Is there a way to reduce the sensitivity on this car?
I am having an issue where on long drives on the interstates in hot weather the "Tire pressure low" message appears. This will occur two or three times
in a day. Quickly checking the pressures show no tire is down and I will reset the TPMS and continue on. At most one tire might be 2 psi lower than the other three.
I have experimented with setting cold pressures between 32-38 PSI and frequent tire rotations. I have three different tire brands and it does not matter.
This gets annoying having to stop and only to find nothing is wrong.
Included a scan I did two weeks ago.
Friday,02,October,2026,09:55:17:58638
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.4
VIN: WVWHA7CD9RW220030 License Plate:
Mileage: 30538km-18975mi Repair Order:
Chassis Type: CD-VW38 (5WA)
Scan: 01 03 05 08 09 10 13 14 15 17 19 23 2B 32 3C 42 44 4B 52 5F
6C 75 A5 A9 D6 D7 C002 C003
VIN: WVWHA7CD9RW220030 Mileage: 30538km-18975miles
Address 01: Engine (J623-DRNA) Labels: Redir Fail!
Part No SW: 8Y0 906 264 E HW: 06K 907 425 N
Component: R4 2.0l TFS H08 0001
Dataset Number: 06Q909102BF 0001 CVN: 946F4280FCD25DD3
Coding: 091900122464000E30000000000000000000000000000000
ASAM Dataset: EV_ECM20TFS0208Y0906264E 001002
ROD: EV_ECM20TFS0208Y0906264E.rod
VCID: 41DF4AB311079AE2A8E-8014
VINID: 9E69D84474D42629C2080003007F91DDBB
25575 - Camera control module
U107A 00 [00100000] - No communication
Reset counter: 6
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:13
Engine speed: 2215.25 /min
Normed load value: 41.2 %
Vehicle speed: 103 km/h
Coolant temperature: 102 C
Intake air temperature: 27 C
Voltage terminal 30: 12.714 V
Unlearning counter according OBD: 6
LF_MVB_PDU_INTC_DIAG_8: 0
LF_MVB_PDU_INTC_DIAG_9: 0
LF_MVB_PDU_INTC_DIAG_10: 64
LF_MVB_PDU_INTC_DIAG_11: 8192
LF_MVB_PDU_INTC_DIAG_13: 31
LF_MVB_BUS_INTC_DIAG: 256
23043 - Implausible Data Received from Body Control Module (Central Electric)
U0422 00 [00100000] - -
Reset counter: 25
Mileage: 26263 km
Date: 2026.08.11
Time: 09:08:25
Engine speed: 1316.25 /min
Normed load value: 7.1 %
Coolant temperature: 68 C
Intake air temperature: 57 C
Voltage terminal 30: 12.031 V
Unlearning counter according OBD: 25
LF_MVB_PDU_INTC_DIAG_15: 0
LF_MVB_PDU_INTC_DIAG_16: 0
LF_MVB_PDU_INTC_DIAG_17: 0
LF_MVB_PDU_INTC_DIAG_18: 0
LF_MVB_PDU_INTC_DIAG_19: 0
LF_MVB_PDU_INTC_DIAG_20: 0
15131 - Cylinder 3
P0303 00 [01100000] - Misfire Detected
15074 - Cylinder Disabling
P130A 00 [00100000] - -
Address 03: ABS Brakes (J104) Labels: 5WA-614-517-V1.clb
Part No SW: 5WA 614 517 CF HW: 5WA 614 517 N
Component: ESC H13 0135
Serial number: 61364000000370 Dataset Number: V03935397FY 0001 CVN: E33E0D70
Coding: 36FC6C9056226A6C9377640326C360064A525855528803C02014B831018FF100002814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 013058
ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
VCID: 0E45A18F10D9359A65C-805A SFD [x]
8472 - Implausible Data Received from Airbag Control Module
U0452 00 [00100000] - -
[CCan_AB_Gurtschloss_FA_ext_inv]
8531 - No Communications with Front Sensor Package for Driver Assist. Systems
U10E0 00 [00100000] - -
[CCan_EA_01_timeout]
Reset counter: 6
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:14
