How to check battery condition
leonardobdes
England
C?ID=661854
I had some reboots on the MMI and communication DTCs, so I decided to look at the state of the battery.
I have updated MMI to the latest version, that may or may not fix the reboots.
I followed this post:
However, I could not get the same information from my car.
The post says higher than 3.6 mOhm, I have 3.6.
Battery lifetime says 20H, so that does not seem correct, as it is the original battery from 2014.
Which metrics should I be using to decide if it is time to change the battery?
I am adding some screenshots from the battery history, and I will also add the text output.
I will also add some data I got that I think may be relevant.
Battery info:
Varta
7P0 915 105 C
12V 92Ah 520 A DIN
850 A EN/SAE/GS
AGM
Saturday,03,October,2026,21:25:54:52314
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.5
VIN: WAUZZZ4G0EN147449   License Plate:
Mileage: 233824km-145291mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F
          62 6D 72 AC
VIN: WAUZZZ4G0EN147449   Mileage: 233824km-145291miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 BD    HW: 04L 907 309
   Component: R4 2.0l TDI   H23 9972
   Revision: 85H23---    CVN: 5497682EC2AAFDD538D3FF82
   Coding: 12254012242401080000
   Shop #: WSC 99999 999 2097151
   ASAM Dataset: EV_ECM20TDI01104L906021BD 004010
   ROD: EV_ECM20TDI01104L906021BD_004.rod
   VCID: 688E594F82FF1EEA4F0-803C
   VINID: 9D196AAAA117015781107104247A20EAA1
   Part No SW: 4G0 927 153     HW: 0CK 927 156 L
   Component: 0CK 20TDI RdW H02 0002
   Revision: --H02---    Serial number: 0000000009 CVN: 85314FAF
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL382021 002009
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 6692577788EB089A7DC-8032
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 06A29F016045F980DB00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A2AD307ACD35C7AE94-806E
   Part No SW: 4H0 907 064 EN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0521
   Coding: 01B93046000000000000
   VCID: 79A80C0BE9D59762A0E-802C
   Serial number: 0214000061547001
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 BB    HW: 4G0 820 043 BB
   Component: KLIMA 2 ZONEN H14 0094
   Serial number: 27031400110731
   Coding: 3422090829
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 609E416F6ACF66AA870-8034
   Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
   Revision: 20012002    Serial number: 00000001724746
   Coding: 2600201040349FE00181008300001D0C0F9DC70827090201000004606100
   VCID: 6E822F57A09BC0DA05C-803A
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 140314  H37 0080
   Serial number:         140318150913
   Coding: 0045F7
   Subsystem 2 - Part No SW: 81A 955 547 B    HW: 81A 955 547
   Serial number: 20304351X81A955547B0
   Coding: 02006C
   Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
   Component: E1 - LDS  H07 0044
   Serial number: 01 04 2014  00001779
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 2FE8CF17000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061409801643
   Coding: 08C308
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71B8342BB125DF2218E-8024
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00HF8KC Dataset Number: 4G0909602H  0002
   Coding: 3032343631324E303235554A305234473053
   VCID: 3632C73798CBB81A0DC-8062
   Serial number: 3575HRB40692FNOG59EU
   Serial number: 3585HRB404V2FL62GGQ4
   Serial number: 3515JRB400O50V9KP1O%
   Serial number: 3525JRB400O50V9KKI7
   Serial number: 3554VRB400850UJCKHJ5
   Serial number: 3564VRB400O50UUO71QN
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20140226000005
   Coding: 000035
   VCID: 303EF12F7A2F962A570-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
   Component: MDieGb        H43 0411
   Revision: 27450259    Serial number: 658010414592004
   Coding: 33A712000B412600010000
   ASAM Dataset: EV_RBC7KMID 004048
   ROD: EV_RBC7KMID.rod
   VCID: 3FDCA213B7F17952DEA-806A
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001335696 Dataset Number: 4G0909515H  0067
   Coding: 00CD074400
   GVL: FDA1C800FC6160030000
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72BA3B27B423E43AE14-8026
   Control module for battery monitoring:
   Serial number: 3620842903
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 14011800000000000582
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA7209DV5I Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3334FE238BB9AD322A2-8066
   Component: TSG FA        H03 0507
   Coding: 011C16004001620002080002
   VCID: 47CCBAF3EFA1319266A-8012
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0028433000 Dataset Number: 4G0909852K  0030
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323AFB2774A3A43A214-8066
   Revision: 00002001    Serial number: 0332045136
   Coding: 013F0622A0B930948320090400010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J245 PS20.008  H02 0007
   Serial number:     WOO2767195B
   Coding: 901E00
   Subsystem 4 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J394 PS20.008  H02 0007
   Serial number:     WOO27691436
   Coding: 801E00
   Revision: CJ007001    Serial number: 00000000090895
   VCID: 1D60389B1DBD0B42EC6-8048
   Component: TSG BF        H03 0507
   Coding: 011C16004401620002080002
   VCID: 46D2B7F7E8AB289A9DC-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H03 0015
   Revision: --------    Serial number: 00000001014314 Dataset Number: 4G0909522D  0007
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D00E85B6D9DFBC27C6-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140403-0002-205
   Coding: 112296101000A300
   ROD: EV_HeadlRegulBasic_AU35.rod
   Part No SW: 4G0 035 192 R    HW: 4G0 035 192 F
   Component: RMC Nav Plus  H55 0840
   Coding: 0101010101415B47082B060301020100000000
   VCID: 3138F42B71259F2258E-8064
   Subsystem 1 - Part No: 8X0 919 884 G
   Component: P24-50-13.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464CY0E2655208
   Subsystem 3 - Part No SW: 4G2 919 610 B    HW: 4G2 919 610 B
   Component: E380 BDT C7  H11 0204
   Serial number: 90349ND2000ZM
                    Reset counter: 70
                    Mileage: 233824 km
                    Date: 2026.10.03
                    Time: 21:17:14
                    Voltage: 14.30 V
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 49C8BCCBF9B5C7E270E-801C
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 087400408 Dataset Number: 4G0909541D  0027
   Coding: 097205C010
   ROD: EV_HDSGAu571_AU57.rod
   VCID: 3530C03B85CDB302046-8060
   Component: TSG HR        H03 0507
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H09 0010
   Revision: 00000000    Serial number: 140620476 Dataset Number: 4G0909571F  0014
   ROD: EV_RDCMA00100.rod
   VCID: 2B04E6435389F5F2622-807E
End----------(Elapsed Time: 02:02, VBatt start/end: 14.6V/14.6V)-----------
-------------------------------1 Fault Found-------------------------------
Tuesday,29,September,2026,21:43:24:52314
Control Module Part Number: 4G0 907 468 AD
  Component and/or Version: J533--Gateway H13 0050
           Software Coding: 00CD074400
            Work Shop Code: WSC 02391
History Data
Record 1/16: No-load voltage underranging
2026-09-27-16:32*00.0*01*00954***
2026-09-16-09:07*18.3*01**
2026-09-15-15:00*24.0*01**
2026-09-14-14:59*24.0*01**
2026-09-12-12:18*00.1*01**
2026-09-12-11:24*00.0*01**
2026-09-07-21:26*05.1*01**
2026-09-06-16:28*00.0*01*00030***
2026-04-25-12:23*00.0*01**
2026-04-25-11:48*00.0*01**
2026-04-25-10:28*00.0*01**
2026-01-08-21:59*00.0*01**
2025-12-30-12:40*00.1*01**
2025-05-14-08:30*12.7*01**
2000-01-01-00:00*00.0*00*00000***
2000-01-01-00:00*00.0*00**
Record 2/16: No-load current overranging
2015-07-22-13:56*0003*030*-01.88*0-1-0-0-0-0*0*01*00004**
2014-06-05-08:59*0001*055*+00.00*0-0-1-0-0-0*0*01**
2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**
Record 3/16: Shut-off stage history
2014-05-21-07:40*4*0*084*066*-11.03*0-0-0-0-0-0*0*0*00.0*00.0**
2014-05-12-15:09*4*0*083*068*-17.50*0-0-0-0-0-0*0*0*00.0*00.0**
2014-05-12-09:56*4*0*085*067*-08.91*0-0-0-0-0-0*0*0*00.0*00.0**
2014-05-12-09:53*4*0*085*068*-25.98*0-0-0-0-0-0*0*0*00.0*00.0**
2014-05-12-09:49*4*0*087*070*-17.39*0-0-0-0-0-0*0*0*00.0*00.0**
2014-05-09-15:25*4*0*084*068*-00.09*0-0-1-0-0-0*0*0*00.0*00.0**
2014-05-09-11:37*4*0*088*069*+00.61*0-0-0-0-0-0*0*0*00.0*00.0**
2014-05-07-07:54*4*0*089*074*-21.76*0-0-0-0-0-0*0*0*00.0*00.0**
2014-05-05-16:09*4*0*087*069*+09.78*0-0-0-0-0-0*0*0*00.0*00.0**
2014-05-05-09:51*4*0*089*069*+04.98*0-0-0-0-0-0*0*0*00.0*00.0**
2014-04-16-19:55*4*0*096*079*+06.25*0-0-0-0-0-0*0*0*00.0*00.0**
2014-04-15-07:01*4*0*091*072*-03.48*0-0-1-0-0-0*0*0*00.0*00.0**
2014-04-15-06:58*4*0*093*073*-22.38*0-0-1-0-0-0*0*0*00.0*00.0**
2014-04-15-06:56*4*0*093*073*-04.32*0-0-1-0-0-0*1*0*00.0*00.0**
2014-04-14-22:00*4*0*083*067*+15.79*0-0-0-0-0-0*0*0*00.0*00.0**
