Golf 7 1.6 TDI DSG DQ200 - B1162 29 - Selector Lever Park Switch - 5Q0713128A
Ivan B
Montenegro
C?ID=644192
Hello everyone,
I am writing from Montenegro and would appreciate some advice.
Vehicle: VW Golf Mk7, 2016, 1.6 TDI
Transmission: 7-speed DSG DQ200
Mileage: 224,549 km
My VCDS Auto-Scan shows the following fault in Address 16 – Steering Wheel:
617752 - Selector Lever Park Position Lock Switch
B1162 29 - Signal Implausible
Confirmed - Fault Frequency: 254
Address 02 – Auto Transmission has no fault codes.
I found a repair kit with part number 5Q0 713 128 A.
I would like to ask:
  1. Is this the correct repair kit for my vehicle?
  2. Can this problem normally be fixed by replacing only the microswitch, without replacing the complete gear selector assembly?
  3. Can anyone recommend a trustworthy seller of genuine VW parts or a good-quality repair kit that ships to Montenegro?
  4. Is any coding or adaptation required after replacement?
My complete VCDS Auto-Scan is included below.
Thank you very much for your help!
Best regards from Montenegro.
Wednesday,14,October,2026,11:02:13:09184
VCDS Version: 26.9.0.3 (x64)  HEX-NET2 CB: 0.4713.5
VIN: WVWZZZAUZGW066609   License Plate:
Mileage: 224549km-139528mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGW066609   Mileage: 224549km-139528miles
Address 01: Engine (2D2D2-CXXB)       Labels:. 04L-907-425-V1.clb
   Part No SW: 04L 906 056 CR    HW: 04L 907 445 B
   Component: R4 1.6l TDI   H06 2181
   Revision: 22004001
   Coding: 0125401243641D092000
   ASAM Dataset: EV_ECM16TDI03004L906056CR 002004
   ROD: EV_ECM16TDI03004L906056AJ_002_VW37.rod
   VCID: 7F50725EB77F42F29EA-802A
   VINID: 9E69EAAAA465A979C0186180248F411F2C
14 Faults Found:
25796 - Body Control Module (Central Electric)
          U0140 00 [00100000] - No Communications
                    Mileage: 223722 km
                    Engine speed: 0.00 /min
                    Vehicle speed: 5 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 12.031 V
                    Unlearning counter according OBD: 20
                    Accelerator pedal travel: raw value: 0.00 %
                    Cruise Control System (CCS): status: Malfunction
                    selected gear: Shifting process active
25797 - Diagnostic Gateway
          U0146 00 [00100000] - No Communications
                    Mileage: 223722 km
                    Voltage terminal 30: 12.078 V
                    Cruise Control System (CCS): status: Initialization
25807 - No Communication with ABS Brake Control Module
          U0121 00 [00100000] - -
          [Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
                    Mileage: 223722 km
                    Voltage terminal 30: 12.070 V
25809 - Power Steering Control Module
          U101D 00 [00100000] - No Communication
          [Power steering control moduleNo communication]
                    Mileage: 223722 km
25810 - No Communication with Instrument Cluster
          U0155 00 [00100000] - -
          [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
                    Mileage: 223722 km
25811 - No Communications with HVAC Control Module (J301)
          U0164 00 [00100000] - -
                    Mileage: 223722 km
25812 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00100000] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 223722 km
                    Voltage terminal 30: 12.062 V
25802 - Steering Column Control Module
          U0212 00 [00100000] - No Communications
                    Mileage: 223722 km
25107 - Cruise Control Switch (E45)
          P0568 00 [00100000] - Implausible Signal
                    Date: 2000.01.00
                    Shut-off timer: last ECM after-run time: 162 s
                    Terminal 15 status: On
25124 - Databus
          U1123 00 [00100000] - Received Error Message
25126 - Databus
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:33
                    Coolant temperature: 91 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 12.148 V
                    Unlearning counter according OBD: 21
                    CAN status - engine control module: 0
25130 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [00100000] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 223722 km
27019 - Implausible Data Received from ABS Control Module
          U0415 00 [00100000] - -
          [Invalid Data Received FromAnti-Lock Brake System Control Module]
                    Mileage: 223722 km
                    Voltage terminal 30: 12.140 V
                    Air mass at air mass meter 1: 0.0 kg/h
                    Standardized air flow ratio: 1.000 counts
                    Exhaust recirculation valve 1 bank 1: position feedback – actual value: 0.00 %
                    Throttle valve adapter 1 bank 1: position feedback – actual value: 0.00 %
                    Charge air pressure: specified value: 0.000 bar
                    Absolute intake pressure: 99 kPa abs
                    Mean injection quantity: 0 mg/stroke
