Hi
Looking at the AutoScan (see below) for my ID.7 I can see that I have 19 modules without any labels available, and Id be happy to help mitigate that.
Now that SFD seems to be on every other module in VWs ID-series of cars (my ID.7 has 48 modules listed and 28 of those has SFD, and 26 of those 28 also has SFD2).
Trying to read measurements from "C6 Batt. Chrg." I found out that I needed to use SFD just to see the most basic measurements such as the modules knowledge of current year, month and date..
I was wondering how I could gather module data in the easiest and best possible way, and if I should take SFD into account when doing so - eg. unlocking the module before gathering measuring values and adaptations to a pre-label file?
I can also see that there are mentions of raising debug level to 2 at certain times before gathering data and I was wondering if that recommendation still stands as a recommendation at certain times?
Lastly, gathering channel maps for an entire car takes quite a long time.
If SFD unlocking plays into that, gathering maps using the "whole vehicle"-mode is likely to begin failing when the online token expires and with no possible way of halting gathering data to re-authenticate, and as the alternative to that is manually unlocking a controller, gather maps for that one controller and repeat it makes for a slow an manual process.
This lead me to an idea for a new function supplementing the two existing ones for a single controller and the whole vehicle - "scan controllers without maps".
This would - of course - require an scan prior to see what controllers are avilable and what labels are already known, but it would speed up how long it takes gathering just the missing maps.
If not, would it be possible to expand the "whole vehicle" function to take SFD unlocking into account prior to beginning scanning a new module?
It would require keeping an eye on VCDS while running, but at least it should work for ~30 minutes at a time.
For reference heres my latest AutoScan:
Wednesday,30,September,2026,16:56:08:57346
VCDS Version: 26.10.0.2 (x64) HEX-V2 CB: 0.4713.5
Data version: 20260828 DS379.0
VIN: WVWZZZED3RE001110 License Plate:
Chassis Type: ED-VWE4 (1EE)
Scan: 01 03 05 06 08 09 10 13 15 16 19 23 2B 36 3C 42 44 51 52 5F
69 6C 6D 75 7E 82 8C A5 BB BC C0 C6 D6 D7 DE 8105 8107 8117 811E 811F
8120 8121 8123 8124 8125 8128 C002 C003
VIN: WVWZZZED3RE001110 Mileage: 29546km-18359miles
51-Electric Drive -- Status: Malfunction 0010
7E-Ctrl Head Dash -- Status: OK 0000
8C-HV Battery -- Status: Malfunction 0010
8105-DC/DC Converter 12V -- Status: OK 0000
8107-Antenna -- Status: Malfunction 0010
8117-Rear surroundings cam -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Malfunction 0010
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: OK 0000
Address 01: Engine (J623----A) Labels: 0EA-907-425-V2.clb
Part No SW: 0EA 906 014 FT HW: 0EA 907 425 K
Component: E-Vehicle H80 4098
Dataset Number: V03935424SD 0001 CVN: 12BEA25D
Coding: 010200030C042C020E050000000000000000000000000000
ASAM Dataset: EV_VCU00XXX0200EA906014FT 003003
ROD: EV_VCU00XXX0200EA906014GA.rod
VCID: 04566D6E8E951F0ACF9-8050 SFD+SFD2 [x]
VINID: 9E69EAAAA5540E2540001041008E9AE31D
Radiator shutter:
Subsystem 1 - Part No SW: 1EA 965 501 B HW: 1EA 965 501 B
Component: V711 023 0008
Serial number: 20240411060604084254
33295 - Implausible Data Received from Battery Energy Control Module 2
U0413 00 [00100000] - -
[Control module 2 for battery energy management implausible signal]
Reset counter: 22
Mileage: 29098 km
Date: 2026.09.17
Time: 20:28:53
Engine speed: 16383.75 /min
Normed load value: 100.0 %
Coolant temperature: 215 °C
Intake air temperature: 215 °C
Ambient air pressure: 2550 mbar
Voltage terminal 30: 12.265 V
Unlearning counter according OBD: 22
Current of H-V / hybrid battery: 0.0 A
Power electronics: traction network voltage: 364.3 V
Rear axle: maximum mechanical power: 0.0 kW
Outside temperature: 15.0 °C
Driver intention torque: 0.0 Nm
Hybrid batt charge cond act val standardized: 62.00 %
Address 03: ABS Brakes (J104) Labels: 1EA-614-517-V2.clb
Part No SW: 1EA 907 379 BQ HW: 1EA 614 517 M
Component: ESC-ZF_EBC470 H18 0754
Serial number: 0000000 Dataset Number: V03935436FR 0001 CVN: 5D980B
Coding: 6810438404815902430B990000B78C00250090614000
ASAM Dataset: EV_BrakeZFESCMEBUNECE 001035
ROD: EV_BrakeZFESCMEBUNECE_001.rod
