serial number: 0300060120230C200302
204293 - Remote key 1
          B1479 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 69
                    Mileage: 134788 km
                    Date: 2026.10.24
                    Time: 12:02:09
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beams: Not operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 14.6 V
                    Outside temperature: 11.5 °C
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Dataset Number: V03935369FJ 0001
   Coding: 3000009118FF8728949C810500408700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_VW41.rod
   VCID: 73A6C1FFDA07B1054D-8027
8 Faults Found:
1054 - Databus
          [FAULT_TIMEOUT_EPB_01]
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:29
                    Voltage terminal 15: 14.4 V
                    Control Module temperature: 66 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:29
                    Voltage terminal 15: 14.5 V
0862 - Databus
          [FAULT_DIRECTION_OF_TRAVEL_INVALID_SIGNAL]
                    Reset counter: 105
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 10:37:41
                    Voltage terminal 15: 13.3 V
                    Control Module temperature: 71 °C
                    Vehicle speed: 2.88 m/s
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:29
0822 - Databus
          [FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT]
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:29
                    Voltage terminal 15: 14.3 V
0828 - Databus
          [FAULT_EGO_FZG_GUETE_GIERRATE_SENSOR_DEFECT]
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:29
0800 - Databus
          [FAULT_SWA_RELEVANT_ERROR]
                    Fault Frequency: 189
                    Reset counter: 65
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:29
196808 - Databus
          [VDY_VEH_YWR_NOT_AVAIL]
                    Reset counter: 105
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 10:37:39
                    Voltage terminal 15: 13.2 V
                    Vehicle speed: 1.26 m/s
   Part No SW: 3Q0 959 655 DM    HW: 3Q0 959 655 DM
   Component: Airbag VW21   008 0732
   Revision: --------    Serial number: 003013VMC3J2 Dataset Number: V03935355LS 0001
   Coding: 8CCCFC00000000005000001AC20840000065
   VCID: 0C54BA03A7F9CEFD2C-8059
   Component: Occ.Detection  H16 0022
   Serial number: IBH0000D22000JI8DO0G
   Coding: 303635
   Subsystem 2 - Part No SW: -----------    HW: 454 000 109 22
   Serial number: 35700000000EDA3DD061
   Subsystem 3 - Part No SW: -----------    HW: 454 000 509 22
   Serial number: 35800000000977F8A16-
   Subsystem 4 - Part No SW: -----------    HW: 454 801 410 22
   Serial number: 3510083610820000000.
   Subsystem 5 - Part No SW: -----------    HW: 454 800 711 22
   Serial number: 35200E9D15520000000G
   Subsystem 6 - Part No SW: -----------    HW: 454 800 711 22
   Serial number: 3550027A592200000007
   Subsystem 7 - Part No SW: -----------    HW: 454 800 711 22
   Component: FrontSensor_P  304 0149
   Serial number: 3560022B692200000005
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [10001000] - Open or Short to Ground
1063168 - Databus
          [NWD: 0x104 EPB_01 Timeout]
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:27
          B13BC F2 [10001001] - No function
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 10:08:23
   Part No SW: 5NA 920 410 B    HW: 5NA 920 410 B
   Component: KOMBI         060 4846
   Coding: 08A400082B88CF05028822091000000020201004
   ASAM Dataset: EV_DashBoardJCIMQBAB 010007
   ROD: EV_DashBoardJCIMQBAB_010_VW27.rod
   VCID: 362038EB89F5E42DAA-8063
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:23
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:23
   ROD: EV_GatewNF_VW41.rod
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 AH    HW: 3G0 959 442 AH  Labels: 3C8-959-537.CLB
   Component: E221__MFL-YLG  H50 0500
   Serial number: YLG-0700092238221097
   Coding: 280800
   Component: J367-BDMHella  H11 9070
   Serial number: 0999139200
                    Reset counter: 83
                    Mileage: 135558 km
                    Date: 2026.10.28
                    Time: 22:37:39
                    Terminal 15: OFF
                    Fault Frequency: 12
                    Reset counter: 105
                    Mileage: 134678 km
                    Date: 2026.10.22
                    Time: 05:39:50
                    Terminal 15: OFF
Address 22: AWD (-----)       Labels:| 0CQ-907-554-V1.clb
   Part No SW: 5WA 907 554 P    HW: 5WA 525 130
   Component: 4Motion       H65 0724
   Coding: 0301
   ASAM Dataset: EV_AllWheelContrHA1VW37X 005001
   ROD: EV_AllWheelContrHA1VW37X_005.rod
   VCID: 5BF6895F5297194575-800F
Address 3C: Lane Change (J1086)       Labels:| 2Qx-907-686-V2.clb
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 11230052968038  Dataset Number: V03935332MH 0001
   Coding: 5294C640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW41.rod
   VCID: 393A33D7B8EB0B5547-806D
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 11230053012268
2240560 - Databus
          [databus error value received - ESP_10 - ESP_HR_Fahrtrichtung]
                    Fault Frequency: 49
                    Mileage: 134561 km
                    Date: 2026.10.21
                    Time: 11:24:10
2240559 - Databus
          [databus error value received - ESP_10 - ESP_HL_Fahrtrichtung]
                    Fault Frequency: 49
                    Mileage: 134561 km
                    Date: 2026.10.21
                    Time: 11:24:10
2240558 - Databus
          [databus error value received - ESP_33 - ESC_Verz_Reg_nicht_verfuegbar]
                    Reset counter: 3
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 10:29:58
2240515 - Databus
          [databus error value received - ESP_02 - ESP_QBit_Gierrate]
