When I run a diagnostic scan with VCDS, the following errors appear. The one we are interested in is Adress 09(Central. Elec(J519).
Is it normal for the coding to be displayed as ?
Wednesday,30,September,2026,11:57:45:20823
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.5
VIN: WVGZZZ5NZJW362778 License Plate: 19619D8
Mileage: 71633km-44510mi Repair Order:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 29 36 39 42 44 4B 52 5F 6C
BB BC CA D6 D7
VIN: WVGZZZ5NZJW362778 Mileage: 71633km-44510miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRFD) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 CK HW: 04L 907 309 T
Component: R4 2.0l TDI H24 3046
Revision: B7H24--- CVN: BFF15F13
Coding: 0125011203261C002000
ASAM Dataset: EV_ECM20TDI01104L906026CK 004002
ROD: EV_ECM20TDI01104L906026CK_004_VW37.rod
VCID: 75B0388B054423D2C46-8020
VINID: 9E65EAAAA15EA9A9C31821C7200155887E
Part No SW: 0DL 300 012 N HW: 0GC 927 711 G
Component: GSG DQ500 H06 2109
Revision: 00H06V07 CVN: 3AB5C4D0
ROD: EV_TCMDQ500021.rod
VCID: 3436C58F4EBE7ADA338-8060
Part No SW: 5Q0 614 517 CG HW: 5Q0 614 517 AG
Component: ESC H62 0643
Revision: 00000000 Serial number: 62897000001304
Coding: 0AEE6A9A34260B6E477E070762CB4950562CD0E2E046923D20605038C20A4200002F641A1B13111435351919323200
VCID: 78AE31BF12565EBADF0-802C
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NA 907 044 N HW: 5NA 907 044 N
Component: AC Automat H35 4301
Revision: 20K09000 Serial number: 00000E00710178
Coding: 0002012420010000000510401210142A
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ACClimaPrehVW37X 002023
VCID: 4ACABB773C3A1C2A794-801E
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
263425 - Air Quality Sensor
B10AF 04 [00001000] - Internal System Fault
Fault Frequency: 11
Reset counter: 111
Mileage: 71594 km
Date: 2026.09.29
Time: 10:21:53
Outside temperature: 26.5 C
Voltage terminal 30: 12.2 V
Air quality status: Malfunction
Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG
Component: BCM MQBAB H H36 0253
Serial number: 01001731701949 Dataset Number: V03935268HN 0001
ROD: EV_BCMBOSCH_018.rod
VCID: 0948447B79BC5732B0E-805C
Subsystem 1 - Part No SW: 5NB 955 119 HW: 5NB 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 171017 033 0372
Serial number: 00000001710130310685
Component: RLHS 047 0105
Serial number: S5Y17M11D13H22M57S06
Coding: 00A8DD
Serial number: 000000000ZY172830B07
Serial number: 00000000000039649853
264968 - Sensor 2 for interior monitoring
B1332 29 [00001000] - Signal Implausible
Reset counter: 111
Mileage: 71628 km
Date: 2026.09.29
Time: 16:26:37
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beams: Not operated
Voltage: 12.7 V
Outside temperature: 27.5 C
Part No SW: 3Q0 919 298 B HW: 3Q0 919 298
Component: PLA 3.0 12K H09 0029
Serial number: 001810177478041 Dataset Number: V03935263AX 0001
Coding: 0231561011
ASAM Dataset: EV_EPHBO2CVW3260000 010016
ROD: EV_EPHBO2CVW3260000_VW37.rod
VCID: 3C26EDAF66EEB29AFB8-8068
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 005 0336
Serial number: 003VWR3F7G8D Dataset Number: V03935268MW 0001
Coding: 88CCC0000C0000005C5400CF000800000065
Subsystem 1 - Part No SW: ----------- HW: 480 001 411 17
Serial number: 3570000000080BA8192L
Subsystem 2 - Part No SW: ----------- HW: 480 001 411 17
Serial number: 35800000000D65C8292U
Subsystem 3 - Part No SW: ----------- HW: 480 401 411 17
Serial number: 3510001C1272BA84A60/
Subsystem 4 - Part No SW: ----------- HW: 480 401 411 17
Serial number: 3520001C1272BA83D699
Subsystem 5 - Part No SW: ----------- HW: 480 401 311 17
Serial number: 35500019D2825B24D7DH
Subsystem 6 - Part No SW: ----------- HW: 480 401 411 17
Component: PedP_Sensor_D 000 6149
Serial number: 2280001C927CBDB4F21Q
Subsystem 7 - Part No SW: ----------- HW: 480 401 411 17
Component: PedP_Sensor_P 000 6149
Serial number: 2290001C927CBDB484EZ
Subsystem 8 - Part No SW: ----------- HW: 480 401 411 17
Component: PedP_Sensor_C 000 6149
Serial number: 2300001C927CBDB4920C
Subsystem 9 - Part No SW: ----------- HW: 480 000 411 17
Serial number: I0M00000000E1A4D692D
Subsystem 10 - Part No SW: ----------- HW: 480 000 411 17
Serial number: I0N00000000C8CA0492C
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20170603200129
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 3FDC9AA377F8A982DEA-806A
Part No SW: 5NA 920 790 B HW: 5NA 920 790 B
Component: KOMBI 407 3193
Coding: 47AD00082B80000801087B001401000000000000
VCID: 41D89C5B010CDF72A8E-8014
1048578 - No Basic Setting
B2010 00 [00001001] - -
[Steuerger t keine oder falsche Grundeinstellung]