VCID: 0D40484ADDDF5E42907-8058 SFD+SFD2 [x]
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 N HW: 5WA 959 436 N
Component: Kessy IOBOX 122 0757
Serial number: --------------- Dataset Number: V03935383MW 0001
ASAM Dataset: EV_Kessy37w 005030
ROD: EV_Kessy37w_005_VW38.rod
VCID: 5F9C420247B39CD2B2B-800A
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 1N3 959 760 H HW: 1N3 959 760 H
Component: MEM-BFS 011 0571
Serial number: 2441901KA05354 Dataset Number: V03935380RK 0001
Coding: 0118BA4000012A008803010101010000000000000000000000000000211000
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
VCID: 3E22DF86A0F9B5DAD9D-806A
Address 08: Auto HVAC (J979) Labels:* None
Part No SW: 1EE 907 007 C HW: 1EE 907 007 B
Component: Climatronic H01 0247
Serial number: 115052405342550 Dataset Number: V03935419BZ 0001
Coding: 30202204A010120010200010111001102000102110201001000100000000
ASAM Dataset: EV_ACClimaBHBE3ADV 002051
ROD: EV_ACClimaBHBE3ADV_002_VW41.rod
VCID: 3530C0AA95CF7682087-8060 SFD+SFD2 [x]
Interior temperature sensor:
Subsystem 1 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00002280424140615503
Air quality sensor:
Subsystem 2 - Part No SW: 5Q0 907 659 D HW: 5Q0 907 659 D
Component: G238 _AQS H02 0003
Serial number: 00000000010000275679
A/C compressor sub:
Subsystem 3 - Part No SW: 1EA 816 797 G HW: 1EA 816 797 G
Component: J842 eKK H09 0005
Serial number: 1EA816797G15042410Q1
Auxiliary Heater Control Module/PTC 2:
Subsystem 4 - Part No SW: 1EA 963 581 E HW: 1EA 963 581 E
Component: 0123456789012 020 0172
Serial number: T745647BB24141000104
Subsystem 5 - Part No SW: 1EA 820 021 B HW: 1EA 820 021 B
Component: J126 J126 001 0001
Serial number: 00000000000000000151
Expansion valve 1 for refrigerant:
Subsystem 6 - Part No SW: 1EA 816 590 A HW: 1EA 816 590 A
Component: N636 EV1_KaMi H17 0020
Serial number: 01500387230707110290
Subsystem 7 - Part No SW: 4M0 959 603 F HW: 4M0 959 603 F
Component: G395 pT-Sens1 H15 0015
Subsystem 8 - Part No SW: 11A 907 049 HW: 11A 907 049
Component: E265 KPH H02 0183
Serial number: G07S25.04.2400973255
327939 - Motor for Left Temperature Flap
B108C 13 [00100000] - Open Circuit
Reset counter: 36
Mileage: 29494 km
Date: 2026.09.28
Time: 09:41:45
Voltage terminal 30: 14.10 V
Inside temperature: 20.60 °C
Outside temperature: 16.00 °C
Left temperature flap - actual value: 233
Left temperature flap - actual value: 7.0 %
Temperature door left - Specified value: 391
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 1EE 937 089 B HW: 1EE 937 089
Component: SAM_H H08 0555
Serial number: 01102413501018- Dataset Number: V03935437F 0001
ASAM Dataset: EV_SAMVW31x 006001
ROD: EV_SAMVW31x_006.rod
VCID: 41D8A47AD107CA22A4F-8014 SFD [x]
Subsystem 1 - Part No SW: 14A 955 119 HW: 14A 955 119
Component: WISCHER_MYJTL 004 0114
Serial number: VSCCHA23042403008277
Wiper motor control unit 2:
Subsystem 2 - Part No SW: 14A 955 120 HW: 14A 955 120
Component: FWISCHER_SL02 004 0114
Serial number: VSCCHA07052404007080
Subsystem 3 - Part No SW: 89A 955 555 A HW: 89A 955 555 A
Component: G397_RLFSS 004 0005
Serial number: MRO71331012400010755
Subsystem 4 - Part No SW: 10A 941 193 R HW: 10A 941 193 R
Component: LiSi H04 0515
Serial number: RRB71529042400025971
Subsystem 5 - Part No SW: 14A 953 509 HW: 14A 953 509
Component: DiETa H06 0026
Serial number: LZH 8BS00136365
Subsystem 6 - Part No SW: 5H0 959 569 C HW: 5H0 959 569 C
Component: DACHKONSOLE 101 0104
Serial number: 000000092661XEB00405
Valve block 1 in front seat driver side:
Subsystem 7 - Part No SW: 14A 881 643 B HW: 14A 881 643 B
Component: J873 MKS_FSv H02 0152
Serial number: 7009362240C241600341
Valve block 1 in front seat passenger side:
Subsystem 8 - Part No SW: 14A 881 643 B HW: 14A 881 643 B
Component: J872 MKS_BFSv H02 0152
Serial number: 7009362240C241601674
1074806 - Databus
U1123 00 [00101000] - Received Error Message
[ICAS1_Gateway Datenbus empfangener Fehlerwert]
Fault Frequency: 25
Reset counter: 35
Mileage: 29173 km
Date: 2026.09.19
Time: 13:33:20
Terminal 15 status: OFF
Terminal 50 status: OFF
Status drive readiness: not ready to drive
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Operating State: Normal mode
Voltage: 12.4 V
Outside temperature: 17.5 °C
Light switch position: automatic
15401472 - Secure Onboard Communication
U14FF 00 [01100100] - Signature Generation Failed