Vehlicle_speed: 101.3 km/h
Resolution Mileage: 812 m
Voltage_value_KL.30_ESC_V: 12.7 V
Wake up EPB: not active
Wake up CAN: not active
Postrun_activ: not active
Comparison_pressure_sensor: completed successfully
Comparison_longitudinal_accleration: completed successfully
Comparison_transverse_accleration: completed successfully
Comparison_yaw_rate_sensor: completed successfully
LWS_comparison: completed successfully
Internal_failure_code: 00 34
00 02 40 00 08 05 80 08 80 84 82 80 81 00 00 40 00 00 08 40 04
16401 - Tire Pressure Warning
C102D 00 [00101000] - -
Fault Frequency: 15
Reset counter: 36
Mileage: 12871 km
Date: 2025.07.06
Time: 06:40:29
Vehlicle_speed: 88.8 km/h
Resolution Mileage: 48 m
Voltage_value_KL.30_ESC_V: 12.8 V
Internal_failure_code: 00 F7
00 02 40 00 08 05 80 08 80 84 80 80 80 00 00 40 00 00 08 40 04
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 P HW: 5WA 959 436 P
Component: Kessy IOBOX 100 0725
Serial number: --------------- Dataset Number: V03935341VY 0001
ASAM Dataset: EV_Kessy37w 004024
ROD: EV_Kessy37w_004.rod
VCID: 619FAA33B1C7FAE288E-8034
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 5WA 907 007 AB HW: 5WA 907 007 AB
Component: AC Automat H30 3623
Serial number: --------------- Dataset Number: V03935418JG 0001
Coding: 002000010210000000100010111110010000011000000000000000000000
ASAM Dataset: EV_ACClimaPREVW38X 001102
ROD: EV_ACClimaPREVW38X_VW38.rod
VCID: 074B94AB7FA364D2A6A-8052
Interior temperature sensor:
Subsystem 1 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00002290424084007518
Address 09: Cent. Elect. (J519) Labels: 5WA-937-08X-V1.clb
Part No SW: 5WA 937 086 BR HW: 5WA 937 086 AT
Component: BCM37w_M134 0183
Serial number: BXJ53F150524940 Dataset Number: V03935400FM 0001
ASAM Dataset: EV_BCM37w 007001
ROD: EV_BCM37w_007_VW38.rod
VCID: 221DE53FF441A1FAD14-8076 SFD [x]
Subsystem 1 - Part No SW: 5H1 955 119 B HW: 5H1 955 119
Component: FWISCHER_MYJT 003 0061
Serial number: 907453F0302410702759
Subsystem 2 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S5Y24M05D31H08M40S39
Subsystem 3 - Part No SW: 5H0 941 193 AP HW: 5H0 941 193 AP
Component: LiSi H06 0008
Serial number: 92471XEA001LN
Subsystem 4 - Part No SW: 5H0 925 200 R HW: 5H0 925 200 R
Component: DiETa H07 0008
Serial number: 92471XE3002HT
Subsystem 5 - Part No SW: 5H0 959 561 BM HW: 5H0 959 561 BM
Component: -VW----LINDA- 504 0831
Serial number: MW3LND23052400012663
Steering Column Switch:
Subsystem 6 - Part No SW: 5Q1 953 507 GB HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000015052404220079
15400960 - Secure Onboard Communication
U14FD 00 [00101000] - Time Server not Available
[Sichere on-board Kommunikation: Zeitserver nicht verf gbar]
Reset counter: 39
Mileage: 9145 km
Date: 2025.03.19
Time: 17:23:20
Terminal 15 status: OFF
Terminal 50 status: OFF
Engine run: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 12.3 V
Outside temperature: 21.0 C
Light switch position: automatic
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5R3 919 294 HW: 5R3 919 294
Component: PDC 08 Kanal H05 1550
Serial number: 000995460324135 Dataset Number: V03935375FW 0001
Coding: 0040014001
ASAM Dataset: EV_EPHVA18VW3800000 002036
ROD: EV_EPHVA18VW3800000_VW38.rod