Record 4/16: Battery change history
2014-04-14-00:00*01*092*JCB*34040770X0*10007*25041*0000*0000*0000**
2000-01-01-00:00*00*---*---*----------*09999*00000*0000*0000*0000**
2000-01-01-00:00*00*---*---*----------*00000*00000*0000*0000*0000**
Record 5/16: Energy-critical vehicle states
2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00**
Record 6/16: Energy balances (last 20 trips)
2026-09-29-15:44*045*+22*+001.8*00.13**
2026-09-29-14:42*046*+21*+001.9*00.11**
2026-09-29-10:39*044*+19*+003.2*00.16**
2026-09-29-08:42*049*+18*+001.4*00.20**
2026-09-29-08:20*048*+18*+000.3*00.15**
2026-09-28-20:19*055*+20*+000.9*00.26**
2026-09-28-13:26*062*+19*+000.1*00.00**
2026-09-28-12:11*062*+19*+007.7*01.23**
2026-09-26-16:22*042*+18*+000.3*00.00**
2026-09-26-15:47*044*+17*+000.2*00.00**
2026-09-26-14:31*045*+16*+000.1*00.00**
2026-09-26-09:18*054*+16*+001.1*00.50**
2026-09-24-09:00*047*+16*+000.5*00.25**
2026-09-24-08:37*050*+16*+000.3*00.15**
2026-09-23-17:25*053*+23*+000.3*00.05**
2026-09-23-16:24*054*+23*+000.9*00.31**
2026-09-23-15:34*048*+22*+000.4*00.13**
2026-09-23-15:02*051*+21*+000.9*00.25**
2026-09-23-08:52*047*+20*+000.6*00.18**
2026-09-23-08:32*048*+20*+000.2*00.20**
Record 7/16: Energy balances (last 20 standing times)
2026-09-29-15:53*041*-000.3*004.8*00.0*00.0**
2026-09-29-14:50*040*-001.3*000.8*00.2*00.0**
2026-09-29-10:49*042*-002.1*003.8*00.1*00.0**
2026-09-29-08:54*042*-005.1*001.7*00.3*00.2**
2026-09-29-08:30*048*-002.0*000.2*00.2*00.0**
2026-09-28-20:35*049*-000.8*010.3*00.0*00.0**
2026-09-28-13:26*050*-000.5*006.8*00.0*00.0**
2026-09-28-13:25*062*-000.1*000.0*00.0*00.0**
2026-09-26-16:22*038*-002.2*043.9*00.1*00.0**
2026-09-26-15:48*045*-001.5*000.5*00.0*00.0**
2026-09-26-14:32*044*-002.5*001.1*00.1*00.0**
2026-09-26-09:49*044*-001.8*004.6*00.1*00.0**
2026-09-24-09:16*047*-000.6*030.8*00.0*00.0**
2026-09-24-08:46*046*-000.4*000.2*00.0*00.0**
2026-09-23-17:29*047*-000.4*015.1*00.0*00.0**
2026-09-23-16:43*052*-000.2*000.6*00.0*00.0**
2026-09-23-15:43*046*-000.5*000.6*00.0*00.0**
2026-09-23-15:18*048*-000.3*000.2*00.0*00.0**
2026-09-23-15:17*051*-000.1*000.0*00.0*00.0**
2026-09-23-09:03*048*-000.2*005.9*00.0*00.0**
Record 8/16: Battery manipulation (e.g. charging)
2026-08-17-15:33*1*15*00*00*13*02*00*00*2000-01-01-00:00*01**
2026-08-17-15:12*1*14*00*00*13*02*00*00*2000-01-01-00:00*01**
2026-08-13-17:12*1*13*00*00*13*02*00*00*2000-01-01-00:00*01**
2026-08-13-16:52*1*12*00*00*13*02*00*00*2000-01-01-00:00*01**
2026-08-13-12:01*1*11*00*00*13*02*00*00*2000-01-01-00:00*01**
Record 9/16: Battery aging
2014-05-12-09:48*099*100*088*071*00020*12.60*+14*01*02.90*00000*00000**
2026-09-04-15:42*083*088*070*045*24899*12.40*+23*01*02.95*02809*13753**
2026-08-07-12:57*088*086*087*064*24376*12.60*+26*01*02.95*02736*13449**
2026-07-09-15:14*073*078*077*044*24074*12.50*+27*01*03.00*02683*13137**
2026-06-13-11:47*071*075*071*036*23894*12.40*+16*01*03.10*02655*12919**
2026-05-16-08:38*072*073*064*029*23655*12.30*+09*01*03.05*02605*12524**
2026-04-20-08:37*070*074*076*037*23459*12.50*+11*01*03.10*02571*12254**
2026-03-23-08:33*074*076*074*036*23301*12.40*+07*01*02.95*02543*12056**
2026-02-25-18:09*072*074*073*037*23066*12.40*+12*01*03.05*02499*11769**
2026-01-26-15:02*072*073*068*030*22852*12.40*+06*01*02.95*02469*11608**
2025-12-30-10:26*072*072*073*033*22643*12.40*+04*01*02.95*02444*11479**
2025-12-02-08:33*072*074*071*035*22431*12.40*+10*01*02.90*02401*11256**
Record 10/16: Dynamic energy management
2017-01-18-13:38*1*000.4*0*000.0*0*000.0*00.00**
2000-01-01-00:00*0*000.0*0*000.0*0*000.0*00.00**
2000-01-01-00:00*0*0*0*00.00**
2000-01-01-00:00*0*000.0*00.00**
2026-09-28-12:17*99*15.00*14.64*31.70**
2026-09-18-15:13*99*15.00*14.75*21.70**
2026-09-12-13:59*99*15.00*14.66*31.60**
2026-09-09-12:55*99*15.00*14.74*22.30**
2026-09-09-12:41*99*15.00*14.75*22.40**
Record 11/16: Recuperation
2020-04-24-11:52*000*000*000*000*0000*025*00.0*00.0*075*043*091*058*01*00356*00635*00387*00853*01607**
2020-02-09-11:50*000*000*034*000*0383*043*00.6*01.7*092*062*093*061*01**
2020-02-09-09:53*000*000*082*000*0915*109*01.4*03.4*090*059*093*062*01**
2020-02-09-09:31*000*000*009*000*0053*028*00.2*00.6*092*061*092*061*02**
2020-02-08-14:30*000*000*001*000*0001*000*00.0*00.2*089*060*088*060*01**
2020-02-08-12:12*000*000*020*064*1171*114*02.5*07.6*090*054*091*061*20**
2020-02-08-11:55*000*000*000*008*0071*074*00.1*00.3*077*047*096*063*01**
2019-12-29-13:38*000*000*003*001*0154*008*00.1*01.2*091*066*091*066*04**
2019-12-29-13:25*000*000*002*005*0149*069*00.1*00.7*091*066*091*066*04**
2019-10-24-17:13*000*000*006*000*0220*039*00.2*00.3*081*046*092*056*01**
Record 12/16: Start-Stop
2026-07-15-16:31*2*060*029*+23*01*+30.0*+01.4*12.3*1**
2026-04-04-15:20*2*059*027*+13*02*+30.0*+04.5*13.0*1**
2026-03-09-18:11*2*059*019*+11*02*+30.0*-12.0*11.1*1**
2026-02-26-17:57*2*059*019*+13*02*+30.0*-04.8*11.7*1**
2026-02-24-08:33*2*060*024*+12*02*+30.0*+04.8*14.0*1**
00001*00061*00000**
Record 13/16: Sporadic alternator faults
2000-01-01-00:00*0-0-0-0-0*000.0*00000**
2000-01-01-00:00*0-0-0-0-0*000.0**
Record 14/16: Small battery for hybrid vehicle
2000-01-01-00:00*00*---*---*----------*00000*00000**
2000-01-01-00:00*0*00*00*00*00*00**
00000*00000*00000**
2026-09-29-15:44*0-0-0-0-1-0-0-0**
2026-09-29-14:47*0-0-0-0-1-0-0-0**
00000*00000*00000*00021*00000*00000*00000*00000**
2000-01-01-00:00*0*000*000*00*00000*00000**
00000*00000*00000**
Record 15/16: Local activ.
2000-01-01-00:00*000*00*00*000*00*00*000*00*00**
Record 16/16: Vehicle energy balance
233824**
00478*05672*16009*00284*00006**
06128*00174*00063*00008**
53723*03078*00430*00009**
12022*17555*02766*05190**
22456*10622*04455**
54606*03061*00502*00028**
16277*00065*00005**
00071*00000*00000**
00326*00017*00004**
05626*03035*01917*01424*00982*00788*01410*00423*00290*00627**
02063*02528*02808*04101*09230**
                Address 19: CAN Gateway  (4G0 907 468 AD)
21:41:33
  IDE01833-MAS03159   Battery version-Manufacturer JCI
  IDE01833-MAS04490   Battery version-Size 92 Ah
  IDE01839   Battery charge status 85 %
  IDE01840   Battery condition for display 80 %
  IDE01841   Battery internal resistance 3.6 mOhm
  IDE01842   Usable battery charge 52 Ah
  ENG106155-ENG99338   EM_prcSoh-prc SohP 79 %
  ENG106155-ENG101494   EM_prcSoh-prc SohQ 77 %
21:57:44
  IDE01948   Battery internal resistance not normed 3.4 mOhm
  IDE06747-IDE01841   Battery Monitoring Control Module 2-Battery internal resistance 0.0 mOhm
  IDE06747-IDE01948   Battery Monitoring Control Module 2-Battery internal resistance not normed 0.0 mOhm
22:01:47
  IDE01834   Battery voltage 14.431 V
  IDE01839   Battery charge status 86 %
  IDE01842   Usable battery charge 53 Ah
  IDE03899   Battery monitoring control module: status communication active
Eric
HC800000
If this were my car, I'd be pretty concerned with those no-load voltage under-ranging (record 1) that have been happening in September. On a mostly daily-driven vehicle, that should not happen with a healthy battery and charging system.
Other than that, the battery manager seems to think your battery is pretty OK, but it's entirely possible that with a 12.5 year old battery, the electronics just aren't able to tell the whole story. FWIW 3 of the 4 screenshots you posted for the toolbox are timestamped 2014, so they are not going to tell you anything useful about the current state of things. Look instead at the battery aging record timestamped 2026-09-04-15:42 . But I think the battery manager is overly optimistic, if you're seeing symptoms.
Another thing to consider, you're already getting low voltage now and we've just hit fall. Even if the car is garaged, it's only going to get worse as the ambient temperature gets lower. As someone who got 10 years of their B8 S4 battery, I can totally empathize with seeing how far you can push it; if you do, make sure you carry a jump starter with you. Those Li-Ion ones work really well. I was glad I had mine when my battery died with no warning in September 2025 :) And yes, the battery manager thought I had 60+Ah usable that week :)
leonardobdes
England
C?ID=661854
The car has been parked for most of September, as I was fixing things.
Would that explain the "no-load voltage under-ranging"?
I think I selected other dates in the battery history, but it was all empty.
I will check again tomorrow.
I am not trying to win a competition for the oldest battery, but I also did not want to change it if it was not necessary.
However, based on your feedback and what I read, a 12.5-year-old battery is just a time bomb.
About a jump starter cable, yes, I have 2 cars, each one has one. :D
I helped more people than I had to use for my cars.
Eric
HC800000
Ah, my bad, I thought the lines in Record 6 were actual trips. Yes, if the battery hasn't been significantly charging over the last month, the low voltages are to be expected.
