Golf 7 turn signals as DRL (5Q0-937-08X-HV1) - solved
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Someone set the turn signals to work like DRLs and that causes the bulb sockets to melt.
The owner reduced them every couple of months. He asked for disconnection, I solved it like this, if anyone needs it, here it is.
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0134
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Daytime running lights ,16 - set NOT active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,Daytime running lights ,16 - set NOT active
Saturday,17,October,2026,20:40:13:24894
VCDS Version: 26.10.0.2 (x64)  HEX-NET3 CB: 0.4713.5
Data version: 20260828 DS379.0
VIN: WVWZZZAUZFW087820   License Plate: KEMP G7
Mileage: 326457km-202850mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 52 55 5F 69 A5
VIN: WVWZZZAUZFW087820   Mileage: 326457km-202850miles
Address 01: Engine (J623-CRKB)       Labels: None
   Part No SW: 04L 906 021 AR    HW: 04L 907 309 E
   Component: R4 1,6L EDC   H22 7727
   Revision: 86H22---    CVN: F4A276C3
   Coding: 01190032045605093000
   ASAM Dataset: EV_ECM16TDI01104L906021AR 002005
   ROD: EV_ECM16TDI01104L906021AN_VW37.rod
   VCID: F5BF3EBB2547A542487-80A0
   VINID: 9E69EAAAA465A969C02072020069F7DF11
19226 - Particulate Trap Bank 1
          P2002 00 [01100000] - Efficiency Below Threshold
8195 - NOx Catalyst/Trap Bank 1
          P2000 00 [01100000] - Efficiency Below Threshold
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 62134000003791
   Coding: 01FA62A124280973037F070241C32980462490C0E08294F3F440507AC009
   VCID: 874344734FABA7D22AB-80D2
16401 - Tire Pressure Warning
          C102D 00 [00001000] - -
                    Reset counter: 14
                    Mileage: 325480 km
                    Date: 2026.10.05
                    Time: 19:29:17
   Revision: 00021000    Serial number: 0343294139 Dataset Number: 5G0IJ1v____ 0001
   Coding: 030C0C
   VCID: BA25ED874CD90A3A655-80EE
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   H03 0907
   Revision: 00001K08
   Coding: 00020114202100011105000000101000
   VCID: F3BB00A32B33BB72663-80A6
   Air quality sensor:
   Serial number: 01011421700759 Dataset Number: 5G0063v____ 0001
   Coding: 00130E46C24122FB0BA44080B11C07081800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 80515F6F6A8590EA6B1-80D4
   Component: WWS    140721  043 0551
   Serial number:         140728054848
   Component: RLHS  037 0059
   Serial number: S5Y14M08D12H17M13S00
   Coding: 00A8DD
   Serial number: 000000000ZY142022WJY
   Serial number: 00000000000030141218
   Sunroof control module:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO31533533
   Coding: 181801
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [00001000] - Open or Short to Plus
                    Reset counter: 19
                    Mileage: 325293 km
                    Date: 2026.10.02
                    Time: 19:17:14
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beams: Not operated
                    Voltage: 13.5 V
                    Outside temperature: 20.5 °C
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39431421801646 Dataset Number: 5G0039v__B_ 0078
   Coding: 0031061141
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: C2D59567240942FA3D5-8096
1111556 - Side Front Left Parking Aid Sensor
          B10F6 04 [00001000] - Internal System Fault
                    Fault Frequency: 47
                    Reset counter: 50
                    Mileage: 324913 km
                    Date: 2026.09.23
                    Time: 07:15:22
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 10081477030001 Dataset Number: 5g0114v____ 1018
   Coding: 00000D00FE0739
   VCID: B821F78F72D5182A931-80EC
1792 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [00001001] - -
          [FAULT_WORKSHOP_ALIGNMENT_NOT_DONE]
                    Reset counter: 167
                    Mileage: 318326 km
                    Date: 2026.05.26
                    Time: 19:08:43
                    Control Module temperature: 42 °C
                    Voltage terminal 15: 12.2 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R0A6T1B Dataset Number: 5G0003v____ 0096
   VCID: C1D79A6B210F59E224F-8094
   Subsystem 1 - Part No SW: -----------    HW: 480 000 508 14
   Serial number: 35767000000A6919A01V
   Subsystem 2 - Part No SW: -----------    HW: 480 000 508 14
   Serial number: 35867000000AE4D8C015
   Subsystem 3 - Part No SW: -----------    HW: 480 400 908 14
   Serial number: 3516502B916DB81112FF
   Subsystem 4 - Part No SW: -----------    HW: 480 400 908 14
   Serial number: 3526502BB16DB814812E
   Subsystem 5 - Part No SW: -----------    HW: 480 401 408 14
   Serial number: 3556502A516FC222638C
   Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 07081404401923
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_017.rod
   VCID: FBAB28830363F3323E3-80AE
   Part No SW: 5G1 920 751     HW: 5G1 920 751
   Component: KOMBI         303 5290
   Coding: 03A518106F90000800886A031400000000000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_DashBoardJCIMQBAB 009003
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: E59F6EFB95E755C2F87-80B0
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002357373 Dataset Number: 5G0067v____ 1821
   Coding: 030100340B087300EF00025A080F00010001050000000000000000000000
   GVL: 01D43C0000000600C08C90000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011_VW37.rod
   Generator:
   Component: E221__MFL-DC1  H16 0038
   Serial number: 27140001989370074326
   Coding: 2CFFFF
   Serial number: 3798754003
8526355 - Voltage Drop in Generator Leads too large
          P30DE 00 [00001000] - -
                    Reset counter: 39
                    Mileage: 318326 km
                    Date: 2026.06.03
                    Time: 17:41:32
                    Terminal 30 power supply: 13.8 V
                    Terminal 15: On
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7081
   Serial number: HA1-00024.06.14 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002011
   ROD: EV_AllWheelContrHA1VW37X_002_VW37.rod
   VCID: C6DD897708217EDA11D-8092
   Revision: 00000000    Serial number: 14000204010005
   Coding: 5500000000000000
   VCID: B439C3BF6EBDFC4ABF9-80E0
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-DCD-V1.clb
   Serial number: 31071406070233 Dataset Number: 5G0222v____ 0058
   Coding: 00311220D000040000001000
   VCID: C0D19F6F2A0550EA2B1-8094
   Serial number: 00000000000003476803
65608 - Lamp for Ambient Speaker Illumination
          B13C8 01 [00001001] - Electrical Failure
                    Reset counter: 10
                    Mileage: 316039 km
                    Date: 2026.03.24
                    Time: 12:10:49
   Component: EPS_MQB_ZFLS  123 1043
   Dataset Number: 5G0074v____ 0354
   Coding: 1303
   ROD: EV_SteerAssisMQB_010.rod
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 191
                    Mileage: 306607 km
                    Date: 2025.07.24
                    Time: 04:13:41
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 41.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Freeze frame conditions: 20
                    uioUdNotFilt_xdu16: 12.38 V
                    uAdSensI_SwitchedKl30_xdu16: 12.36 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
12288 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung]
                    Mileage: 306607 km
                    Date: 2025.08.17
                    Time: 15:40:51
                    Motor status: 01
                    Supply voltage: 5.50 V
                    Temperature: 34.0 °C
                    KFC: 30
                    KFA: 00 01
                    uioUdNotFilt_xdu16: 5.41 V
                    uAdSensI_SwitchedKl30_xdu16: 5.41 V
19716 - Databus
          [ESP_10 Botschaft - SNA-Check]
                    Reset counter: 220
                    Mileage: 312998 km
                    Date: 2025.11.21
                    Time: 13:05:44
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 14.00 V
                    Temperature: 11.0 °C
                    KFC: 4D
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 14.06 V
                    uAdSensI_SwitchedKl30_xdu16: 14.06 V
20740 - Databus
          [ESP_21 Botschaft - SNA-Check]
                    Reset counter: 220
                    Mileage: 312998 km
                    Date: 2025.11.21
                    Time: 13:05:44
                    Motor status: 02
                    KFC: 51
                    KFA: 00 04
                    uioUdNotFilt_xdu16: 14.03 V
                    uAdSensI_SwitchedKl30_xdu16: 14.03 V
   Serial number: 29071401102595 Dataset Number: 5G0157v____ 0055
   Coding: 00311020DE00040000801000
   VCID: BFD39C9357FB2F1252B-80EA
   Serial number: 00000000000003455696
   Coding: 190000
          B1487 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 48
                    Mileage: 326056 km
                    Date: 2026.10.16
                    Time: 14:31:35
                    Reset counter: 10
                    Mileage: 316039 km
                    Date: 2026.03.24
                    Time: 12:10:49
589855 - Window regulator motor; front passenger side
          B1322 02 [00001000] - Signal Failure
                    Mileage: 306607 km
                    Date: 2025.08.14
                    Time: 13:45:15
   Revision: --------    Serial number: -------------- Dataset Number: 5G0036v____ 0021
   Coding: 02AA00104F010200
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   Subsystem 1 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
   Coding: 900000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 043 K    HW: 5G0 035 043 D
   Component: MU-H-N-EU     H43 0362
   Serial number: A309H0EB009064 Dataset Number: 5G0CV1v____ 0001
   Coding: 02730001FF00000011110001000800031F0100C401000100D7
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: A61D29F7A8619EDA31D-80F2
   Component: ABT_High  H60 0030
   Serial number: VWZ8Z9PS1005EB
   Subsystem 2 - Part No SW: V03 959 801 FF    HW: -----------
   Component: ECE 2018  --- 0166
   Compact disc data bank:
   Component: Gracenote  --- 1010
1537 - Supply voltage
          [Supply voltage - lower limit value not reached]
                    Reset counter: 50
                    Mileage: 306607 km
                    Date: 2025.08.14
                    Time: 13:00:53
                    Voltage terminal 30: 8.6 V
2571 - Navigation System
          B126C F2 [00001000] - Navigation Database not Enabled
                    Reset counter: 50
                    Mileage: 296612 km
                    Date: 2025.05.01
                    Time: 09:46:49
                    Voltage terminal 30: 13.0 V
1562 - Microphone 1
          B129B 11 [00001000] - Short to Ground
                    Reset counter: 50
                    Mileage: 295005 km
                    Date: 2025.04.19