VCID: 7CA1FB473665370ABB8-8028
13688835 - Databus
U1123 00 [00100000] - Received Error Message
[Steuerger t f r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
Address 13: Auto Dist. Reg (J428) Labels:| 5WA-907-572.clb
Part No SW: 5WA 907 572 C HW: 5WA 907 572 A
Component: ACC BOSCH MQB H45 0461
Dataset Number: V03935392FC 0001
Coding: 05220094400780451247400000804004AE4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
VCID: 4EC5618FD059759A25C-801A
14 Faults Found:
1107 - Databus
U1121 00 [00101000] - Missing Message
[FAULT_TIMEOUT_KAMERA_STATUS]
Reset counter: 6
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:12
1538 - Sensor for Automatic Distance Control
C110B F0 [00100000] - Limited Visibility
[FAULT_SENSOR_BLINDNESS]
1545 - Databus
U1122 00 [00100000] - Implausible Message
[FAULT_VZM_SYSTEM_STATUS]
1584 - Databus
U1122 00 [00101000] - Implausible Message
[FAULT_ESP_FZR_OVERSTEER_INIT]
Fault Frequency: 9
Reset counter: 3
Mileage: 23110 km
Date: 2026.02.28
Time: 12:47:43
1587 - Databus
[FAULT_ESP_FZR_UNDERSTEER_INIT]
Fault Frequency: 9
Reset counter: 3
Mileage: 23110 km
Date: 2026.02.28
Time: 12:47:43
2068 - Databus
[FAULT_TSK_IRREV_ERROR]
2425 - Databus
[FAULT_SENSORFUSION_INPUT_CAMERA_NOT_AVAILABLE]
Reset counter: 6
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:12
0520 - Databus
[FAULT_TIMEOUT_BV1_LINIEN_01]
Reset counter: 6
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:12
0536 - Databus
[FAULT_TIMEOUT_VZE_04]
Reset counter: 6
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:14
0567 - Databus
[FAULT_HMS_FAILURE_STATUS_ERROR]
0729 - Databus
[FAULT_TIMEOUT_TA_01]
Reset counter: 6
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:13
0731 - Databus
[FAULT_TIMEOUT_BV1_LINIEN_02]
Reset counter: 6
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:12
0732 - Databus
[FAULT_TIMEOUT_EA_01]
Reset counter: 6
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:16
0742 - Databus
[FAULT_TIMEOUT_HCA_01]
Reset counter: 6
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:16
Address 14: Susp. Elect. (J250) Labels: 1EA-907-376.clb
Part No SW: 1EA 907 376 C HW: 1EA 907 376
Component: DAEMPFUNGS-SG H05 0457
Serial number: 2C7673241308012 Dataset Number: V03935344MM 0001
ASAM Dataset: EV_DCC3CONTITEMIC 002006
ROD: EV_DCC3CONTITEMIC_002_VW38.rod
VCID: 3A2D3D5F7CD1C93AE94-806E
Address 15: Airbags (J234) Labels:* 5WA-959-655.clb
Part No SW: 5WA 959 655 AE HW: 5WA 959 655 AE
Component: AirbagVW40 011 0660
Serial number: 000000003C0RMRB Dataset Number: V03935414HD 0001
Coding: 8CCC000000FCC00000000000000000005100000000000000000036F800130065
ASAM Dataset: EV_AirbaVW40SMEVW38X 001034
ROD: EV_AirbaVW40SMEVW38X.rod
VCID: 1A6DDDDFDC11E93A094-804E SFD [x]
Component: ------------- H17 0022
Serial number: IBH00000000000MJW54%
Subsystem 2 - Part No SW: ----------- HW: 480 051 405 24
Component: SideSensor_Dr 000 0149
Serial number: 3510000C0D398B8BC82K
Subsystem 3 - Part No SW: ----------- HW: 480 051 405 24
Component: SideSensor_Pr 000 0149
Serial number: 3520000C2D398B89E44L
Subsystem 4 - Part No SW: ----------- HW: 480 001 004 24
Serial number: 35700000000569443F6O
Subsystem 5 - Part No SW: ----------- HW: 480 001 004 24
Serial number: 3580000000067D805F6X
