2011 Jetta Sportwagen 2.5 Swap No Start
Mortgage payer
North Dakota
C?ID=667764
The Background;
Above JSW fell into my hands. After 236k highway miles the 2.5 was about played out.
It ran like it had a jumped timing chain and was blowing oil out the failed rear main seal.
It seemed to have both of the killers of the 2.5, but the body and interior were in decent shape.
A local salvage yard had a 2011 sedan with a low mileage 2.5 CBUA from a front end collision, and the engine was very cheap as it had to be cut out of the car. My first problem was that the gorillas who cut the engine out could not figure out a VAG electrical connector to save their lives so they just cut the main harness. I had to pull the old harness complete off the bad motor and transfer it to the replacement engine.
It turns over well enough, but will only fire once if at all.
Autoscan is just the data collected from me grinding on the starter.
Curiously, there are no engine faults.
Immobilizer or some other security?
Thanks in advance.
Thursday,17,September,2026,14:18:53:57926
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.5
VIN: 3VWPZ7AJ8BMxxx512   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72
          77
VIN: 3VWPZ7AJ8BMxxx512   Mileage: 380160km-236220miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 BE    HW: 07K 906 055
   Component: 2,5l R5/4V      G01 9213
   Revision: T4H04---    Serial number:
   Coding: 0000075
   Shop #: WSC 02665 444 101366
   VCID: 72BA3A5328A105FAE14-8026
   VINID: 0E69E0A8745A21274604514108C3E72371
Readiness: 1110 1101
   Part No SW: 09G 927 750 LM    HW: 09G 927 750 LM
   Component: AQ 250 6F           1734
   Revision: 00H90000    Serial number:
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 074C7B8733231052A6A-8052
                    Fault Status: 00101101
                    Reset counter: 198
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V1.clb
   Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
   Component: ESP MK60EC1   H30 0106
   Revision: 00H30001
   Coding: 114B400C492300FF881002E5921B0041B70000
   VCID: 74B63C4B5EB50BCAF38-8020
                    Reset counter: 28
                    Mileage: 380165 km
                    Date: 2021.02.07.
                    Time: 03:48:57
                    Count: 2
                    Count: 12
                    Count: 20992
                    Count: 8193
                    Count: 46336
                    Count: 1
                    Reset counter: 28
                    Mileage: 380165 km
                    Date: 2021.02.07.
                    Time: 03:45:32
                    Count: 3
                    Count: 12
                    Count: 28672
                    Count: 16390
                    Count: 44032
                    Count: 1
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 00066 000 00149
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75B0014F554F12C2C46-8020
9480469 - Control Circuit for A/C Compressor
          B10A9 15 [00001001] - Open or Short to Plus
                    Reset counter: 28
                    Mileage: 380165 km
                    Date: 2026.09.17.
                    Time: 03:45:25
   Part No SW: 5K0 937 087 K    HW: 5K0 937 087 K
   Component: BCM PQ35 H    011 0035
   Revision: BK011001
   Coding: 2D380E1F902F3EC4008800816000004401000986435D8D60648020000040
   Shop #: WSC 37945 004 1048576
   VCID: 3D20D96F2D7F8A82CC6-8068
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 09081  21  0512
   Coding: 009795
                    Reset counter: 68
                    Mileage: 380165 km
                    Date: 2021.02.07.
                    Time: 01:36:24
                    Voltage: 11.60 V
01503 - Bulb for 3rd Brake Light (M25)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 28
                    Mileage: 380165 km
                    Date: 2021.02.07.
                    Time: 01:36:11
                    Voltage: 11.55 V
                    Reset counter: 28
                    Mileage: 380165 km
                    Date: 2021.02.07.