[Sichere on-board Kommunikation: Signaturerstellung fehlgeschlagen]
Reset counter: 17
Mileage: 29004 km
Date: 2026.09.16
Time: 15:33:32
Terminal 15 status: On
Voltage: 14.5 V
Outside temperature: 19.0 °C
8667507 - Databus
U1121 00 [00101110] - Missing Message
[BMS_07 Datenbus fehlende Botschaft]
Fault Frequency: 82
Reset counter: 39
Mileage: 29026 km
Date: 2026.09.17
Time: 09:25:55
Voltage: 12.3 V
Outside temperature: 14.5 °C
Address 10: Park/Steer Assist (J446) Labels:| 1EE-919-300.clb
Part No SW: 1EE 919 300 B HW: 1EE 919 300
Component: RPA12K H01 0630
Serial number: 000008042494630 Dataset Number: V03935417BX 0001
Coding: 0238026101
ASAM Dataset: EV_EPHBO3CVW4130000 001014
ROD: EV_EPHBO3CVW4130000.rod
VCID: 3334FEB29BBB68B2263-8066
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 1EA 907 567 B HW: 1EA 907 819
Component: ARS512VW13 H05 0232
Dataset Number: V03935435JU 0001
Coding: 06831AE3407140441257400800C040C52F4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARCONTIVW310 004013
ROD: EV_FRONTRADARCONTIVW310.rod
VCID: 3B24D692B3EBA0F2FE3-806E SFD+SFD2 [x]
209054 - Databus
[FAULT_BV_BLINDNESS_ERROR]
Reset counter: 37
Mileage: 29526 km
Date: 2026.09.30
Time: 06:15:44
Address 15: Airbags (J234) Labels:* 3WA-959-655.clb
Part No SW: 3WA 959 655 AA HW: 3WA 959 655 AA
Component: Airbag VW50 006 0151
Revision: -------- Serial number: 003C0T5CA4HA9P Dataset Number: V03935437UR 0001
Coding: 88CC008000F0C0000000C0200000000091540000A1540000C000F680C02B0065
Shop #: WSC 00015 015 00574
ASAM Dataset: EV_AirbaVW50TS6VW49X 001001
ROD: EV_AirbaVW50TS6VW49X.rod
VCID: 14765D2EFEF58F8A5F9-8040 SFD+SFD2 [x]
Left seat belt tensioner:
Subsystem 1 - Part No SW: 85E 980 945 D HW: 85E 980 945 D
Component: BeltPretRevFL 002 3040
Serial number: 14B857705A0131Y00682
Right seat belt tensioner:
Subsystem 2 - Part No SW: 85E 980 946 D HW: 85E 980 946 D
Component: BeltPretRevFR 002 3040
Serial number: 14B857706A0131Y00376
Subsystem 3 - Part No SW: ----------- HW: 654 001 402 24
Component: SideSensor_Df 010 0887
Serial number: 3570000473890D255870
Subsystem 4 - Part No SW: ----------- HW: 654 002 302 24
Component: SideSensor_Pf 010 0887
Serial number: 3580000FC4890F50626C
Subsystem 5 - Part No SW: ----------- HW: 654 000 804 24
Component: SideSensor_Dr 040 0148
Serial number: 351005068C6BF78FE850
Subsystem 6 - Part No SW: ----------- HW: 654 000 804 24
Component: SideSensor_Pr 040 0148
Serial number: 35200507CC6BF791669U
Subsystem 7 - Part No SW: ----------- HW: 654 000 202 24
Component: FrontSensor_D 030 010A
Serial number: 355005066C87D397889S
Subsystem 8 - Part No SW: ----------- HW: 654 000 202 24
Component: FrontSensor_P 030 010A
Serial number: 35600509523FE4920769
Subsystem 9 - Part No SW: ----------- HW: 654 001 703 24
Component: PedP_Sensor_D 010 014A
Serial number: 228005094C47010E87A7
Subsystem 10 - Part No SW: ----------- HW: 654 001 603 24
Component: PedP_Sensor_P 010 014A
Serial number: 229005096C6BF784260I
Subsystem 11 - Part No SW: ----------- HW: 654 002 712 22
Component: PedP_Sensor_C 070 014A
Serial number: 23000509724F49D26A8D
Subsystem 12 - Part No SW: ----------- HW: 654 800 803 24
Component: PedPSensor_D2 010 0887
Serial number: I0M0000053DD3784381M
Subsystem 13 - Part No SW: ----------- HW: 654 800 803 24
Component: PedPSensor_P2 010 0887
Serial number: I0N0000053D117844C1E
Crash sensor for side airbag: B-pillar: driver side:
Subsystem 14 - Part No SW: ----------- HW: 654 000 804 24
Component: Side_Sens_B_D 040 0148
Serial number: I0P005092C6BF792AAFR
Crash sensor for side airbag: B-pillar: passenger side:
Subsystem 15 - Part No SW: ----------- HW: 654 000 804 24
Component: Side_Sens_B_P 040 0148
Serial number: I0Q0050A2CA8D38C436B
Address 16: Steering wheel (J527) Labels: 1EE-953-507.clb
Part No SW: 1EE 953 507 D HW: 1EE 953 507 D
Component: GSMMEB 005 0067
Serial number: 000000100524260
ASAM Dataset: EV_SMLSKLOGEN2 009005
ROD: EV_SMLSKLOGEN2_009_VWE3.rod
VCID: 3C26D58EB6E5A7CAF79-8068 SFD [x]
Address 19: CAN Gateway (J533) Labels: 1EE-937-012.clb
Part No SW: 1EE 937 012 K HW: 1EE 937 012
Component: ICAS1 Host-SG 021 0711
Serial number: SMERBG150524006 Dataset Number: V03935439ZH 0001
GVL: 2D08080006C8D0FC8062904248180040C000200001060000040200000000DE57
ASAM Dataset: EV_GatewICAS1MEBUNECE 001024
ROD: EV_GatewICAS1MEBUNECE_VWE2.rod
VCID: 3C26D58EB6E5A7CAF79-8068 SFD+SFD2 [ ]
Subsystem 1 - Part No SW: 1EE 915 181 HW: 1EE 915 181