                    Time: 04:57:13
                    Voltage terminal 30: 14.1 V
1564 - Microphone 1
          B129B 13 [00001000] - Open Circuit
                    Reset counter: 50
                    Mileage: 293361 km
                    Date: 2025.03.28
                    Time: 22:53:53
                    Voltage terminal 30: 14.3 V
6697 - Databus
          [Airbag: no communication]
                    Reset counter: 50
                    Mileage: 273744 km
                    Date: 2023.11.14
                    Time: 14:13:00
                    Voltage terminal 30: 13.3 V
                    Network diagnosis-Status: Enabled
6922 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 50
                    Mileage: 298111 km
                    Date: 2025.05.13
                    Time: 19:55:31
                    Voltage terminal 30: 12.2 V
   Part No SW: 5Q0 907 383 F    HW: 5Q0 907 383 C
   Component: Anhaenger     H14 0137
   Revision: 8B001001    Serial number: 0342896631 Dataset Number: 0G0124v____ 0014
   Coding: 0100000202000000
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 00000208761    Dataset Number: 5G0HL1V____ 0046
   Coding: 0100020001020303000400000100000101
   ROD: EV_MFKBoschAU370.rod
   VCID: BB2BE88343E333327E3-80EE
End----------(Elapsed Time: 02:08, VBatt start/end: 14.2V/14.1V)-----------
------------------------------21 Faults Found------------------------------
Ad. map before:
;SW:5Q0-937-084-AJ   HW:5Q0-937-084-AJ ---  09: Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H   H18 0134, Coding:00130E46C24122FB0BA44080B11C07081800000000000000000000000000
;EV_BCMCONTI,013000,EV_BCMBOSCH_013.rod
;Saturday,17,October,2026,20:55:03:24894
;VCDS Version: 26.10.0.2 (x64)  Data version: 20260828 DS379.0
;VCID: 80515F6F6A8590EA6B1-80D4
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE01268-ENG115835-Front windshield wiper-Adaptives Nachwischen bei SRA,not active ,12
IDE01268-ENG116609-Front windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,12
IDE01268-ENG115836-Front windshield wiper-Frontwischer Notlaufprogramm,active ,12
IDE01268-ENG116614-Front windshield wiper-Frontwischer Referenzlauf,active ,12
IDE01268-ENG116617-Front windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
IDE01268-ENG116615-Front windshield wiper-Menuesteuerung Frontwischer,not active ,12
IDE01268-ENG115771-Front windshield wiper-Regensensor aktivieren,Deactivating ,12
IDE01268-ENG115769-Front windshield wiper-SRA bei Waschwassermangel,not active ,12
IDE01268-ENG115767-Front windshield wiper-SRA Einweichpausenzeit,2000 ms,12
IDE01268-ENG115768-Front windshield wiper-SRA Nachwaschzeit,320 ms,12
IDE01268-ENG116611-Front windshield wiper-SRA Pausenzeit,0 ms,12
IDE01268-ENG116610-Front windshield wiper-SRA Verzoegerungszeit,0 ms,12
IDE01268-ENG115766-Front windshield wiper-SRA Waschzeit,320 ms,12
IDE01268-ENG116616-Front windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
IDE01268-ENG116618-Front windshield wiper-Traenenwischen Front Status,not active ,12
IDE01268-ENG115770-Front windshield wiper-Variable Regensensoraktivierung,not active ,12
IDE01268-ENG126844-Front windshield wiper-Washer_Tipwiping_Variant,0 ,12
IDE01268-ENG116613-Front windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
IDE01268-ENG116612-Front windshield wiper-Wischer stop bei KL15 aus,not active ,12
IDE01268-ENG122185-Front windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,12
IDE01550-Service position,170.49 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,4
IDE02488-Anti-theft system interior monitoring,100 %,1
IDE02711-ENG116692-Rear wiper-Kein automatisches Abparken,not active ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
IDE03638-IDE04231-Static cornering light-Steering wheel angle: offset,-63.75 °,14
IDE03638-ENG116677-Static cornering light-Abdimmgeschwindigkeit,50.00 %/s,14
IDE03638-ENG116673-Static cornering light-bei Rueckwaertsfahrt,double sided ,14
IDE03638-ENG116675-Static cornering light-Lower speed threshold,0.00 km/h,14
IDE03638-ENG116682-Static cornering light-Maximaltemperatur,100.00 °C,14
IDE03638-ENG116679-Static cornering light-obere Grenztemperatur,95.00 °C,14
IDE03638-ENG116681-Static cornering light-Oberer Lenkradwinkel,120 °,14
IDE03638-ENG116680-Static cornering light-untere Grenztemperatur,80.00 °C,14
IDE03638-ENG116678-Static cornering light-Unterer Lenkradwinkel,180 °,14
IDE03638-ENG116676-Static cornering light-Upper speed threshold,40.00 km/h,14
IDE03638-ENG116674-Static cornering light-Vorschrift,ECE R119 ,14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10 ,8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %,8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,not active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,active ,14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beams ,8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,manually ,8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
IDE04927-ENG126845-Window heater-FSH Automatik,active ,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,not active ,4
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,4
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,driver door contact thatcham ,4
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,4
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,10 Alarme ,4
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,not active ,4
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,keine verzoegerung ,4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,not active ,8
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,8
IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,8
IDE05142-ENG115755-Access control-Notschließfunktion,active ,8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8
IDE05142-ENG115758-Access control-Valet Parking,not active ,8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,8
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00 ,560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00 ,560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38 ,560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42 ,560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48 ,560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,00 ,560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,00 ,560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,1A ,560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C ,560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A ,560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44 ,560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,35 ,560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,3F ,560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,minimize ,560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,minimize ,560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,minimize ,560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,minimize ,560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100 ,560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100 ,560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0 ,560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0 ,560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,100 ,560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,100 ,560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,100 ,560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,100 ,560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,100 ,560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127 ,560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,10 ,560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,86 ,560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,86 ,560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,100 ,560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,0 ,560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127 ,560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127 ,560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,127 ,560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,127 ,560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,80 ,560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,80 ,560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,26 ,560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,10 ,560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,10 ,560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,10 ,560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,10 ,560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,26 ,560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,127 ,560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,127 ,560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,0 ,560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,0 ,560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00 ,560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00 ,560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22 ,560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23 ,560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,41 ,560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,42 ,560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A ,560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,00 ,560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,00 ,560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,2A ,560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C ,560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00 ,560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49 ,560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,26 ,560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,27 ,560
IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten ,560
IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten ,560
IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,560
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
IDE05145-ENG116176-Light configuration-Lasttyp 16,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116195-Light configuration-Lasttyp 17,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,560
IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,560
IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,560
IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten ,560
IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten ,560
IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
IDE05145-ENG116309-Light configuration-Lasttyp 23,34 - LED Bremsleuchten ,560
IDE05145-ENG116328-Light configuration-Lasttyp 24,34 - LED Bremsleuchten ,560
IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
IDE05145-ENG116366-Light configuration-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG116385-Light configuration-Lasttyp 27,32 - allgemeine LED bis 12W ,560
IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,560
IDE05145-ENG116442-Light configuration-Lasttyp 30,not active ,560
