Hi everyone,
This is my first post, although I’ve been reading the forum and using VCDS for years. Thanks for all the helpful information shared here!
We’re working on a 2016 Audi S6 and have replaced the complete factory air suspension with conventional coilovers.
I’m looking for help identifying the coding changes needed in the relevant modules to remove the suspension malfunction warning while keeping ABS/ESC and headlight leveling working correctly.
The Long Coding Helper descriptions are incomplete for several modules. In particular, I cannot find a suspension type option in the ABS module:
Does anyone know which bytes/bits need to be changed, and which other modules or wiring changes are required when removing the level control module?
I’ll include the full Auto-Scan below. If this belongs in the Retrofits section, please feel free to move it.
Thanks in advance!
- Part number: 4G0 907 379 Q
- Component: ESP9 Premium H01 0420
- ASAM: EV_ESP9BOSCHAU57X 003019
- Current coding: 65A6D641A6656B821B00
Thanks in advance!
VIN: WAUF2AFC2GN009949 License Plate:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 34 36 3B 3C 42 44 46 47 52
53 55 5F 62 6C 72 8F 90 A9 BA
VIN: WAUF2AFC2GN009949 Mileage: 116792km-72571miles
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CTGE) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 D HW: 4H0 906 014
Component: 4.0l V8TFSI / X62 0002
Revision: NCX62--- CVN: 67F06E17
Coding: 0A2500326526010E3000
Shop #: WSC 82976 802 690857
ASAM Dataset: EV_ECM40TFS0114G0906014D 001002
ROD: EV_ECM40TFS0114G0906014D.rod
VCID: 23189CF88B5D7412B31-8076
VINID: 9D195609159309778000924424BE6D7B6F
18062 - Coolant Pump 2
P261A 00 [00101000] - Open circuit
Fault Frequency: 23
Mileage: 114545 km
Date: 2025.09.24
Time: 20:45:28
Engine speed: 1295.50 /min
Normed load value: 18.0 %
Coolant temperature: 27 C
Intake air temperature: 28 C
Voltage terminal 30: 13.452 V
Engine status: COENG_RUNNING
15356 - Oxygen (Lambda) Sensor Signal B1 S2
P2270 00 [01100000] - too Lean
Mileage: 114693 km
Date: 2025.10.05
Time: 23:16:26
Engine speed: 1299.50 /min
Normed load value: 21.2 %
Vehicle speed: 75 km/h
Coolant temperature: 69 C
Intake air temperature: 18 C
Voltage terminal 30: 14.017 V
Unlearning counter according OBD: 7
Rear cat conv temp main cat conv model value: 427.94 C
O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean: 0.10 s
O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich: 0.20 s
O2 sensor dwnstrm. of cat.: delay time transf. rich -> lean: 0.00 s
O2 sensor dwnstrm. of cat.: delay time transf. lean -> rich: 0.08 s
4028 - Oxygen (Lambda) Sensor B2 S2
P0157 00 [01100000] - Signal too Low
4024 - Oxygen (Lambda) Sensor B1 S2
P0137 00 [01100000] - Signal too Low
Part No SW: 4G0 927 166 F HW: 0B5 927 156 K
Component: 0B5 40TFSINAR H03 0007
Revision: --H03--- CVN: 00008173
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL501021 001022
ROD: EV_TCMDL501021.rod
VCID: 303263B4CAABDF8A3E3-8064
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Coding: 65A6D641A6656B821B00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FD0308807F530F2B79-806A
14 Faults Found:
154624 - Tire Pressure Warning
C102D 00 [00100000] - -
155392 - Tire Pressure Warning
161024 - Tire Pressure Warning
161792 - Tire Pressure Warning
C102D 00 [00101000] - -
Mileage: 116682 km
Date: 2026.03.19
Time: 17:10:44
VzRef: 20
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
Uz: B8
179712 - Function Restriction due to Faults in Other Modules