Component: J367-BDMConti H05 1076
Serial number: 78561200002404050376
Subsystem 2 - Part No SW: 3G0 959 542 B HW: 3G0 959 542 B
Component: J IEEHOD1ZONE 251 0303
Serial number: 00000000230201226831
Left taillight 1:
Subsystem 3 - Part No SW: 14B 945 423 HW: 14B 945 423
Component: SBBR-LINKS1 H01 0001
Serial number: 3000000001100L000411
Left taillight 2:
Subsystem 4 - Part No SW: 14B 945 429 HW: 14B 945 429
Component: SBBR-LINKS2 H03 0001
Serial number: 3000000001300L000051
Right taillight 1:
Subsystem 5 - Part No SW: 14B 945 424 HW: 14B 945 424
Component: SBBR-RECHTS1 H01 0001
Serial number: 3000000001200R000045
Right taillight 2:
Subsystem 6 - Part No SW: 14B 945 430 HW: 14B 945 430
Component: SBBR-RECHTS2 H03 0001
Serial number: 3000000001300R000034
Subsystem 7 - Part No SW: 5Q0 951 172 C HW: 5Q0 951 172 C
Component: Sensor, DWA 006 0501
Serial number: 0000000000000Q3G95AT
Subsystem 8 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000004294055
Power rear lid opening control module:
Subsystem 9 - Part No SW: 3G0 962 243 D HW: 3G0 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 45130056
12 Faults Found:
7467521 - Data Set Implausible
B2012 00 [00101111] - -
[Data_set_implausible_CMS]
Mileage: 29004 km
Date: 2026.09.16
Time: 14:37:37
7467522 - Data Set Implausible
[Data_set_implausible_HLC]
Mileage: 29004 km
Date: 2026.09.16
Time: 14:37:37
8491266 - Secure Onboard Communication
U14FE 00 [00101110] - Signature Verification Failed
[SOK_signature_verification_failed]
Fault Frequency: 85
Mileage: 29026 km
Date: 2026.09.17
Time: 04:15:15
B184C 00 [00100111] - -
[Unlock_protection_of_vehicle_diagnosis_active]
Mileage: 29546 km
Date: 2026.09.30
Time: 14:53:14
2166908 - Control Module for Electric Drive Power Output
U0110 00 [00100000] - No Communications
Reset counter: 23
Mileage: 29098 km
Date: 2026.09.17
Time: 20:29:59
Installation list: specified installations: 2D 08 08 00 06 C8 D0 FC 80 62 90 42 48 18 00 40 C0 00 20 00 01 06 00 00 04 02 00 00 00 00 DE 57
Installation list: current installations: 2D 08 08 00 06 C8 D0 3C 00 22 90 00 48 08 00 40 C0 00 20 00 01 06 00 00 00 02 00 00 00 00 DE 53
8515671 - High-Voltage Safety
B18C6 F0 [01100100] - Emergency Shutdown Requested
[HVLM_emergency_shut_down_hv_safety]
Reset counter: 26
Mileage: 29173 km
Date: 2026.09.20
Time: 09:08:13
8516869 - External Charging Infrastructure
P1DCB 00 [01101100] - Not Ready for Charging Socket 1
[HVLM_unknown_cp_communication_a]
Reset counter: 35
Mileage: 29424 km
Date: 2026.09.26
Time: 04:53:15
8516881 - Charging Socket 1
P1DD3 00 [01100100] - Connector Locking Status Faulty
[HVLM_error_plug_lock_status_a]
Reset counter: 27
Mileage: 29219 km
Date: 2026.09.21
Time: 09:40:46
8397829 - Low-Voltage Energy Management
U192F 00 [00101000] - Autonomous 12 V Convenience Functions Limited
[Nvem_autonomous_12V_convenience_functions_limited]
Reset counter: 23
Mileage: 29098 km
Date: 2026.09.17
Time: 20:28:29
NVEM: autonomous 12-V convenience functions limited: 4352
8830976 - Databus for Virtual Remote Control Key
U1A2F 00 [00100000] - Single Wire Mode
[Data_bus_mdk_single_wire_mode]
Reset counter: 35
Mileage: 29098 km
Date: 2026.09.17
Time: 19:11:14
8417280 - Diagnostic Filter
U17A0 00 [00100111] - Not Activated
[Filter_is_not_active]
Mileage: 29546 km
Date: 2026.09.30
Time: 14:53:15
15361792 - Data Set Implausible
[Data_set_implausible_MDK_CCC]
Mileage: 29004 km
Date: 2026.09.16
Time: 14:37:38
Address 23: Brake Booster (J539) Labels: 1EA-909-059-V2.clb
Part No SW: 1EA 909 059 BG HW: 1EA 909 059 Q
Component: EBB-ZF-Gen1 H33 0853
Serial number: ÿÿÿÿÿÿÿ Dataset Number: V03935435CU 0001
Coding: 60302040300028
ASAM Dataset: EV_BrakeBoostZFMEBUNECE 001034
ROD: EV_BrakeBoostZFMEBUNECE_001.rod
VCID: 005E617E9A8D032AEB1-8054 SFD+SFD2 [x]
Address 2B: Steer. Col. Lock (J764) Labels:. 3WA-905-861.clb
Part No SW: 3WA 905 861 HW: 3WA 905 861
Component: ELV-MQB_UNECE H05 0063
Serial number: 24000116288004 Dataset Number: V03935370PA 0001
Coding: 8880000000000000
Shop #: WSC 00015 015 00547
ASAM Dataset: EV_ELVMarqUNECE 003006
ROD: EV_ELVMarqUNECE_003_VW27.rod
VCID: 084E795EB2BD3B6AA31-805C SFD+SFD2 [x]
Component: MEM-FS 011 0571
Serial number: 2441901KA04713 Dataset Number: V03935379EA 0001
Coding: 0118BA4000012A008803010101010000000000000000000000000000215000
Address 3C: Lane Change (J1086) Labels:* Redir Fail!
