AutoScan: 3VVUW7RM1TM130726
blockmap-01-06U-906-070-BH_3VVUW7RM1TM130726-20260930-1156.CSV
colde start
blockmap-01-06U-906-070-BH_3VVUW7RM1TM130726-20260930-1212.CSV
hot engine
blockmap-02-09H-927-158-L_3VVUW7RM1TM130726-20260930-1158.CSV
blockmap-03-3WA-614-517-AS_3VVUW7RM1TM130726-20260930-1158.CSV
blockmap-05-5WA-959-436-AD_3VVUW7RM1TM130726-20260930-1158.CSV
blockmap-06-5QS-959-760-H_3VVUW7RM1TM130726-20260930-1159.CSV
blockmap-08-3WA-907-007-F_3VVUW7RM1TM130726-20260930-1159.CSV
blockmap-09-5WA-937-084-AR_3VVUW7RM1TM130726-20260930-1200.CSV
Wednesday,30,September,2026,12:12:41:11564
VCDS Version: 26.10.0.2 (x64) HEX-NET3 CB: 0.4713.5
Data version: 20260921 DS379.0
VIN: 3VVUW7RM1TM130726 License Plate:
Chassis Type: RM-VW38P PA* (5QS)
Scan: 01 02 03 05 06 08 09 13 15 17 19 23 36 42 44 47 4B 52 5F 6C
6D 75 82 A5 BB BC D6 D7 810C C002 C003
VIN: 3VVUW7RM1TM130726 Mileage: 496km-308miles
810C-Close Rge Radar 4 -- Status: OK 0000
Address 01: Engine (J623-DYKA) Labels: Redir Fail!
Part No SW: 06U 906 070 BH HW: 06U 907 425 A
Component: R4 2.0l TFS H80 5627
Dataset Number: V03935451AU 0001 CVN: 312D525E0C94DFB4
Coding: 012A007245661108F0800000000000000000000000000000
ASAM Dataset: EV_ECM20TFS02006U906070BH 002005
ROD: EV_ECM20TFS02006U906070BH.rod
VCID: 7BABA8810367B212BE3-802E-R SFD+SFD2 {x}
VINID: 0E69A59C789D0647410C01C218F6314AD1
Radiator shutter:
Subsystem 1 - Part No SW: 5QS 965 501 E HW: 5QS 965 501 E
Component: V544_SAB_XS_1 H03 0003
Serial number: 20251221060506051352
Flush-air pump:
Subsystem 2 - Part No SW: 04E 906 703 C HW: 04E 906 703 C
Component: PurgePump0001 102 2700
Serial number: JE-BLDC-KM-860750550
22008 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 {00100000} - -
Reset counter: 36
Mileage: 132 km
Date: 2026.09.05
Time: 13:23:20
Engine speed: 208.75 /min
Coolant temperature: 44 °C
Intake air temperature: 49 °C
Voltage terminal 30: 10.468 V
Unlearning counter according OBD: 36
FAC_TPS_1_SAE: 20.7843141 %
FUP_H_SAE: 19970 kPa
MAP_MES_SAE: 97 kPa
Engine status: Engine start
TAA: 48.000 °C
T_AST_SAE: 0 s
Oxygen sensor 1 bank 1: voltage raw value O2 signal: 1.997 V
25575 - Camera control module
U107A 00 {00100000} - No communication
Reset counter: 36
Mileage: 132 km
Date: 2026.09.05
Time: 13:23:22
Engine speed: 1083.50 /min
Normed load value: 7.8 %
Coolant temperature: 43 °C
Intake air temperature: 48 °C
Voltage terminal 30: 11.855 V
FAC_TPS_1_SAE: 18.8235297 %
FUP_H_SAE: 17650 kPa
MAP_MES_SAE: 54 kPa
Engine status: Idle
TAA: 48.000 °C
T_AST_SAE: 0 s
Address 02: Auto Trans (J217) Labels: Redir Fail!
Part No SW: 09H 927 158 L HW: 09H 927 309 A
Component: AQ8 HTS H07 2505
Serial number: K6NC2602160731 CVN: 5F7FDCCA
ASAM Dataset: EV_TCMAQ301073 001001
ROD: EV_TCMAQ301073_001.rod
VCID: 3D2F66995DF37C22C07-8068-R SFD+SFD2 {x}
Parking lock:
Subsystem 1 - Part No SW: 5QS 907 483 A HW: 5QS 907 483
Component: SB_Auto H03 0060
Serial number: 9923424600517006
Subsystem 2 - Part No SW: 09U 927 152 A HW: 09U 927 152 A
Component: OIL_PUMP_UNIT 006 0013
Serial number: 19112501N00600131522
Address 03: ABS Brakes (J104) Labels: 3WA-614-517-V1.clb
Part No SW: 3WA 614 517 AS HW: 3WA 614 517 D
Component: EBC470IESCH09 0391
Serial number: 0000000 Dataset Number: V03935496HB 0001 CVN: 8CE360
Coding: 2C985248A25D3A9E600799BC9E0501040593752353B0
ASAM Dataset: EV_Brake1ZFESCEPBMQB48W 002059
ROD: EV_Brake1ZFESCEPBMQB48W_002.rod
VCID: 176394311F0F76723AB-8042-R SFD+SFD2 {x}
82320 - Diagnostic Gateway Module
U0447 00 {00100000} - Implausible Signal
{MSG_MOTOR_55_TS_STATUS_MOMRAD_IST_QM_FEHLERFREI}
Reset counter: 34
Mileage: 129 km
Date: 2026.08.26
Time: 09:58:26
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 AD HW: 5WA 959 436 N
Component: Kessy IOBOX 122 0771
Serial number: --------------- Dataset Number: V03935452DQ 0001
ASAM Dataset: EV_Kessy37w 005030
ROD: EV_Kessy37w_005_VW38.rod
VCID: 167D993518054F7A21D-8042-R
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 5QS 959 760 H HW: 5QS 959 760 H
Component: MEM-BFS 011 0372
Serial number: 14B20612571033 Dataset Number: V03935454QS 0001
Coding: 0118BA4000013A008803010121010000000000000000000000000000211000
Shop #: WSC 00066 790 00564
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
ROD: EV_SCMPasseSideCONTIAU736_VWF3.rod
VCID: 659FEEF995E314E2787-8030-R
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 3WA 907 007 F HW: 3WA 907 007
Component: Climatronic H01 5089
Serial number: 213052613533160 Dataset Number: V03935456TL 0001
Coding: 422000240211021012201010111111110000132111200100000000001000
ASAM Dataset: EV_ACClimaBHBE3ADV 002062
ROD: EV_ACClimaBHBE3ADV_002_VW41.rod
VCID: 48C1074D0231298A631-801C-R SFD+SFD2 {x}
Interior temperature sensor:
Subsystem 1 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00003260226055235107
Subsystem 2 - Part No SW: 3J0 963 345 B HW: 3J0 963 345 B
Component: V512 LLR1SLvL H01 0002
Serial number: DD24MM11YY2540520850
Subsystem 3 - Part No SW: 3G0 963 345 D HW: 3G0 963 345 D
Component: SysNameFanLin 016 0103
Serial number: ESEYSKD0509841
Subsystem 4 - Part No SW: 3J0 963 345 B HW: 3J0 963 345 B
Component: V516 LLR1SLvR H01 0002
Serial number: DD13MM12YY2540514040
Subsystem 5 - Part No SW: 3G0 963 345 D HW: 3G0 963 345 D
Serial number: ESEYSKD0503623
Subsystem 6 - Part No SW: 11A 907 049 B HW: 11A 907 049 B
Component: E265 KPH SH H02 0184
Serial number: G08S30.11.2500971001
Address 09: Cent. Elect. (J519) Labels: 5WA-937-08X-V1.clb
Part No SW: 5WA 937 084 AR HW: 5WA 937 084 R
Component: BCM37w_H H26 0350
Serial number: 022026072014100 Dataset Number: V03935483JR 0001
ASAM Dataset: EV_BCMwBL 005001
ROD: EV_BCMwBL_005.rod
VCID: 1F13BC11F73F0E32F2B-804A-R SFD+SFD2 {x}
Subsystem 1 - Part No SW: 57N 955 113 HW: 57N 955 113
Component: WISCHER_MYJTL 006 0093
Serial number: VALSLP22052601003931
Subsystem 2 - Part No SW: 85E 955 555 A HW: 85E 955 555
Component: G397_RLFSS H09 0009
Serial number: 45614268X85E955555A0
Subsystem 3 - Part No SW: 571 941 633 D HW: 571 941 633 D
Component: E1 - LiAM H05 0070
Serial number: 09S21.02.2626790487
Subsystem 4 - Part No SW: 5H0 959 561 CN HW: 5H0 959 561 CN
Component: -VW----LINDA- 505 0835
Serial number: MW3LND01042600012521
Valve block 1 in front seat driver side:
Subsystem 5 - Part No SW: 14A 881 643 J HW: 14A 881 643 J
Component: J873 MKS_FSv H02 0165
Serial number: 7009362202A260603371
Valve block 1 in front seat passenger side:
Subsystem 6 - Part No SW: 14A 881 643 J HW: 14A 881 643 J
Component: J872 MKS_BFSv H02 0165
Serial number: 7009362202A260616416
Power rear lid opening control module:
Subsystem 7 - Part No SW: 57L 962 243 B HW: 57L 962 243 B
Component: GEB.F.Heckoef H02 0014
Serial number: 00000000000661047768
Left taillight 1:
Subsystem 8 - Part No SW: 57N 945 423 HW: 57N 945 423
Component: SHL_li1 030 0055
Serial number: 00056550301401260354
Left taillight 2:
Subsystem 9 - Part No SW: 57N 945 429 HW: 57N 945 429
Component: SHL_li2 030 0055
Serial number: 00093900300801260108
Right taillight 1:
Subsystem 10 - Part No SW: 57N 945 424 HW: 57N 945 424
Component: SHL_re1 030 0055
Serial number: 00056560300501260431
Right taillight 2:
Subsystem 11 - Part No SW: 57N 945 430 HW: 57N 945 430
Component: SHL_re2 030 0055
Serial number: 00093910301001260434
8667429 - Databus
U1123 00 {00101000} - Received Error Message
{Gurtschloss Fahrerseiteempfangener Fehlerwert}
Reset counter: 35
Mileage: 129 km
Date: 2026.08.26
Time: 10:24:36
Terminal 15 status: On
Terminal 50 status: OFF
Engine run: On
Status drive readiness: not ready to drive
Status of brake lamp switch: discrete: On
Brake lamp switch via CAN: status: On
Operating State: Normal mode
Voltage: 12.90 V
Outside temperature: 50.00 °C
Light switch position: automatic
8511745 - Occupant Detection
U173E 00 {00101000} - Function Restriction due to Implausible Message
{Occupant_Presence_Service_Restriction}
Fault Frequency: 9
Reset counter: 35
Mileage: 129 km
Date: 2026.08.26
Time: 10:24:36
Engine run: On
Voltage: 12.90 V
950533 - Light Switch
U110B 00 {00101000} - No Communcations
{Lichtschalter-E1 - kein Signal/Kommunikation}
Fault Frequency: 9
Mileage: 496 km
Date: 2026.09.29
Time: 11:59:43
Terminal 15 status: OFF
Engine run: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 12.10 V
Outside temperature: 35.00 °C
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 1N3 907 567 E HW: 1N3 907 819 A
Component: ACC Bosch MQB H03 0550
Dataset Number: V03935474BS 0001
Coding: 0E2920E64071C0404002000000004000000020008006000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW412 002017
ROD: EV_FRONTRADARBOSCHVW412_002_VW41.rod
VCID: 3927728949DB4002ECF-806C-R SFD+SFD2 {x}
0322 - Databus
U1122 00 {00101110} - Implausible Message
{FAULT_SWA_MODE_SYSTEM_NOT_AVAILABLE}
Fault Frequency: 15
Mileage: 18 km
Date: 2026.08.05
Time: 11:11:31
Outside temperature: 25.00 °C
Control Module temperature: 73 °C
Voltage terminal 30: 12.0 V
Vehicle speed: -0.00 m/s
Longitudinal acceleration: -0.00 m/s²
Adaptive distance regulation: status: initialized
kilometer reading: 18 km
Monitoring_debug_information: 00 00 00 00 00 00 00 00
Event_Id: 02 36
1842 - Databus
U1122 00 {00101000} - Implausible Message
{FAULT_RB_MFK_BLINDNESS_ODACC}
Reset counter: 36
Mileage: 335 km
Date: 2026.09.12
Time: 13:10:35
Outside temperature: 21.00 °C
Control Module temperature: 43 °C
Voltage terminal 30: 12.8 V
Vehicle speed: 31.22 m/s
Longitudinal acceleration: 0.18 m/s²
Adaptive distance regulation: status: Readiness
kilometer reading: 335 km
Event_Id: 02 05
1884 - Databus
{FAULT_RB_MFK_BLINDNESS_OD_PED}
Reset counter: 36
Mileage: 335 km
Date: 2026.09.12
Time: 13:10:35
Event_Id: 02 06
1885 - Databus
{FAULT_RB_MFK_BLINDNESS_LDA}
Reset counter: 36
Mileage: 335 km
Date: 2026.09.12
Time: 13:10:35
Event_Id: 02 04
Address 15: Airbags (J234) Labels:| 5QS-959-655.clb
Part No SW: 5QS 959 655 AF HW: 5QS 959 655 AF
Component: AirbagVW50 010 0251
Serial number: 000000003C0UDRF Dataset Number: V03935494XB 0001
Coding: 9EFC008000FCC00000000000000000005154000081000000800036F8002B00A7
ASAM Dataset: EV_AirbaVW50SMEVW49X 001062
ROD: EV_AirbaVW50SMEVW49X.rod
VCID: 2703A4F1AF6FC6F28AB-8072-R SFD+SFD2 {x}
Component: BF-Gewichtss. H17 0022
Serial number: IBH0000D26000QTV4400
Subsystem 2 - Part No SW: ----------- HW: 480 001 403 1A
Serial number: 35700009C78D57EF3420
Subsystem 3 - Part No SW: ----------- HW: 480 001 403 1A
Serial number: 35800001D781394B4370
Subsystem 4 - Part No SW: ----------- HW: 480 051 A02 1A
Component: SideSensor_Dr 000 0189
Serial number: 3510000A6EB1C9546330
Subsystem 5 - Part No SW: ----------- HW: 480 051 A02 1A
Component: SideSensor_Pr 000 0189
Serial number: 35200009CEB8740AC8B0
Subsystem 6 - Part No SW: ----------- HW: 480 051 504 1A
Component: FrontSensor_D 000 014A
Serial number: 3550000A6FED3D878A00
Subsystem 7 - Part No SW: ----------- HW: 480 050 505 1A
Component: FrontSensor_P 000 014A
Serial number: 35600009EFECB0C947A0
Crash sensor for side airbag: B-pillar: driver side:
Subsystem 8 - Part No SW: ----------- HW: 480 051 802 1A
Component: Side_Sens_B_D 000 0149
Serial number: I0P0000B2EB190C72420
Crash sensor for side airbag: B-pillar: passenger side:
Subsystem 9 - Part No SW: ----------- HW: 480 051 603 1A
Component: Side_Sens_B_P 000 0149
Serial number: I0Q00009AEB960CE4310
Address 17: Instruments (J1050) Labels:* None-SRI2
Part No SW: 2GV 920 340 HW: 2GV 920 340
Component: KOMBI 008 0760
Serial number: LG5LGH210326001 Dataset Number: V03935476FP 0001
Coding: 103400416B9CCF850280620B0000030830307C0000
ASAM Dataset: EV_DashBoardLGMQB37W 002032
ROD: EV_DashBoardLGMQB37W_002_VW42.rod
VCID: 0157DA69618BD8C2E4F-8054-R SFD+SFD2 {x}
Address 19: CAN Gateway (J533-----) Labels:* None
Part No SW: 5QS 907 530 K HW: 5QS 907 530
Component: GW MQB 23 005 2097
Serial number: SMERBG200326007 Dataset Number: V03935490ZG 0001
Coding: 000000000000000000000000000000000000000000000301030000000000000000000000000000000000000000000000
GVL: 3D08080000E840BC804080C2C80010400C4040020078000002000000000000D4
ASAM Dataset: EV_GatewMQBwBL 001027
ROD: EV_GatewMQBwBL_VW41.rod
VCID: 5CE9CB1DA6A9552AD79-8008 SFD+SFD2 {x}
Generator:
Component: 5-00-18-01-03
Subsystem 2 - Part No SW: 5QS 915 181 HW: 5QS 915 181
Component: J367-BDMHella H01 2362
Serial number: 8435598106
Subsystem 3 - Part No SW: 57N 959 442 C HW: 57N 959 442 C
Component: E221__MFL-YLG H07 0130
Serial number: YLG-0700092107261305
Subsystem 4 - Part No SW: 3G0 959 542 B HW: 3G0 959 542 B
Component: J IEEHOD1ZONE 251 0303
Serial number: 00000000230700673990
Address 23: Brake Booster (J539) Labels: None
Part No SW: 3WA 909 059 R HW: 3WA 909 059 B
Component: EBB-ZF-Gen1 H06 0486
Serial number: 8100303 Dataset Number: V03935496TR 0001
Coding: 805040400040E8
ASAM Dataset: EV_BrakeBoostZFMQB48W 001072
ROD: EV_BrakeBoostZFMQB48W_001.rod
VCID: 5DEFC619BDB35C22A07-8008-R SFD+SFD2 {x}
Component: MEM-FS 011 0372
Serial number: 14B20613277175 Dataset Number: V03935454QP 0001
Coding: 0118BA4000013A008803010121010000000000000000000000000000215000
ROD: EV_SCMDriveSideCONTIAU736_VW42.rod
Part No SW: 3WA 959 593 A HW: 3WA 959 593
Component: TSG FS 001 0222
Serial number: Y3007ZB100AIF Dataset Number: V03935462BE 0001
Coding: 003D1B205200000102002030
ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
ROD: EV_DCU4DriveSideMAXHBRO_VW42.rod
VCID: 54F9233DCE799D6A1F9-8000-R SFD+SFD2 {x}
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V2.clb
Part No SW: 5QV 907 144 F HW: 5QV 907 144
Component: BASGEN1MQB37 104 1122
Serial number: 03450274 Dataset Number: V03935478ZF 0001
Coding: 00000100010000010001020101000100000001010101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
ROD: EV_SteerAssisBASGEN1MQB37_017.rod
VCID: 5BEBC801A3A75212DE3-800E-R SFD+SFD2 {x}
Part No SW: 3G0 035 466 J HW: 3G0 035 466 J
Component: AMPeth16CDoIP H05 4852
Serial number: A1130T00397512 Dataset Number: V03935468Q 0001
Coding: 24060000000000000000000000000000000000000000000000
ASAM Dataset: EV_AMPEthMQB37w 001005
ROD: EV_AMPEthMQB37w_VW38.rod
VCID: 2C095BDDB689E5AA679-8078-R SFD {x}
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5QS 907 338 E HW: 5QS 907 338 B
Component: FCM Baseline 019 4010
Serial number: 780542040026076 Dataset Number: V03935450TU 0001
Coding: 0000000009001B52022123000B0003000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiWBL 001008
ROD: EV_MultiModulContiWBL.rod
VCID: 5CE9CB1DA6A9552AD79-8008-R SFD {x}
Part No SW: 3WA 959 592 A HW: 3WA 959 592
Component: TSG BFS 001 0222
Serial number: Y3007ZBI00G5A Dataset Number: V03935462BF 0001
Coding: 003D13205E00000002002030
ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
ROD: EV_DCU4PasseSideMAXHKLO_VW41.rod
VCID: 53FB2021CB779A52063-8006-R SFD+SFD2 {x}
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 571 035 877 A HW: 571 035 877
Component: MU-O-NS-US H11 2756
Serial number: WG8LGM250326004 Dataset Number: V03935483QM 0001
Coding: 23363406000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 002001
ROD: EV_MUOIMQB37w_002_VN3SP.rod
VCID: 1C698B1DE629152A179-8048-R SFD+SFD2 {x}
Subsystem 1 - Part No SW: 14A 919 606 P HW: 14A 919 606
Component: ABT-E3_15 H54 7049
Serial number: TPO00121012615011005
Subsystem 2 - Part No: V03 959 822 LG
Component: NAR 2025/26 3129
Address 6C: Back-up Cam. (J928---------) Labels:* None
Part No SW: 5QS 907 556 F HW: 5WA 907 556 E
Component: TV eEntry H35 0726
Serial number: FZ6ESP211225000 Dataset Number: V03935470MJ 0001
Coding: 020240003F140000
ASAM Dataset: EV_CamSysTVFicosBL 001004
ROD: EV_CamSysTVFicosBL_VW41.rod
VCID: 5F93FC11B7BF4E32B2B-800A-R
Front peripheral camera slave:
Subsystem 1 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R243 UmfKamSV H23 0070
Serial number: FCLMAR17052600092FB1
Peripheral camera slave: left:
Subsystem 2 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R244 UmfKamSL H23 0070
Serial number: FCLMAR3003260005070A
Right peripheral camera slave:
Subsystem 3 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R245 UmfKamSR H23 0070
Serial number: FCLMAR300326000709CB
Rear peripheral camera slave:
Subsystem 4 - Part No SW: 5WA 980 546 E HW: 5WA 980 546 D
Component: R246 UmfKamSH H23 0070
Serial number: FCLMAR0801260002370E
Part No SW: 5WB 959 107 C HW: 5WB 959 107 B
Component: HDSG-Modul H08 0444
Revision: -------- Serial number: A2-C767-1202-1 Dataset Number: V03935453AF 0001
Coding: 2208
Shop #: WSC 00066 790 00514
ASAM Dataset: EV_DeckLidCONTIAU536 001009
ROD: EV_DeckLidCONTIAU536_001_VW42.rod
VCID: 50F12F2DFA61E14A3B1-8004-R
Part No SW: 571 035 285 B HW: 571 035 285
Component: OCUMQBW2023_H H09 0672
Serial number: 0000000603VIVR7 Dataset Number: V03935465Q 0001
Coding: 02020601020000211000010013002E07101112111012011110
ASAM Dataset: EV_OCUMWB2023 001072
ROD: EV_OCUMWB2023_VW42.rod
VCID: 167D993518054F7A21D-8042-R SFD+SFD2 {x}
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 571 919 608 B HW: 571 919 608 B
Component: HeadupDisplay H02 2449
Coding: 5700A000
ASAM Dataset: EV_HUDMQBwBL 002013
ROD: EV_HUDMQBwBL_002.rod
VCID: 2011BFEDCA4131CACB1-8074-R SFD+SFD2 {x}
13894400 - Function limitation due to excessive temperature
B1050 00 {00001000} - -
{ECU_function_restriction_overtemperature}
Reset counter: 36
Mileage: 22 km
Date: 2026.08.22
Time: 13:32:02
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 3WA 907 217 F HW: 3WA 907 217
Component: MFK120_MQB H18 1550
Dataset Number: V03935484NZ 0001
Coding: 00070000000000000000009AF940E00600000000204100000000F80000002BDE23F240748000000000800000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_MFK120MAGNAMQBWB 005004
ROD: EV_MFK120MAGNAMQBWB_005_VN54P.rod
VCID: 4BCB38411347C2924E3-801E-R SFD+SFD2 {x}
1049858 - Data Fusion for Driver Assistance Systems Service
U198B 00 {00100000} - Received Malfunction Value
{Service_AdasFusedObjectsSmall_MFK_OD_Error}
Reset counter: 28
Mileage: 335 km
Date: 2026.09.12
Time: 13:10:35
1049859 - Data Fusion for Driver Assistance Systems Service
{Service_AdasFusedObjectsSmall_MFK_PED_Error}
Reset counter: 28
Mileage: 335 km
Date: 2026.09.12
Time: 13:10:35
Address BB: Door Rear Drv (J388) Labels:* Redir Fail!
Part No SW: 3WA 959 395 A HW: 3WA 959 395
Component: TSG HFS 001 0222
Serial number: Y2007ZCL00EP2 Dataset Number: V03935462BJ 0001
Coding: 000811200100000100002020
ASAM Dataset: EV_DCU4RearDriveMAXHKLO 001016
ROD: EV_DCU4RearDriveMAXHBRO_VW42.rod
Address BC: Door Rear Pass (J389) Labels:* Redir Fail!
Part No SW: 3WA 959 394 A HW: 3WA 959 394
Component: TSG HBFS 001 0222
Serial number: Y2007ZC500IT5 Dataset Number: V03935462BG 0001
ASAM Dataset: EV_DCU4RearPasseMAXHKLO 001016
ROD: EV_DCU4RearPasseMAXHBRO_VW42.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PX-941-LED-V1.clb
Part No SW: 992 941 572 AH HW: 992 941 572 A
Component: LED1L H25 9204
ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
VCID: 6987E2C979FB30825CF-803C-R
Address D7: Light Ctrl Right 2 (A27) Labels: 7PX-941-LED-V1.clb
Component: LED1R H25 9204
ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address 810C: Close Rge Radar 4 (J769) Labels:* None
Part No SW: 3WA 907 670 F HW: 95C 907 550
Component: Nanoradar 4 H09 0162
Serial number: 36306007903235 Dataset Number: V03935492NR 0001
Coding: 95696E1631C40A000000
ASAM Dataset: EV_NR4HELLAVW38X 002116
ROD: EV_NR4HELLAVW38X_001_VWE3.rod
VCID: 4ECD3155E055F7BA29D-801A-R SFD+SFD2 {x}
End----------(Elapsed Time: 18:48, VBatt start/end: 14.2V/14.1V)-----------
------------------------------13 Faults Found------------------------------
colde start
;SW:06U-906-070-BH HW:06U-907-425-A --- 01: Engine
;Component:R4 2.0l TFS H80 5627, Coding:012A007245661108F0800000000000000000000000000000
;EV_ECM20TFS02006U906070BH,002005,EV_ECM20TFS02006U906070BH.rod
;Wednesday,30,September,2026,11:56:29:11564
;VCDS Version: 26.10.0.2 (x64) Data version: 20260921 DS379.0
;VCID: 7BABA8810367B212BE3-802E-R SFD+SFD2 [x]
Group,Description,Actual
IDE00018,Voltage terminal 15,14.316, V
IDE00019,Voltage terminal 30,14.511, V
IDE00021,Engine speed,900, /min
IDE00025,Coolant temperature,61, °C
IDE00078,Time since engine start,219, s
IDE00083,Throttle valve position (absolute),15.3, %
IDE00084,Absolute load value,28, %
IDE00085,Normed load value,23.1, %
IDE00086,Accelerator pedal position,14.5, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00102,Control Module temperature,42.0, °C
IDE00148,Mean injection time,0.0, ms
IDE00149,Ignition angle of current cylinder: actual value,2.88, °
IDE00150,Pressure in brake servo unit,0.000, bar
IDE00151,Oil fill level,38, mm
IDE00167,Exhaust temperature 1 bank 1,372.1, °C
IDE00172,A/C compressor torque,-2.50, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,5.0, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,5.0, °
IDE00178,Camshaft adjustment intake bank 1: specified value,3.0, °
IDE00179,Camshaft adjustment intake bank 1: actual value,3.1, °
IDE00182,Camshaft adaptation intake bank 1: phase position,-2.6, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-3.3, °
IDE00187,Coolant temperature at engine start,21.7, °C
IDE00188,Fuel high-pressure: actual value,135.1, bar
IDE00189,Activation of fuel pump electronics,51.34, %
IDE00190,Charge air pressure: specified value,0.355, bar
IDE00191,Charge air pressure: actual value,0.987, bar
IDE00192,Coolant temperature at radiator outlet: actual value,27.2, °C
IDE00193,Coolant temperature at engine outlet: specified value,61.5, °C
IDE00194,Coolant temperature at radiator output: specified value,-48.0, °C
IDE00195,Coolant temperature difference between engine and radiator,33.7, °C
IDE00196,Engine oil temperature,27.9, °C
IDE00199,Mean engine air mass,17, kg/h
IDE00200,Average vehicle speed,0.00, km/h
IDE00201,Fuel high-pressure: specified value,134.4, bar
IDE00202,Low fuel pressure: specified value,5.000, bar
IDE00252,Vacuum pump for brakes,Pump off,
IDE00304,Fuel level,25, l
IDE00348,Intake air temperature,30, °C
IDE00349,Throttle valve position: normed,4.7, %
IDE00355,Cruise Control System (CCS): status,passive,
IDE00357,Fuel temperature,27.0, °C
IDE00358,Limitation: torque,186.8, Nm
IDE00371,Fuel consumption,1.72, l/h
IDE00375,Generator: load signal,35.50, %
IDE00380,Coolant fan 1: activation,37.89, %
IDE00381,Coolant fan 2: activation,37.89, %
IDE00392,Accelerator pedal: sensor voltage 1,0.720, V
IDE00393,Accelerator pedal: sensor voltage 2,0.360, V
IDE00400,Intake manifold Runner Control (IMRC): activation,0.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,0.00, %
IDE00404,Throttle valve: activation,8.65, %
IDE00405,Crankshaft speed (RPM),905, /min
IDE00406,Camshaft RPM,872, /min
IDE00407,Rail pressure regulation: status,Regulated operation via quantity control valve,
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,00,
IDE00414,Starter control: relay 1,00,
IDE00415,Starter control: relay 2,00,
IDE00416,Starter control: terminal 50 feedback,01,
IDE00417,Starter control: shut-off conditions 1,00 01,
IDE00434,Particle filter: soot mass calculated,0.02, g
IDE00436,Particle filter: kilometers since last regeneration,496.4,
IDE00451,Currently running routine,Unknown (0),
IDE00472,Mean injection quantity,10, mg/stroke
IDE00474,Ambient air pressure,98, kPa abs
IDE00476,Fuel Metering Valve,0.00, %
IDE00477,Torque request: sum of auxiliary aggregate,12.8, Nm
IDE00478,Engine-drag torque,14.6, Nm
IDE00482,Limitation: torque of clutch protection,1024.0, Nm
IDE00495,Calculated oil temperature,28.0, °C
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,Open,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,closed,
IDE00556,Outside temperature,33, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.004 Lambda / -0.004 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.755, V
IDE00582,Specified value of equivalence ratio,1.001, Lambda
IDE00583,Throttle valve specified value,3.5, %
IDE00584,Distance driven since erasing DTC memory,477, km
IDE00587,Vapor pressure in tank ventilation system,-31968, Pa
IDE00588,Fuel tank fill level,43.9, %
IDE00592,Status of oxygen sensor control,Closed loop, / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,1.0, Degrees
IDE00594,Absolute intake pressure,36, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,-0.8, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,5,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,72.9, %
IDE00949-ENG98517,Hide cylinder-Cylinder 1,not active,
IDE00949-ENG98491,Hide cylinder-Cylinder 10,not active,
IDE00949-ENG98492,Hide cylinder-Cylinder 11,not active,
IDE00949-ENG98493,Hide cylinder-Cylinder 12,not active,
IDE00949-ENG98518,Hide cylinder-Cylinder 13,not active,
IDE00949-ENG98519,Hide cylinder-Cylinder 14,not active,
IDE00949-ENG98520,Hide cylinder-Cylinder 15,not active,
IDE00949-ENG98494,Hide cylinder-Cylinder 16,not active,
IDE00949-ENG98521,Hide cylinder-Cylinder 2,not active,
IDE00949-ENG98522,Hide cylinder-Cylinder 3,not active,
IDE00949-ENG98523,Hide cylinder-Cylinder 4,not active,
IDE00949-ENG98495,Hide cylinder-Cylinder 5,not active,
IDE00949-ENG98524,Hide cylinder-Cylinder 6,not active,
IDE00949-ENG98496,Hide cylinder-Cylinder 7,not active,
IDE00949-ENG98497,Hide cylinder-Cylinder 8,not active,
IDE00949-ENG98498,Hide cylinder-Cylinder 9,not active,
IDE01098,Test of knock sensors: short trip result,Test not started,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.000,
IDE01377,Throttle valve adapter: actual value,5.3, °
IDE01378,Fuel high pressure: control deviation,0, bar
IDE01385,Wear index,0.00000046,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test not started,
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.758, V
IDE01649,Throttle valve position 1,0.780, V
IDE01650,Throttle valve position 2,15, %
IDE01652,Opening degree Evap. Emission (EVAP) Canister Purge Reg. Valve,73, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test not started,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test not started,
IDE01670,Short trip status for oil pressure control,Test not started,
IDE01671,Starter control: clutch switch,pressed,
IDE01672,Starter control: automatic start,possible,
IDE01673-MAS05513,Starter control: readiness bits-Bit 0,Mechanical test of starter complete,
IDE01673-MAS05514,Starter control: readiness bits-Bit 1,Test of starter relay switching contacts not complete,
IDE01673-MAS05515,Starter control: readiness bits-Bit 2,Test of starter relay activation complete,
IDE01673-MAS05516,Starter control: readiness bits-Bit 3,Test of terminal 50R return measuring line completed,
IDE01673-MAS05517,Starter control: readiness bits-Bit 4,Test of starter request double injection complete,
IDE01673-MAS05518,Starter control: readiness bits-Bit 5,Test of PN signal complete,
IDE01673-MAS05519,Starter control: readiness bits-Bit 6,Test of interlock switch complete,
IDE01673-MAS05520,Starter control: readiness bits-Bit 7,Test of clutch pedal switch complete,
IDE01677,Result: oxygen sensor test operational readiness B1 downstream CAT,Test not started,
IDE01685,Result of test of valve stroke switch AVS,Test not started,
IDE01773,Misfire totalizer,0,
IDE01774,Status misfire recognition,active,
IDE01870,Oxygen sensor after catalytic converter: operating status,Bank 1: sensor 1 OK,
IDE01873,Test of catalytic converter: measured value,0.000,
IDE01874,Test of catalytic converter: result,Test not started,
IDE01876,Adaptation of loss torque,3.4, Nm
IDE01878,Adaptation of throttle valve,Test of closing springs ended,
IDE01880,Accelerator pedal position 2,14.5, %
IDE01881,Adaptation of kick-down shifting point,4.102, V
IDE01884,Camshaft adjustment intake bank 1: activation,0.00, %
IDE01886,Number of high pressure incursions,0,
IDE01894,Charge press. ctrl.: adapt. higher than max. threshold,0.00, %
IDE01895,Charge pressure control: less than min. threshold adaptation,0.00, %
IDE01901,Lost torque adaptation: idle,2.2, Nm
IDE01905,Average of ignition timing angle delay adjustment,18.94, °
IDE01906,Dynamic average of ignition timing angle delay adjustment,5.94, °
IDE01913,Number of oxygen sensor dynamic tests: bank 1 sensor 1,0,
IDE01922,Vehicle distance driven,496, km
IDE01923,Control module distance driven,497, km
IDE01924,Load shift flaps: actual value,Open,
IDE01925,Load shift flaps: specified value,Open,
IDE01926,Adaptation of intake manifold runner flaps,is running,
IDE01928,Close cam shaft angle at quantity control valve,33.5, °
IDE01929,Open cam shaft angle at quantity control valve,2.3, °
IDE01931,High pressure pump injection volume control deviation,-6, mg/stroke
IDE01932,High pressure pump injection volume,0, mg/stroke
IDE01975,Numb.of misfir.: cylinder 1,23,
IDE01976,Numb.of misfir.: cylinder 2,30,
IDE01977,Numb.of misfir.: cylinder 3,23,
IDE01978,Numb.of misfir.: cylinder 4,58,
IDE02116,Exhaust gas temperature before catalytic converter,295.6, °C
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02229,Exhaust gas temperature sensor 1,372.2, °C
IDE02756,Number of manual engine starts,117,
IDE02757,Number of automatic engine starts,10,
IDE02832,Coolant circulation pump: activation,44.39, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,5,
IDE03010-MAS01627,Number of prevented stop processes-Steering,26,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,32,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,1,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,33,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,10,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,2,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,8,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test not started,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,-179.96, °
IDE03246,Neutral position sensor: upper adaptation value,0.000, V
IDE03247,Neutral position sensor: lower adaptation value,0.000, V
IDE03262,Adapt of angle sensor 1 f throttle valve,0.496, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.501, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.948, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.049, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,0.000, V
IDE03328,Transmission neutral position sensor voltage,0.000, V
IDE03361,Driver intention torque,46.1, Nm
IDE03377,Coolant temp at radiator output: unconditioned voltage,3.265, V
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03587-IDE02697,Stopping prohibitions for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping prohibitions for active participants-A/C system,active,
IDE03587-MAS00127,Stopping prohibitions for active participants-Brake,not active,
IDE03587-MAS00506,Stopping prohibitions for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping prohibitions for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping prohibitions for active participants-Gearbox,not active,
IDE03587-MAS01106,Stopping prohibitions for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping prohibitions for active participants-Energy management,active,
IDE03587-MAS01627,Stopping prohibitions for active participants-Steering,not active,
IDE03587-MAS02237,Stopping prohibitions for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping prohibitions for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping prohibitions for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping prohibitions for active participants-Motor,not active,
IDE03587-MAS06709,Stopping prohibitions for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping prohibitions for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping prohibitions for active participants-Front sensor for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C system,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-Brake,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Gearbox,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication errors,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03711,Mass flow through throttle valve,14, kg/h
IDE03767,Engine status,Idle,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,39.23, %
IDE03806,Oxygen sensor bank 1 sensor 1: status,1,
IDE03807,Oxygen sensor bank 1 sensor 2: status,1,
IDE03816,Exhaust flap bank 1,Open,
IDE03818,Heated oxygen sensor bank 1: sensor 2: resistance,310, Ohm
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,27.73, %
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,162, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,14.45, %
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,Test not started,
IDE03892,Fuel high pressure sensor: unconditioned voltage,0.000, V
IDE03920,Oxygen adaptation status,Condition not met,
IDE03921,Mixture adaptation factor at partial load,-0.05, %
IDE03922,Mixture adaptation factor at idle speed,0.39, %
IDE03923,Adaptive long-term value of mix. condition after cat. conv,0.00000,
IDE03924,Relay for reserve coolant pump: status,not activated,
IDE03928,Counter for fuel entry in oil,0,
IDE03930,Charge pressure actuator: operating status,Operating mode,
IDE03949,Air mass: actual value (mg/stroke),163.82, mg/stroke
IDE03953,Oxygen control: adaptation value at partial load: bank 1,-0.06, %
IDE03957,Throttle valve angle: specified value,5.6, °
IDE03963,Low fuel pressure adaptation value for EFP,1200, mbar
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE04002,Charge air pressure control,BP_A act:98.2, kPa
IDE04010,Engine torque: normalized,12.0, %
IDE04011,Nominal torque,370, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:13220/--- kPa,
IDE04083,Coolant temperatures,ECT 1:64 °C / ECT 2:27 °C,
IDE04086,Turbocharger guide vane adjustment,VGT_A cmd/act:0.0/0.0 % / VGT_B cmd/act:---/--- %,
IDE04088,Turbocharger 1: temperature,Compr. in/out---/31 °C / Turbine in/out---/--- °C,
IDE04092,Particulate filter bank 1,-327.34/0.30/0.63, kPa
IDE04094,Particle filter: temperature,B1:323/--- °C / B2:---/--- °C,
IDE04110,Additional inputs and outputs,GEAR_RCMD: N,
IDE04322,Short term adaptation of oxygen sensor control bank 1,-0.8, %
IDE04405,Mixture variation in adapted part load range 1,0.00, %
IDE04409,Intake manifold pressure: corrected,0.370, bar
IDE04410,Intake manifold pressure: specified value,0.358, bar
IDE04412,Pressure upstream of throttle valve: corrected,0.987, bar
IDE04420,Secondary air system activation,Atmosphere/off,