U1113 00 [00101000] - -
[SCL_FA_Niveau_Druck_HL_Error]
Mileage: 116673 km
Date: 2026.02.23
Time: 18:05:02
VzRef: 04
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 22
Bit Info 4: 1F
Uz: B6
Unlearning counter according OBD: 27
179968 - Function Restriction due to Implausible Message(s)
U1112 00 [00100000] - -
[SCL_FA_Niveau_Druck_HL_Invalid]
180224 - Function Restriction due to Faults in Other Modules
U1113 00 [00100000] - -
[SCL_FA_Niveau_Druck_HR_Error]
180480 - Function Restriction due to Implausible Message(s)
[SCL_FA_Niveau_Druck_HR_Invalid]
180736 - Function Restriction due to Faults in Other Modules
U1113 00 [00101111] - -
[SCL_FA_Niveau_Druck_VL_Error]
Fault Frequency: 8
Mileage: 116673 km
Date: 2026.02.23
Time: 18:04:52
VzRef: 04
Bit Info 1: 40
Bit Info 2: 40
Bit Info 3: 22
Bit Info 4: 1F
Uz: B6
180992 - Function Restriction due to Implausible Message(s)
U1112 00 [00100011] - -
[SCL_FA_Niveau_Druck_VL_Invalid]
181248 - Function Restriction due to Faults in Other Modules
U1113 00 [00100011] - -
[SCL_FA_Niveau_Druck_VR_Error]
181504 - Function Restriction due to Implausible Message(s)
[SCL_FA_Niveau_Druck_VR_Invalid]
200448 - Function Restriction due to Faults in Other Modules
[SCL_LWR_Hoehenwert_HL_Error]
Mileage: 116673 km
Date: 2026.02.23
Time: 15:34:40
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 22
Bit Info 4: 1F
Uz: 92
200192 - Function Restriction due to Implausible Message(s)
[SCL_LWR_Hoehenwert_HL_Invalid]
Part No SW: 4H0 907 064 FR HW: 4H0 907 064 ER
Component: BCM2 2.0 H36 0560
Coding: 0DA86F4E000000000000
VCID: 7EAE8D8C40FFF9FAFCF-802A
Serial number: 3215000017994005
Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
Serial number: 26021500040421
Coding: 68013078490000
VCID: 6A86B1DC2CF7655A307-803E
Part No SW: 4H0 907 063 DM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0311
Revision: 21020001 Serial number: 00001007879001
Coding: 01050011043C9FE0890048C780003800CF9CD208A608022180000814F110170200600034030000
VCID: 76BE95AC68CFB1BAA4F-8022
Component: WWS57X 150207 H37 0080
Serial number: 150210184134
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23750126
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
Component: E1 - LDS H07 0044
Serial number: 17 02 2015 00000103
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01E32CE9
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA120138000011600761
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 41E84397000000000001
00471 - Control Module for Elect. Regulated Dampers (J250)
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 230
Mileage: 116673 km
Date: 2026.02.23
Time: 15:34:39
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H62 0086
Revision: -------- Serial number: 003G0001XGZI Dataset Number: 4G0909602N 0002
Coding: 303331343135303334394A55304C34473053
VCID: 343A6FA43EB3E3AA5AB-8060
Component: BF-Gewichtss. H15 0046
Serial number: 6940000Y150001ATF70Z
Serial number: 3575HRB401052T4EDGJA
Serial number: 3585HRB400O52SLGD94U
Serial number: 3515JRB401C5358SCI2/
Serial number: 3525JRB405J35IMQ6P2Z
Serial number: 3554VRB400S52JMQ4H86
Serial number: 3564VRB400K52SHK71R3
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OBH000VK
Coding: 000034
VCID: 3B284498136D2CD29B1-806E
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Serial number: 11 02 2015 E0034219
Part No SW: 4G0 920 982 C HW: 4G0 920 982 C
Component: TBenUsa Nv H07 0043
Revision: 03001036 Serial number: 658150215596000
Coding: 0BE709051B41D705020200
