- May 25, 2023
- 21
- 7
- Baltimore, MD, USA
- C?ID=552127
Am currently trying to determine if it is possible to adjust the steering wheel heat levels. The only related setting I've been able to find is in control module 9, ENG153727-ENG154788:
I'm guessing this some sort of upper temp to shut off the circuit.
Should I be looking elsewhere? Is it even possible with this platform?
Full scan:
Thank you -
GG
Full scan:
Sunday,18,October,2026,10:19:29:54238
VCDS Version: 26.9.0.3 (x64) HEX-NET2 CB: 0.4713.5
VIN: xx License Plate:
Mileage: 23731km-14745mi Repair Order:
Chassis Type: B2-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 3C 42 44 4B 52 5F 6C 75
A5 BB BC CA D6 D7
VIN: xx Mileage: 23731km-14745miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DYBA) Labels: Redir Fail!
Part No SW: 05E 906 013 BL HW: 05E 907 309 BM
Component: R4 1.5l TFS H80 4651
Revision: K6H80000 CVN: C02B500C
Coding: 412A003223661108B0000000000000000000000000000000
Shop #: WSC 111111 128 28888
ASAM Dataset: EV_ECM15TFS01105E906013BL 001008
ROD: EV_ECM15TFS01105E906013BK.rod
VCID: 6B88A9F62308CDB2222-803E-R SFD+SFD2 [x]
VINID: 0E69844C74820237400090800C06FD1C31
38483 - Exhaust Gas Temp Bank 1 Sensor 1 (G235)
P2080 00 [01100000] - Implausible Signal
Reset counter: 26
Mileage: 23508 km
Date: 2026.10.14
Time: 09:48:30
Engine speed: 1277.00 /min
Vehicle speed: 39 km/h
Coolant temperature: 71 °C
Intake air temperature: 29 °C
Voltage terminal 30: 14.260 V
Unlearning counter according OBD: 26
Outside temperature: 21 °C
Absolute intake pressure: 24 kPa abs
Engine torque: 0.0 Nm
Fuel: tank fill level: 54.0 l
Oxygen sensor bank 1 sensor 1: specified value: 15.9998
Particulate filter: loading stage: 0
Overrun cut-off-Bits 0-7: 1
Address 02: Auto Trans (J217) Labels: Redir Fail!
Part No SW: 09H 927 158 B HW: 09H 927 309 A
Component: AQ8 HTS H07 0502
Serial number: K6NC2410020043 CVN: C20579B9
ASAM Dataset: EV_TCMAQ301071 001001
ROD: EV_TCMAQ301071_001.rod
VCID: 333871963BB855722A2-8066-R SFD+SFD2 [x]
Part No SW: 5Q0 614 517 GB HW: 5Q0 614 517 BP
Component: ESC H36 0114
Revision: 00000000 Serial number: 62514000002492 Dataset Number: V03935452N 0001
Coding: 86FB6A7EA0202475C5790300A2C63961560524A3C0459C7C38415558D2AA4A0B00402F641A1B13111452653B484E7CFC
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
ROD: EV_Brake1UDSContiMK100IPB_049_VW37.rod
VCID: 77A085866F407952D6A-8022-R
Part No SW: 3Q1 959 435 C HW: 3Q1 959 435 C
Component: VWKESSYMQB 037 1501
Revision: 00037000 Serial number: 0650051783 Dataset Number: V03935432CB 0001
Coding: 132C0C0723
Shop #: WSC 00066 790 00091
ASAM Dataset: EV_KessyHellaMQBAB 004056
VCID: 3B2859B613E89D32F22-806E-R
Part No SW: 2GJ 907 044 L HW: 2GJ 907 044 L
Component: Climatronic H20 0306
Dataset Number: V03935453GR 0001
Coding: 0902002420211C0C1104010C1211D014
Shop #: WSC 00066 790 00150
ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002005
ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
VCID: 47C035465F20C9D266A-8012-R
Part No SW: 5Q1 937 085 C HW: 5Q1 937 085 C
Component: BCM MQBAB HLN H56 0711
Serial number: 4309036901ÿÿÿÿ Dataset Number: V03935453KG 0001
Shop #: WSC 00066 790 00249
ASAM Dataset: EV_BCMMQB 023001
ROD: EV_BCMBOSCH_023.rod
VCID: 3A265CB21CD2A43AE94-806E-R SFD+SFD2 [x]
Subsystem 1 - Part No SW: 5Q0 955 555 A HW: 5Q0 955 555 A
Component: RLHSS 054 0207
Serial number: S7Y24M09D16H08M12S16
Coding: 0018DD
Steering Column Switch:
Subsystem 2 - Part No SW: 5Q1 953 521 KS HW: 5Q1 953 569 K
Component: Lenks.Modul H24 0190
Serial number: 0300081120240C201691
Subsystem 3 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0102
Serial number: ESE4233142
Subsystem 4 - Part No SW: 3G0 963 345 A HW: 3G0 963 345 A