IDE04615,Segment adaptation for rough running: status,completed successfully,
IDE04634,AVS switch-over meter for reg activation of curr. drive cycle,0,
IDE04638,Transmission coolant valve,Open,
IDE04677,Oxygen sensor 1 bank 1: lambda actual value,1,
IDE04680,Oxygen sensor 1 bank 1: voltage raw value O2 signal,1.948, V
IDE04713,Active brake system status,Not operated,
IDE04885,Hybrid batt charge cond act val standardized,0.00, %
IDE04913,Current speed of electric motor,0.0, /min
IDE04937,Sensor for engine block temperature: raw value,64.0, °C
IDE05140,Intake manifold pressure raw value,0.358, bar
IDE05259,Gear position sensor: raw value,0.00, %
IDE05260,Gear position sensor: current value,Neutral,
IDE05310,Charge air pressure control valve position: target value,100.00, %
IDE05311,Charge air pressure control valve position: actual value,100.30, %
IDE05312,Charge air pressure control valve uncond voltage sensor,2.8850, V
IDE05313,Charge air pressure control valve activation pulse duty factor,-2.25, %
IDE05315,Charge air pressure control valve voltage: position closed,0.0000, V
IDE05316,Charge air pressure control valve voltage: position open,0.0000, V
IDE05317,Charge air pressure control valve adaptation performed,00000000 ,
IDE05508,Adaptation val cyl 1 with slow diagnosis,0.000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,0.000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,2.304,
IDE05511,Adaptation val cyl 2 with slow diagnosis,0.000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,0.000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,0.000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,0.000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,0.000,
IDE05593,Secondary air injection sensor 1,0.986, bar
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,Power fail: content of RAM cell no longer valid,
IDE06006,Idle speed specified value,900, /min
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06175,Intake air temperature before throttle valve: actual value,31.37, °C
IDE06192,Knock sensor: cylinder 2: voltage,0.392, V
IDE06193,Knock sensor: cylinder 3: voltage,0.385, V
IDE06194,Knock sensor: cylinder 4: voltage,0.614, V
IDE06195,Knock sensor: cylinder 1: voltage,0.460, V
IDE06307,Stop prevention history data,|Year,Month,Day,Hours,Minutes,Seconds,,,,,,,,,,,,,,,,,,,,,,,,,,,,,|2026,9,29,12,55,19,not active,not active,not active,not active,not active,not active,not active,not active,Steering,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active|2026,9,29,12,6,0,not active,not active,not active,not active,not active,not active,not active,not active,Steering,not active,Driving situation,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active|2026,9,29,11,53,58,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,Driving situation,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active|2026,9,29,11,53,43,not active,not active,not active,not active,not active,not active,not active,not active,Steering,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active|2026,9,29,11,34,33,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,Driving situation,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active|2026,9,25,18,37,17,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,Driving situation,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active|2127,15,31,31,63,63,Engine temperature,Ambient air pressure,Brake under pressure too low,Sporadic function prevention,Poor start detection,Mixture adaptation,Regeneration Mode,hood open,Steering,Steering angle,Driving situation,Anti-play protection,Function locked due to frequent stalling,Brake pedal information: plausibility,Slow traffic detected,Hybrid battery power too low,Auxiliary equipment power consumption too high,Deceleration takeover active,E machine output too low,Clutch protection K0,Learning function active,Engine protection active,Fuel gelling protection active,Diagnosis of exhaust system,Exhaust treatment diagnosis,Air system diagnosis,Thermostat testing not completed,DTC memory entry in engine control module,Restriction in start system|2127,15,31,31,63,63,Engine temperature,Ambient air pressure,Brake under pressure too low,Sporadic function prevention,Poor start detection,Mixture adaptation,Regeneration Mode,hood open,Steering,Steering angle,Driving situation,Anti-play protection,Function locked due to frequent stalling,Brake pedal information: plausibility,Slow traffic detected,Hybrid battery power too low,Auxiliary equipment power consumption too high,Deceleration takeover active,E machine output too low,Clutch protection K0,Learning function active,Engine protection active,Fuel gelling protection active,Diagnosis of exhaust system,Exhaust treatment diagnosis,Air system diagnosis,Thermostat testing not completed,DTC memory entry in engine control module,Restriction in start system|2127,15,31,31,63,63,Engine temperature,Ambient air pressure,Brake under pressure too low,Sporadic function prevention,Poor start detection,Mixture adaptation,Regeneration Mode,hood open,Steering,Steering angle,Driving situation,Anti-play protection,Function locked due to frequent stalling,Brake pedal information: plausibility,Slow traffic detected,Hybrid battery power too low,Auxiliary equipment power consumption too high,Deceleration takeover active,E machine output too low,Clutch protection K0,Learning function active,Engine protection active,Fuel gelling protection active,Diagnosis of exhaust system,Exhaust treatment diagnosis,Air system diagnosis,Thermostat testing not completed,DTC memory entry in engine control module,Restriction in start system|2127,15,31,31,63,63,Engine temperature,Ambient air pressure,Brake under pressure too low,Sporadic function prevention,Poor start detection,Mixture adaptation,Regeneration Mode,hood open,Steering,Steering angle,Driving situation,Anti-play protection,Function locked due to frequent stalling,Brake pedal information: plausibility,Slow traffic detected,Hybrid battery power too low,Auxiliary equipment power consumption too high,Deceleration takeover active,E machine output too low,Clutch protection K0,Learning function active,Engine protection active,Fuel gelling protection active,Diagnosis of exhaust system,Exhaust treatment diagnosis,Air system diagnosis,Thermostat testing not completed,DTC memory entry in engine control module,Restriction in start system|,
IDE06308,Start request history data,|Year,Month,Day,Hours,Minutes,Seconds,,,,,,,,,,,,,,,|2127,15,31,31,63,63,Engine temperature too low,Engine temperature too high,Brake under pressure too low,SCR System requires restart,hood open,Steering,Rolling vehicle,Auxiliary equipment power consumption too high,Hybrid battery power too low,Deceleration takeover active,Engine protection active,Fuel gelling protection active,CAT heating,Sporadic function prevention,Restriction in start system|2127,15,31,31,63,63,Engine temperature too low,Engine temperature too high,Brake under pressure too low,SCR System requires restart,hood open,Steering,Rolling vehicle,Auxiliary equipment power consumption too high,Hybrid battery power too low,Deceleration takeover active,Engine protection active,Fuel gelling protection active,CAT heating,Sporadic function prevention,Restriction in start system|2127,15,31,31,63,63,Engine temperature too low,Engine temperature too high,Brake under pressure too low,SCR System requires restart,hood open,Steering,Rolling vehicle,Auxiliary equipment power consumption too high,Hybrid battery power too low,Deceleration takeover active,Engine protection active,Fuel gelling protection active,CAT heating,Sporadic function prevention,Restriction in start system|2127,15,31,31,63,63,Engine temperature too low,Engine temperature too high,Brake under pressure too low,SCR System requires restart,hood open,Steering,Rolling vehicle,Auxiliary equipment power consumption too high,Hybrid battery power too low,Deceleration takeover active,Engine protection active,Fuel gelling protection active,CAT heating,Sporadic function prevention,Restriction in start system|2127,15,31,31,63,63,Engine temperature too low,Engine temperature too high,Brake under pressure too low,SCR System requires restart,hood open,Steering,Rolling vehicle,Auxiliary equipment power consumption too high,Hybrid battery power too low,Deceleration takeover active,Engine protection active,Fuel gelling protection active,CAT heating,Sporadic function prevention,Restriction in start system|2127,15,31,31,63,63,Engine temperature too low,Engine temperature too high,Brake under pressure too low,SCR System requires restart,hood open,Steering,Rolling vehicle,Auxiliary equipment power consumption too high,Hybrid battery power too low,Deceleration takeover active,Engine protection active,Fuel gelling protection active,CAT heating,Sporadic function prevention,Restriction in start system|2127,15,31,31,63,63,Engine temperature too low,Engine temperature too high,Brake under pressure too low,SCR System requires restart,hood open,Steering,Rolling vehicle,Auxiliary equipment power consumption too high,Hybrid battery power too low,Deceleration takeover active,Engine protection active,Fuel gelling protection active,CAT heating,Sporadic function prevention,Restriction in start system|2127,15,31,31,63,63,Engine temperature too low,Engine temperature too high,Brake under pressure too low,SCR System requires restart,hood open,Steering,Rolling vehicle,Auxiliary equipment power consumption too high,Hybrid battery power too low,Deceleration takeover active,Engine protection active,Fuel gelling protection active,CAT heating,Sporadic function prevention,Restriction in start system|2127,15,31,31,63,63,Engine temperature too low,Engine temperature too high,Brake under pressure too low,SCR System requires restart,hood open,Steering,Rolling vehicle,Auxiliary equipment power consumption too high,Hybrid battery power too low,Deceleration takeover active,Engine protection active,Fuel gelling protection active,CAT heating,Sporadic function prevention,Restriction in start system|2127,15,31,31,63,63,Engine temperature too low,Engine temperature too high,Brake under pressure too low,SCR System requires restart,hood open,Steering,Rolling vehicle,Auxiliary equipment power consumption too high,Hybrid battery power too low,Deceleration takeover active,Engine protection active,Fuel gelling protection active,CAT heating,Sporadic function prevention,Restriction in start system|2127,15,31,31,63,63,Engine temperature too low,Engine temperature too high,Brake under pressure too low,SCR System requires restart,hood open,Steering,Rolling vehicle,Auxiliary equipment power consumption too high,Hybrid battery power too low,Deceleration takeover active,Engine protection active,Fuel gelling protection active,CAT heating,Sporadic function prevention,Restriction in start system|2127,15,31,31,63,63,Engine temperature too low,Engine temperature too high,Brake under pressure too low,SCR System requires restart,hood open,Steering,Rolling vehicle,Auxiliary equipment power consumption too high,Hybrid battery power too low,Deceleration takeover active,Engine protection active,Fuel gelling protection active,CAT heating,Sporadic function prevention,Restriction in start system|2127,15,31,31,63,63,Engine temperature too low,Engine temperature too high,Brake under pressure too low,SCR System requires restart,hood open,Steering,Rolling vehicle,Auxiliary equipment power consumption too high,not active,not active,not active,not active,not active,not active,not active|,
IDE06386,Oil level: static measurement,0, mm
IDE06387,Oil level: last valid dynamic value,0, mm
IDE06388,Oil level: condition for static measurement fulfilled,Condition not met,
IDE06389,Oil level: maximum value,0, mm
IDE06390,Oil level: minimum value,0, mm
IDE06391,Oil temperature sensor 2,24.0, °C
IDE06392,Oil temperature sensor 2: raw value,24.000, V
IDE06393,Oil level: dynamic average value,0, mm
IDE06394,Sensor 1 for secondary air pressure: unconditioned voltage,2.444, V
IDE06396,Coolant temperature at engine outlet: unconditioned voltage,1.699, V
IDE06397,Temperature sensor for engine temp. management: target value,90.0, °C
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,1.698, V
IDE06405,Engine oil temperature_SAE,24, °C
IDE06432,Oxygen sensor 1 bank 1 signal status,active,
IDE06444,Oxygen sensor before cat bank 1 (LSB) voltage,1.992, V
IDE06567,Frequency counter deactivate start/stop function,10,
IDE06568,Stop prevention by driver frequency counter,109,
IDE06569,Frequency counter vehicle standstill,290,
IDE06573,Long-term adaptation of intake manifold injection,0.00, %
IDE06574,Long-term adaptation of intake manifold injection in idle,0.00, mg/stroke
IDE06610,Frequency counter vehicle standstill with stop,10,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system malfunction,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,No,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,No,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,Yes,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC with Stop & Go,
IDE06707,CCS Switch,ACC operating unit,
IDE06709,ACC variants (coding),ACC with braking until at standstill/Stop & Go,
IDE06710,Cruise control system: permanent deactivation,No switch-off occurs,
IDE06726,Timing deviation after chain replacement: intake bank 1,0.00, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,-3.88, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06738,Chain elongation: no. of valid initial values: intake bank 1,0,
IDE06740,Chain elongation: no. of valid initial values: exhaust bank 1,1,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,not active,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,Available,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Passive Regeneration,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Not available,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Not available,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Adsorption,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,not active,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,Not available,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,Available,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,0.0, %
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,Not available,
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,0, min
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,Available,
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,0, km
IDE07001,Piston-cooling jets: activation,On,
IDE07017,Catalytic converter damaging misfires direct injection,0,
IDE07019,Number of ignitions direct injection,1734295,
IDE07020,Number of ignitions intake manifold injection,0,
IDE07023,Misfires per 1000 revolutions of cyl. 1 intake manif. injection,0,
IDE07024,Misfires per 1000 revolutions of cyl. 2 intake manif. injection,0,
IDE07025,Misfires per 1000 revolutions of cyl. 3 intake manif. injection,0,
IDE07026,Misfires per 1000 revolutions of cyl. 4 intake manif. injection,0,
IDE07027,Heat quantity that was transported via the catalytic converter,0, J
IDE07031,Oil pressure switch for piston-cooling jets: status,Open,
IDE07077-ENG391566,AVS valve stroke position: exhaust-AVS_actual_position_1,not installed,
IDE07077-ENG391170,AVS valve stroke position: exhaust-AVS_actual_position_2,not installed,
IDE07077-ENG391445,AVS valve stroke position: exhaust-AVS_actual_position_3,not installed,
IDE07077-ENG391386,AVS valve stroke position: exhaust-AVS_actual_position_4,not installed,
IDE07077-ENG391253,AVS valve stroke position: exhaust-AVS_actual_position_5,AVS Stroke,
IDE07077-ENG391620,AVS valve stroke position: exhaust-AVS_actual_position_6,AVS Stroke,
IDE07077-ENG391480,AVS valve stroke position: exhaust-AVS_actual_position_7,AVS Stroke,
IDE07077-ENG391539,AVS valve stroke position: exhaust-AVS_actual_position_8,AVS Stroke,
IDE07079,AVS result of last switch-over: exhaust,Malfunction,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07254,Gasoline pressure tank refueling request button,not coded / not installed,
IDE07548,Engine temp. mangmt. actuator: specified value of angle,131.20, °
IDE07549,Engine temp. mangmt. actuator: actual value of angle,131.83, °
IDE07550,Engine temp. management actuator: raw value,2111,
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07552,Engine temper.managem.actuator adaptation: result adaptation,Adaptation successfully finished,
IDE07553,Engine temperature management actuator: after-run stop,3965,
IDE07554,Engine temperature management actuator: stop open,129,
IDE07564,Required torque adjustment by idling regulator,11.9, Nm
IDE07571,Engine torque,31.7, Nm
IDE07574,Long-term fuel trim bank 1 at idle,0.06, mg/stroke
IDE07575,Driver intention torque,28.9, Nm
IDE07576,Lost torque adaptation driving mode,3.4, Nm
IDE07577,Lost torque adaptation A/C compressor and driving mode,2.0, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,operated,
IDE07598-MAS00325,Cruise control switch actuation-Set,Not operated,
IDE07598-MAS00326,Cruise control switch actuation-Resume,Not operated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,Not operated,
IDE07598-MAS02310,Cruise control switch actuation-DELAY,Not operated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,Not operated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,operated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,Not operated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,operated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,Not operated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07608,Standard test of current section,0,
IDE07669,Oxygen sensor 2 bank 1 after catalytic converter operational readiness status,active,
IDE07784,Turbine actuator 1 bank 1: position feedback – specified value,100.00, %
IDE07785,Turbine actuator 1 bank 1: position feedback – actual value,100.36, %
IDE07787,Turbine actuator 1 bank 1: position feedback – mechanical stops,72,
IDE07788,Turbine actuator 1 bank 1: position feedback – breakaway attempts,0,
IDE07789,Turbine actuator 1 bank 1: activation,-2.27, %
IDE07901,Error counter bad fuel,0,
IDE07904-ENG118117,Brake test switch status-actuated__activated,Not operated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,Not operated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,Not operated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07963,Cam piece counter position malfunction,0,
IDE08071,Remote start cancellation reason store 1,16385,
IDE08072,Remote start cancellation reason store 2,0,
IDE08073,Remote start cancellation reason store 3,0,
IDE08074,Remote start cancellation reason store 4,0,
IDE08075,Remote start cancellation reason store 5,0,
IDE08805,EVAP valve diag. activation condition at minimal load,0.000, counts
IDE08806,EVAP valve diag. activation condition at maximum load,-2717, mbar
IDE09907,Fuel quality,Fuel according to DIN EN 228 detected,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-2.95, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,-3.28, °
IDE10063-MAS00666,Engine oil level: current value-Warning,no warning,
IDE10063-MAS00900,Engine oil level: current value-Oil level,0.00, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,0, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,0, km
IDE10063-MAS09804,Engine oil level: current value-Test method 1,OFF,
IDE10063-MAS09805,Engine oil level: current value-Test method 2,OFF,
IDE10063-MAS09806,Engine oil level: current value-Test method 3,OFF,
IDE10063-MAS09807,Engine oil level: current value-Qualification,0,
IDE10064-MAS00666,Engine oil level: history 1-Warning,no warning,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,0.00, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,0, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,0, km
IDE10064-MAS09804,Engine oil level: history 1-Test method 1,OFF,
IDE10064-MAS09805,Engine oil level: history 1-Test method 2,OFF,
IDE10064-MAS09806,Engine oil level: history 1-Test method 3,OFF,
IDE10064-MAS09807,Engine oil level: history 1-Qualification,0,
IDE10065-MAS00666,Engine oil level: history 2-Warning,no warning,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,0.00, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,0, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,0, km
IDE10065-MAS09804,Engine oil level: history 2-Test method 1,OFF,
IDE10065-MAS09805,Engine oil level: history 2-Test method 2,OFF,
IDE10065-MAS09806,Engine oil level: history 2-Test method 3,OFF,
IDE10065-MAS09807,Engine oil level: history 2-Qualification,0,
IDE10066-MAS00666,Engine oil level: history 3-Warning,no warning,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,0.00, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,0, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,0, km
IDE10066-MAS09804,Engine oil level: history 3-Test method 1,OFF,
IDE10066-MAS09805,Engine oil level: history 3-Test method 2,OFF,
IDE10066-MAS09806,Engine oil level: history 3-Test method 3,OFF,
IDE10066-MAS09807,Engine oil level: history 3-Qualification,0,
IDE10067-MAS00666,Engine oil level: history 4-Warning,no warning,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,0.00, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,0, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,0, km
IDE10067-MAS09804,Engine oil level: history 4-Test method 1,OFF,
IDE10067-MAS09805,Engine oil level: history 4-Test method 2,OFF,
IDE10067-MAS09806,Engine oil level: history 4-Test method 3,OFF,
IDE10067-MAS09807,Engine oil level: history 4-Qualification,0,
IDE10068-MAS00666,Engine oil level: history 5-Warning,no warning,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,0.00, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,0, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,0, km
IDE10068-MAS09804,Engine oil level: history 5-Test method 1,OFF,
IDE10068-MAS09805,Engine oil level: history 5-Test method 2,OFF,
IDE10068-MAS09806,Engine oil level: history 5-Test method 3,OFF,
IDE10068-MAS09807,Engine oil level: history 5-Qualification,0,
IDE10069-MAS00666,Engine oil level: history 6-Warning,no warning,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,0.00, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,0, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,0, km
IDE10069-MAS09804,Engine oil level: history 6-Test method 1,OFF,
IDE10069-MAS09805,Engine oil level: history 6-Test method 2,OFF,
IDE10069-MAS09806,Engine oil level: history 6-Test method 3,OFF,
IDE10069-MAS09807,Engine oil level: history 6-Qualification,0,
IDE10070-MAS00666,Engine oil level: history 7-Warning,no warning,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,0.00, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,0, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,0, km
IDE10070-MAS09804,Engine oil level: history 7-Test method 1,OFF,
IDE10070-MAS09805,Engine oil level: history 7-Test method 2,OFF,
IDE10070-MAS09806,Engine oil level: history 7-Test method 3,OFF,
IDE10070-MAS09807,Engine oil level: history 7-Qualification,0,
IDE10071-MAS00666,Engine oil level: history 8-Warning,no warning,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,0.00, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,0, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,0, km
IDE10071-MAS09804,Engine oil level: history 8-Test method 1,OFF,
IDE10071-MAS09805,Engine oil level: history 8-Test method 2,OFF,
IDE10071-MAS09806,Engine oil level: history 8-Test method 3,OFF,
IDE10071-MAS09807,Engine oil level: history 8-Qualification,0,
IDE10072-MAS00666,Engine oil level: history 9-Warning,no warning,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,0.00, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,0, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,0, km
IDE10072-MAS09804,Engine oil level: history 9-Test method 1,OFF,
IDE10072-MAS09805,Engine oil level: history 9-Test method 2,OFF,
IDE10072-MAS09806,Engine oil level: history 9-Test method 3,OFF,
IDE10072-MAS09807,Engine oil level: history 9-Qualification,0,
IDE10120,Chain elongation inlet: mileage of the last adaptation,0, km
IDE10121,Chain elongation outlet: mileage of the last adaptation,0, km
IDE10254,Turbine actuator 1 bank 1: pos. contr. spec. value,100.00, %
IDE10300,OBD Driving Cycle detected,active,
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,0.000, V
IDE10380,Knock sensor average voltage bank 1,0.402, V
IDE10551-MAS05304,Pre-ignition counter for oxygen shift-Cylinder 1,1,
IDE10551-MAS05305,Pre-ignition counter for oxygen shift-Cylinder 2,1,
IDE10551-MAS05306,Pre-ignition counter for oxygen shift-Cylinder 3,1,
IDE10551-MAS05307,Pre-ignition counter for oxygen shift-Cylinder 4,1,
IDE10551-MAS05308,Pre-ignition counter for oxygen shift-Cylinder 5,0,
IDE10551-MAS05309,Pre-ignition counter for oxygen shift-Cylinder 6,0,
IDE10551-MAS05310,Pre-ignition counter for oxygen shift-Cylinder 7,0,
IDE10551-MAS05311,Pre-ignition counter for oxygen shift-Cylinder 8,0,
IDE10552-MAS05304,Pre-ignition counter for torque reduction-Cylinder 1,0,
IDE10552-MAS05305,Pre-ignition counter for torque reduction-Cylinder 2,0,
IDE10552-MAS05306,Pre-ignition counter for torque reduction-Cylinder 3,0,
IDE10552-MAS05307,Pre-ignition counter for torque reduction-Cylinder 4,0,
IDE10552-MAS05308,Pre-ignition counter for torque reduction-Cylinder 5,0,
IDE10552-MAS05309,Pre-ignition counter for torque reduction-Cylinder 6,0,
IDE10552-MAS05310,Pre-ignition counter for torque reduction-Cylinder 7,0,
IDE10552-MAS05311,Pre-ignition counter for torque reduction-Cylinder 8,0,
IDE10553-MAS05304,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1,0,
IDE10553-MAS05305,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2,0,
IDE10553-MAS05306,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3,0,
IDE10553-MAS05307,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4,0,
IDE10553-MAS05308,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5,0,
IDE10553-MAS05309,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6,0,
IDE10553-MAS05310,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7,0,
IDE10553-MAS05311,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8,0,
IDE10554-MAS05304,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1,0,
IDE10554-MAS05305,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2,0,
IDE10554-MAS05306,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3,0,
IDE10554-MAS05307,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4,0,
IDE10554-MAS05308,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5,0,
IDE10554-MAS05309,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6,0,
IDE10554-MAS05310,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7,0,
IDE10554-MAS05311,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8,0,
IDE10560,Adaption of radiator shutters: status,completed successfully,
IDE10580,Engine oil level: test method 1,94.20, %
IDE10581,Engine oil level: test method 2,90.30, %
IDE10582,Engine oil level: test method 3,97.70, %
IDE10633,Clutch protection function: reduced torque,1023.9, Nm
IDE10634,Clutch protection function: slip speed of the clutch,0, /min
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG355207,Exhaust warning light: triggering contr. module-MIL_Request_from_BCCM,No,
IDE10710-ENG353763,Exhaust warning light: triggering contr. module-MIL_Request_from_DCDC,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG420335,Exhaust warning light: triggering contr. module-MIL-Request from Battery Diagnostic Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG137566,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG137567,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10732,Engine oil level: factor volume,58.00,
IDE10848,Accelerator pedal position,0.00, %
IDE10968,Activation radiator shutter result,72.90, %
IDE10970-MAS11563,Number of prevented stop processes-hood open,2,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,2,
IDE10989,Immobilizer: historic data,|Year,Month,Day,Hours,Minutes,Seconds,,,|2026,5,28,3,20,45,hood open,not active,Brake pedal information: plausibility|2000,0,0,0,1,41,not active,not active,not active|2074,8,2,16,0,0,not active,not active,not active|2127,15,31,31,63,63,hood open,Function locked due to frequent stalling,Brake pedal information: plausibility|2127,15,31,31,63,63,hood open,Function locked due to frequent stalling,Brake pedal information: plausibility|2127,15,31,31,63,63,hood open,Function locked due to frequent stalling,Brake pedal information: plausibility|2127,15,31,31,63,63,hood open,Function locked due to frequent stalling,Brake pedal information: plausibility|2127,15,31,31,63,63,hood open,Function locked due to frequent stalling,Brake pedal information: plausibility|2127,15,31,31,63,63,hood open,Function locked due to frequent stalling,Brake pedal information: plausibility|2127,15,31,31,63,63,hood open,Function locked due to frequent stalling,Brake pedal information: plausibility|2127,15,31,31,63,63,hood open,Function locked due to frequent stalling,Brake pedal information: plausibility|2127,15,31,31,63,63,hood open,Function locked due to frequent stalling,Brake pedal information: plausibility|2127,15,31,31,63,63,hood open,Function locked due to frequent stalling,Brake pedal information: plausibility|2127,15,31,31,63,63,hood open,Function locked due to frequent stalling,Brake pedal information: plausibility|2127,15,31,31,63,63,hood open,Function locked due to frequent stalling,Brake pedal information: plausibility|,
IDE10994,Poor start counter at start-stop,0,
IDE11080,AVS operating state: outlet,regular operation,
IDE11115,Start/stop driver request: counter restart by starter,1,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11267,Oil level: max. value: relative,110.60, %
IDE11268,Oil level: min. value: relative,85.50, %
IDE11302-MAS05513,Engine oil level: test method 1 qualification-Bit 0,5,
IDE11302,Engine oil level: test method 1 qualification,Unknown (5),
IDE11303-MAS05513,Engine oil level: test method 3 qualification-Bit 0,7,
IDE11303,Engine oil level: test method 3 qualification,Saved mean value,
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometres,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometres,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometres,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometres,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometres,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometres,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometres,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometres,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometres,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometres,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11351,Position sensor for chrg. press. actuator: digit. value,2886,
IDE11493,Disengaging clutch actuator: act. position,0.00000, mm
IDE11494-MAS03359,Disengaging clutch actuator: status-Text,OFF,
IDE11495,Disengaging clutch actuator: current,-50.0, A
IDE11496,Disengaging clutch actuator: voltage,0.0, V
IDE11498,Decoupler actuator,0.00, °C
IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
IDE11577-MAS04416,Stop process prevented 2-Sporadic function prevention,not active,
IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
IDE11577-MAS04591,Stop process prevented 2-Air system diagnosis,not active,
IDE11577-MAS04870,Stop process prevented 2-Thermostat testing not completed,not active,
IDE11577-MAS06602,Stop process prevented 2-Engine temperature,not active,
IDE11577-MAS06604,Stop process prevented 2-Start/stop sensors:,active,
IDE11577-MAS06605,Stop process prevented 2-Regeneration Mode,not active,
IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
IDE11577-MAS08032,Stop process prevented 2-DTC memory entry in engine control module,not active,
IDE11577-MAS09416,Stop process prevented 2-Learning function active,not active,
IDE11577-MAS13644,Stop process prevented 2-Engine protection active,not active,
IDE11577-MAS13645,Stop process prevented 2-Fuel gelling protection active,not active,
IDE11577-MAS13661,Stop process prevented 2-Exhaust treatment diagnosis,not active,
IDE11577-MAS16918,Stop process prevented 2-Restriction in start system,not active,
IDE11598,Tank deaeration valve diagnosis: unweighted input value,0.000, counts
IDE11599,Tank deaeration valve diagnosis: weighted output value,0.000, counts
IDE11910-MAS09435,Turbine actuator 1 bank 1: adaptation status-Resetting of adaptation values,not active,
IDE11910-MAS12399,Turbine actuator 1 bank 1: adaptation status-Sign of sensor characteristic slope,not active,
IDE11910-MAS12400,Turbine actuator 1 bank 1: adaptation status-Learn offset enable: ambient air pressure,not active,
IDE11910-MAS12401,Turbine actuator 1 bank 1: adaptation status-Learn offset enable: time after start,not active,
IDE11910-MAS12402,Turbine actuator 1 bank 1: adaptation status-Learn offset enable,not active,
IDE11910-MAS12403,Turbine actuator 1 bank 1: adaptation status-Offset learning active,not active,
IDE11910-MAS12404,Turbine actuator 1 bank 1: adaptation status-Opened stop successfully learned,not active,
IDE11910-MAS12405,Turbine actuator 1 bank 1: adaptation status-Closed stop successfully learned,not active,
IDE11910-MAS12406,Turbine actuator 1 bank 1: adaptation status-Offset learning completed,not active,
IDE11910-MAS12407,Turbine actuator 1 bank 1: adaptation status-Reading EEPROM was not successful,not active,
IDE11910-MAS12408,Turbine actuator 1 bank 1: adaptation status-Blocking of control monitoring up to end stops learned,not active,
IDE11910-MAS12409,Turbine actuator 1 bank 1: adaptation status-brake applied,not active,
IDE11910-MAS12410,Turbine actuator 1 bank 1: adaptation status-Open position in idle successfully learned,not active,
IDE11910-MAS12411,Turbine actuator 1 bank 1: adaptation status-Closed position in idle successfully taught,not active,
IDE11910,Turbine actuator 1 bank 1: adaptation status,0,
IDE11919,Lock time for cooling down of secondary air pump,0, s