Subsystem 6 - Part No SW: ----------- HW: 480 052 705 24
Component: FrontSensor_D 000 014A
Serial number: 3550000C0D109E144A3+
Subsystem 7 - Part No SW: ----------- HW: 480 052 705 24
Component: FrontSensor_P 000 014A
Serial number: 3560000C0D109E15672+
Address 17: Instruments (J285) Labels:| 5H0-920-KOM-V1.clb-SRI2
Part No SW: 5H0 920 340 C HW: 5H0 920 340 C
Component: KOMBI 310 7380
Dataset Number: V03935364SX 0001
Coding: 08BC04027B8CCF050280220B2000000800300400
ASAM Dataset: EV_DashBoardVDDMQB37W 003035
ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
Part No SW: 5WA 907 530 AB HW: 5WA 907 530 L
Component: GW2020 High 778 7105
Revision: -------- Serial number: 771049110024142 Dataset Number: V03935439LN 0001
Coding: 0000800D0E00000000000000012303307302600902000300030100000001010000000000000000000000000000000000
GVL: 3D400000020840CC800080024C00004004004002004000000000000000000044
ASAM Dataset: EV_GatewMQB2020 006012
ROD: EV_GatewMQB2020_006_VW38.rod
VCID: 0849979772BD6BAAAF0-805C SFD [x]
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5WA 915 181 C HW: 5WA 915 181 C
Component: J367-BDMHella H11 9080
Serial number: 9933434306
Subsystem 3 - Part No SW: 1EA 959 442 E HW: 1EA 959 442 E
Component: MFL H03 0219
Serial number: 17036218141412400345
Subsystem 4 - Part No SW: 5H0 959 542 N HW: 5H0 959 542 N
Component: KLR_JSS_1Zone 089 0023
Serial number: 3136188AA24141343403
8 Faults Found:
1049105 - Powertrain Databus
U0002 00 [00100000] - No Communications
[Data_bus_powertrain_no_communication]
2097231 - No Communications with Front Sensor Package for Driver Assist. Systems
2175079 - No Communications with Emergency Call Module
U10E1 00 [00100000] - -
1049254 - Ethernet Databus Branch 6
U1231 00 [00100000] - No Communication
[Ethernet_databus_no_communication_branch_6_/_port_7]
8397571 - LV Energy Management
B1802 F1 [00100000] - Warning Triggered
8466689 - VKMS
B18B0 F0 [00100000] - Missing Adaptation
[VKMS_new_download_container_required_due_to_vehicle_change]
8482819 - Activatable Functions
B18D3 F3 [01100000] - Faulty Vehicle Configuration
[Fs_id_configuration_error]
8398594 - Control unit for battery monitoring
U1050 00 [00100000] - No Communication
[BDMs_FuSi_no_communication]
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 AB HW: 3Q0 909 059 D
Component: EBKV H09 0372
Serial number: BPA085060524013 Dataset Number: V03935367RC 0001
Coding: 5003C5409F00007BEFBDF7DE000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
VCID: 1079BFF70AED236A770-8044 SFD [x]
1024368 - Brake Booster
C1187 F6 [00100000] - Function Limitation due to External Brake Pressure Build-Up
[ActiveRestrictionDetected]
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H10 0040
Serial number: 24000125819012 Dataset Number: V03935336NF 0001
Coding: 0000000000000000
ROD: EV_ELVMarqMQBA0_VW38.rod
VCID: 323D157FA4A1317A214-8066
Address 32: Differential Locks (-----) Labels:| 0CQ-907-554-V2.clb
Part No SW: 5WA 907 554 B HW: 5WA 525 130
Component: Quersperre H65 8643
Serial number: HH3-00025.01.24 Dataset Number: V03935287KY 0001
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 005001
ROD: EV_LockElectHA1VW37X_005.rod
VCID: 4DC76683DD5F4E825C6-8018
Address 3C: Lane Change (J1086) Labels:* Redir Fail!