                    Index of current engine mode: 8
                    Index of next requested engine mode: 8
                    Index of engine target mode: 8
27171 - Heater support pump
          P16C1 00 [00100000] - Open circuit
                    Date: 2000.01.00
                    Coolant temperature: 53 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 12.359 V
                    Unlearning counter according OBD: 7
                    Particulate filter output: temp. sensor 1: bank 1: raw value: -40.0 °C
                    Exhaust flap actuator 1 bank 1: position feedback – specified value: -0.01 %
                    Exhaust flap actuator 1 bank 1: position feedback – actual value: 0.00 %
                    Exhaust flap actuator 1 bank 1: position feedback – offset closed: 1.47 %
                    Exhaust flap actuator 1 bank 1: position feedback – uncnd. voltage: 4.285 V
Readiness: N/A
   Part No SW: 0CW 300 048 J    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0611
   Revision: 00005005    Serial number: CU501507155597 CVN: 9981641C
   ROD: EV_TCMDQ200021.rod
   VCID: 43D83EAE9B17E612BA2-8016
   Revision: 00000000    Serial number: 61895000002138
   Coding: 01FA62A124260972077D060041CC2580462490E06082A4F31842F078C202
   VCID: 7AA6834AAC5D67DAA94-802E
19 Faults Found:
8192 - Databus
          [FCAN: ACC_07 message is not received]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
8196 - Databus
          [FCAN : ACC_10 message is not received]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
8200 - Databus
          [FCAN: Airbag_01 message is not received]
                    Reset counter: 69
                    Mileage: 223722 km
8212 - Databus
          [FCAN: BEM_05 message is not received]
                    Reset counter: 69
                    Mileage: 223722 km
8222 - Databus
          [FCAN : Getriebe_11 message is not received]
                    Reset counter: 69
                    Mileage: 223722 km
8236 - Databus
          [FCAN: Kombi_01 messagei is not received]
                    Reset counter: 69
                    Mileage: 223722 km
8252 - Databus
          [FCAN: Motor_11 message is not received]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
8254 - Databus
          [FCAN: Motor_12 message is not received]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
8258 - Databus
          [FCAN: Motor_20 message is not received]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
8264 - Databus
          [FCAN: Tsk_06 message is not received]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
8286 - Databus
          [FCAN: MO_Timeout_ESP signal is invalid]
                    Reset counter: 69
                    Mileage: 223722 km
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [00001000] - -
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:12
32864 - Databus
          [IPB-BUS: Klemmen-Status_01 / ZAS_KL_S invalid]
                    Reset counter: 69
                    Mileage: 223722 km
32865 - Databus
          [IPB_BUS: Motor_12 / MO_Drehzahl_01]
                    Reset counter: 69
                    Mileage: 223722 km
32866 - Databus
          [IPB-BUS: Motor_20 / MO_Solldrehz_Leerlauf invalid]
                    Reset counter: 69
                    Mileage: 223722 km
32867 - Databus
          [IPB-BUS: Motor_11 / MO_Mom_ist_Summe invalid]
                    Reset counter: 69
                    Mileage: 223722 km
32870 - Databus
          [IPB-BUS: Getriebe_11 / GE_Zielgang invalid]
                    Reset counter: 69
                    Mileage: 223722 km
32872 - Databus
          [IPB-BUS: Motor_20 / MO_Fahrpedalrohwert_01invalid]
                    Reset counter: 69
                    Mileage: 223722 km
32874 - Databus
          [IPB_BUS: Klemmen_Status_01 / ZAS_KL_15 invalid]
                    Reset counter: 69
                    Mileage: 223722 km
   Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
   Revision: 00001K08
   Coding: 00020114202100011005000000101002
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6984CC06D9FBDC4250E-803C
   Air quality sensor:
   Part No SW: 5Q0 937 084 AQ    HW: 5Q0 937 084 AL
   Component: BCM MQBAB M   H24 0175
   Serial number: 01061519603177 Dataset Number: V03935222AW 0001
   Coding: 00101842C24102FB4BE44000000403081000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0740EABEEFAF0A32A6A-8052
   Component: WWS    150629  043 0551
   Serial number:         150710043540
   Component: RLHS  037 0059
   Serial number: S3Y15M07D21H17M57S53
   Coding: 90A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.403  H03 0004
   Serial number: 0000FST000F5KKO00000
   Coding: 181901
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [00001000] - Open or Short to Plus
                    Reset counter: 56
                    Mileage: 223074 km
                    Date: 2026.08.28
                    Time: 15:37:07
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beams: operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 13.3 V