IDE12099-MAS10949,Decoupler actuator: manufacturers code: block A-Manufacturer code 1,0,
IDE12099-MAS10950,Decoupler actuator: manufacturers code: block A-Manufacturer code 2,0,
IDE12100-MAS10951,Decoupler actuator: manufacturers code: block B-Manufacturer code 3,0,
IDE12100-MAS10952,Decoupler actuator: manufacturers code: block B-Manufacturer code 4,0,
IDE12137,Tank fill level diagnostic reference value,39.9, l
IDE12138,Fuel consumption per driving cycle,92.52, l/100km
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,-2.32, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,9.26, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,5.00, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,-12.44, %
IDE12210,Particle filter: water mass,0.0, g
IDE12392,Turbocharger: pin separation from min. throughput position,6553.4, mV
IDE12401-MAS02397,Turbocharger: positioner status-Sensor error,No,
IDE12401-MAS09482,Turbocharger: positioner status-Current limitation active,No,
IDE12401-MAS12412,Turbocharger: positioner status-Closed position successfully taught,Yes,
IDE12401-MAS14320,Turbocharger: positioner status-Actuator completely open,No,
IDE12401-MAS14321,Turbocharger: positioner status-Actuator completely closed,No,
IDE12401-MAS14322,Turbocharger: positioner status-Open position successfully taught,Yes,
IDE12401-MAS14324,Turbocharger: positioner status-Actuated deactivated due to output stages malfunction,No,
IDE12401-MAS14327,Turbocharger: positioner status-Remaining control deviation recognized,No,
IDE12401-MAS14329,Turbocharger: positioner status-Actuator sticks in the open position,No,
IDE12401-MAS14330,Turbocharger: positioner status-Actuator sticks in the closed position,No,
IDE12401-MAS14332,Turbocharger: positioner status-Time limitation or routine active,No,
IDE12401-MAS14333,Turbocharger: positioner status-Wiping active,No,
IDE12401-MAS14334,Turbocharger: positioner status-Specified position reached,No,
IDE12401-MAS14335,Turbocharger: positioner status-Bearing regulation due to faults deactivated,No,
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,15.36, g
IDE13086,Particle filter: maximum soot build-up reached,20.48, g
IDE13087,Particle filter: maximum ash build-up reached,30.00, g
IDE13088,Particle filter: maximum ash loading ratio reached,5.000, counts
IDE13089,Particle filter: high soot accumulation ratio,7.770, counts
IDE13090,Particle filter: maximum soot loading ratio reached,10.600, counts
IDE13091,Particle filter: ash loading ratio,1.000, counts
IDE13092,Particle filter: soot accumulation ratio,0.999, counts
IDE13301-MAS06606,Drivetrain coordinator: brake fault status-Brake under pressure too low,No,
IDE13301-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE13301-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE13301-MAS14988,Drivetrain coordinator: brake fault status-ESP system malfunction,No,
IDE13301-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE13301-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE13301-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE13301-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE13301-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE13301-MAS16114,Drivetrain coordinator: brake fault status-Deceleration management error,No,
IDE13301-MAS16115,Drivetrain coordinator: brake fault status-Deceleration management: restricted performance,No,
IDE13301-MAS16116,Drivetrain coordinator: brake fault status-Deceleration management not available,No,
IDE13336-MAS04795,Drive train coordinator reversible switch off conditions-main switch off,No,
IDE13336-MAS05192,Drive train coordinator reversible switch off conditions-Driver braking,No,
IDE13336-MAS05823,Drive train coordinator reversible switch off conditions-Speed signal error during initialization,No,
IDE13336-MAS05824,Drive train coordinator reversible switch off conditions-Emer. engine operation,No,
IDE13336-MAS05836,Drive train coordinator reversible switch off conditions-Acceleration monitoring error,No,
IDE13336-MAS05901,Drive train coordinator reversible switch off conditions-Trans. emerg. operation,No,
IDE13336-MAS12585,Drive train coordinator reversible switch off conditions-Speed threshold for reversible ACC shut-off,No,
IDE13336-MAS12586,Drive train coordinator reversible switch off conditions-Speed threshold for ending the brake torque shut-off ramp,No,
IDE13336-MAS12588,Drive train coordinator reversible switch off conditions-Speed cut-off active,No,
IDE13336-MAS12590,Drive train coordinator reversible switch off conditions-Reversible brake system error,No,
IDE13336-MAS12591,Drive train coordinator reversible switch off conditions-Engine off or drive is not ready,No,
IDE13336-MAS15049,Drive train coordinator reversible switch off conditions-Drive train open or no gear selected,No,
IDE13336-MAS16227,Drive train coordinator reversible switch off conditions-Stopping distance reduction 3 interventions,No,
IDE13336-MAS16228,Drive train coordinator reversible switch off conditions-Tracking system interface shutdown,No,
IDE13336-MAS16230,Drive train coordinator reversible switch off conditions-ESP safety-related message condition,No,
IDE13336-MAS16231,Drive train coordinator reversible switch off conditions-ACC switch off because of driver braking,No,
IDE13336-MAS16232,Drive train coordinator reversible switch off conditions-PCC sensor: reversible error,No,
IDE13336-MAS16235,Drive train coordinator reversible switch off conditions-Intelligent parking assistant reversible error,No,
IDE13336-MAS16246,Drive train coordinator reversible switch off conditions-ACC breaking only possible because of CAN bus,No,
IDE13336-MAS16247,Drive train coordinator reversible switch off conditions-Diagnostics fadeout due to identified malfunction,No,
IDE13336-MAS16248,Drive train coordinator reversible switch off conditions-Safety computer detects crash,No,
IDE13336-MAS16249,Drive train coordinator reversible switch off conditions-Electrical parking brake: braking,No,
IDE13336-MAS16253,Drive train coordinator reversible switch off conditions-GRA breaking intervention: switch off due to brake disc temperature,No,
IDE13336-MAS16254,Drive train coordinator reversible switch off conditions-Hill descent assistant active,No,
IDE13336-MAS16255,Drive train coordinator reversible switch off conditions-Locking by trailer shunting assistant,No,
IDE13336-MAS16256,Drive train coordinator reversible switch off conditions-Blocking by parking assistant,No,
IDE13337-MAS05814,Drive train coordinator irreversible switch off conditions-CAN communication error,No,
IDE13337-MAS05815,Drive train coordinator irreversible switch off conditions-CAN signal error,No,
IDE13337-MAS05818,Drive train coordinator irreversible switch off conditions-Transmission coding not plausible,No,
IDE13337-MAS05820,Drive train coordinator irreversible switch off conditions-ACC malfunction,No,
IDE13337-MAS05821,Drive train coordinator irreversible switch off conditions-Braking intervention too weak,No,
IDE13337-MAS05824,Drive train coordinator irreversible switch off conditions-Emer. engine operation,No,
IDE13337-MAS05825,Drive train coordinator irreversible switch off conditions-Engine control module fault,No,
IDE13337-MAS05829,Drive train coordinator irreversible switch off conditions-Brake light fault,No,
IDE13337-MAS05830,Drive train coordinator irreversible switch off conditions-CCS deactivated due to fault in control component,No,
IDE13337-MAS05831,Drive train coordinator irreversible switch off conditions-ACC deactivated due to fault in control component,No,
IDE13337-MAS05832,Drive train coordinator irreversible switch off conditions-Coding error,No,
IDE13337-MAS05833,Drive train coordinator irreversible switch off conditions-ESC error,No,
IDE13337-MAS05835,Drive train coordinator irreversible switch off conditions-Clutch pedal fault,No,
IDE13337-MAS05836,Drive train coordinator irreversible switch off conditions-Acceleration monitoring error,No,
IDE13337-MAS15052,Drive train coordinator irreversible switch off conditions-Brake light actuation malfunction,No,
IDE13337-MAS16257,Drive train coordinator irreversible switch off conditions-Brake pedal implausible,No,
IDE13337-MAS16258,Drive train coordinator irreversible switch off conditions-Transport mode active,No,
IDE13337-MAS16259,Drive train coordinator irreversible switch off conditions-GRA looking due to software as product,No,
IDE13337-MAS16260,Drive train coordinator irreversible switch off conditions-Emergency assistant: actual acceleration error,No,
IDE13337-MAS16262,Drive train coordinator irreversible switch off conditions-Vehicle speed determination: substitute value,No,
IDE13337-MAS16263,Drive train coordinator irreversible switch off conditions-Intelligent parking assistant irreversible error,No,
IDE13385,Turbocharger : current actual minimum throughput position raw value,1200.0, mV
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,3VVUW7RM1TM130726,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,21,
IDE13845,Production mode status,not active,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 65 F0 A7 B9 49 1B E3,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 0A,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14753,Particulate filter: loading stage,0, counts
IDE14760,Particulate filter: oil ash load measured,0.0, %
IDE14761,Particulate filter: oil ash load calculated,0.0, %
IDE14763,Particulate filter: water load,0.0, %
IDE14765,Particulate filter: soot load measured,0.0, %
IDE14767,Particulate filter: soot load calculated,0.0, %
IDE14789-ENG252532,Currently selected and last used starter device-active start device selection - belt starter generator,not selected,
IDE14789-ENG252533,Currently selected and last used starter device-active start device selection - electrical machine,not selected,
IDE14789-ENG252534,Currently selected and last used starter device-active start device selection - pinion starter,not selected,
IDE14789-ENG252584,Currently selected and last used starter device-last used start device - belt starter generator,not active,
IDE14789-ENG252585,Currently selected and last used starter device-last used start device - electrical machine,not active,
IDE14789-ENG252586,Currently selected and last used starter device-last used start device - pinion starter,not active,
IDE15781,VW Trustcenter Project ID,1069,
IDE15972,Charge Air Pressure Actuator blocking position,0.0, %
IDE15976-ENG275973,Particulate filter regeneration history-Endkilometer 1,0, km
IDE15976-ENG275974,Particulate filter regeneration history-Endkilometer 2,0, km
IDE15976-ENG275975,Particulate filter regeneration history-Endkilometer 3,0, km
IDE15976-ENG275971,Particulate filter regeneration history-Startkilometer 1,0, km
IDE15976-ENG275970,Particulate filter regeneration history-Startkilometer 2,0, km
IDE15976-ENG275972,Particulate filter regeneration history-Startkilometer 3,0, km
IDE15979,Service regeneration of particulate filter: advance,0, %
IDE16744,Venting system of purge air pump: temperature,46.0, °C
IDE16745,Venting system of purge air pump: speed,29.5, %
IDE16746,Venting system of purge air pump: set speed,30.0, %
IDE17086,Charge air pressure actuator: initial adaptation of the lower stop,1074, counts
IDE17130,Charge air pressure actuator: initial adaptation of the upper stop,3283, counts
IDE17177,Charge air pressure actuator: averaged adaptation of the upper stop,3270, counts
IDE17309,Charge air pressure actuator: averaged adaptation of the lower stop,1098, counts
IDE17938,Charge air pressure actuator: adaptation for lower stop,1094, counts
IDE17939,Charge air pressure actuator: adaptation for upper stop,3267, counts
IDE18169,Activated charcoal container: loading of filtered value,0.04, no unit
IDE18171,Fuel tank ventilation line pressure: raw value,995.3, hPa
IDE18172,Fuel tank ventilation line pressure: filtered value,6553.5, hPa
IDE18776,Audi valvelift system switchover counter 2: total,151, no unit
IDE19010,Crankcase breather line pressure: raw value,986.7184, hPa
MAS17031,Radiator shutter 1: actual position,73, %
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS23170,Tank ventilation valve blockage: diagnosis status,Diagnosis not finished,
MAS23171,Tank ventilation valve blockage: diagnosis result,No malfunction detected,
MAS23172,Purge air line: diagnosis status,Diagnosis not finished,
MAS23173,Purge air line: diagnosis result,Diagnosis not finished,
MAS23174,Ventilation system flow rate: diagnosis status,Diagnosis not finished,
MAS23175,Ventilation system flow rate: diagnosis result,No malfunction detected,
MAS29691,Tank leakage diagnostics: principal diagnostics for routine ATLD,Function is not active,
MAS29707,Tank leakage diagnostics: additional diagnostics for routine ATLD,Function is not active,
MAS29855,Duration of pump-up phase last diagnostic run,0.00, s
MAS29856,Tank differential pressure at start of observation phase,0.00, hPa
MAS29857,Tank differential pressure at end of observation phase,0.00, hPa
MAS29858,Fuel outgassing in fuel tank system,0.000, Pa/s
MAS29859,Counter for PinPointing starts,0, counts
MAS29860,Leak in fuel tank system at end of diagnostic phase,0.000, mm
MAS29861,Tank differential pressure at end of last diagnostic phase,0.00, hPa
MAS30050,Fuel tank leak detection: successful diagnoses since last refueling,0, counts
MAS30150,Status of adaptation for injector opening time cyl. 1,0, units
MAS30154,Average of the boost voltage of the high-pressure injector,66, V
MAS30155,Status of adaptation for injector opening time cyl. 2,0, units
MAS30157,Smallest hydraulic injection time in the driving cycle,1085, µs
MAS30158,Plausibility of the injector return value byte 3,0, units
MAS30159,Plausibility of the injector return value byte 0,0, units
MAS30160,Plausibility of the injector return value byte 4,0, units
MAS30161,Plausibility of the injector return value byte 2,0, units
MAS30162,Plausibility of the injector return value byte 1,0, units
MAS30163,Status of electr. monitoring of general multi-point injection,0, units
MAS30164,Status of monitoring of multi-point injection,0, units
MAS30166,Status of electr. monitoring of multi-point injection,0, units
MAS30169,Status of monitoring of general multi-point injection,0, units
MAS30170,Error pattern of the power output stage for injector during start,0, units
MAS30171,Status of adaptation for injector opening time cyl. 4,0, units
MAS30172,Status of adaptation for injector opening time cyl. 3,0, units
MAS30173,Number of injector activations per work cycle,1, units
MAS30174,Error pattern of the power output stage for the injector,0, units
MAS30175,Current boost voltage of the high-pressure injector,66, V
ENG102981,AC compressor: speed increase,true,
ENG103860,AC request: speed increase,true,
ENG103042,Accelerator pedal sender: learned end stop,4.102, V
ENG103474,Activation of oil pressure switching valve,00000001 ,
ENG252355,Active Aerodynamic Features #1 Off-cycle Credit Vehicle Data,|Active Grille Air Shutter A Timer 1 (Recent),Active Grille Air Shutter A Timer 2 (Recent),Active Grille Air Shutter A Timer 1 (Lifetime),Active Grille Air Shutter A Timer 2 (Lifetime),Active Grille Air Shutter B Timer 1 (Recent),Active Grille Air Shutter B Timer 2 (Recent),Active Grille Air Shutter B Timer 1 (Lifetime),Active Grille Air Shutter B Timer 2 (Lifetime)|13092,1374,13112,1380,4294967295,4294967295,4294967295,4294967295|, s
ENG252358,Active Powertrain Warm-up Features Off-cycle Credit Vehicle Data,|Active Engine Warm-up Timer (Recent),Active Engine Warm-up Timer (Lifetime),Active Transmission Warm-up Timer (Recent),Active Transmission Warm-up Timer (Lifetime)|9713,14538,4294967295,4294967295|, s
ENG103323,Additional water pump,00000001 ,
ENG101828,Air mass,17.09, kg/h
ENG104264,Alternator load,850, W
ENG103910,Ambient temperature,33.00, °C
ENG112539,AR_THR_AD_ADD_MMV,-0.0000, cm²
ENG103165,Battery voltage,14.5, V
ENG138673,Bypasstool_a2l_name,SD2C56,
ENG138672,Bypasstool_manipulation_bit,not active,
ENG101413,Calibration Identifications,||06U070BH5627BXAB|5QS530K+20970143|,
ENG99697,Calibration Verification Numbers,||31 2D 52 5E|0C 94 DF B4|,
ENG128780,CAM_DIF_VCP[EX_1],-0.02, °
ENG128781,CAM_DIF_VCP[IN_1],0.05, °
ENG112540,CAM_PHA_ENG[GES_EX][CBK_1],4.961, °
ENG112541,CAM_PHA_ENG[GES_IN][CBK_1],3.117, °
ENG101785,Cat. temperature: bank 1,391.98, °C
ENG252361,Certification Test Group/Engine Family Number,|Certification Test Group/Engine Family Number|TVGAJ02.0V3G|,
ENG125189,CTR_CAM_IN_SP_PI_DET_REQ[0],0,
ENG125190,CTR_CAM_IN_SP_PI_DET_REQ[1],0,
ENG125191,CTR_CAM_IN_SP_PI_DET_REQ[2],0,
ENG125192,CTR_CAM_IN_SP_PI_DET_REQ[3],0,
ENG390342,CTR_DEB_ACT_VVL_STC,2,
ENG390343,CTR_ERR_DET_CAM_STK_0_VVL_STC,0,
ENG390344,CTR_ERR_DET_CAM_STK_1_VVL_STC,0,
ENG390345,CTR_ERR_INTM_SIG_VVL_STC,0,
ENG390346,CTR_ERR_INTM_SWI_VVL_STC,0,
ENG390347,CTR_ERR_SUSP_MAP_VVL_STC,0,
ENG390348,CTR_ERR_SUSP_MISF_VVL_STC,0,
ENG125193,CTR_LAMB_SP_PI_REQ[0],1,
ENG125194,CTR_LAMB_SP_PI_REQ[1],1,
ENG125195,CTR_LAMB_SP_PI_REQ[2],1,
ENG125196,CTR_LAMB_SP_PI_REQ[3],1,
ENG390349,CTR_LIH_ACT_VVL_STC,0,
ENG112554,CTR_MIS_DC_MMV_CYL_SAE[0],0,
ENG112555,CTR_MIS_DC_MMV_CYL_SAE[1],0,
ENG112556,CTR_MIS_DC_MMV_CYL_SAE[2],0,
ENG112557,CTR_MIS_DC_MMV_CYL_SAE[3],0,
ENG112558,CTR_MIS_TOT_NVMY_SAE,134,
ENG125197,CTR_REQ_IV_OFF_PI_FAST[0],0,
ENG125198,CTR_REQ_IV_OFF_PI_FAST[1],0,
ENG125199,CTR_REQ_IV_OFF_PI_FAST[2],0,
ENG125200,CTR_REQ_IV_OFF_PI_FAST[3],0,
ENG125201,CTR_REQ_IV_OFF_PI_SLOW[0],0,
ENG125202,CTR_REQ_IV_OFF_PI_SLOW[1],0,
ENG125203,CTR_REQ_IV_OFF_PI_SLOW[2],0,
ENG125204,CTR_REQ_IV_OFF_PI_SLOW[3],0,
ENG128782,CTR_REQ_IV_OFF_PI_SLOW_TMP[0],0,
ENG128783,CTR_REQ_IV_OFF_PI_SLOW_TMP[1],0,
ENG128784,CTR_REQ_IV_OFF_PI_SLOW_TMP[2],0,
ENG128785,CTR_REQ_IV_OFF_PI_SLOW_TMP[3],0,
ENG100764,CTR_SUM_SRV_INTL,0.0,
ENG125205,CTR_TQI_POW_MAX_PI_REQ[0],0,
ENG125206,CTR_TQI_POW_MAX_PI_REQ[1],0,
ENG125207,CTR_TQI_POW_MAX_PI_REQ[2],0,
ENG125208,CTR_TQI_POW_MAX_PI_REQ[3],0,
ENG119929,CTR_VLD_CAT_GAP_AFL[1],0,
ENG119930,CTR_VLD_CAT_GAP_AFR[1],0,
ENG101652,Cylinder shut-off: cylinder suppression,00000000 ,
ENG112560,DIST_ACT_MIL_SAE,0, km
ENG112561,DIST_DTC_CLR_SAE,477, km
ENG100531,DIST_ST,496500, m
ENG275645,Distance Traveled Since Evap Monitoring Decision,|Distance Traveled Since Evap Monitoring Decision|365|, km
ENG100131,ECU_STATE,SYN_ENG_IGK_ON,
ENG100152,ECUNAME,|ECU,ECUNAME|ECM,EngineControl|,
ENG390364,EFF_IGA_CH_L_QUO_IS_MAX,15, %
ENG390365,EFF_IGA_CH_L_QUO_PL_MAX,60, %
ENG100882,EFF_IGA_CST_QUO_IS_MAX,2, %
ENG99938,EFF_IGA_CST_QUO_PL_MAX,27, %
ENG247045,Engine Exhaust Flow Rate,18.4, kg/h
ENG151174,Engine Friction - Percent Torque,4.0, %
ENG104044,Engine load,21.9, %
ENG103667,ENVD_0_MON,0,
ENG99424,ENVD_1_MON,0,
ENG99790,ENVD_2_MON,0,
ENG99455,ENVD_3_MON,0,
ENG132815,ENVD_4_MON,0,
ENG132816,ENVD_5_MON,0,
ENG132817,ENVD_6_MON,0,
ENG101942,ESI (extended service intervals) oil warning threshold,0.00, mm
ENG112562,FAC_AR_THR_AD,0.000000, %
ENG245642,FAC_FQ_ST_AD_SAVE_RNG_1_H_RES,1.00000,
ENG245643,FAC_FQ_ST_AD_SAVE_RNG_2_H_RES,1.00000,
ENG245644,FAC_FQ_ST_AD_SAVE_RNG_3_H_RES,1.00000,
ENG245645,FAC_FQ_ST_AD_SAVE_RNG_4_H_RES,1.00000,
ENG100298,FAC_LAM_CP,0.000, %
ENG100108,FAC_LAM_LIM[1],1.143, %
ENG102306,FAC_TPS_1_SAE,14.5098042, %
ENG102292,FAC_TPS_1_SAE,14.9019610, %
ENG101437,Fan request from air conditioner,34.375000, %
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG128786,FTL_SAE,43.9, %
ENG104248,Fuel consumption signal,26995, µl
ENG247046-ENG186450,Fuel Rate-Engine Fuel Rate,0.34, g/s
ENG247046-ENG247209,Fuel Rate-Vehicle Fuel Rate,0.34, g/s
ENG102108,FUP_H,132471.7, hPa
ENG112563,FUP_H_SAE,13120, kPa
ENG99170,Height correction,988.46, hPa
ENG103575,High-pressure system: regulator,0.00, mg
ENG103879,High-pressure system: regulator: mobile part,-4.92, mg
ENG101567,Idling speed stabilisation: duty cycle/AC compressor torque,10.00, Nm
ENG101946,Idling stabilisation: operating status,false,
ENG245650,IDX_FUEL_SYS_SAE[1],2,
ENG100345,IGA_ADJ_KNK[0],0.000, °
ENG103593,IGA_ADJ_KNK[1],0.000, °
ENG103360,IGA_ADJ_KNK[2],0.000, °
ENG99404,IGA_ADJ_KNK[3],0.000, °
ENG100425,IGA_IGC[0],9.375, °
ENG101655,IGA_IGC[1],7.125, °
ENG100410,IGA_IGC[2],3.375, °
ENG100407,IGA_IGC[3],1.875, °
ENG112564,IGA_IGC_SAE,2.5, °
ENG410437,Injector_adaption_counter,10357,
ENG410438,Injector_mass_deviation_adaption_counter,416,
ENG100634-ENG299122,In-use Performance Tracking: 16 or 20 counters-Counters 3-EOP,|Completion Condition Counts,Conditions Encountered Counts|6,5|0,0|6,5|0,0|15,5|46,3|11,2|4,5|0,0|4,5|0,0|6,5|0,0|, counts
ENG100634-ENG102823,In-use Performance Tracking: 16 or 20 counters-Ignition Cycle Counter,0, counts
ENG100634-ENG99988,In-use Performance Tracking: 16 or 20 counters-OBD Monitoring Conditions Encountered Counts,0, counts
ENG100634-ENG250449,In-use Performance Tracking: 16 or 20 counters-Raw Data,00,
ENG125209,KNKS_ERR_REL[0],0.0195, V
ENG99741,LAMB_DELTA_AD_LAM_ADJ[1],0.00043,
ENG112565,LAMB_DELTA_SUM_LAM_ADJ_AD[1],0.00043,
ENG99674,Lambda controller: bank 1 (averaged value),1.149, %
ENG101381,Lambda probe 1: bank 1: status,00000001 ,
ENG101039,Lambda probe 1: bank 1: status,00000000 ,
ENG102886,Lambda probe 1: bank 1: status,00000000 ,
ENG104200,Lambda probe 2: bank 1: status,00000000 ,
ENG101336,Lambda probe 2: bank 1: status,00000001 ,
ENG101869,Lambda probe ageing: bank 1: probe 1: short trip result,301.73, °C
ENG100478,Lambda probe correction: duty cycle offset: bank 1,-0.00006,
ENG102763,Lambda probes actual: bank1,1.0029,
ENG245657,LF_DPS_CYC_ERR_RAW_BSW[CYL_0],0,
ENG245658,LF_DPS_CYC_ERR_RAW_BSW[CYL_1],0,
ENG245659,LF_DPS_CYC_ERR_RAW_BSW[CYL_2],0,
ENG245660,LF_DPS_CYC_ERR_RAW_BSW[CYL_3],0,
ENG245661,LF_DPS_CYC_ERR_VLD_BSW[CYL_0],2097151,
ENG245662,LF_DPS_CYC_ERR_VLD_BSW[CYL_1],2097151,
ENG245663,LF_DPS_CYC_ERR_VLD_BSW[CYL_2],2097151,
ENG245664,LF_DPS_CYC_ERR_VLD_BSW[CYL_3],2097151,
ENG112570,LF_DPS_INI_ERR_RAW_BSW[1],0,
ENG112571,LF_DPS_INI_ERR_RAW_BSW[2],0,
ENG245665,LF_IV_ERR_RAW_BSW[CYL_0],0,
ENG245666,LF_IV_ERR_RAW_BSW[CYL_1],0,
ENG245667,LF_IV_ERR_RAW_BSW[CYL_2],0,
ENG245668,LF_IV_ERR_RAW_BSW[CYL_3],0,
ENG245669,LF_IV_ERR_VLD_BSW[CYL_0],511,
ENG245670,LF_IV_ERR_VLD_BSW[CYL_1],511,
ENG245671,LF_IV_ERR_VLD_BSW[CYL_2],511,
ENG245672,LF_IV_ERR_VLD_BSW[CYL_3],511,
ENG138674,LF_MVB_BUS_INTC_DIAG,0,
ENG138675,LF_MVB_PDU_INTC_DIAG_1,0,
ENG138676,LF_MVB_PDU_INTC_DIAG_10,0,
ENG168842,LF_MVB_PDU_INTC_DIAG_11,0,
ENG168843,LF_MVB_PDU_INTC_DIAG_12,0,
ENG138677,LF_MVB_PDU_INTC_DIAG_13,0,
ENG138679,LF_MVB_PDU_INTC_DIAG_15,0,
ENG138680,LF_MVB_PDU_INTC_DIAG_16,0,
ENG138681,LF_MVB_PDU_INTC_DIAG_17,0,
ENG138682,LF_MVB_PDU_INTC_DIAG_18,0,
ENG168844,LF_MVB_PDU_INTC_DIAG_19,0,
ENG138683,LF_MVB_PDU_INTC_DIAG_2,0,
ENG168845,LF_MVB_PDU_INTC_DIAG_20,0,
ENG168846,LF_MVB_PDU_INTC_DIAG_22,0,
ENG168847,LF_MVB_PDU_INTC_DIAG_23,0,
ENG168848,LF_MVB_PDU_INTC_DIAG_24,0,
ENG168849,LF_MVB_PDU_INTC_DIAG_25,0,
ENG168850,LF_MVB_PDU_INTC_DIAG_26,0,
ENG168851,LF_MVB_PDU_INTC_DIAG_27,0,
ENG138684,LF_MVB_PDU_INTC_DIAG_3,0,
ENG138685,LF_MVB_PDU_INTC_DIAG_4,0,
ENG138686,LF_MVB_PDU_INTC_DIAG_5,0,
ENG138687,LF_MVB_PDU_INTC_DIAG_6,0,
ENG138689,LF_MVB_PDU_INTC_DIAG_8,0,
ENG138690,LF_MVB_PDU_INTC_DIAG_9,0,
ENG249153,LF_TQ_PT_ACT_REQ,512,
ENG127734,Life_cycle_data_start_requirement_development,|Year,Month,Day,Hours,Minutes,Seconds,,,,,,,,,,,,,,,,,|2026,9,29,11,53,44,not active,Gearbox,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active|2063,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,12,0,0,0,0,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active|,
ENG127735,Life_cycle_data_stop_prohibition_development,|Year,Month,Day,Hours,Minutes,Seconds,,,,,,,,,,,,,,,,,|2026,9,29,12,6,14,not active,not active,not active,not active,A/C system,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active|2000,1,21,7,42,59,not active,not active,Kessy,Immobilizer,not active,not active,12-volt vehicle electrical system,ACC,not active,not active,not active,not active,Level control system,not active,not active,not active,not active|2000,0,0,6,41,58,not active,Gearbox,not active,Immobilizer,A/C system,Brake,not active,ACC,Steering,Parking aid,not active,not active,not active,All-wheel drive electronics,not active,not active,not active|2000,0,0,0,1,42,not active,Gearbox,not active,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,not active,not active,not active,not active,Quattro Sport,Level control system,All-wheel drive electronics,not active,Convertible top control module,Front Axle Lift System|2000,0,0,0,3,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,12,0,0,0,0,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active|,
ENG127733,Life_cycle_data_system_failure,|Year,Month,Day,Hours,Minutes,Seconds,,,,,,,,,,,,,,,,,|2026,8,5,10,27,11,Motor,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active|2000,1,21,0,19,22,not active,Gearbox,Kessy,not active,not active,not active,not active,ACC,Steering,not active,not active,not active,not active,not active,not active,not active,not active|2000,0,0,6,40,3,not active,Gearbox,not active,not active,not active,not active,not active,not active,Steering,not active,Multifunction unit control module,not active,Level control system,not active,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2000,0,0,0,1,41,not active,Gearbox,not active,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,not active,Parking aid,not active,not active,Level control system,not active,Front sensor for driver assistance systems,not active,not active|2064,0,0,0,3,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,15,31,31,63,63,Motor,Gearbox,Kessy,Immobilizer,A/C system,Brake,12-volt vehicle electrical system,ACC,Steering,Parking aid,Multifunction unit control module,Quattro Sport,Level control system,All-wheel drive electronics,Front sensor for driver assistance systems,Convertible top control module,Front Axle Lift System|2127,12,0,0,0,0,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active,not active|,
ENG245673,LOAD_CLC_SAE,23.1, %
ENG100402,LOIL_SUM_SRV_INTL,-0.06, mm
ENG99162,LV_ACC_RED_CMD,false,
ENG112584,LV_BPA_AD_REQ[0],00000000 ,
ENG114829,LV_BPA_LIH_REQ[0],00000000 ,
ENG128787,LV_CMD_RCL_OPEN,00000000 ,
ENG245677,LV_CRU_ENA_BRAKE_INTV,00000001 ,
ENG112471,LV_IGK,00000001 ,
ENG100044,LV_LOIL_L_WARN,00000000 ,
ENG103492,LV_LOIL_L_WARN_ACT,false,
ENG103908,LV_LOIL_L_WARN_TMP,false,
ENG245679,LV_PWR_RLY[ENG_RLY],00000001 ,
ENG102417,LV_TPS_AD_ACT,00000000 ,
ENG100842,LV_TPS_AD_DIAG_ERR,00000000 ,
ENG103996,LV_TPS_AD_REQ,00000000 ,
ENG112588,MAP_MES_SAE,35, kPa
ENG103501,MASS_SA_REL[0],0.984,
ENG100896,MASS_SA_REL_21_PHA,0.000,
ENG103045,MASS_SA_REL_22_PHA,0.000,
ENG126493,MFF_MPL_ADD_LAM_AD[1][1],0.04, mg/stroke
ENG101360,Misfire detection active,00000000 ,
ENG102335,Misfires all cylinders per 1000 rpm,0,
ENG245686,N_SAE,906.3, /min
ENG128796,N_SP_IS_CLC,900, /min
ENG103004,N_TCHA,11578.4, /min
ENG112590,N_TOOTH,901, /min
ENG126111,NL_PRE[0],0.302, V
ENG126112,NL_PRE[1],0.295, V
ENG126113,NL_PRE[2],0.392, V
ENG126114,NL_PRE[3],0.328, V
ENG245687,NR_CYC_AD_DC_BAL_HOM[0],0,
ENG245688,NR_CYC_AD_DC_BAL_HOM[1],0,
ENG245689,NR_CYC_AD_DC_BAL_HOM[2],0,
ENG275707,NR_CYC_DIAG_BAL_HOM_AD_MAX[0],0,
ENG275708,NR_CYC_DIAG_BAL_HOM_AD_MAX[1],0,
ENG275709,NR_CYC_DIAG_BAL_HOM_AD_MAX[2],0,
ENG275710,NR_CYC_DIAG_BAL_HOM_AD_MAX[3],0,
ENG275711,NR_CYC_DIAG_BAL_HOM_AD_MIN[0],0,
ENG275712,NR_CYC_DIAG_BAL_HOM_AD_MIN[1],0,
ENG275713,NR_CYC_DIAG_BAL_HOM_AD_MIN[2],0,
ENG275714,NR_CYC_DIAG_BAL_HOM_AD_MIN[3],0,
ENG119936,O2L_MAX_CAT_GAP_AFL_MV[1],0.00000, g
ENG119937,O2L_MAX_CAT_GAP_AFR_MV[1],0.00000, g
ENG99157,PRS_SA_DIF,0.00, hPa
ENG128797,PV,0.00, %
ENG102195,PV_AV_1,0.00, %
ENG99137,PV_AV_2,0.00, %
ENG101068,PV_AV_H,0.00, %
ENG112593,PWM_ACT_VCP[EX_1],100.000, %
ENG112594,PWM_ACT_VCP[IN_1],100.000, %
ENG112597,PWM_PAS_VCP[EX_1],0.000, %
ENG112598,PWM_PAS_VCP[IN_1],0.000, %
ENG101201,Radiator fan 1: run-on: status,600W,
ENG102359,Radiator fan 2: run-on: status,600W,
ENG119939,RATIO_O2L_LIM_CAT_GAP_AFL_MV[1],5.1995225,
ENG119940,RATIO_O2L_LIM_CAT_GAP_AFR_MV[1],0.0000000,
ENG252416,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data,|Idle Stop-Start Timer (Recent),Idle Stop-Start Timer (Lifetime),Engine Running Coasting Timer (Recent),Engine Running Coasting Timer (Lifetime),Engine Off Coasting Timer (Recent),Engine Off Coasting Timer (Lifetime)|94,168,4294967295,4294967295,4294967295,4294967295|, s
ENG103248,SEG_AD_MMV_ER[0],0.0000, ‰
ENG101135,SEG_AD_MMV_ER[1],0.5901, ‰
ENG99078,SEG_AD_MMV_ER[2],0.1178, ‰
ENG103257,SEG_AD_MMV_ER[3],0.7358, ‰
ENG100919,Starter control: interlock switch,false,
ENG245709,STATE_CRU_DCC_REQ_CUS,2,
ENG114834,STATE_CRU_OFF_IRR_CUS,0,
ENG114835,STATE_CRU_OFF_REV_CUS,16924736,
ENG245710,STATE_CRU_PT_CUS,16388,
ENG245711,STATE_FRF_BYTE_IMMO_APP_1,0,
ENG245712,STATE_FRF_BYTE_IMMO_APP_2,0,
ENG245713,STATE_FRF_BYTE_IMMO_APP_3,0,
ENG245714,STATE_FRF_BYTE_IMMO_APP_4,0,
ENG245715,STATE_FRF_BYTE_IMMO_APP_5,0,
ENG245716,STATE_FRF_BYTE_IMMO_APP_6,0,
ENG245717,STATE_FRF_BYTE_IMMO_DEAC_1,0,
ENG245718,STATE_FRF_BYTE_IMMO_DEAC_2,0,
ENG245719,STATE_FRF_BYTE_IMMO_DEAC_3,0,
ENG245720,STATE_FRF_BYTE_IMMO_DEAC_4,0,
ENG245721,STATE_FRF_BYTE_IMMO_DEAC_5,0,
ENG245722,STATE_FRF_BYTE_IMMO_DEAC_6,0,
ENG245723,STATE_FRF_BYTE_IMMO_RST_SAFE_1,0,
ENG245724,STATE_FRF_BYTE_IMMO_RST_SAFE_2,0,
ENG245725,STATE_FRF_BYTE_IMMO_RST_SAFE_3,0,
ENG245726,STATE_FRF_BYTE_IMMO_RST_SAFE_4,0,
ENG245727,STATE_FRF_BYTE_IMMO_RST_SAFE_5,0,
ENG245728,STATE_FRF_BYTE_IMMO_RST_SAFE_6,0,
ENG112606,STATE_PWM_VCP[EX_1],pas,
ENG112607,STATE_PWM_VCP[IN_1],HLD,
ENG158210,STATE_T_ES_VLD_ATIC,1,
ENG245731,STATE_T_ES_VLD_ENVD,135444,
ENG112608,STATE_VCP,passive,
ENG114836,STATE_VCV_CLOSE_SL,OFF,
ENG112609,T_ACT_MIL_SAE,0, min
ENG112494,T_AST_SAE,291, s
ENG104148,T_COOL_LOIL,704.9, ms
ENG112613,T_DTC_CLR_SAE,550, min
ENG251838,T_ECU_OFF_ENVD,4, s
ENG109299,T_ES,1413, min
ENG158245,T_ES_ATIC,85137, s
ENG158250,T_ES_ATIC_OLD_ENVD,0, s
ENG245741,T_ES_ATIC_PLAUS_DEV,0, s
ENG251839,T_ES_ATIC_PLAUS_TMR_CHK,60.0, s
ENG112616,T_ES_DC,1413, min
ENG99463,T_ES_H,65535, s
ENG128802,T_IGK,295.60, s
ENG99398,T_POP_COC_INTER_1,0.0, s
ENG102747,T_PWL,0.0, s
ENG245742,T_PWL_END,0.0, s
ENG101325,T_TEMP_SIG_LOIL,48.3, ms
ENG125440,TAA,33.000, °C
ENG102048,Tank breather valve: duty cycle,73.0, %
ENG101339,Tank breather valve: short trip result,1.4644, kg/h
ENG100439,Tank level,00000000 ,
ENG112610,TCO_1_FIRST_ST,22, °C
ENG112611,TCO_1_ST,22, °C
ENG112612,TCO_1_SYS,72, °C
ENG128800,TCO_MDL[STUCK_L_COOL_MON],37.000, °C
ENG124460,TCO_MDL[TH],40.820, °C
ENG102279,TCS/ESP: specified torque,28.8125, Nm
ENG99857,TCS: status,false,
ENG110436,TEG_DYN_LS_DOWN[1],394.29, °C
ENG101941,TEMP_CAT_STAT_MDL[1],460.23, °C
ENG112614,TEMP_CAT_UP_1_SAE,382.2, °C
ENG114837,TFPA,45, °C
ENG114838,TFU_HPP,32.3, °C
ENG101411,Throttle valve angle,5.048, °
ENG390554,TI_MES_CHK[CYL_0][PLS_1],1032.7, µs
ENG390555,TI_MES_CHK[CYL_0][PLS_2],0.0, µs
ENG390556,TI_MES_CHK[CYL_0][PLS_3],0.0, µs
ENG390557,TI_MES_CHK[CYL_0][PLS_4],0.0, µs
ENG390558,TI_MES_CHK[CYL_0][PLS_5],0.0, µs
ENG390559,TI_MES_CHK[CYL_0][PLS_6],0.0, µs
ENG390560,TI_MES_CHK[CYL_0][PLS_7],0.0, µs
ENG390561,TI_MES_CHK[CYL_0][PLS_8],0.0, µs
ENG390562,TI_MES_CHK[CYL_1][PLS_1],1036.1, µs
ENG390563,TI_MES_CHK[CYL_1][PLS_2],0.0, µs
ENG390564,TI_MES_CHK[CYL_1][PLS_3],0.0, µs
ENG390565,TI_MES_CHK[CYL_1][PLS_4],0.0, µs
ENG390566,TI_MES_CHK[CYL_1][PLS_5],0.0, µs
ENG390567,TI_MES_CHK[CYL_1][PLS_6],0.0, µs
ENG390568,TI_MES_CHK[CYL_1][PLS_7],0.0, µs
ENG390569,TI_MES_CHK[CYL_1][PLS_8],0.0, µs
ENG390570,TI_MES_CHK[CYL_2][PLS_1],986.9, µs
ENG390571,TI_MES_CHK[CYL_2][PLS_2],0.0, µs
ENG390572,TI_MES_CHK[CYL_2][PLS_3],0.0, µs
ENG390573,TI_MES_CHK[CYL_2][PLS_4],0.0, µs
ENG390574,TI_MES_CHK[CYL_2][PLS_5],0.0, µs
ENG390575,TI_MES_CHK[CYL_2][PLS_6],0.0, µs
ENG390576,TI_MES_CHK[CYL_2][PLS_7],0.0, µs
ENG390577,TI_MES_CHK[CYL_2][PLS_8],0.0, µs
ENG390578,TI_MES_CHK[CYL_3][PLS_1],999.3, µs
ENG390579,TI_MES_CHK[CYL_3][PLS_2],0.0, µs
ENG390580,TI_MES_CHK[CYL_3][PLS_3],0.0, µs
ENG390581,TI_MES_CHK[CYL_3][PLS_4],0.0, µs
ENG390582,TI_MES_CHK[CYL_3][PLS_5],0.0, µs
ENG390583,TI_MES_CHK[CYL_3][PLS_6],0.0, µs
ENG390584,TI_MES_CHK[CYL_3][PLS_7],0.0, µs
ENG390585,TI_MES_CHK[CYL_3][PLS_8],0.0, µs
ENG128801,TIA_CHA_DOWN_MV,32.561, °C
ENG125276,TIG_MES_SAE[IM],31, °C
ENG103351,Time since engine start,299.1, s
ENG112634,TLTS_MES[TCE],73.789, °C
ENG245765,TLTS_MES_SAE[TCE],73, °C
ENG112635,TMAG_VCP,26, °C
ENG110444,TPS_AD_CDN_MIS,0,
ENG128804,TQI_ADD_ACT,51.50000, Nm
ENG101426,TQI_GS_FAST_INC,0.00, Nm
ENG128805,TQI_N_TCHA_MAX,1023.96875, Nm
ENG247047-ENG247196,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG247047-ENG247180,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG247047-ENG247177,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG247047-ENG247188,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG102329,TTIP_MES_LS_UP[1],720.0000, °C
ENG245767,V_LS_SENS[1],0.7330, V
ENG114840,V_PVS_KD,0.000, V
ENG245768,VB_SAE,14.570, V
ENG99514,VBOOST,65.5, V
ENG103201,VCV_CLOSE_RNG,20.6, °
ENG247048,Vehicle Odometer,496.7, km
ENG252424,Vehicle Operation Data - Distance/Fuel Used,|Total Distance Traveled (Recent),Total Distance Traveled (Lifetime),Total Fuel Consumed (Recent),Total Fuel Consumed (Lifetime)|478.6,496.7,49.67,55.80|, l
ENG252425,Vehicle Operation Data - Engine Run/Idle Time,|Ignition Counter (Recent),Ignition Counter (Lifetime),Fueled Engine Operation Ignition Cycle Counter (Recent),Fueled Engine Operation Ignition Cycle Counter (Lifetime),Total Engine Run Time (Recent),Total Engine Run Time (Lifetime),Total Idle Engine Run Time (Recent),Total Idle Engine Run Time (Lifetime)|56,119,56,119,32950,41150,12745,17190|, s
ENG252426,Vehicle Operation Data - PKE/EOE,|Positive Kinetic Energy (Recent),Positive Kinetic Energy (Lifetime),Engine Output Energy (Recent),Engine Output Energy (Lifetime)|3254,3525,138.3,151.8|, kWh
ENG252427,Vehicle Operation Data - PSA,|Total Propulsion System Active Time (Recent),Total Propulsion System Active Time (Lifetime),Total Idle Propulsion System Active Time (Recent),Total Idle Propulsion System Active Time (Lifetime),Total City Propulsion System Active Time (Recent),Total City Propulsion System Active Time (Lifetime)|33050,41334,12845,17379,5686,9302|, s
