Since few days my Hex Net started giving Can Init Timeout errors when connecting to any ECU. The timeout occurs only when connected by wireless mode regardless as ad hoc or infrastructure; when I connect Hex Net by USB cable, the timeout doesn't occur and everything works. I tried several different computers, different cars, it doesn't matter - timeout occurs on each ECU whether it is gateway, infotainment or engine. Engine falls back to KWP, but the others don't.
I've attached logs with debug level set to 1024. Both logs contain the same procedure - starting the app, setting debug level to 1024, selecting the connection type USB or NET, then Test, then finally selecting gateway and trying to connect to it.
What can be wrong? VCDS is the latest 26.10.2, Hex Net is updated to latest version. It was bought in January 2017, so almost 10 years old and maybe it has reached end of life and it's time to replace? I'm about to renew the SFD license, but I'm not sure if I could transfer it to the new device in case this is unrepairable.