Part No SW: 2Q0 907 686 J HW: 2Q0 907 686 J
Component: HRE_Master H27 0288
Serial number: 00000645468021 Dataset Number: V03935373GS 0001
Coding: 569945D0
ASAM Dataset: EV_HREntryHellaGen3Mstr 001016
ROD: EV_HREntryHellaGen3Mstr_VW38.rod
Subsystem 1 - Part No SW: 2Q0 907 685 J HW: 2Q0 907 685 J
Component: HRE_Slave H27 0288
Serial number: 00000645492253
Lane change assistance display left:
Subsystem 2 - Part No SW: 5H1 949 145 HW: 5H1 949 145
Component: SWA LED VL H05 0005
Serial number: 00000000000016909060
Lane change assistance display right:
Subsystem 3 - Part No SW: 5H1 949 146 HW: 5H1 949 146
Component: SWA LED VR H05 0005
2252891 - Databus
[databus error value received - VMM_02 - VZM_Systemstatus]
Address 42: Door Elect, Driver (J386) Labels:* Redir Fail!
Part No SW: 5Q0 959 593 L HW: 5Q0 959 593 F
Component: TSG FS004 0350
Serial number: YE007XE425429 Dataset Number: V03935413UZ 0001
Coding: 003B03205000040008000000
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 4ACD6D9F2C3159BA794-801E
Subsystem 1 - Part No SW: 5Q0 959 408 G HW: 5Q0 959 164 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000081639570
Coding: 111000
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V1.clb
Part No SW: 5WA 907 145 G HW: 5WA 907 145 C
Component: BASGEN1MQB37 502 1040
Serial number: 03710865 Dataset Number: V03935358SR 0001
Coding: 0000000000000001000002010100010000000100010101
ROD: EV_SteerAssisBASGEN1MQB37_007.rod
6192 - Databus
U1121 00 [00100000] - Missing Message
[DTC_HCA_03_TIMEOUT]
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5WA 907 338 B HW: 5WA 907 338
Component: FCM2020 Low H14 1447
Serial number: 250151224186270 Dataset Number: V03935346BX 0001
Coding: 000000000900070A06110310040003000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW38X 004012
ROD: EV_MultiModulContiVW38X.rod
VCID: 4DC76683DD5F4E825C6-8018 SFD [x]
Part No SW: 5Q0 959 592 L HW: 5Q0 959 592 F
Component: TSG BFS004 0350
Serial number: YE007XE71302E Dataset Number: V03935413V 0001
Coding: 003B03205C00040000800000
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 49CF5293293752A270E-801C
Subsystem 1 - Part No SW: 5Q0 959 407 G HW: 5Q0 959 163 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000081462927
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 5H0 035 871 HW: 5H0 035 871
Component: MU-E--US 135 1805
Serial number: CVRV59N0AED0007 Dataset Number: V03935431DH 0001
Coding: 23800000000200000000000000000000000000000000000000
ASAM Dataset: EV_MUEIMQB37w 001003
ROD: EV_MUEIMQB37w_VW38.rod
VCID: 6597BE23A5EF96C2746-8030 SFD [x]
6938 - Function Restricted due to Interrupted Communications
U1110 00 [00001000] - -
[Side assist (0x1A) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 8
Mileage: 17265 km
Date: 2025.09.02
Time: 06:38:06
Voltage terminal 30: 12.4 V
6937 - Function Restricted due to Interrupted Communications
[Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 27
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:16
Voltage terminal 30: 12.8 V
7193 - Function Restricted due to Interrupted Communications
[Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 27