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 2C0A77C4E683BB6A02B-8078
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G8 907 468 HW: 4G8 907 468
Revision: -------- Serial number: 00000001743833 Dataset Number: 4G0909515G 0019
Coding: C0ED074814
GVL: FD83C84CDC22600D11040000
VCID: 75BC92A07549BAA2AD5-8020
Serial number: 9808585703
Voltage stabilizer:
Serial number: 141216000000000005EF
U140B 00 [00001000] - -
[Powermanagement active]
Reset counter: 0
Mileage: 116673 km
Date: 2026.02.23
Time: 15:35:44
Voltage terminal 30: 11.4 V
Voltage terminal 15: 11.4 V
Control Module temperature: 28 C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 1
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 27021500040539
Coding: 20
VCID: 3D2C4A800DF922E2A55-8068
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Dataset Number: 4G0909553G 0036
Coding: 008000
ROD: EV_AirSuspe_AU57.rod
VCID: 2F3060C8D795C072279-807A
12 Faults Found:
455688 - Sensor for Ride-Height
C1048 07 [00001000] - Mechanical Failure
Reset counter: 0
Mileage: 116672 km
Date: 2026.01.23
Time: 11:30:45
455690 - Sensor for Ride-Height
Reset counter: 0
Mileage: 116672 km
Date: 2026.01.23
Time: 11:30:45
677384 - Ride-Height System; Plausibility Error
C1046 00 [00001001] - -
Fault Frequency: 13
Reset counter: 230
Mileage: 116677 km
Date: 2026.03.16
Time: 11:43:25
677385 - Ride-Height System; Plausibility Error
Fault Frequency: 12
Reset counter: 230
Mileage: 116673 km
Date: 2026.02.23
Time: 18:04:52
405256 - Pressure Accumulator for Level Control
C11AF F0 [00001000] - Leak Detected
Reset counter: 15
Mileage: 116685 km
Date: 2026.03.19
Time: 17:24:50
36363 - Valve for DamPing Adjustment Front Left
C1040 13 [00001001] - Open Circuit
Fault Frequency: 19
Reset counter: 230
Mileage: 116681 km
Date: 2026.03.19
Time: 17:06:42
36619 - Valve for DamPing Adjustment Front Right
C1041 13 [00001001] - Open Circuit
Reset counter: 230
Mileage: 116703 km
Date: 2026.03.19
Time: 18:21:36
36875 - Valve for DamPing Adjustment Rear Left
C1042 13 [00001001] - Open Circuit
Reset counter: 222
Mileage: 116674 km
Date: 2026.02.25
Time: 09:44:58
37131 - Valve for DamPing Adjustment Rear Right
C1043 13 [00001001] - Open Circuit
Reset counter: 222
Mileage: 116674 km
Date: 2026.02.25
Time: 09:44:58
455693 - Sensor for Ride-Height
Fault Frequency: 14
Reset counter: 15
Mileage: 116676 km
Date: 2026.03.16
Time: 11:40:18
36635 - Valve for DamPing Adjustment Front Right
C1041 13 [00001000] - Open Circuit
Reset counter: 15
Mileage: 116712 km
Date: 2026.03.19
Time: 18:53:50
677124 - Ride-Height System
C1047 07 [00001000] - Mechanical Failure
Reset counter: 245
Mileage: 116606 km
Date: 2026.01.10
Time: 15:09:44
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000137145333
VCID: 77A098A86FC5C8B2BF9-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA82091RA8 Dataset Number: 4G0909573C 0006
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 363E55AC28CFF1BA64F-8062
Component: SWA Master H06 0060
Serial number: 0361379840 Dataset Number: 4G0909535C 0008
Coding: 040211
ROD: EV_LaneChangAssis_AU48.rod
VCID: 39245E9019D11EC289D-806C
Component: SWA Slave H06 0060
Serial number: 0361233610
Coding: 040211
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F17015E00628002000012
VCID: 47C028685FA578320F9-8012
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0025447564 Dataset Number: 4G0909852M 0031
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
VCID: 33386CB83BBDE492431-8066