ENG112639,VLS_DOWN_SAE[1],0.730, V
ENG128806,VOL_FLOW_CHA_UP_RED_MV,0.004211, m³/s
ENG102985,VP_TPS_2,4.2334, V
ENG101674,VP_TPS_AD_LIH_1,0.9485, V
ENG99507,VP_TPS_AD_LIH_2,4.0491, V
ENG245772,VS_MAX_THD,204.87, km/h
ENG245773,VS_SAE,0, km/h
Elapsed Time: 01:25
blockmap-01-06U-906-070-BH_3VVUW7RM1TM130726-20260930-1212.CSV
hot engine
;SW:06U-906-070-BH HW:06U-907-425-A --- 01: Engine
;Component:R4 2.0l TFS H80 5627, Coding:012A007245661108F0800000000000000000000000000000
;EV_ECM20TFS02006U906070BH,002005,EV_ECM20TFS02006U906070BH.rod
;Wednesday,30,September,2026,12:12:54:11564
;VCDS Version: 26.10.0.2 (x64) Data version: 20260921 DS379.0
;VCID: 7BABA8810367B212BE3-802E-R SFD+SFD2 {x}
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),||3VVUW7RM1TM130726|,
IDE00018,Voltage terminal 15,14.199, V
IDE00019,Voltage terminal 30,14.414, V
IDE00021,Engine speed,901, /min
IDE00025,Coolant temperature,91, °C
IDE00078,Time since engine start,1200, s
IDE00083,Throttle valve position (absolute),14.5, %
IDE00084,Absolute load value,23, %
IDE00085,Normed load value,17.6, %
IDE00086,Accelerator pedal position,14.5, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00102,Control Module temperature,53.0, °C
IDE00148,Mean injection time,0.0, ms
IDE00149,Ignition angle of current cylinder: actual value,6.88, °
IDE00150,Pressure in brake servo unit,0.000, bar
IDE00151,Oil fill level,41, mm
IDE00167,Exhaust temperature 1 bank 1,408.7, °C
IDE00172,A/C compressor torque,-7.91, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,5.0, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,5.1, °
IDE00178,Camshaft adjustment intake bank 1: specified value,3.0, °
IDE00179,Camshaft adjustment intake bank 1: actual value,3.1, °
IDE00182,Camshaft adaptation intake bank 1: phase position,-2.6, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-3.3, °
IDE00187,Coolant temperature at engine start,21.7, °C
IDE00188,Fuel high-pressure: actual value,131.5, bar
IDE00189,Activation of fuel pump electronics,58.62, %
IDE00190,Charge air pressure: specified value,0.349, bar
IDE00191,Charge air pressure: actual value,0.986, bar
IDE00192,Coolant temperature at radiator outlet: actual value,39.3, °C
IDE00193,Coolant temperature at engine outlet: specified value,91.5, °C
IDE00194,Coolant temperature at radiator output: specified value,-48.0, °C
IDE00195,Coolant temperature difference between engine and radiator,51.7, °C
IDE00196,Engine oil temperature,87.9, °C
IDE00199,Mean engine air mass,14, kg/h
IDE00200,Average vehicle speed,0.00, km/h
IDE00201,Fuel high-pressure: specified value,130.6, bar
IDE00202,Low fuel pressure: specified value,6.250, bar
IDE00252,Vacuum pump for brakes,Pump off,
IDE00304,Fuel level,25, l
IDE00348,Intake air temperature,44, °C
IDE00349,Throttle valve position: normed,4.3, %
IDE00355,Cruise Control System (CCS): status,passive,
IDE00357,Fuel temperature,59.2, °C
IDE00358,Limitation: torque,187.2, Nm
IDE00371,Fuel consumption,1.40, l/h
IDE00375,Generator: load signal,38.73, %
IDE00380,Coolant fan 1: activation,38.28, %
IDE00381,Coolant fan 2: activation,38.28, %
IDE00392,Accelerator pedal: sensor voltage 1,0.720, V
IDE00393,Accelerator pedal: sensor voltage 2,0.360, V
IDE00400,Intake manifold Runner Control (IMRC): activation,0.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,0.00, %
IDE00404,Throttle valve: activation,7.41, %
IDE00405,Crankshaft speed (RPM),894, /min
IDE00406,Camshaft RPM,881, /min
IDE00407,Rail pressure regulation: status,Regulated operation via quantity control valve,
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,00,
IDE00414,Starter control: relay 1,00,
IDE00415,Starter control: relay 2,00,
IDE00416,Starter control: terminal 50 feedback,01,
IDE00417,Starter control: shut-off conditions 1,00 01,
IDE00434,Particle filter: soot mass calculated,0.02, g
IDE00436,Particle filter: kilometers since last regeneration,496.4,
IDE00451,Currently running routine,Unknown (0)
IDE00472,Mean injection quantity,10, mg/stroke
IDE00474,Ambient air pressure,98, kPa abs
IDE00476,Fuel Metering Valve,0.00, %
IDE00477,Torque request: sum of auxiliary aggregate,21.4, Nm
IDE00478,Engine-drag torque,11.8, Nm
IDE00482,Limitation: torque of clutch protection,1024.0, Nm
IDE00495,Calculated oil temperature,88.0, °C
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,Open,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,closed,
IDE00556,Outside temperature,36, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.999 Lambda / -0.012 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.620, V
IDE00582,Specified value of equivalence ratio,0.999, Lambda
IDE00583,Throttle valve specified value,4.3, %
IDE00584,Distance driven since erasing DTC memory,477, km
IDE00587,Vapor pressure in tank ventilation system,-31909, Pa
IDE00588,Fuel tank fill level,43.1, %
IDE00592,Status of oxygen sensor control,Closed loop, / using O2 sensors
IDE00593,Ignition timing adjustment cylinder 1,4.5, Degrees
IDE00594,Absolute intake pressure,33, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,-0.8, %
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00603,Number of driving cycles since erasing DTC memory,5,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,76.9, %
IDE00949-ENG98517,Hide cylinder-Cylinder 1,not active,
IDE00949-ENG98491,Hide cylinder-Cylinder 10,not active,
IDE00949-ENG98492,Hide cylinder-Cylinder 11,not active,
IDE00949-ENG98493,Hide cylinder-Cylinder 12,not active,
IDE00949-ENG98518,Hide cylinder-Cylinder 13,not active,
IDE00949-ENG98519,Hide cylinder-Cylinder 14,not active,
IDE00949-ENG98520,Hide cylinder-Cylinder 15,not active,
IDE00949-ENG98494,Hide cylinder-Cylinder 16,not active,
IDE00949-ENG98521,Hide cylinder-Cylinder 2,not active,
IDE00949-ENG98522,Hide cylinder-Cylinder 3,not active,
IDE00949-ENG98523,Hide cylinder-Cylinder 4,not active,
IDE00949-ENG98495,Hide cylinder-Cylinder 5,not active,
IDE00949-ENG98524,Hide cylinder-Cylinder 6,not active,
IDE00949-ENG98496,Hide cylinder-Cylinder 7,not active,
IDE00949-ENG98497,Hide cylinder-Cylinder 8,not active,
IDE00949-ENG98498,Hide cylinder-Cylinder 9,not active,
IDE01098,Test of knock sensors: short trip result,Test not started,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.000,
IDE01377,Throttle valve adapter: actual value,5.3, °
IDE01378,Fuel high pressure: control deviation,0.4, bar
IDE01385,Wear index,0.00000030,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test not started,
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.623, V
IDE01649,Throttle valve position 1,0.710, V
IDE01650,Throttle valve position 2,14, %
IDE01652,Opening degree Evap. Emission (EVAP) Canister Purge Reg. Valve,77, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test not started,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test not started,
IDE01670,Short trip status for oil pressure control,Test not started,
IDE01671,Starter control: clutch switch,pressed,
IDE01672,Starter control: automatic start,possible,
IDE01673-MAS05513,Starter control: readiness bits-Bit 0,Mechanical test of starter complete,
IDE01673-MAS05514,Starter control: readiness bits-Bit 1,Test of starter relay switching contacts not complete,
IDE01673-MAS05515,Starter control: readiness bits-Bit 2,Test of starter relay activation complete,
IDE01673-MAS05516,Starter control: readiness bits-Bit 3,Test of terminal 50R return measuring line completed,
IDE01673-MAS05517,Starter control: readiness bits-Bit 4,Test of starter request double injection complete,
IDE01673-MAS05518,Starter control: readiness bits-Bit 5,Test of PN signal complete,
IDE01673-MAS05519,Starter control: readiness bits-Bit 6,Test of interlock switch complete,
IDE01673-MAS05520,Starter control: readiness bits-Bit 7,Test of clutch pedal switch complete,
IDE01677,Result: oxygen sensor test operational readiness B1 downstream CAT,Test not started,
IDE01685,Result of test of valve stroke switch AVS,Test not started,
IDE01773,Misfire totalizer,0,
IDE01774,Status misfire recognition,active,
IDE01870,Oxygen sensor after catalytic converter: operating status,Bank 1: sensor 1 OK,
IDE01873,Test of catalytic converter: measured value,0.000,
IDE01874,Test of catalytic converter: result,Test not started,
IDE01876,Adaptation of loss torque,3.4, Nm
IDE01878,Adaptation of throttle valve,Test of closing springs ended,
IDE01880,Accelerator pedal position 2,14.5, %
IDE01881,Adaptation of kick-down shifting point,4.102, V
IDE01884,Camshaft adjustment intake bank 1: activation,0.00, %
IDE01886,Number of high pressure incursions,0,
IDE01894,Charge press. ctrl.: adapt. higher than max. threshold,0.00, %
IDE01895,Charge pressure control: less than min. threshold adaptation,0.00, %
IDE01901,Lost torque adaptation: idle,2.2, Nm
IDE01905,Average of ignition timing angle delay adjustment,20.56, °
IDE01906,Dynamic average of ignition timing angle delay adjustment,4.63, °
IDE01913,Number of oxygen sensor dynamic tests: bank 1 sensor 1,0,
IDE01922,Vehicle distance driven,496, km
IDE01923,Control module distance driven,497, km
IDE01924,Load shift flaps: actual value,Open,
IDE01925,Load shift flaps: specified value,Open,
IDE01926,Adaptation of intake manifold runner flaps,is running,
IDE01928,Close cam shaft angle at quantity control valve,33.9, °
IDE01929,Open cam shaft angle at quantity control valve,3.1, °
IDE01931,High pressure pump injection volume control deviation,-1, mg/stroke
IDE01932,High pressure pump injection volume,0, mg/stroke
IDE01975,Numb.of misfir.: cylinder 1,23,
IDE01976,Numb.of misfir.: cylinder 2,30,
IDE01977,Numb.of misfir.: cylinder 3,23,
IDE01978,Numb.of misfir.: cylinder 4,58,
IDE02116,Exhaust gas temperature before catalytic converter,330.9, °C
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02229,Exhaust gas temperature sensor 1,418.2, °C
IDE02756,Number of manual engine starts,117,
IDE02757,Number of automatic engine starts,10,
IDE02832,Coolant circulation pump: activation,61.59, %
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,5,
IDE03010-MAS01627,Number of prevented stop processes-Steering,26,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,32,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,1,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,33,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,10,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,2,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,8,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test not started,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,-179.96, °
IDE03246,Neutral position sensor: upper adaptation value,0.000, V
IDE03247,Neutral position sensor: lower adaptation value,0.000, V
IDE03262,Adapt of angle sensor 1 f throttle valve,0.496, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.501, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.948, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.049, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,0.000, V
IDE03328,Transmission neutral position sensor voltage,0.000, V
IDE03361,Driver intention torque,34.6, Nm
IDE03377,Coolant temp at radiator output: unconditioned voltage,2.731, V
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03587-IDE02697,Stopping prohibitions for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping prohibitions for active participants-A/C system,active,
IDE03587-MAS00127,Stopping prohibitions for active participants-Brake,not active,
IDE03587-MAS00506,Stopping prohibitions for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping prohibitions for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping prohibitions for active participants-Gearbox,not active,
IDE03587-MAS01106,Stopping prohibitions for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping prohibitions for active participants-Energy management,not active,
IDE03587-MAS01627,Stopping prohibitions for active participants-Steering,not active,
IDE03587-MAS02237,Stopping prohibitions for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping prohibitions for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping prohibitions for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping prohibitions for active participants-Motor,not active,
IDE03587-MAS06709,Stopping prohibitions for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping prohibitions for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping prohibitions for active participants-Front sensor for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C system,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-Brake,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Gearbox,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication errors,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03711,Mass flow through throttle valve,12, kg/h
IDE03767,Engine status,Idle,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,45.32, %
IDE03806,Oxygen sensor bank 1 sensor 1: status,1,
IDE03807,Oxygen sensor bank 1 sensor 2: status,1,
IDE03816,Exhaust flap bank 1,Open,
IDE03818,Heated oxygen sensor bank 1: sensor 2: resistance,310, Ohm
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,27.34, %
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,162, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,12.89, %
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,Test not started,
IDE03892,Fuel high pressure sensor: unconditioned voltage,0.000, V
IDE03920,Oxygen adaptation status,Condition not met,
IDE03921,Mixture adaptation factor at partial load,-0.05, %
IDE03922,Mixture adaptation factor at idle speed,0.00, %
IDE03923,Adaptive long-term value of mix. condition after cat. conv,0.00000,
IDE03924,Relay for reserve coolant pump: status,not activated,
IDE03928,Counter for fuel entry in oil,0,
IDE03930,Charge pressure actuator: operating status,Operating mode,
IDE03949,Air mass: actual value (mg/stroke),134.66, mg/stroke
IDE03953,Oxygen control: adaptation value at partial load: bank 1,-0.06, %
IDE03957,Throttle valve angle: specified value,4.9, °
IDE03963,Low fuel pressure adaptation value for EFP,1200, mbar
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE04002,Charge air pressure control,BP_A act:98.4, kPa
IDE04010,Engine torque: normalized,10.0, %
IDE04011,Nominal torque,370, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:12980/--- kPa,
IDE04083,Coolant temperatures,ECT 1:91 °C / ECT 2:39 °C,
IDE04086,Turbocharger guide vane adjustment,VGT_A cmd/act:0.0/0.0 % / VGT_B cmd/act:---/--- %,
IDE04088,Turbocharger 1: temperature,Compr. in/out---/53 °C / Turbine in/out---/--- °C,
IDE04092,Particulate filter bank 1,-327.64/0.00/0.00, kPa
IDE04094,Particle filter: temperature,B1:390/--- °C / B2:---/--- °C,
IDE04110,Additional inputs and outputs,GEAR_RCMD: N,
IDE04322,Short term adaptation of oxygen sensor control bank 1,0.0, %
IDE04405,Mixture variation in adapted part load range 1,0.00, %
IDE04409,Intake manifold pressure: corrected,0.335, bar
IDE04410,Intake manifold pressure: specified value,0.334, bar
IDE04412,Pressure upstream of throttle valve: corrected,0.986, bar
IDE04420,Secondary air system activation,Atmosphere/off,
IDE04615,Segment adaptation for rough running: status,completed successfully,
IDE04634,AVS switch-over meter for reg activation of curr. drive cycle,0,
IDE04638,Transmission coolant valve,closed,
IDE04677,Oxygen sensor 1 bank 1: lambda actual value,0,
IDE04680,Oxygen sensor 1 bank 1: voltage raw value O2 signal,2.007, V
IDE04713,Active brake system status,Not operated,
IDE04885,Hybrid batt charge cond act val standardized,0.00, %
IDE04913,Current speed of electric motor,0.0, /min
IDE04937,Sensor for engine block temperature: raw value,91.0, °C
IDE05140,Intake manifold pressure raw value,0.342, bar
IDE05259,Gear position sensor: raw value,0.00, %
IDE05260,Gear position sensor: current value,Neutral,
IDE05310,Charge air pressure control valve position: target value,100.00, %
IDE05311,Charge air pressure control valve position: actual value,100.12, %
IDE05312,Charge air pressure control valve uncond voltage sensor,2.8819, V
IDE05313,Charge air pressure control valve activation pulse duty factor,-1.59, %
IDE05315,Charge air pressure control valve voltage: position closed,0.0000, V
IDE05316,Charge air pressure control valve voltage: position open,0.0000, V
IDE05317,Charge air pressure control valve adaptation performed,00000000 ,
IDE05508,Adaptation val cyl 1 with slow diagnosis,0.000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,0.000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,2.304,
IDE05511,Adaptation val cyl 2 with slow diagnosis,0.000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,0.000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,0.000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,0.000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,0.000,
IDE05593,Secondary air injection sensor 1,0.985, bar
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,Power fail: content of RAM cell no longer valid,
IDE06006,Idle speed specified value,900, /min
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06175,Intake air temperature before throttle valve: actual value,52.75, °C
IDE06192,Knock sensor: cylinder 2: voltage,0.443, V
IDE06193,Knock sensor: cylinder 3: voltage,0.490, V
IDE06194,Knock sensor: cylinder 4: voltage,0.566, V
IDE06195,Knock sensor: cylinder 1: voltage,0.521, V
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06386,Oil level: static measurement,0, mm
IDE06387,Oil level: last valid dynamic value,0, mm
IDE06388,Oil level: condition for static measurement fulfilled,Condition not met,
IDE06389,Oil level: maximum value,0, mm
IDE06390,Oil level: minimum value,0, mm
IDE06391,Oil temperature sensor 2,79.0, °C
IDE06392,Oil temperature sensor 2: raw value,65.535, V
IDE06393,Oil level: dynamic average value,0, mm
IDE06394,Sensor 1 for secondary air pressure: unconditioned voltage,2.441, V
IDE06396,Coolant temperature at engine outlet: unconditioned voltage,0.974, V
IDE06397,Temperature sensor for engine temp. management: target value,90.0, °C
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,0.975, V
IDE06405,Engine oil temperature_SAE,79, °C
IDE06432,Oxygen sensor 1 bank 1 signal status,active,
IDE06444,Oxygen sensor before cat bank 1 (LSB) voltage,1.968, V
IDE06567,Frequency counter deactivate start/stop function,10,
IDE06568,Stop prevention by driver frequency counter,109,
IDE06569,Frequency counter vehicle standstill,290,
IDE06573,Long-term adaptation of intake manifold injection,0.00, %
IDE06574,Long-term adaptation of intake manifold injection in idle,0.00, mg/stroke
IDE06610,Frequency counter vehicle standstill with stop,10,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system malfunction,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,No,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,No,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,Yes,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC with Stop & Go,
IDE06707,CCS Switch,ACC operating unit,
IDE06709,ACC variants (coding),ACC with braking until at standstill/Stop & Go,
IDE06710,Cruise control system: permanent deactivation,No switch-off occurs,
IDE06726,Timing deviation after chain replacement: intake bank 1,0.00, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,-3.88, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06738,Chain elongation: no. of valid initial values: intake bank 1,0,
IDE06740,Chain elongation: no. of valid initial values: exhaust bank 1,1,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,not active,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,Available,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Passive Regeneration,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Not available,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Not available,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Adsorption,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,not active,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,Not available,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,Available,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,0.0, %
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,Not available,
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,0, min
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,Available,
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,0, km
IDE07001,Piston-cooling jets: activation,On,
IDE07017,Catalytic converter damaging misfires direct injection,0,
IDE07019,Number of ignitions direct injection,1763898,
IDE07020,Number of ignitions intake manifold injection,0,
IDE07023,Misfires per 1000 revolutions of cyl. 1 intake manif. injection,0,
IDE07024,Misfires per 1000 revolutions of cyl. 2 intake manif. injection,0,
IDE07025,Misfires per 1000 revolutions of cyl. 3 intake manif. injection,0,
IDE07026,Misfires per 1000 revolutions of cyl. 4 intake manif. injection,0,
IDE07027,Heat quantity that was transported via the catalytic converter,0, J
IDE07031,Oil pressure switch for piston-cooling jets: status,Open,
IDE07077-ENG391566,AVS valve stroke position: exhaust-AVS_actual_position_1,not installed,
IDE07077-ENG391170,AVS valve stroke position: exhaust-AVS_actual_position_2,not installed,
IDE07077-ENG391445,AVS valve stroke position: exhaust-AVS_actual_position_3,not installed,
IDE07077-ENG391386,AVS valve stroke position: exhaust-AVS_actual_position_4,not installed,
IDE07077-ENG391253,AVS valve stroke position: exhaust-AVS_actual_position_5,AVS Stroke,
IDE07077-ENG391620,AVS valve stroke position: exhaust-AVS_actual_position_6,AVS Stroke,
IDE07077-ENG391480,AVS valve stroke position: exhaust-AVS_actual_position_7,AVS Stroke,
IDE07077-ENG391539,AVS valve stroke position: exhaust-AVS_actual_position_8,AVS Stroke,
IDE07079,AVS result of last switch-over: exhaust,Malfunction,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07254,Gasoline pressure tank refueling request button,not coded / not installed,
IDE07548,Engine temp. mangmt. actuator: specified value of angle,68.91, °
IDE07549,Engine temp. mangmt. actuator: actual value of angle,68.73, °
IDE07550,Engine temp. management actuator: raw value,1198,
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07552,Engine temper.managem.actuator adaptation: result adaptation,Adaptation successfully finished,
IDE07553,Engine temperature management actuator: after-run stop,3965,
IDE07554,Engine temperature management actuator: stop open,129,
IDE07564,Required torque adjustment by idling regulator,0.1, Nm
IDE07571,Engine torque,22.9, Nm
IDE07574,Long-term fuel trim bank 1 at idle,-0.02, mg/stroke
IDE07575,Driver intention torque,22.1, Nm
IDE07576,Lost torque adaptation driving mode,3.4, Nm
IDE07577,Lost torque adaptation A/C compressor and driving mode,-2.0, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,operated,
IDE07598-MAS00325,Cruise control switch actuation-Set,Not operated,
IDE07598-MAS00326,Cruise control switch actuation-Resume,Not operated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,Not operated,
IDE07598-MAS02310,Cruise control switch actuation-DELAY,Not operated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,Not operated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,operated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,Not operated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,operated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,Not operated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07608,Standard test of current section,0,
IDE07669,Oxygen sensor 2 bank 1 after catalytic converter operational readiness status,active,
IDE07784,Turbine actuator 1 bank 1: position feedback specified value,100.00, %
IDE07785,Turbine actuator 1 bank 1: position feedback actual value,100.18, %
IDE07787,Turbine actuator 1 bank 1: position feedback mechanical stops,72,
IDE07788,Turbine actuator 1 bank 1: position feedback breakaway attempts,0,
IDE07789,Turbine actuator 1 bank 1: activation,-1.86, %
IDE07901,Error counter bad fuel,0,
IDE07904-ENG118117,Brake test switch status-actuated__activated,Not operated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,Not operated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,Not operated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07963,Cam piece counter position malfunction,0,
IDE08071,Remote start cancellation reason store 1,16385,
IDE08072,Remote start cancellation reason store 2,0,
IDE08073,Remote start cancellation reason store 3,0,
IDE08074,Remote start cancellation reason store 4,0,
IDE08075,Remote start cancellation reason store 5,0,
IDE08805,EVAP valve diag. activation condition at minimal load,0.000, counts
IDE08806,EVAP valve diag. activation condition at maximum load,-2717, mbar
IDE09907,Fuel quality,Fuel according to DIN EN 228 detected,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-2.95, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,-3.28, °
IDE10063-MAS00666,Engine oil level: current value-Warning,no warning,
IDE10063-MAS00900,Engine oil level: current value-Oil level,0.00, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,0, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,0, km
IDE10063-MAS09804,Engine oil level: current value-Test method 1,OFF,
IDE10063-MAS09805,Engine oil level: current value-Test method 2,OFF,
IDE10063-MAS09806,Engine oil level: current value-Test method 3,OFF,
IDE10063-MAS09807,Engine oil level: current value-Qualification,0,
IDE10064-MAS00666,Engine oil level: history 1-Warning,no warning,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,0.00, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,0, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,0, km
IDE10064-MAS09804,Engine oil level: history 1-Test method 1,OFF,
IDE10064-MAS09805,Engine oil level: history 1-Test method 2,OFF,
IDE10064-MAS09806,Engine oil level: history 1-Test method 3,OFF,
IDE10064-MAS09807,Engine oil level: history 1-Qualification,0,
IDE10065-MAS00666,Engine oil level: history 2-Warning,no warning,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,0.00, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,0, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,0, km
IDE10065-MAS09804,Engine oil level: history 2-Test method 1,OFF,
IDE10065-MAS09805,Engine oil level: history 2-Test method 2,OFF,
IDE10065-MAS09806,Engine oil level: history 2-Test method 3,OFF,
IDE10065-MAS09807,Engine oil level: history 2-Qualification,0,
IDE10066-MAS00666,Engine oil level: history 3-Warning,no warning,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,0.00, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,0, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,0, km
IDE10066-MAS09804,Engine oil level: history 3-Test method 1,OFF,
IDE10066-MAS09805,Engine oil level: history 3-Test method 2,OFF,
IDE10066-MAS09806,Engine oil level: history 3-Test method 3,OFF,
IDE10066-MAS09807,Engine oil level: history 3-Qualification,0,
IDE10067-MAS00666,Engine oil level: history 4-Warning,no warning,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,0.00, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,0, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,0, km
IDE10067-MAS09804,Engine oil level: history 4-Test method 1,OFF,
IDE10067-MAS09805,Engine oil level: history 4-Test method 2,OFF,
IDE10067-MAS09806,Engine oil level: history 4-Test method 3,OFF,
IDE10067-MAS09807,Engine oil level: history 4-Qualification,0,
IDE10068-MAS00666,Engine oil level: history 5-Warning,no warning,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,0.00, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,0, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,0, km
IDE10068-MAS09804,Engine oil level: history 5-Test method 1,OFF,
IDE10068-MAS09805,Engine oil level: history 5-Test method 2,OFF,
IDE10068-MAS09806,Engine oil level: history 5-Test method 3,OFF,
IDE10068-MAS09807,Engine oil level: history 5-Qualification,0,
IDE10069-MAS00666,Engine oil level: history 6-Warning,no warning,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,0.00, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,0, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,0, km
IDE10069-MAS09804,Engine oil level: history 6-Test method 1,OFF,
IDE10069-MAS09805,Engine oil level: history 6-Test method 2,OFF,
IDE10069-MAS09806,Engine oil level: history 6-Test method 3,OFF,
IDE10069-MAS09807,Engine oil level: history 6-Qualification,0,
IDE10070-MAS00666,Engine oil level: history 7-Warning,no warning,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,0.00, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,0, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,0, km
IDE10070-MAS09804,Engine oil level: history 7-Test method 1,OFF,
IDE10070-MAS09805,Engine oil level: history 7-Test method 2,OFF,
IDE10070-MAS09806,Engine oil level: history 7-Test method 3,OFF,
IDE10070-MAS09807,Engine oil level: history 7-Qualification,0,
IDE10071-MAS00666,Engine oil level: history 8-Warning,no warning,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,0.00, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,0, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,0, km
IDE10071-MAS09804,Engine oil level: history 8-Test method 1,OFF,
IDE10071-MAS09805,Engine oil level: history 8-Test method 2,OFF,
IDE10071-MAS09806,Engine oil level: history 8-Test method 3,OFF,
IDE10071-MAS09807,Engine oil level: history 8-Qualification,0,
IDE10072-MAS00666,Engine oil level: history 9-Warning,no warning,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,0.00, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,0, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,0, km
IDE10072-MAS09804,Engine oil level: history 9-Test method 1,OFF,
IDE10072-MAS09805,Engine oil level: history 9-Test method 2,OFF,
IDE10072-MAS09806,Engine oil level: history 9-Test method 3,OFF,
IDE10072-MAS09807,Engine oil level: history 9-Qualification,0,
IDE10120,Chain elongation inlet: mileage of the last adaptation,0, km
IDE10121,Chain elongation outlet: mileage of the last adaptation,0, km
IDE10254,Turbine actuator 1 bank 1: pos. contr. spec. value,100.00, %
IDE10300,OBD Driving Cycle detected,active,
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,0.000, V
IDE10380,Knock sensor average voltage bank 1,0.442, V
IDE10551-MAS05304,Pre-ignition counter for oxygen shift-Cylinder 1,1,
IDE10551-MAS05305,Pre-ignition counter for oxygen shift-Cylinder 2,1,
IDE10551-MAS05306,Pre-ignition counter for oxygen shift-Cylinder 3,1,
IDE10551-MAS05307,Pre-ignition counter for oxygen shift-Cylinder 4,1,
IDE10551-MAS05308,Pre-ignition counter for oxygen shift-Cylinder 5,0,
IDE10551-MAS05309,Pre-ignition counter for oxygen shift-Cylinder 6,0,
IDE10551-MAS05310,Pre-ignition counter for oxygen shift-Cylinder 7,0,
IDE10551-MAS05311,Pre-ignition counter for oxygen shift-Cylinder 8,0,
IDE10552-MAS05304,Pre-ignition counter for torque reduction-Cylinder 1,0,
IDE10552-MAS05305,Pre-ignition counter for torque reduction-Cylinder 2,0,
IDE10552-MAS05306,Pre-ignition counter for torque reduction-Cylinder 3,0,
IDE10552-MAS05307,Pre-ignition counter for torque reduction-Cylinder 4,0,
IDE10552-MAS05308,Pre-ignition counter for torque reduction-Cylinder 5,0,
IDE10552-MAS05309,Pre-ignition counter for torque reduction-Cylinder 6,0,
IDE10552-MAS05310,Pre-ignition counter for torque reduction-Cylinder 7,0,
IDE10552-MAS05311,Pre-ignition counter for torque reduction-Cylinder 8,0,
IDE10553-MAS05304,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1,0,
IDE10553-MAS05305,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2,0,
IDE10553-MAS05306,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3,0,
IDE10553-MAS05307,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4,0,
IDE10553-MAS05308,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5,0,
IDE10553-MAS05309,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6,0,
IDE10553-MAS05310,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7,0,
IDE10553-MAS05311,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8,0,
IDE10554-MAS05304,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1,0,
IDE10554-MAS05305,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2,0,
IDE10554-MAS05306,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3,0,
IDE10554-MAS05307,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4,0,
IDE10554-MAS05308,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5,0,
IDE10554-MAS05309,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6,0,
IDE10554-MAS05310,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7,0,
IDE10554-MAS05311,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8,0,
IDE10560,Adaption of radiator shutters: status,completed successfully,
IDE10580,Engine oil level: test method 1,94.20, %
IDE10581,Engine oil level: test method 2,89.40, %
IDE10582,Engine oil level: test method 3,97.70, %
IDE10633,Clutch protection function: reduced torque,1023.9, Nm
IDE10634,Clutch protection function: slip speed of the clutch,0, /min
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG355207,Exhaust warning light: triggering contr. module-MIL_Request_from_BCCM,No,
IDE10710-ENG353763,Exhaust warning light: triggering contr. module-MIL_Request_from_DCDC,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG420335,Exhaust warning light: triggering contr. module-MIL-Request from Battery Diagnostic Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG137566,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG137567,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10732,Engine oil level: factor volume,58.00,
IDE10848,Accelerator pedal position,0.00, %
IDE10968,Activation radiator shutter result,72.90, %
IDE10970-MAS11563,Number of prevented stop processes-hood open,2,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,2,
IDE10989,Immobilizer: historic data,|Year,Month