For entertainment value, this is the battery history 8 days before my battery died:
;Wednesday,10,September,2025,13:34:53:05054
;                Address 19: CAN Gateway
;Control Module Part Number: 8R0 907 468 P
;  Component and/or Version: GW-BEM 5CAN-M H11 0060
;           Software Coding: 80C303FF00
;            Work Shop Code: WSC 06325
;                      VCID: CCDB67966FD829F96F-8098
;History Data
2023-12-22-11:04*00.0*01*00876***
2023-12-17-09:06*00.0*01**
2020-11-26-10:56*00.0*01**
2020-11-19-15:04*00.0*01**
2019-11-02-08:27*00.0*01**
2018-03-16-08:35*00.0*01**
2018-01-31-14:05*00.0*01**
2018-03-07-10:12*0005*071*-00.22*0-0-0-0-0-0*0*01*00005**
2018-03-07-16:04*1*0*081*070*-00.73*0-0-0-0-0-0*0*0*00.0*00.1**
2015-09-28-16:54*4*0*070*072*-14.10*0-0-0-0-0-0*0*0*00.0*00.0**
2015-08-01-18:06*4*0*083*087*-22.32*0-0-0-0-0-0*0*0*00.0*00.0**
2015-07-14-17:45*4*0*080*084*-19.11*0-0-0-0-0-0*0*0*00.0*00.0**
2015-07-14-15:26*4*0*085*090*-33.40*0-0-0-0-0-0*0*0*00.0*00.0**
2015-07-14-01:43*4*0*087*092*-39.46*0-0-0-0-0-0*0*0*00.0*00.0**
2015-07-10-19:00*4*0*091*097*-20.73*0-0-0-0-0-0*0*0*00.0*00.0**
2015-07-10-18:44*4*0*088*092*-27.97*0-0-0-0-0-0*0*0*00.0*00.0**
2015-06-30-15:00*4*0*089*094*-47.67*0-0-0-0-0-0*0*0*00.0*00.0**
2015-06-29-20:54*4*0*089*093*-00.93*0-0-0-0-0-0*0*0*00.0*00.0**
2015-06-24-19:53*4*0*091*097*-50.53*0-0-0-0-0-0*0*0*00.0*00.0**
2015-06-10-14:33*4*0*092*094*-26.63*0-0-0-0-0-0*0*0*00.0*00.0**
2015-06-09-06:21*4*0*094*095*-14.02*0-0-0-0-0-0*0*0*00.0*00.0**
2015-06-08-08:52*4*0*092*092*-14.14*0-0-1-0-0-0*0*0*00.0*00.0**
2015-06-08-07:52*4*0*095*096*-20.77*0-0-0-0-0-0*0*0*00.0*00.0**
2015-05-29-05:00*01*8K0915105F *MLA*150515F9HO*10009*08648*0000*0000*0000**
2000-01-01-00:00*00*-----------*XXX*----------*09999*00000*0000*0000*0000**
2000-01-01-00:00*00*-----------*XXX*----------*00000*00000*0000*0000*0000**
2025-09-10-12:22*043*+26*+001.1*00.65**
2025-09-10-10:57*038*+25*+001.3*00.63**
2025-09-10-07:49*033*+26*+002.0*00.57**
2025-09-09-18:17*030*+27*+000.5*00.10**
2025-09-09-14:35*031*+26*+000.4*00.12**
2025-09-09-11:16*030*+25*+000.4*00.12**
2025-09-09-11:00*031*+25*+000.5*00.14**
2025-09-09-09:43*032*+25*+001.0*00.23**
2025-09-09-09:22*031*+25*+000.6*00.13**
2025-09-08-19:51*032*+25*+000.6*00.12**
2025-09-08-15:55*037*+25*+000.5*00.13**
2025-09-07-17:24*037*+28*+000.0*00.01**
2025-09-07-16:59*039*+28*+001.5*00.25**
2025-09-07-16:28*036*+28*+000.0*00.01**
2025-09-07-13:21*039*+28*+000.2*00.11**
2025-09-07-12:57*040*+28*+000.8*00.31**
2025-09-07-11:45*037*+29*+001.0*00.31**
2025-09-07-11:18*035*+29*+000.4*00.09**
2025-09-07-10:34*036*+29*+000.5*00.26**
2025-09-06-16:38*039*+32*+000.5*00.22**
2025-09-10-11:35*029*-000.5*000.7*00.0*00.0**
2025-09-10-08:24*031*-000.6*002.5*00.0*00.0**
2025-09-09-18:23*029*-000.8*013.4*00.0*00.0**
2025-09-09-14:42*023*-000.5*003.5*00.0*00.0**
2025-09-09-11:23*028*-000.6*003.1*00.0*00.0**
2025-09-09-11:09*031*-000.2*000.1*00.0*00.0**
2025-09-09-09:57*031*-000.5*001.0*00.0*00.0**
2025-09-09-09:30*030*-000.4*000.2*00.0*00.0**
2025-09-08-19:58*029*-000.8*013.4*00.0*00.0**
2025-09-08-16:03*031*-000.6*003.7*00.0*00.0**
2025-09-07-17:25*034*-000.7*021.7*00.0*00.0**
2025-09-07-17:14*038*-000.3*000.1*00.0*00.0**
2025-09-07-16:29*036*-001.2*000.4*00.0*00.0**
2025-09-07-13:28*031*-000.2*000.8*00.0*00.0**
2025-09-07-13:16*039*-000.2*000.0*00.0*00.0**
2025-09-07-12:04*029*-000.6*000.8*00.0*00.0**
2025-09-07-11:23*033*-000.5*000.3*00.0*00.0**
2025-09-07-10:50*028*-000.5*000.4*00.0*00.0**
2025-09-06-16:52*033*-000.6*013.2*00.0*00.0**
2025-09-06-14:28*039*-000.5*002.1*00.0*00.0**
2025-09-10-13:25*1*99*00*00*02*05*2000-01-01-00:00*01**
2025-08-22-17:41*1*99*00*00*02*05*2000-01-01-00:00*01**
2025-08-15-18:28*1*99*00*00*02*05*2000-01-01-00:00*01**
2025-08-15-17:23*1*99*00*00*02*05*2000-01-01-00:00*01**
2025-08-14-13:54*1*99*00*00*02*05*2000-01-01-00:00*01**
2015-05-29-06:25*100*100*092*091*00003*12.70*+24*01*12.70*00000*00000**
2025-08-20-17:23*051*039*084*041*08579*12.60*+28*01*12.70*00000*00000**
2025-07-23-15:26*052*041*084*043*08551*12.60*+28*01*12.70*00000*00000**
2025-06-26-15:20*052*042*086*044*08473*12.60*+29*01*12.70*00000*00000**
2025-05-27-18:44*049*042*079*037*08399*12.50*+22*01*12.70*00000*00000**
2025-04-30-13:46*052*044*095*050*08321*12.70*+25*01*12.70*00000*00000**
2025-04-02-13:17*052*044*096*048*08269*12.70*+18*01*12.70*00000*00000**
2025-03-04-13:03*052*041*097*047*08173*12.80*+11*01*12.70*00000*00000**
2025-02-07-11:29*051*043*100*046*08116*12.80*+08*01*12.70*00000*00000**
2025-01-06-12:47*050*044*100*044*08049*12.80*+06*01*12.70*00000*00000**
2024-12-05-14:17*052*044*084*040*08015*12.60*+12*01*12.70*00000*00000**
2024-11-08-10:20*052*046*083*042*07965*12.60*+20*01*12.70*00000*00000**
2000-01-01-00:00*0*000.0*0*000.0*00.00**
2025-04-13-13:06*99*15.00*14.82*005.3**
2025-04-13-11:39*99*15.00*14.80*010.9**
2025-04-13-11:18*99*15.00*14.80*007.6**
2025-04-09-11:01*99*15.00*14.83*003.9**
2025-03-23-11:55*99*15.00*14.82*004.8**
2016-07-19-09:07*000*000*005*000*0045*006*00.2*00.4*090*094*091*093*01*00017*00037*00017*00042*00068**
2016-07-18-17:51*000*002*006*000*0060*009*01.0*00.6*092*095*091*094*01**
2016-07-11-15:13*000*000*001*000*0000*001*00.1*00.1*091*095*091*093*01**
2016-06-28-13:13*000*002*006*000*0100*010*01.1*00.8*091*094*091*095*01**
2016-06-18-18:49*000*000*002*000*0032*003*00.0*00.4*089*091*089*089*01**
2016-06-18-17:59*000*000*011*015*0235*057*00.0*00.6*090*088*090*091*01**
2016-06-15-09:45*000*000*001*000*0001*001*00.0*00.1*089*087*089*087*01**
2016-06-15-09:32*000*000*000*000*0000*000*00.0*00.0*090*089*090*089*01**
2016-06-15-09:25*000*000*003*001*0074*029*00.0*00.1*090*086*091*090*01**
2016-06-13-17:17*000*000*001*020*0216*052*00.0*00.8*090*084*091*090*01**
2000-01-01-00:00*0-0-0-0-0-0-0-0**
00000*00000*00000*00000*00000*00000*00000*00000**
2025-09-10-12:22*1*082*029*+25*07*-030*-29.16*10.0*0**
2025-09-10-10:57*1*073*031*+25*07*-030*-27.49*10.0*0**
2025-09-10-07:49*1*068*029*+26*08*-030*+05.21*10.0*0**
2025-09-09-18:17*1*069*023*+27*08*-030*+27.32*10.3*0**
2025-09-09-14:35*1*070*028*+25*08*-030*-27.01*10.1*0**
11073*00031*00000**
00000*00000*00000**
2000-01-01-00:00*0*000*+00*00*00000*00000**
00000*00000*00000**
2019-02-03-11:23*001*02*00*000*00*00*000*00*00**
2017-09-14-08:35*001*01*00*000*00*00*000*00*00**
105238**
02536*05957*03406*00017*00000**
10644*00098*00162*00265**
21443*13090*00088*00000**
00563*05736*02307*02497**
06043*03837*01223**
14580*00977*00346*00215**
04321*00007*00001**
00000*00000*00000**
00009*00002*00000**
00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**
No recent low voltage and about 40Ah available. It died at 8674 hours.
  • Informative
leonardobdes
England
C?ID=661854
I was playing a little bit more today with the battery screen, and now it makes more sense.
My battery lifetime is 25 042 hours, and you said yours died at 8 674 hours.
The link I posted says to change the battery after 10 000 hours.
However, the post does not say whether it is for batteries installed close to the engine or in the boot/trunk.
As I read, it makes sense that batteries installed close to the engine last less time because of the heat from the engine.
Anyway, my conclusion is that it is a good idea to change this battery.
It has worked enough, it is time to retire.
Thanks for your help with this.
TTT
C?ID=547002
WHy not post an channel map for measuring blocks and admap, maybe we can find SoH in it?
leonardobdes
England
C?ID=661854
Ok, I will try to get that tomorrow.
leonardobdes
England
C?ID=661854
Ok, so the channel map is just a dump of all options and values from adaptations and measuring blocks.
The only thing I found in the files with "soh" or "state of health" was these fields that I already posted here.
ENG106155-ENG99338,EM_prcSoh-prc SohP,82, %
ENG106155-ENG101494,EM_prcSoh-prc SohQ,79, %
Initial values were:
As I said above, the car was parked most of September, but I drove the car a little bit before the new values.
