Resolved Polo 9N ABS coding (ESP 5.7)
Resolved
Edin Ibrisimovic
Bosnia and Herzegovina
C?ID=644190
Hi Team,
Need help about this Polo.
Wednesday,14,October,2026,17:31:13:42296
VCDS Version: 26.3.0.0 (x64)  HEX-NET2 CB: 0.4713.5
VIN: WVWZZZ9NZ3D172202   License Plate: POLO ABS
Mileage: 362090km-224992mi   Repair Order:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ3D172202   Mileage: 362090km-224992miles
Address 01: Engine        Labels: 038-906-019-AXR.lbl
   Part No: 038 906 019 HR
   Component: 1,9l R4 EDC G000SG  1557
   Coding: 00002
   Shop #: WSC 31414
   VCID: 6E8EBF1AD98D56FA2DF-4B1E
   VINID: 9E69EAAAA25EA835011C20800858586F80
   WVWZZZ9NZ3D172202     VWZ7Z0C6688433
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 6Q0-907-37x-ESP.clb
   Part No: 6Q0 907 379 M
   Component: ESP 5.7 front   H02 0001
   Coding: 0003362
   Shop #: WSC 31414 000 00000
   VCID: 47C02ABE93B7A7B24E9-50D0
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
Address 08: Auto HVAC        Labels: 6Q0-907-044.clb
   Part No: 6Q0 907 044
   Component: CLIMAtronic PQ24    0201
   VCID: 6FB0A21EDB875FF2269-50D0
00710 - Defroster Flap Positioning Motor (V107)
01271 - Positioning Motor for Temperature Flap (V68)
01273 - Fresh Air Blower (V2)
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 C
   Component: 00 BN-SG.           1S33
   Coding: 09646
   Shop #: WSC 31414
   VCID: 3B28464EDA7FF352DA1-50D0
            80-10 - Single-Wire Operation - Intermittent
   Part No: 1C0 909 605 F
   Component: 0J AIRBAG VW61 0P07 0003
   Coding: 12362
   Shop #: WSC 31414
   VCID: 27008A3E36F747B2AE9-50D0
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 801 E
   Component: KOMBI+WEGFAHRSP VDO V16
   Coding: 01142
   VCID: 303261620339000A7F3-50D0
   Part No: 6N0 909 901
   Component: 09 GATEWAY  CAN    1S33
   Coding: 00014
   Shop #: WSC 31414
   VCID: 70B2A162C3B9400A3F3-50D0
   Part No: 6Q0 423 156 R
   Component: LenkhilfeKYO        V913
   Coding: 10140
   Shop #: WSC 31414
   VCID: 3E2E4F5AC96DE67AFDF-50D0
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 6Q0 959 433 E
   Component: 3L Komfortgerát     0002
   Coding: 00259
   Shop #: WSC 31414
   VCID: 3D2C4856C46BFD62E45-4B1E
   Subsystem 1 - Part No: 6Q2959802A
   Component: 3L Tőrsteuer.FS TFK 0004
   Subsystem 2 - Part No: 6Q2959801A
   Component: 3L Tőrsteuer.BF TFK 0004
   Subsystem 3 - Part No: 6Q0959811A
   Component: 3L Tőrsteuer.HL TFK 0004
   Subsystem 4 - Part No: 6Q0959812A
   Component: 3L Tőrsteuer.HR TFK 0004
            80-00 - Single-Wire Operation
Address 56: Radio        Labels: 1J0-035-15x-56.lbl
   Part No: 6X0 035 152 C
   Component:  Radio BNO         0006
   Coding: 00003
   Shop #: WSC 31414
   VCID: 313464660833090270D-4B00
End----(Elapsed Time: 02:46, VBatt start/end: 12.5V/12.5V. VIgn 0.0V)------
------------------------------9 Faults Found-------------------------------
TIA,
Edin
Vdub
C?ID=57533
   Coding: 00002
can you try 00102 as the engine coding? Or maybe it will give a popup how to code the ECU
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Good observation. I tried two potential codings in the ABS.
0003362 and 0003416. No joy.
Could someone from @RTSupport please take a look at this?
Vdub
C?ID=57533
can it be that the ABS coding isnt wrong, as it doesnt say wrong coding, but wrong coding on POWER Train, so probably another ECU than the ABS is wrong coded?
Boki Ar
C?ID=57300
NEtech has provided a proposal for the coding, I think we are on the right track. ;)
Boki Ar
C?ID=57300
@NEtech, thank you. :thumbs:
Thursday,15,October,2026,10:11:11:42296
VIN: WVWZZZ9NZ3D172202   License Plate: ABS AFTER
   Coding: 00002
   Shop #: WSC 31414
   Coding: 0003374
   Coding: 09646
   Shop #: WSC 31414
   Coding: 12362
   Shop #: WSC 31414
   Coding: 01142
   Coding: 00014
   Shop #: WSC 31414
   Coding: 10140
   Shop #: WSC 31414
   Coding: 00259
   Shop #: WSC 31414
   Coding: 00003
   Shop #: WSC 31414
End----(Elapsed Time: 02:46, VBatt start/end: 12.2V/12.2V. VIgn 0.0V)------
------------------------------8 Faults Found-------------------------------
Case closed. :cool:
Boki Ar
C?ID=57300
This topic is an excellent example and a reminder again of "first Auto Scan, then everything else."
Also a call to users from the area ex. YU to get more involved here.
Support is worth more than the tool itself. :cool: :thumbs:
