Real mileage
Lihnidos
North Macedonia
C?ID=647813
Is it possible to read the vehicle's actual mileage using VCDS software?
Thank you.
Depending on the vehicle in question, there may be a module or two that does an mileage calculation independently of the instrument cluster, but this will generally be less accurate than the mileage in the cluster.
Lihnidos
North Macedonia
C?ID=647813
It is VW Passat 2.0 Variant BMT, 103KW/140HP, 2010
Some cars, possibly yours, do store the mileage in the engine ECU. VCDS has a function to use this.
Lihnidos
North Macedonia
C?ID=647813
I have tried the engine ECU, but it's not working.
I think it was only EDC 15 and 16 but I haven’t used the function in years.
Lihnidos
North Macedonia
C?ID=647813
As requested please post a complete Auto-Scan
Monday,28,September,2026,12:47:35:42703
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.5
VIN: WVWZZZ3CZAE134060   License Plate:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 56 61 69 77
VIN: WVWZZZ3CZAE134060   Mileage: 274280km-170429miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 019 AC    HW: 03L 907 309 F
   Component: R4 2.0l TDI G000SG  9977
   Revision: 22H28---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00999 444 64523
   VCID: 6C85136D1A819B9A2B8-8038
   VINID: 9E69EAAAA0D3A915410C400600F9676E64
Address 03: ABS Brakes        Labels: None
   Part No SW: 3C0 698 109 F    HW: 3C0 614 109 AH
   Component: J104    C4 440 V2   0028
   Revision: --025---    Serial number: 00000705544666
   Coding: 0033275
   Shop #: WSC 38191 001 1048576
   VCID: 2D03DE69E11B52927C6-8078
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000003
   Shop #: WSC 05311 115 00000
   VCID: 7EA12925707D190A95C-802A
   Part No SW: 3C8 937 049 AB    HW: 3C8 937 049 AB
   Component: Bordnetz-SG     H57 3204
   Revision: 00H57000    Serial number: 00000003799515
   Coding: E1988F0700041A00470A00000F00000080015D435C000120000308000000
   Shop #: WSC 05124 000 00000
   VCID: 71BB02193DA3767218E-8024
   Subsystem 1 - Part No: 3C1 955 419 B  Labels: 1KX-955-119.CLB
   Component: Wischer 200410 006  0208
   Coding: 00046997
   Shop #: WSC 05124
   Subsystem 2 - Component: Fehler Lin-Slave 02
02071 - Local Databus
                    Reset counter: 83
                    Mileage: 262995 km
                    Date: 2021.02.18.
                    Time: 14:14:01
                    Voltage: 12.50 V
                    Reset counter: 83
                    Mileage: 262995 km
                    Date: 2021.02.18.
                    Time: 14:14:01
                    Voltage: 12.50 V
   Part No SW: 5N0 959 655 N    HW: 5N0 959 655 N
   Component: J234__005 VW10 HI   1916
   Revision: 21014000    Serial number: 003GHP8WT0HI
   Coding: 0012341
   Shop #: WSC 05311 000 00000
   VCID: 48CD8FFD6EB997BA6F0-801C
   Subsystem 1 - Serial number: 6332MTS670030920
   Subsystem 2 - Serial number: 6342MTS667710990
   Subsystem 3 - Serial number: 6351HTS6G41V79KJ
   Subsystem 4 - Serial number: 6361HTS6NSJ089KJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 BP    HW: 5K0 953 569 AA
   Component: LENKS.MODUL   009 0135
   Revision: FF010036    Serial number: 20100428100481
   Coding: 5180270002
   VCID: 78AD3F3D5259273ADF0-802C
   Part No SW: 3C0 920 872 G    HW: 3C0 920 872 G
   Component: KOMBI         H03 0305
   Coding: 161D00
   Shop #: WSC 05314 115 12345
   VCID: 290B2A79D9734EB290E-807C
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 N    HW: 3C0 907 951
   Component: J533  Gateway   H14 0170
   Revision:   H14       Serial number: 0821G098190140
   Coding: F9801F46000603042002
   VCID: 2C05D36DDA015B9A6B8-8078
01304 - Radio
                    Reset counter: 123
                    Mileage: 262995 km
                    Date: 2021.02.18.
                    Time: 14:14:16
02830 - CAN-Extended Separator for Driver Assistance Systems
                    Fault Status: 01101100
                    Reset counter: 83
                    Mileage: 262995 km
                    Date: 2021.02.18.
                    Time: 14:15:42
   Part No SW: 3C0 959 433 AQ    HW: 3C0 959 433 AQ
   Component:    IMMO         044 0383
   Revision: 00044000    Serial number: VWZCZ000000000
   Shop #: WSC 06402 785 00200
   VCID: 79AB3A3965D33E32A0E-802C
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
01176 - Key
                    Fault Status: 01101000
                    Reset counter: 240
                    Mileage: 265268 km
                    Date: 2021.02.18.
                    Time: 19:46:04
02823 - Requirements for Locking the Steering Column Lock not met
                    Reset counter: 99
                    Mileage: 272904 km
                    Date: 2021.02.18.