;SW:4G0-907-468-AD   HW:4G0-907-468-AC ---  19: CAN Gateway
;Component:J533--Gateway H13 0050, Coding:00CD074400
;EV_GatewPkoUDS,001019,EV_GatewPkoUDS_001_AU57.rod
;Monday,05,October,2026,22:18:36:52314
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 72BA3B27B423E43AE14-8026
IDE00859-Counter of sporadic MOST-ring disruptions,0 ,3
IDE00860-Timer of sporadic MOST-ring disruptions,15000 ,3
IDE01211-Static current measuring mode,not active ,1
IDE01457-Energy management: shut-off stage,- ,1
IDE01847-Auxiliary heater activation restriction request-,- ,2
IDE01847-ENG100234-Auxiliary heater activation restriction request-park_heater_target_time,not active ,2
IDE01862-Switch-over LIN flash mode,normal ,1
IDE01863-MOST light performance,Decrease 0 dB ,1
IDE02200-Component protection showroom mode,not active ,1
IDE03256-IDE00010-Battery adaptation-Serial number,34040770X0 ,12
IDE03256-MAS03159-Battery adaptation-Manufacturer,JCB ,12
IDE03256-MAS04490-Battery adaptation-Size,92 Ah ,12
IDE03902-Automatic ring break diagnostic,No automatic start ,1
IDE03903-Production process data 1,00 00 00 00 ,4
IDE03904-Production process data 2,00 00 FF FF ,4
IDE03905-Production process data 3,00 00 00 3C ,4
IDE04159-Deactivation of start/stop function,OFF ,1
IDE06417-IDE00010-Battery adaptation 2-Serial number,---------- ,12
IDE06417-MAS03159-Battery adaptation 2-Manufacturer,Unknown ,12
IDE06417-MAS04490-Battery adaptation 2-Size,Unknown ,12
IDE06425-Dynamometer mode: functional,0 ,1
IDE06748-Break recommendation,not active ,1
IDE06753-ENG152429-Efficiency program display-Air Conditioning,Yes ,4
IDE06753-ENG152436-Efficiency program display-Auxiliary heating,Yes ,4
IDE06753-ENG152461-Efficiency program display-Fahrstufe D verwenden,No ,4
IDE06753-ENG152460-Efficiency program display-Gaspedal im Stand nicht betätigen,Yes ,4
IDE06753-ENG152482-Efficiency program display-Klima Ein Fenster schliessen,Yes ,4
IDE06753-ENG152484-Efficiency program display-Klima Ein Fenster und Schiebedach,Yes ,4
IDE06753-ENG152483-Efficiency program display-Klima Ein Schiebedach schliessen,Yes ,4
IDE06753-ENG152485-Efficiency program display-Klima Ein Verdeck offen,Yes ,4
IDE06753-ENG152432-Efficiency program display-Left heated seat,Yes ,4
IDE06753-ENG152434-Efficiency program display-Left seat ventilation,Yes ,4
IDE06753-ENG152478-Efficiency program display-LuftWD Fenster u Schiebedachsc,Yes ,4
IDE06753-ENG152476-Efficiency program display-LuftWD Fensterschliessen,Yes ,4
IDE06753-ENG152477-Efficiency program display-LuftWD Schiebedachschliessen,Yes ,4
IDE06753-ENG152437-Efficiency program display-Mirror heater,Yes ,4
IDE06753-ENG152431-Efficiency program display-Motorbremse,Yes ,4
IDE06753-ENG152458-Efficiency program display-Motorstart ohne Gaspedal,Yes ,4
IDE06753-ENG152459-Efficiency program display-Motorwarmlauf vermeiden,Yes ,4
IDE06753-ENG152472-Efficiency program display-Nebel_Scheinwerfer,No ,4
IDE06753-ENG152473-Efficiency program display-Nebel_Schlussleuchte,Yes ,4
IDE06753-ENG152427-Efficiency program display-Rear window defogger,Yes ,4
IDE06753-ENG152433-Efficiency program display-Right heated seat,Yes ,4
IDE06753-ENG152435-Efficiency program display-Right seat ventilation,Yes ,4
IDE06753-ENG152479-Efficiency program display-Schaltanzeige beachten,Yes ,4
IDE06753-ENG152475-Efficiency program display-Sitzheizung_Sitzlueftung_im_Fond,No ,4
IDE06753-ENG152474-Efficiency program display-Standheizung_Verbrauch,Yes ,4
IDE06753-ENG152481-Efficiency program display-Start-Stopp einschalten,Yes ,4
IDE06753-ENG152480-Efficiency program display-Start-Stopp nutzen,Yes ,4
IDE06753-ENG152430-Efficiency program display-Steering wheel heating,Yes ,4
IDE06753-ENG152426-Efficiency program display-Windshield defogger,Yes ,4
IDE08528-MAS07123-Service-key: extended settings-Distance for activation,50 km,3
IDE08528-MAS07124-Service-key: extended settings-Lower speed threshold,40 km/h,3
IDE08528-MAS07125-Service-key: extended settings-Upper speed threshold,100 km/h,3
MAS00468-Unlearning counter,73 ,1
ENG105057-Activate_ECU_Monitor,active ,1
ENG105321-ENG101306-BEM KM Boundary Setting-qrsmode_deactivation_border_BEM KM Boundary Setting,100 ,6
ENG105321-ENG103942-BEM KM Boundary Setting-transportmode_deactivation_border_BEM KM Boundary Setting,50 ,6
ENG113394-EPS Leistungsanforderung neu,- ,1
ENG106577-Flexray Tx-Konflikt Detection,active ,1
ENG113395-Hybrid_Zustart,- ,1
ENG110998-Lokal Aktiv Chronik,not active ,1
ENG107871-ENG98417-NWDF Control-Anpassung,not active ,3
ENG107871-ENG103325-NWDF Control-NWDF-Bit,1 ,3
ENG107871-ENG101466-NWDF Control-NWDF-QBit,1 ,3
ENG108152-ENG99814-Parametrization_ECU_Monitor-AdaptiveOpenFilter_CountDelay,1800 s,43
ENG108152-ENG101074-Parametrization_ECU_Monitor-AdaptiveOpenFilterTime,6000 s,43
ENG108152-ENG102686-Parametrization_ECU_Monitor-Max_MMI_Off_Time,11 s,43
ENG108152-ENG99272-Parametrization_ECU_Monitor-Max_MMI_On_Time,1800 s,43
ENG108152-ENG99340-Parametrization_ECU_Monitor-Max_MMI_Standby_Time,90 s,43
ENG108152-ENG100899-Parametrization_ECU_Monitor-Max_MOST_Shutdowm_Query_Time,3 s,43
ENG108152-ENG100287-Parametrization_ECU_Monitor-Max_Num_Car_WakeUp_Events,10 ,43
ENG108152-ENG99074-Parametrization_ECU_Monitor-Max_Num_Keeping_Awake_Events,100 ,43
ENG108152-ENG103057-Parametrization_ECU_Monitor-Max_Num_Logical_WakeUp_Events,40 ,43
ENG108152-ENG104006-Parametrization_ECU_Monitor-Max_Num_Physical_WakeUp_Events,10 ,43
ENG108152-ENG103606-Parametrization_ECU_Monitor-Max_Time_Clamp15_Off_To_Shutdown_Query.,1901 s,43
ENG108152-ENG101206-Parametrization_ECU_Monitor-Max_Time_Light_On_After_Shutdown_Execute,3 s,43
ENG108152-ENG103242-Parametrization_ECU_Monitor-Max_Time_Shutdown_Query_To_Shutdown_Query,13 s,43
ENG108152-ENG101904-Parametrization_ECU_Monitor-Open_Filter_Wake_Time,60 s,43
ENG108152-ENG103852-Parametrization_ECU_Monitor-Sample_Time_Keeping_Awake_Events,12 s,43
ENG108152-ENG103196-Parametrization_ECU_Monitor-WakeUp_Monitor_Start_Delay,0 ms,43
ENG122797-ENG122802-Service_Key_Entwicklung-Retrycounter_Nrc,3 ,2
ENG122797-ENG122801-Service_Key_Entwicklung-Retrycounter_Timeout,3 ,2
ENG101693-Set_Diagnostic_Baudrate,500 kBaud ,1
ENG109015-ENG101259-Spiegelung von CCP / Entwicklungsbotschaften-messagetyp_Spiegelung von CCP / Entwicklungsbotschaften,Mirroring_of_all_CAN_messages ,2
ENG109015-ENG100981-Spiegelung von CCP / Entwicklungsbotschaften-source-bus_Spiegelung von CCP / Entwicklungsbotschaften,No_mirroring ,2
ENG109395-ENG101403-Testing Display BEM-alternator_diagnosis_Testing Display BEM,- ,4
ENG109395-ENG102609-Testing Display BEM-batterie_diagnosis_Testing Display BEM,- ,4
ENG109395-ENG101924-Testing Display BEM-batterie_status_Testing Display BEM,- ,4
ENG109395-ENG103309-Testing Display BEM-mmi_prewarning_Testing Display BEM,- ,4
Elapsed Time: 00:14
;Monday,05,October,2026,22:17:55:52314
Group,Description,Actual
IDE00018,Voltage terminal 15,11.8, V
IDE00019,Voltage terminal 30,11.7, V
IDE00056,History data 1,||2026-10-03-20:54*00.6*01*00955***
2026-09-27-16:32*00.0*01**
2000-01-01-00:00*00.0*00**|,
IDE00057,History data 2,||2015-07-22-13:56*0003*030*-01.88*0-1-0-0-0-0*0*01*00004**
2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**|,
IDE00058,History data 3,||2014-05-21-07:40*4*0*084*066*-11.03*0-0-0-0-0-0*0*0*00.0*00.0**
2014-04-14-22:00*4*0*083*067*+15.79*0-0-0-0-0-0*0*0*00.0*00.0**|,
IDE00059,History data 4,||2014-04-14-00:00*01*092*JCB*34040770X0*09996*25104*0000*0000*0000**
2000-01-01-00:00*00*---*---*----------*00000*00000*0000*0000*0000**|,
IDE00060,History data 5,||2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00**
2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00**|,
IDE00061,History data 6,||2026-10-05-15:26*061*+19*+001.0*00.18**
2026-10-05-15:01*059*+19*+001.0*00.13**
2026-10-05-13:03*057*+17*+001.7*00.21**
2026-10-05-12:39*053*+16*+003.1*00.20**
2026-10-03-20:55*059*+22*+013.9*00.60**
2026-10-03-14:15*047*+17*+000.0*00.01**
2026-10-02-23:42*052*+26*+004.4*00.75**
2026-10-02-22:32*049*+26*+022.8*00.51**
2026-09-29-20:42*053*+26*+006.1*01.41**
2026-09-26-14:31*045*+16*+000.1*00.00**|,
IDE00062,History data 7,||2026-10-05-15:10*056*-000.3*000.2*00.0*00.0**
2026-10-05-13:16*054*-000.3*001.7*00.0*00.0**
2026-10-05-12:52*051*-000.3*000.1*00.0*00.0**
2026-10-03-21:31*047*-006.5*034.1*00.3*00.2**
2026-10-03-14:17*039*-014.8*006.5*00.6*00.4**
2026-10-03-00:28*046*-000.3*013.8*00.0*00.0**
2026-10-02-23:04*044*-000.5*000.6*00.0*00.0**
2026-09-29-22:08*018*-025.5*062.6*01.0*00.9**
2026-09-26-09:49*044*-001.8*004.6*00.1*00.0**|,
IDE00063,History data 8,||2026-08-17-15:33*1*15*00*00*13*02*00*00*2000-01-01-00:00*01**
2026-08-13-12:01*1*11*00*00*13*02*00*00*2000-01-01-00:00*01**|,
IDE00064,History data 9,||2014-05-12-09:48*099*100*088*071*00020*12.60*+14*01*02.90*00000*00000**
2026-10-01-20:31*075*079*078*046*25042*12.50*+19*01*02.95*02826*13888**
2025-12-30-10:26*072*072*073*033*22643*12.40*+04*01*02.95*02444*11479**|,
IDE00065,History data 10,||2017-01-18-13:38*1*000.4*0*000.0*0*000.0*00.00**
2026-10-03-21:09*99*15.00*14.56*42.90**
2026-10-02-22:52*99*15.00*14.49*49.50**
2026-09-12-13:59*99*15.00*14.66*31.60**|,
IDE00066,History data 11,||2020-04-24-11:52*000*000*000*000*0000*025*00.0*00.0*075*043*091*058*01*00356*00635*00387*00853*01607**
2019-10-24-17:13*000*000*006*000*0220*039*00.2*00.3*081*046*092*056*01**|,
IDE00067,History data 12,||2026-07-15-16:31*2*060*029*+23*01*+30.0*+01.4*12.3*1**
00001*00061*00000**|,
IDE00068,History data 13,||2000-01-01-00:00*0-0-0-0-0*000.0*00000**
2000-01-01-00:00*0-0-0-0-0*000.0**|,
IDE00069,History data 14,||2000-01-01-00:00*00*---*---*----------*00000*00000**
00000*00000*00000**
2026-10-05-15:28*0-0-0-0-1-0-0-0**
2026-10-05-13:12*0-0-0-0-1-0-0-0**
00000*00000*00000*00025*00000*00000*00000*00000**
00000*00000*00000**|,
IDE00070,History data 15,||2000-01-01-00:00*000*00*00*000*00*00*000*00*00**
2000-01-01-00:00*000*00*00*000*00*00*000*00*00**|,
IDE00071,History data 16,||233847**
00478*05684*16013*00285*00006**
06133*00174*00065*00009**
53755*03079*00430*00009**
12028*17562*02767*05190**
22462*10626*04459**
54633*03064*00504*00029**
16283*00066*00006**
00071*00000*00000**
00326*00017*00004**
05629*03037*01917*01424*00982*00788*01410*00423*00290*00627**
02067*02529*02808*04102*09239**|,
IDE00102,Control Module temperature,32, °C
IDE00276,Position in MOST Ring,02,
IDE01803,History data 17,||2000-01-01-00:00*0000*00*0**
0*0000*0000*00*00*0000*00**
0000*00*0000*00*0000*0000**
2000-01-01-00:00*+000*0000*000*0000*00*0000*00**
2000-01-01-00:00*+000*0000*000*0000*00*0000*00**|,
IDE01807,History data 21,||17841*2024-03-28-18:57*0001.1*5f*0000.6*00*0000.0*00*0000.0*00*0000.0*00*0000.0**
17617*2024-02-15-19:09*0001.0*5f*0000.5*00*0000.0*00*0000.0*00*0000.0*00*0000.0**
15092*2023-01-12-19:05*0000.8*5f*0000.3*00*0000.0*00*0000.0*00*0000.0*00*0000.0**
10556*2021-03-08-13:26*0000.3*09*0000.3*00*0000.0*00*0000.0*00*0000.0*00*0000.0**
06716*2019-02-25-10:00*0000.5*17*0000.5*53*0000.5*42*0000.5*52*0000.5*08*0000.5**|,
IDE01808,History data 22,||19*00007*09*00006*05*00006*17*00005*42*00004*52*00004*01*00001*02*00001*53*00001*16*00001**|,
IDE01809,History data 23,||23375*2026-09-07-21:28*0081.0*K*00042*06e1*0*06e3*1*06e1*0*06e2*1*0003*0**
15800*2023-05-07-11:08*0005.2*K*00045*06f6*0*06e1*1*06e2*1*06c7*0*06e3*1**
01971*2015-07-12-11:03*0013.9*K*00046*06ec*0*06e1*1*06e0*0*06e2*1*06e3*1**
00000*2000-00-00-00:00*0000.0*0*00000*0000*0*0000*0*0000*0*0000*0*0000*0**
00000*2000-00-00-00:00*0000.0*0*00000*0000*0*0000*0*0000*0*0000*0*0000*0**|,
IDE01810,History data 24,||23390*2026-09-12-13:35*0068.2*K*00044*000006e0*003*000006e1*003*000006e3*002*00000000*000*00000000*000**
23390*2026-09-12-11:47*0066.4*K*00020*000006e2*005*000006e0*004*000006e3*003*000000ff*002*000006e1*001**
23375*2026-09-07-21:32*0081.1*K*00052*000006e0*007*000000ff*004*000006e3*003*000006e1*002*00000000*000**
23375*2026-09-04-19:07*0006.7*K*00024*000006e3*003*000006e0*002*000006e2*001*000006e1*001*00000000*000**
23271*2026-08-28-17:55*0000.9*K*00034*000006e0*010*000006f8*008*000006e1*005*000000ff*002*000006c2*002**|,
IDE01811,History data 25,||00019*2014-05-21-08:15*0000.0**
00001*2014-04-14-21:15*0000.0**
00000*2014-04-14-21:02*0000.0**
00000*2000-00-00-00:00*0000.0**|,
IDE01812,History data 26,||65535*08360*04665*00057*49146*00000*05079*00913**|,
IDE01813,History data 27,||65535*03741*11196*62746*00000*00000*07562**|,
IDE01814,History data 28,||51875*00000*00000*51875*00000**|,
IDE01815,History data 29,||00001*00000*00000*00000*00001*00000*00000*00000**|,
IDE01816,History data 30,||00003*00000*00001*00002*00000*00000*00000**|,
IDE01817,History data 31,||00001*00000*00000*00001*00000**|,
IDE01818,History data 32,||23505*2026-10-05-21:56*0006.3*06e1*1**
23505*2026-10-05-21:55*0006.2*06c7*0**
23505*2026-10-05-15:38*0000.0*06e1*0**
23504*2026-10-05-15:26*0000.2*06c7*0**
23504*2026-10-05-15:26*0000.2*06e2*1**|,
IDE01819,History data 33,||23499*2026-10-04-17:21*0018.3*000006e2*K**
23499*2026-10-04-17:20*0018.3*000000ff*M**
23499*2026-10-03-21:33*0000.0*000006e3*K**
23495*2026-10-03-16:22*0000.0*000006e0*K**
23493*2026-10-03-16:14*0001.8*000006e0*K**|,
IDE01820,History data 34,||23505*2026-10-05-21:56*0006.3*06e1**
23504*2026-10-05-15:26*0000.2*06e2**
23504*2026-10-05-15:26*0000.2*06e3**
23504*2026-10-05-15:10*0000.0*06e2**
23501*2026-10-05-13:03*0000.1*06e2**|,
IDE01821,History data 35,||00003*04236*00009*00000*00003*00000*00000*00001*00273**|,
IDE01822,History data 36,||23499*2026-10-03-21:35*0000.0*00000*00092*00017*00000*00000*00000*00000**
23497*2026-10-03-16:56*0000.0*00000*00102*00021*00000*00000*00000*00000**
23495*2026-10-03-16:22*0000.0*00000*00000*00022*00000*00000*00000*00000**
23493*2026-10-03-15:53*0001.5*00000*00000*00025*00000*00000*00000*00000**
23492*2026-10-03-00:30*0000.0*00000*00102*00000*00000*00000*00000*00000**|,
IDE01823,History data 37,23506*2014-04-14-21:02*0000.0*0000.3**,
IDE01827,Specified generator voltage,10.6, V
IDE01828,Generator DF Signal,0.025, %
IDE01829,Generator exciter current,0.000, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,electrically OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Valeo GmbH,
IDE01831-MAS04490,Generator variant-Size,---,
IDE01831-ENG113380,Generator variant-alternator identification_regulator,4,
IDE01831-ENG113379,Generator variant-alternator manufacture_regulator,Infineon Technologies AG,
IDE01833-MAS03159,Battery version-Manufacturer,JCI,
IDE01833-MAS04490,Battery version-Size,92 Ah,
IDE01834,Battery voltage,11.998, V
IDE01835,Battery current filtered,-24.400, A
IDE01836,Battery current,-24.498, A
IDE01837,Temperature of battery sensor,23, °
IDE01838,Battery temperature,22, °
IDE01839,Battery charge status,71, %
IDE01840,Battery condition for display,70, %
IDE01841,Battery internal resistance,3.4, mOhm
IDE01842,Usable battery charge,37, Ah
IDE01843,Battery voltage at rest,12.4, V
IDE01844,request idle speed increase,not active,
IDE01845,Reduce internal fan request,not active,
IDE01846,Static current shut-off stage,not active,
IDE01847,Auxiliary heater activation restriction request,-,
IDE01847-ENG100234,Auxiliary heater activation restriction request-park_heater_target_time,not active,
IDE01848,Energy balance of last driving cycle,0.0, Ah
IDE01849,Duration of last driving cycle,0.00, H
IDE01850,Overall energy balance,9996.2, Ah
IDE01851,Entire energy throughput,25104.7, Ah
IDE01852,Static current measurement: result,0.01, A
IDE01853,Static current measurement: status,Measurement end,
IDE01854,Energy reclamation request,not active,
IDE01855,Generator current,0.0, A
IDE01856,Battery acid stratification,0, %
IDE01864-MAS03173,Status of current bus communication-Powertrain data bus,active,
IDE01864-MAS03174,Status of current bus communication-Comfort data bus,active: local wakeup event,
IDE01864-MAS03175,Status of current bus communication-Extended data bus,active,
IDE01864-MAS03176,Status of current bus communication-Display and control head databus,active,
IDE01864-MAS03177,Status of current bus communication-Infotainment data bus,active,
IDE01864-MAS03178,Status of current bus communication-Suspension data bus,not installed,
IDE01864-MAS03179,Status of current bus communication-Local data bus 2,not installed,
IDE01864-MAS03180,Status of current bus communication-Local data bus,active,
IDE01864-MAS03181,Status of current bus communication-Flexray databus,active,
IDE01864-MAS07380,Status of current bus communication-Data bus Sensor/Hybrid,Bus sleep mode,
IDE01865-MAS03182,Status flex ray communication-Branch 1,active,
IDE01865-MAS03183,Status flex ray communication-Branch 2,active,
IDE01865-MAS03184,Status flex ray communication-Branch 3,active,
IDE01865-MAS03185,Status flex ray communication-Branch 4,active,
IDE01865-MAS03186,Status flex ray communication-Branch 5,not installed,