                    Time: 20:35:52
                    Voltage: 10.65 V
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4R00KKKK   Dataset Number: 1KM003v__B_ 0027
   Coding: 00003044
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3928CD7F39D7B6A2E0E-806C
   Seat occupant detection:
   Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
   Component: BF-Gewichtss.  007 0001
   Serial number: ---0000R--0005BJUE00
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME714A7354ZZZY
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME540A3154ZZZQ
   Serial number: 3511HSME1B0C2C22ZZZN
   Serial number: 3521HSME66492D22ZZZQ
   Serial number: 35527SME4C027921ZZZD
   Serial number: 35627SME17087921ZZZC
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90422JFP001BG Dataset Number: 5K0953507AH D005
   Coding: 188A140000
   Shop #: WSC 00066 000 00184
   ROD: EV_SMLSNGKUDS_A05_VW32.rod
   VCID: 76B20643484919DACDC-8022
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0003027
   Coding: 820000
   Part No SW: 5K0 920 971 B    HW: 5K0 920 971 B
   Component: KOMBI         H03 0406
   Coding: 270F01
   VCID: 2E02EE23F099611A45C-807A
   Part No SW: 7N0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H25 5603
   Revision:   H25       Serial number: 09081001202011
   Coding: ED807F0640061300002002
   VCID: 2E02EE23FC19611A45C-807A
                    Reset counter: 28
                    Mileage: 380165 km
                    Date: 2021.02.07.
                    Time: 03:45:33
   Component: IMMO          H03 0406
   VCID: 6A8A22330CF1CD3A594-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668269600
   Coding: 020000
   VCID: 270C1B07DFE3305286A-8072
   Part No SW: 1K0 035 274     HW: 1K0 035 274
   Component: RNS315-NAR    H03 0007
   Serial number: VWZAZ2K8405032
   Coding: 040004210400000000001000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_RNS315VWNARV1UDS A01005
   ROD: EV_RNS315VWNARV1UDS.rod
   VCID: 6198451FF1C78E6288E-8034
1048659 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [CAN TO phone control unit]
                    Reset counter: 28
                    Mileage: 380165 km
                    Date: 2026.09.17.
                    Time: 03:45:37
                    Reset counter: 28
                    Mileage: 380165 km
                    Date: 2026.09.17.
                    Time: 03:45:32
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0307
   Revision: 13101005    Serial number: 0001252568
   Coding: 0004B5
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 270C1B07DF63305286A-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000005044985
   Coding: 000490
          B11EC 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 28
                    Mileage: 380165 km
                    Date: 2026.09.17.
                    Time: 03:45:33
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 3138F55FED277EE258E-8064
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 380165 km
                    Date: 2021.02.07.
                    Time: 03:45:35
                    Battery Volts: 12.3 V
                        DD
                    Temperature: 29.0 C
                    Count: 2
                    Steering Angle: 0.00
                        SteerAng n.Init
   Component: EZE_2         H25 5603
   Coding: 050B0500
   VCID: 6FBC3327379328120EA-803A
   Component: J245EE20SKB13  H02 0220
02071 - Local Databus
                    Fault Status: 00101100
                    Reset counter: 68
                    Mileage: 380165 km
                    Date: 2021.02.07.
                    Time: 01:52:12
01512 - Control Module for Sliding Roof
                    Fault Status: 01100101
                    Reset counter: 28
                    Mileage: 380165 km
                    Date: 2021.02.07.
                    Time: 03:45:37
02907 - Control Module for Roof Shade (J394)
                    Reset counter: 28
                    Mileage: 380165 km
                    Date: 2021.02.07.
                    Time: 03:45:37
   Part No SW: 3C0 959 702 B    HW: 3C0 959 792
   Component: TUER-SG BT    002 0307
   Revision: 15101005    Serial number: 0001231574
   Coding: 0004B4
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 280E183BD27D3F2A8F0-807C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1401
   Serial number: 00000005136511
   Coding: 000490
Address 77: Telephone
End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.3V)-----------
------------------------------15 Faults Found------------------------------
Ziddywerks
Northern NJ USA
C?ID=208579
If it was immobilizer related you would have immobilizer faults or something to the effect immobilizer active on the dash or, engine control unit locked or something similar. So based on all that its not a immobilizer issue unless you changed any module which it doesnt look like you did.
