Hi
Polo power steering does not wake up every time.
But when i shake steering wheel (right-left-right fast) it start to work. Then it will work for some time.
But when i drive for couple seconds, power steering stop working.
This is not good for traffic safety. And steering is really hard when steering assist is not working.
I can see steering pump is running 1152 1/min at idle.
When assist is working it runs about 1800 1/min.
I have video what can show the problem, but i cant attach it here.
I have breaked down this power steerind pump assy, cleaned and put back. Does not help. Oil was really bad.
Electrical contacts in fine. Voltages stays more than 13 V at adress 44 even when assist is working.
1,4 B engine BBY. Manual.
- Any help?
- Coding now is 00140. What is correct coding?
- Another question: Can i put cruise control to this car?
there is 6Q1937049C what supports cruise control, but i found somewhere that cruise is not possible to cars under 60hp. I have 55hp.
- Any help?
VCDS-Lite Version: Release 1.2
Tuesday, 24 January 2023, 23:12:13:30869
Chassis Type: 9N - VW Polo
Scan: 01,02,03,08,09,15,17,19,25,37,44,45,46,56,76
Address 01: Engine Labels:
Controller: 0 ö0 öp ö
VCID: E2B7D11E7D57
Note: Can't Synch Baud Rate
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.LBL
Controller: 6Q0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001097
Shop #: WSC 00788
VCID: 46FFAD8E71BF
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.LBL
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 25788
Shop #: WSC 12400
VCID: 3B09CC7A3A7D
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 1C0 909 605 K
Component: 0K AIRBAG VW51 0N 0006
Coding: 12363
Shop #: WSC 00788
VCID: 2C2BFF26CF13
Address 17: Instruments Labels: 6Q0-920-xxx-17.LBL
Controller: 6Q0 920 800 F
Component: KOMBI+WEGFAHRSP VDO V14
Coding: 01141
VCID: 44FBB7864783
WVWZZZ9NZ3Y163151 VWZ7Z0B6324541
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: 08 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 00788
VCID: F093AB56A3BB
Address 25: Immobilizer Labels: None
Controller: Bit teA dre ss
Component: e 17 eingeben
VCID: 5AC769FED507
No Faults Found
or a communication error ocurred
Address 44: Steering Assist Labels: None
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00140
VCID: 3905D6723041
End --------------------------------------------------------------------------------------------------