Reset counter: 69
Mileage: 71594 km
Date: 2026.09.29
Time: 10:21:49
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 436 4326
Revision: -------- Serial number: 0007031491 Dataset Number: V03935272MW 0001
Coding: 0105000810087300FB07220A1E0F00000001070000000000000000000000
GVL: 01D63C0000000000401C00000002C80010000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW37.rod
VCID: 382EF1BF52D69EBA1F0-806C
Generator:
Subsystem 2 - Part No SW: 5TA 959 442 A HW: 5TA 959 442 A Labels: 3C8-959-537.CLB
Serial number: 2831708211701049AN2B
Coding: 290000
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00015.09.17 Dataset Number: v1260x015G0 0000
Coding: 0101
VCID: 4CC6BD6F364E021A4B8-8018
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
VCID: 45D0884B1524F352946-8010
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0023
Serial number: Y0006QK123880
Coding: 0010000200000400018281808181000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002021
ROD: EV_SeatMemorDriveSide_VW37.rod
VCID: 3D20E0AB7DF4BB92CC6-8068
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-DCD-V1.clb
Component: TSG FS 020 0041
Serial number: 311017EJT32477 Dataset Number: V03935272D0001
Coding: 003F0220D200040000001000
VCID: 43D496531B10CD62BA2-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0002151985 Dataset Number: V03935272SQ 0001
Coding: 01010010000001
ROD: EV_SteerAssisVWBSMQBA_009.rod
VCID: 40DE995F0A06D67AA70-8014
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 02111710803787 Dataset Number: V03935262L 0001
Coding: 000000050100085200000F000A0000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_001_VW37.rod
VCID: 72BA0397742A34EAE14-8026
Component: TSG BFS 020 0041
Serial number: 291017EJS34203 Dataset Number: V03935272CZ 0001
Coding: 003F0020DE00040000001000
VCID: 42DA9357040AC46AB14-8016
Part No SW: 3Q0 035 864 C HW: 3Q0 035 864 C
Component: MU-S-N-ER 853 0891
Serial number: Dataset Number: V03935311FY 0001
Coding: 02730601FF0000005111000100080A001F0506F4012000008E
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 3138CC9BB1AC4FF258E-8064
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H50 8130
Serial number: VWZ6ZJT3071908
Subsystem 2 - Part No SW: V03 959 822 NA HW: -----------
Component: MRM3 2025/26 --- 2410
1553 - Function Restriction
B200D F0 [00001001] - due to Internal Communcations Error
[Function restriction due to internal communication error: optical drive (fitted)]
Reset counter: 69
Mileage: 71594 km
Date: 2026.09.29
Time: 10:21:49
0522 - Front Left Bass Speaker
B105F 13 [00001001] - Open Circuit
[Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
Reset counter: 69
Mileage: 71594 km
Date: 2026.09.29
Time: 10:21:52
7195 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 69
Mileage: 71594 km
Date: 2026.09.29
Time: 10:21:52
Voltage terminal 30: 12.0 V
BAP-BAP_Function_ID: 02
7219 - Function Restricted due to Missing Message(s)
[Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 69
Mileage: 71594 km
Date: 2026.09.29
Time: 10:21:53
7223 - Function Restricted due to Missing Message(s)
[ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 69
Mileage: 71594 km
Date: 2026.09.29
Time: 10:21:53
Component: RVC Compact H12 0231
Dataset Number: V03935254KA 0001
Coding: 0123060122002017000040
VCID: 3928F4BB69DC87B2E0E-806C
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V1.clb
Component: TSG HFS 020 0041
Serial number: 011117EK116522 Dataset Number: V03935272CS 0001
Coding: 002A00200101040000001000
ROD: EV_DCURearDriveMAXCONT_VW37.rod
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V1.clb
Component: TSG HBFS 020 0041
Serial number: 011117EK105009 Dataset Number: V03935272CV 0001
ROD: EV_DCURearPasseMAXCONT_VW37.rod
65578 - Motors for Central Locking
B122B 12 [00001001] - Short to Plus
Reset counter: 70
Mileage: 71604 km
Date: 2026.09.29
Time: 11:07:19
65579 - Motors for Central Locking
B122B 11 [00001001] - Short to Ground
Reset counter: 70
Mileage: 71604 km
Date: 2026.09.29
Time: 11:07:19
65593 - Switch for Central Locking
B122D 29 [00001001] - Signal Implausible
Reset counter: 70
Mileage: 71613 km
Date: 2026.09.29
Time: 11:51:27
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Dataset Number: V03935259XS 0001
Coding: 008040732602
ROD: EV_SunRoofCONTIAU736_006_VW37.rod
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 16721F07380288CA2DC-8042
Component: LED1R H09 0003
End----------(Elapsed Time: 01:58, VBatt start/end: 12.7V/12.5V)-----------
------------------------------11 Faults Found------------------------------