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115986-Light configuration-Lasttyp 6,3 - Xenon Abblendlicht ,560
IDE05145-ENG116005-Light configuration-Lasttyp 7,3 - Xenon Abblendlicht ,560
IDE05145-ENG116024-Light configuration-Lasttyp 8,36 - LED Kleinleistung ,560
IDE05145-ENG116043-Light configuration-Lasttyp 9,36 - LED Kleinleistung ,560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,only_if_closed ,560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,only_if_closed ,560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,only_if_closed ,560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,only_if_closed ,560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,only_if_closed ,560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0 ,560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0 ,560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0 ,560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18 ,560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19 ,560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,2 ,560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,4 ,560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,20 ,560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,24 ,560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,24 ,560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,27 ,560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,8 ,560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,20 ,560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,0 ,560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,8 ,560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,8 ,560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0 ,560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0 ,560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0 ,560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0 ,560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,0 ,560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,0 ,560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0 ,560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15 ,560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15 ,560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,9 ,560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,10 ,560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,20 ,560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,20 ,560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,8 ,560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,8 ,560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,8 ,560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,8 ,560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,8 ,560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,8 ,560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,8 ,560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,8 ,560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,8 ,560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,8 ,560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,9 ,560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,9 ,560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,10 ,560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,10 ,560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,9 ,560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,10 ,560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,3 ,560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,5 ,560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,6 ,560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,7 ,560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,0 ,560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,0 ,560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0 ,560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0 ,560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
IDE05822-Anti-theft alarm system vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 03 32 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 03 22 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 24 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 10 22 29 67 ,172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C,24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C,24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,24
IDE06096-ENG116596-Interior lights-Innenlicht bei offenem Heckdeckel einschalten,active ,8
IDE06096-ENG116597-Interior lights-KL30G ohne PWM,not active ,8
IDE06096-ENG116598-Interior lights-KL58 Einschalten mit Rampe,not active ,8
IDE06096-ENG116599-Interior lights-KL58 Verriegelungsausschalten,not active ,8
IDE06096-ENG116600-Interior lights-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
IDE06096-ENG115631-Interior lights-Suchbeleuchtung Festwert,100 %,8
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
IDE07356-Position during interval mode,31.49 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
IDE08542-IDE02022-Access control 2-Comfort opening,not active ,8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,8
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,8
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active ,8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not active ,8
IDE08542-ENG154261-Access control 2-Reserved_4,not active ,8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,active ,8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,active ,8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active ,8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,8
IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,8
IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,8
IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,8
IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,8
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,8
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,8
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,8
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,8
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,8
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,8
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,8
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,8
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,8
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,8
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,8
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,8
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,8
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,8
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,8
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,8
IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,8
IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,present ,8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE09377-IDE00761-Multi-contour seat driver's side-Run-on time,No Response From Subnet Component,4
IDE09377-IDE03006-Multi-contour seat driver's side-Running time of massage function,No Response From Subnet Component,4
IDE09377-IDE03007-Multi-contour seat driver's side-Component location,No Response From Subnet Component,4
IDE09377-IDE03099-Multi-contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,4
IDE09377-IDE03100-Multi-contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,4
IDE09378-IDE00761-Multi-contour seat passenger side-Run-on time,No Response From Subnet Component,4
IDE09378-IDE03006-Multi-contour seat passenger side-Running time of massage function,No Response From Subnet Component,4
IDE09378-IDE03007-Multi-contour seat passenger side-Component location,No Response From Subnet Component,4
IDE09378-IDE03099-Multi-contour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,4
IDE09378-IDE03100-Multi-contour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,4
IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,4
IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,4
IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,not installed ,2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
IDE09733-ENG147405-LED bar setting values-Lockout time,0 s,10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE10298-Alternating park position 1,7.49 °,2
IDE10299-Alternating park position 2,29.49 °,2
IDE10308-Garage door opener: support door name,No Response From Subnet Component,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,2
MAS05055-lower turn position,31.49 °,2
MAS05056-upper turn position,170.49 °,2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active ,8
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung,No Response From Subnet Component,60
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht,No Response From Subnet Component,60
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1,No Response From Subnet Component,60
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1,No Response From Subnet Component,60
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2,No Response From Subnet Component,60
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2,No Response From Subnet Component,60
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung,No Response From Subnet Component,60
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten,No Response From Subnet Component,60
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3,No Response From Subnet Component,60
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne,No Response From Subnet Component,60
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung,No Response From Subnet Component,60
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0,No Response From Subnet Component,60
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1,No Response From Subnet Component,60
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10,No Response From Subnet Component,60
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2,No Response From Subnet Component,60
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3,No Response From Subnet Component,60
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4,No Response From Subnet Component,60
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5,No Response From Subnet Component,60
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6,No Response From Subnet Component,60
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7,No Response From Subnet Component,60
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8,No Response From Subnet Component,60
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9,No Response From Subnet Component,60
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0,No Response From Subnet Component,60
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1,No Response From Subnet Component,60
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10,No Response From Subnet Component,60
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2,No Response From Subnet Component,60