Part No SW: 2Q0 907 686 H HW: 2Q0 907 686 H
Component: HRE_Master H26 0320
Serial number: 14520044821074 Dataset Number: V03935407CY 0001
Coding: 6AA54750
ASAM Dataset: EV_HREHellaGen3MstrUNECE 001001
ROD: EV_HREHellaGen3MstrUNECE_VW27.rod
VCID: 3FDCA282A7F3BCD2D2B-806A
Subsystem 1 - Part No SW: 2Q0 907 685 H HW: 2Q0 907 685 H
Component: HRE_Slave H26 0320
Serial number: 14520046870067
Address 42: Door Elect, Driver (J386) Labels:* Redir Fail!
Part No SW: 1EA 959 593 H HW: 1EA 959 593 F
Component: TSG FS 009 0571
Serial number: 0000528354080 Dataset Number: V03935471 0001
Coding: 0035DA20DE000480A6009030
ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001004
ROD: EV_DCU3DriveSideMAXHCONT.rod
VCID: 47CCBA62FF23F4126AB-8012
Door operating panel: driver side:
Subsystem 1 - Part No SW: 10A 959 862 AQ HW: 10A 959 862 AQ
Component: EX36 TBF_FS H22 0110
Serial number: 0692-07.05.24-------
Address 44: Steering Assist (J500) Labels: Redir Fail!
Part No SW: 1EB 907 164 F HW: 1EB 907 164 B
Component: EPS_ECU 450 4305
Serial number: 000008.09.23000 Dataset Number: V03935426LP 0001
Coding: 000000000000020100000201010001000000010001010001
ASAM Dataset: EV_SteerAssisNSKGEN4MEB 006009
ROD: EV_SteerAssisNSKGEN4MEB.rod
VCID: 3928CC9AB9D792E2ECF-806C SFD+SFD2 [x]
Address 51: Electric Drive (J841) Labels: 0ET-907-INV-V1.clb
Part No SW: 0ET 907 121 AH HW: 0ET 907 121 D
Component: MEB INV6.0 H10 7302
Dataset Number: V03935396ZD 0001
ASAM Dataset: EV_DMCM21000110ET907121AH 001001
ROD: EV_DMCM21000110ET907121AH_VWE3.rod
VCID: 06527766B8A92D1AD1D-8052 SFD+SFD2 [x]
41631 - No Communication with ESP (Vehicle Dynamics) Control Module
U0122 00 [00100000] - -
[Lost Communication With Vehicle Dynamics Control Module]
41657 - Implausible Data Received from Engine Control Module
U0401 00 [00101000] - -
[Invalid Data Received From ECM/PCM "A"]
Reset counter: 38
Mileage: 29144 km
Date: 2026.09.19
Time: 09:56:08
43408 - Online Remote Update
U192A 00 [00101100] - No Signal
[Online Remote UpdateNo signal]
Fault Frequency: 146
Mileage: 29098 km
Date: 2026.09.17
Time: 21:55:23
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 1EA 959 592 H HW: 1EA 959 592 F
Component: TSG BFS 009 0571
Serial number: 0000528448332 Dataset Number: V03935471AF 0001
Coding: 00355020DE000480A2809030
ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001004
ROD: EV_DCU3PasseSideMAXHCONT.rod
VCID: 46D2B766F829ED1A91D-8012
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 10C 035 816 B HW: 10C 035 816 A
Component: IC3GSF-AR--EU H09 3612
Dataset Number: V03935425YS 0001
Coding: 24121030000000000000000000000000000000000000000000
ASAM Dataset: EV_MUICASSAFEPart 002001
ROD: EV_MUICASSAFEPart_002_VWE3.rod
VCID: 1D60380A0D3FCEC2E07-8048 SFD+SFD2 [x]
Subsystem 1 - Part No SW: 1T3 919 606 H HW: 1T3 919 606
Component: ABT-E3_15 H52 7046
Serial number: TPO00126112315010702
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H2 907 383 D HW: 5H2 907 383
Component: Anhaenger H12 0204
Serial number: 000000000006451 Dataset Number: V03935340SJ 0001
Coding: 0100000202001400
ASAM Dataset: EV_TrailFunctG3MPFMHella 001009
ROD: EV_TrailFunctG3MPFMHella_VW27.rod
VCID: 3138F4BA61A75AA254F-8064 SFD+SFD2 [x]
Address 6C: Back-up Cam. (J928) Labels:| 5WA-980-556.clb
Part No SW: 1EE 907 556 A HW: 5WA 907 556 D
Component: TV eEntry H32 0605
Serial number: FZ6ESP080524000 Dataset Number: V03935434ND 0001
Coding: 020380003F140080
ASAM Dataset: EV_CamSysTVFicosUNECE 002004
ROD: EV_CamSysTVFicosUNECE_VWE3.rod
Front peripheral camera slave:
Subsystem 1 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R243 UmfKamSV H23 0070
Serial number: FCLMAR100524000709DD
Peripheral camera slave: left:
Subsystem 2 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R244 UmfKamSL H23 0070
Serial number: FCLMAR25042401060277
Right peripheral camera slave:
Subsystem 3 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R245 UmfKamSR H23 0070
Serial number: FCLMAR200424000512E9
Part No SW: 4KE 959 107 B HW: 4KE 959 107 B