IDE01865-MAS03187,Status flex ray communication-Branch 6,not installed,
IDE01865-MAS03188,Status flex ray communication-Branch 7,not installed,
IDE01865-MAS03189,Status flex ray communication-Branch 8,not installed,
IDE01866,MOST system condition,Configuration OK,
IDE01867-IDE01863,MOST hardware parameter-MOST light performance,Decrease 0 dB,
IDE01867-MAS03121,MOST hardware parameter-Ring break diagnostic line status,1,
IDE01867-MAS03122,MOST hardware parameter-Ring break diagnostic line voltage,25.5, V
IDE01867-ENG100178,MOST hardware parameter-HW Instance (MP1-4)_MOST hardware value,0,
IDE01868,Ring break diagnostic result,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE01948,Battery internal resistance not normed,3.6, mOhm
IDE01979,Stored key for component protection participants,05 81 48 00 20 40 00 00 00 00,
IDE01980,Component protection participant currently wrongly authent.,00 00 00 00 00 00 00 00 00 00,
IDE01981,Comp. protect participant occasionally wrongly authent.,00 00 00 00 00 00 00 00 00 00,
IDE01982,Transport protocol used for component protection,01 01 40 00 00 00 00 00 00 00,
IDE01983,Number of successfully repaired keys,0,
IDE01984,Number of successful key downloads,0,
IDE01985-ENG101043,FAZIT identification test sum-Checksum,91 E3 EB 89,
IDE01985-ENG99027,FAZIT identification test sum-Version,1,
IDE01992-ENG100904,Installation list: current installations-ECUs present,|ECU present Bit 0,ECU present Bit 1,ECU present Bit 2,ECU present Bit 3,ECU present Bit 4,ECU present Bit 5,ECU present Bit 6,ECU present Bit 7|reachable,not reachable,reachable,reachable,reachable,reachable,reachable,reachable|reachable,not reachable,not reachable,not reachable,not reachable,reachable,not reachable,reachable|not reachable,not reachable,not reachable,reachable,not reachable,not reachable,reachable,reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,reachable,reachable,reachable,reachable,reachable,reachable|reachable,not reachable,not reachable,not reachable,not reachable,reachable,reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,reachable,reachable,not reachable|reachable,reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|,
IDE01993-ENG103664,Control module reference number-ECU IDs,|ECU ID,ECM name|01,Engine Electronics|02,Transmission Electronics|03,Brake electronics|03,Brake electronics|04,Steering angle sensor|05,Access/start authorization|06,Seat adjustment: passenger's side|08,HVAC electronics|09,Electronic central electric|0E,Media Player 1|10,Park distance control 2|11,Engine electronics 2|13,Adaptive Cruise Control|8B,Distance regulation 2|34,Level control system|15,Airbag|16,Steering Column Electronics|17,Instrument cluster|17,Instrument cluster|18,Auxiliary/parking heating|19,Data Bus OBD Interface|1B,Active Steering|1E,Media Player 2|20,High beam assistant|22,All-wheel drive electronics|28,Rear A/C control head|2E,Media Player 3|30,Special Function 2|36,Seat adjustment: driver side|3C,Lane change assistance|3D,Special Function|3E,Media Player 4|42,Driver's door electronics|46,Convenience system central module|47,Sound System|52,Passenger's door electronics|53,Parking Brake|55,Headlamp range control|56,Radio|57,TV Tuner|85,Camera control module|5F,Information electronics 1|62,Left rear door electronics|26,Convertible top operation|65,Tire Pressure Monitoring System (TPMS)|69,Trailer Function|6C,Rear view camera system|6D,Rear lid electronics|6F,Comfort system central control module 2|72,Right rear door electronics|3B,Sensor Electronics|7F,Information electronics 2|82,Head-Up-Display|84,Night vision system|48,Seat adjustment: rear driver's side|5B,Seat adjustment: rear passenger's side|88,Multi-contour seat driver's side|89,Multi-contour seat passenger side|8A,Multi-contour seat rear driver's side|8D,Multi-contour seat rear passenger's side|8F,Left front seat belt tensioner|90,Right front seat belt tensioner|AC,Reducing Agent Metering System|44,Power steering|81,Shift lever|8E,Image processing control module|C0,Actuator For Exterior Noise|A9,Structure-borne sound actuator|40,A/C compressor|51,Electric drive|8C,Hybrid Battery Management|BA,Subframe mount|14,Wheel Damping Electronics|20,High beam assistant|20,High beam assistant|20,High beam assistant|20,High beam assistant|20,High beam assistant|20,High beam assistant|20,High beam assistant|,
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0,TP 1.6,K Line,Ethernet|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|No,No,No,No,No|No,Yes,No,No,No|No,No,No,No,No|Yes,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|Yes,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,Yes,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|Yes,No,No,No,No|No,Yes,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|,
IDE01996-ENG99724,Installation list: specified installations-ECU coded,|ECU coded Bit 0,ECU coded Bit 1,ECU coded Bit 2,ECU coded Bit 3,ECU coded Bit 4,ECU coded Bit 5,ECU coded Bit 6,ECU coded Bit 7|Yes,No,Yes,Yes,Yes,Yes,Yes,Yes|Yes,No,No,No,No,Yes,No,Yes|No,No,No,Yes,No,No,Yes,Yes|No,No,No,No,No,No,No,No|No,No,Yes,Yes,Yes,Yes,Yes,Yes|Yes,No,No,No,No,Yes,Yes,No|No,No,No,No,No,Yes,Yes,No|Yes,Yes,No,No,No,No,No,No|No,No,No,No,No,No,No,No|No,No,No,No,No,No,No,No|,
IDE02384-ENG102478,Status of event memory-ECU Dtcs,|ECU Dtc Bit 0,ECU Dtc Bit 1,ECU Dtc Bit 2,ECU Dtc Bit 3,ECU Dtc Bit 4,ECU Dtc Bit 5,ECU Dtc Bit 6,ECU Dtc Bit 7|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|,
IDE03008-ENG98388,Stop process prevented-Battery state of charge too low,0,
IDE03008-ENG98389,Stop process prevented-Battery temperature,0,
IDE03008-ENG99012,Stop process prevented-Consumer/component current too high,0,
IDE03008-ENG103231,Stop process prevented-Entnehmbare Ladung zu gering,0,
IDE03008-ENG98719,Stop process prevented-Idle increase active,0,
IDE03008-ENG122800,Stop process prevented-Intermittierender Betrieb aktiv,0,
IDE03008-ENG98746,Stop process prevented-Possible standing time too short,0,
IDE03008-ENG103267,Stop process prevented-Sonderveto aktiv,0,
IDE03008-ENG104139,Stop process prevented-Veto DC/DC Wandler,0,
IDE03009-ENG98388,Start process requested-Battery state of charge too low,0,
IDE03009-ENG104067,Start process requested-Charge contingency,0,
IDE03009-ENG99104,Start process requested-Entnehmbare Ladung,0,
IDE03009-ENG99021,Start process requested-insufficient voltage,0,
IDE03009-ENG101118,Start process requested-Stromverbrauch,0,
IDE03009-ENG102869,Start process requested-Zielzeit abgelaufen,0,
IDE03127,Prevented stop processes (ring memory),||2026-07-21-22:44*1-0-0-0-1-0-0-0**
2026-06-16-08:35*1-0-0-0-0-0-0-0**
2026-06-11-18:11*1-0-0-0-0-0-0-0**
2026-06-11-18:10*1-0-0-0-0-0-0-0**
2026-06-11-18:09*1-0-0-0-0-0-0-0**
01818*00000*00312*00000*00141*00000*00316*00224**|,
IDE03128,Requested start processes (ring memory),||2024-09-25-10:00*0-0-0-0-1-0-0-0**
2015-01-15-11:39*0-0-0-0-1-0-0-0**
00000*00000*00000*00000*00002*00000*00000*00000**|,
IDE03150-ENG113353,Readiness for bus sleep mode-ECU Sleepready New,|ECU SleepReady Bit0,ECU SleepReady Bit1,ECU SleepReady Bit2,ECU SleepReady Bit3,ECU SleepReady Bit4,ECU SleepReady Bit5,ECU SleepReady Bit6,ECU SleepReady Bit7|not reachable,reachable,not reachable,not reachable,not reachable,reachable,not reachable,not reachable|not reachable,reachable,not reachable,not reachable,reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,reachable,not reachable,not reachable,not reachable|not reachable,reachable,not reachable,reachable,reachable,not reachable,reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable,not reachable|not reachable,reachable,reachable,reachable,reachable,reachable,not reachable,not reachable|reachable,reachable,not reachable,reachable,not reachable,reachable,reachable,reachable|reachable,not reachable,not reachable,not reachable,reachable,reachable,reachable,reachable|not reachable,reachable,reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|,
IDE03151,TP CAN identifier,|TP CAN identifier|00 00|00 00|07 13|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|07 57|07 56|07 55|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|07 1D|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|07 21|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|07 12|00 00|07 58|00 00|00 00|00 00|00 00|00 00|00 00|00 00|30 31|2D 30|31 2D|30 30|3A 30|30 2A|30 2D|,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03897,Generator: status communication,active,
