- Sep 30, 2026
- 4
- 0
- Illinois, USA
- C?ID=107922
Good evening Ross-Tech community. I'm having a problem with my air suspension compressor running briefly every 5-12 seconds while driving. Only code I'm getting is 01577- turn off due to over temp. It seems that I would have a leak in the system. When looking at measuring block 6 watching the pressure sensor G291 the compressor will sometimes build up to 16 bar other times only 8-10 bar. after the compressor turns off the pressure slowly drops to 3 bar and if left overnight with go to a little over 1 bar. I don't thinks its in a strut because spraying the bags and residual pressure valve I don't see any bubbles and if put into tire change mode the car ride height doesn't drop over night. I sprayed the valve block and the lines going into both air tanks and see no leaks. Some other thing are the car will not fully lift to the highest air setting and the left front height sensor is always 10-20 lower then the right side despite measuring the same with a tape measure. So do I have a leak somewhere, a weak compressor or a skewed level sensor that that car is constantly trying to level out?
Thursday,01,October,2026,17:27:56:01744
VCDS Version: 22.3.1.4 (x64)
VIN: WA1DGAFE4FD029857 License Plate:
Mileage: 195080km-121217mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 34 36 3C 42 46 47 4C
4F 52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE4FD029857 Mileage: 195080km-121217miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CTW) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4L0 910 551 Q HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0030
Revision: --H08--- Serial number:
Coding: 0121000A290F0A28
Shop #: WSC 31414 790 00001
VCID: 366830264141AD3F25-8062
VINID: 9D10545D15951165000892051CBC2534AE
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q
Component: AL1000 AISIN 002 2443
Serial number: CVN: 354289C1
Coding: 001378
Shop #: WSC 47377 006 1048576
ROD: EV_TCMAL991031_002_AU56.rod
VCID: 3A702416BD59495FC1-806E
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0627793
VCID: 346C0A2E573DBF2F1B-8060
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10603902212490
Coding: 0000135
VCID: 254AE76AECE7D6A79C-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H05 0020
Component: FBSAUDIC6 KSG H03 0020
Component: FBSAUDIC6 IDG H01 0053
8 Faults Found:
02639 - Antenna Reader for Keyless Access Authorization
Reset counter: 119
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground
Fault Status: 01110111
Reset counter: 212
Mileage: 177822 km
Date: 2024.11.07
Time: 08:27:13
00193 - Rear Right Door Handle Touch Sensor (G418)
Reset counter: 212
Mileage: 177822 km
Date: 2024.11.07
Time: 08:27:13
00190 - Driver's Door Handle Touch Sensor (G415)
Fault Status: 00110111
Fault Frequency: 17
Reset counter: 69
Mileage: 178395 km
Date: 2024.12.09
Time: 07:41:48
00192 - Rear Left Door Handle Touch Sensor (G417)
Fault Frequency: 81
Reset counter: 118
Mileage: 187106 km
Date: 2025.10.24
Time: 14:45:30
00955 - Key 1
Fault Status: 00110010
Mileage: 182955 km
Date: 2025.07.04
Time: 10:20:44
Fault Status: 01111011
Fault Frequency: 123
Reset counter: 79
Mileage: 177822 km
Date: 2024.11.07
Time: 08:28:14
Reset counter: 212
Mileage: 177822 km
Date: 2024.11.07
Time: 08:28:14
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Revision: 00---031 Serial number: 00000030389624
Coding: 000CC026
VCID: 254AE76A2CE7D6A79C-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0147798044
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0147798116
Coding: 070000
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0133123
VCID: 6ED8D8467991D5FF2D-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961513900479
Coding: 290120
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 346C0A2E9F3DBF2F1B-8060
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 A HW: 4L0 907 561
Component: ABSTANDSREGELUNGH07 0160
Revision: -------- Serial number: 00000000000000
Coding: 0011111
VCID: 2756ED6296EBC4B7AE-8072
Fault Status: 00101101
Reset counter: 84
Mileage: 194708 km
Date: 2026.07.22
Time: 10:15:50
Temperature: 24.0 C
Voltage: 12.54 V
Bin. Bits: 00000
Hex Value: 0x0442
Hex Value: 0x0002
Speed: -3.6 km/h
Lateral Accel.: 0.00 m/s^2
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH46 0230
Revision: 10H46000 Serial number: 0038QDA028WG
Coding: 0014131
VCID: 2B5E11528A03E0D74A-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME07571C5CO
Subsystem 3 - Serial number: 6342QSME07571C40C
Subsystem 4 - Serial number: 6352QSME01572C509
Subsystem 5 - Serial number: 6362QSME64564374H
Subsystem 6 - Serial number: 63734SME43584F68B
Subsystem 7 - Serial number: 63834SME41544D4C6
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026151330280