IDE10994,Poor start counter at start-stop,0,
IDE11080,AVS operating state: outlet,regular operation,
IDE11115,Start/stop driver request: counter restart by starter,1,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11267,Oil level: max. value: relative,110.60, %
IDE11268,Oil level: min. value: relative,85.50, %
IDE11302-MAS05513,Engine oil level: test method 1 qualification-Bit 0,5,
IDE11302,Engine oil level: test method 1 qualification,Unknown (5)
IDE11303-MAS05513,Engine oil level: test method 3 qualification-Bit 0,7,
IDE11303,Engine oil level: test method 3 qualification,Saved mean value,
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometres,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometres,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometres,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometres,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometres,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometres,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometres,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometres,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometres,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometres,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11351,Position sensor for chrg. press. actuator: digit. value,2883,
IDE11493,Disengaging clutch actuator: act. position,0.00000, mm
IDE11494-MAS03359,Disengaging clutch actuator: status-Text,OFF,
IDE11495,Disengaging clutch actuator: current,-50.0, A
IDE11496,Disengaging clutch actuator: voltage,0.0, V
IDE11498,Decoupler actuator,0.00, °C
IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
IDE11577-MAS04416,Stop process prevented 2-Sporadic function prevention,not active,
IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
IDE11577-MAS04591,Stop process prevented 2-Air system diagnosis,not active,
IDE11577-MAS04870,Stop process prevented 2-Thermostat testing not completed,not active,
IDE11577-MAS06602,Stop process prevented 2-Engine temperature,not active,
IDE11577-MAS06604,Stop process prevented 2-Start/stop sensors:,active,
IDE11577-MAS06605,Stop process prevented 2-Regeneration Mode,not active,
IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
IDE11577-MAS08032,Stop process prevented 2-DTC memory entry in engine control module,not active,
IDE11577-MAS09416,Stop process prevented 2-Learning function active,not active,
IDE11577-MAS13644,Stop process prevented 2-Engine protection active,not active,
IDE11577-MAS13645,Stop process prevented 2-Fuel gelling protection active,not active,
IDE11577-MAS13661,Stop process prevented 2-Exhaust treatment diagnosis,not active,
IDE11577-MAS16918,Stop process prevented 2-Restriction in start system,not active,
IDE11598,Tank deaeration valve diagnosis: unweighted input value,0.000, counts
IDE11599,Tank deaeration valve diagnosis: weighted output value,0.000, counts
IDE11910-MAS09435,Turbine actuator 1 bank 1: adaptation status-Resetting of adaptation values,not active,
IDE11910-MAS12399,Turbine actuator 1 bank 1: adaptation status-Sign of sensor characteristic slope,not active,
IDE11910-MAS12400,Turbine actuator 1 bank 1: adaptation status-Learn offset enable: ambient air pressure,not active,
IDE11910-MAS12401,Turbine actuator 1 bank 1: adaptation status-Learn offset enable: time after start,not active,
IDE11910-MAS12402,Turbine actuator 1 bank 1: adaptation status-Learn offset enable,not active,
IDE11910-MAS12403,Turbine actuator 1 bank 1: adaptation status-Offset learning active,not active,
IDE11910-MAS12404,Turbine actuator 1 bank 1: adaptation status-Opened stop successfully learned,not active,
IDE11910-MAS12405,Turbine actuator 1 bank 1: adaptation status-Closed stop successfully learned,not active,
IDE11910-MAS12406,Turbine actuator 1 bank 1: adaptation status-Offset learning completed,not active,
IDE11910-MAS12407,Turbine actuator 1 bank 1: adaptation status-Reading EEPROM was not successful,not active,
IDE11910-MAS12408,Turbine actuator 1 bank 1: adaptation status-Blocking of control monitoring up to end stops learned,not active,
IDE11910-MAS12409,Turbine actuator 1 bank 1: adaptation status-brake applied,not active,
IDE11910-MAS12410,Turbine actuator 1 bank 1: adaptation status-Open position in idle successfully learned,not active,
IDE11910-MAS12411,Turbine actuator 1 bank 1: adaptation status-Closed position in idle successfully taught,not active,
IDE11910,Turbine actuator 1 bank 1: adaptation status,0,
IDE11919,Lock time for cooling down of secondary air pump,0, s
IDE12099-MAS10949,Decoupler actuator: manufacturers code: block A-Manufacturer code 1,0,
IDE12099-MAS10950,Decoupler actuator: manufacturers code: block A-Manufacturer code 2,0,
IDE12100-MAS10951,Decoupler actuator: manufacturers code: block B-Manufacturer code 3,0,
IDE12100-MAS10952,Decoupler actuator: manufacturers code: block B-Manufacturer code 4,0,
IDE12137,Tank fill level diagnostic reference value,39.9, l
IDE12138,Fuel consumption per driving cycle,92.52, l/100km
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,-2.78, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,10.94, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,3.12, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,-11.84, %
IDE12210,Particle filter: water mass,0.0, g
IDE12392,Turbocharger: pin separation from min. throughput position,6553.4, mV
IDE12401-MAS02397,Turbocharger: positioner status-Sensor error,No,
IDE12401-MAS09482,Turbocharger: positioner status-Current limitation active,No,
IDE12401-MAS12412,Turbocharger: positioner status-Closed position successfully taught,Yes,
IDE12401-MAS14320,Turbocharger: positioner status-Actuator completely open,No,
IDE12401-MAS14321,Turbocharger: positioner status-Actuator completely closed,No,
IDE12401-MAS14322,Turbocharger: positioner status-Open position successfully taught,Yes,
IDE12401-MAS14324,Turbocharger: positioner status-Actuated deactivated due to output stages malfunction,No,
IDE12401-MAS14327,Turbocharger: positioner status-Remaining control deviation recognized,No,
IDE12401-MAS14329,Turbocharger: positioner status-Actuator sticks in the open position,No,
IDE12401-MAS14330,Turbocharger: positioner status-Actuator sticks in the closed position,No,
IDE12401-MAS14332,Turbocharger: positioner status-Time limitation or routine active,No,
IDE12401-MAS14333,Turbocharger: positioner status-Wiping active,No,
IDE12401-MAS14334,Turbocharger: positioner status-Specified position reached,No,
IDE12401-MAS14335,Turbocharger: positioner status-Bearing regulation due to faults deactivated,No,
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,15.36, g
IDE13086,Particle filter: maximum soot build-up reached,20.48, g
IDE13087,Particle filter: maximum ash build-up reached,30.00, g
IDE13088,Particle filter: maximum ash loading ratio reached,5.000, counts
IDE13089,Particle filter: high soot accumulation ratio,7.770, counts
IDE13090,Particle filter: maximum soot loading ratio reached,10.600, counts
IDE13091,Particle filter: ash loading ratio,1.000, counts
IDE13092,Particle filter: soot accumulation ratio,0.999, counts
IDE13301-MAS06606,Drivetrain coordinator: brake fault status-Brake under pressure too low,No,
IDE13301-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE13301-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE13301-MAS14988,Drivetrain coordinator: brake fault status-ESP system malfunction,No,
IDE13301-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE13301-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE13301-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE13301-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE13301-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE13301-MAS16114,Drivetrain coordinator: brake fault status-Deceleration management error,No,
IDE13301-MAS16115,Drivetrain coordinator: brake fault status-Deceleration management: restricted performance,No,
IDE13301-MAS16116,Drivetrain coordinator: brake fault status-Deceleration management not available,No,
IDE13336-MAS04795,Drive train coordinator reversible switch off conditions-main switch off,No,
IDE13336-MAS05192,Drive train coordinator reversible switch off conditions-Driver braking,No,
IDE13336-MAS05823,Drive train coordinator reversible switch off conditions-Speed signal error during initialization,No,
IDE13336-MAS05824,Drive train coordinator reversible switch off conditions-Emer. engine operation,No,
IDE13336-MAS05836,Drive train coordinator reversible switch off conditions-Acceleration monitoring error,No,
IDE13336-MAS05901,Drive train coordinator reversible switch off conditions-Trans. emerg. operation,No,
IDE13336-MAS12585,Drive train coordinator reversible switch off conditions-Speed threshold for reversible ACC shut-off,No,
IDE13336-MAS12586,Drive train coordinator reversible switch off conditions-Speed threshold for ending the brake torque shut-off ramp,No,
IDE13336-MAS12588,Drive train coordinator reversible switch off conditions-Speed cut-off active,No,
IDE13336-MAS12590,Drive train coordinator reversible switch off conditions-Reversible brake system error,No,
IDE13336-MAS12591,Drive train coordinator reversible switch off conditions-Engine off or drive is not ready,No,
IDE13336-MAS15049,Drive train coordinator reversible switch off conditions-Drive train open or no gear selected,No,
IDE13336-MAS16227,Drive train coordinator reversible switch off conditions-Stopping distance reduction 3 interventions,No,
IDE13336-MAS16228,Drive train coordinator reversible switch off conditions-Tracking system interface shutdown,No,
IDE13336-MAS16230,Drive train coordinator reversible switch off conditions-ESP safety-related message condition,No,
IDE13336-MAS16231,Drive train coordinator reversible switch off conditions-ACC switch off because of driver braking,No,
IDE13336-MAS16232,Drive train coordinator reversible switch off conditions-PCC sensor: reversible error,No,
IDE13336-MAS16235,Drive train coordinator reversible switch off conditions-Intelligent parking assistant reversible error,No,
IDE13336-MAS16246,Drive train coordinator reversible switch off conditions-ACC breaking only possible because of CAN bus,No,
IDE13336-MAS16247,Drive train coordinator reversible switch off conditions-Diagnostics fadeout due to identified malfunction,No,
IDE13336-MAS16248,Drive train coordinator reversible switch off conditions-Safety computer detects crash,No,
IDE13336-MAS16249,Drive train coordinator reversible switch off conditions-Electrical parking brake: braking,No,
IDE13336-MAS16253,Drive train coordinator reversible switch off conditions-GRA breaking intervention: switch off due to brake disc temperature,No,
IDE13336-MAS16254,Drive train coordinator reversible switch off conditions-Hill descent assistant active,No,
IDE13336-MAS16255,Drive train coordinator reversible switch off conditions-Locking by trailer shunting assistant,No,
IDE13336-MAS16256,Drive train coordinator reversible switch off conditions-Blocking by parking assistant,No,
IDE13337-MAS05814,Drive train coordinator irreversible switch off conditions-CAN communication error,No,
IDE13337-MAS05815,Drive train coordinator irreversible switch off conditions-CAN signal error,No,
IDE13337-MAS05818,Drive train coordinator irreversible switch off conditions-Transmission coding not plausible,No,
IDE13337-MAS05820,Drive train coordinator irreversible switch off conditions-ACC malfunction,No,
IDE13337-MAS05821,Drive train coordinator irreversible switch off conditions-Braking intervention too weak,No,
IDE13337-MAS05824,Drive train coordinator irreversible switch off conditions-Emer. engine operation,No,
IDE13337-MAS05825,Drive train coordinator irreversible switch off conditions-Engine control module fault,No,
IDE13337-MAS05829,Drive train coordinator irreversible switch off conditions-Brake light fault,No,
IDE13337-MAS05830,Drive train coordinator irreversible switch off conditions-CCS deactivated due to fault in control component,No,
IDE13337-MAS05831,Drive train coordinator irreversible switch off conditions-ACC deactivated due to fault in control component,No,
IDE13337-MAS05832,Drive train coordinator irreversible switch off conditions-Coding error,No,
IDE13337-MAS05833,Drive train coordinator irreversible switch off conditions-ESC error,No,
IDE13337-MAS05835,Drive train coordinator irreversible switch off conditions-Clutch pedal fault,No,
IDE13337-MAS05836,Drive train coordinator irreversible switch off conditions-Acceleration monitoring error,No,
IDE13337-MAS15052,Drive train coordinator irreversible switch off conditions-Brake light actuation malfunction,No,
IDE13337-MAS16257,Drive train coordinator irreversible switch off conditions-Brake pedal implausible,No,
IDE13337-MAS16258,Drive train coordinator irreversible switch off conditions-Transport mode active,No,
IDE13337-MAS16259,Drive train coordinator irreversible switch off conditions-GRA looking due to software as product,No,
IDE13337-MAS16260,Drive train coordinator irreversible switch off conditions-Emergency assistant: actual acceleration error,No,
IDE13337-MAS16262,Drive train coordinator irreversible switch off conditions-Vehicle speed determination: substitute value,No,
IDE13337-MAS16263,Drive train coordinator irreversible switch off conditions-Intelligent parking assistant irreversible error,No,
IDE13385,Turbocharger : current actual minimum throughput position raw value,1200.0, mV
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,3VVUW7RM1TM130726,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,21,
IDE13845,Production mode status,not active,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 65 F0 A7 B9 49 42 38,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 0A,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14753,Particulate filter: loading stage,0, counts
IDE14760,Particulate filter: oil ash load measured,0.0, %
IDE14761,Particulate filter: oil ash load calculated,0.0, %
IDE14763,Particulate filter: water load,0.0, %
IDE14765,Particulate filter: soot load measured,0.0, %
IDE14767,Particulate filter: soot load calculated,0.0, %
IDE14789-ENG252532,Currently selected and last used starter device-active start device selection - belt starter generator,not selected,
IDE14789-ENG252533,Currently selected and last used starter device-active start device selection - electrical machine,not selected,
IDE14789-ENG252534,Currently selected and last used starter device-active start device selection - pinion starter,not selected,
IDE14789-ENG252584,Currently selected and last used starter device-last used start device - belt starter generator,not active,
IDE14789-ENG252585,Currently selected and last used starter device-last used start device - electrical machine,not active,
IDE14789-ENG252586,Currently selected and last used starter device-last used start device - pinion starter,not active,
IDE15781,VW Trustcenter Project ID,1069,
IDE15972,Charge Air Pressure Actuator blocking position,0.0, %
IDE15976-ENG275973,Particulate filter regeneration history-Endkilometer 1,0, km
IDE15976-ENG275974,Particulate filter regeneration history-Endkilometer 2,0, km
IDE15976-ENG275975,Particulate filter regeneration history-Endkilometer 3,0, km
IDE15976-ENG275971,Particulate filter regeneration history-Startkilometer 1,0, km
IDE15976-ENG275970,Particulate filter regeneration history-Startkilometer 2,0, km
IDE15976-ENG275972,Particulate filter regeneration history-Startkilometer 3,0, km
IDE15979,Service regeneration of particulate filter: advance,0, %
IDE16744,Venting system of purge air pump: temperature,59.0, °C
IDE16745,Venting system of purge air pump: speed,52.5, %
IDE16746,Venting system of purge air pump: set speed,52.5, %
IDE17086,Charge air pressure actuator: initial adaptation of the lower stop,1074, counts
IDE17130,Charge air pressure actuator: initial adaptation of the upper stop,3283, counts
IDE17177,Charge air pressure actuator: averaged adaptation of the upper stop,3270, counts
IDE17309,Charge air pressure actuator: averaged adaptation of the lower stop,1098, counts
IDE17938,Charge air pressure actuator: adaptation for lower stop,1094, counts
IDE17939,Charge air pressure actuator: adaptation for upper stop,3267, counts
IDE18169,Activated charcoal container: loading of filtered value,0.01, no unit
IDE18171,Fuel tank ventilation line pressure: raw value,990.1, hPa
IDE18172,Fuel tank ventilation line pressure: filtered value,6553.5, hPa
IDE18776,Audi valvelift system switchover counter 2: total,151, no unit
IDE19010,Crankcase breather line pressure: raw value,985.3918, hPa
MAS17031,Radiator shutter 1: actual position,73, %
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS23170,Tank ventilation valve blockage: diagnosis status,Diagnosis not finished,
MAS23171,Tank ventilation valve blockage: diagnosis result,No malfunction detected,
MAS23172,Purge air line: diagnosis status,Diagnosis not finished,
MAS23173,Purge air line: diagnosis result,Diagnosis not finished,
MAS23174,Ventilation system flow rate: diagnosis status,Diagnosis not finished,
MAS23175,Ventilation system flow rate: diagnosis result,No malfunction detected,
MAS29691,Tank leakage diagnostics: principal diagnostics for routine ATLD,Function is not active,
MAS29707,Tank leakage diagnostics: additional diagnostics for routine ATLD,Function is not active,
MAS29855,Duration of pump-up phase last diagnostic run,0.00, s
MAS29856,Tank differential pressure at start of observation phase,0.00, hPa
MAS29857,Tank differential pressure at end of observation phase,0.00, hPa
MAS29858,Fuel outgassing in fuel tank system,0.000, Pa/s
MAS29859,Counter for PinPointing starts,0, counts
MAS29860,Leak in fuel tank system at end of diagnostic phase,0.000, mm
MAS29861,Tank differential pressure at end of last diagnostic phase,0.00, hPa
MAS30050,Fuel tank leak detection: successful diagnoses since last refueling,0, counts
MAS30150,Status of adaptation for injector opening time cyl. 1,0, units
MAS30154,Average of the boost voltage of the high-pressure injector,66, V
MAS30155,Status of adaptation for injector opening time cyl. 2,0, units
MAS30157,Smallest hydraulic injection time in the driving cycle,917, µs
MAS30158,Plausibility of the injector return value byte 3,0, units
MAS30159,Plausibility of the injector return value byte 0,0, units
MAS30160,Plausibility of the injector return value byte 4,0, units
MAS30161,Plausibility of the injector return value byte 2,0, units
MAS30162,Plausibility of the injector return value byte 1,0, units
MAS30163,Status of electr. monitoring of general multi-point injection,0, units
MAS30164,Status of monitoring of multi-point injection,0, units
MAS30166,Status of electr. monitoring of multi-point injection,0, units
MAS30169,Status of monitoring of general multi-point injection,0, units
MAS30170,Error pattern of the power output stage for injector during start,0, units
MAS30171,Status of adaptation for injector opening time cyl. 4,0, units
MAS30172,Status of adaptation for injector opening time cyl. 3,0, units
MAS30173,Number of injector activations per work cycle,1, units
MAS30174,Error pattern of the power output stage for the injector,0, units
MAS30175,Current boost voltage of the high-pressure injector,66, V
ENG102981,AC compressor: speed increase,true,
ENG103860,AC request: speed increase,true,
ENG103042,Accelerator pedal sender: learned end stop,4.102, V
ENG103474,Activation of oil pressure switching valve,00000001 ,
ENG252355,Active Aerodynamic Features #1 Off-cycle Credit Vehicle Data,|Active Grille Air Shutter A Timer 1 (Recent),Active Grille Air Shutter A Timer 2 (Recent)
ENG252358,Active Powertrain Warm-up Features Off-cycle Credit Vehicle Data,|Active Engine Warm-up Timer (Recent),Active Engine Warm-up Timer (Lifetime)
ENG103323,Additional water pump,00000001 ,
ENG101828,Air mass,14.78, kg/h
ENG104264,Alternator load,1400, W
ENG103910,Ambient temperature,31.50, °C
ENG112539,AR_THR_AD_ADD_MMV,-0.0000, cm²
ENG103165,Battery voltage,14.4, V
ENG138673,Bypasstool_a2l_name,SD2C56,
ENG138672,Bypasstool_manipulation_bit,not active,
ENG101413,Calibration Identifications,||06U070BH5627BXAB|5QS530K+20970143|,
ENG99697,Calibration Verification Numbers,||31 2D 52 5E|0C 94 DF B4|,
ENG128780,CAM_DIF_VCP{EX_1},-0.10, °
ENG128781,CAM_DIF_VCP{IN_1},0.16, °
ENG112540,CAM_PHA_ENG{GES_EX}{CBK_1},4.930, °
ENG112541,CAM_PHA_ENG{GES_IN}{CBK_1},3.063, °
ENG101785,Cat. temperature: bank 1,428.91, °C
ENG252361,Certification Test Group/Engine Family Number,|Certification Test Group/Engine Family Number|TVGAJ02.0V3G|,
ENG125189,CTR_CAM_IN_SP_PI_DET_REQ{0},0,
ENG125190,CTR_CAM_IN_SP_PI_DET_REQ{1},0,
ENG125191,CTR_CAM_IN_SP_PI_DET_REQ{2},0,
ENG125192,CTR_CAM_IN_SP_PI_DET_REQ{3},0,
ENG390342,CTR_DEB_ACT_VVL_STC,2,
ENG390343,CTR_ERR_DET_CAM_STK_0_VVL_STC,0,
ENG390344,CTR_ERR_DET_CAM_STK_1_VVL_STC,0,
ENG390345,CTR_ERR_INTM_SIG_VVL_STC,0,
ENG390346,CTR_ERR_INTM_SWI_VVL_STC,0,
ENG390347,CTR_ERR_SUSP_MAP_VVL_STC,0,
ENG390348,CTR_ERR_SUSP_MISF_VVL_STC,0,
ENG125193,CTR_LAMB_SP_PI_REQ{0},1,
ENG125194,CTR_LAMB_SP_PI_REQ{1},1,
ENG125195,CTR_LAMB_SP_PI_REQ{2},1,
ENG125196,CTR_LAMB_SP_PI_REQ{3},1,
ENG390349,CTR_LIH_ACT_VVL_STC,0,
ENG112554,CTR_MIS_DC_MMV_CYL_SAE{0},0,
ENG112555,CTR_MIS_DC_MMV_CYL_SAE{1},0,
ENG112556,CTR_MIS_DC_MMV_CYL_SAE{2},0,
ENG112557,CTR_MIS_DC_MMV_CYL_SAE{3},0,
ENG112558,CTR_MIS_TOT_NVMY_SAE,134,
ENG125197,CTR_REQ_IV_OFF_PI_FAST{0},0,
ENG125198,CTR_REQ_IV_OFF_PI_FAST{1},0,
ENG125199,CTR_REQ_IV_OFF_PI_FAST{2},0,
ENG125200,CTR_REQ_IV_OFF_PI_FAST{3},0,
ENG125201,CTR_REQ_IV_OFF_PI_SLOW{0},0,
ENG125202,CTR_REQ_IV_OFF_PI_SLOW{1},0,
ENG125203,CTR_REQ_IV_OFF_PI_SLOW{2},0,
ENG125204,CTR_REQ_IV_OFF_PI_SLOW{3},0,
ENG128782,CTR_REQ_IV_OFF_PI_SLOW_TMP{0},0,
ENG128783,CTR_REQ_IV_OFF_PI_SLOW_TMP{1},0,
ENG128784,CTR_REQ_IV_OFF_PI_SLOW_TMP{2},0,
ENG128785,CTR_REQ_IV_OFF_PI_SLOW_TMP{3},0,
ENG100764,CTR_SUM_SRV_INTL,0.0,
ENG125205,CTR_TQI_POW_MAX_PI_REQ{0},0,
ENG125206,CTR_TQI_POW_MAX_PI_REQ{1},0,
ENG125207,CTR_TQI_POW_MAX_PI_REQ{2},0,
ENG125208,CTR_TQI_POW_MAX_PI_REQ{3},0,
ENG119929,CTR_VLD_CAT_GAP_AFL{1},0,
ENG119930,CTR_VLD_CAT_GAP_AFR{1},0,
ENG101652,Cylinder shut-off: cylinder suppression,00000000 ,
ENG112560,DIST_ACT_MIL_SAE,0, km
ENG112561,DIST_DTC_CLR_SAE,477, km
ENG100531,DIST_ST,496500, m
ENG275645,Distance Traveled Since Evap Monitoring Decision,|Distance Traveled Since Evap Monitoring Decision|365|, km
ENG100131,ECU_STATE,SYN_ENG_IGK_ON,
ENG100152,ECUNAME,|ECU,ECUNAME|ECM
ENG390364,EFF_IGA_CH_L_QUO_IS_MAX,15, %
ENG390365,EFF_IGA_CH_L_QUO_PL_MAX,60, %
ENG100882,EFF_IGA_CST_QUO_IS_MAX,2, %
ENG99938,EFF_IGA_CST_QUO_PL_MAX,27, %
ENG247045,Engine Exhaust Flow Rate,15.6, kg/h
ENG151174,Engine Friction - Percent Torque,3.0, %
ENG104044,Engine load,17.2, %
ENG103667,ENVD_0_MON,0,
ENG99424,ENVD_1_MON,0,
ENG99790,ENVD_2_MON,0,
ENG99455,ENVD_3_MON,0,
ENG132815,ENVD_4_MON,0,
ENG132816,ENVD_5_MON,0,
ENG132817,ENVD_6_MON,0,
ENG101942,ESI (extended service intervals) oil warning threshold,0.00, mm
ENG112562,FAC_AR_THR_AD,0.000000, %
ENG245642,FAC_FQ_ST_AD_SAVE_RNG_1_H_RES,1.00000,
ENG245643,FAC_FQ_ST_AD_SAVE_RNG_2_H_RES,1.00000,
ENG245644,FAC_FQ_ST_AD_SAVE_RNG_3_H_RES,1.00000,
ENG245645,FAC_FQ_ST_AD_SAVE_RNG_4_H_RES,1.00000,
ENG100298,FAC_LAM_CP,0.000, %
ENG100108,FAC_LAM_LIM{1},0.160, %
ENG102306,FAC_TPS_1_SAE,14.9019610, %
ENG102292,FAC_TPS_1_SAE,14.5098042, %
ENG101437,Fan request from air conditioner,33.203125, %
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG128786,FTL_SAE,43.1, %
ENG104248,Fuel consumption signal,45687, µl
ENG247046-ENG186450,Fuel Rate-Engine Fuel Rate,0.28, g/s
ENG247046-ENG247209,Fuel Rate-Vehicle Fuel Rate,0.28, g/s
ENG102108,FUP_H,130842.5, hPa
ENG112563,FUP_H_SAE,12940, kPa
ENG99170,Height correction,987.80, hPa
ENG103575,High-pressure system: regulator,-0.11, mg
ENG103879,High-pressure system: regulator: mobile part,-1.27, mg
ENG101567,Idling speed stabilisation: duty cycle/AC compressor torque,10.25, Nm
ENG101946,Idling stabilisation: operating status,false,
ENG245650,IDX_FUEL_SYS_SAE{1},2,
ENG100345,IGA_ADJ_KNK{0},0.000, °
ENG103593,IGA_ADJ_KNK{1},0.000, °
ENG103360,IGA_ADJ_KNK{2},0.000, °
ENG99404,IGA_ADJ_KNK{3},0.000, °
ENG100425,IGA_IGC{0},2.250, °
ENG101655,IGA_IGC{1},-0.375, °
ENG100410,IGA_IGC{2},1.500, °
ENG100407,IGA_IGC{3},5.625, °
ENG112564,IGA_IGC_SAE,8.5, °
ENG410437,Injector_adaption_counter,10727,
ENG410438,Injector_mass_deviation_adaption_counter,416,
ENG100634-ENG299122,In-use Performance Tracking: 16 or 20 counters-Counters 3-EOP,|Completion Condition Counts,Conditions Encountered Counts|6
ENG100634-ENG102823,In-use Performance Tracking: 16 or 20 counters-Ignition Cycle Counter,0, counts
ENG100634-ENG99988,In-use Performance Tracking: 16 or 20 counters-OBD Monitoring Conditions Encountered Counts,0, counts
ENG100634-ENG250449,In-use Performance Tracking: 16 or 20 counters-Raw Data,00,
ENG125209,KNKS_ERR_REL{0},0.0391, V
ENG99741,LAMB_DELTA_AD_LAM_ADJ{1},0.00043,
ENG112565,LAMB_DELTA_SUM_LAM_ADJ_AD{1},0.00043,
ENG99674,Lambda controller: bank 1 (averaged value),0.185, %
ENG101381,Lambda probe 1: bank 1: status,00000001 ,
ENG101039,Lambda probe 1: bank 1: status,00000000 ,
ENG102886,Lambda probe 1: bank 1: status,00000000 ,
ENG104200,Lambda probe 2: bank 1: status,00000000 ,
ENG101336,Lambda probe 2: bank 1: status,00000001 ,
ENG101869,Lambda probe ageing: bank 1: probe 1: short trip result,331.85, °C
ENG100478,Lambda probe correction: duty cycle offset: bank 1,0.00024,
ENG102763,Lambda probes actual: bank1,1.0010,
ENG245657,LF_DPS_CYC_ERR_RAW_BSW{CYL_0},0,
ENG245658,LF_DPS_CYC_ERR_RAW_BSW{CYL_1},0,
ENG245659,LF_DPS_CYC_ERR_RAW_BSW{CYL_2},0,
ENG245660,LF_DPS_CYC_ERR_RAW_BSW{CYL_3},0,
ENG245661,LF_DPS_CYC_ERR_VLD_BSW{CYL_0},2097151,
ENG245662,LF_DPS_CYC_ERR_VLD_BSW{CYL_1},2097151,
ENG245663,LF_DPS_CYC_ERR_VLD_BSW{CYL_2},2097151,
ENG245664,LF_DPS_CYC_ERR_VLD_BSW{CYL_3},2097151,
ENG112570,LF_DPS_INI_ERR_RAW_BSW{1},0,
ENG112571,LF_DPS_INI_ERR_RAW_BSW{2},0,
ENG245665,LF_IV_ERR_RAW_BSW{CYL_0},0,
ENG245666,LF_IV_ERR_RAW_BSW{CYL_1},0,
ENG245667,LF_IV_ERR_RAW_BSW{CYL_2},0,
ENG245668,LF_IV_ERR_RAW_BSW{CYL_3},0,
ENG245669,LF_IV_ERR_VLD_BSW{CYL_0},511,
ENG245670,LF_IV_ERR_VLD_BSW{CYL_1},511,
ENG245671,LF_IV_ERR_VLD_BSW{CYL_2},511,
ENG245672,LF_IV_ERR_VLD_BSW{CYL_3},511,
ENG138674,LF_MVB_BUS_INTC_DIAG,0,
ENG138675,LF_MVB_PDU_INTC_DIAG_1,0,
ENG138676,LF_MVB_PDU_INTC_DIAG_10,0,
ENG168842,LF_MVB_PDU_INTC_DIAG_11,0,
ENG168843,LF_MVB_PDU_INTC_DIAG_12,0,
ENG138677,LF_MVB_PDU_INTC_DIAG_13,0,
ENG138679,LF_MVB_PDU_INTC_DIAG_15,0,
ENG138680,LF_MVB_PDU_INTC_DIAG_16,0,
ENG138681,LF_MVB_PDU_INTC_DIAG_17,0,
ENG138682,LF_MVB_PDU_INTC_DIAG_18,0,
ENG168844,LF_MVB_PDU_INTC_DIAG_19,0,
ENG138683,LF_MVB_PDU_INTC_DIAG_2,0,
ENG168845,LF_MVB_PDU_INTC_DIAG_20,0,
ENG168846,LF_MVB_PDU_INTC_DIAG_22,0,
ENG168847,LF_MVB_PDU_INTC_DIAG_23,0,
ENG168848,LF_MVB_PDU_INTC_DIAG_24,0,
ENG168849,LF_MVB_PDU_INTC_DIAG_25,0,
ENG168850,LF_MVB_PDU_INTC_DIAG_26,0,
ENG168851,LF_MVB_PDU_INTC_DIAG_27,0,
ENG138684,LF_MVB_PDU_INTC_DIAG_3,0,
ENG138685,LF_MVB_PDU_INTC_DIAG_4,0,
ENG138686,LF_MVB_PDU_INTC_DIAG_5,0,
ENG138687,LF_MVB_PDU_INTC_DIAG_6,0,
ENG138689,LF_MVB_PDU_INTC_DIAG_8,0,
ENG138690,LF_MVB_PDU_INTC_DIAG_9,0,
ENG249153,LF_TQ_PT_ACT_REQ,512,
ENG127734,Life_cycle_data_start_requirement_development,|Year,Month
ENG127735,Life_cycle_data_stop_prohibition_development,|Year,Month
ENG127733,Life_cycle_data_system_failure,|Year,Month
ENG245673,LOAD_CLC_SAE,16.1, %
ENG100402,LOIL_SUM_SRV_INTL,-0.06, mm
ENG99162,LV_ACC_RED_CMD,false,
ENG112584,LV_BPA_AD_REQ{0},00000000 ,
ENG114829,LV_BPA_LIH_REQ{0},00000000 ,
ENG128787,LV_CMD_RCL_OPEN,00000000 ,
ENG245677,LV_CRU_ENA_BRAKE_INTV,00000001 ,
ENG112471,LV_IGK,00000001 ,
ENG100044,LV_LOIL_L_WARN,00000000 ,
ENG103492,LV_LOIL_L_WARN_ACT,false,
ENG103908,LV_LOIL_L_WARN_TMP,false,
ENG245679,LV_PWR_RLY{ENG_RLY},00000001 ,
ENG102417,LV_TPS_AD_ACT,00000000 ,
ENG100842,LV_TPS_AD_DIAG_ERR,00000000 ,
ENG103996,LV_TPS_AD_REQ,00000000 ,
ENG112588,MAP_MES_SAE,33, kPa
ENG103501,MASS_SA_REL{0},0.984,
ENG100896,MASS_SA_REL_21_PHA,0.000,
ENG103045,MASS_SA_REL_22_PHA,0.000,
ENG126493,MFF_MPL_ADD_LAM_AD{1}{1},-0.02, mg/stroke
ENG101360,Misfire detection active,00000000 ,
ENG102335,Misfires all cylinders per 1000 rpm,0,
ENG245686,N_SAE,902.8, /min
ENG128796,N_SP_IS_CLC,900, /min
ENG103004,N_TCHA,11010.7, /min
ENG112590,N_TOOTH,914, /min
ENG126111,NL_PRE{0},0.386, V
ENG126112,NL_PRE{1},0.410, V
ENG126113,NL_PRE{2},0.476, V
ENG126114,NL_PRE{3},0.371, V
ENG245687,NR_CYC_AD_DC_BAL_HOM{0},0,
ENG245688,NR_CYC_AD_DC_BAL_HOM{1},0,
ENG245689,NR_CYC_AD_DC_BAL_HOM{2},0,
ENG275707,NR_CYC_DIAG_BAL_HOM_AD_MAX{0},0,
ENG275708,NR_CYC_DIAG_BAL_HOM_AD_MAX{1},0,
ENG275709,NR_CYC_DIAG_BAL_HOM_AD_MAX{2},0,
ENG275710,NR_CYC_DIAG_BAL_HOM_AD_MAX{3},0,
ENG275711,NR_CYC_DIAG_BAL_HOM_AD_MIN{0},0,
ENG275712,NR_CYC_DIAG_BAL_HOM_AD_MIN{1},0,
ENG275713,NR_CYC_DIAG_BAL_HOM_AD_MIN{2},0,
ENG275714,NR_CYC_DIAG_BAL_HOM_AD_MIN{3},0,
ENG119936,O2L_MAX_CAT_GAP_AFL_MV{1},0.00000, g
ENG119937,O2L_MAX_CAT_GAP_AFR_MV{1},0.00000, g
ENG99157,PRS_SA_DIF,0.00, hPa
ENG128797,PV,0.00, %
ENG102195,PV_AV_1,0.00, %
ENG99137,PV_AV_2,0.00, %
ENG101068,PV_AV_H,0.00, %
ENG112593,PWM_ACT_VCP{EX_1},100.000, %
ENG112594,PWM_ACT_VCP{IN_1},100.000, %
ENG112597,PWM_PAS_VCP{EX_1},0.000, %
ENG112598,PWM_PAS_VCP{IN_1},0.000, %
ENG101201,Radiator fan 1: run-on: status,600W,
ENG102359,Radiator fan 2: run-on: status,600W,
ENG119939,RATIO_O2L_LIM_CAT_GAP_AFL_MV{1},5.1995225,
ENG119940,RATIO_O2L_LIM_CAT_GAP_AFR_MV{1},0.0000000,
ENG252416,Run Time for Stop-Start and Coasting Off-cycle Credit Vehicle Data,|Idle Stop-Start Timer (Recent),Idle Stop-Start Timer (Lifetime)
ENG103248,SEG_AD_MMV_ER{0},0.0000,
ENG101135,SEG_AD_MMV_ER{1},0.5901,
ENG99078,SEG_AD_MMV_ER{2},0.1178,
ENG103257,SEG_AD_MMV_ER{3},0.7358,
ENG100919,Starter control: interlock switch,false,
ENG245709,STATE_CRU_DCC_REQ_CUS,2,
ENG114834,STATE_CRU_OFF_IRR_CUS,0,
ENG114835,STATE_CRU_OFF_REV_CUS,16924736,
ENG245710,STATE_CRU_PT_CUS,16388,
ENG245711,STATE_FRF_BYTE_IMMO_APP_1,0,
ENG245712,STATE_FRF_BYTE_IMMO_APP_2,0,
ENG245713,STATE_FRF_BYTE_IMMO_APP_3,0,
ENG245714,STATE_FRF_BYTE_IMMO_APP_4,0,
ENG245715,STATE_FRF_BYTE_IMMO_APP_5,0,
ENG245716,STATE_FRF_BYTE_IMMO_APP_6,0,
ENG245717,STATE_FRF_BYTE_IMMO_DEAC_1,0,
ENG245718,STATE_FRF_BYTE_IMMO_DEAC_2,0,
ENG245719,STATE_FRF_BYTE_IMMO_DEAC_3,0,
ENG245720,STATE_FRF_BYTE_IMMO_DEAC_4,0,
ENG245721,STATE_FRF_BYTE_IMMO_DEAC_5,0,
ENG245722,STATE_FRF_BYTE_IMMO_DEAC_6,0,
ENG245723,STATE_FRF_BYTE_IMMO_RST_SAFE_1,0,
ENG245724,STATE_FRF_BYTE_IMMO_RST_SAFE_2,0,
ENG245725,STATE_FRF_BYTE_IMMO_RST_SAFE_3,0,
ENG245726,STATE_FRF_BYTE_IMMO_RST_SAFE_4,0,
ENG245727,STATE_FRF_BYTE_IMMO_RST_SAFE_5,0,
ENG245728,STATE_FRF_BYTE_IMMO_RST_SAFE_6,0,
ENG112606,STATE_PWM_VCP{EX_1},pas,
ENG112607,STATE_PWM_VCP{IN_1},HLD,
ENG158210,STATE_T_ES_VLD_ATIC,1,
ENG245731,STATE_T_ES_VLD_ENVD,135444,
ENG112608,STATE_VCP,passive,
ENG114836,STATE_VCV_CLOSE_SL,OFF,
ENG112609,T_ACT_MIL_SAE,0, min
ENG112494,T_AST_SAE,1273, s
ENG104148,T_COOL_LOIL,689.1, ms
ENG112613,T_DTC_CLR_SAE,567, min
ENG251838,T_ECU_OFF_ENVD,4, s
ENG109299,T_ES,1413, min
ENG158245,T_ES_ATIC,86143, s
ENG158250,T_ES_ATIC_OLD_ENVD,0, s
ENG245741,T_ES_ATIC_PLAUS_DEV,0, s
ENG251839,T_ES_ATIC_PLAUS_TMR_CHK,60.0, s
ENG112616,T_ES_DC,1413, min
ENG99463,T_ES_H,65535, s
ENG128802,T_IGK,655.35, s
ENG99398,T_POP_COC_INTER_1,0.0, s
ENG102747,T_PWL,0.0, s
ENG245742,T_PWL_END,0.0, s
ENG101325,T_TEMP_SIG_LOIL,63.6, ms
ENG125440,TAA,32.000, °C
ENG102048,Tank breather valve: duty cycle,77.0, %
ENG101339,Tank breather valve: short trip result,1.4492, kg/h
ENG100439,Tank level,00000000 ,
ENG112610,TCO_1_FIRST_ST,22, °C
ENG112611,TCO_1_ST,22, °C
ENG112612,TCO_1_SYS,90, °C
ENG128800,TCO_MDL{STUCK_L_COOL_MON},58.602, °C
ENG124460,TCO_MDL{TH},67.000, °C
ENG102279,TCS/ESP: specified torque,32.6875, Nm
ENG99857,TCS: status,false,
ENG110436,TEG_DYN_LS_DOWN{1},430.85, °C
ENG101941,TEMP_CAT_STAT_MDL{1},447.48, °C
ENG112614,TEMP_CAT_UP_1_SAE,406.9, °C
ENG114837,TFPA,87, °C
ENG114838,TFU_HPP,51.0, °C
ENG101411,Throttle valve angle,4.683, °
ENG390554,TI_MES_CHK{CYL_0}{PLS_1},950.9, µs
ENG390555,TI_MES_CHK{CYL_0}{PLS_2},0.0, µs
ENG390556,TI_MES_CHK{CYL_0}{PLS_3},0.0, µs
ENG390557,TI_MES_CHK{CYL_0}{PLS_4},0.0, µs
ENG390558,TI_MES_CHK{CYL_0}{PLS_5},0.0, µs
ENG390559,TI_MES_CHK{CYL_0}{PLS_6},0.0, µs
ENG390560,TI_MES_CHK{CYL_0}{PLS_7},0.0, µs
ENG390561,TI_MES_CHK{CYL_0}{PLS_8},0.0, µs
ENG390562,TI_MES_CHK{CYL_1}{PLS_1},918.7, µs
ENG390563,TI_MES_CHK{CYL_1}{PLS_2},0.0, µs
ENG390564,TI_MES_CHK{CYL_1}{PLS_3},0.0, µs
ENG390565,TI_MES_CHK{CYL_1}{PLS_4},0.0, µs
ENG390566,TI_MES_CHK{CYL_1}{PLS_5},0.0, µs
ENG390567,TI_MES_CHK{CYL_1}{PLS_6},0.0, µs
ENG390568,TI_MES_CHK{CYL_1}{PLS_7},0.0, µs
ENG390569,TI_MES_CHK{CYL_1}{PLS_8},0.0, µs
ENG390570,TI_MES_CHK{CYL_2}{PLS_1},913.3, µs
ENG390571,TI_MES_CHK{CYL_2}{PLS_2},0.0, µs
ENG390572,TI_MES_CHK{CYL_2}{PLS_3},0.0, µs
ENG390573,TI_MES_CHK{CYL_2}{PLS_4},0.0, µs
ENG390574,TI_MES_CHK{CYL_2}{PLS_5},0.0, µs
ENG390575,TI_MES_CHK{CYL_2}{PLS_6},0.0, µs
ENG390576,TI_MES_CHK{CYL_2}{PLS_7},0.0, µs
ENG390577,TI_MES_CHK{CYL_2}{PLS_8},0.0, µs
ENG390578,TI_MES_CHK{CYL_3}{PLS_1},981.4, µs
ENG390579,TI_MES_CHK{CYL_3}{PLS_2},0.0, µs
ENG390580,TI_MES_CHK{CYL_3}{PLS_3},0.0, µs
ENG390581,TI_MES_CHK{CYL_3}{PLS_4},0.0, µs
ENG390582,TI_MES_CHK{CYL_3}{PLS_5},0.0, µs
ENG390583,TI_MES_CHK{CYL_3}{PLS_6},0.0, µs
ENG390584,TI_MES_CHK{CYL_3}{PLS_7},0.0, µs
ENG390585,TI_MES_CHK{CYL_3}{PLS_8},0.0, µs
ENG128801,TIA_CHA_DOWN_MV,53.695, °C
ENG125276,TIG_MES_SAE{IM},43, °C
ENG103351,Time since engine start,1280.9, s
ENG112634,TLTS_MES{TCE},90.656, °C
ENG245765,TLTS_MES_SAE{TCE},90, °C
ENG112635,TMAG_VCP,85, °C
ENG110444,TPS_AD_CDN_MIS,0,
ENG128804,TQI_ADD_ACT,43.90625, Nm
ENG101426,TQI_GS_FAST_INC,0.00, Nm
ENG128805,TQI_N_TCHA_MAX,1023.96875, Nm
ENG247047-ENG247196,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG247047-ENG247180,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG247047-ENG247177,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG247047-ENG247188,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG102329,TTIP_MES_LS_UP{1},719.8750, °C