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3,No Response From Subnet Component,60
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4,No Response From Subnet Component,60
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5,No Response From Subnet Component,60
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6,No Response From Subnet Component,60
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7,No Response From Subnet Component,60
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8,No Response From Subnet Component,60
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9,No Response From Subnet Component,60
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,No Response From Subnet Component,60
ENG125611-ENG125702-Blower_1_Backrest_Left-Read_Coding_Pin,No Response From Subnet Component,60
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,No Response From Subnet Component,60
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,No Response From Subnet Component,60
ENG125612-ENG125702-Blower_1_Backrest_Right-Read_Coding_Pin,No Response From Subnet Component,60
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,No Response From Subnet Component,60
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,No Response From Subnet Component,60
ENG125609-ENG125702-Blower_1_Cushion_Left-Read_Coding_Pin,No Response From Subnet Component,60
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,No Response From Subnet Component,60
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,No Response From Subnet Component,60
ENG125610-ENG125702-Blower_1_Cushion_Right-Read_Coding_Pin,No Response From Subnet Component,60
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,No Response From Subnet Component,60
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,11
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,11
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,11
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,11
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,11
ENG125594-ENG125682-Driver_failure_detection_multi-contour_seat-s_GrobleckerkennungDauer,No Response From Subnet Component,11
ENG125594-ENG125680-Driver_failure_detection_multi-contour_seat-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,11
ENG125594-ENG125681-Driver_failure_detection_multi-contour_seat-s_Leckageerkennung,No Response From Subnet Component,11
ENG125594-ENG125678-Driver_failure_detection_multi-contour_seat-s_UeberspannungsSschwelle,No Response From Subnet Component,11
ENG125594-ENG125679-Driver_failure_detection_multi-contour_seat-s_UnterspannungsSchwelle,No Response From Subnet Component,11
ENG125588-ENG125667-Driver_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125666-Driver_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125668-Driver_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125673-Driver_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125672-Driver_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125674-Driver_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125670-Driver_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125669-Driver_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125671-Driver_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125676-Driver_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125675-Driver_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125677-Driver_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125664-Driver_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125663-Driver_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125665-Driver_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125667-Driver_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125666-Driver_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125668-Driver_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125673-Driver_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125672-Driver_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125674-Driver_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125670-Driver_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125669-Driver_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125671-Driver_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125676-Driver_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125675-Driver_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125677-Driver_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125664-Driver_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125663-Driver_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125665-Driver_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125667-Driver_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125666-Driver_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125668-Driver_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125673-Driver_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125672-Driver_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125674-Driver_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125670-Driver_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125669-Driver_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125671-Driver_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125676-Driver_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125675-Driver_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125677-Driver_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125664-Driver_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125663-Driver_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125665-Driver_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125667-Driver_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125666-Driver_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125668-Driver_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125673-Driver_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125672-Driver_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125674-Driver_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125670-Driver_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125669-Driver_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125671-Driver_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125676-Driver_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125675-Driver_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125677-Driver_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125664-Driver_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125663-Driver_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125665-Driver_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125667-Driver_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125666-Driver_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125668-Driver_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125673-Driver_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125672-Driver_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125674-Driver_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125670-Driver_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125669-Driver_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125671-Driver_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125676-Driver_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125675-Driver_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125677-Driver_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125664-Driver_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125663-Driver_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125665-Driver_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125667-Driver_massage_program_2_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125666-Driver_massage_program_2_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125668-Driver_massage_program_2_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125673-Driver_massage_program_2_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125672-Driver_massage_program_2_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125674-Driver_massage_program_2_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125670-Driver_massage_program_2_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125669-Driver_massage_program_2_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125671-Driver_massage_program_2_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125676-Driver_massage_program_2_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125675-Driver_massage_program_2_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125677-Driver_massage_program_2_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125664-Driver_massage_program_2_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125663-Driver_massage_program_2_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125665-Driver_massage_program_2_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125596-ENG125687-Driver_pressure_correction_multi-contour_seat-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,11
ENG125596-ENG125689-Driver_pressure_correction_multi-contour_seat-s_AussendruckschwelleNachregelung,No Response From Subnet Component,11
ENG125596-ENG125685-Driver_pressure_correction_multi-contour_seat-s_BasismessintervallNachregelung,No Response From Subnet Component,11
ENG125596-ENG125688-Driver_pressure_correction_multi-contour_seat-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,11
ENG125596-ENG125686-Driver_pressure_correction_multi-contour_seat-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,11
ENG125595-ENG125684-Driver_pressure_values_multi-contour_seat_driver-s_DruckschwelleNachlauf,No Response From Subnet Component,11
ENG125595-ENG126855-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_m,No Response From Subnet Component,11
ENG125595-ENG126854-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_o,No Response From Subnet Component,11
ENG125595-ENG126856-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_u,No Response From Subnet Component,11
ENG125595-ENG126857-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,11
ENG125595-ENG126863-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,11
ENG125595-ENG126862-Driver_pressure_values_multi-contour_seat_driver-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,No Response From Subnet Component,11
ENG125595-ENG126859-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_m,No Response From Subnet Component,11
ENG125595-ENG126858-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_o,No Response From Subnet Component,11
ENG125595-ENG126860-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_u,No Response From Subnet Component,11
ENG125595-ENG126864-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_Massage,No Response From Subnet Component,11
ENG125595-ENG126861-Driver_pressure_values_multi-contour_seat_driver-s_MinimaldruckSitzlehnenwangen,No Response From Subnet Component,11