Component: HDSG-Modul H08 0342
Revision: -------- Serial number: A2-C765-4922-2 Dataset Number: V03935422FB 0001
Coding: 5488
ASAM Dataset: EV_DeckLidCONTIAU536 001006
ROD: EV_DeckLidCONTIAU536_001_VWE4.rod
VCID: 45D0B06AC52FE602987-8010
Part No SW: 14A 035 284 A HW: 14A 035 284
Component: OCU4MEB_UNECE H11 0554
Serial number: 0000000401VILZL Dataset Number: V03935438KZ 0001
Coding: 02010700010000000000010013000000101112111012000010
ASAM Dataset: EV_OCUGen4UNECE 001050
ROD: EV_OCUGen4UNECE.rod
1375744 - Secure Onboard Communication
U14FE 00 [00100000] - Signature Verification Failed
Reset counter: 27
Mileage: 29119 km
Date: 2026.09.18
Time: 05:54:43
1375488 - Secure Onboard Communication
U14FD 00 [00101000] - Time Server not Available
[SOK_timeserver_not_available]
Reset counter: 39
Address 7E: Ctrl Head Dash (J1254) Labels:* None
Part No SW: 14A 920 441 A HW: 14A 920 441 A
Component: Fahrerdisplay 200 1622
Serial number: 4TUJ00301023000 Dataset Number: V03935429DF 0001
Coding: 500F80
ASAM Dataset: EV_DashBoardALPINEMEB 002014
ROD: EV_DashBoardALPINEMEB.rod
VCID: 1B643612132BC0F21E3-804E SFD+SFD2 [x]
9582602 - Video Cable for Information Electronics 1
B13B9 01 [00100000] - Electrical Failure
Address 82: Head Up Display (J898) Labels: 10B-919-608.clb
Part No SW: 14G 919 608 A HW: 14G 919 608 A
Component: HeadupDisplay H05 0505
Serial number: ARHUD
ASAM Dataset: EV_ARHeadUpDisplMEB 002044
ROD: EV_ARHeadUpDisplMEB_002.rod
VCID: 2E02EFC67099455A49D-807A
Address 8C: HV Battery (J840) Labels: 0Z1-915-184.clb
Part No SW: 0Z1 915 184 AE HW: 0Z1 915 184 D
Component: J840 K8C BMC 010 1141
Serial number: 000000040324010 Dataset Number: V03935430CT 0001 CVN: 30DE26FF00000000384B0A12384B0A12384B0A12
ASAM Dataset: EV_BMCeVWBSMEB 003018
ROD: EV_BMCeVWBSMEB_003_VWE3.rod
VCID: 7DA0188AED7F6EC2807-8028
Cell module control module 1:
Subsystem 1 - Part No SW: 0Z1 915 140 M HW: 0Z1 915 140 D
Component: SX6 X74 CMC 005 1140
Serial number: 00000024042401062565
Cell module control module 5:
Subsystem 2 - Part No SW: 0Z1 915 140 M HW: 0Z1 915 140 D
Serial number: 00000024042401062562
Cell module control module 9:
Subsystem 3 - Part No SW: 0Z1 915 140 M HW: 0Z1 915 140 D
Serial number: 00000024042401052564
Coolant heating:
Subsystem 4 - Part No SW: 1EE 963 231 HW: 1EE 963 231
Component: J848 HV-PTC H04 0026
Serial number: 1EE96323124120000715
42865 - Online Remote Update
B199A 00 [00101000] - -
[Diag_F_ORU_Updatemode]
Reset counter: 14
Mileage: 29098 km
Date: 2026.09.17
Time: 20:28:53
Terminal 15 status via CAN: OFF
Mode HV battery actual value: Hybrid battery mode: emergency shutdown
Voltage terminal 30: 12.146 V
H-V battery voltage: 364.250 V
Current of H-V / hybrid battery: -40 °C
Current of H-V / hybrid battery: -0.000 A
Current 2 of H-V / hybrid battery: -0.000 A
maximum voltage for battery cells-Index 1: 0
maximum voltage for battery cells-Value: 3.795 V
minimum voltage for battery cells-Index 1: 0
minimum voltage for battery cells-Value: 3.789 V
Address A5: Frt Sens. Drv. Assist (R242) Labels:* 1EA-980-65X-V2.clb
Part No SW: 1EA 980 653 E HW: 1EA 980 653 A
Component: MEB MFK 4.1 H08 5556
Dataset Number: V03935437DL 0001
Coding: 0008306E1FD100E93F243A2C4000000000000000000000000000000000000000
ASAM Dataset: EV_MFK41ValeoMEB 001080
ROD: EV_MFK41ValeoMEB.rod
1126434 - Module for Camera
C110A F7 [00101000] - Lane Detection View Restricted
[Temporary_blindness_of_lane_detection]
Reset counter: 37
Mileage: 29525 km
Date: 2026.09.30
Time: 06:15:12
Blindness_cause_light_functions: Partial_blockage
Blindness_cause_traffic_sign_control: Partial_blockage
Blindness_cause_error_memory: Partial_blockage
Blindness_cause_pedestrian_detection: Partial_blockage
Blindness_cause_lane_detection: Partial_blockage
Blindness_cause_object_detection: Partial_blockage
Blindness_cause_road_free_detection: Partial_blockage
Blindness_cause_windscreen_heater_request: blockage
Blindness_detection_visibility_range: Blindness_detection_no_visibility
Address BB: Door Rear Drv (J388) Labels:* Redir Fail!
