VW Caddy 2023. DTR
Tomasz Płotczyk
Poland
C?ID=528688
Good morning. I am sending the VW Caddy auto-scan.
Best regards, Tomek.
Tuesday,13,October,2026,07:40:49:05334
VCDS Version: 26.10.1.2 (x64)  HEX-V2 CB: 0.4713.4
Data version: 20260921 DS379.0
VIN: WV2ZZZSK8RX006747   License Plate: DTR
Mileage: 210433km-130757mi   Repair Order:
Chassis Type: SK-VN3S (5WB)
Scan: 01 02 03 08 09 13 15 17 19 23 42 44 52 5F 75 A5 D6 D7 C002 C003
VIN: WV2ZZZSK8RX006747   Mileage: 210433km-130757miles
Address 01: Engine (J623-DTRC)       Labels:. 05L-907-309-V1.clb
   Part No SW: 05L 906 023 EM    HW: 05L 907 309 AA
   Component: R4 2.0l TDI   H80 2147
   Revision: ECH80---    Dataset Number: V03935347HQ 0001 CVN: BC45482A04B77F64660402296604022943FB2DAA
   Coding: 012500120364050920000000000000000000000000000000
   Shop #: WSC 35110 377 00023
   ASAM Dataset: EV_ECM20TDI01105L906023EM 009001
   ROD: GV_ECM20TDI011VN35S.rod
   VCID: 77ABE7CDDF4C09D2DA3-8022
   VINID: 9E60AAAAA8DB222A000061C41C62BD4BE7
   Part No SW: 0GC 906 555 S    HW: 0GC 300 047 L
   Component: GSG DQ381     H06 4161
   CVN: 3160EFEF
   ASAM Dataset: EV_TCMDQ381062 001001
   ROD: EV_TCMDQ381062_VW38.rod
   VCID: 4BC36B3DF3445D324EB-801E
   Subsystem 1 - Part No SW: 5WA 713 033 CD    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20230524000087526056
   Subsystem 2 - Part No SW: 7T0 713 052 D    HW: 7T0 713 052 D
   Component: ZSB_SB_mono    H01 0005
   Serial number: 19062306S00000058655
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810700005477587
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 CF    HW: 5WA 614 517 N
   Component: ESC           H13 0135
   Serial number: 61783000002251  Dataset Number: V03935397GD 0001 CVN: 83FF7D8B
   Coding: 540C2A9744202272827E50040ACA60066DB658F55AC8670821BCA23121CFF300001C38
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013058
   ROD: EV_Brake1ESCEPBMQB37W_013_AU38.rod
   VCID: 0E45A229C0D6281A695-805A SFD [x]
590080 - Release / Enable Active
          B184C 00 [00101000] - -
          [Unlock_protection_of_vehicle_diagnosis_active]
                    Reset counter: 20
                    Mileage: 207613 km
                    Date: 2026.09.22
                    Time: 18:45:05
                    Vehlicle_speed: 0.0 km/h
                    Resolution Mileage: 552 m
                    Voltage_value_KL.30_ESC_V: 11.6 V
                    Wake up EPB: not active
                    Wake up CAN: active
                    Postrun_activ: not active
                    Comparison_pressure_sensor: completed successfully
                    Comparison_longitudinal_accleration: completed successfully
                    Comparison_transverse_accleration: not completed successfully
                    Comparison_yaw_rate_sensor: completed successfully
                    LWS_comparison: completed successfully
                    Internal_failure_code: 01 AE
                    00 E0 40 00 04 0C 80 08 20 00 00 00 80 00 00 00 06 00 08 40 04
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 727 AA    HW: 5WA 907 727 AA
   Component: AC Manuell    H02 0440
   Serial number: --------------- Dataset Number: V03935362SF 0001
   Coding: 023010019211000000000000101000010000010000000000000000000000
   ASAM Dataset: EV_ACManueBHBVW38X 001027
   ROD: EV_ACManueBHBVW38X_VN3S.rod
   VCID: 0F7BBF2DC7DC2112623-805A
459533 - Databus
          U1123 00 [00101111] - Received Error Message
          [Databus_error_value_received_Botschaft_Airbag_02]
                    Fault Frequency: 22
                    Mileage: 180908 km
                    Date: 2026.01.09
                    Time: 17:02:56
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [01100000] - -
                    Reset counter: 22
                    Mileage: 207997 km
                    Date: 2026.09.25
                    Time: 14:23:40
                    Voltage terminal 30: 11.80 V
                    Compressor shut-off condition: Shut-off from Engine Control Module (ECM) via CAN
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [00100000] - -
                    Reset counter: 0
                    Mileage: 184898 km
                    Date: 2026.01.23
                    Time: 08:15:17
                    Voltage terminal 30: 14.60 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 2
                    Auxiliary heater: in stages-Actual value: 3
                    Auxiliary heater: in stages-Specified value: 2