ENG125595-ENG125683-Driver_pressure_values_multi-contour_seat_driver-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,11
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
ENG126651-ENG115658-Kennlinie Abdimmen-x0,No Response From Subnet Component,10
ENG126651-ENG101574-Kennlinie Abdimmen-X1,No Response From Subnet Component,10
ENG126651-ENG115664-Kennlinie Abdimmen-x10,No Response From Subnet Component,10
ENG126651-ENG99557-Kennlinie Abdimmen-X2,No Response From Subnet Component,10
ENG126651-ENG102140-Kennlinie Abdimmen-X3,No Response From Subnet Component,10
ENG126651-ENG102936-Kennlinie Abdimmen-X4,No Response From Subnet Component,10
ENG126651-ENG103548-Kennlinie Abdimmen-X5,No Response From Subnet Component,10
ENG126651-ENG113992-Kennlinie Abdimmen-X6,No Response From Subnet Component,10
ENG126651-ENG115661-Kennlinie Abdimmen-x7,No Response From Subnet Component,10
ENG126651-ENG115662-Kennlinie Abdimmen-x8,No Response From Subnet Component,10
ENG126651-ENG115663-Kennlinie Abdimmen-x9,No Response From Subnet Component,10
ENG126651-ENG115659-Kennlinie Abdimmen-y0,No Response From Subnet Component,10
ENG126651-ENG99777-Kennlinie Abdimmen-Y1,No Response From Subnet Component,10
ENG126651-ENG115668-Kennlinie Abdimmen-y10,No Response From Subnet Component,10
ENG126651-ENG100480-Kennlinie Abdimmen-Y2,No Response From Subnet Component,10
ENG126651-ENG100773-Kennlinie Abdimmen-Y3,No Response From Subnet Component,10
ENG126651-ENG100631-Kennlinie Abdimmen-Y4,No Response From Subnet Component,10
ENG126651-ENG102174-Kennlinie Abdimmen-Y5,No Response From Subnet Component,10
ENG126651-ENG113993-Kennlinie Abdimmen-Y6,No Response From Subnet Component,10
ENG126651-ENG115665-Kennlinie Abdimmen-y7,No Response From Subnet Component,10
ENG126651-ENG115666-Kennlinie Abdimmen-y8,No Response From Subnet Component,10
ENG126651-ENG115667-Kennlinie Abdimmen-y9,No Response From Subnet Component,10
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,minimize ,16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,80 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Daytime running lights ,16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,Blinken links Dunkelphase ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,41 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Blinken links Hellphase ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,42 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,only_if_closed ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Blinken rechts Hellphase ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,minimize ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,80 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,Daytime running lights ,16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,Blinken rechts Dunkelphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,10 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,10 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,minimize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,10 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,00 ,16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,00 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,34 - LED Bremsleuchten ,16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Brake lamp ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,Blinken links aktiv (beide Phasen) ,16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,minimize ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,10 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,00 ,16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,00 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,34 - LED Bremsleuchten ,16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Brake lamp ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Parking light right ,16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,Blinken rechts aktiv (beide Phasen) ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,10 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2A ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,86 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,86 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,26 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,26 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Parking light right ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,Parking light right ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,26 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,35 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,36 - LED Kleinleistung ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,27 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3F ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,36 - LED Kleinleistung ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Parking light right ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
ENG126648-ENG148864-LIN-Mirrormode-level,0 ,1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
ENG99457-ENG117394-Neck heating-blower_speed,1 ,2
ENG99457-ENG98971-Neck heating-Temperature,-2 ,2
ENG125607-ENG126865-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,2
ENG125607-ENG126867-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,2
ENG125607-ENG126866-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,2
ENG125607-ENG126868-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,2
ENG125607-ENG125690-Passenger_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,2
ENG125604-ENG125693-Passenger_failure_detection_multi-contour_seat-s_DauerFuerGrobleckerkennung,No Response From Subnet Component,2
ENG125604-ENG125680-Passenger_failure_detection_multi-contour_seat-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,2
ENG125604-ENG125681-Passenger_failure_detection_multi-contour_seat-s_Leckageerkennung,No Response From Subnet Component,2
ENG125604-ENG125678-Passenger_failure_detection_multi-contour_seat-s_UeberspannungsSschwelle,No Response From Subnet Component,2
ENG125604-ENG125679-Passenger_failure_detection_multi-contour_seat-s_UnterspannungsSchwelle,No Response From Subnet Component,2
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I,No Response From Subnet Component,2
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I,No Response From Subnet Component,2
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125667-Passenger_massage_program_2_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125666-Passenger_massage_program_2_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125668-Passenger_massage_program_2_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125673-Passenger_massage_program_2_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125672-Passenger_massage_program_2_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125674-Passenger_massage_program_2_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125670-Passenger_massage_program_2_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125669-Passenger_massage_program_2_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125671-Passenger_massage_program_2_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125676-Passenger_massage_program_2_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125675-Passenger_massage_program_2_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125677-Passenger_massage_program_2_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125664-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125663-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125665-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125606-ENG125687-Passenger_pressure_correction_multi-contour_seat-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,2
ENG125606-ENG125689-Passenger_pressure_correction_multi-contour_seat-s_AussendruckschwelleNachregelung,No Response From Subnet Component,2
ENG125606-ENG125685-Passenger_pressure_correction_multi-contour_seat-s_BasismessintervallNachregelung,No Response From Subnet Component,2
ENG125606-ENG125688-Passenger_pressure_correction_multi-contour_seat-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,2
ENG125606-ENG125686-Passenger_pressure_correction_multi-contour_seat-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,2
ENG125605-ENG126871-Passenger_pressure_values_multi-contour_seat-s_Druckschwelle_Nachlauf,No Response From Subnet Component,2
ENG125605-ENG126855-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_m,No Response From Subnet Component,2
ENG125605-ENG126854-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_o,No Response From Subnet Component,2
ENG125605-ENG126856-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_u,No Response From Subnet Component,2
ENG125605-ENG126857-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,2
ENG125605-ENG126863-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,2
ENG125605-ENG126870-Passenger_pressure_values_multi-contour_seat-s_Maximaler_Differenzdruck_LRD_VorZurueck,No Response From Subnet Component,2
ENG125605-ENG126859-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_m,No Response From Subnet Component,2
ENG125605-ENG126858-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_o,No Response From Subnet Component,2
ENG125605-ENG126860-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_u,No Response From Subnet Component,2
ENG125605-ENG126864-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_Massage,No Response From Subnet Component,2
ENG125605-ENG126869-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_Sitzlehnenwangen,No Response From Subnet Component,2
ENG125605-ENG125683-Passenger_pressure_values_multi-contour_seat-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,2
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,2 ,8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer,10 min,8
ENG125614-Reset_Blower_1_Backrest_Left,No Response From Subnet Component,8
ENG125615-Reset_Blower_1_Backrest_Right,No Response From Subnet Component,8
ENG125613-Reset_Blower_1_Cushion_Left,No Response From Subnet Component,8
ENG125616-Reset_Blower_1_Cushion_Right,No Response From Subnet Component,8
Elapsed Time: 01:38
TTT
C?ID=547002
Same drl might be applied with functions b,f,g,h.
Why is function d set to parking light? That still burns the socket out??
Boki Ar
Arandjelovac, Serbia
C?ID=57300
I didn't go into further consideration, there wasn't enough time.
If you can, give me some advice, is it at the same addresses (ENG116936-ENG115880 & ENG116937-ENG115899). :cool:
TTT
C?ID=547002
Look at function D, why is this set to Standlicht instead of not active? As of now, when parking lights are on, are the turn signals also on?
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Daytime running lights ,16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,Blinken links Dunkelphase ,16
Boki Ar
C?ID=57300
TNX! :thumbs:
I reduced the values to 30. The owner is very happy with it and loves the US-style look.