IDE03898,Voltage stabilizer: status communication,active,
IDE03899,Battery monitoring control module: status communication,active,
IDE06747-IDE01834,Battery Monitoring Control Module 2-Battery voltage,4.000, V
IDE06747-IDE01836,Battery Monitoring Control Module 2-Battery current,-32.768, A
IDE06747-IDE01838,Battery Monitoring Control Module 2-Battery temperature,-40, °
IDE06747-IDE01839,Battery Monitoring Control Module 2-Battery charge status,0, %
IDE06747-IDE01841,Battery Monitoring Control Module 2-Battery internal resistance,0.0, mOhm
IDE06747-IDE01948,Battery Monitoring Control Module 2-Battery internal resistance not normed,0.0, mOhm
IDE06747,Battery Monitoring Control Module 2,not active,
IDE06747-ENG113366,Battery Monitoring Control Module 2-battery current puls,0,
IDE06747-ENG113365,Battery Monitoring Control Module 2-battery voltage puls,9.000, V
IDE06747-ENG113367,Battery Monitoring Control Module 2-BZE_Min_puls_duration,0, ms
IDE06747-ENG113368,Battery Monitoring Control Module 2-BZE_Min_trigger,0,
IDE06747-ENG101157,Battery Monitoring Control Module 2-BZE_Q_Elad,0.0, Ah
IDE06747-ENG100159,Battery Monitoring Control Module 2-BZE_Q_Lad,0.0, Ah
IDE06747-ENG106125,Battery Monitoring Control Module 2-EM_blBatteryDisconnected,connected,
IDE06747-ENG98970,Battery Monitoring Control Module 2-Temperature of battery sensor,-40, °
IDE08529-MAS01632,Service-key: query status-Status,not active,
IDE08529-MAS07126,Service-key: query status-Standard query,not active,
IDE08529-MAS07127,Service-key: query status-Immediate query,not active,
IDE08529-MAS07128,Service-key: query status-Control module in except. handling 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE08529-MAS07129,Service-key: query status-Control module in except. handling 2,5F 7F 57 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG107689-IDE01868,Automatic loop break diagnosis-Ring break diagnostic result,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG107689-MAS00043,Automatic loop break diagnosis-Terminal 30 power supply,0.0, V
ENG107689-MAS00711,Automatic loop break diagnosis-kilometer reading,0, km
ENG107689-MAS01230,Automatic loop break diagnosis-Date,00.00.2000,
ENG107689-MAS02957,Automatic loop break diagnosis-Time,00:00,
ENG105315-ENG103971,BCmE_Versionnumber-Patch,2,
ENG105315-ENG98889,BCmE_Versionnumber-Release,5,
ENG111625-MAS00106,Break recommendation-Year,2000,
ENG111625-MAS00107,Break recommendation-Month,0,
ENG111625-MAS00108,Break recommendation-Day,0,
ENG111625-MAS00109,Break recommendation-Hours,0,
ENG111625-MAS00110,Break recommendation-Minutes,0,
ENG111625-ENG151621,Break recommendation-Deaktiviert durch EEPROM-Wert,Yes,
ENG111625-ENG151620,Break recommendation-Deaktiviert durch falschen Datensatz,No,
ENG111625-ENG113361,Break recommendation-PE_Art_der_Meldung,Initialization,
ENG111625-ENG113357,Break recommendation-PE_Einstellung,not active,
ENG111625-ENG113359,Break recommendation-PE_Fehlercode,Initialization,
ENG111625-ENG113362,Break recommendation-PE_Index_HFC_TP,1.000,
ENG111625-ENG113358,Break recommendation-PE_Stufe,0,
ENG105771-ENG102240,DCDC_First_Branch-DC_STST1_Bypassrelais_defekt_TW1,0,
ENG105771-ENG102373,DCDC_First_Branch-DC_STST1_El_Fehler_Ausgang_KS_TW1,0,
ENG105771-ENG104027,DCDC_First_Branch-DC_STST1_Lastabschaltung_TW1,0,
ENG105771-ENG101272,DCDC_First_Branch-DC_STST1_Uebertemperatur_TW1,0,
ENG105771-ENG100694,DCDC_First_Branch-DC_STST1_Unterspannung_Eingang_TW1,0,
ENG105772-ENG102945,DCDC_Second_Branch-DC_STST1_Bypassrelais_defekt_TW2,0,
ENG105772-ENG99327,DCDC_Second_Branch-DC_STST1_El_Fehler_Ausgang_KS_TW2,0,
ENG105772-ENG100692,DCDC_Second_Branch-DC_STST1_Lastabschaltung_TW2,0,
ENG105772-ENG100445,DCDC_Second_Branch-DC_STST1_Uebertemperatur_TW2,0,
ENG105772-ENG101117,DCDC_Second_Branch-DC_STST1_Unterspannung_Eingang_TW2,0,
ENG105773-ENG100371,DCDC_STST_Status-DC_STST1_Boost,0,
ENG105773-ENG101192,DCDC_STST_Status-DC_STST1_Defekt,0,
ENG105773-ENG101605,DCDC_STST_Status-DC_STST1_ErrorGueltigkeit,1,
ENG105773-ENG103583,DCDC_STST_Status-DC_STST1_Fail,0,
ENG105773-ENG103918,DCDC_STST_Status-DC_STST1_Fktbereit,1,
ENG105773-ENG102020,DCDC_STST_Status-DC_STST1_Lokalaktiv,0,
ENG105773-ENG103598,DCDC_STST_Status-DC_STST1_Stromgrenze,0,
ENG105773-ENG99195,DCDC_STST_Status-DC_STST1_Uebertemperatur,0,
ENG113398,EM Produktionsmodus Freigabe,1,
ENG113397,EM RSM Freigabe,1,
ENG106120,EM_battery identification known,known,
ENG106121-ENG101157,EM_Battery_charge_discharge-BZE_Q_Elad,25103.0, Ah
ENG106121-ENG100159,EM_Battery_charge_discharge-BZE_Q_Lad,26457.5, Ah
ENG106122,EM_battery_identification,12,
ENG106123,EM_blAlternator On,OFF,
ENG106124,EM_blAlternator Valid,Yes,
ENG106125,EM_blBatteryDisconnected,connected,
ENG106126,EM_blBemSleepRdy,0,
ENG106127,EM_blBoostRecognised,detected,
ENG106128,EM_blCanMostActive,1,
ENG106129,EM_blControlKFan,0,
ENG106130,EM_blDisconnectionAdeptChannel,0,
ENG106131,EM_blMmi Advance Warning,0,
ENG106132,EM_blMmi Advance Warning Diag,0,
ENG106133,EM_blParkHeatingEncoded,Not coded,
ENG106134,EM_blRecuperation Encoded,coded,
ENG106135,EM_blRecuperation Enforce,Not coded,
ENG106136,EM_blSleepIndication,1,
ENG106137,EM_blStabilisation EBalance,0,
ENG106138,EM_blStabilisation EPowerSystem,0,
ENG106139,EM_blVnaActive,0,
ENG106140,EM_Current_Control_Recu,not active,
ENG121181,EM_Energiebilanz_2,10000.0, Ah
ENG106141,EM_errEBalanceDiag,0,
ENG106142,EM_errEPowerSystem,0,
ENG106143,EM_errOverVoltage,0,
ENG113400-ENG113369,EM_Hybrid_Info-Hybrid_Info,Motorstart_ueber_12V_Starter_nur_bei_0kmh_moeglich,
ENG106144,EM_IAlternator L1,0.0, A
ENG106145,EM_IAlternator Reserve,0.0, A
ENG106146,EM_IInternalFan,0.00, A
ENG106147,EM_IKmStandTm Active,0, km
ENG106148,EM_IKmStandTmActiveIn,56, km
ENG106149,EM_INeutralBem,-0.343, A
ENG106150,EM_IParkHeatingRequirements,10, A
ENG121178,EM_Ladestrombegrenzung,not active,
ENG106151,EM_Load Response Time,6.00, s
ENG106160-ENG102785,EM_loss_of_voltage / param_specified_capacity-Battery technology,Batterietechnologie unbekannt,
ENG106160-ENG100745,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Aktuell,2.85, V
ENG106160-ENG101482,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Mittel,2.90, V
ENG106160-ENG102509,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Trigger,1,
ENG106160-ENG102743,EM_loss_of_voltage / param_specified_capacity-BZE_MinUStart,9.75, V
ENG106160-ENG101108,EM_loss_of_voltage / param_specified_capacity-BZE_MinUStart_Trigger,1,
ENG106160-ENG100156,EM_loss_of_voltage / param_specified_capacity-BZE_Q_Nom,100, Ah
ENG106160-ENG100059,EM_loss_of_voltage / param_specified_capacity-Nenn Kapazität,Init,
ENG106152,EM_MAlternator,0.0, Nm
ENG106153,EM_NDisconnectionEngineSpeed,5990, /min
ENG106154,EM_PAltMechanical,0, W
ENG106156,EM_PReserveFilter,0, W
ENG106157-ENG101729,EM_RecuMode_Engine-Modus Rekuperation (Motor),Acceleration limited,
ENG106159-ENG102920,EM_Recuperation_Prerequisite-Auslastung des Generators,1,
ENG106159-ENG100983,EM_Recuperation_Prerequisite-Batteriealterung (Ladung),1,
ENG106159-ENG99619,EM_Recuperation_Prerequisite-Batteriealterung (Leistung),1,
ENG106159-ENG102670,EM_Recuperation_Prerequisite-Batterieregeneration,1,
ENG106159-ENG103895,EM_Recuperation_Prerequisite-Energie Netz,1,
ENG106159-ENG99263,EM_Recuperation_Prerequisite-Energiedurchsatz,0,
ENG106159-ENG99104,EM_Recuperation_Prerequisite-Entnehmbare Ladung,1,
ENG106159-ENG99756,EM_Recuperation_Prerequisite-Generatordiagnose,1,
ENG106159-ENG103581,EM_Recuperation_Prerequisite-Ladezustand der Batterie,0,
ENG106159-ENG100106,EM_Recuperation_Prerequisite-Leerlaufanhebung,1,
ENG106159-ENG104009,EM_Recuperation_Prerequisite-LIN-Kommunikation,1,
ENG106159-ENG98425,EM_Recuperation_Prerequisite-Outside temperature,1,
ENG106159-ENG102570,EM_Recuperation_Prerequisite-Säureschichtung,1,
ENG106159-ENG101873,EM_Recuperation_Prerequisite-Sonderveto,1,
ENG106159-ENG103261,EM_Recuperation_Prerequisite-Spannung der Batterie,1,
ENG106159-ENG103394,EM_Recuperation_Prerequisite-Temperatur der Batterie,1,
ENG106158-ENG104224,EM_Recuperation_Restriction-Abblendlicht Aktiv,1,
ENG106158-ENG99969,EM_Recuperation_Restriction-Auslastung Innegeblaese Hoch,0,
ENG106158-ENG103587,EM_Recuperation_Restriction-Bauteilschutz BDM,0,
ENG106158-ENG102567,EM_Recuperation_Restriction-Bauteilschutz Fernlicht,0,
ENG106158-ENG101156,EM_Recuperation_Restriction-Blinker links Aktiv,0,