                    Outside temperature: 35.0 °C
12307 - License Plate Light
          B12CA 01 [00001001] - Electrical Failure
                    Reset counter: 49
                    Mileage: 224285 km
                    Date: 2026.10.05
                    Time: 13:23:56
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: operated
                    Low beams: Not operated
                    Voltage: 10.2 V
                    Outside temperature: 24.5 °C
   Revision: --------    Serial number: 39331519804340 Dataset Number: 5G0039v__A_ 0023
   Coding: 0071051011
13637426 - Databus
                    Reset counter: 69
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 12061503211412 Dataset Number: 5g0114v____ 1027
   Coding: 001C1100FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A26434AECDDA7DAE94-806E
10 Faults Found:
0264 - Databus
          [FAULT_CIM_TIMEOUT_ESP_08]
                    Reset counter: 69
                    Control Module temperature: 35 °C
                    Voltage terminal 15: 11.6 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
0265 - Databus
          [FAULT_CIM_TIMEOUT_ESP_10]
                    Reset counter: 69
0268 - Databus
          [FAULT_CIM_TIMEOUT_ESP_21]
                    Reset counter: 69
0269 - Databus
          [FAULT_CIM_TIMEOUT_GRA_ACC_01]
                    Reset counter: 69
0284 - Databus
          [FAULT_CIM_TIMEOUT_Getriebe_11]
                    Reset counter: 69
0281 - Databus
          [FAULT_CIM_TIMEOUT_TSK_06]
                    Reset counter: 69
1797 - Internal Fault
          B200F F0 [00001000] - -
          [FAULT_TX_TIMEOUT_ACC_06]
                    Reset counter: 69
                    Voltage terminal 15: 11.8 V
1796 - Internal Fault
          [FAULT_TX_TIMEOUT_ACC_07]
                    Reset counter: 69
1795 - Internal Fault
          [FAULT_TX_TIMEOUT_ACC_10]
                    Reset counter: 69
0077 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [FAULT_VMON_VZ_LOW]
                    Reset counter: 81
                    Mileage: 224285 km
                    Date: 2026.10.05
                    Time: 13:24:09
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 10.4 V
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    015 0388
   Serial number: 003MLR0XT8CQ Dataset Number: 5G0003v____ 0094
   Left seat belt tensioner:
   Serial number: 34169667B16071510645
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169668B16071540200
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 907 15
   Serial number: 3576700000041749251I
   Subsystem 4 - Part No SW: -----------    HW: 480 000 707 15
   Serial number: 358670000008BA95551/
   Subsystem 5 - Part No SW: -----------    HW: 480 400 907 15
   Serial number: 3516502A11B7E8F2915K
   Subsystem 6 - Part No SW: -----------    HW: 480 400 907 15
   Serial number: 3526502C51B7E8F4133L
   Subsystem 7 - Part No SW: -----------    HW: 480 400 907 15
   Serial number: 3556502C71B7E8F413E.
   Part No SW: 5Q0 953 507 GK    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 16071504401644
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_017_VW37.rod
   VCID: 055CE0B6D5A31822D46-8050
          B1162 29 [00001001] - Signal Implausible
                    Reset counter: 49
                    Mileage: 221437 km
                    Date: 2026.07.02
                    Time: 11:21:01
                    Operating time: 350555 min
                    Terminal 30 power supply: 14.5 V
                    Vehicle speed: 11 km/h
                    Voltage at switch: 5.02 V
                    Terminal 15 status: active
                    System status: 30
   Part No SW: 5G1 920 741 A    HW: 5G1 920 741 A
   Component: KOMBI         207 7640
   Coding: 07A41A082780000801886A011400000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009005
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 251C803675633822B46-8070
13 Faults Found:
9456433 - Key
          B104B 31 [00001000] - No Signal
                    Reset counter: 70
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
16776962 - Databus
          [Airbag_01 keine Kommunikation]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
16776965 - Databus
          [BEM_02 keine Kommunikation]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
16776968 - Databus
          [ESP_24 keine Kommunikation]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
16776971 - Databus
          [Motor_04 keine Kommunikation]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
16776978 - Databus
          [LH_EPS_01 keine Kommunikation]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
16776983 - Databus
          [WBA_03 keine Kommunikation]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
16776988 - Databus
          [TSK_07 keine Kommunikation]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
16776993 - Databus
          [ESP_21 keine Kommunikation]
                    Reset counter: 69
                    Mileage: 223722 km