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:31
2236417 - Databus
          [databus unreasonable message - LWI_QBit_Lenkradwinkel]
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:31
2236426 - Databus
          [databus unreasonable message - LWI_Lenkradwinkel]
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:31
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS003 0350
   Serial number: YB008VKR005FE Dataset Number: V03935346DY 0001
   Coding: 003413200000020000040000
   ROD: EV_DCU2DriveSideMAXHKLO_VW41.rod
   VCID: 4AD87C1BED0D90CDDE-801F
   Subsystem 1 - Part No SW: 5Q6 959 812 A    HW: 5Q6 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  001 0006
   Serial number: 00000000000014317320
   Coding: 011000
   Part No SW: 3QF 909 144 B    HW: 3QF 909 144 A
   Component: EPS_MQB_ZFLS  570 1582
   Dataset Number: V03935328UN 0001
   Coding: 891F0000
   ROD: EV_SteerAssisMQB_015.rod
15873 - Steering angle sensor
          B1168 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:13
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 14.25 V
                    Temperature: 50.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 14.27 V
                    uAdSensI_SwitchedKl30_xdu16: 14.18 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 65
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:13
                    Motor status: 01
                    KFC: 4B
                    KFA: 00 04
                    Freeze frame conditions: 7F
                    uioUdNotFilt_xdu16: 14.44 V
                    uAdSensI_SwitchedKl30_xdu16: 14.36 V
   Part No SW: 3Q0 907 338 G    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0382
   Serial number: 24122200840357 Dataset Number: V03935379CD 0001
   Coding: 000000070900135200012000030000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 004006
   ROD: EV_MultiModulContiVW48X_004_VW41.rod
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS003 0350
   Serial number: YB008VKR00C45 Dataset Number: V03935346DZ 0001
   ROD: EV_DCU2PasseSideMAXHKLO_VW41.rod
   VCID: 49DA4317E80B9BD5D7-801D
   Subsystem 1 - Part No SW: 5Q6 959 811 A    HW: 5Q6 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  001 0006
   Serial number: 00000000000014419711
   Coding: 091000
   Part No SW: 3CN 035 869 D    HW: 3CN 035 869 D
   Component: MU-E--ER      720 0970
   Serial number: 26102300020259 Dataset Number: V03935358JE 0001
   Coding: 02140600BE00000041220001001000009F0000D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001044
   ROD: EV_MUEnt4CGen2LGE_VW41.rod
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [00001001] - Open Circuit
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:13
                    Voltage terminal 30: 14.3 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 54 dBµV
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [A/C system (0x02) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 43
                    Mileage: 134678 km
                    Date: 2026.10.22
                    Time: 07:00:30
                    Voltage terminal 30: 14.4 V
                    BAP-BAP_Function_ID: 00
7171 - Function Restricted due to Missing Message(s)
          [Auxiliary heater (0x03) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 21
                    Mileage: 134628 km
                    Date: 2026.10.21
                    Time: 16:31:18
                    Voltage terminal 30: 13.2 V
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:16
7206 - Function Restricted due to Missing Message(s)
          [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 19
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:16
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 5WA 035 283 C    HW: 5WA 035 283
   Component: OCUGen3Low    H10 0304
   Serial number: 0000000207NVPA2 Dataset Number: V03935386VP 0001
   Coding: 02416020196828008005461160100607
   ASAM Dataset: EV_OCUGen3Low 003008
   ROD: EV_OCUGen3Low.rod
   VCID: 45C24F27C4137FB533-8011
1585 - invalid data record
          B2005 00 [00001001] - -
          [ECU (Dataset Download)- Invalid data record (ECall)]
                    Fault Frequency: 104
                    Mileage: 134600 km
                    Date: 2026.10.21
                    Time: 13:48:49
12866049 - Databus
          [Airbag: Error value received]
                    Fault Frequency: 89
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:25
2566 - GPS Antenna
          B1054 13 [00001001] - Open Circuit
          [GPS-Antenna - Interruption]
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:28
1575699 - LTE Antenna 2
          B180B 13 [00001001] - Open Circuit
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:28
1572115 - LTE Antenna 1
          B17FD 13 [00001001] - Open Circuit
                    Mileage: 134547 km
                    Date: 2026.10.21
                    Time: 09:51:28
   Part No SW: 992 941 571 AA    HW: 992 941 571 A
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_001_VW41.rod
   VCID: 618ABBB770FB33952F-8035
   Component: LED1R         H08 9002
End----------(Elapsed Time: 01:47, VBatt start/end: 12.6V/12.5V)-----------
------------------------------53 Faults Found------------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
We usually don't do this for non-customers, so thank the person you borrowed the HEX-NET from. If you had used VCDS initially, there would be record and you would not have to ask for this in the first place. ;) Your ESC Coding should be...
44FC6B8D80221A75C57C0308A2C66922D60158A3C045967610415558D28A4A0B004023641C12141A1D8DDB45506CC8CF
Quantum11
New York, USA
Thank you so much you don’t understand how much this helped me. I will input the long code tomorrow. I will honestly look at investing in this tool myself seeing all the stuff it can actually do. Thank you again