Verify the basics, ignition and fuel to start. You can check ignition by cranking the engine over... does the tach move when cranking? No tach no ignition/spark. Then fuel, cran kthe line put a container under it and crank it over for a few seconds. Do you have fuel? how much? 100ml?250ml? or way less like its residual?
Mortgage payer
North Dakota
C?ID=667764
Thanks for your help.
Tank is half full.
Fuel pressure measured at the rail Schrader valve is just under 50 psi at key on.
Falls a few psi when cranking.
I can fill a soda bottle with the hose to the rail.
Coils and plugs show good spark when bench tested with 12vdc and a signal.
Tach moves up while cranking hitting 500rpm when you get that one spark.
DrPeter
16.4905° S, 151.7375° W
Hi there...
So if you have fuel (good fuel), spark, and it sounds like there is still oxygen in your area, I would then want to check compression and timing.
Also verify the air intake is free and clear, and that the gorillas did not put any bananas in the tailpipe either, because, "Look man, we ain't falling for no banana in my tailpipe!"
Hope this helps,
drpeter
Mortgage payer
North Dakota
C?ID=667764
175 psi across all 5.
Packs a punch.
The airbox is off the vehicle.
Sucking straight clean ND air.
How do I check timing?
Vehicle has both cam position and crank position senders.
Ziddywerks
Northern NJ USA
C?ID=208579
Can you look and pull up the measured value for intake air temp or coolant temp? If you have 175psi across all 5 cylinders vehicle should start. You said you bench tested the coils and plugs. Why not test them on the vehicle. We need to make sure as it sits that the ecm is firing the coils.
Mortgage payer
North Dakota
C?ID=667764
Fair enough.
I crafted what I'll call the 2x4 test.
I get a nice hot spark on each of the 5 at their turn.
It's actually cool to watch.
That nice hot spark just needs to arrive at the right moment in the piston cycle.
It doesn't show any of the usual timing errors like backfiring.
In cranking like this you can smell the gas too.
Ziddywerks
Northern NJ USA
C?ID=208579
So what were the initial codes stored in the ecm?
Mortgage payer
North Dakota
C?ID=667764
I'll put it back together and take a look
Mortgage payer
North Dakota
C?ID=667764
Not surprised to see P0016. I knew the timing chain on the old engine was shot.
Is it still trying to use values from the bad chain on the new(er) engine?
How do I reset these?
Tuesday,06,October,2026,11:43:04:57926
VIN: 3VWPZ7AJ8BM615512   License Plate: NONE
Mode 0A: Permanent Fault Codes
Address 7E8: 4 Faults Found:
P0302 - Cylinder 2: Misfire Detected
P0016 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28): Incorrect Correlation
P0300 - Random/Multiple Cylinder Misfire Detected
P0106 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
Address 7E9: No fault code found.
TTT
C?ID=547002
Engine is not timed. Spare the start motor.
Mortgage payer
North Dakota
C?ID=667764
The camshaft and the crankshaft are timed. The spark, not so much.
TTT
C?ID=547002
That is a false statement, according ecu.
Ziddywerks
Northern NJ USA
C?ID=208579
It looks like the engine it out of time by those fault codes.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Ignition only On, do not crank
01-Egine,
Clear all faulty codes , go back , get out of controller
Again 01-Engine ,
with ignition On only (do not crank) verified there is no faulty codes after you clear it. Then start cranking engine and if the p0016 comes back then you have timing problem.
Mortgage payer
North Dakota
C?ID=667764
Under 01-Engine I have no fault codes
There is nothing to clear.
The Autoscan I posted confirms this.
I went through the procedure as outlined as no fault codes were found.
Especially the dreaded P0016.
I found the P0016 under OBD-II Perm DTCs
At this point I'm assuming that the ECU is trying to run the engine with the learned values from the old jumped chain engine.
Mortgage payer
North Dakota
C?ID=667764
As it is right now Group 093 shows 0.00deg phase position.