Here is the adaptation map after the intervention:
;SW:5Q0-937-084-AJ   HW:5Q0-937-084-AJ ---  09: Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H   H18 0134, Coding:00130E46C24122FB0BA44080B11C07081800000000000000000000000000
;EV_BCMCONTI,013000,EV_BCMBOSCH_013.rod
;Sunday,18,October,2026,13:00:59:24894
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 80515F6F6A8590EA670-80D4
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE01268-ENG115835-Front windshield wiper-Adaptives Nachwischen bei SRA,not active ,12
IDE01268-ENG116609-Front windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,12
IDE01268-ENG115836-Front windshield wiper-Frontwischer Notlaufprogramm,active ,12
IDE01268-ENG116614-Front windshield wiper-Frontwischer Referenzlauf,active ,12
IDE01268-ENG116617-Front windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
IDE01268-ENG116615-Front windshield wiper-Menuesteuerung Frontwischer,not active ,12
IDE01268-ENG115771-Front windshield wiper-Regensensor aktivieren,Deactivating ,12
IDE01268-ENG115769-Front windshield wiper-SRA bei Waschwassermangel,not active ,12
IDE01268-ENG115767-Front windshield wiper-SRA Einweichpausenzeit,2000 ms,12
IDE01268-ENG115768-Front windshield wiper-SRA Nachwaschzeit,320 ms,12
IDE01268-ENG116611-Front windshield wiper-SRA Pausenzeit,0 ms,12
IDE01268-ENG116610-Front windshield wiper-SRA Verzoegerungszeit,0 ms,12
IDE01268-ENG115766-Front windshield wiper-SRA Waschzeit,320 ms,12
IDE01268-ENG116616-Front windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
IDE01268-ENG116618-Front windshield wiper-Traenenwischen Front Status,not active ,12
IDE01268-ENG115770-Front windshield wiper-Variable Regensensoraktivierung,not active ,12
IDE01268-ENG126844-Front windshield wiper-Washer_Tipwiping_Variant,0 ,12
IDE01268-ENG116613-Front windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
IDE01268-ENG116612-Front windshield wiper-Wischer stop bei KL15 aus,not active ,12
IDE01268-ENG122185-Front windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,12
IDE01550-Service position,170.49 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,4
IDE02488-Anti-theft system interior monitoring,100 %,1
IDE02711-ENG116692-Rear wiper-Kein automatisches Abparken,not active ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
IDE03638-IDE04231-Static cornering light-Steering wheel angle: offset,-63.75 °,14
IDE03638-ENG116677-Static cornering light-Abdimmgeschwindigkeit,50.00 %/s,14
IDE03638-ENG116673-Static cornering light-bei Rueckwaertsfahrt,double sided ,14
IDE03638-ENG116675-Static cornering light-Lower speed threshold,0.00 km/h,14
IDE03638-ENG116682-Static cornering light-Maximaltemperatur,100.00 °C,14
IDE03638-ENG116679-Static cornering light-obere Grenztemperatur,95.00 °C,14
IDE03638-ENG116681-Static cornering light-Oberer Lenkradwinkel,120 °,14
IDE03638-ENG116680-Static cornering light-untere Grenztemperatur,80.00 °C,14
IDE03638-ENG116678-Static cornering light-Unterer Lenkradwinkel,180 °,14
IDE03638-ENG116676-Static cornering light-Upper speed threshold,40.00 km/h,14
IDE03638-ENG116674-Static cornering light-Vorschrift,ECE R119 ,14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10 ,8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %,8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,not active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,active ,14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beams ,8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,manually ,8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
IDE04927-ENG126845-Window heater-FSH Automatik,active ,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,not active ,4
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,4
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,driver door contact thatcham ,4
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,4
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,10 Alarme ,4
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,not active ,4
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,keine verzoegerung ,4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,not active ,8
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active ,8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,8
IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,8
IDE05142-ENG115755-Access control-Notschließfunktion,active ,8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8
IDE05142-ENG115758-Access control-Valet Parking,not active ,8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,8
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00 ,560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00 ,560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38 ,560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42 ,560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,00 ,560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,00 ,560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48 ,560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,00 ,560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,00 ,560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,1A ,560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C ,560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A ,560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44 ,560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,35 ,560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,3F ,560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,minimize ,560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,minimize ,560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,minimize ,560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,minimize ,560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100 ,560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100 ,560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0 ,560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0 ,560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,100 ,560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,100 ,560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,100 ,560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,100 ,560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,100 ,560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127 ,560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,10 ,560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,86 ,560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,86 ,560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,100 ,560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,0 ,560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127 ,560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127 ,560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,127 ,560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,127 ,560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,30 ,560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,30 ,560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,26 ,560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,10 ,560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,10 ,560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,10 ,560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,10 ,560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,26 ,560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,127 ,560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,127 ,560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,0 ,560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,0 ,560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00 ,560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00 ,560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22 ,560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23 ,560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,41 ,560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,42 ,560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A ,560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,00 ,560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,00 ,560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,2A ,560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C ,560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00 ,560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49 ,560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,26 ,560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,27 ,560
IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten ,560
IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten ,560
IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,560
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
IDE05145-ENG116176-Light configuration-Lasttyp 16,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116195-Light configuration-Lasttyp 17,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,560
IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,560
IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,560
IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten ,560
IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten ,560
IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
IDE05145-ENG116309-Light configuration-Lasttyp 23,34 - LED Bremsleuchten ,560
IDE05145-ENG116328-Light configuration-Lasttyp 24,34 - LED Bremsleuchten ,560
IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
IDE05145-ENG116366-Light configuration-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG116385-Light configuration-Lasttyp 27,32 - allgemeine LED bis 12W ,560
IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,560
IDE05145-ENG116442-Light configuration-Lasttyp 30,not active ,560
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115986-Light configuration-Lasttyp 6,3 - Xenon Abblendlicht ,560
IDE05145-ENG116005-Light configuration-Lasttyp 7,3 - Xenon Abblendlicht ,560
IDE05145-ENG116024-Light configuration-Lasttyp 8,36 - LED Kleinleistung ,560
IDE05145-ENG116043-Light configuration-Lasttyp 9,36 - LED Kleinleistung ,560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,only_if_closed ,560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,only_if_closed ,560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,only_if_closed ,560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,only_if_closed ,560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,only_if_closed ,560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0 ,560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0 ,560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0 ,560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18 ,560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19 ,560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,2 ,560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,4 ,560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,20 ,560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,24 ,560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,24 ,560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,27 ,560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,8 ,560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,20 ,560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,0 ,560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,8 ,560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,8 ,560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0 ,560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0 ,560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0 ,560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0 ,560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,0 ,560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,0 ,560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0 ,560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15 ,560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15 ,560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,9 ,560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,10 ,560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,8 ,560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,8 ,560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,8 ,560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,8 ,560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,8 ,560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,8 ,560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,8 ,560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,8 ,560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,8 ,560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,8 ,560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,9 ,560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,9 ,560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,10 ,560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,9 ,560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,10 ,560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,10 ,560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,9 ,560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,10 ,560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,3 ,560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,5 ,560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,6 ,560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,7 ,560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,0 ,560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,0 ,560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0 ,560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0 ,560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
IDE05822-Anti-theft alarm system vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 03 32 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 03 22 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 24 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 10 22 29 67 ,172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C,24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C,24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,24