Part No SW: 1EA 959 597 H HW: 1EA 959 597 F
Component: TSG HFS 009 0571
Serial number: 0000513415629 Dataset Number: V03935471AJ 0001
Coding: 0001D02000000480A2009030
ASAM Dataset: EV_DCU3RearDriveMAXHCONT 001004
ROD: EV_DCU3RearDriveMAXHKLO.rod
VCID: 4BC48652E34B10724E3-801E
Address BC: Door Rear Pass (J389) Labels:* Redir Fail!
Part No SW: 1EA 959 596 H HW: 1EA 959 596 F
Component: TSG HBFS 009 0571
Serial number: 0000528397256 Dataset Number: V03935471AG 0001
Coding: 0001D02001000480A2009030
ASAM Dataset: EV_DCU3RearPasseMAXHCONT 001004
ROD: EV_DCU3RearPasseMAXHCONT.rod
VCID: 4ACA8356EC31097A755-801E
Address C0: Act. for Ext. Noise (J943) Labels: None
Part No SW: 14B 035 335 C HW: 1EA 035 335
Component: E_SOUND_SG H06 0005
Serial number: JTK072070524953
ASAM Dataset: EV_ESounHarmaMEBUNECE 001006
ROD: EV_ESounHarmaMEBUNECE.rod
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 1EE 915 684 Q HW: 1EE 915 684 E
Component: HV_CHARGER H65 1026
Serial number: 93286XAF000ET Dataset Number: V03935370KP 0001
Coding: 10C0
ASAM Dataset: EV_OCC2XPhaseKLOMEB01B 001006
ROD: EV_OCC2XPhaseKLOMEB01B_VWE3.rod
VCID: 4DC0884A1D5F1E42507-8018 SFD+SFD2 [x]
3280899 - Charging Station
B1AD0 F0 [00101111] - Identification Failed
[ETHTRCV_30_AR7000_SLAC_STEP_3_PARAM_REQ_Timeout]
Mileage: 29119 km
Date: 2026.09.18
Time: 05:31:50
DID 1DA0: AC main charge
DID 1DAC: Charging
Frequency: 1000 Hz
Control voltage: 6022.0 mV
Pulse duty factor: 28.5 %
Activation charge cover lock charge socket A: not requested
Lock for high-voltage charging connector: locked
Status connect. recognition: detected
Charging socket temperature sensor AC: 30.0 °C
Temperature sensor 1: resistance value: 1029 Ohm
DID 15E2: 18.0 °C
DID 081C: 1921 W
DID 081D: 18 W
DID 081E: 1 W
DID 0286: 14.8 V
DID 497C: not active
DID 537A: 14.3 V
DID 1525: 1952 mV
DID 4219: high-voltage de-energization not detected
DID 5372: 16.0 °C
No. of lockings: 1430
No. of connections: 354
Number of successful charging connector locks: 652
Wake-up counter: contact (proximity): 0
Wake-up counter: Control Pilot: 0
Charging standard abort: status: not active
Loading plan: status: Not available
Price/performance table: status: Not available
Transport Layer Security (TLS) status communication: not active
DID 103A: supported
number_evse_slac: 0
PLC_modem_status: active
number_slac_attemps: 1
DID 1033: SLAC_active
DID 1038: no_description
DID 1039: supported
Target HV charge current: 14.4 A
Powerline communication: charging process status: Standby
14750981 - Charging Socket 1
P1CF6 00 [01100000] - Unlock Prohibited
[Plug_unlocking_error]
14752805 - High-Voltage Battery Charger
U19FF 00 [00100000] - Non Standards Compliant Network Connection Detected
[grid_configuration_not_standard_compliant]
Reset counter: 9
Mileage: 29368 km
Date: 2026.09.24
Time: 10:00:38
DID 1DAC: Charging
Temperature sensor 1: resistance value: 1024 Ohm
DID 15E2: 17.0 °C
DID 0286: 14.7 V
DID 537A: 14.3 V
Phase 1: 225 V
Phase 2: 0 V
Phase 3: 230 V
DID 082B: 3.9 V
DID 082C: Malfunction
Phase 1: 224.8 V
Phase 2: 143.8 V
Phase 3: 229.8 V
Actual phase angle L1 – L2: 362 °
Actual phase angle L1 – L3: 234 °
Actual phase angle L2 – L3: 362 °
Network mode: Two phases
Charging start status: active
Part No SW: 992 941 592 AG HW: 992 941 592 A
Component: LED1L H17 9104
ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
VCID: 6A8A23D68CF1E97A555-803E
Component: LED1R H17 9104
ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address DE: Charger 1 for mobile dev (J0000) Labels:* None
Part No SW: 3P0 035 502 B HW: 3P0 035 502
Component: COUPLING BOX 004 0170
Serial number: 324000000000017 Dataset Number: V03935426MT 0001
Coding: 400080
ASAM Dataset: EV_DualCouplBoxSK336 001006
ROD: EV_DualCouplBoxSK336.rod
VCID: 24160DEE2E55FF0AAF9-8070 SFD+SFD2 [x]
Address 8105: DC/DC Converter 12V (A19) Labels: 1EA-907-190-V2.clb
Part No SW: 1EA 907 190 R HW: 1EA 907 190 M
Component: DCDC Gen4 H52 1354
Revision: 00H52000