Revision: 00002001 Serial number: 0360904501
Coding: 0106063A00FA408580B0080402070E470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000274697
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST0005S0WT00000
Coding: 101F02
Subsystem 4 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93437150
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 71
Mileage: 110959 km
Date: 2025.05.01
Time: 04:37:19
02615 - Fuel Tank Cap; Lock
Reset counter: 73
Mileage: 110959 km
Date: 2025.05.01
Time: 09:58:01
Part No SW: 4G8 035 223 B HW: 4G8 035 223
Component: MIB2_amp_PA H02 0270
Serial number: 00000000000349 Dataset Number: 4G1909510F 0010
Coding: 0175510A018AF02A5A0000010F00
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
VCID: 241A9FE48E53732ACAB-8070
0575 - Right Effects Speaker
B106B 13 [00011000] - Open Circuit
[Tieftonlautsprecher Kanal 10: Unterbrechung (DC-Diagnose)]
Reset counter: 254
Mileage: 116672 km
Date: 2026.01.23
Time: 11:53:21
Component: TSG BF H03 0507
Coding: 011F17015E00628002000002
VCID: 46DE256C58AF613AF4F-8012
Fault Status: 01101100
Reset counter: 105
Mileage: 115175 km
Date: 2025.10.31
Time: 07:19:14
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001375709 Dataset Number: 4G0909522E 0008
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D0C7AC0DD99B262155-8078
Component: MxB-ECU 001 0100
Revision: -------- Serial number: -------------- Dataset Number: 4G0909865D 0017
Coding: 04FA021122200400
Coding: E01E00
Coding: E01E00
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 K HW: 4G1 035 025
Component: MU-H-LNS-US 040 0143
Serial number: A278B0FB007290 Dataset Number: 4G1909545B 0019
Coding: 017551020000000013220002041A00102F0007E5F1700104FE
VCID: 261E85ECF86F813AD4F-8072
Subsystem 1 - Part No SW: V03 959 801 GG HW: -----------
Component: NAR 2017 --- 0057
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0006
Serial number: AUZ8Z9EY800B9Q
Serial number: 90349OBD000KA
Compact disc data bank:
Component: Gracenote2 --- 3006
Reset counter: 71
Mileage: 110959 km
Date: 2025.05.01
Time: 04:37:45
Voltage terminal 30: 14.3 V
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
0009 - Antenna for Satellite Radio
B10F4 13 [00001001] - Open Circuit
Fault Frequency: 8
Reset counter: 230
Mileage: 116658 km
Date: 2026.01.20
Time: 18:33:12
Voltage terminal 30: 14.6 V
Satellite radio tuner status-Antenna current: 45 mA
Satellite radio tuner status-Satellite radio tuner: pre-activation status: Initial_value_forMPFA_not_coded
Component: TSG HL H03 0507
Coding: 010F17004000628002000002
VCID: 49C42E5049B18E4219D-801C
Part No SW: 4S0 907 441 B HW: 5Q0 907 441 A
Component: D4-PA RVC Mid H07 0050
Dataset Number: 4G0909460C 0011
Coding: 027501010201000300
ASAM Dataset: EV_CamSysRearPANAAU914 002002
ROD: EV_CamSysRearPANAAU914.rod
VCID: 323669BCC4A7ED9A487-8066
Component: TSG HR H03 0507
Component: RGS-VL H13 0080
Dataset Number: 4G0909614C 0001
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313466B0C1A1D68231D-8064
Component: RGS-VR H13 0080
Dataset Number: 4G0909615C 0001
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0010
Serial number: 150205200680
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H09 0008
Revision: 00001001 Serial number: 97811004753702 Dataset Number: 4G0909578B 0013
ROD: EV_AEMLearAU64X_AU57.rod
VCID: 28028BD4F27B974AE63-807C
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [00001001] - Mechanical Failure
Reset counter: 70
Mileage: 110958 km
Date: 2025.05.01
Time: 00:07:19
