Hi all
New person here. New to using scan tools on cars and trying to fix them too, so please bear with me
I've a 2015, 64 plate Audi A1 (RHD UK) that has no heating. After a bit of googling and testing things I've narrowed the main problem down to heat flap door actuator, V68 I believe. Decided I needed a scan tool to be sure of some things and so bought VCDS. I've run a scan now and got the following results:
So I know there's a few different codes there (not worried about the tyres, I just need to inflate them. Also not worried about airbag since I have that partially disconnected since I removed glove box) but I want to focus on getting my heating sorted ASAP. Planning to take the dash of the car out this weekend. Never done that before so should be interesting
I'm removing the dash because current access to the actuator in question is really poor from passenger footwell. Also, I understand V68 sits in a plastic carrier frame with another actuator, and I don't see it's reasonably possible to remove that with the dash on.
What I've done so far:
Google and chatGPT led me to check cooling system and heater matrix. I've checked for a bag of silica gel in the coolant tank, and can't see any. Apparently this model/year car may have those, and they can break, leaking the gel into the matrix and clogging it. I've established there is heat to the matrix since both hoses are hot when engine is warm. So since there's not a lot of room in these little A1's I've already removed the centre console, and drivers and passenger side under-dash panels. Then I followed the clicking sound to find a faulty actuator. It's obvious there's a problem with the actuator since when moving the heat control to hot I can see and hear the actuator slipping/clicking, trying to turn, but it will not. I can manually wind the sprocket that the suspect actuator connects to, opening the heat flap. When I do that I do get heat coming through the vents, so with a little luck, replacing V68 will solve my main problem. Interestingly, when I turn heat control to hot and also manually move the sprocket to hot, turning heat control back to cold does function normally and the actuator & flap will move back into the cold position.
I do also have another faulty actuator which seems to be preventing airflow to drivers side footwell, both front and rear.
To be honest, I will probably need some help with coding a new actuator to the vehicle once fitted, and maybe resolving some of the other minor issues. VCDS looks super cool and a handy bit of kit but this is new territory for me, so should be interesting!
Anyhow, I will keep this post updated as I move along trying to solve the problem
Tuesday,20,October,2026,19:10:51:33568
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.5
VIN: WAUZZZ8X0FB006541 License Plate:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F
VIN: WAUZZZ8X0FB006541 Mileage: 93080km-57837miles
Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 AL HW: 04E 907 309 AC
Component: 1.4l R4 TSI H21 0826
Revision: R7H21--- CVN: 6321B5F8
Coding: 00190032242401080000
Shop #: WSC 40509 001 1048576
ASAM Dataset: EV_ECM14TFS01104E906027AL 001004
ROD: EV_ECM14TFS01104E906027AL.rod
VCID: 6E822FE3601F377A05C-803A
VINID: 9D196AAAA22801648000614404B2586522
Address 03: ABS Brakes (J104) Labels:. 6C0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 J HW: 6R0 907 379 BA
Component: ESP9.0i H03 0003
Serial number: 08505922141029
Coding: 33DF488B4E2333C60919106D0052CC1272CC9008000AE2090F00
Shop #: WSC 00046 412 00000
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
ROD: EV_Brake1ESP90iBOSCHPQ26_AU21.rod
VCID: 3632C78358CF4FBA0DC-8062
0629 - Tire Pressure Warning
C102D 00 [10001001] - -
Fault Frequency: 57
Reset counter: 0
Mileage: 92904 km
Date: 2026.10.07
Time: 17:50:03
Address 08: Auto HVAC (J255) Labels:* Redir Fail!