Coding: 0012152
VCID: 2854EE5E9BF5CBCFA7-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 F HW: 4L0 920 985 F
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2C42VV5G
Coding: 8BD663040D01CF05020205
VCID: 37763D22864B54373E-8062
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M15512081B
Coding: 00C303
VCID: 3F865502AE7B6C77F6-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 32140445094121971327
Reset counter: 99
Mileage: 194831 km
Date: 2026.08.16
Time: 04:21:00
Bin. Bits: 00000
Voltage: 12.20 V
Count: 18
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Revision: 00---012 Serial number: 00000000478154
Coding: 0000006
VCID: 68D4AE5E5B750BCF67-803C
00003 - Control Module
Fault Status: 00100011
Fault Frequency: 18
Mileage: 164851 km
Date: 2023.08.07
Time: 11:22:25
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 J HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7860
Revision: --H04001 Serial number: 15.1528-0143.2
Coding: 0015520
VCID: 3162033AA82F8A0770-8064
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000149652972
Coding: 00581B00000011110000
VCID: 32600C366D29B11F09-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 E HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0030
Revision: 00H03000 Serial number: 6PZ 009 014-16
Coding: 0010001
VCID: 3064063EA325830F7F-8064
Subsystem 1 - Part No: 4L0 910 568 E
Component: J0770_SWA_Slave_H03 0030
Subsystem 2 - Serial number: 6PZ 009 014-36
Subsystem 3 - Serial number: 5F18.05.1500H03000AMS14225
Subsystem 4 - Serial number: S14225
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000151771180
Coding: 011F57205E40440004
VCID: 48944EDEFBB52BCF47-801C
01705 - Selection Switch for Mirror-Adjust (E48)
Fault Frequency: 14
Reset counter: 101
Mileage: 193420 km
Date: 2026.07.06
Time: 12:42:33
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82010214180000
Coding: 3569949
VCID: 38743E1E4B555B4F37-806C
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000085633
Coding: 030000
VCID: 2952EB5A40FFF2C7B8-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191104329
Coding: 0694221
VCID: 234EF972E2D32897F2-8076
02214 - Tire Pressure Warning
Reset counter: 107
Mileage: 194936 km
Date: 2026.09.13
Time: 00:29:06
Hex Value: 0x00B0
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.20 V
Temperature: 24.0 C
(no units): 108.0
Reset counter: 84
Mileage: 194708 km
Date: 2026.07.22
Time: 11:12:25
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0005
Voltage: 11.80 V
Temperature: 23.0 C
(no units): 0.0
01310 - Level Control System Control Module (J197)
Reset counter: 118
Mileage: 195084 km
Date: 2026.09.28
Time: 07:59:48
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0005
Voltage: 13.10 V
Temperature: 20.0 C
(no units): 0.0
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H17 0100
Revision: Serial number: 00000000238789
Coding: 0012001
VCID: 5EB888868931457F9D-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000151779773
VCID: 47964DE2F6AB24B74E-8012
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000032
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156FY0F8272105
Coding: 020007010000000000
VCID: 244CFA6E27DD2FAF8B-8070
Part No SW: 4L2 035 746 G HW: 4L2 035 746 G
Component: H-BNT-NA H42 0901
Revision: -------- Serial number: 513F-0F7524750
Coding: 180200060004F9EF710023456F632003140000000100000000
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Component: DU7 High H42 0104
Serial number: A130EY0F3362893
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002253062
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000151798054
Coding: 010E57204040230004
VCID: 468840E6F1A13DBFB5-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H12 0100
Revision: 2A001001 Serial number: 00000370216068
Coding: 0200000000000000
VCID: 3162033A682F8A0770-8064
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0231822
Coding: 020C000001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6ED8D846B191D5FF2D-803A
9617697 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Mileage: 153242 km
Date: 2022.07.11
Time: 07:23:18
Voltage terminal 30: 7.2 V
Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H61 0500
Revision: --H61001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CDCD24E4F8D27EF03-8038
Subsystem 2 - Serial number: 5
Subsystem 3 - Serial number: RD28.05.15--H61001002F0438
Subsystem 4 - Serial number: 2F0438
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0152924651----
Coding: 0003595
VCID: 2648E06691E1DDBF95-8072
Component: J_245_EE16_SKB10H15 0220
Component: J_394_EE16_SKB10H15 0220
Component: J_392_EE16_SKB10H15 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000151798053
End-------------------------(Elapsed Time: 04:11)--------------------------