ENG245767,V_LS_SENS{1},0.6589, V
ENG114840,V_PVS_KD,0.000, V
ENG245768,VB_SAE,14.394, V
ENG99514,VBOOST,65.5, V
ENG103201,VCV_CLOSE_RNG,22.1, °
ENG247048,Vehicle Odometer,496.7, km
ENG252424,Vehicle Operation Data - Distance/Fuel Used,|Total Distance Traveled (Recent),Total Distance Traveled (Lifetime)
ENG252425,Vehicle Operation Data - Engine Run/Idle Time,|Ignition Counter (Recent),Ignition Counter (Lifetime)
ENG252426,Vehicle Operation Data - PKE/EOE,|Positive Kinetic Energy (Recent),Positive Kinetic Energy (Lifetime)
ENG252427,Vehicle Operation Data - PSA,|Total Propulsion System Active Time (Recent),Total Propulsion System Active Time (Lifetime)
ENG112639,VLS_DOWN_SAE{1},0.655, V
ENG128806,VOL_FLOW_CHA_UP_RED_MV,0.003326, m³/s
ENG102985,VP_TPS_2,4.2859, V
ENG101674,VP_TPS_AD_LIH_1,0.9485, V
ENG99507,VP_TPS_AD_LIH_2,4.0491, V
ENG245772,VS_MAX_THD,204.87, km/h
ENG245773,VS_SAE,0, km/h
Elapsed Time: 01:22
;SW:09H-927-158-L HW:09H-927-309-A --- 02: Auto Trans
;Component:AQ8 HTS H07 2505, Coding:
;EV_TCMAQ301073,001001,EV_TCMAQ301073_001.rod
;Wednesday,30,September,2026,11:58:03:11564
;VCDS Version: 26.10.0.2 (x64) Data version: 20260921 DS379.0
;VCID: 3D2F66995DF37C22C07-8068-R SFD+SFD2 {x}
Group,Description,Actual
IDE00008,Software version,2505,
IDE00021-ENG99543,Engine speed-Engine RPM,911, /min
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,807.0, /min
IDE00023,Transmission output speed,0.0, /min
IDE00024-ENG98981,ATF temperature-Transmission fluid temperature,27, °C
IDE00025-ENG101037,Coolant temperature-Engine coolant temperature,76.50, °C
IDE00026,Vehicle speed from transmission,0.00000, km/h
IDE00031-ENG101217,Torque transmitting function-Transmission function,0.0,
IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0,
IDE00086,Accelerator pedal position,0.0, %
IDE00087-ENG404263,Tiptronic status-Tip DOWN (Shift lever),not activated,
IDE00087-ENG404072,Tiptronic status-Tip DOWN (Steering wheel),not activated,
IDE00087-ENG404115,Tiptronic status-Tip Error (Shift lever),activated,
IDE00087-ENG404236,Tiptronic status-Tip Error (Steering wheel),not activated,
IDE00087-ENG404219,Tiptronic status-Tip UP (Shift lever),not activated,
IDE00087-ENG404117,Tiptronic status-Tip UP (Steering wheel),not activated,
IDE00087-ENG404202,Tiptronic status-Tip-Slot,not activated,
IDE00089-ENG101851,Position-Automatic Transmission shift position,position_p,
IDE00090,selected gear,Gang P/N (ausgekuppeit),
IDE00094,Kick-down status,OFF,
IDE00095,Status of selector lever lock,not active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position_nicht_betaetigt,
IDE00098-ENG103732,Transmission position-POS_INFO Signal,P,
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,was not yet started,
IDE00324-MAS20321,Programming preconditions-Program precondition,Readiness code not reset,
IDE00324-MAS20322,Programming preconditions-Number of programming requirements,5,
IDE00358-ENG101555,Limitation: torque-Engine torque limitation,159, Nm
IDE00544,Factor torque,Factor 0.5,
IDE00548-ENG101198,Converter clutch slip-Slip Speed LU,95.0, /min
IDE00820-ENG114742,Activating and deactivating all development messages-Activation of Development Messages,00,
IDE00972,Idle speed increase,OFF,
IDE02211,Brake pressure,0.00, bar
IDE02220-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,valid value,
IDE02713-ENG98471,Brake lamp switch-Brake Light Switch,OFF,
IDE02714,Brake test switch,OFF,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,CAN,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,keine_Ganganzeige,
IDE02820,Transmission mileage,49.6, km
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03008-ENG406262,Stop process prevented-Activation of basic setting,OFF,
IDE03008-ENG406266,Stop process prevented-All other reasons,OFF,
IDE03008-ENG406267,Stop process prevented-ATF condition is not fulfilled,OFF,
IDE03008-ENG406276,Stop process prevented-Dismantling,OFF,
IDE03008-ENG406279,Stop process prevented-Failure of pressure sensor,OFF,
IDE03008-ENG406286,Stop process prevented-In emergency mode,OFF,
IDE03008-ENG406287,Stop process prevented-In shifting,OFF,
IDE03008-ENG406248,Stop process prevented-switch off,OFF,
IDE03010-ENG162587,Number of prevented stop processes-Frequency_counter_Start_/_Stop_ prohibition,19,
IDE03152-ENG404039,Neutral due to driver registr. proced. cond.: cause-Soft-Shift lock,not activated,
IDE03171-ENG103012,Driving strategy transmission mileage-Total Driving Time2,N/A---
IDE03180-ENG103176,Number of standard trips-General Denominator,5,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,119,
IDE03212-ENG100620,Start/stop conditions-Start_/_Stop_conditions,Allow engine stop,
IDE03361-ENG130487,Driver intention torque-Driver Requested Torque,527, Nm
IDE05398-ENG130490,Transmission output speed: uncond voltage-Automatic transmission output speed raw voltage,9.0,
IDE05400-ENG102986,Hill factor driving strategy-DSP Mountain Index,4.7, %
IDE05401-ENG130491,Transmission input speed: uncond voltage-Automatic transmission input speed raw voltage,9.0,
IDE05403-ENG130492,Accelerator pedal idling-Accelerator Idle signal,Not operated,
IDE05668-ENG101751,Transmission control module torque request-TCM Requested Torque,1018, Nm
IDE06323-ENG404222,Status: switch valve S1/S2-Status Switch0valve S1/S2,SS-A & RD_SWI On/Off Solenoids on,
IDE06658-ENG99605,Pressure control valve 2: act. current-Actual current SLB1,10374, mA
IDE06659-ENG101258,Pressure control valve 3: act. current-Actual current SLC1,492, mA
IDE06660-ENG101181,Pressure control valve 3: spec. current-Order current SLC1,500, mA
IDE06661-ENG100294,Pressure control valve 2: spec. current-Order current SLB1,10375, mA
IDE06662-ENG100356,Pressure control valve 4: spec. current-Order current SLC2,1012, mA
IDE06663-ENG99880,Pressure control valve 4: act. current-Actual current SLC2,1008, mA
IDE06664-ENG99347,Pressure control valve 5: act. current-Actual current SLC3,8862, mA
IDE06665-ENG101266,Pressure control valve 5: spec. current-Order current SLC3,8866, mA
IDE06666-ENG101252,Pressure control valve 6: act. current-Actual current SLC4,492, mA
IDE06667-ENG103324,Pressure control valve 6: spec. current-Order current SLC4,500, mA
IDE06668-ENG103285,Pressure control valve 1: act. current-Actual current SLT,492, mA
IDE06669-ENG103245,Pressure control valve 1: spec. current-Order current SLT,500, mA
IDE06672-ENG406250,Current gear/clutch status-Actual gear,Unknown (72)
IDE06672-ENG406292,Current gear/clutch status-LU Mode,LockUp Off,
IDE06674-ENG102023,Driving strategy: rolling resistance-DSP Road Resistance,-0.3, %
IDE06675-ENG100839,Driving strategy: Sport Index-DSP Sport Index,0.000, %
IDE06676-ENG404095,Driving strategy: driving mode-DSP in D-Tip-mode,not activated,
IDE06676-ENG404260,Driving strategy: driving mode-DSP in Efficiency-mode,not activated,
IDE06676-ENG404081,Driving strategy: driving mode-DSP in S-mode,not activated,
IDE06676-ENG404244,Driving strategy: driving mode-DSP in Tip-mode,not activated,
IDE06677-ENG100939,Driving strategy: Sport Index Hybrid-DSP Sport Index Hybrid,0.000, %
IDE06875-ENG101762,Height-Altitude,0.99187, mbar
IDE06879-ENG103976,Software level supplier-ATCU software level,for series production,
IDE06880-ENG137172,Calc. transmission fluid temp.-Temp TC Lifetime Max Value,110, °C
IDE06881-ENG130493,Max. transmission fluid temperature over lifetime-ATF Temperature Lifetime Max Value,108, °C
IDE06884-ENG99385,Trans. fluid temp. sensor: voltage-ATF-Temperature Voltage,0.0, V
IDE06885-ENG102696,Torque converter: torque loss-Converter Loss Torque,7, Nm
IDE06893-ENG130489,Trans. thermal management request-DSP Fan control,heating,
IDE06894-ENG130495,Hot running progr. status-DSP Hotmode Status,not activated,
IDE06895-ENG130502,Level/hill recognition-DSP Plain/Mountains,1.0, %
IDE06896-ENG103489,Driving strategy: software version-DSP software level,for series production,
IDE06913-ENG102247,Trans. pilot control torque-Idle Speed Loss Torque,515, Nm
IDE06914-ENG99114,Unfiltered transmission input speed-Turbine Speed Signal Current Value,804.0, /min
IDE06916-ENG101593,Software_ID-Mot-File,HA82691225051,
IDE06919-ENG102285,Torque converter clutch: status-Lock Up Clutch Status,Clutch safely open without torque transfer,
IDE06920-ENG109457,Tiptronic: raw signal-Tiptronic,OFF,
IDE06921-ENG100848,Calculated vehicle speed-Vehicle Speed Sensor (Dev),0.00000, km/h
IDE07159-ENG159831,Control module switch-off: counter-Knockout_counter,0,
IDE14703-ENG102978,Pressure control valve for torque converter lock-up clutch: actual flow-Actual current SLU,504, mA
IDE14704-ENG101564,Pressure control valve for torque converter lock-up clutch: specified flow-Order current SLU,500, mA
IDE15108-MAS19447,OBD class-Versioning,01,
IDE15108-MAS21042,OBD class-SecondaryOBDECU,System is not SecondaryOBDECU,
IDE15108-MAS21048,OBD class-SecondaryOBDComponent,System is not SecondaryOBDComponent,
IDE15108-MAS21053,OBD class-PrimaryOBDECUnoMILMaster,System is PrimaryOBDECUnoMILMaster,
IDE15108-MAS21054,OBD class-PrimaryOBDECUMILMaster,System is not PrimaryOBDECUMILMaster,
IDE15108-MAS21055,OBD class-FullFunctionalCodeClear,FullFunctionalCodeClear is required,
IDE15781,VW Trustcenter Project ID,1077,
IDE16066-MAS01170,OBD class of the sub-bus users-Subsystem designation,Parking lock,
IDE16066-MAS21042,OBD class of the sub-bus users-SecondaryOBDECU,System is not SecondaryOBDECU,
IDE16066-MAS21048,OBD class of the sub-bus users-SecondaryOBDComponent,System is not SecondaryOBDComponent,
IDE16066-MAS21053,OBD class of the sub-bus users-PrimaryOBDECUnoMILMaster,System is not PrimaryOBDECUnoMILMaster,
IDE16066-MAS21054,OBD class of the sub-bus users-PrimaryOBDECUMILMaster,System is not PrimaryOBDECUMILMaster,
IDE16066-MAS21055,OBD class of the sub-bus users-FullFunctionalCodeClear,FullFunctionalCodeClear is not required,
IDE16066-ENG170217,OBD class of the sub-bus users-Number Of Expected SubSystem Identification,1,
IDE16066-ENG170218,OBD class of the sub-bus users-Number Of Retrieved SubSystem Identification,1,
IDE16066-ENG170221,OBD class of the sub-bus users-SubSystem Node Address,01 42,
IDE80020,Analysis 20,255,
IDE80021,Analysis 21,255,
IDE80022,Analysis 22,243,
IDE80023,Analysis 23,96,
IDE80024,Analysis 24,88,
IDE80025,Analysis 25,115,
IDE80026,Analysis 26,64,
IDE80027,Analysis 27,64,
IDE80028,Analysis 28,121,
IDE80029,Analysis 29,6,
IDE80030,Analysis 30,83,
IDE80031,Analysis 31,153,
IDE80032,Analysis 32,255,
IDE80033,Analysis 33,IUP Not Support,
IDE80034,Analysis 34,64,
IDE80035,Analysis 35,70,
IDE80036,Analysis 36,16393,
IDE80039,Analysis 39,N/A---
IDE80040,Analysis 40,N/A---
IDE80041,Analysis 41,N/A---
IDE80042,Analysis 42,N/A---
IDE80043,Analysis 43,N/A---
IDE80046,Analysis 46,N/A---
IDE80049,Analysis 49,0,
MAS12659-IDE00007,VW/Audi part numbers of sub-bus users-VW/Audi part number,5QS907483A ,
MAS12659-MAS01170,VW/Audi part numbers of sub-bus users-Subsystem designation,Parking lock,
MAS12659-ENG170217,VW/Audi part numbers of sub-bus users-Number Of Expected SubSystem Identification,2,
MAS12659-ENG170218,VW/Audi part numbers of sub-bus users-Number Of Retrieved SubSystem Identification,2,
MAS12659-ENG170221,VW/Audi part numbers of sub-bus users-SubSystem Node Address,01 42,
MAS12660-IDE00016,Hardware version number of sub-bus users-Hardware version,H03,
MAS12660-MAS01170,Hardware version number of sub-bus users-Subsystem designation,Parking lock,
MAS12660-ENG170217,Hardware version number of sub-bus users-Number Of Expected SubSystem Identification,2,
MAS12660-ENG170218,Hardware version number of sub-bus users-Number Of Retrieved SubSystem Identification,2,
MAS12660-ENG170221,Hardware version number of sub-bus users-SubSystem Node Address,01 42,
MAS12661-IDE00008,Software version number of sub-bus users-Software version,0060,
MAS12661-MAS01170,Software version number of sub-bus users-Subsystem designation,Parking lock,
MAS12661-ENG170217,Software version number of sub-bus users-Number Of Expected SubSystem Identification,2,
MAS12661-ENG170218,Software version number of sub-bus users-Number Of Retrieved SubSystem Identification,2,
MAS12661-ENG170221,Software version number of sub-bus users-SubSystem Node Address,01 42,
MAS12662-IDE00012,Hardware part number of sub-bus users-Hardware part number,5QS907483 ,
MAS12662-MAS01170,Hardware part number of sub-bus users-Subsystem designation,Parking lock,
MAS12662-ENG170217,Hardware part number of sub-bus users-Number Of Expected SubSystem Identification,2,
MAS12662-ENG170218,Hardware part number of sub-bus users-Number Of Retrieved SubSystem Identification,2,
MAS12662-ENG170221,Hardware part number of sub-bus users-SubSystem Node Address,01 42,
MAS12663-IDE00010,Series number of sub-bus users-Serial number,9923424600517006 ,
MAS12663-MAS01170,Series number of sub-bus users-Subsystem designation,Parking lock,
MAS12663-ENG170217,Series number of sub-bus users-Number Of Expected SubSystem Identification,2,
MAS12663-ENG170218,Series number of sub-bus users-Number Of Retrieved SubSystem Identification,2,
MAS12663-ENG170221,Series number of sub-bus users-SubSystem Node Address,01 42,
MAS12665-MAS00966,FAZIT identifications of sub-bus users-Manufacturer index location,787-796,
MAS12665-MAS00968,FAZIT identifications of sub-bus users-Day of manufacture,31.03.26,
MAS12665-MAS00969,FAZIT identifications of sub-bus users-Manufacturer- test stand number,0001,
MAS12665-MAS00970,FAZIT identifications of sub-bus users-Running manufacturer number,0346,
MAS12665-MAS01170,FAZIT identifications of sub-bus users-Subsystem designation,Parking lock,
MAS12665-ENG170217,FAZIT identifications of sub-bus users-Number Of Expected SubSystem Identification,2,
MAS12665-ENG170218,FAZIT identifications of sub-bus users-Number Of Retrieved SubSystem Identification,2,
MAS12665-ENG170221,FAZIT identifications of sub-bus users-SubSystem Node Address,01 42,
MAS12666-ENG299104,SubSystemNodeAddress of sub bus participant-SubSystem Node Addresses,|SubSystem Node Address,Subsystem designation|01 42
MAS12668-ENG299105,Actual installation of sub-bus users-SubSystems present,|SubSystem present Bit 0,SubSystem present Bit 1
MAS12669-ENG299103,Bus identification of sub-bus users-SubSystem Bus IDs,|Bus ID|17|216|,
MAS13422-IDE00013,System description of sub bus participant-System designation,SB_Auto ,
MAS13422-MAS01170,System description of sub bus participant-Subsystem designation,Parking lock,
MAS13422-ENG170217,System description of sub bus participant-Number Of Expected SubSystem Identification,2,
MAS13422-ENG170218,System description of sub bus participant-Number Of Retrieved SubSystem Identification,2,
MAS13422-ENG170221,System description of sub bus participant-SubSystem Node Address,01 42,
MAS14468,OBD type,OBD II,
ENG403979-ENG404229,Adaptive Values-Adaptation value (28B),0.06250, kgf/cm^2
ENG403979-ENG404256,Adaptive Values-Adaptation value (37R),0.06250, kgf/cm^2
ENG403979-ENG404138,Adaptive Values-Adaptation value (46C),0.06250, kgf/cm^2
ENG403979-ENG404233,Adaptive Values-Adaptation value (DC),0.500, %
ENG403979-ENG404142,Adaptive Values-Adaptation value (ODC),0.06250, kgf/cm^2
ENG403979-ENG404089,Adaptive Values-Adaptation value (UDC),0.06250, kgf/cm^2
ENG403979-ENG404118,Adaptive Values-Coasting Adaptation_{5}{2},0.500, %
ENG403979-ENG404182,Adaptive Values-Coasting Adaptation_{5}{3},0.500, %
ENG403979-ENG404227,Adaptive Values-Coasting Adaptation_{6}{2},0.500, %
ENG403979-ENG404208,Adaptive Values-Coasting Adaptation_{6}{3},0.500, %
ENG403979-ENG404078,Adaptive Values-Coasting Adaptation_{7}{2},0.500, %
ENG403979-ENG404145,Adaptive Values-Coasting Adaptation_{7}{3},0.500, %
ENG403979-ENG404223,Adaptive Values-Coasting-down (43R)_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404211,Adaptive Values-Coasting-down (43R)_{3}{2},0.06250, kgf/cm^2
ENG403979-ENG404248,Adaptive Values-Coasting-down (43R)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404154,Adaptive Values-Coasting-down (54R)_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404237,Adaptive Values-Coasting-down (54R)_{3}{2},0.06250, kgf/cm^2
ENG403979-ENG404198,Adaptive Values-Coasting-down (54R)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404150,Adaptive Values-Coasting-down (65R)_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404183,Adaptive Values-Coasting-down (65R)_{3}{2},0.06250, kgf/cm^2
ENG403979-ENG404144,Adaptive Values-Coasting-down (65R)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404181,Adaptive Values-Coasting-down (76R)_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404086,Adaptive Values-Coasting-down (76R)_{3}{2},0.06250, kgf/cm^2
ENG403979-ENG404258,Adaptive Values-Coasting-down (76R)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404074,Adaptive Values-Coasting-down (87R)_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404111,Adaptive Values-Coasting-down (87R)_{3}{2},0.06250, kgf/cm^2
ENG403979-ENG404116,Adaptive Values-Coasting-down (87R)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404195,Adaptive Values-Kick-down (32Z)_{0}{2},0.06250, kgf/cm^2
ENG403979-ENG404201,Adaptive Values-Kick-down (32Z)_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404241,Adaptive Values-Kick-down (32Z)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404212,Adaptive Values-Kick-down (43Z)_{0}{2},0.06250, kgf/cm^2
ENG403979-ENG404094,Adaptive Values-Kick-down (43Z)_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404228,Adaptive Values-Kick-down (43Z)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404243,Adaptive Values-Kick-down (54Z)_{0}{2},0.06250, kgf/cm^2
ENG403979-ENG404168,Adaptive Values-Kick-down (54Z)_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404091,Adaptive Values-Kick-down (54Z)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404079,Adaptive Values-Kick-down (65Z)_{0}{2},0.06250, kgf/cm^2
ENG403979-ENG404175,Adaptive Values-Kick-down (65Z)_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404173,Adaptive Values-Kick-down (65Z)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404102,Adaptive Values-Kick-down (76Z)_{0}{2},0.06250, kgf/cm^2
ENG403979-ENG404075,Adaptive Values-Kick-down (76Z)_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404082,Adaptive Values-Kick-down (76Z)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404218,Adaptive Values-Kick-down (87Z)_{0}{2},0.06250, kgf/cm^2
ENG403979-ENG404176,Adaptive Values-Kick-down (87Z)_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404225,Adaptive Values-Kick-down (87Z)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404290,Adaptive Values-Power-on Upshift (12Z)_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404152,Adaptive Values-Power-on Upshift (12Z)_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404269,Adaptive Values-Power-on Upshift (12Z)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404133,Adaptive Values-Power-on Upshift (23Z)_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404203,Adaptive Values-Power-on Upshift (23Z)_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404080,Adaptive Values-Power-on Upshift (23Z)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404285,Adaptive Values-Power-on Upshift (34Z)_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404157,Adaptive Values-Power-on Upshift (34Z)_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404096,Adaptive Values-Power-on Upshift (34Z)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404153,Adaptive Values-Power-on Upshift (45Z)_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404224,Adaptive Values-Power-on Upshift (45Z)_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404292,Adaptive Values-Power-on Upshift (45Z)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404162,Adaptive Values-Power-on Upshift (56Z)_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404265,Adaptive Values-Power-on Upshift (56Z)_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404143,Adaptive Values-Power-on Upshift (56Z)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404141,Adaptive Values-Power-on Upshift (67Z)_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404283,Adaptive Values-Power-on Upshift (67Z)_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404207,Adaptive Values-Power-on Upshift (67Z)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404206,Adaptive Values-Power-on Upshift (78Z)_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404097,Adaptive Values-Power-on Upshift (78Z)_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404159,Adaptive Values-Power-on Upshift (78Z)_{4}{2},0.06250, kgf/cm^2
ENG403979-ENG404158,Adaptive Values-Static ND1_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404100,Adaptive Values-Static ND1_{2}{2},0.06250, kgf/cm^2
ENG403979-ENG404226,Adaptive Values-Static NR_{1}{2},0.06250, kgf/cm^2
ENG403979-ENG404167,Adaptive Values-Static NR_{2}{2},0.06250, kgf/cm^2
ENG125778,EMOP Demand Duty %,0, /min
ENG125927-ENG125781,EMOP_Feedback_ON OFF-EMOP Feedback ON/OFF,0, /min
ENG403986,Event logging,65 4B 62 49 69 4E 68 50 6E 4C 6E 47 63 41 68 4A 6B 4E 67 43 68 41 66 4C 6A 41 67 42 63 50 66 4C 6E 44 6D 41 61 49 66 4C 62 49 66 43 67 4C 6E 4D 62 48 6F 44 6F 4C 6A 45 6E 47 67 41 6F 50 6C 4C 6A 4F 63 4C 63 4F 64 46 64 4E 6C 4E 6C 4C 6B 46 67 46 64 49 69 43 68 4E 68 44 70 47 69 48 6A 4D 61 49 6E 4F 6B 45 69 4C 67 47 65 4B 6C 49 6E 45 66 4F 65 45 6A 50 65 47 65 44 65 41 69 4A 63 46 6D 48 64 42 68 41 6F 50 66 41 6B 4A 65 4E 6A 4D 64 4B 62 46 63 49 63 4D 6A 4D 66 4F 64 4D 70 49 6A 4F 61 44 61 4C 6C 46 69 46 61 50 6D 4C 66 4E 63 4A 63 4B 6D 4E 69 43 6D 46 6C 50 65 42 6F 45 64 50 67 49 63 42 68 4D 70 45 70 41 66 50 62 50 67 4C 6E 4E 6A 46 61 4A 6E 44 6C 45 6C 46 67 42 69 45 70 48 63 4D 69 44 66 4C 64 4F 67 4F 65 44 63 44 64 46 6F 47 68 48 64 41 67 46 63 42 64 4D 66 46 61 42 68 4D 6A 4A 61 47 6E 4F 6A 48 64 43 63 4D 63 4D 69 48 6B 42 64 4A 6A 41 6B 4B 65 4B 6D 41 66 4E 62 48 6B 4A 69 49 70 4C 65 46 6F 48 61 4D 67 4E 65 44 65 41 70 4F 6C 4F 62 4E 67 4F 66 4B 6B 50 63 47 6B 41 6C 44 62 47 64 4C 64 4D 68 43 67 47 69 46 62 50 68 41 61 4B 68 47 62 42 6D 43 6F 4C 6A 4E 68 4A 61 4F 65 42 62 4A 6F 50 65 4C 61 41 6F 4B 6A 46 6D 4E 70 4A 63 43 6F 41 66 47 67 4C 63 44 63 42 62 49 6C 45 6E 48 66 48 6F 41 6D 43 65 47 69 4C 6E 44 62 49 64 42 6B 47 6A 47 6F 46 6C 47 69 48 6E 4C 70 4F 66 4C 66 4F 62 4F 6F 47 6B 48 69 4C 6D 4A 62 42 70 4B 63 42 67 4D 6D 43 6F 4A 69 4C 69 50 68 47 69 4D 62 4B 70 4D 65 45 68 50 6E 4C 69 46 61 42 66 47 6C 48 70 43 61 45 63 4C 6F 50 6E 49 6F 43 68 47 63 47 6B 44 6A 4D 6E 4D 62 46 62 48 6E 50 6C 4F 6B 4A 61 42 6B 50,
ENG264435-MAS19447,In_use_monitor_performance_ratio-Versioning,01,
ENG264435-ENG101817,In_use_monitor_performance_ratio-Denominator,5,
ENG264435-ENG103772,In_use_monitor_performance_ratio-DFCC Value,41937,
ENG264435-ENG103176,In_use_monitor_performance_ratio-General Denominator,5,
ENG264435-ENG102823,In_use_monitor_performance_ratio-Ignition Cycle Counter,119,
ENG264435-ENG100120,In_use_monitor_performance_ratio-Milage,4960, km
ENG264435-ENG102846,In_use_monitor_performance_ratio-Number of IUMPR Records,24,
ENG264435-ENG99150,In_use_monitor_performance_ratio-Numerator,41,
ENG404011,Silent alarm,69 44 62 4F 69 47 6B 42 66 4B 6A 45 6F 4E 63 4A 68 49 62 43 61 46 6D 4C 6F 42 6A 4C 70 48 6E 44 6C 50 6C 44 6A 4B 6F 44 6D 4D 6E 45 6C 4F 65 42 61 4B 67 4C 6B 4C 62 44 6C 45 70 44 6E 47 70 46 6E 4A 64 4D 6F 44 6C 45 6F 49 61 46 6E 50 61 42 70 4F 65 50 69 4C 64 4A 68 46 68 43 70 44 6E 44 6C 46 6C 42 6B 4C 66 44 6E 4C 61 4F 63 4E 65 4F 6C 4F 67 46 6A 47 6B 4C 66 41 61 4B 62 46 6C 4F 62 48 62 48 64 46 64 4B 66 4B 70 4F 6A 49 6C 49 68 4B 66 47 65 4B 70 50 63 41 64 4D 66 4E 62 44 6C 4F 61 47 6B 4C 6A 4F 69 4E 62 42 68 44 69 4C 6C 48 64 41 6E 4A 6D 48 65 43 70 49 63 48 6C 49 6D 43 67 49 64 46 6A 4F 69 4C 6D 4D 6D 49 6A 41 62 49 69 4A 68 4A 64 49 69 4E 66 42 67 49 66 4D 69 4B 6E 49 67 42 6A 4B 66 45 69 42 70 4A 62 42 66 42 68 49 6C 50 70 4A 6D 4F 65 4C 6A 48 67 50 6C 46 61 46 6B 41 6A 4E 6F 50 66 47 66 4B 66 49 62 42 67 46 67 4C 6F 45 66 44 65 49 70 4C 61 46 62 4E 62 44 6B 4F 69 4C 6F 4D 6D 43 62 48 69 4C 6A 4A 70 50 6E 43 65 45 61 47 6D 4E 64 48 6F 4C 65 45 68 44 6D 4A 6E 4D 65 41 6A 48 6B 50 6E 42 65 46 63 45 6D 50 6C 48 64 50 61 4F 62 48 70 4A 6F 48 61 45 61 4A 6C 48 6E 4F 6A 46 6E 4D 6A 41 61 45 6F 47 6D 4B 63 41 6A 42 6B 48 6B 46 6C 50 6F 41 6C 45 70 46 62 48 69 41 64 43 6F 46 66 44 69 41 61 41 6F 47 6C 4D 64 4E 6F 4E 67 41 68 44 69 4A 65 4C 6B 44 68 43 6E 4E 63 4D 67 4D 6C 4C 67 50 66 4F 6C 4B 70 43 61 49 6B 4E 69 50 66 47 68 47 6E 4E 6D 42 6C 48 70 4C 67 4D 67 46 63 50 66 46 6E 4E 64 49 67 4E 70 4A 6F 4B 64 4B 68 50 6D 4C 6F 46 68 4B 63 4F 61 50 6F 48 64 4A 69 4A 70 4A 6B 44 66 4A 65 41 62 4C 65 44 6D 4A 6F 42 61 42 6B 50,
ENG404012,StartStop Enable Conditions,1,
ENG432336-ENG432595,Status of present IPA messages-IPA 01 message available,activated,
ENG432336-ENG434239,Status of present IPA messages-IPA 02 message available,activated,
ENG432336-ENG433992,Status of present IPA messages-Parken 01 message available,activated,
ENG404014,Switch Over Challenge,9A D6 55 B9 67 1F 27 69 DA 28 C3 62 03 0B 86 77 1C 18 01 A8 7C 05 80 7D 14 8A D1 35 FA 5E 2E 89 00 00,
ENG404015,Switch Over Status,production,
ENG99034,Voltage terminal 15,13.3, V
ENG99035,Voltage terminal 30,14.4, V
Elapsed Time: 00:26
;SW:3WA-614-517-AS HW:3WA-614-517-D --- 03: ABS Brakes
;Component:EBC470IESCH09 0391, Coding:2C985248A25D3A9E600799BC9E0501040593752353B0
;EV_Brake1ZFESCEPBMQB48W,002059,EV_Brake1ZFESCEPBMQB48W_002.rod
;Wednesday,30,September,2026,11:58:35:11564
;VCID: 176394311F0F76723AB-8042-R SFD+SFD2 {x}
IDE00019,Voltage terminal 30,14.65, V
IDE00021,Engine speed,901.00, /min
IDE00025,Coolant temperature,79, °C
IDE00085,Normed load value,21.57, %
IDE00086,Accelerator pedal position,14.12, %
IDE00602-ENG161054,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_continous_diagnostics,00000100 ,
IDE00602-ENG161055,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_non_continous_diagnostics,00000000 ,
IDE00602-ENG161141,Monitoring status in current driving cycle-Readiness_Code,00000000 ,
IDE02270-IDE00925,CAN input signal(s) status-Yaw rate,0.00, °/s
IDE02270-IDE01267,CAN input signal(s) status-Height correction,0.99,
IDE02270-IDE02492,CAN input signal(s) status-Start/Stop Function: coding information,installed,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-IDE03451,CAN input signal(s) status-Transverse acceleration,0.00, m/s²
IDE02270-IDE03660,CAN input signal(s) status-Longitudinal acceleration,0.15, m/s²
IDE02270-IDE04457,CAN input signal(s) status-Speed of electric drive motor,Initialization/not installed,
IDE02270-IDE04703,CAN input signal(s) status-Tire circumference,2202, mm
IDE02270-IDE05726,CAN input signal(s) status-Dimmer terminal 58xd,253,
IDE02270-IDE08586,CAN input signal(s) status-Status: electromechanical power brake,ready,
IDE02270-MAS00218,CAN input signal(s) status-Driver´s door,Driver's door open,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,Not operated,
IDE02270-MAS00371,CAN input signal(s) status-Engine speed,899.00, /min
IDE02270-MAS00373,CAN input signal(s) status-Accelerator pedal position,0.00, %
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamps,OFF,
IDE02270-MAS01619,CAN input signal(s) status-Fuel type,Petrol,
IDE02270-MAS02289,CAN input signal(s) status-Outside temperature,32.50, °
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,3VVUW7RM1TM130726,
IDE02270-MAS02666,CAN input signal(s) status-Seat belt buckle scan,not connected,
IDE02270-MAS04004,CAN input signal(s) status-Transmission code,aq_450,
IDE02270-MAS04188,CAN input signal(s) status-Transport mode,not active,
IDE02270-MAS06429,CAN input signal(s) status-Transport protection,not active,
IDE02270-MAS07469,CAN input signal(s) status-Target gear,park position,
IDE02270-MAS15790,CAN input signal(s) status-Setting for clear error memory,locked,
IDE02270-MAS17574,CAN input signal(s) status-Pitch rate,0.00, °/s
IDE02270-MAS17575,CAN input signal(s) status-Roll rate,-0.06, °/s
IDE02270-MAS18095,CAN input signal(s) status-Output rod,-1.17, mm
IDE02270-MAS25020,CAN input signal(s) status-Presence detection: status,Non-safe presence detection,
IDE02270-ENG379013,CAN input signal(s) status-acceleration_vertical_a_z,9.83, m/s²
IDE02270-ENG378751,CAN input signal(s) status-confidence_factor_acceleration_lateral,valid value,
IDE02270-ENG378701,CAN input signal(s) status-confidence_factor_acceleration_longitudinal,valid value,
IDE02270-ENG378886,CAN input signal(s) status-confidence_factor_acceleration_vertical,valid value,
IDE02270-ENG381284,CAN input signal(s) status-confidence_factor_pitch_rate,not installed,
IDE02270-ENG379024,CAN input signal(s) status-confidence_factor_roll_rate,valid value,
IDE02270-ENG378769,CAN input signal(s) status-confidence_factor_yaw_rate,valid value,
IDE02270-ENG99862,CAN input signal(s) status-Reserved 2,
IDE02270-ENG379371,CAN input signal(s) status-Rotation_angle_front_left,Malfunction,
IDE02270-ENG378785,CAN input signal(s) status-Rotation_angle_front_right,Malfunction,
IDE02270-ENG379394,CAN input signal(s) status-Rotation_angle_rear_left,Malfunction,
IDE02270-ENG380348,CAN input signal(s) status-Rotation_angle_rear_right,Malfunction,
IDE02271-IDE02070,CAN output signal(s) status-Wake-up cause,Bus communication,
IDE03008-IDE05181,Stop process prevented-Emerg.braking,not active,
IDE03008-MAS01299,Stop process prevented-Offroad,not active,
IDE03008-MAS01478,Stop process prevented-insufficient voltage,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.00, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,255,
IDE04425-IDE04436,Left front ABS wheel speed sensor-Minimum division value,Steady driving: calculation in process,
IDE04425-IDE04437,Left front ABS wheel speed sensor-Maximum division value,Steady driving: calculation in process,
IDE04425-IDE04438,Left front ABS wheel speed sensor-Average division value,Steady driving: calculation in process,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,forward,
IDE04425-MAS09580,Left front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.00, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,255,
IDE04426-IDE04436,Right front ABS wheel speed sensor-Minimum division value,Steady driving: calculation in process,
IDE04426-IDE04437,Right front ABS wheel speed sensor-Maximum division value,Steady driving: calculation in process,
IDE04426-IDE04438,Right front ABS wheel speed sensor-Average division value,Steady driving: calculation in process,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,forward,
IDE04426-MAS09580,Right front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.00, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,255,
IDE04427-IDE04436,Left rear ABS wheel speed sensor-Minimum division value,Steady driving: calculation in process,
IDE04427-IDE04437,Left rear ABS wheel speed sensor-Maximum division value,Steady driving: calculation in process,
IDE04427-IDE04438,Left rear ABS wheel speed sensor-Average division value,Steady driving: calculation in process,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04427-MAS09580,Left rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.00, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,255,
IDE04428-IDE04436,Right rear ABS wheel speed sensor-Minimum division value,Steady driving: calculation in process,
IDE04428-IDE04437,Right rear ABS wheel speed sensor-Maximum division value,Steady driving: calculation in process,
IDE04428-IDE04438,Right rear ABS wheel speed sensor-Average division value,Steady driving: calculation in process,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-MAS09580,Right rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE10300,OBD Driving Cycle detected,active,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,5,
IDE14227-IDE02955,modular vehicle dynamic controller-System status,Available,
IDE14227-MAS18086,modular vehicle dynamic controller-Dynamic Chassis Control function status,mFDR_active_DCC_not_configured,
IDE14227-ENG370771,modular vehicle dynamic controller-mFDR_FPA_value_actual,4,
IDE14227-ENG370772,modular vehicle dynamic controller-mFDR_FPA_value_nominal,4,
IDE14329-MAS19447,IUMPR data-Versioning,01,
IDE14329-ENG101817,IUMPR data-Denominator,65535,
IDE14329-ENG103772,IUMPR data-DFCC Value,16777215,
IDE14329-ENG310665,IUMPR data-Distance_IUMPR,4960, km
IDE14329-ENG106773,IUMPR data-General_Denominator,6,
IDE14329-ENG106916,IUMPR data-Ignition_Cycle_Counter,119,
IDE14329-ENG310655,IUMPR data-Number_of_IUMPR_single_ratios,0,
IDE14329-ENG99150,IUMPR data-Numerator,65535,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,1,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 0E,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 65 F0 A7 B9 49 1F 55,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,3,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 0E,
IDE14623,Commutation test status,not active,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Available,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.00, Nm
MAS02138-IDE02955,Hill-start assistant-System status,Available,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver´s door,Open,
MAS02138-MAS03095,Hill-start assistant-Function status,not active,
MAS26780-MAS26781,Distance safety-Total of average distance pulses from rear wheels,00 01 28 0B 8E,
ENG99697-ENG110852,Calibration Verification Numbers-Calibration Verification Number,8C E3 60 00,
ENG99697-ENG420209,Calibration Verification Numbers-Calibration Verification Number Secondary,00 00 00 00,
ENG99697-ENG274086,Calibration Verification Numbers-Number of Data Items,44,
ENG377741,development_measurement_values_100,|Internal_error_code,km-Mileage
ENG100152,ECUNAME,SCM-BrakeSystem,
ENG100152-ENG274086,ECUNAME-Number of Data Items,66,
ENG264447-ENG135743,Entwicklermesswert_11-Left_Brake_Full_Clamping_Force,17500,
ENG264447-ENG135741,Entwicklermesswert_11-Right_Brake_Full_Clamping_Force,17500,
ENG264448,Entwicklermesswert_12,ÿº1,
Elapsed Time: 00:17
;SW:5WA-959-436-AD HW:5WA-959-436-N --- 05: Acc/Start Auth.