IDE06096-ENG116596-Interior lights-Innenlicht bei offenem Heckdeckel einschalten,active ,8
IDE06096-ENG116597-Interior lights-KL30G ohne PWM,not active ,8
IDE06096-ENG116598-Interior lights-KL58 Einschalten mit Rampe,not active ,8
IDE06096-ENG116599-Interior lights-KL58 Verriegelungsausschalten,not active ,8
IDE06096-ENG116600-Interior lights-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
IDE06096-ENG115631-Interior lights-Suchbeleuchtung Festwert,100 %,8
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
IDE07356-Position during interval mode,31.49 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
IDE08542-IDE02022-Access control 2-Comfort opening,not active ,8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,8
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,8
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once ,8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active ,8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not active ,8
IDE08542-ENG154261-Access control 2-Reserved_4,not active ,8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,active ,8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,active ,8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active ,8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,8
IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,8
IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,8
IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,8
IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,8
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,8
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,8
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,8
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,8
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,8
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,8
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,8
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,8
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,8
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,8
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,8
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,8
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,8
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,8
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,8
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,8
IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,8
IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,present ,8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE09377-IDE00761-Multi-contour seat driver's side-Run-on time,No Response From Subnet Component,4
IDE09377-IDE03006-Multi-contour seat driver's side-Running time of massage function,No Response From Subnet Component,4
IDE09377-IDE03007-Multi-contour seat driver's side-Component location,No Response From Subnet Component,4
IDE09377-IDE03099-Multi-contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,4
IDE09377-IDE03100-Multi-contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,4
IDE09378-IDE00761-Multi-contour seat passenger side-Run-on time,No Response From Subnet Component,4
IDE09378-IDE03006-Multi-contour seat passenger side-Running time of massage function,No Response From Subnet Component,4
IDE09378-IDE03007-Multi-contour seat passenger side-Component location,No Response From Subnet Component,4
IDE09378-IDE03099-Multi-contour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,4
IDE09378-IDE03100-Multi-contour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,4
IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,4
IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,4
IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,2
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,not installed ,2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
IDE09733-ENG147405-LED bar setting values-Lockout time,0 s,10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE10298-Alternating park position 1,7.49 °,2
IDE10299-Alternating park position 2,29.49 °,2
IDE10308-Garage door opener: support door name,No Response From Subnet Component,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,2
MAS05055-lower turn position,31.49 °,2
MAS05056-upper turn position,170.49 °,2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active ,8
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung,No Response From Subnet Component,60
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht,No Response From Subnet Component,60
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1,No Response From Subnet Component,60
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1,No Response From Subnet Component,60
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2,No Response From Subnet Component,60
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2,No Response From Subnet Component,60
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung,No Response From Subnet Component,60
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten,No Response From Subnet Component,60
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3,No Response From Subnet Component,60
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne,No Response From Subnet Component,60
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung,No Response From Subnet Component,60
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0,No Response From Subnet Component,60
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1,No Response From Subnet Component,60
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10,No Response From Subnet Component,60
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2,No Response From Subnet Component,60
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3,No Response From Subnet Component,60
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4,No Response From Subnet Component,60
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5,No Response From Subnet Component,60
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6,No Response From Subnet Component,60
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7,No Response From Subnet Component,60
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8,No Response From Subnet Component,60
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9,No Response From Subnet Component,60
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0,No Response From Subnet Component,60
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1,No Response From Subnet Component,60
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10,No Response From Subnet Component,60
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2,No Response From Subnet Component,60
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3,No Response From Subnet Component,60
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4,No Response From Subnet Component,60
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5,No Response From Subnet Component,60
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6,No Response From Subnet Component,60
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7,No Response From Subnet Component,60
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8,No Response From Subnet Component,60
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9,No Response From Subnet Component,60
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,No Response From Subnet Component,60
ENG125611-ENG125702-Blower_1_Backrest_Left-Read_Coding_Pin,No Response From Subnet Component,60
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,No Response From Subnet Component,60
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,No Response From Subnet Component,60
ENG125612-ENG125702-Blower_1_Backrest_Right-Read_Coding_Pin,No Response From Subnet Component,60
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,No Response From Subnet Component,60
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,No Response From Subnet Component,60
ENG125609-ENG125702-Blower_1_Cushion_Left-Read_Coding_Pin,No Response From Subnet Component,60
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,No Response From Subnet Component,60
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,60
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,No Response From Subnet Component,60
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,60
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,60
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,60
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,No Response From Subnet Component,60
ENG125610-ENG125702-Blower_1_Cushion_Right-Read_Coding_Pin,No Response From Subnet Component,60
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,No Response From Subnet Component,60
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,11
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,11
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,11
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,11
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,11
ENG125594-ENG125682-Driver_failure_detection_multi-contour_seat-s_GrobleckerkennungDauer,No Response From Subnet Component,11
ENG125594-ENG125680-Driver_failure_detection_multi-contour_seat-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,11
ENG125594-ENG125681-Driver_failure_detection_multi-contour_seat-s_Leckageerkennung,No Response From Subnet Component,11
ENG125594-ENG125678-Driver_failure_detection_multi-contour_seat-s_UeberspannungsSschwelle,No Response From Subnet Component,11
ENG125594-ENG125679-Driver_failure_detection_multi-contour_seat-s_UnterspannungsSchwelle,No Response From Subnet Component,11
ENG125588-ENG125667-Driver_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125666-Driver_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125668-Driver_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125673-Driver_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125672-Driver_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125674-Driver_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125670-Driver_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125669-Driver_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125671-Driver_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125676-Driver_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125675-Driver_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125677-Driver_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125664-Driver_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125663-Driver_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125588-ENG125665-Driver_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125667-Driver_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125666-Driver_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125668-Driver_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125673-Driver_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125672-Driver_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125674-Driver_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125670-Driver_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125669-Driver_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125671-Driver_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125676-Driver_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125675-Driver_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125677-Driver_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125664-Driver_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125663-Driver_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125589-ENG125665-Driver_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125667-Driver_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125666-Driver_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125668-Driver_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125673-Driver_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125672-Driver_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125674-Driver_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125670-Driver_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125669-Driver_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125671-Driver_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125676-Driver_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125675-Driver_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125677-Driver_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125664-Driver_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125663-Driver_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125590-ENG125665-Driver_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125667-Driver_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125666-Driver_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125668-Driver_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125673-Driver_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125672-Driver_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125674-Driver_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125670-Driver_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125669-Driver_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125671-Driver_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125676-Driver_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125675-Driver_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125677-Driver_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125664-Driver_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125663-Driver_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125591-ENG125665-Driver_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125667-Driver_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125666-Driver_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125668-Driver_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125673-Driver_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125672-Driver_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125674-Driver_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125670-Driver_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125669-Driver_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125671-Driver_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125676-Driver_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125675-Driver_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125677-Driver_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125664-Driver_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125663-Driver_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125592-ENG125665-Driver_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125667-Driver_massage_program_2_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125666-Driver_massage_program_2_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125668-Driver_massage_program_2_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125673-Driver_massage_program_2_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125672-Driver_massage_program_2_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125674-Driver_massage_program_2_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125670-Driver_massage_program_2_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125669-Driver_massage_program_2_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125671-Driver_massage_program_2_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125676-Driver_massage_program_2_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125675-Driver_massage_program_2_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125677-Driver_massage_program_2_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125664-Driver_massage_program_2_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125663-Driver_massage_program_2_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,11