                    Time: 21:24:43
02827 - Wake-Up request via ESP
                    Reset counter: 99
                    Mileage: 272904 km
                    Date: 2021.02.18.
                    Time: 21:24:43
   Part No SW: 3C0 959 701     HW: 3C0 959 793
   Component: TUER-SG FT    002 0305
   Revision: 13101005    Serial number: 0000803027
   Coding: 020035
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 65936649F5EBAAD2746-8030
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.147 0703
   Revision: 1AH03726    Serial number: 00101100075601
   Coding: 0000258
   VCID: 3A29E5352055F52AE94-806E
                    Reset counter: 99
                    Mileage: 272904 km
                    Date: 2021.02.18.
                    Time: 21:24:32
                        Term 15 Off
                    RPM: 533 /min
                    (no units): 7.0
                    Voltage: 13.50 V
03375 - Steering Motor
            003 - Mechanical Failure - MIL ON
                    Fault Status: 11100011
                    Reset counter: 106
                    Mileage: 253287 km
                    Date: 2021.02.18.
                    Time: 00:11:29
                    (no units): 7.0
                    Steering Angle: 0.00
                        OK
                    (no units): 9
                    Reset counter: 99
                    Mileage: 272904 km
                        Term 15 Off
                    RPM: 217 /min
                    (no units): 7.0
                    Voltage: 13.20 V
                    Reset counter: 99
                    Mileage: 272904 km
                        Term 15 Off
                    RPM: 217 /min
                    (no units): 7.0
                    Voltage: 13.20 V
                    Reset counter: 99
                    Mileage: 272904 km
                        Term 15 Off
                    RPM: 217 /min
                    (no units): 11.0
                    Voltage: 13.20 V
   Component:    KSG PQ46 ELV 044 0612
   Coding: 0091020851030E763004941570084B0E703C01
   Shop #: WSC 08224 211 56823
   Subsystem 1 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HORN H11 9004
   Part No SW: 1K0 907 532     HW: 3C0 907 951
   Component: EZE_2         H14 0170
   Revision: --------    Serial number: 0821G098190140
   Coding: 00000001
   VCID: 66916145086DA1CA7DC-8032
   Part No SW: 3C0 959 702     HW: 3C0 959 792
   Component: TUER-SG BT    002 0305
   Revision: 15101005    Serial number: 0000813425
   Coding: 020034
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 6691614508EDA1CA7DC-8032
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000265126
   Coding: 0000056
Address 56: Radio
   Part No SW: 1K0 907 534     HW: 3C0 907 951
   Component: Batt.regelung H14 0170
   Coding: 030B085A
   VCID: 688D6F7D0279B7BA4F0-803C
   Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0125
   Serial number: 33083827012791796244
   Component: Anhaenger     H07 0070
   Revision: 3A001001    Serial number: 00000129595300
   Coding: 410D000100000000
   Shop #: WSC 05314 000 00000
   VCID: 303DC71DFA293F7A570-8064
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000A07798056
   Coding: 012120
   VCID: 2A09D575DCF545AA994-807E
03426 - Left Audio Channel
                    Reset counter: 198
                    Mileage: 262995 km
                    Date: 2021.02.18.
                    Time: 14:12:40
03427 - Right Audio Channel
                    Reset counter: 198
                    Mileage: 262995 km
                    Date: 2021.02.18.
                    Time: 14:12:40
01524 - Antenna for Telephone
                    Reset counter: 198
                    Mileage: 262995 km
                    Date: 2021.02.18.
                    Time: 14:12:40
02791 - Telephone baseplate (R126)
                    Reset counter: 198
                    Mileage: 262995 km
                    Date: 2021.02.18.
                    Time: 14:12:40
End----------(Elapsed Time: 01:21, VBatt start/end: 12.2V/12.2V)-----------
------------------------------16 Faults Found------------------------------
I'm not aware of any independent (of the instrument cluster) mileage reading in that car that VCDS can show you.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Check MVB 085.1 in the ECM. If available (and I believe your specific ECM & SW Level supports that), this should show you the independent mileage counter of the ECM as part of the IUPR. Since this MVB has been documented in VCDS for the last decade, every half decent odometer tweaker should be well aware of it by now. So take the value with a grain of salt, as this isn't safe to be not manipulated.
As a general approach, check Control Modules 01, 02, 03 and 15 > Adv. Meas. Values > Load Selection From File > "Vehicle Assessment". These pre-selections which are included with VCDS will cover many more modern engine, transmission and brake electronics as well as airbag systems with relevant data to help with a possible purchase or to assess some of the vehicle history. (This won't do too much in this specific case though, as the vehicle is indeed rather old.)
Lihnidos
North Macedonia
C?ID=647813
I will. Thank you.
imy
C?ID=438070
Could this be a feature request?
A button that checked all the modules that contain mileage and just displays it, in a table, so module 01 is reporting xxxx miles, module 02 is reporting xxxx miles, and so forth.
I have been asked multiple times to check the mileage on cars for prospective buyers, and agreed yes mileage can be changed, but it would be convenient.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Something related has been on our wishlist for some time, though with very low priority because of all sorts of different platforms and modules.
Use the aforementioned "Vehicle Assessment" instead, it's more precise and provides more context than a single mileage per module ever would.