Component: SysNameFanLin 015 0102
Serial number: ESE4239900
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE4233385
Subsystem 6 - Part No SW: 3G0 963 345 A HW: 3G0 963 345 A
Serial number: ESE4239912
Part No SW: 5QA 919 294 L HW: 5QA 919 294
Component: PDC 8 Kanal H12 0083
Serial number: 000C58849124316 Dataset Number: V03935456UX 0001
Coding: 8471555811
ASAM Dataset: EV_EPHVA18AU3700000 010058
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 55FCEF0E958C6B42E46-8000-R
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 2Q0 907 567 C HW: 2Q0 907 819
Component: ACCCONTIMQB H04 0541
Dataset Number: V03935448SZ 0001
Coding: 300207C25CFF8748949C812480409700000000000000004034
ASAM Dataset: EV_ACCMRRCONTIUNECEMQB 004021
ROD: EV_ACCMRRCONTIUNECEMQB_VW27.rod
VCID: 382246BA22DEB62A1F0-806C-R SFD+SFD2 [x]
Part No SW: 5Q0 959 655 CB HW: 5Q0 959 655 CB
Component: AirbagVW21 010 0421
Serial number: 003J4M0U2JX3 Dataset Number: V03935457PP 0001
Coding: 8CCCFC00000000005000001FC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
VCID: 0256E45234822CFAF14-8056-R
Component: BF-Gewichtss. H17 0022
Serial number: IBH00000000000NLWLN.
Coding: 303555
Subsystem 2 - Part No SW: ----------- HW: 480 001 009 24
Serial number: 35700000000495D8027K
Subsystem 3 - Part No SW: ----------- HW: 480 001 009 24
Serial number: 35800000000DF935327U
Subsystem 4 - Part No SW: ----------- HW: 480 400 909 24
Component: SideSensor_Dr 003 6149
Serial number: 3510001B1169E154B80
Subsystem 5 - Part No SW: ----------- HW: 480 401 809 24
Component: SideSensor_Pr 003 6149
Serial number: 3520001CE3E4B3A0980D
Subsystem 6 - Part No SW: ----------- HW: 480 021 308 24
Component: FrontSensor_D 005 0189
Serial number: 35500019EAFA0FC8580Y
Subsystem 7 - Part No SW: ----------- HW: 480 021 308 24
Component: FrontSensor_P 005 0189
Serial number: 35600019EAFA0FC3F841
Part No SW: 17A 920 420 F HW: 17A 920 420 F
Component: KOMBI 712 8125
Dataset Number: V03935456UQ 0001
Coding: 08244808EF8CCF050288624B500000080060070D
ASAM Dataset: EV_DashBoardVDDMQBA0 003062
ROD: EV_DashBoardVDDMQBA0_003_VW27.rod
VCID: 20128EDA9A4EDEEAC70-8074-R SFD+SFD2 [x]
Part No SW: 3Q0 907 530 BF HW: 3Q0 907 530 BB
Component: GW 2023 CLA 550 5585
Revision: -------- Serial number: 423702500243170 Dataset Number: V03935432SQ 0001
Coding: 0000808D0F00000000000000000000000000000000000301030000000001000000000000000000000000000000000000
GVL: 3D000000040040CC80000002C8001000000000020000000000000000000000C6
ASAM Dataset: EV_GatewMQB2020Class 001001
ROD: EV_GatewMQB2020Class_VW37.rod
VCID: 74BAB28A7E36124AF38-8020 SFD+SFD2 [x]
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H11 9070
Serial number: 2513501401
Subsystem 3 - Part No SW: 3G0 959 442 AF HW: 3G0 959 442 AF
Component: E221__MFL-YLG H07 0120
Serial number: YLG-0700084281240465
Subsystem 4 - Part No SW: 3G0 959 542 B HW: 3G0 959 542 B
Component: J IEEHOD1ZONE 251 0303
Serial number: 00000000230601283632
Control head driving profile:
Subsystem 5 - Part No SW: 5NA 927 531 A HW: 5NA 927 531 A
Component: E881 BedieFPA 001 0460
Serial number: 000000091698XKE000E7
2166903 - No Communication with Transmission Control Module
U0101 00 [00100000] - -
[TCM_no_communication]
Fault Frequency: 0
Reset counter: 0
8417280 - Diagnostic Filter
U17A0 00 [00100000] - Not Activated
[Filter_is_not_active]
Fault Frequency: 0
Reset counter: 0
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 5WA 907 554 R HW: 5WA 525 130
Component: 4Motion H66 2020
Serial number: 000004.04.24000 Dataset Number: V03935402CV 0001
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 006001
ROD: EV_AllWheelContrHA1VW37X_006_VW37.rod
VCID: 5DECF72EEDBCB302AC6-8008-R
Address 3C: Lane Change (J1086) Labels:* Redir Fail!