ASAM Dataset: EV_DCDC2101011VW31X 001030
ROD: EV_DCDC2101011VW31X.rod
VCID: 43D4AE72CB1BD832B63-8016 SFD+SFD2 [x]
Address 8107: Antenna (J666) Labels:* None
Part No SW: 1EA 035 741 L HW: 1EA 035 741 F
Component: TrxModulBasic H04 0522
Dataset Number: V03935426AC 0001
Coding: 0231210101010002000001010101010101000000
ASAM Dataset: EV_TrxMLGEMEB31 001026
ROD: EV_TrxMLGEMEB31_VWE3.rod
VCID: 372CCAA28FC384921AB-8062 SFD+SFD2 [x]
1375488 - Communication Authentication
U3036 00 [01100000] - Signal Malfunction
1375744 - Communication Authentication
U3035 00 [01101000] - Invalid Signal
Reset counter: 33
Mileage: 29525 km
Date: 2026.09.29
Time: 21:11:07
Failed verification status: valid
Number of failed verifications: 11
Verification failed: 00 08
Address 8117: Rear surroundings cam (J772) Labels:* None
Part No SW: 1EA 980 568 C HW: 1EA 980 568 B
Component: RV eSmart H20 0425
Serial number: FCLK20230524000 Dataset Number: V03935434M 0001
Coding: 0203800027140080
ASAM Dataset: EV_AVCamerRearFicosUNECE 004031
ROD: EV_AVCamerRearFicosUNECE_004_VWE3.rod
VCID: 3E22DF86A0F9B5DAD9D-806A SFD+SFD2 [x]
Address 811E: Burglary Protection FL (J518) Labels: 5WA-962-133.clb
Part No SW: 5WA 962 133 E HW: 5WA 962 133 E
Component: Kessy RSAD 122 0756
ASAM Dataset: EV_RSADVL37w 004018
ROD: EV_RSADHR37w_004_VW38.rod
Address 811F: Burglary Protection FR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADVR37w 004018
Address 8120: Burglary Protection RL (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHL37w 004018
ROD: EV_RSADHL37w_004_VW38.rod
Address 8121: Burglary Protection RR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHR37w 004018
Address 8123: App server 1 system 1 adaptive (SWC4) Labels: V04-007-XXX-SWC4.clb
Part No: V04 007 009 JP
Component: ICAS1 Sys_Ada 0711
Dataset Number: V03935433DL 0001
ASAM Dataset: EV_AppServ1Sys1ICAS1UNECE 001006
ROD: EV_AppServ1Sys1ICAS1UNECE.rod
Address 8124: App server 1 system 2 Java (SWC5) Labels: V04-007-XXX-SWC5.clb
Part No: V04 007 009 JQ
Component: ICAS1 Sys_Jav 0711
Dataset Number: V03935433MX 0001
ASAM Dataset: EV_AppServ1Sys2ICAS1UNECE 001009
ROD: EV_AppServ1Sys2ICAS1UNECE.rod
VCID: 0550706A85AF2602D87-8050 SFD+SFD2 [x]
8478976 - OTA Update
B199A F0 [01101100] - Software Version Inconsistent
Mileage: 29098 km
Date: 2026.09.17
Time: 20:28:20
Address 8125: App server 3 system 1 infotaint. (SWC6) Labels:| V04-007-XXX-SWC6.clb
Part No: V04 007 003 RG
Component: IC3GIVI-D--EU 3612
Dataset Number: V03935440NS 0001
ASAM Dataset: EV_MUICASIVIPart 003001
ROD: EV_MUICASIVIPart_003_VWE3.rod
VCID: 7DA0188AED7F6EC2807-8028 SFD+SFD2 [x]
1872 - Automotive Audio Bus (A2B)
B1994 F4 [00001000] - Microphone Module Defective
[a2b_bus_micro_defect]
Fault Frequency: 77
Mileage: 29004 km
Date: 2026.09.16
Time: 15:06:41
Voltage terminal 30: 14.5 V
amount_of_nodes: 2
Node number: 1
Node name: Emergency call module and communication unit
Node status: OK
Address 8128: Light line display (J145) Labels: 1T3-919-451.clb
Part No SW: 14A 919 451 C HW: 14A 919 451 C
Component: ID_Light_GA 033 0064
ASAM Dataset: EV_SmartLight1MEBGA 001014
ROD: EV_SmartLight1MEBGA.rod
VCID: 261217E658690D1AB1D-8072 SFD+SFD2 [x]
Address C002: SW Cluster Embedded (SWC2) Labels: V04-007-XXX-SWC2.clb
Part No: V04 007 009 JR
Component: ICAS1 SWCL_Em 0711
Dataset Number: V03935434JA 0001
ASAM Dataset: EV_SWCLEmbed1ICAS1UNECE 001011
ROD: EV_SWCLEmbed1ICAS1UNECE.rod
13706049 - Databus
U1123 00 [00100100] - Received Error Message
[WLA_Blindheit received error value]
Mileage: 29525 km
Date: 2026.09.30
Time: 06:14:52
Address C003: SW Cluster Housekeeping (SWC3) Labels: V04-007-XXX-SWC3.clb
Part No: V04 007 009 JS
Component: ICAS1 SWCL_HK 0711
ASAM Dataset: EV_SWCLHouse1ICAS1UNECE 001007
ROD: EV_SWCLHouse1ICAS1UNECE.rod
VCID: 074C7A62BFA33412AAB-8052 SFD+SFD2 [x]
End----------(Elapsed Time: 02:41, VBatt start/end: 14.7V/14.7V)-----------
------------------------------34 Faults Found------------------------------