ENG106158-ENG101146,EM_Recuperation_Restriction-Blinker rechts Aktiv,0,
ENG106158-ENG113355,EM_Recuperation_Restriction-EPS Leistunsanforderung,0,
ENG106158-ENG101898,EM_Recuperation_Restriction-ESP-Anforderung,0,
ENG106158-ENG99511,EM_Recuperation_Restriction-Innenlicht Aktiv,1,
ENG106158-ENG102650,EM_Recuperation_Restriction-Motor-Anforderung,0,
ENG121180-ENG121171,EM_Rekuperation_Sonderveto-Sonderveto_Anhaenger,No,
ENG121180-ENG121172,EM_Rekuperation_Sonderveto-Sonderveto_Klima,No,
ENG121180-ENG121174,EM_Rekuperation_Sonderveto-Sonderveto_Motor_Spannungsanforderung,No,
ENG121180-ENG121170,EM_Rekuperation_Sonderveto-Sonderveto_Produktion,No,
ENG121180-ENG121169,EM_Rekuperation_Sonderveto-Sonderveto_Transportmodus,No,
ENG121180-ENG121173,EM_Rekuperation_Sonderveto-Sonderveto_Zustart_Batterie,No,
ENG106161-ENG102992,EM_Start_Stop_State-Mögliche Stoppzeit,13,
ENG106161-ENG100942,EM_Start_Stop_State-Start Stopp Phase,Phase 1,
ENG106161-ENG103632,EM_Start_Stop_State-Status Motorstopp,not active,
ENG106161-ENG102878,EM_Start_Stop_State-Status Wiederstart,not active,
ENG106161-ENG100005,EM_Start_Stop_State-Stromverbrauchsschätzung Stoppphase,30, A
ENG106162-ENG101997,EM_Start_Stop_System_Error / system fault DC-Batterie zyklisch verbraucht,0,
ENG106162-ENG103373,EM_Start_Stop_System_Error / system fault DC-Battery fault,0,
ENG106162-ENG99392,EM_Start_Stop_System_Error / system fault DC-Fehler Diagnosesignal DC/DC-Wandler,0,
ENG106162-ENG102635,EM_Start_Stop_System_Error / system fault DC-Generator malfunction,0,
ENG106162-ENG101407,EM_Start_Stop_System_Error / system fault DC-Start/Stopp-Koordinator unplausibel,0,
ENG106162-ENG122799,EM_Start_Stop_System_Error / system fault DC-Systemfehler BDM Defekt,0,
ENG106162-ENG100042,EM_Start_Stop_System_Error / system fault DC-Systemfehler DC/DC-Wandler,0,
ENG106163-ENG99559,EM_tSgErrors-tSgError IO Duration tSgErrors,369, min
ENG106163-ENG100405,EM_tSgErrors-tSgError NIO Duration tSgErrors,7, min
ENG106163-ENG100563,EM_tSgErrors-tSgErrorDuration In tSgErrors,0, s
ENG106163-ENG103494,EM_tSgErrors-tSgErrorDuration tSgErrors,0, s
ENG106164,EM_UControlUnit,11.932, V
ENG106165,EM_Ustart,6.5, V
ENG106166,EM_valBdm LinTableSwitch,Terminal 15 on,
ENG106167,EM_valBdm WakeUpReason,0,
ENG106168,EM_valEngineId,1,
ENG106169,EM_valHlkLevelRequirement,1,
ENG106170,EM_valStatusHlk,0,
ENG106171-ENG103971,EM_Versionnumber-Patch,11,
ENG106171-ENG98889,EM_Versionnumber-Release,15,
ENG113401-ENG113374,EM_Zustart Freigabe-Freigabe Aussentemperatur,Yes,
ENG113401-ENG113370,EM_Zustart Freigabe-Freigabe Batterietemperatur (Bat1),Yes,
ENG113401-ENG113372,EM_Zustart Freigabe-Freigabe Batterietemperatur (Bat2),Yes,
ENG113401-ENG113371,EM_Zustart Freigabe-Freigabe Entnehmbare Ladung (Bat1),Yes,
ENG113401-ENG113373,EM_Zustart Freigabe-Freigabe Leistungsfähigkeit Zustart,No,
ENG121179-ENG121165,EM_Zustart_Systemfehler-EM_BatterieAb_BDM1,No,
ENG121179-ENG121166,EM_Zustart_Systemfehler-EM_BatterieAb_BDM2,No,
ENG121179-ENG121167,EM_Zustart_Systemfehler-EM_LIN1_ungueltig,No,
ENG121179-ENG121168,EM_Zustart_Systemfehler-EM_LIN2_ungueltig,No,
ENG113402-ENG113377,GW_Bap_Status-Lifecycle,run,
ENG113402-ENG99775,GW_Bap_Status-MOST,On,
ENG113402-ENG113378,GW_Bap_Status-PE_Freigabe,1,
ENG106825,GW_SYS_BEM_SleepReady,EM active,
ENG106826,GW_SYS_BM_Run-on,60, s
ENG106827-ENG100038,GW_SYS_CPU_Load-CPU Load,0, %
ENG106827-ENG113384,GW_SYS_CPU_Load-Task Level 1,0, %
ENG106827-ENG113383,GW_SYS_CPU_Load-Task Level 2,0, %
ENG106827-ENG113382,GW_SYS_CPU_Load-Task Level 3,0, %
ENG106827-ENG113381,GW_SYS_CPU_Load-Task Level 4,0, %
ENG106828,GW_SYS_EEPROM Repair,0,
ENG106832-ENG100323,GW_SYS_LastWakeupReason-Car WakeUp Reason,Comfort data bus,
ENG106832-ENG99403,GW_SYS_LastWakeupReason-Gateway WakeUp Reason,Comfort data bus,
ENG106833,GW_SYS_Reset_Count,0,
ENG106834,GW_SYS_ResetReason,Power On Reset,
ENG100548-MAS00049,GW_SYS_State-Component protection,not active,
ENG100548-MAS00795,GW_SYS_State-Data Bus On Board Diagnostic Interface,active,
ENG100548-MAS01468,GW_SYS_State-Terminal 15,active,
ENG100548-MAS01490,GW_SYS_State-Energy management,not active,
ENG100548-MAS03173,GW_SYS_State-Powertrain data bus,not active,
ENG100548-MAS03174,GW_SYS_State-Comfort data bus,not active,
ENG100548-MAS03175,GW_SYS_State-Extended data bus,active,
ENG100548-MAS03176,GW_SYS_State-Display and control head databus,not active,
ENG100548-MAS03177,GW_SYS_State-Infotainment data bus,active,
ENG100548-MAS03178,GW_SYS_State-Suspension data bus,not active,
ENG100548-MAS03180,GW_SYS_State-Local data bus,active,
ENG100548-MAS03181,GW_SYS_State-Flexray databus,not active,
ENG100548-ENG102839,GW_SYS_State-A-Can Flexray F-Can SubMaster,active,
ENG100548-ENG100518,GW_SYS_State-Busmonitor,active,
ENG100548-ENG98571,GW_SYS_State-EEPROM,active,
ENG100548-ENG99046,GW_SYS_State-Emergency signal flashing,not active,
ENG100548-ENG100049,GW_SYS_State-K-Can Dash-Can SubMaster,active,
ENG100548-ENG102799,GW_SYS_State-Mindestaktivzeit,active,
ENG106837,GW_SYS_TP20_Counter,0,
ENG110999,GW_Watchdog_Version,0,
ENG100189,IN ESP_standstill flag,1,
ENG100411,IN ESP_v_Signal,0, km/h
ENG100786,IN HW terminal 15,1,
ENG101017,IN KBI_odometer_reading,233847,
ENG101398,IN MO_engine_speed_01,0.00, /min
ENG103286,IN MO_Motor_running,0,
ENG106958-MAS00106,IN time_01-Year,2026,
ENG106958-MAS00107,IN time_01-Month,10,
ENG106958-MAS00108,IN time_01-Day,5,
ENG106958-MAS00109,IN time_01-Hours,22,
ENG106958-MAS00110,IN time_01-Minutes,18,
ENG106958-MAS00111,IN time_01-Seconds,31,
ENG106958-MAS00690,IN time_01-Daylight saving time,Daylight saving time,
ENG106958-ENG103328,IN time_01-type of clock,GPS,
ENG101569,IN ZAS_Te_15,1,
ENG103048,IN ZAS_Te_X,1,
ENG107685-ENG103912,MOST Deattaches-deatatch counter_MOST Deatatches,0,
ENG107685-ENG99643,MOST Deattaches-present deatatch counter_MOST Deatatches,0,
ENG107685-ENG100756,MOST Deattaches-present status_MOST Deatatches,connected,
ENG102460,MOST Notifications,|Function ID,Target Adress 1,Target Adress 2,Target Adress 3|00 00,00 00,00 00,00 00|00 00,00 00,00 00,00 01|00 00,00 00,00 00,00 00|00 00,00 00,00 02,00 00|00 00,00 00,00 00,00 00|00 00,0C FE,00 00,00 00|00 00,00 00,00 00,00 00|0C FF,00 00,00 00,00 00|00 00,00 00,00 00,0E 02|01 00,00 00,00 00,00 00|00 00,00 00,0E 03,03 FF|00 00,00 00,00 00,00 00|00 00,0E 04,03 FF,00 00|00 00,00 00,00 00,00 00|0E 05,01 00,00 00,00 00|00 00,00 00,00 00,0E 06|03 FF,00 00,00 00,00 00|00 00,00 00,0E 10,03 FF|00 00,00 00,00 00,00 00|00 00,0E 24,03 FF,00 00|00 00,00 00,00 00,00 00|0E 30,03 FF,00 00,00 00|00 00,00 00,00 00,0E 31|03 FF,00 00,00 00,00 00|00 00,00 00,0E 32,03 FF|00 00,00 00,00 00,00 00|00 00,0E 33,00 00,00 00|00 00,00 00,00 00,00 00|0E 34,00 00,00 00,00 00|00 00,00 00,00 00,0E 36|01 00,00 00,00 00,00 00|00 00,00 00,0E 38,00 00|00 00,00 00,00 00,00 00|00 00,0E 3C,01 00,00 00|00 00,00 00,00 00,00 00|0E 3E,00 00,00 00,00 00|00 00,00 00,00 00,0E 3F|00 00,00 00,00 00,00 00|00 00,00 00,0E 40,00 00|00 00,00 00,00 00,00 00|00 00,0E A0,01 00,00 00|00 00,00 00,00 00,00 00|0E A1,01 00,00 00,00 00|00 00,00 00,00 00,0E A2|,
ENG107869-ENG102318,NW_MOST Addressing-diag inst-id,19,
ENG107869-ENG101908,NW_MOST Addressing-groupadress,03 FF,
ENG107869-ENG101657,NW_MOST Addressing-logical adress,05 19,
ENG107869-ENG99161,NW_MOST Addressing-vehicle inst-id,01,
ENG107870-ENG100752,NW_MOST net mngmt status-Configuration_NW_MOST Networkmanagment.Status,New,
ENG107870-ENG99305,NW_MOST net mngmt status-MMI_State_NW_MOST Networkmanagment.Status,MMI_On,
ENG107870-ENG103488,NW_MOST net mngmt status-ShutDownState_NW_MOST Networkmanagment.Status,Suspend,
ENG107870-ENG104176,NW_MOST net mngmt status-Systemstate_NW_MOST Networkmanagment.Status,normal operation,
ENG107948,OUT_Alternator_reference_voltage_value,10.6, V
ENG107949,OUT_GW_Aging_counter_DIAG_01_message,73,
ENG102605,outside_temperature,18.5, °C
ENG113399-ENG113364,PE_Version-DS_Version,5.1,
ENG113399-ENG109174,PE_Version-SW_VERSION,5.1,
ENG107686-IDE00317,Reset date for counter: sporadic loop breaks-Date,00.00.2000,
ENG125408,SK2_AnpassungStatus,1,
ENG122798-ENG103971,Sk2_Version-Patch,4,
ENG122798-ENG98889,Sk2_Version-Release,1,
ENG110089,Warm-Up-Cycle Counter (zVZ),0,
Elapsed Time: 00:40
TTT
C?ID=547002
With SoH 82%, still good.
evisceratum
Romania
C?ID=530930
A good measure is to check the internal resistance of the battery. Anything higher that 7-8mOhm is bad news.