Part No SW: 8XA 820 043 HW: 8XA 820 043
Component: Klima 1 Zone H01 0010
Serial number: 00000000302354 Dataset Number: 8X0820043 0001
Coding: 6420080880
ASAM Dataset: EV_AirCondiFrontAU210 007002
ROD: EV_AirCondiFrontAU210_007.rod
VCID: 025A6B534487231AF14-8056
0001 - Motor for Temperature Flap
B108F 07 [00001001] - Mechanical Failure
Reset counter: 177
Mileage: 91508 km
Date: 2026.06.29
Time: 10:48:33
Voltage terminal 30: 14.4 V
Inside temperature: 25.6 C
Outside temperature: 24.0 C
Temperature door - Specified value-Data: 0.0 %
Temperature flap: actual value-Data: 5.4 %
0005 - Motor for Central Flap
B11AB 07 [00001001] - Mechanical Failure
Reset counter: 150
Mileage: 91508 km
Date: 2026.06.29
Time: 09:54:48
Voltage terminal 30: 14.3 V
Inside temperature: 24.0 C
Outside temperature: 23.0 C
Central air flap motor: actual value-Data: 100.0 %
Central air flap motor: spec. value-Data: 8.9 %
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 AB HW: 8X0 907 063 AB
Component: BCM PQ35 M 113 0817
Revision: AB113817
Coding: 08000A2CB805F100205841E02104015453FB290A01EF4922DC08878300C5
Shop #: WSC 00046 000 00000
VCID: 7CA615AB26E355EABB8-8028
Subsystem 1 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 23448517
Coding: 02005D
Subsystem 2 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 AE HW: 8X0 919 475
Component: PARKHILFE 4K H03 0080
Revision: 11001001 Serial number: 37031431501898
Coding: 000002
ASAM Dataset: EV_EPHVA14AU21X0000 003007
ROD: EV_EPHVA14AU21X0000_003.rod
VCID: 09487C7F79B17042B0E-805C
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8XA 959 655 HW: 8XA 959 655
Component: Airbag10.41 H07 0011
Revision: -------- Serial number: 003NV0004EXM Dataset Number: 8XA909602A 0007
Coding: 30314539313130323430554A305238584153
ASAM Dataset: EV_Airba1041BPAAU210 001018
ROD: EV_Airba1041BPAAU210.rod
VCID: 186E293B321B99CA3F0-804C
Serial number: 3554VRB400K52M14SPAZ
Serial number: 3575HRB40672QRBID8F/
Serial number: 3585HRB40532PMQ00955
Rear end impact crash sensor:
Serial number: 3515ZRB400452MRAFOL6
9446677 - Redundant signal path for airbag shut-off; passenger side
B1025 15 [10001001] - Open or Short to Plus
Mileage: 92947 km
Date: 2026.10.11
Time: 14:24:36
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [10001001] - Open or Short to Plus
Mileage: 92947 km
Date: 2026.10.11
Time: 14:24:37
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 521 D HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0162
Revision: FF010018 Serial number: 20141104200327
Coding: 1084204000
ROD: EV_SMLSNGVOLWSXS.rod
VCID: 3D20D8AF7DF99CE2CC6-8068
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Serial number: 28 10 2014 C0084437
Address 17: Instruments (J285) Labels:| 8XA-920-KOM-V1.clb-SRI1
Part No SW: 8XA 920 980 HW: 8XA 920 980
Component: KOMBI_MEDIUM H04 0450
Coding: 41DE01
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
VCID: 0D40486F0DD96C629C6-8058
Address 19: CAN Gateway (J533) Labels:. 8X0-907-468.clb
Part No SW: 8U0 907 468 AC HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0074
Revision: 1P140041 Serial number: 4141P14B090DB9
Coding: FBCF1A57000100010153
VCID: 03546E575B1D2A12FA2-8056
Subsystem 1 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 61282E20512821904491
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 14082000000000000748
Component: IMMO H04 0450
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 K HW: 8X0 959 793 K
Component: TSG FA H11 0415
Coding: 011E02200001000100
VCID: 55F0600FE50964A2E46-8000
02111 - Motor for Window Regulator
Fault Status: 01100101
Reset counter: 170
Mileage: 93053 km
Date: 2026.10.19
Time: 07:51:30
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R2 909 144 AD HW: 6R2 909 144 E
Component: EPS_TRW_ALow 322 3124
Serial number: CEAE0625 Dataset Number: 8XA909852B 0014
Coding: 800700
ASAM Dataset: EV_SteerAssisUDSTRW 014026
ROD: EV_SteerAssisUDSTRW_014.rod
VCID: 7AAA13B32C576BDAA94-802E
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 K HW: 8X0 959 792 K
Component: TSG BF H11 0415
VCID: 54F69D0BEEF37DAA138-8000
Part No SW: 8XA 035 192 A HW: 8XA 035 192 A
Component: RMC Nav Plus H61 0139
Coding: 0101000100C053470023020103010000000000
VCID: 46D2B74328AFDF3A9DC-8012
Subsystem 1 - Part No: 8X0 919 884 H
Component: P28-50-14.06 0001
Subsystem 2 - Part No SW: 8X0 919 603 B HW: 8X0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9462K80E2838945
End----(Elapsed Time: 00:55, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
------------------------------6 Faults Found----------------
I'm removing the dash because current access to the actuator in question is really poor from passenger footwell. Also, I understand V68 sits in a plastic carrier frame with another actuator, and I don't see it's reasonably possible to remove that with the dash on.What I've done so far:
