Audi A4 B8 2010 01705 - Selection Switch for Mirror-Adjust (E48)
Bill-A4B8
C?ID=271215
Hi everyone
Just scanned first time my car and found this error. Any advise will be appreciated. I have retro the puddle lights on all doors and about to code them but on first scan on VCDS came up this error and non of the door modules are accessible '' no response from Controller'' :banghead:
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 J HW: 8K0 959 793 E
Component: TSG FA H11 0306
Revision: Serial number: 0000102421931
Coding: 011002204001410001
Shop #: WSC 06325 000 00000
VCID: 479D3578F6096806FF-8012
Reset counter: 217
Mileage: 119679 km
Date: 2016.02.27
Time: 11:44:42
Do you mean none of the OTHER door control modules are accessible? Because clearly 42 is. ;)
Mind posting a complete Auto-Scan please?
Also, when did you retrofit the puddle lights, and did you do a scan prior?
Bill-A4B8
C?ID=271215
Hi Uwe
yes non of the doors modules are accessible. I have done the doors few weeks ago and a lot of people just installed and worked straight. So I thought will work on mine as well but I think I am not that lucky.
I never done any scan before as didn't had the cable which I bought 4 days ago. Here is the full scan
VCDS Version: Release 15.7.4 (x64) Running on Windows 7 x64
Data version: 20160216
Tuesday,15,March,2016,20:55:22:42140
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 55 56 5F 62 72
VIN: WAUZZZ8K3AA102067   Mileage: 119890km-74496miles
Address 01: Engine (------CDHA)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8K1 907 115 C    HW: 8K1 907 115
   Component: 1.8l R4/4V TF H11 0003
   Revision: A5H11---
   Coding: 0104000C18070120
   ASAM Dataset: EV_ECM18TFS8K1907115C A01004
   ROD: EV_ECM18TFS_AU48.rod
   VCID: 2E5360DC71B3D94EDC-807A
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AK    HW: 8K0 907 379 AK
   Component: ESP8 front    H04 0070
   Coding: 010500
   VCID: 020BE46C9DAB8D2E68-8056
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0326
   Coding: 031100
   VCID: 0109EB6098AD963671-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 63
                    Mileage: 117665 km
                    Date: 2015.11.28
                    Time: 17:37:11
   Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
   Component: KLIMA 3 ZONEN H08 0171
   Revision: D0000000    Serial number: 01021220091344
   Coding: 64140000
   VCID: 76E388BCC163A18E54-8022
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H25 0380
   Revision: 09025001    Serial number: 00000000527842
   Coding: 260050914034AF010001000000001D0D001D030800010141000000
   VCID: 3A7B5C8CB5FB05EE70-806E
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 271109  H05 0070
   Coding: 00FD11
   Component: RLS  H04 0003
   Coding: 025028
   Component: E1 - LDS  H08 0090
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EFD07ZZ0-
   Coding: 30363435363030303030554A3052384B3053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 41892B60D02D563631-8014
   Serial number: 6334MSME4D450B77O
   Serial number: 6344MSME4D432370A
   Serial number: 6352QSME19454D34K
   Serial number: 6362QSME0A452000%
   Serial number: 63732SME5345342E$
   Serial number: 63832SME3A465400W
   Revision: --------    Serial number: 90315IL2000NS
   Coding: 000016
   VCID: 3D715790A4D532D655-8068
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 980 L    HW: 8K0 920 980 L
   Component: KOMBIINSTR.   H20 0255
   Revision: 00100000    Serial number: CIW22VTC9
   Coding: 2F04080002002600010000
   VCID: 3B755988BAC13CE66B-806E
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E09B20020A
   Coding: 00C303
   VCID: 52AB142C0D4BDDAE98-8006
   Component: J367-BDM  H06 0170
                    Reset counter: 217
                    Mileage: 119679 km
                    Date: 2016.02.27
                    Time: 11:44:42
   Revision: 00002001    Serial number: 0124495386
   Coding: 011B0622003904400030013280000000
   Part No SW: 8K0 959 792 J    HW: 8K0 959 792 E
   Revision:             Serial number: 0000102382678
   VCID: 4683387CF103710E04-8012
   Revision: 00000003    Serial number: 10000000384828
   VCID: 346772B4979FF39EAA-8060
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06324 000 00000
   VCID: 77FD85B80669D8864F-8022
   Part No SW: 4F0 035 056 B    HW: 4F0 035 056
   Component: Radio U STD   H45 0020
   Revision: AB001007    Serial number: 342LZ097734162
   Coding: 010003020100000001
   VCID: 1F4D8D180E1940C667-804A
   Part No SW: 8T2 035 666 E    HW: 8T2 035 666 E
   Component: H-BN-EU       H45 0047
   Revision: --------    Serial number: 475LZ097540025
   Coding: 01010100010681EC01000B1C000000030001
   Subsystem 1 - Part No: 8R0 060 884 J
   Component: EUR 2010  1005
   Component: DU7 High  H43 0306
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component:   CD-Database  1293
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000102449751
   Coding: 010002204001210001
   VCID: 428B246CDD2B4D2E28-8016
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Revision:             Serial number: 0000102449754
End-------------------------(Elapsed Time: 02:47)--------------------------
Bill-A4B8
C?ID=271215
for all doors same message
I'm confused how this can be. Your Auto-Scan shows all four doors responding:
                    Reset counter: 217
                    Mileage: 119679 km
                    Date: 2016.02.27
                    Time: 11:44:42
So the question is, what's different when you did the Auto-Scan and when you're trying to access the doors individually. I know this sounds silly, but do you have the ignition on when you're trying to access the doors individually?
Bill-A4B8
C?ID=271215
ok I done one scan with key in ignition and second one to be sure with running engine both scan same. but I tried to access the door when engine was running. not sure if that makes a difference?:confused:
I don't think so, but please try with Key On, Engine Off.
PS: Please see How to get Verified. I think you fall into category 2) in that post.
Bill-A4B8
C?ID=271215
I will try in the morning and also get the account verified.
thanks for your help
Bill-A4B8
C?ID=271215
done a third scan today and manage to access door module but I think need help with codes.
(Uwe@filled verification form)
Verified...
I would move this, but it's unclear to me whether it belongs in Car Repair (for the fault code with the mirror switch) or in Retrofits (for the puddle lights).
Bill-A4B8
C?ID=271215
Thanks for quick verification
I have cleared the fault code and rescanned, now there is no error showing up. Now I need help with puddle lights code so I think retrofit will be gud for now.
Maybe it would be cleaner if you started a new thread called "Audi B8 Puddle Lights" in the Retrofit section? Be sure to include an Auto-Scan. The one you posted in this thread earlier will be fine for that purpose.
Bill-A4B8
C?ID=271215
I have cleared the error and new scan not showing any error now. I need help with puddle lights so I think move to retrofit
here I just checked bit 0 and bit 2 (as installed puddle and warning light). but this following error comes up. either I am doing some thing wrong or need codes along with check box ticks
That's not an error per se. It's a warning that the module MIGHT not accept zeros in Importer Number and Equipment Number.
If it were me, I'd click [No] first to see if the module will accept the zeros.
If it doesn't, I'd put 444 in Importer and your ZIP code in Equipment number.