;Component:Kessy IOBOX 122 0771, Coding:
;EV_Kessy37w,005030,EV_Kessy37w_005_VW38.rod
;Wednesday,30,September,2026,11:58:58:11564
;VCID: 167D993518054F7A21D-8042-R
IDE00019,Voltage terminal 30,14.506, V
IDE02413,Door handle touch sensor: last operation,Driver´s door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,263,
IDE02419,Proximity sensor frt.pass. door: number of triggers,115,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,33,
IDE02422-MAS01483,Driver door handle: version information-Software version,49,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,36,
IDE02422,Driver door handle: version information,19 00 19 13 2C,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,33,
IDE02423-MAS01483,ass. door handle: version information-Software version,49,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,36,
IDE02423,ass. door handle: version information,19 00 18 7D D4,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,0,
IDE02424-MAS01483,Left rear door handle: version information-Software version,0,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,0,
IDE02424,Left rear door handle: version information,00 00 00 00 00,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,0,
IDE02425-MAS01483,Right rear door handle: version information-Software version,0,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,0,
IDE02425,Right rear door handle: version information,00 00 00 00 00,
IDE02466,Play protection activation counter driver door,0,
IDE02466,Play protection activation counter driver door,not active,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02467,Play protection activation counter frt.pass. door,not active,
IDE02468,Play protection activation counter left rear door,0,
IDE02468,Play protection activation counter left rear door,not active,
IDE02469,Play protection activation counter right rear door,not active,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72h-Signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02486,Data logger triggering,not initialized,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,14.5, V
IDE07359,Dimming of starter button lighting,8966,
IDE14837-MAS19401,Outer door handle switch: status-Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19402,Outer door handle switch: status-Front Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19403,Outer door handle switch: status-Rear Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19404,Outer door handle switch: status-Rear Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19612,Outer door handle switch: status-Rear Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19613,Outer door handle switch: status-Tank Exterior Door Handle Switch: status,Not operated,
IDE14924-MAS00218,Status of release conditions Passive Entry-Driver´s door,not enabled,
IDE14924-MAS00219,Status of release conditions Passive Entry-Passenger´s door,not enabled,
IDE14924-MAS00220,Status of release conditions Passive Entry-Rear left door,not enabled,
IDE14924-MAS00221,Status of release conditions Passive Entry-Rear right door,not enabled,
IDE14924-MAS19581,Status of release conditions Passive Entry-Rear,not enabled,
IDE14924-MAS19611,Status of release conditions Passive Entry-Tank,not enabled,
IDE14925-MAS00218,Status of release conditions Passive Exit-Driver´s door,not enabled,
IDE14925-MAS00219,Status of release conditions Passive Exit-Passenger´s door,Enabled,
IDE14925-MAS00220,Status of release conditions Passive Exit-Rear left door,not enabled,
IDE14925-MAS00221,Status of release conditions Passive Exit-Rear right door,not enabled,
IDE14925-MAS19581,Status of release conditions Passive Exit-Rear,not enabled,
IDE14925-MAS19611,Status of release conditions Passive Exit-Tank,not enabled,
IDE14926,Status of release conditions for key search,Key search: release activated,
IDE14927-MAS19605,History of range limiter for automatic functions-Reduction level,|Level_of_reduction,Year
IDE14928-MAS00080,Sensor for control section-Coding information,Not coded,
IDE14928-MAS02176,Sensor for control section-Approach to the inside,not active,
IDE14928-MAS02177,Sensor for control section-Actuation to the inside,not active,
IDE14928-MAS02178,Sensor for control section-Approach to the outside,not active,
IDE14928-MAS02179,Sensor for control section-Actuation to the outside,not active,
IDE14928-MAS02451,Sensor for control section-Pulling actuation: outside door handle,not active,
IDE14929-MAS00080,Sensor for fuel filler flap control section-Coding information,Not coded,
IDE14929-MAS02176,Sensor for fuel filler flap control section-Approach to the inside,not active,
IDE14929-MAS02177,Sensor for fuel filler flap control section-Actuation to the inside,not active,
IDE14929-MAS02178,Sensor for fuel filler flap control section-Approach to the outside,not active,
IDE14929-MAS02179,Sensor for fuel filler flap control section-Actuation to the outside,not active,
IDE14929-MAS02451,Sensor for fuel filler flap control section-Pulling actuation: outside door handle,not active,
IDE14930,Sensor fuel filler flap control section: number of triggers,0,
IDE14931,Sensor control section trunk: number of triggers,0,
IDE14932,Fuel filler flap control section: play protection,0,
IDE14932,Fuel filler flap control section: play protection,not active,
IDE14933,Trunk control section: play protection counter,0,
IDE14933,Trunk control section: play protection counter,not active,
IDE14934-MAS01482,Trunk control section: version information-Hardware version,0,
IDE14934-MAS01483,Trunk control section: version information-Software version,0,
IDE14934-MAS04065,Trunk control section: version information-EEPROM,0,
IDE14934,Trunk control section: version information,00 00 00 00 00,
IDE14935-MAS01482,Fuel filler cap control section: version information-Hardware version,0,
IDE14935-MAS01483,Fuel filler cap control section: version information-Software version,0,
IDE14935-MAS04065,Fuel filler cap control section: version information-EEPROM,0,
IDE14935,Fuel filler cap control section: version information,00 00 00 00 00,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,Software_Request_Flashbootloader,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,Power_On_Reset,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,Power_On_Reset,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,Power_On_Reset,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,Power_On_Reset,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,Power_On_Reset,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,Power_On_Reset,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,Power_On_Reset,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,Power_On_Reset,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,Software_Request_Flashbootloader,
ENG254757-MAS00106,Lf_antenna_eight_detune_counter-Year,2000,
ENG254757-MAS00107,Lf_antenna_eight_detune_counter-Month,0,
ENG254757-MAS00108,Lf_antenna_eight_detune_counter-Day,0,
ENG254757-MAS00109,Lf_antenna_eight_detune_counter-Hours,0,
ENG254757-MAS00110,Lf_antenna_eight_detune_counter-Minutes,0,
ENG254757-MAS00111,Lf_antenna_eight_detune_counter-Seconds,0,
ENG254757-ENG255615,Lf_antenna_eight_detune_counter-Detune_counter,0,
ENG254758-MAS00106,Lf_antenna_five_detune_counter-Year,2000,
ENG254758-MAS00107,Lf_antenna_five_detune_counter-Month,0,
ENG254758-MAS00108,Lf_antenna_five_detune_counter-Day,0,
ENG254758-MAS00109,Lf_antenna_five_detune_counter-Hours,0,
ENG254758-MAS00110,Lf_antenna_five_detune_counter-Minutes,0,
ENG254758-MAS00111,Lf_antenna_five_detune_counter-Seconds,0,
ENG254758-ENG255615,Lf_antenna_five_detune_counter-Detune_counter,0,
ENG254759-MAS00106,Lf_antenna_four_detune_counter-Year,2000,
ENG254759-MAS00107,Lf_antenna_four_detune_counter-Month,0,
ENG254759-MAS00108,Lf_antenna_four_detune_counter-Day,0,
ENG254759-MAS00109,Lf_antenna_four_detune_counter-Hours,0,
ENG254759-MAS00110,Lf_antenna_four_detune_counter-Minutes,0,
ENG254759-MAS00111,Lf_antenna_four_detune_counter-Seconds,0,
ENG254759-ENG255615,Lf_antenna_four_detune_counter-Detune_counter,0,
ENG254760-MAS00106,Lf_antenna_one_detune_counter-Year,2000,
ENG254760-MAS00107,Lf_antenna_one_detune_counter-Month,0,
ENG254760-MAS00108,Lf_antenna_one_detune_counter-Day,0,
ENG254760-MAS00109,Lf_antenna_one_detune_counter-Hours,0,
ENG254760-MAS00110,Lf_antenna_one_detune_counter-Minutes,0,
ENG254760-MAS00111,Lf_antenna_one_detune_counter-Seconds,0,
ENG254760-ENG255615,Lf_antenna_one_detune_counter-Detune_counter,0,
ENG254761-MAS00106,Lf_antenna_seven_detune_counter-Year,2000,
ENG254761-MAS00107,Lf_antenna_seven_detune_counter-Month,0,
ENG254761-MAS00108,Lf_antenna_seven_detune_counter-Day,0,
ENG254761-MAS00109,Lf_antenna_seven_detune_counter-Hours,0,
ENG254761-MAS00110,Lf_antenna_seven_detune_counter-Minutes,0,
ENG254761-MAS00111,Lf_antenna_seven_detune_counter-Seconds,0,
ENG254761-ENG255615,Lf_antenna_seven_detune_counter-Detune_counter,0,
ENG254762-MAS00106,Lf_antenna_six_detune_counter-Year,2000,
ENG254762-MAS00107,Lf_antenna_six_detune_counter-Month,0,
ENG254762-MAS00108,Lf_antenna_six_detune_counter-Day,0,
ENG254762-MAS00109,Lf_antenna_six_detune_counter-Hours,0,
ENG254762-MAS00110,Lf_antenna_six_detune_counter-Minutes,0,
ENG254762-MAS00111,Lf_antenna_six_detune_counter-Seconds,0,
ENG254762-ENG255615,Lf_antenna_six_detune_counter-Detune_counter,0,
ENG254763-MAS00106,Lf_antenna_three_detune_counter-Year,2000,
ENG254763-MAS00107,Lf_antenna_three_detune_counter-Month,0,
ENG254763-MAS00108,Lf_antenna_three_detune_counter-Day,0,
ENG254763-MAS00109,Lf_antenna_three_detune_counter-Hours,0,
ENG254763-MAS00110,Lf_antenna_three_detune_counter-Minutes,0,
ENG254763-MAS00111,Lf_antenna_three_detune_counter-Seconds,0,
ENG254763-ENG255615,Lf_antenna_three_detune_counter-Detune_counter,0,
ENG254764-MAS00106,Lf_antenna_two_detune_counter-Year,2000,
ENG254764-MAS00107,Lf_antenna_two_detune_counter-Month,0,
ENG254764-MAS00108,Lf_antenna_two_detune_counter-Day,0,
ENG254764-MAS00109,Lf_antenna_two_detune_counter-Hours,0,
ENG254764-MAS00110,Lf_antenna_two_detune_counter-Minutes,0,
ENG254764-MAS00111,Lf_antenna_two_detune_counter-Seconds,0,
ENG254764-ENG255615,Lf_antenna_two_detune_counter-Detune_counter,0,
ENG254789-MAS00106,Over_temperature_counter_lf_driver-Year,2000,
ENG254789-MAS00107,Over_temperature_counter_lf_driver-Month,0,
ENG254789-MAS00108,Over_temperature_counter_lf_driver-Day,0,
ENG254789-MAS00109,Over_temperature_counter_lf_driver-Hours,0,
ENG254789-MAS00110,Over_temperature_counter_lf_driver-Minutes,0,
ENG254789-MAS00111,Over_temperature_counter_lf_driver-Seconds,0,
ENG254789-MAS27962,Over_temperature_counter_lf_driver-Excessive temperature counter for Kessy OK box,0, counts
ENG108452,Reset_counter,11,
ENG108925-ENG103300,Service_Key_Data_Current_Page-Service_Data,00 0B 00 00 00 00 00 01 01 01 FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF,
ENG108926-ENG103300,Service_Key_Data_Previous_Page-Service_Data,00 0B 00 00 00 00 00 01 01 01 FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF,
ENG119884-ENG119837,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_0,0, d
ENG119884-ENG119867,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_1,1, d
ENG119884-ENG119868,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_2,31, d
ENG119884-ENG119866,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_3,31, d
ENG119884-ENG119870,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_0,0,
ENG119884-ENG119836,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_1,8,
ENG119884-ENG119850,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_2,15,
ENG119884-ENG119851,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_3,7,
ENG119884-ENG119869,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_0,2000,
ENG119884-ENG119835,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_1,2000,
ENG119884-ENG119845,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_2,2127,
ENG119884-ENG119846,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_3,2000,
ENG119884-ENG119834,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_0,2816, km
ENG119884-ENG119839,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_1,1, km
ENG119884-ENG119840,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_2,16776960, km
ENG119884-ENG119841,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_3,16777215, km
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG161255,Service_Key_Pointer-Write_Pointer_Adr_160,Write_Pointer_Adr,
ENG108929-ENG161256,Service_Key_Pointer-Write_Pointer_Adr_184,Write_Pointer_Adr,
ENG108929-ENG161257,Service_Key_Pointer-Write_Pointer_Adr_208,Write_Pointer_Adr,
ENG254855,WUP_measurement_historie,|Learned wake pattern,Mileage|932609940
Elapsed Time: 00:07
;SW:5QS-959-760-H HW:5QS-959-760-H --- 06: Seat Mem. Pass
;Component:MEM-BFS 011 0372, Coding:0118BA4000013A008803010121010000000000000000000000000000211000
;EV_SCMPasseSideCONTIAU736,006013,EV_SCMPasseSideCONTIAU736_VWF3.rod
;Wednesday,30,September,2026,11:59:12:11564
;VCID: 659FEEF995E314E2787-8030-R
IDE00019-MAS00043,Voltage terminal 30-Terminal 30 power supply,14.50, V
IDE00102,Control Module temperature,45,
IDE00787,Cause for cancellation,none,
IDE01277-IDE09268,Counter of compressor activations-Switch on occurrences of compressor,0, counts
IDE01277-MAS06166,Counter of compressor activations-Current operation time,0, s
IDE01457,Energy management: shut-off stage,Deactivation stage 0,
IDE05738-MAS12801,Subssystem diagnosis classes-DK0 systems supported,DK0 systems not supported,
IDE05738-MAS12803,Subssystem diagnosis classes-DK1 systems supported,DK1 systems not supported,
IDE05738-MAS12805,Subssystem diagnosis classes-DK2/DK2F systems supported,DK2/DK2F systems not supported,
IDE05738-MAS12807,Subssystem diagnosis classes-DK3 or DK4 high/low systems supported,DK3 or DK4 high/low systems not supported,
IDE06510-MAS01390,Adjustment for backrest angle-Block 1,34017,
IDE06510-MAS01391,Adjustment for backrest angle-Block 2,32434,
IDE06510-MAS02282,Adjustment for backrest angle-Position,32889,
IDE06510-MAS02955,Adjustment for backrest angle-Engine temperature,25, °C
IDE06510-MAS03129,Adjustment for backrest angle-Reset counter,13,
IDE06510-MAS04160,Adjustment for backrest angle-Load change,15,
IDE06510-MAS04337,Adjustment for backrest angle-Engine current,0, A
IDE06510-MAS05370,Adjustment for backrest angle-Direction of movement,Not operated,
IDE06510-MAS05563,Adjustment for backrest angle-Standardization,standardized,
IDE06510-MAS05719,Adjustment for backrest angle-Maximum travel,1583,
IDE06510-MAS12838,Adjustment for backrest angle-Standardization flag,standardized,
IDE06511-MAS01390,Seat height adjustment-Block 1,33244,
IDE06511-MAS01391,Seat height adjustment-Block 2,32756,
IDE06511-MAS02282,Seat height adjustment-Position,33116,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,25, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,7,
IDE06511-MAS04160,Seat height adjustment-Load change,10,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, A
IDE06511-MAS05370,Seat height adjustment-Direction of movement,Not operated,
IDE06511-MAS05563,Seat height adjustment-Standardization,standardized,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,488,
IDE06511-MAS12838,Seat height adjustment-Standardization flag,standardized,
IDE06512-MAS01390,Adjustment for seat forward/back position-Block 1,33117,
IDE06512-MAS01391,Adjustment for seat forward/back position-Block 2,32653,
IDE06512-MAS02282,Adjustment for seat forward/back position-Position,32940,
IDE06512-MAS02955,Adjustment for seat forward/back position-Engine temperature,25, °C
IDE06512-MAS03129,Adjustment for seat forward/back position-Reset counter,103,
IDE06512-MAS04160,Adjustment for seat forward/back position-Load change,131,
IDE06512-MAS04337,Adjustment for seat forward/back position-Engine current,0, A
IDE06512-MAS05370,Adjustment for seat forward/back position-Direction of movement,Not operated,
IDE06512-MAS05563,Adjustment for seat forward/back position-Standardization,standardized,
IDE06512-MAS05719,Adjustment for seat forward/back position-Maximum travel,464,
IDE06512-MAS12838,Adjustment for seat forward/back position-Standardization flag,standardized,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS01601,Memory seat adjustment control head-storing,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,32769,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,32497,
IDE06683-MAS02282,Seat inclination adjustment-Position,32572,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,25, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,3,
IDE06683-MAS04160,Seat inclination adjustment-Load change,6,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, A
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,Not operated,
IDE06683-MAS05563,Seat inclination adjustment-Standardization,standardized,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,272,
IDE06683-MAS12838,Seat inclination adjustment-Standardization flag,standardized,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,0,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,0,
IDE06684-MAS02282,Lumbar support height adjustment-Position,0,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,0, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,0,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,0,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, A
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,Not operated,
IDE06684-MAS05563,Lumbar support height adjustment-Standardization,not standardized,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,0,
IDE06684-MAS12838,Lumbar support height adjustment-Standardization flag,never normed,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,0,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,0,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,0,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,0, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,0,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,0,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, A
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,Not operated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Standardization,not standardized,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,0,
IDE06685-MAS12838,Lumbar support longitudinal position adjustment-Standardization flag,never normed,
IDE06871-IDE06510,Seat adjustment control head-Adjustment for backrest angle,Not operated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,Not operated,
IDE06871-IDE06512,Seat adjustment control head-Adjustment for seat forward/back position,Not operated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,Not operated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,Not operated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,Not operated,
IDE06871-IDE08989,Seat adjustment control head-Seat depth adjustment,Not operated,
IDE06871-IDE08990,Seat adjustment control head-Backrest top adjustment,Not operated,
IDE06871-IDE08991,Seat adjustment control head-Belt height adjustment,Not operated,
IDE06871-IDE11024,Seat adjustment control head-Headrest height adjustment,Not operated,
IDE06871-IDE11025,Seat adjustment control head-Headrest length adjustment,Not operated,
IDE07159,Control module switch-off: counter,0,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Adjustment for backrest angle,32434,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,33244,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Adjustment for seat forward/back position,32653,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,32769,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,0,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07347-IDE08989,Memory setting 1 for seat adjustment-Seat depth adjustment,0,
IDE07347-IDE08990,Memory setting 1 for seat adjustment-Backrest top adjustment,0,
IDE07347-IDE08991,Memory setting 1 for seat adjustment-Belt height adjustment,0,
IDE07347-IDE11024,Memory setting 1 for seat adjustment-Headrest height adjustment,0,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Adjustment for backrest angle,0,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,0,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,0,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,0,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07348-IDE08989,Memory setting 2 for seat adjustment-Seat depth adjustment,0,
IDE07348-IDE08990,Memory setting 2 for seat adjustment-Backrest top adjustment,0,
IDE07348-IDE08991,Memory setting 2 for seat adjustment-Belt height adjustment,0,
IDE07348-IDE11024,Memory setting 2 for seat adjustment-Headrest height adjustment,0,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Adjustment for backrest angle,0,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,0,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,0,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,0,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07349-IDE08989,Memory setting 3 for seat adjustment-Seat depth adjustment,0,
IDE07349-IDE08990,Memory setting 3 for seat adjustment-Backrest top adjustment,0,
IDE07349-IDE08991,Memory setting 3 for seat adjustment-Belt height adjustment,0,
IDE07349-IDE11024,Memory setting 3 for seat adjustment-Headrest height adjustment,0,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Adjustment for backrest angle,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07350-IDE08989,Memory setting 4 for seat adjustment-Seat depth adjustment,0,
IDE07350-IDE08990,Memory setting 4 for seat adjustment-Backrest top adjustment,0,
IDE07350-IDE08991,Memory setting 4 for seat adjustment-Belt height adjustment,0,
IDE07350-IDE11024,Memory setting 4 for seat adjustment-Headrest height adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,0,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07351-IDE08989,Memory setting 1: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07351-IDE08990,Memory setting 1: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07351-IDE08991,Memory setting 1: remote master key for seat adjustment-Belt height adjustment,0,
IDE07351-IDE11024,Memory setting 1: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,0,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07352-IDE08989,Memory setting 2: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07352-IDE08990,Memory setting 2: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07352-IDE08991,Memory setting 2: remote master key for seat adjustment-Belt height adjustment,0,
IDE07352-IDE11024,Memory setting 2: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,0,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07353-IDE08989,Memory setting 3: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07353-IDE08990,Memory setting 3: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07353-IDE08991,Memory setting 3: remote master key for seat adjustment-Belt height adjustment,0,
IDE07353-IDE11024,Memory setting 3: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,0,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07354-IDE08989,Memory setting 4: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07354-IDE08990,Memory setting 4: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07354-IDE08991,Memory setting 4: remote master key for seat adjustment-Belt height adjustment,0,
IDE07354-IDE11024,Memory setting 4: remote master key for seat adjustment-Headrest height adjustment,0,
IDE08988-MAS01390,Head restraint adjustment-Block 1,0,
IDE08988-MAS01391,Head restraint adjustment-Block 2,0,
IDE08988-MAS02282,Head restraint adjustment-Position,0,
IDE08988-MAS02955,Head restraint adjustment-Engine temperature,0, °C
IDE08988-MAS03129,Head restraint adjustment-Reset counter,0,
IDE08988-MAS04160,Head restraint adjustment-Load change,0,
IDE08988-MAS04337,Head restraint adjustment-Engine current,0, A
IDE08988-MAS05370,Head restraint adjustment-Direction of movement,Not operated,
IDE08988-MAS05563,Head restraint adjustment-Standardization,not standardized,
IDE08988-MAS05719,Head restraint adjustment-Maximum travel,0,
IDE08988-MAS12838,Head restraint adjustment-Standardization flag,never normed,
IDE08989-MAS01390,Seat depth adjustment-Block 1,0,
IDE08989-MAS01391,Seat depth adjustment-Block 2,0,
IDE08989-MAS02282,Seat depth adjustment-Position,0,
IDE08989-MAS02955,Seat depth adjustment-Engine temperature,0, °C
IDE08989-MAS03129,Seat depth adjustment-Reset counter,0,
IDE08989-MAS04160,Seat depth adjustment-Load change,0,
IDE08989-MAS04337,Seat depth adjustment-Engine current,0, A
IDE08989-MAS05370,Seat depth adjustment-Direction of movement,Not operated,
IDE08989-MAS05563,Seat depth adjustment-Standardization,not standardized,
IDE08989-MAS05719,Seat depth adjustment-Maximum travel,0,
IDE08989-MAS12838,Seat depth adjustment-Standardization flag,never normed,
IDE08990-MAS01390,Backrest top adjustment-Block 1,0,
IDE08990-MAS01391,Backrest top adjustment-Block 2,0,
IDE08990-MAS02282,Backrest top adjustment-Position,0,
IDE08990-MAS02955,Backrest top adjustment-Engine temperature,0, °C
IDE08990-MAS03129,Backrest top adjustment-Reset counter,0,
IDE08990-MAS04160,Backrest top adjustment-Load change,0,
IDE08990-MAS04337,Backrest top adjustment-Engine current,0, A
IDE08990-MAS05370,Backrest top adjustment-Direction of movement,Not operated,
IDE08990-MAS05563,Backrest top adjustment-Standardization,not standardized,
IDE08990-MAS05719,Backrest top adjustment-Maximum travel,0,
IDE08990-MAS12838,Backrest top adjustment-Standardization flag,never normed,
IDE08991-MAS01390,Belt height adjustment-Block 1,0,
IDE08991-MAS01391,Belt height adjustment-Block 2,0,
IDE08991-MAS02282,Belt height adjustment-Position,0,
IDE08991-MAS02955,Belt height adjustment-Engine temperature,0, °C
IDE08991-MAS03129,Belt height adjustment-Reset counter,0,
IDE08991-MAS04160,Belt height adjustment-Load change,0,
IDE08991-MAS04337,Belt height adjustment-Engine current,0, A
IDE08991-MAS05370,Belt height adjustment-Direction of movement,Not operated,
IDE08991-MAS05563,Belt height adjustment-Standardization,not standardized,
IDE08991-MAS05719,Belt height adjustment-Maximum travel,0,
IDE08991-MAS12838,Belt height adjustment-Standardization flag,never normed,
IDE09081-MAS08291,Seat switch module-Plate: vertical actuation direction,Not operated,
IDE09081-MAS08292,Seat switch module-Plate: horizontal actuation direction,Not operated,
IDE09081-MAS08293,Seat switch module-Rocker,Not operated,
IDE09082,Massage function button,Not operated,
IDE09083-MAS08294,Entry assistance button-Entry assistance button: actuation direction forward,Not operated,
IDE09083-MAS08295,Entry assistance button-Entry assistance button: actuation direction backward,Not operated,
IDE09084-MAS08296,Backrest lock switch-Switch state normally closed,operated,
IDE09084-MAS08297,Backrest lock switch-Switch state normally open,Not operated,
IDE09085,Backrest limit switch,Not operated,
IDE10995-IDE06510,Calibrating the motors: status-Adjustment for backrest angle,standardized,
IDE10995-IDE06511,Calibrating the motors: status-Seat height adjustment,standardized,
IDE10995-IDE06512,Calibrating the motors: status-Adjustment for seat forward/back position,standardized,
IDE10995-IDE06683,Calibrating the motors: status-Seat inclination adjustment,standardized,
IDE10995-IDE06684,Calibrating the motors: status-Lumbar support height adjustment,not standardized,
IDE10995-IDE06685,Calibrating the motors: status-Lumbar support longitudinal position adjustment,not standardized,
IDE10995-IDE08988,Calibrating the motors: status-Head restraint adjustment,not standardized,
IDE10995-IDE08989,Calibrating the motors: status-Seat depth adjustment,not standardized,
IDE10995-IDE08990,Calibrating the motors: status-Backrest top adjustment,not standardized,
IDE10995-IDE08991,Calibrating the motors: status-Belt height adjustment,not standardized,
IDE10995-IDE11957,Calibrating the motors: status-Display unit adjustment,not standardized,
IDE10995-IDE11969,Calibrating the motors: status-Adjustment of foot rest,not standardized,
IDE10995-IDE11986,Calibrating the motors: status-Adjustment 2 of visual display unit,not standardized,
IDE10995-MAS11869,Calibrating the motors: status-Headrest adjustment: horizontal,not standardized,
IDE10995-MAS11890,Calibrating the motors: status-Headrest adjustment: vertical,not standardized,
IDE10996-MAS11891,Excessive force limit: status-Seat forward/back position adjustment: forwards,Adapted,
IDE10996-MAS11892,Excessive force limit: status-Seat forward/back position adjustment: backwards,Adapted,
IDE10996-MAS11895,Excessive force limit: status-Backrest inclination adjustment: forwards,Not adapted,
IDE10996-MAS11896,Excessive force limit: status-Backrest inclination adjustment: backwards,Not adapted,
IDE10996-MAS11959,Excessive force limit: status-Seat height adjustment higher,Not adapted,
IDE10996-MAS11960,Excessive force limit: status-Seat height adjustment lower,Not adapted,
IDE11024-MAS01390,Headrest height adjustment-Block 1,0,
IDE11024-MAS01391,Headrest height adjustment-Block 2,0,
IDE11024-MAS02282,Headrest height adjustment-Position,0,
IDE11024-MAS02955,Headrest height adjustment-Engine temperature,0, °C
IDE11024-MAS03129,Headrest height adjustment-Reset counter,0,
IDE11024-MAS04160,Headrest height adjustment-Load change,0,
IDE11024-MAS04337,Headrest height adjustment-Engine current,0, A
IDE11024-MAS05370,Headrest height adjustment-Direction of movement,Not operated,
IDE11024-MAS05563,Headrest height adjustment-Standardization,not standardized,
IDE11024-MAS05719,Headrest height adjustment-Maximum travel,0,
IDE11024-MAS12838,Headrest height adjustment-Standardization flag,never normed,
IDE11025-MAS01390,Headrest length adjustment-Block 1,0,
IDE11025-MAS01391,Headrest length adjustment-Block 2,0,
IDE11025-MAS02282,Headrest length adjustment-Position,0,
IDE11025-MAS02955,Headrest length adjustment-Engine temperature,0, °C
IDE11025-MAS03129,Headrest length adjustment-Reset counter,0,
IDE11025-MAS04160,Headrest length adjustment-Load change,0,
IDE11025-MAS04337,Headrest length adjustment-Engine current,0, A
IDE11025-MAS05370,Headrest length adjustment-Direction of movement,Not operated,
IDE11025-MAS05563,Headrest length adjustment-Standardization,not standardized,
IDE11025-MAS05719,Headrest length adjustment-Maximum travel,0,
IDE11025-MAS12838,Headrest length adjustment-Standardization flag,never normed,
IDE11957-MAS01390,Display unit adjustment-Block 1,0,
IDE11957-MAS01391,Display unit adjustment-Block 2,0,
IDE11957-MAS02282,Display unit adjustment-Position,0,
IDE11957-MAS02955,Display unit adjustment-Engine temperature,0, °C
IDE11957-MAS03129,Display unit adjustment-Reset counter,0,
IDE11957-MAS04160,Display unit adjustment-Load change,0,
IDE11957-MAS04337,Display unit adjustment-Engine current,0, A
IDE11957-MAS05370,Display unit adjustment-Direction of movement,Not operated,
IDE11957-MAS05563,Display unit adjustment-Standardization,not standardized,
IDE11957-MAS05719,Display unit adjustment-Maximum travel,0,
IDE11957-MAS12838,Display unit adjustment-Standardization flag,never normed,
IDE11969-MAS01390,Adjustment of foot rest-Block 1,0,
IDE11969-MAS01391,Adjustment of foot rest-Block 2,0,
IDE11969-MAS02282,Adjustment of foot rest-Position,0,
IDE11969-MAS02955,Adjustment of foot rest-Engine temperature,0, °C
IDE11969-MAS03129,Adjustment of foot rest-Reset counter,0,
IDE11969-MAS04160,Adjustment of foot rest-Load change,0,
IDE11969-MAS04337,Adjustment of foot rest-Engine current,0, A
IDE11969-MAS05370,Adjustment of foot rest-Direction of movement,Not operated,
IDE11969-MAS05563,Adjustment of foot rest-Standardization,not standardized,
IDE11969-MAS05719,Adjustment of foot rest-Maximum travel,0,
IDE11969-MAS12838,Adjustment of foot rest-Standardization flag,never normed,
IDE11986-MAS01390,Adjustment 2 of visual display unit-Block 1,0,
IDE11986-MAS01391,Adjustment 2 of visual display unit-Block 2,0,
IDE11986-MAS02282,Adjustment 2 of visual display unit-Position,0,
IDE11986-MAS02955,Adjustment 2 of visual display unit-Engine temperature,0, °C
IDE11986-MAS03129,Adjustment 2 of visual display unit-Reset counter,0,
IDE11986-MAS04160,Adjustment 2 of visual display unit-Load change,0,
IDE11986-MAS04337,Adjustment 2 of visual display unit-Engine current,0, A
IDE11986-MAS05370,Adjustment 2 of visual display unit-Direction of movement,Not operated,
IDE11986-MAS05563,Adjustment 2 of visual display unit-Standardization,not standardized,
IDE11986-MAS05719,Adjustment 2 of visual display unit-Maximum travel,0,
IDE11986-MAS12838,Adjustment 2 of visual display unit-Standardization flag,never normed,
IDE12083-MAS13890,Switch for lateral backrest support adjustment-Adjustment for lateral support backrest,Not operated,
IDE12083-MAS13891,Switch for lateral backrest support adjustment-Adjustment for lateral support seat cushion,Not operated,
MAS12838-IDE06510,Standardization flag-Adjustment for backrest angle,standardized,
MAS12838-IDE06511,Standardization flag-Seat height adjustment,standardized,
MAS12838-IDE06512,Standardization flag-Adjustment for seat forward/back position,standardized,
MAS12838-IDE06683,Standardization flag-Seat inclination adjustment,standardized,
MAS12838-IDE06684,Standardization flag-Lumbar support height adjustment,never normed,
MAS12838-IDE06685,Standardization flag-Lumbar support longitudinal position adjustment,never normed,
MAS12838-IDE08988,Standardization flag-Head restraint adjustment,never normed,
MAS12838-IDE08989,Standardization flag-Seat depth adjustment,never normed,
MAS12838-IDE08990,Standardization flag-Backrest top adjustment,never normed,
MAS12838-IDE08991,Standardization flag-Belt height adjustment,never normed,
MAS12838-IDE11957,Standardization flag-Display unit adjustment,never normed,
MAS12838-IDE11969,Standardization flag-Adjustment of foot rest,never normed,
MAS12838-IDE11986,Standardization flag-Adjustment 2 of visual display unit,never normed,
MAS12838-MAS11869,Standardization flag-Headrest adjustment: horizontal,never normed,
MAS12838-MAS11890,Standardization flag-Headrest adjustment: vertical,never normed,
ENG139951-IDE06510,Account_1-Adjustment for backrest angle,0,
ENG139951-IDE06511,Account_1-Seat height adjustment,0,
ENG139951-IDE06512,Account_1-Adjustment for seat forward/back position,0,
ENG139951-IDE06683,Account_1-Seat inclination adjustment,0,
ENG139951-IDE06684,Account_1-Lumbar support height adjustment,0,
ENG139951-IDE06685,Account_1-Lumbar support longitudinal position adjustment,0,
ENG139951-IDE08989,Account_1-Seat depth adjustment,0,
ENG139951-IDE08990,Account_1-Backrest top adjustment,0,
ENG139951-IDE08991,Account_1-Belt height adjustment,0,
ENG139951-IDE11024,Account_1-Headrest height adjustment,0,
ENG139952-IDE06510,Account_2-Adjustment for backrest angle,0,
ENG139952-IDE06511,Account_2-Seat height adjustment,0,
ENG139952-IDE06512,Account_2-Adjustment for seat forward/back position,0,
ENG139952-IDE06683,Account_2-Seat inclination adjustment,0,
ENG139952-IDE06684,Account_2-Lumbar support height adjustment,0,
ENG139952-IDE06685,Account_2-Lumbar support longitudinal position adjustment,0,
ENG139952-IDE08989,Account_2-Seat depth adjustment,0,
ENG139952-IDE08990,Account_2-Backrest top adjustment,0,
ENG139952-IDE08991,Account_2-Belt height adjustment,0,
ENG139952-IDE11024,Account_2-Headrest height adjustment,0,
ENG139953-IDE06510,Account_3-Adjustment for backrest angle,0,
ENG139953-IDE06511,Account_3-Seat height adjustment,0,
ENG139953-IDE06512,Account_3-Adjustment for seat forward/back position,0,
ENG139953-IDE06683,Account_3-Seat inclination adjustment,0,
ENG139953-IDE06684,Account_3-Lumbar support height adjustment,0,
ENG139953-IDE06685,Account_3-Lumbar support longitudinal position adjustment,0,
ENG139953-IDE08989,Account_3-Seat depth adjustment,0,
ENG139953-IDE08990,Account_3-Backrest top adjustment,0,
ENG139953-IDE08991,Account_3-Belt height adjustment,0,
ENG139953-IDE11024,Account_3-Headrest height adjustment,0,
ENG139954-IDE06510,Account_4-Adjustment for backrest angle,0,
ENG139954-IDE06511,Account_4-Seat height adjustment,0,
ENG139954-IDE06512,Account_4-Adjustment for seat forward/back position,0,
ENG139954-IDE06683,Account_4-Seat inclination adjustment,0,
ENG139954-IDE06684,Account_4-Lumbar support height adjustment,0,
ENG139954-IDE06685,Account_4-Lumbar support longitudinal position adjustment,0,
ENG139954-IDE08989,Account_4-Seat depth adjustment,0,
ENG139954-IDE08990,Account_4-Backrest top adjustment,0,
ENG139954-IDE08991,Account_4-Belt height adjustment,0,
ENG139954-IDE11024,Account_4-Headrest height adjustment,0,
ENG139955-IDE06510,Account_5-Adjustment for backrest angle,0,
ENG139955-IDE06511,Account_5-Seat height adjustment,0,
ENG139955-IDE06512,Account_5-Adjustment for seat forward/back position,0,
ENG139955-IDE06683,Account_5-Seat inclination adjustment,0,
ENG139955-IDE06684,Account_5-Lumbar support height adjustment,0,
ENG139955-IDE06685,Account_5-Lumbar support longitudinal position adjustment,0,
ENG139955-IDE08989,Account_5-Seat depth adjustment,0,
ENG139955-IDE08990,Account_5-Backrest top adjustment,0,
ENG139955-IDE08991,Account_5-Belt height adjustment,0,
ENG139955-IDE11024,Account_5-Headrest height adjustment,0,
ENG139956-IDE06510,Account_6-Adjustment for backrest angle,0,
ENG139956-IDE06511,Account_6-Seat height adjustment,0,
ENG139956-IDE06512,Account_6-Adjustment for seat forward/back position,0,
ENG139956-IDE06683,Account_6-Seat inclination adjustment,0,
ENG139956-IDE06684,Account_6-Lumbar support height adjustment,0,
ENG139956-IDE06685,Account_6-Lumbar support longitudinal position adjustment,0,
ENG139956-IDE08989,Account_6-Seat depth adjustment,0,
ENG139956-IDE08990,Account_6-Backrest top adjustment,0,
ENG139956-IDE08991,Account_6-Belt height adjustment,0,
ENG139956-IDE11024,Account_6-Headrest height adjustment,0,
ENG139957-IDE06510,Account_7-Adjustment for backrest angle,0,
ENG139957-IDE06511,Account_7-Seat height adjustment,0,
ENG139957-IDE06512,Account_7-Adjustment for seat forward/back position,0,
ENG139957-IDE06683,Account_7-Seat inclination adjustment,0,
ENG139957-IDE06684,Account_7-Lumbar support height adjustment,0,
ENG139957-IDE06685,Account_7-Lumbar support longitudinal position adjustment,0,
ENG139957-IDE08989,Account_7-Seat depth adjustment,0,
ENG139957-IDE08990,Account_7-Backrest top adjustment,0,
ENG139957-IDE08991,Account_7-Belt height adjustment,0,
ENG139957-IDE11024,Account_7-Headrest height adjustment,0,
ENG139950-IDE06510,BAP_Seat_Adjustment_Button_Status-Adjustment for backrest angle,Not operated,
ENG139950-IDE06511,BAP_Seat_Adjustment_Button_Status-Seat height adjustment,Not operated,
ENG139950-IDE06512,BAP_Seat_Adjustment_Button_Status-Adjustment for seat forward/back position,Not operated,
ENG139950-IDE06683,BAP_Seat_Adjustment_Button_Status-Seat inclination adjustment,Not operated,
ENG139950-IDE06684,BAP_Seat_Adjustment_Button_Status-Lumbar support height adjustment,Not operated,
ENG139950-IDE06685,BAP_Seat_Adjustment_Button_Status-Lumbar support longitudinal position adjustment,Not operated,
ENG139950-IDE08989,BAP_Seat_Adjustment_Button_Status-Seat depth adjustment,Not operated,
ENG139950-IDE08990,BAP_Seat_Adjustment_Button_Status-Backrest top adjustment,Not operated,
ENG139950-IDE08991,BAP_Seat_Adjustment_Button_Status-Belt height adjustment,Not operated,
ENG139950-IDE11024,BAP_Seat_Adjustment_Button_Status-Headrest height adjustment,Not operated,
ENG139950-IDE11025,BAP_Seat_Adjustment_Button_Status-Headrest length adjustment,Not operated,
ENG139950-IDE11957,BAP_Seat_Adjustment_Button_Status-Display unit adjustment,Not operated,
ENG139950-IDE11969,BAP_Seat_Adjustment_Button_Status-Adjustment of foot rest,Not operated,
ENG139950-IDE11986,BAP_Seat_Adjustment_Button_Status-Adjustment 2 of visual display unit,Not operated,
ENG139950-ENG140668,BAP_Seat_Adjustment_Button_Status-backrest_side_bolster,Not operated,
ENG139950-ENG140669,BAP_Seat_Adjustment_Button_Status-footmat,Not operated,
ENG139950-ENG140667,BAP_Seat_Adjustment_Button_Status-side_bolster,Not operated,
ENG136330-ENG136340,Cause of de-normalization-Axis_1,Normierroutine,
ENG136330-ENG136349,Cause of de-normalization-Axis_10,Achse decodiert,
ENG136330-ENG136341,Cause of de-normalization-Axis_2,Normierroutine,
ENG136330-ENG136342,Cause of de-normalization-Axis_3,Normierroutine,
ENG136330-ENG136343,Cause of de-normalization-Axis_4,Normierroutine,
ENG136330-ENG136344,Cause of de-normalization-Axis_5,Achse decodiert,
ENG136330-ENG136345,Cause of de-normalization-Axis_6,Achse decodiert,
ENG136330-ENG136346,Cause of de-normalization-Axis_7,Achse decodiert,
ENG136330-ENG136347,Cause of de-normalization-Axis_8,Achse decodiert,
ENG136330-ENG136348,Cause of de-normalization-Axis_9,Achse decodiert,
ENG136325-ENG101098,crash_precrash-Crash,not active,
ENG136325-ENG131963,crash_precrash-Precrash,not active,
ENG247801-ENG248126,info_developer-ax_da,80 AC 7F 8D 81 5D 00 07 80 79 7E B2 84 E1 00 07 81 5C 7F F4 81 DC 00 07 7F 3C 7E F1 80 01 00 07 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A,
ENG247801-ENG248078,info_developer-gl_lo,35 51 53 39 35 39 37 36 30 48 20 00 00 00 00 00 30 33 37 30 00 00 00 00 32 35 34 31 00 00 00 00 53 43 58 58 58 58 58 58 56 57 54 37 00 00 00 00 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG247947,info_developer-gl_pr,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0B 00 05 00 03 00 00 03 04 04 00 00 00 00,
ENG247801-ENG248107,info_developer-pne,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG248040,info_developer-so_deb,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG136350-ENG136426,key_memory_activated-mmi_key_memory_activated,not active,
ENG157282-ENG161450,Maximum travel-Axis_1_current,464,
ENG157282-ENG161451,Maximum travel-Axis_1_last,0,
ENG157282-ENG161452,Maximum travel-Axis_10_current,65535,
ENG157282-ENG161453,Maximum travel-Axis_10_last,0,
ENG157282-ENG161454,Maximum travel-Axis_2_current,1583,
ENG157282-ENG161455,Maximum travel-Axis_2_last,0,
ENG157282-ENG161456,Maximum travel-Axis_3_current,488,
ENG157282-ENG161457,Maximum travel-Axis_3_last,0,
ENG157282-ENG161458,Maximum travel-Axis_4_current,272,
ENG157282-ENG161459,Maximum travel-Axis_4_last,0,
ENG157282-ENG161460,Maximum travel-Axis_5_current,65535,
ENG157282-ENG161461,Maximum travel-Axis_5_last,0,
ENG157282-ENG161462,Maximum travel-Axis_6_current,65535,
ENG157282-ENG161463,Maximum travel-Axis_6_last,0,
ENG157282-ENG161464,Maximum travel-Axis_7_current,65535,
ENG157282-ENG161465,Maximum travel-Axis_7_last,0,
ENG157282-ENG161466,Maximum travel-Axis_8_current,65535,
ENG157282-ENG161467,Maximum travel-Axis_8_last,0,
ENG157282-ENG161468,Maximum travel-Axis_9_current,65535,
ENG157282-ENG161469,Maximum travel-Axis_9_last,0,
ENG136323-IDE06842,Memory_ID_CAN_1-Status - Button 1,not active,
ENG136323-IDE06843,Memory_ID_CAN_1-Status - Button 2,not active,
ENG136323-IDE06844,Memory_ID_CAN_1-Status - Button 3,not active,
ENG136323-IDE06845,Memory_ID_CAN_1-Status - Button 4,not active,
ENG136323-ENG123088,Memory_ID_CAN_1-FFB_Close_Button,not active,
ENG136323-ENG123087,Memory_ID_CAN_1-FFB_Open_Button,not active,
ENG136323-ENG123089,Memory_ID_CAN_1-FT_lock,not active,
ENG136323-ENG123090,Memory_ID_CAN_1-FT_locked,not active,
ENG136324-MAS03679,Memory_ID_CAN_2-Terminal 15 status,active,
ENG136324-ENG123091,Memory_ID_CAN_2-DoorContact_more_than_10min_opened,not active,
ENG136324-ENG123092,Memory_ID_CAN_2-DoorContact_NotActive_Active,not active,
ENG136324-ENG140350,Memory_ID_CAN_2-FFB_HDF_Button,not active,
ENG136324-ENG136335,Memory_ID_CAN_2-Hardware_onoff,active,
ENG136324-ENG123093,Memory_ID_CAN_2-Memory_Adjustment,not active,
ENG136324-ENG123094,Memory_ID_CAN_2-MemoryButton_Pressed,not active,
ENG136324-ENG248058,Memory_ID_CAN_2-v_signal_less_v_threshold,active,
ENG158048-MAS03760,missing_pre_conditions-Wind deflector position,not active,
ENG158048-ENG161471,missing_pre_conditions-backrest_locked,active,
ENG158048-ENG161472,missing_pre_conditions-backrest_unlocked,active,
ENG158048-ENG161506,missing_pre_conditions-button_pressed,not active,
ENG158048-ENG161716,missing_pre_conditions-coded_axes_not_normalized,not active,
ENG158048-ENG163288,missing_pre_conditions-other_adjustment_already_active,not active,
ENG158048-ENG98864,missing_pre_conditions-Reserved,0,
ENG158048-ENG310748,missing_pre_conditions-reserviert_01,0,
ENG158048-ENG163523,missing_pre_conditions-reset_problem,not active,
ENG158048-ENG163733,missing_pre_conditions-speed_above_5kmh,not active,
ENG158048-ENG159469,missing_pre_conditions-Voltage_supply,not active,
ENG158102-ENG161674,personalization_last_function-cause_of_termination,0,
ENG158102,personalization_last_function,none,
ENG158102-ENG99298,personalization_last_function-State,none,
ENG136328-ENG136337,pwm_generator-pwm_generator_group_1_overload,not active,
ENG136328-ENG136338,pwm_generator-pwm_generator_group_2_overload,not active,
ENG136326-ENG99389,Resets-Resetcounter,11,
ENG136329-ENG136339,sbc-sbc_overload,not active,
ENG136351-ENG136438,Seat_Actual_Positions-Current_Position_fsv,32768,
ENG136351-ENG136434,Seat_Actual_Positions-Current_Position_ghv,32768,
ENG136351-ENG136441,Seat_Actual_Positions-Current_Position_kks,32768,
ENG136351-ENG136437,Seat_Actual_Positions-Current_Position_ksv_x,32768,
ENG136351-ENG136431,Seat_Actual_Positions-Current_Position_ksv_z,32768,
ENG136351-ENG136436,Seat_Actual_Positions-Current_Position_ldh,32768,
ENG136351-ENG136435,Seat_Actual_Positions-Current_Position_ldw,32768,
ENG136351-ENG136433,Seat_Actual_Positions-Current_Position_lkv,32768,
ENG136351-ENG136428,Seat_Actual_Positions-Current_Position_lnv,32889,
ENG136351-ENG136439,Seat_Actual_Positions-Current_Position_rse1,32768,
ENG136351-ENG136440,Seat_Actual_Positions-Current_Position_rse2,32768,
ENG136351-ENG136429,Seat_Actual_Positions-Current_Position_shv,33116,
ENG136351-ENG136427,Seat_Actual_Positions-Current_Position_slv,32940,
ENG136351-ENG136430,Seat_Actual_Positions-Current_Position_snv,32572,
ENG136351-ENG136432,Seat_Actual_Positions-Current_Position_stv,32768,
ENG123054-ENG136421,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_1,not active,
ENG123054-ENG136422,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_2,not active,
ENG123054-ENG136423,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_3,not active,
ENG123054-ENG136424,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_4,not active,
ENG123054-ENG136425,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_SET,not active,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,not active,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,Key 2,
ENG123053-ENG136417,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Head_Movement,not active,
ENG123053-ENG136412,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Inclination_Movement,not active,
ENG123053-ENG136418,Seat_Adjustment_State_Info_CAN-FSM_Belt_Height_Movement,not active,
ENG123053-ENG136415,Seat_Adjustment_State_Info_CAN-FSM_Headrest_Movement,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG136420,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Height_Movement,not active,
ENG123053-ENG136419,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Longitudial_Movement,not active,
ENG123053-ENG136416,Seat_Adjustment_State_Info_CAN-FSM_Seat_Depth_Movement,not active,
ENG123053-ENG136413,Seat_Adjustment_State_Info_CAN-FSM_Seat_Height_Movement,not active,
ENG123053-ENG136414,Seat_Adjustment_State_Info_CAN-FSM_Seat_Inclination_Movement,not active,