                    Auxiliary heater: in stages-Specified value for control: 2
                    Auxiliary heater: controlled-Status: not active
                    Auxiliary heater: controlled-Current: actual value: 0.00
                    Auxiliary heater: controlled-Power: actual value: 0.00
                    Auxiliary heater: controlled-Power: target value: 0.00
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 BM    HW: 5WA 937 086 AT
   Component: BCM37w_M134 0182
   Serial number: BXJ53F120623940 Dataset Number: V03935414RF 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_VN3S.rod
   VCID: 1D67D5651D308382E0F-8048 SFD [x]
   Subsystem 1 - Part No SW: 5H0 941 193 AD    HW: 5H0 941 193 AD
   Component: LiSi           H04 0513
   Serial number: TW571415062300010677
   Subsystem 2 - Part No SW: 5H0 925 200 AA    HW: 5H0 925 200 AA
   Component: DiETa          H07 0008
   Serial number: 92471WEU001KA
   Subsystem 3 - Part No SW: 7T0 959 561 P    HW: 7T0 959 561 P
   Component: -VW----LINDA-  504 0831
   Serial number: MW3LND30052300013177
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 507 EQ    HW: 5Q1 953 549 D
   Serial number: 00000015062304220995
1074835 - Rear Left Ride-Height Sensor
          C1036 01 [00101000] - Electrical Failure
          [PSI5-Strang hinten links: elektrischer Fehler (Anteil Niveausensor)]
                    Reset counter: 30
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    Engine run: OFF
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Voltage: 12.6 V
                    Outside temperature: 12.0 °C
                    Light switch position: automatic
71936 - Rear Left Ride-Height Sensor
          C1036 31 [00101110] - No Signal
          [Drehwinkelsensor hinten links: Leitungsunterbrechung]
                    Engine run: OFF
                    Voltage: 12.5 V
                    Outside temperature: -5.0 °C
Address 13: Auto Dist. Reg (J428)       Labels:| 5WA-907-572.clb
   Part No SW: 5WA 907 572 C    HW: 5WA 907 572 A
   Component: ACC BOSCH MQB H40 0461
   Dataset Number: V03935372EJ 0001
   Coding: 08020005007740451247400000C000044E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
   ROD: EV_FRONTRADARBOSCHVW380_004_VN3S.rod
   VCID: 4EC562290056681A295-801A
14 Faults Found:
1396 - Sensor for Automatic Distance Control
          C110B F0 [00100000] - Limited Visibility
          [FAULT_SENSOR_NO_FREE_SIGHT]
1538 - Sensor for Automatic Distance Control
          [FAULT_SENSOR_BLINDNESS]
1545 - Databus
          U1122 00 [00100000] - Implausible Message
          [FAULT_VZM_SYSTEM_STATUS]
1561 - Databus
          U1123 00 [00101000] - Received Error Message
          [FAULT_BV_AVAILABILITY_ERROR]
                    Reset counter: 13
                    Mileage: 206523 km
                    Date: 2026.09.17
                    Time: 12:18:39
2082 - Databus
          U1123 00 [00100000] - Received Error Message
          [FAULT_EPB_SWITCH_ERROR]
209054 - Databus
          [FAULT_BV_BLINDNESS_ERROR]
                    Reset counter: 35
                    Mileage: 206725 km
                    Date: 2026.09.19
                    Time: 06:17:24
2425 - Databus
          U1122 00 [00101000] - Implausible Message
          [FAULT_SENSORFUSION_INPUT_CAMERA_NOT_AVAILABLE]
                    Reset counter: 35
                    Mileage: 206523 km
                    Date: 2026.09.17
                    Time: 12:18:40
0567 - Databus
          [FAULT_HMS_FAILURE_STATUS_ERROR]
0574 - Databus
          [FAULT_HMS_SYSTEM_STATUS_ERROR]
0577 - Databus
          [FAULT_VZM_SYSTEM_STATUS_ERROR]
0615 - Databus
          [FAULT_BRAKE_REQUEST_INVALID]
0727 - Databus
          [FAULT_QBIT_VZM_DRIVER_BRAKES_INVALID]
0859 - Databus
          [FAULT_KAMERA_HIGH_SYSTEMZUSTAND_INIT]
                    Reset counter: 13
                    Mileage: 206523 km
                    Date: 2026.09.17
                    Time: 12:18:42
0862 - Databus
          [FAULT_DIRECTION_OF_TRAVEL_HL_HR_INVALID_SIGNAL]
Address 15: Airbags (J234)       Labels: 1EA-959-655.clb
   Part No SW: 1EA 959 655 FB    HW: 1EA 959 655 EM
   Component: VW40Airbag    011 0185
   Serial number: X164LhE2C04     Dataset Number: V03935412NR 0001
   Coding: 88CC008000E0C00000000000000000005154500020AAA2005F00F680002B0065
   Shop #: WSC 33187 006 1048576
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001016
   ROD: EV_AirbaVW40ALVVW38X_VN3S.rod
   VCID: 06559A09A8A6605AD15-8052 SFD [x]
   Seat occupancy detection 1:
   Subsystem 1 - Part No SW: 2K7 959 760 B    HW: 2K7 959 760 B
   Component: wSBR F-SG      037 0166
   Serial number:         94DC4E0C6ECB
   Subsystem 2 - Part No SW: -----------    HW: 440 000 704 23
   Component: SideSensor_Df  00A 0887
   Serial number: 357CJ000000AD16D586M
   Subsystem 3 - Part No SW: -----------    HW: 440 000 704 23
   Component: SideSensor_Pf  00A 0887
   Serial number: 358CJ000000265E4586B
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 4 - Part No SW: -----------    HW: 440 000 811 22
   Component: Side_Sens_B_D  00A 0149
   Serial number: I0PCJA30BD78D351800R
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 5 - Part No SW: -----------    HW: 440 000 811 22
   Component: Side_Sens_B_P  00A 0149
   Serial number: I0QCJAF0BD78E215600
   Subsystem 6 - Part No SW: -----------    HW: 440 000 811 22
   Component: SideSensor_Dr  00A 0149
   Serial number: 351CJA10BE0C7485400U
   Subsystem 7 - Part No SW: -----------    HW: 440 000 811 22
   Component: SideSensor_Pr  00A 0149
   Serial number: 352CJA10BD790252E00T
   Subsystem 8 - Part No SW: -----------    HW: 440 000 106 23
   Component: FrontSensor_D  00A 014A
   Serial number: 355CJBF0EC830125200V
   Part No SW: 2K7 920 741 A    HW: 2K7 920 741 A
   Component: KOMBI         300 6423
   Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙ Dataset Number: V03935388LU 0001
   Coding: 04A4154763840008018022030000000800601C00
   ASAM Dataset: EV_DashBoardVISMQB37W 002021
   ROD: EV_DashBoardVISMQB37W_SK38.rod
   VCID: 2C0108A1568A7A0A671-8078 SFD [x]
16777020 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Fault Frequency: 80
                    Reset counter: 37
                    Mileage: 180997 km
                    Date: 2026.01.12
                    Time: 15:45:54
16711695 - Low Coolant Level
          B1B07 00 [00001000] - -
          [warning_insufficient_coolant]
                    Reset counter: 25
                    Mileage: 204760 km
                    Date: 2026.09.08
                    Time: 07:39:05
16711686 - Secure Onboard Communication
          U14FE 00 [00001000] - Signature Verification Failed
          [SOK_signature_verification_failed]
                    Fault Frequency: 25
                    Reset counter: 38
                    Mileage: 194272 km
                    Date: 2026.04.30
                    Time: 18:49:43
   Part No SW: 5WB 907 530 J    HW: 5WB 907 530 J
   Component: GW2020 LOW    845 8324
   Serial number: BXJ53F130623958 Dataset Number: V03935400WF 0001
   Coding: 0000808D0700000000000000012303320101000900000300030100000001000000000000000000000000000000000000
   GVL: 3D0000000008408C80008000C800000000000000000000000000000000000040
   ASAM Dataset: EV_GatewMQB2020 006012
   ROD: EV_GatewMQB2020_006_VN3S.rod
   VCID: 50F97C511A627EEA3B9-8004 SFD [x]
   Generator:
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 8888992206
   Subsystem 3 - Part No SW: 3G0 959 442 AB    HW: 3G0 959 442 AB
   Component: E221__MFL-PR6  H07 0120
   Serial number: PR6-0440071341225602
                    Reset counter: 21
                    Mileage: 207613 km
                    Date: 2026.09.22
                    Time: 18:45:05
   Part No SW: 5WA 909 059 AB    HW: 3Q0 909 059 D
   Component: EBKV          H09 0372
   Serial number: BPA085220623013 Dataset Number: V03935367RL 0001
   Coding: 5402C10000000031C618638C000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VN3S.rod
   VCID: 1079BC51DAE23EEA7B9-8044 SFD [x]
172400 - System Voltage
          P0562 00 [00101000] - Too Low
          [PSCUnderVoltageLevel1]
                    Reset counter: 18
                    Mileage: 209769 km
                    Date: 2026.10.11
                    Time: 11:22:13
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000501881947  Dataset Number: V03935403N  0001
   Coding: 00308320D000040100001020
   Shop #: WSC 35110 377 00049
   ROD: EV_DCU2DriveSideMAXHCONT_VN3S.rod
   VCID: 52FD7659146E0CFA0DD-8006
   Part No SW: 5R3 907 146 A    HW: 5R3 907 146
   Component: BASGEN1MQB37  261 2040
   Serial number: 00031682 Dataset Number: V03935347P  0001
   Coding: 0000000100000000000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007.rod
   VCID: 36352AC998C630DA015-8062
5407 - Terminal 30
          U140A 00 [00100000] - Open Circuit
          [DTC_RESET_SDK]
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000501229771  Dataset Number: V03935403NA 0001
   Coding: 00300120D000040100801000
   ROD: EV_DCU2PasseSideMAXHCONT_VN3S.rod
   VCID: 51FF7955116877E2347-8004
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 5H0 035 869 A    HW: 5H0 035 869
   Component: MU-E-D-ER     125 1776
   Serial number: CVRV5BX1AEA0031 Dataset Number: V03935397MN 0001
   Coding: 63521000002000000000000000000000000000000000000000
   ASAM Dataset: EV_MUEIMQB37w 001003
   ROD: EV_MUEIMQB37w_VN3S.rod
   VCID: 2D0705A56D90730270F-8078 SFD [x]
7955 - Control module
          B2001 00 [00001000] - Incorrect software version
          [Central unit master (0x13) - control module: incorrect software version - BapErr_incompatible data specification]
                    Reset counter: 7
                    Mileage: 200815 km
                    Date: 2026.08.02
                    Time: 20:19:36
                    Voltage terminal 30: 12.4 V
1872 - Automotive Audio Bus (A2B)
          B1994 F4 [00001000] - Microphone Module Defective
          [a2b_bus_micro_defect]
                    Reset counter: 32
                    Mileage: 184931 km
                    Date: 2026.03.30
                    Time: 16:15:13
                    Voltage terminal 30: 10.7 V
                    amount_of_nodes: 0
                    Node number: 0
                    Node name: Left rear microphone module
                    Node status: OK
                    Voltage terminal 30: 0.1 V
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 5WA 035 284 F    HW: 5WA 035 284 C
   Component: OCU3HMQB37W   H14 0144
   Serial number: 0000000305VIKED Dataset Number: V03935377QJ 0001
   Coding: 06359010106818208005460070002607
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VN3S.rod
   VCID: 49CF5135F9384F227C7-801C SFD [x]
7423 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [PaCo_0x55_function_restriction_due_to_communication_error_BapErr_RetryNotSuccessful]
                    Fault Frequency: 181
                    Mileage: 180908 km
                    Date: 2026.01.12
                    Time: 12:28:20
                    Voltage terminal 30: 11.6 V
1644017 - Online Services
          B1915 F1 [00001000] - Temporary Function Restriction due to Battery Budget
          [Functional restriction due to insufficient power budget]
                    Reset counter: 7
                    Mileage: 204918 km
                    Date: 2026.09.09
                    Time: 11:32:23
                    Voltage terminal 30: 12.5 V
                    Remaining long term energy budget: 3560 mAh
                    Remaining short term energy budget: 2 mAh
                    Wake up cycles counter: 5937
   Part No SW: 5WA 980 653 D    HW: 5WA 980 653
   Component: MQB MFK 3.0   H09 3403
   Serial number: EA8808903231290 Dataset Number: V03935412KV 0001
   Coding: 0001089000404040409E00001020002002018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005055
   ROD: EV_MFK3ValeoMQB_005_VN3S.rod
1126400 - Internal Fault
          B200F F4 [00001000] - -
          [Failure_fusion_internal_error]
                    Reset counter: 13
                    Mileage: 206523 km
                    Date: 2026.09.17
                    Time: 12:18:49
1124198 - Development code 1
          B2F01 00 [00001000] - -
          [VZF_Init]
                    Fault Priority: 9
                    Reset counter: 13
                    Mileage: 206523 km
                    Date: 2026.09.17
                    Time: 12:18:44
1124116 - Internal Fault
          B200F F0 [00001000] - -
          [SPI_communication_to_EyeQ_timout]
                    Reset counter: 13
                    Mileage: 206523 km
                    Date: 2026.09.17
                    Time: 12:18:39
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PX-941-LED-V1.clb
   Part No SW: 992 941 571 AG    HW: 992 941 571 A
   Component: LED1L         H17 9104
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_001_VW48.rod
   VCID: 678BB78D8FEC99524A3-8032
135696 - Positioning Motor for Headlamp Range
          C11C0 13 [00100000] - Open Circuit
          [leveling motor - electrical failure OL]
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PX-941-LED-V1.clb
   Component: LED1R         H17 9104
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
End----(Elapsed Time: 01:07, VBatt start/end: 11.9V/11.8V. VIgn 12.0V)-----
------------------------------35 Faults Found------------------------------
