- Jul 20, 2026
- 4
- 0
- South Africa
- C?ID=659912
Good day all,
I am sitting with an odd issue and can't seem to find the problem!
Firstly the vehicle in question - 2016 T6 Crewbus 2.0Btdi DSG 4 Motion
When I am driving as the vehicle should do it locks doors when I reach 15 Km/h, I have physically checked all doors do lock and stay locked, no open door displays on the dashboard and with VDCS plugged in, shows all four doors closed and locked (I don't see an option for Tailgate though unless it is somewhere else)
But the strange part is when I slow down and have decelerated to exactly 30Km/h it sounds as if the doors actuators are being powered and attempting to lock doors again. One thing I must add, is it only does this when decelerating with the foot on the brake pedal, if you just leave accelerator and allow the vehicle slow down by itself it does not try locking the doors!
I have driven with VCDS connected, monitoring door locks and status does not change at all, all four show locked and stay that way while driving.
Could anyone advise about how I could eliminate or track the fault? Because the tailgate doesn't show on VCDS, I unplugged both cables to the locks hoping if it was that door that the problem would stop, but not sure if that would have worked as I know there are micro-switches in latches that need to be activated.
PS: I see there is a new error now under 09 this has not shown up on all previous scans, I think it may be because I had unplugged rear latch and actuator yesterday as i was trying to isolate the problem and did not clear codes again before scanning today.
Thursday,22,October,2026,11:25:44:20369
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.5
VIN: WV2ZZZ7HZHH024860 License Plate: JLR778FS
Mileage: 253600km-157579mi Repair Order: 261022
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 22 25 5F 69 0B
VIN: WV2ZZZ7HZHH024860 Mileage: 253600km-157579miles
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 019 GM HW: 03L 907 309 L
Component: R4 2,0L EDC X38 8374
Revision: 22X38--- Serial number: 00000000000000 CVN: 2A9F68D5
Coding: 01254012233600080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20BTD01103L906019GM 003007
ROD: EV_ECM20BTD01103L906019GL_003.rod
VCID: 7CA52197F66F9EFABB8-8028
VINID: 9E60AAAAA1D8A9860008420600CA9F5837
4990 - Glow Plug Cylinder 3
P066E 00 [01101101] - Short to Ground
Mileage: 253491 km
Date: 2026.10.19.
Time: 06:26:26
Engine speed: 0.00 /min
Coolant temperature: 19 °C
Intake air temperature: 18 °C
Ambient air pressure: 850 mbar
Voltage terminal 30: 11.920 V
Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
Electric auxiliary heater: relay activation-Bits 0-7: 0
Pre-glow time: 1100 ms
Glow status-Bits 0-7: 0
Glow status-Bits 0-7: 48
Glow cycles above temperature threshold-Bits 0-7: 0
Glow cycles below temperature threshold-Bits 0-7: 0
Glow cycles below temperature threshold-Bits 0-7: 8
Outside temperature: 15.5 °C
Readiness: 0 0 0 0 X
Part No SW: 0BT 300 011 R HW: 0BH 927 711 G
Component: DSG DQ500-7A H11 2410
Revision: 00H11V01 CVN: 1193518F
ROD: EV_TCMDQ500021.rod
VCID: 3D23EC93ADF557F2CC6-8068
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 41786000001623
Coding: 307EC098656484820C7D037CA68221A3290000
Shop #: WSC 02739 790 50316
VCID: 3FDF969BA7F945E2DEA-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 08061613470101
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA12B9FE0738CEA95C-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AJ HW: 7E0 907 047 AJ
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000402
Shop #: WSC 02737 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 72B90FAFA42BD88AE14-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 187160301
Coding: 32AC393A0A61361380284874642B8CD40F80710F60CE4D60320400230800
Shop #: WSC 07623 002 1048576
VCID: 2A09D7CF4CFBD04A994-807E
Subsystem 1 - Part No SW: 7E0 959 801 P HW: 7E0 959 801 P Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 0653
Serial number: KU0KU005071661875811
Coding: 1000B0
Subsystem 2 - Part No SW: 7E0 959 802 P HW: 7E0 959 802 P Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 0653
Serial number: KU0KU005071661874144
Coding: 0000A0
Subsystem 4 - Part No SW: 2H0 959 442 HW: 2H0 959 442
Component: E221__MFL-DC1 H02 0103
Serial number: 29160001336840126266
Coding: A4FFFF
00329 - Control Circuit for Unlocking Rear Lid
Fault Status: 00101011
Reset counter: 247
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28261613100997
Coding: 31810C
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BB00A3A12DE39218E-8024
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag021 H08 0018
Revision: -------- Serial number: 003V3001BLA. Dataset Number: 7E0003V____ 0905
Coding: 000000000000000000000000000000003231
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A29E78FBCDB60CAE94-806E
Part No SW: 7E0 920 870 S HW: 7E0 920 870 S
Component: KOMBI H03 1104
Coding: 140B010100
VCID: 392BF883B9DD6BD2E0E-806C
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042305
VCID: 688D6DC79277225A4F0-803C
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0AY 907 554 L HW: 0CQ 525 130 A
Component: Haldex4Motion H53 7620
Serial number: HA1-00017.05.16 Dataset Number: v1260x015G0 0000
Coding: 0505
ROD: EV_AllWheelContrHA1VW37X_002_VW37.rod
VCID: 54F5A9373E7FB6BA138-8000
Component: IMMO H03 1104
VCID: 6A8917CF8CFB104A594-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 G HW: 1K8 035 150 G
Component: MU-E--ER 055 7067
Serial number: 18051600011259 Dataset Number: V03935243TT 0001
Coding: 065700003C00000041110001000110001F0000D60000010001
ROD: EV_MUEnt4CGen2LGE_SK26.rod
VCID: 290B28C3497DDB5290E-807C
0001 - Antenna 1 for Radio
B1119 13 [00001001] - Open Circuit
Reset counter: 200
Mileage: 253484 km
Date: 2026.10.18.
Time: 15:13:47
Voltage terminal 30: 13.7 V
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000410784939
Coding: 410D000103000000
Shop #: WSC 02739 790 00000
VCID: 3239CFAF642B988A214-8066
End----------(Elapsed Time: 01:21, VBatt start/end: 13.8V/13.8V)-----------
------------------------------3 Faults Found-------------------------------