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:19
BAP: 02
12316 - Clock Syncronization Failure
U138F 00 [00001000] - -
Reset counter: 39
Mileage: 9498 km
Date: 2025.03.21
Time: 13:19:06
1865 - Automotive Audio Bus (A2B)
B1994 F5 [00001000] - Participant Error
[a2b_bus_next_node_defect]
Fault Frequency: 28
Reset counter: 33
Mileage: 9498 km
Date: 2025.03.21
Time: 12:45:12
amount_of_nodes: 3
Node number: 0
Node name: Information electronics control module 1
Node status: OK
1872 - Automotive Audio Bus (A2B)
B1994 F4 [00001000] - Microphone Module Defective
[a2b_bus_micro_defect]
Reset counter: 8
Mileage: 23110 km
Date: 2026.02.28
Time: 07:33:21
Voltage terminal 30: 12.5 V
amount_of_nodes: 0
Node number: 0
Node name: Left rear microphone module
Node status: OK
Voltage terminal 30: 0.1 V
Address 6C: Back-up Cam. (J772) Labels:| 5WA-980-556.clb
Part No SW: 5WA 980 556 D HW: 5WA 980 556 B
Component: RV eCompact H31 0344
Serial number: FCLK20290224000 Dataset Number: V03935359FC 0001
Coding: 02030004E42800
ASAM Dataset: EV_CamSysRVCCompaFicos 010024
ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
VCID: 52FD75FFC461117A014-8006
Part No SW: 5WA 035 285 F HW: 5WA 035 285 A
Component: OCU3HMQB37W H14 0026
Serial number: 0000000312VIQS1 Dataset Number: V03935379BN 0001
Coding: 02380020906828208005460070102607
ASAM Dataset: EV_OCU3HMQB37W 001051
ROD: EV_OCU3HMQB37W_001_VW38.rod
VCID: 4ACD6D9F2C3159BA794-801E SFD [x]
1644017 - Online Services
B1915 F1 [00001000] - Temporary Function Restriction due to Battery Budget
[Functional restriction due to insufficient power budget]
Fault Frequency: 27
Reset counter: 16
Mileage: 28355 km
Date: 2026.09.09
Time: 08:46:09
Voltage terminal 30: 12.3 V
Remaining long term energy budget: 3521 mAh
Remaining short term energy budget: 1 mAh
Wake up cycles counter: 1236
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 5WA 980 653 D HW: 5WA 980 653
Component: MQB MFK 3.0 H12 3405
Serial number: EB7590904241430 Dataset Number: V03935412E 0001
Coding: 00000A88006C4040109F00001020002000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005055
ROD: EV_MFK3ValeoMQB_005_VW38.rod
VCID: 50F97FF7CA6D636A370-8004
1124760 - Databus
[QFK_01_eps_hca_status_failure_me]
Fault Priority: 9
Reset counter: 6
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:16
1124443 - Databus
[Motor_54_TSK_Status_EA]
Reset counter: 6
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:15
1126450 - Databus
[ACC_18_ACC_Status_ACC_reversibel_ERROR]
Reset counter: 6
Mileage: 25839 km
Date: 2026.08.09
Time: 06:48:13
Part No SW: 5H0 907 159 HW: 4K0 907 159
Component: SAS-GEN 2.5 H08 0001
Serial number: 240520290556
ROD: EV_SoundActuaGen2AU64X_003_VW27.rod
VCID: 6C81CB074605A78A2B8-8038
Part No SW: 992 941 571 AH HW: 992 941 571 A
Component: LED1L H25 9204
ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
VCID: 6889B71752FD8BAA4F0-803C
Component: LED1R H25 9204
ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
End----(Elapsed Time: 01:44, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
------------------------------44 Faults Found