                    Date: 2026.09.18
                    Time: 10:02:05
16777024 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
          [BAP_BCME_0x23 keine Kommunikation]
                    Reset counter: 89
                    Mileage: 221436 km
                    Date: 2026.07.01
                    Time: 15:51:40
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1224
   Revision: --------    Serial number: 0003741382 Dataset Number: 5G0067V____ 2215
   Coding: 030100041F087300FB00025C1C0F00010001050000000000000000000000
   GVL: 01543C0000000000400C80000000C80000000000000000000000000000000000
   ROD: EV_GatewLear_013_VW37.rod
   VCID: 75BC9076854308A2C46-8020
   Generator:
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001446150055285
   Coding: 2CFFFF
   Serial number: 0786307103
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-DCD-V1.clb
   Serial number: 080715BG803753 Dataset Number: 5G0222v____ 0064
   Coding: 00310320D000048000001000
   Serial number: 00000000000006830365
   Coding: 110000
          B1487 54 [00001000] - Missing Calibration / Basic Setting
                    Fault Frequency: 9
                    Reset counter: 64
                    Mileage: 221454 km
                    Date: 2026.07.03
                    Time: 17:46:30
65648 - Controls for Window Regulator; Driver Side
          B1315 29 [00001000] - Signal Implausible
                    Fault Frequency: 36
                    Reset counter: 89
                    Mileage: 222435 km
                    Date: 2026.08.04
                    Time: 23:46:41
   Component: EPS_MQB_ZFLS  126 1061
   Dataset Number: 5G0074v____ 0887
   Coding: 0103
7 Faults Found:
22272 - Databus
          [KFC_MOTOR_11 Botschaft - CAN-Timeout]
                    Motor status: 03
                    System status: Driving mode
                    Supply voltage: 11.75 V
                    Temperature: 39.0 °C
                    KFC: 57
                    KFA: 00 00
                    Freeze frame conditions: 20
                    uioUdNotFilt_xdu16: 11.98 V
                    uAdSensI_SwitchedKl30_xdu16: 11.99 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
22528 - Databus
          [MOTOR_12 Botschaft - CAN-Timeout]
                    Motor status: 03
                    KFC: 58
                    KFA: 00 00
23040 - Databus
          [MOTOR_20 Botschaft - CAN-Timeout]
                    Motor status: 03
                    KFC: 5A
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 11.81 V
                    uAdSensI_SwitchedKl30_xdu16: 11.82 V
18944 - Databus
          [BEM_05 Botschaft - CAN-Timeout]
                    Reset counter: 69
                    Motor status: 03
                    KFC: 4A
                    KFA: 00 00
26624 - Databus
          [KLSTAT_01 Botschaft - CAN-Timeout]
                    Reset counter: 69
                    Motor status: 03
                    KFC: 68
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 11.78 V
                    uAdSensI_SwitchedKl30_xdu16: 11.79 V
22784 - Databus
          [MOTOR_14-Botschaft - CAN-Timeout]
                    Reset counter: 69
                    Motor status: 03
                    KFC: 59
                    KFA: 00 00
24576 - Databus
          [GATEWAY_72 Botschaft - CAN-Timeout]
                    Reset counter: 69
                    Motor status: 03
                    KFC: 60
                    KFA: 00 00
                    Freeze frame conditions: 21
   Serial number: 030715BG20920A Dataset Number: 5G0157v____ 0060
   Coding: 00310120DE00048000801000
   VCID: 42D63BAA840DEF1AB14-8016
   Serial number: 00000000000006805582
   Coding: 090000
   Part No SW: 3Q0 035 846     HW: 3Q0 035 846
   Component: MU-S-N-ER     820 0629
   Serial number:                Dataset Number: V03935223SB 0001
   Coding: 02730001FF00000051110001000808031F0100C401200100CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 6E8EBF1AE0153B7A05C-803A
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9R2011687
   Subsystem 2 - Part No SW: 3G0 919 866 H    HW: -----------
   Component: ECE 2015/16  --- 0430
0008 - Connection between Antenna Amp 2 for Radio and Antenna
          B1273 13 [00001000] - Open Circuit
                    Reset counter: 81
                    Mileage: 224285 km
                    Date: 2026.10.05
                    Time: 13:23:56
                    Voltage terminal 30: 11.4 V
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: electrically OK
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Open circuit
                    Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
End----------(Elapsed Time: 01:51, VBatt start/end: 13.0V/13.2V)-----------
------------------------------70 Faults Found------------------------------
Ivan B
Montenegro
C?ID=644192
Thank you!
Aerofan
C?ID=647191
On my old Golf 7 I dissasembled the shifter unit and I have changed the switch. Was only 0,5 euro at the time (2020), because of pandemic I also had a lot of free time :)