ENG125593-ENG125665-Driver_massage_program_2_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,11
ENG125596-ENG125687-Driver_pressure_correction_multi-contour_seat-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,11
ENG125596-ENG125689-Driver_pressure_correction_multi-contour_seat-s_AussendruckschwelleNachregelung,No Response From Subnet Component,11
ENG125596-ENG125685-Driver_pressure_correction_multi-contour_seat-s_BasismessintervallNachregelung,No Response From Subnet Component,11
ENG125596-ENG125688-Driver_pressure_correction_multi-contour_seat-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,11
ENG125596-ENG125686-Driver_pressure_correction_multi-contour_seat-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,11
ENG125595-ENG125684-Driver_pressure_values_multi-contour_seat_driver-s_DruckschwelleNachlauf,No Response From Subnet Component,11
ENG125595-ENG126855-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_m,No Response From Subnet Component,11
ENG125595-ENG126854-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_o,No Response From Subnet Component,11
ENG125595-ENG126856-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_u,No Response From Subnet Component,11
ENG125595-ENG126857-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,11
ENG125595-ENG126863-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,11
ENG125595-ENG126862-Driver_pressure_values_multi-contour_seat_driver-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,No Response From Subnet Component,11
ENG125595-ENG126859-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_m,No Response From Subnet Component,11
ENG125595-ENG126858-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_o,No Response From Subnet Component,11
ENG125595-ENG126860-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_u,No Response From Subnet Component,11
ENG125595-ENG126864-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_Massage,No Response From Subnet Component,11
ENG125595-ENG126861-Driver_pressure_values_multi-contour_seat_driver-s_MinimaldruckSitzlehnenwangen,No Response From Subnet Component,11
ENG125595-ENG125683-Driver_pressure_values_multi-contour_seat_driver-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,11
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
ENG126651-ENG115658-Kennlinie Abdimmen-x0,No Response From Subnet Component,10
ENG126651-ENG101574-Kennlinie Abdimmen-X1,No Response From Subnet Component,10
ENG126651-ENG115664-Kennlinie Abdimmen-x10,No Response From Subnet Component,10
ENG126651-ENG99557-Kennlinie Abdimmen-X2,No Response From Subnet Component,10
ENG126651-ENG102140-Kennlinie Abdimmen-X3,No Response From Subnet Component,10
ENG126651-ENG102936-Kennlinie Abdimmen-X4,No Response From Subnet Component,10
ENG126651-ENG103548-Kennlinie Abdimmen-X5,No Response From Subnet Component,10
ENG126651-ENG113992-Kennlinie Abdimmen-X6,No Response From Subnet Component,10
ENG126651-ENG115661-Kennlinie Abdimmen-x7,No Response From Subnet Component,10
ENG126651-ENG115662-Kennlinie Abdimmen-x8,No Response From Subnet Component,10
ENG126651-ENG115663-Kennlinie Abdimmen-x9,No Response From Subnet Component,10
ENG126651-ENG115659-Kennlinie Abdimmen-y0,No Response From Subnet Component,10
ENG126651-ENG99777-Kennlinie Abdimmen-Y1,No Response From Subnet Component,10
ENG126651-ENG115668-Kennlinie Abdimmen-y10,No Response From Subnet Component,10
ENG126651-ENG100480-Kennlinie Abdimmen-Y2,No Response From Subnet Component,10
ENG126651-ENG100773-Kennlinie Abdimmen-Y3,No Response From Subnet Component,10
ENG126651-ENG100631-Kennlinie Abdimmen-Y4,No Response From Subnet Component,10
ENG126651-ENG102174-Kennlinie Abdimmen-Y5,No Response From Subnet Component,10
ENG126651-ENG113993-Kennlinie Abdimmen-Y6,No Response From Subnet Component,10
ENG126651-ENG115665-Kennlinie Abdimmen-y7,No Response From Subnet Component,10
ENG126651-ENG115666-Kennlinie Abdimmen-y8,No Response From Subnet Component,10
ENG126651-ENG115667-Kennlinie Abdimmen-y9,No Response From Subnet Component,10
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,minimize ,16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,30 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,Blinken links Dunkelphase ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,41 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Blinken links Hellphase ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,42 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,only_if_closed ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Blinken rechts Hellphase ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,minimize ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,30 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,Blinken rechts Dunkelphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,10 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,10 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,Parking light right ,16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,minimize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,10 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,00 ,16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,00 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,34 - LED Bremsleuchten ,16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Brake lamp ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,Blinken links aktiv (beide Phasen) ,16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,minimize ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,10 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,00 ,16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,00 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,34 - LED Bremsleuchten ,16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Brake lamp ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Parking light right ,16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,Blinken rechts aktiv (beide Phasen) ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,10 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2A ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,86 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,86 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,26 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,26 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Parking light right ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,Parking light right ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,26 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,35 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,36 - LED Kleinleistung ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,27 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3F ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,36 - LED Kleinleistung ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Parking light right ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
ENG126648-ENG148864-LIN-Mirrormode-level,0 ,1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
ENG99457-ENG117394-Neck heating-blower_speed,1 ,2
ENG99457-ENG98971-Neck heating-Temperature,-2 ,2
ENG125607-ENG126865-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,2
ENG125607-ENG126867-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,2
ENG125607-ENG126866-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,2
ENG125607-ENG126868-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,2
ENG125607-ENG125690-Passenger_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,2
ENG125604-ENG125693-Passenger_failure_detection_multi-contour_seat-s_DauerFuerGrobleckerkennung,No Response From Subnet Component,2
ENG125604-ENG125680-Passenger_failure_detection_multi-contour_seat-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,2
ENG125604-ENG125681-Passenger_failure_detection_multi-contour_seat-s_Leckageerkennung,No Response From Subnet Component,2
ENG125604-ENG125678-Passenger_failure_detection_multi-contour_seat-s_UeberspannungsSschwelle,No Response From Subnet Component,2
ENG125604-ENG125679-Passenger_failure_detection_multi-contour_seat-s_UnterspannungsSchwelle,No Response From Subnet Component,2
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I,No Response From Subnet Component,2
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I,No Response From Subnet Component,2
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125667-Passenger_massage_program_2_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125666-Passenger_massage_program_2_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125668-Passenger_massage_program_2_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125673-Passenger_massage_program_2_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125672-Passenger_massage_program_2_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125674-Passenger_massage_program_2_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125670-Passenger_massage_program_2_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125669-Passenger_massage_program_2_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125671-Passenger_massage_program_2_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125676-Passenger_massage_program_2_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125675-Passenger_massage_program_2_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125677-Passenger_massage_program_2_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125664-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125663-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,2
ENG125603-ENG125665-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,2
ENG125606-ENG125687-Passenger_pressure_correction_multi-contour_seat-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,2
ENG125606-ENG125689-Passenger_pressure_correction_multi-contour_seat-s_AussendruckschwelleNachregelung,No Response From Subnet Component,2
ENG125606-ENG125685-Passenger_pressure_correction_multi-contour_seat-s_BasismessintervallNachregelung,No Response From Subnet Component,2
ENG125606-ENG125688-Passenger_pressure_correction_multi-contour_seat-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,2
ENG125606-ENG125686-Passenger_pressure_correction_multi-contour_seat-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,2
ENG125605-ENG126871-Passenger_pressure_values_multi-contour_seat-s_Druckschwelle_Nachlauf,No Response From Subnet Component,2
ENG125605-ENG126855-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_m,No Response From Subnet Component,2
ENG125605-ENG126854-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_o,No Response From Subnet Component,2
ENG125605-ENG126856-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_u,No Response From Subnet Component,2
ENG125605-ENG126857-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,2
ENG125605-ENG126863-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,2
ENG125605-ENG126870-Passenger_pressure_values_multi-contour_seat-s_Maximaler_Differenzdruck_LRD_VorZurueck,No Response From Subnet Component,2
ENG125605-ENG126859-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_m,No Response From Subnet Component,2
ENG125605-ENG126858-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_o,No Response From Subnet Component,2
ENG125605-ENG126860-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_u,No Response From Subnet Component,2
ENG125605-ENG126864-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_Massage,No Response From Subnet Component,2
ENG125605-ENG126869-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_Sitzlehnenwangen,No Response From Subnet Component,2
ENG125605-ENG125683-Passenger_pressure_values_multi-contour_seat-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,2
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,2 ,8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer,10 min,8
ENG125614-Reset_Blower_1_Backrest_Left,No Response From Subnet Component,8
ENG125615-Reset_Blower_1_Backrest_Right,No Response From Subnet Component,8
ENG125613-Reset_Blower_1_Cushion_Left,No Response From Subnet Component,8
ENG125616-Reset_Blower_1_Cushion_Right,No Response From Subnet Component,8
Elapsed Time: 01:45