Part No SW: 2Q0 907 686 H HW: 2Q0 907 686 H
Component: HRE_Master H26 0320
Serial number: 11230083524383 Dataset Number: V03935446DA 0001
Coding: 56954640
ASAM Dataset: EV_HREHellaGen3MstrUNECE 001001
ROD: EV_HREHellaGen3MstrUNECE_VW27.rod
VCID: 3FD02DA607F08112DEA-806A-R
Subsystem 1 - Part No SW: 2Q0 907 685 H HW: 2Q0 907 685 H
Component: HRE_Slave H26 0320
Serial number: 11230084092881
Part No SW: 5Q4 959 593 Q HW: 5Q4 959 593 Q
Component: TSG FS 016 0920
Serial number: 26045431700515 Dataset Number: V03935440BS 0001
Coding: 003E13200000028008000000
Shop #: WSC 00066 790 00280
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001023
VCID: 53F811169B7875720A2-8006-R
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000021453379
Coding: 011000
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V2.clb
Part No SW: 5QV 907 144 F HW: 5QV 907 144
Component: BASGEN1MQB37 103 1122
Serial number: 02746189 Dataset Number: V03935421NP 0001
Coding: 01000000010000010001020101000100000001010100
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
ROD: EV_SteerAssisBASGEN1MQB37_017.rod
VCID: 5BE8F936F3A8BD32D22-800E-R SFD+SFD2 [x]
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 P HW: 3Q0 907 338 R
Component: FCM MQB High H09 0408
Serial number: 13112400841003 Dataset Number: V03935454NZ 0001
Coding: 0000000709000B5202110301000000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiMQBCl 001009
ROD: EV_MultiModulContiMQBCl_VW27.rod
VCID: 42D624527402ECFAB14-8016-R
Part No SW: 5Q4 959 592 Q HW: 5Q4 959 592 Q
Component: TSG BFS 016 0920
Serial number: 27045431102094 Dataset Number: V03935440BX 0001
Coding: 003E13200000028000000000
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001023
VCID: 52F61412A4627C7A014-8006-R
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000021388131
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G8 035 842 HW: 3G8 035 842
Component: MU-O-NS-US H04 5422
Serial number: WG8LGM151024004 Dataset Number: V03935456ZF 0001
Coding: 23165000002000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 002001
ROD: EV_MUOIMQB_002_VW27.rod
VCID: 6882D6FA32FEE6AA4F0-803C-R SFD+SFD2 [x]
Subsystem 1 - Part No SW: 5NN 919 605 D HW: 5NN 919 605 D
Component: ABT_Std-2_Nav 290 8321
Serial number: VWZ6ZMC3085073
Subsystem 2 - Part No: V03 959 821 P
Component: NAR 2025 2119
12301 - Ethernet Databus Branch 4
U122F 00 [00001000] - No Communication
Mileage: 22770 km
Date: 2026.10.04
Time: 15:24:22
Ethernet counter checksum error: branch 4: 0
Ethernet counter connection interruptions: branch 4: 0
Component: RVC Compact H19 0231
Dataset Number: V03935421ZH 0001
Coding: 01135602A2002017300040
VCID: 392443BE19D4AF22E0E-806C-R
Part No SW: 2GA 035 285 HW: 2GA 035 285
Component: OCUClas2023_H H11 0615
Serial number: 0000000410VIXF2 Dataset Number: V03935433WX 0001
Coding: 02020500020100211000010013002607111112111012011110
ASAM Dataset: EV_OCUClass2023 001063
ROD: EV_OCUClass2023.rod
VCID: 71B4BB9E0124276218E-8024-R SFD+SFD2 [x]
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 H HW: 2Q0 980 653 A
Component: MQB MFK 3.0 H19 1602
Serial number: EF1689303242430 Dataset Number: V03935440XG 0001
Coding: 00000A90116E4020089F10001030002000418000E00000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007058
1126434 - Front Camera for Driver Assist Systems
C12B3 FD [00001000] - View Temporarily Restricted
[Temporary blindness of lane detection]
Reset counter: 6
Mileage: 22540 km
Date: 2026.10.02
Time: 07:09:50
Part No SW: 4K8 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 010 0010
Dataset Number: V03935439QB 0001
Coding: 00804073163C
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 7DAC97AE4D7C53028C6-8028-R
Part No SW: 992 941 572 AG HW: 992 941 572 A
Component: LED1L H17 9104
ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
139524 - Bulb for High-Beam Headlamp
C1199 FA [00100000] - Short Circuit
[high beam - electric malfunction SC]
Component: LED1R H17 9104
ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
End----------(Elapsed Time: 02:02, VBatt start/end: 12.1V/12.1V)-----------
------------------------------7 Faults Found-------------------------------
Displaying Log-3VV4C7B20SM009203-23731km-14745mi.txt.
Thank you -
GG