ENG123053-ENG136411,Seat_Adjustment_State_Info_CAN-FSM_Seat_Longitudial_Movement,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG158188-IDE06510,Seat_Position_Memory_Remote_Control_5-Adjustment for backrest angle,0,
ENG158188-IDE06511,Seat_Position_Memory_Remote_Control_5-Seat height adjustment,0,
ENG158188-IDE06512,Seat_Position_Memory_Remote_Control_5-Adjustment for seat forward/back position,0,
ENG158188-IDE06683,Seat_Position_Memory_Remote_Control_5-Seat inclination adjustment,0,
ENG158188-IDE06684,Seat_Position_Memory_Remote_Control_5-Lumbar support height adjustment,0,
ENG158188-IDE06685,Seat_Position_Memory_Remote_Control_5-Lumbar support longitudinal position adjustment,0,
ENG158188-IDE08989,Seat_Position_Memory_Remote_Control_5-Seat depth adjustment,0,
ENG158188-IDE08990,Seat_Position_Memory_Remote_Control_5-Backrest top adjustment,0,
ENG158188-IDE08991,Seat_Position_Memory_Remote_Control_5-Belt height adjustment,0,
ENG158188-IDE11024,Seat_Position_Memory_Remote_Control_5-Headrest height adjustment,0,
ENG158189-IDE06510,Seat_Position_Memory_Remote_Control_6-Adjustment for backrest angle,0,
ENG158189-IDE06511,Seat_Position_Memory_Remote_Control_6-Seat height adjustment,0,
ENG158189-IDE06512,Seat_Position_Memory_Remote_Control_6-Adjustment for seat forward/back position,0,
ENG158189-IDE06683,Seat_Position_Memory_Remote_Control_6-Seat inclination adjustment,0,
ENG158189-IDE06684,Seat_Position_Memory_Remote_Control_6-Lumbar support height adjustment,0,
ENG158189-IDE06685,Seat_Position_Memory_Remote_Control_6-Lumbar support longitudinal position adjustment,0,
ENG158189-IDE08989,Seat_Position_Memory_Remote_Control_6-Seat depth adjustment,0,
ENG158189-IDE08990,Seat_Position_Memory_Remote_Control_6-Backrest top adjustment,0,
ENG158189-IDE08991,Seat_Position_Memory_Remote_Control_6-Belt height adjustment,0,
ENG158189-IDE11024,Seat_Position_Memory_Remote_Control_6-Headrest height adjustment,0,
ENG158190-IDE06510,Seat_Position_Memory_Remote_Control_7-Adjustment for backrest angle,0,
ENG158190-IDE06511,Seat_Position_Memory_Remote_Control_7-Seat height adjustment,0,
ENG158190-IDE06512,Seat_Position_Memory_Remote_Control_7-Adjustment for seat forward/back position,0,
ENG158190-IDE06683,Seat_Position_Memory_Remote_Control_7-Seat inclination adjustment,0,
ENG158190-IDE06684,Seat_Position_Memory_Remote_Control_7-Lumbar support height adjustment,0,
ENG158190-IDE06685,Seat_Position_Memory_Remote_Control_7-Lumbar support longitudinal position adjustment,0,
ENG158190-IDE08989,Seat_Position_Memory_Remote_Control_7-Seat depth adjustment,0,
ENG158190-IDE08990,Seat_Position_Memory_Remote_Control_7-Backrest top adjustment,0,
ENG158190-IDE08991,Seat_Position_Memory_Remote_Control_7-Belt height adjustment,0,
ENG158190-IDE11024,Seat_Position_Memory_Remote_Control_7-Headrest height adjustment,0,
ENG136327-ENG116986,Source_Last_Reset-Low_Voltage,not active,
ENG136327-ENG123073,Source_Last_Reset-Low_Voltage_At_Run_Up,not active,
ENG136327-ENG123072,Source_Last_Reset-Power_On_Reset,active,
ENG136327-ENG123071,Source_Last_Reset-Software_Reset_by_diagnosis,not active,
ENG136327-ENG110107,Source_Last_Reset-Watchdog_reset,not active,
ENG136327-ENG123074,Source_Last_Reset-Watchdog_Reset_At_Run_Up,not active,
Elapsed Time: 00:23
;SW:3WA-907-007-F HW:3WA-907-007 --- 08: Auto HVAC
;Component:Climatronic H01 5089, Coding:422000240211021012201010111111110000132111200100000000001000
;EV_ACClimaBHBE3ADV,002062,EV_ACClimaBHBE3ADV_002_VW41.rod
;Wednesday,30,September,2026,11:59:42:11564
;VCDS Version: 26.10.0.2 (x64) Data version: 20260921 DS379.0
;VCID: 48C1074D0231298A631-801C-R SFD+SFD2 {x}
Group,Description,Actual
IDE00019,Voltage terminal 30,14.00, V
IDE00021,Engine speed,901.0, /min
IDE00025,Coolant temperature,87.00, °C
IDE00198,Refrigerant pressure,10.20, bar
IDE00767,No. of unscheduled ECU resets,14,
IDE00965,Compressor shut-off condition,Compressor active: no shut-off condition is present,
IDE00966,Compressor current: actual value,0.44, A
IDE00967,Compressor current: specified value,0.45, A
IDE00968,Compressor speed,550.0, /min
IDE00969,Compressor load,10.0, Nm
IDE00970,Coolant fan activation: actual value,14.40, %
IDE00971,Coolant fan activation: specified value,24.8, %
IDE00973,Outside temperature,33.00, °C
IDE00974,Outside air temperature internally calculated,32.00, °C
IDE00976,Left front vent temperature,9.00, °C
IDE00977,Right front vent temperature,11.00, °C
IDE00981,Footwell vent temperature,22.50,
IDE00982,Temperature downstream of evaporator,2.00, °C
IDE00983,Inside temperature,30.00, °C
IDE00984,Sun intensity left,210.00, W/m²
IDE00985,Sun intensity right,800.00, W/m²
IDE00987,Blower voltage: specified value,4.90, V
IDE00989,Blower status,not active,
IDE00992,Recirculation flap specified value,Measuring value not available,
IDE00994,Actual value for fresh air/recirculation air flow flap,100.0, %
IDE00994,Actual value for fresh air/recirculation air flow flap,856,
IDE00995,Fresh air/recirculating air/back pressure door specified value,872,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,175,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,852,
IDE00998,Left temperature flap - actual value,0.0, %
IDE00998,Left temperature flap - actual value,91,
IDE00999,Temperature door left - Specified value,90,
IDE01040,Left Temperature Control Door - cold stop,110,
IDE01041,Left temperature flap: warm stop,919,
IDE01042,Right temperature flap: actual value,0.0, %
IDE01042,Right temperature flap: actual value,92,
IDE01043,Temperature door right - Specified value,90,
IDE01044,Right temperature flap: cold stop,110,
IDE01045,Right temperature flap: warm stop,912,
IDE01046,Temperature flap: actual value,91,
IDE01046,Temperature flap: actual value,0.00, %
IDE01047,Temperature door - Specified value,90,
IDE01048,Temperature flap: cold stop,110,
IDE01049,Temperature flap: warm stop,919,
IDE01050,Front air distribution flap: actual value,82,
IDE01050,Front air distribution flap: actual value,0.00, %
IDE01051,Air distribution door front - Specified value,82,
IDE01052,Front air distribution flap: air outlet stop,102,
IDE01053,Front air distribution flap: footwell air outlet stop,932,
IDE01054,Defroster flap: actual value,80,
IDE01054,Defroster flap: actual value,0.0, %
IDE01055,Defrost door - Specified value,81,
IDE01056,Defroster flap: stop open,101,
IDE01057,Defroster flap: stop closed,939,
IDE01059,Air distribution flap: actual value,82,
IDE01059,Air distribution flap: actual value,0.00, %
IDE01060,Air distribution flap: specified value,80,
IDE01063,Status of recirculation air,recirc. due to pull down,
IDE01065,Rear vent temperature,9.00, °C
IDE01069,Rear blower voltage: specified value,0.00, V
IDE01076,Time since ignition off,240, min
IDE01088,Rear temperature flap: actual value,69,
IDE01088,Rear temperature flap: actual value,0.0, %
IDE01089,Rear temperature flap: specified value,64,
IDE01090,Rear temperature flap: cold stop,84,
IDE01091,Rear temperature flap: warm stop,944,
IDE01226,Blower voltage: actual value,4.90, V
IDE01227,Blower current,1.50, A
IDE01232,Supply voltage for external components,5.00, V
IDE01419,Compressor shut-off condition: last,Compressor active: no shut-off condition is present,
IDE01420,Compressor shut-off requirement: penultimate,Compressor active: no shut-off condition is present,
IDE01421,Compressor shut-off requirement: antepenultimate,Compressor active: no shut-off condition is present,
IDE01433,Air quality status,not installed,
IDE01442-MAS01533,Pressing a button-Defrost,operated,
IDE01442-MAS01534,Pressing a button-Recirculating air,operated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,operated,
IDE01442-MAS01550,Pressing a button-AC,operated,
IDE01442-MAS01554,Pressing a button-Left heated seat,operated,
IDE01442-MAS01556,Pressing a button-Right heated seat,operated,
IDE01442-MAS01560,Pressing a button-OFF,Not operated,
IDE01442-MAS01564,Pressing a button-Windshield defogger,Not operated,
IDE01442-MAS01577,Pressing a button-Auxiliary heating,operated,
IDE01442-MAS02015,Pressing a button-AUTO,operated,
IDE01442-MAS02192,Pressing a button-SYNC,operated,
IDE01442-MAS03196,Pressing a button-Menu,operated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,operated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,operated,
IDE01442-MAS03832,Pressing a button-Air distribution up,operated,
IDE01442-MAS04605,Pressing a button-AC MAX,operated,
IDE01448,Actual value of heated front window,OFF,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,0, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,6502.90, °C
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,6502.90, °C
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,27.40, °C
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,29.50, °C
IDE01540-MAS07052,Left front heated seat-Setting,OFF,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,655.35, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,655.35, kOhm
IDE01540-MAS07921,Left front heated seat-Balance setting,Neutral,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,99.00, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,6503.00, °C
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,6503.00, °C
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not active,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not active,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,55.54, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,0, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,6502.90, °C
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,6502.90, °C
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,27.80, °C
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,31.10, °C
IDE01541-MAS07052,Right front heated seat-Setting,OFF,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,655.35, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,655.35, kOhm
IDE01541-MAS07921,Right front heated seat-Balance setting,Neutral,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,99.00, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,6503.00, °C
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,6503.00, °C
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not active,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not coded / not installed,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,55.54, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,not coded / not installed,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,not coded / not installed,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,not coded / not installed,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),65534,
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),65534,
IDE01694-MAS01767,Left rear seat heater-Left rear seat heater stage,0,
IDE01694-MAS01768,Left rear seat heater-Left rear seat heater specified temperature,0.0, °C
IDE01694-MAS01769,Left rear seat heater-Left rear seat heater actual temperature,0.0, °C
IDE01694-MAS01770,Left rear seat heater-Left rear seat heater current,0.00, A
IDE01695-MAS01771,Right rear seat heater-Right rear seat heater stage,0,
IDE01695-MAS01772,Right rear seat heater-Right rear seat heater specified temperature,0.0, °C
IDE01695-MAS01773,Right rear seat heater-Right rear seat heater actual temperature,0.0, °C
IDE01695-MAS01774,Right rear seat heater-Right rear seat heater current,0.00, A
IDE02270-IDE01268,CAN input signal(s) status-Front windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management: shut-off stage,Deactivation stage 0,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamps,OFF,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,On,
IDE02744-IDE15944,Steering wheel heating-Energy management approval,Activation,
IDE02744-IDE15945,Steering wheel heating-Heater parameter set,n/a,
IDE02744-MAS01632,Steering wheel heating-Status,switched off,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,Stage 1,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,operated,
IDE02744-MAS09022,Steering wheel heating-PWM value,0, %
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,33, °C
IDE03008-IDE80251,Stop process prevented-Neck heating,not active,
IDE03008-MAS01564,Stop process prevented-Windshield defogger,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS04354,Stop process prevented-Interior comfort humidity too high (humidity sensor),active,
IDE03008-MAS05009,Stop process prevented-A/C request: auxiliary heat mode,not active,
IDE03008-MAS05046,Stop process prevented-Evaporator temperature difference from setting,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03010-IDE80251,Number of prevented stop processes-Neck heating,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01564,Number of prevented stop processes-Windshield defogger,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,0,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,0,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),0,
IDE03010-MAS05009,Number of prevented stop processes-A/C request: auxiliary heat mode,0,
IDE03010-MAS05046,Number of prevented stop processes-Evaporator temperature difference from setting,0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,0,
IDE03011-IDE80251,Number of requested start processes-Neck heating,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Windshield defogger,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,0,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS03904,Number of requested start processes-Maximum permissible stop duration reached,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05009,Number of requested start processes-A/C request: auxiliary heat mode,0,
IDE03011-MAS05046,Number of requested start processes-Evaporator temperature difference from setting,0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE03537-MAS01482,Ionizer: status-Hardware version,65534,
IDE03537-MAS01483,Ionizer: status-Software version,65534,
IDE03537-MAS02829,Ionizer: status-High voltage,not coded / not installed,
IDE03537-MAS02830,Ionizer: status-Ionizer button,not coded / not installed,
IDE03537-MAS02831,Ionizer: status-Ionizer check light,not coded / not installed,
IDE03538-MAS01632,Ionizer: diagnosis-Status,No malfunction,
IDE03538-MAS02830,Ionizer: diagnosis-Ionizer button,not coded / not installed,
IDE03538-MAS02831,Ionizer: diagnosis-Ionizer check light,not coded / not installed,
IDE03538-MAS13074,Ionizer: diagnosis-Error validity status,not coded / not installed,
IDE04312-IDE04095,System run time-Engine running time,255, s
IDE04312-MAS00084,System run time-Terminal 15 on,255, s
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-MAS01447,Driving profile selection-Actual value,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE05533,Heater for nozzles,OFF,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,No,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,56.80, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,57.00, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,12.50, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,18.60, °C
IDE06163-MAS04628,Humidity sensor: exterior-Air temperature,62.10, °C
IDE06163-MAS04629,Humidity sensor: exterior-Sensor temperature,164.50, °C
IDE06163-MAS04630,Humidity sensor: exterior-Relative humidity,126.50, %
IDE06163-MAS04647,Humidity sensor: exterior-Dew point,62.10, °C
IDE06201,Blower reduction,Unknown (0)
IDE06233-MAS01632,Auxiliary heater: controlled-Status,Malfunction,
IDE06233-MAS03746,Auxiliary heater: controlled-Current: actual value,255, A
IDE06233-MAS04625,Auxiliary heater: controlled-Power: actual value,2550, W
IDE06233-MAS04626,Auxiliary heater: controlled-Power: target value,0, W
IDE06235,Potentiometer for rear vent temperature,0,
IDE06235,Potentiometer for rear vent temperature,6.375, V
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0, H
IDE06307-MAS00110,Stop prevention history data-Minutes,0, min
IDE06307-MAS00111,Stop prevention history data-Seconds,0, s
IDE06307-MAS01517,Stop prevention history data-Defrost active,not active,
IDE06307-MAS01564,Stop prevention history data-Windshield defogger,not active,
IDE06307-MAS02802,Stop prevention history data-Interior temperature difference to specifications,not active,
IDE06307-MAS02803,Stop prevention history data-Interior vent difference to setting,not active,
IDE06307-MAS02804,Stop prevention history data-Manual fan speed increase,not active,
IDE06307-MAS04353,Stop prevention history data-Fogging hazard (humidity sensor),not active,
IDE06307-MAS04354,Stop prevention history data-Interior comfort humidity too high (humidity sensor),not active,
IDE06307-MAS05009,Stop prevention history data-A/C request: auxiliary heat mode,not active,
IDE06307-MAS05046,Stop prevention history data-Evaporator temperature difference from setting,not active,
IDE06307-MAS05047,Stop prevention history data-Maximum cooling and heating set,not active,
IDE06307-MAS06551,Stop prevention history data-Seat ventilation,not active,
IDE06307-MAS09538,Stop prevention history data-max A/C,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0, H
IDE06308-MAS00110,Start request history data-Minutes,0, min
IDE06308-MAS00111,Start request history data-Seconds,0, s
IDE06308-MAS01517,Start request history data-Defrost active,not active,
IDE06308-MAS01564,Start request history data-Windshield defogger,not active,
IDE06308-MAS02802,Start request history data-Interior temperature difference to specifications,not active,
IDE06308-MAS02803,Start request history data-Interior vent difference to setting,not active,
IDE06308-MAS02804,Start request history data-Manual fan speed increase,not active,
IDE06308-MAS03904,Start request history data-Maximum permissible stop duration reached,not active,
IDE06308-MAS04353,Start request history data-Fogging hazard (humidity sensor),not active,
IDE06308-MAS04354,Start request history data-Interior comfort humidity too high (humidity sensor),not active,
IDE06308-MAS05009,Start request history data-A/C request: auxiliary heat mode,not active,
IDE06308-MAS05046,Start request history data-Evaporator temperature difference from setting,not active,
IDE06308-MAS05047,Start request history data-Maximum cooling and heating set,not active,
IDE06308-MAS06551,Start request history data-Seat ventilation,not active,
IDE06308-MAS09538,Start request history data-max A/C,not active,
IDE06545,Blower voltage for production routines,6.00, V
IDE06546,Interior specified temperature for production routines,22, °C
IDE06547,Air distribution for production routines,Air distribution top and footwell,
IDE06593,Air recirculation for production routines,Fresh air,
IDE07080-MAS07921,Left rear seat ventilation setting-Balance setting,not coded / not installed,
IDE07080-MAS07928,Left rear seat ventilation setting-Ventilation stage,not coded / not installed,
IDE07080-MAS07929,Left rear seat ventilation setting-Power quota setting by energy management,8382.00, %
IDE07244-MAS07921,Right rear seat ventilation setting-Balance setting,not coded / not installed,
IDE07244-MAS07928,Right rear seat ventilation setting-Ventilation stage,not coded / not installed,
IDE07244-MAS07929,Right rear seat ventilation setting-Power quota setting by energy management,8382.00, %
IDE07245-MAS01447,Left rear seat backrest fan 1: activation-Actual value,255, %
IDE07245-MAS01448,Left rear seat backrest fan 1: activation-Specified value,255, %
IDE07247-MAS01447,Left rear seat cushion fan 1: activation-Actual value,255, %
IDE07247-MAS01448,Left rear seat cushion fan 1: activation-Specified value,255, %
IDE07249-MAS01447,Right rear seat backrest fan 1: activation-Actual value,255, %
IDE07249-MAS01448,Right rear seat backrest fan 1: activation-Specified value,255, %
IDE07251-MAS01447,Right rear seat cushion fan 1: activation-Actual value,255, %
IDE07251-MAS01448,Right rear seat cushion fan 1: activation-Specified value,255, %
IDE07253-IDE11719,Installation info: rear seat ventilation-Fan 1 for left rear seat backrest,not installed,
IDE07253-IDE11720,Installation info: rear seat ventilation-Fan 1 for left rear seat cushion,not installed,
IDE07253-IDE11721,Installation info: rear seat ventilation-Fan 1 for right rear seat backrest,not installed,
IDE07253-IDE11722,Installation info: rear seat ventilation-Fan 1 for right rear seat cushion,not installed,
IDE07991-MAS04446,A/C clutch-Relay activation status,active,
IDE08364-MAS01447,Left seat backrest fan 1: activation-Actual value,0,
IDE08364-MAS01448,Left seat backrest fan 1: activation-Specified value,0, %
IDE08366-MAS01447,Left seat seat cushion fan 1: activation-Actual value,0, %
IDE08366-MAS01448,Left seat seat cushion fan 1: activation-Specified value,0, %
IDE08367-MAS01447,Left seat seat cushion fan 2: activation-Actual value,255,
IDE08367-MAS01448,Left seat seat cushion fan 2: activation-Specified value,255, %
IDE08368-MAS01447,Right seat backrest fan 1: activation-Actual value,0,
IDE08368-MAS01448,Right seat backrest fan 1: activation-Specified value,0, %
IDE08370-MAS01447,Right seat cushion fan 1: activation-Actual value,0,
IDE08370-MAS01448,Right seat cushion fan 1: activation-Specified value,0, %
IDE08371-MAS01447,Right seat cushion fan 2: activation-Actual value,255,
IDE08371-MAS01448,Right seat cushion fan 2: activation-Specified value,255, %
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,OFF,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,0,
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),0,
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,Neutral,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,OFF,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,99.00, %
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,Neutral,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,OFF,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,99.00, %
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Separate activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Separate activation of backrest and seat cushion,
IDE08962-IDE08356,Installation info: seat ventilation-Left seat backrest fan 1,installed,
IDE08962-IDE08358,Installation info: seat ventilation-Left seat cushion fan 1,installed,
IDE08962-IDE08359,Installation info: seat ventilation-Left seat cushion fan 2,not installed,
IDE08962-IDE08360,Installation info: seat ventilation-Right seat backrest fan 1,installed,
IDE08962-IDE08362,Installation info: seat ventilation-Right seat cushion fan 1,installed,
IDE08962-IDE08363,Installation info: seat ventilation-Right seat cushion fan 2,not installed,
IDE09168-MAS01632,Refrigerant Shut-Off Valve 1-Status,closed,
IDE10300,OBD Driving Cycle detected,active,
IDE10942-MAS00788,Expansion valve 1 for refrigerant-LIN node- address,Not adapted,
IDE10942-MAS01447,Expansion valve 1 for refrigerant-Actual value,11932, %
IDE10942-MAS01448,Expansion valve 1 for refrigerant-Specified value,0, %
IDE10942-MAS02201,Expansion valve 1 for refrigerant-Temperature,128, °C
IDE10942-MAS10469,Expansion valve 1 for refrigerant-Raw value,65534,
IDE11698-MAS09216,Instrument panel temperature sensor-Sun intensity,0.00, W/m²
IDE11698-MAS13115,Instrument panel temperature sensor-Sunlight sensor: voltage,655.35, V
IDE11698-MAS13116,Instrument panel temperature sensor-Temperature sensor 1: temperature,30.000, °C
IDE11698-MAS13117,Instrument panel temperature sensor-Temperature sensor 1: resistance value,655.35, kOhm
IDE11698-MAS13118,Instrument panel temperature sensor-Temperature sensor 2: temperature,4045.938, °C
IDE11698-MAS13119,Instrument panel temperature sensor-Temperature sensor 2: resistance value,655.35, kOhm
IDE11698-MAS13179,Instrument panel temperature sensor-Temperature sensor 3: temperature,4045.938, °C
IDE11698-MAS13180,Instrument panel temperature sensor-Temperature sensor 3: resistance value,655.35, kOhm
IDE11791,Particulate matter content in air,65010, µg/m³
IDE11836,Query of the supported PIDs (0x01 - 0x20),135790593,
IDE11837,Query of the supported PIDs (0x21 - 0x40),1,
IDE11838,Query of the supported PIDs (0x41 - 0x60),0,
IDE11839,Query of the supported InfoTypes (0x01 - 0x20),0,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine is running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,not active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-IDE08704,A/C compressor initial running in: interruption conditions-Load management,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside temperature too low,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14625,A/C compressor initial running in: interruption conditions-High-voltage vehicle electrical system,not active,
IDE12500-MAS14626,A/C compressor initial running in: interruption conditions-High-voltage current limitations,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,3VVUW7RM1TM130726,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,3,
IDE13845,Production mode status,not active,
IDE14095,Wiper park position heater,not coded / not installed,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant (challenge response only),
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,3,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 28,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15414,Potentiometer for rear vent temperature - end stop cold,0,
IDE15414,Potentiometer for rear vent temperature - end stop cold,0.000, V
IDE15415,Potentiometer for rear vent temperature - end stop warm,0,
IDE15415,Potentiometer for rear vent temperature - end stop warm,0.000, V
IDE16797,Pre-ventilation: total elapsed time of the function,0, s
IDE16798,Pre-ventilation: number of functions performed,0,
IDE16799,Pre-ventilation: remaining time,1460,
IDE18268-IDE18264,Humidity/temperature sensor for seat: left front-Seat cushion humidity,255, %
IDE18268-IDE18265,Humidity/temperature sensor for seat: left front-Seat cushion temperature,127.50, °C
IDE18268-IDE18266,Humidity/temperature sensor for seat: left front-Backrest humidity,255, %
IDE18268-IDE18267,Humidity/temperature sensor for seat: left front-Temperature seat backrest,20.00, °C
IDE18269-IDE18264,Humidity/temperature sensor for seat: right front-Seat cushion humidity,255, %
IDE18269-IDE18265,Humidity/temperature sensor for seat: right front-Seat cushion temperature,127.50, °C
IDE18269-IDE18266,Humidity/temperature sensor for seat: right front-Backrest humidity,255, %
IDE18269-IDE18267,Humidity/temperature sensor for seat: right front-Temperature seat backrest,127.50, °C
IDE18270-IDE18264,Humidity/temperature sensor for seat: left rear-Seat cushion humidity,255, %
IDE18270-IDE18265,Humidity/temperature sensor for seat: left rear-Seat cushion temperature,127.50, °C
IDE18270-IDE18266,Humidity/temperature sensor for seat: left rear-Backrest humidity,255, %
IDE18270-IDE18267,Humidity/temperature sensor for seat: left rear-Temperature seat backrest,127.50, °C
IDE18271-IDE18264,Humidity/temperature sensor for seat: right rear-Seat cushion humidity,255, %
IDE18271-IDE18265,Humidity/temperature sensor for seat: right rear-Seat cushion temperature,127.50, °C
IDE18271-IDE18266,Humidity/temperature sensor for seat: right rear-Backrest humidity,255, %
IDE18271-IDE18267,Humidity/temperature sensor for seat: right rear-Temperature seat backrest,127.50, °C
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,30,
MAS00464-MAS00109,Standard - ambient data 1-Hours,12,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,9,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,8,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,496, km
MAS11297-MAS01379,Standstilll A/C: customer setting-Operating time,2, min
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 05 03 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,5,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20376-MAS01634,High-voltage air heater status: internal-Supply voltage,too High,
MAS20376-MAS02246,High-voltage air heater status: internal-Timeout,OK,
MAS20376-MAS03746,High-voltage air heater status: internal-Current: actual value,0.00, A
MAS20376-MAS05978,High-voltage air heater status: internal-High voltage supply voltage,128, V
MAS20376-MAS07055,High-voltage air heater status: internal-Response error,OK,
MAS20376-MAS09468,High-voltage air heater status: internal-Vehicle high voltage system,too High,
MAS20376-MAS09469,High-voltage air heater status: internal-HV heater: status,Unknown (10)
MAS20376-MAS10074,High-voltage air heater status: internal-Supply voltage: actual value,6.40, V
MAS20376-MAS21216,High-voltage air heater status: internal-Heater electronics and circuit board temperature (PCB),128, °C
MAS20376-MAS21217,High-voltage air heater status: internal-Heating circuit 1 status,Temperature shut-off,
MAS20376-MAS21218,High-voltage air heater status: internal-Heating circuit 2 status,Temperature shut-off,
MAS20376-MAS21219,High-voltage air heater status: internal-Heating circuit 3 status,Temperature shut-off,
MAS20376-MAS21221,High-voltage air heater status: internal-Heating circuit 4 status,Temperature shut-off,
MAS20376-MAS21222,High-voltage air heater status: internal-Current flow with heating circuit not activated,OK,
MAS20376-MAS21223,High-voltage air heater status: internal-Total current over long period of time too high,OK,
MAS20376-MAS21224,High-voltage air heater status: internal-Circuit board temperature: shut-off value,OK,
MAS20376-MAS21225,High-voltage air heater status: internal-Internal error (other),OK,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
ENG181012,FoD_slave_state,2,
ENG254718-IDE04332,Function_On_Demand_Unlock_ID_Status_Dev-Release code for a SWaP function,Available,
ENG254718-IDE05814,Function_On_Demand_Unlock_ID_Status_Dev-Individualization characteristic,invalid,
ENG254718-IDE06260,Function_On_Demand_Unlock_ID_Status_Dev-ID number,268763904,
ENG254718-MAS01340,Function_On_Demand_Unlock_ID_Status_Dev-Functions,Available,
ENG254718-MAS01903,Function_On_Demand_Unlock_ID_Status_Dev-Configuration,OK,
ENG254718-MAS02934,Function_On_Demand_Unlock_ID_Status_Dev-Preconditions met,Condition not met,
ENG254718-MAS05616,Function_On_Demand_Unlock_ID_Status_Dev-Cancellation,not_canceled,
ENG254718-MAS05617,Function_On_Demand_Unlock_ID_Status_Dev-Authentication,Condition met,
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,5,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
Elapsed Time: 00:36
;SW:5WA-937-084-AR HW:5WA-937-084-R --- 09: Cent. Elect.
;Component:BCM37w_H H26 0350, Coding:
;EV_BCMwBL,005001,EV_BCMwBL_005.rod
;Wednesday,30,September,2026,12:00:26:11564
;VCID: 1F13BC11F73F0E32F2B-804A-R SFD+SFD2 {x}
IDE00001,Production mode,not active,
IDE00301,Distance,496, km
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,not coded / not installed,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,not coded / not installed,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,not coded / not installed,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,not coded / not installed,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,not coded / not installed,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,not coded / not installed,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,not coded / not installed,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,not coded / not installed,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,not coded / not installed,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,not coded / not installed,
IDE00973,Outside temperature,34.00, °C
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,active,
IDE01992-SFT00183,Installation list: current installations-Interface for access/start system,active,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,not active,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,not active,
IDE01992-SFT33031,Installation list: current installations-Antenna module,not active,
IDE01992-SFT33054,Installation list: current installations-Burglary protection control module 1 VL,not active,
IDE01992-SFT33055,Installation list: current installations-Burglary protection control module 2 VR,not active,
IDE01992-SFT33056,Installation list: current installations-Burglary protection control module 3 HL,not active,
IDE01992-SFT33057,Installation list: current installations-Burglary protection control module 4 HR,not active,
IDE01992-SFT33058,Installation list: current installations-Burglary protection control module 5 vehicle interior,not active,
IDE01996-SFT00009,Installation list: specified installations-Electronic central electric,active,
IDE01996-SFT00183,Installation list: specified installations-Interface for access/start system,active,
IDE01996-SFT00214,Installation list: specified installations-Light Control Left 2,not active,
IDE01996-SFT00215,Installation list: specified installations-Light Control Right 2,not active,
IDE01996-SFT33031,Installation list: specified installations-Antenna module,not active,
IDE01996-SFT33054,Installation list: specified installations-Burglary protection control module 1 VL,not active,
IDE01996-SFT33055,Installation list: specified installations-Burglary protection control module 2 VR,not active,
IDE01996-SFT33056,Installation list: specified installations-Burglary protection control module 3 HL,not active,
IDE01996-SFT33057,Installation list: specified installations-Burglary protection control module 4 HR,not active,
IDE01996-SFT33058,Installation list: specified installations-Burglary protection control module 5 vehicle interior,not active,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,Signal from door lock: engaged,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlock button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,Not operated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,Closed,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,Closed,
IDE02092-MAS09072,Tailgate condition-Locking mechanism button in the rear lid,Not operated,
IDE02711-IDE05228,Rear wiper-Operating hour counter,03 00 00 00 0E 00 00 00 45 52 5F 4D 59 4A 54 4C 00 02 47 33 39 37 5F 52 4C 46 53 53 20 20 20 00,
IDE02711-MAS01632,Rear wiper-Status,not active,
IDE02711-MAS20299,Rear wiper-Wiper level: steering column switch module,switched off,
IDE02711-MAS20300,Rear wiper-Actual wiper level,not active,
IDE02857-IDE03111,Activation current-Interior lighting,0, mA
IDE02857-IDE06012,Activation current-Background lighting,27, mA
IDE02857-MAS01288,Activation current-Horn,No malfunction,
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,Measuring value not available,
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,not ready for sleep,
IDE03150-SFT00183,Readiness for bus sleep mode-Interface for access/start system,not ready for sleep,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,not ready for sleep,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,not ready for sleep,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna module,not ready for sleep,
IDE03150-SFT33054,Readiness for bus sleep mode-Burglary protection control module 1 VL,not ready for sleep,
IDE03150-SFT33055,Readiness for bus sleep mode-Burglary protection control module 2 VR,not ready for sleep,
IDE03150-SFT33056,Readiness for bus sleep mode-Burglary protection control module 3 HL,not ready for sleep,
IDE03150-SFT33057,Readiness for bus sleep mode-Burglary protection control module 4 HR,not ready for sleep,
IDE03150-SFT33058,Readiness for bus sleep mode-Burglary protection control module 5 vehicle interior,not ready for sleep,
IDE03150-SFT33111,Readiness for bus sleep mode-Burglary protection control module 6: vehicle interior 2,not ready for sleep,
IDE03150-SFT33112,Readiness for bus sleep mode-Burglary protection control module 7: vehicle interior 3,not ready for sleep,
IDE03150-SFT33113,Readiness for bus sleep mode-Burglary protection control module 8: vehicle interior 4,not ready for sleep,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE05742,Expanded freeze frame conditions-Light switch position,automatic,
IDE04347-MAS01458,Expanded freeze frame conditions-Operating State,Normal mode,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,34.00, °C
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,14.40, V
IDE04347-MAS09388,Expanded freeze frame conditions-Engine run,On,
IDE04347-MAS15304,Expanded freeze frame conditions-Status drive readiness,not ready to drive,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,OFF,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,OFF,
IDE04639,Last wake-up cause,no cause for fault protection,
IDE05042-MAS03873,Emergency flasher button-Pulse duty factor,14.00, %
IDE05045-MAS02832,Front wiper module-Malfunction status,No malfunction,
IDE05045-MAS03638,Front wiper module-Wipe speed,0 revolutions per minute,
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,3900,
IDE05045-MAS05878,Front wiper module-level,not coded / not installed,
IDE05045-MAS09627,Front wiper module-Error status: wiper 2,No malfunction,
IDE05045-MAS22050,Front wiper module-Relay activation stage 1,not active,
IDE05045-MAS22051,Front wiper module-Relay activation stage 2,not active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded / not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05827,Horn for anti-theft warning system,not coded / not installed,
IDE05834-MAS00212,Driver info-Washer fluid low,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded / not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal status,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,101200, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,6126, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE06507-MAS13127,Button in center console-Status of button 1,not coded / not installed,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,not coded / not installed,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded / not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded / not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded / not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded / not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded / not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded / not installed,
IDE06649-MAS05016,Wireless transmitter-Receiver status,not installed,
IDE06649-MAS05048,Wireless transmitter-Number of transmitters adapted,0,
IDE06649-MAS19499,Wireless transmitter-Radio remote control 1 for remote start: identification,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06649-MAS19500,Wireless transmitter-Radio remote control 2 for remote start: identification,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,09,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE08164-MAS06256,TSG driver side rear: signals for central locking-Status door lock,unlocked,
IDE08164-MAS06431,TSG driver side rear: signals for central locking-Door contact switch,closed,
IDE08164-MAS06432,TSG driver side rear: signals for central locking-Interior lock switch,Not operated,
IDE08164-MAS06433,TSG driver side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08165-MAS06256,TSG frt.pass. side rear: signals for central locking-Status door lock,unlocked,
IDE08165-MAS06431,TSG frt.pass. side rear: signals for central locking-Door contact switch,closed,
IDE08165-MAS06432,TSG frt.pass. side rear: signals for central locking-Interior lock switch,Not operated,
IDE08165-MAS06433,TSG frt.pass. side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08185,Counter for play protection of central locking,not active,
IDE08211-MAS03129,History data control module reset-Reset counter,16,
IDE08211-ENG370721,History data control module reset-Field for Iteration,|last cause of reset,Year
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,1C,
IDE08235-MAS06799,Status of immobilizer participant-Immobilizer status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,F8,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-OCU status,00,
IDE08235-MAS06807,Status of immobilizer participant-VTS status,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,Yes,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,Yes,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,No,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,No,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,No,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,0,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,0,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,0,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,0,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,0,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,0,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,0,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,CC 39 36 B2,
IDE08240,Transponder ID Key 2,35 3A 36 B2,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,00 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE08251-MAS11095,Configuration immobilizer-cause:,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,3D 30 C9 0F,
IDE08343,Immobilizer Challenge,8D 60 2D 6F,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,14, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,14, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,40, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,57, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,not coded / not installed,
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,not coded / not installed,
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07881,Operating current: light driver-Conn. pin 14,not coded / not installed,
IDE08949-MAS07882,Operating current: light driver-Conn. pin 15,not coded / not installed,
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,44, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,48, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07895,Operating current: light driver-Conn. pin 28,14, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE08949-MAS07898,Operating current: light driver-Conn. pin 31,4, mA
IDE08949-MAS07899,Operating current: light driver-Conn. pin 32,4, mA
IDE08949-MAS07900,Operating current: light driver-Conn. pin 33,4, mA
IDE08949-MAS07901,Operating current: light driver-Conn. pin 34,4, mA
IDE08949-MAS20146,Operating current: light driver-Conn. pin 35,not coded / not installed,
IDE08949-MAS20147,Operating current: light driver-Conn. pin 36,not coded / not installed,
IDE08949-MAS20148,Operating current: light driver-Conn. pin 37,not coded / not installed,
IDE08949-MAS20149,Operating current: light driver-Conn. pin 38,not coded / not installed,
IDE08949-MAS20150,Operating current: light driver-Conn. pin 39,not coded / not installed,
IDE08949-MAS20151,Operating current: light driver-Conn. pin 40,0, mA
IDE08949-MAS20152,Operating current: light driver-Conn. pin 41,0, mA
IDE08949-MAS21233,Operating current: light driver-Conn. pin 42,0, mA
IDE08949-MAS21234,Operating current: light driver-Conn. pin 43,0, mA
IDE08949-MAS21235,Operating current: light driver-Conn. pin 45,0, mA
IDE08949-MAS21236,Operating current: light driver-Conn. pin 44,377, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,0,
IDE10345-IDE00673,Roof electronics control module: button-Information Service Button -E450-,Not operated,
IDE10345-MAS08884,Roof electronics control module: button-Sunroof button,Not operated,
IDE10345-MAS08932,Roof electronics control module: button-Sunroof shade button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,210, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,815, W/m²
IDE11551-MAS03619,Status of identification data query on LIN-Bus-complete,Yes,
IDE11551-MAS11095,Status of identification data query on LIN-Bus-cause:,Terminal 15 on,
IDE11551-MAS12667,Status of identification data query on LIN-Bus-Specified installation of sub-bus users,11,
IDE11551-MAS12668,Status of identification data query on LIN-Bus-Actual installation of sub-bus users,11,
IDE11551-ENG303032,Status of identification data query on LIN-Bus-complete_config_hash,Yes,
IDE11551-ENG303033,Status of identification data query on LIN-Bus-complete_programming_hash,Yes,
IDE11727-MAS13125,Function of the central console button-Function of button 1,not coded / not installed,
IDE11727-MAS13128,Function of the central console button-Indicator lamp button 1,installed,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded / not installed,
IDE11727-MAS13131,Function of the central console button-Indicator lamp button 2,installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded / not installed,
IDE11727-MAS13134,Function of the central console button-Indicator lamp button 3,installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded / not installed,
IDE11727-MAS13136,Function of the central console button-Indicator lamp button 4,installed,
IDE12262-ENG356520,Virtual radio key: status-Device_auth_and_permisission,Init,
IDE12262-ENG355368,Virtual radio key: status-Ephemeral_keypair_available,Yes,
IDE12262-ENG353272,Virtual radio key: status-Mdk_system_coded,No,
IDE12262-ENG354422,Virtual radio key: status-Mdk_vehicle_id_transfer_nfc_centralconsole,No,
IDE12262-ENG354834,Virtual radio key: status-Mdk_vehicle_id_transfer_nfc_doorhandle,No,
IDE12262-ENG356609,Virtual radio key: status-Mdkccc_backend_nvm_consistent,Yes,
IDE12262-ENG353487,Virtual radio key: status-Mdkccc_config_nvm_consistent,Yes,
IDE12262-ENG353946,Virtual radio key: status-Mdkccc_key_list_nvm_consistent,Yes,
IDE12262-ENG352400,Virtual radio key: status-Mdkccc_owner_conf_nvm_consistent,Yes,
IDE12262-ENG357291,Virtual radio key: status-Mdkccc_service_card_nvm_consistent,Yes,
IDE12262-ENG353419,Virtual radio key: status-Not_authorized_reason,No_error_description,
IDE12262-ENG355337,Virtual radio key: status-Owner_paired,No,
IDE12262-ENG354138,Virtual radio key: status-Owner_pairing_long_term_keypair,invalid,
IDE12262-ENG352847,Virtual radio key: status-Owner_pairing_verifier,invalid,
IDE12262-ENG354351,Virtual radio key: status-Pairing_active,No,
IDE12262-ENG357247,Virtual radio key: status-Servicecard_active,No,
IDE12262-ENG354528,Virtual radio key: status-Status_immotoken,Init,
IDE12262-ENG356037,Virtual radio key: status-System_activated,No,
IDE12262-ENG356733,Virtual radio key: status-Transaction_id_available,Yes,
IDE12262-ENG352422,Virtual radio key: status-Vehicle_config_available,No,
IDE12262-ENG356198,Virtual radio key: status-Vehicle_id_available,No,
IDE12262-ENG357481,Virtual radio key: status-Vehicle_oem_cert_available,No,
IDE12264-ENG354259,Virtual radio key: ticket table-Keyid_key1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG354425,Virtual radio key: ticket table-Keyid_key10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG353187,Virtual radio key: ticket table-Keyid_key11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG356575,Virtual radio key: ticket table-Keyid_key12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG354110,Virtual radio key: ticket table-Keyid_key13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG352704,Virtual radio key: ticket table-Keyid_key14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG357063,Virtual radio key: ticket table-Keyid_key15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG357119,Virtual radio key: ticket table-Keyid_key16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG355217,Virtual radio key: ticket table-Keyid_key2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG353450,Virtual radio key: ticket table-Keyid_key3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG353169,Virtual radio key: ticket table-Keyid_key4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG356144,Virtual radio key: ticket table-Keyid_key5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG357008,Virtual radio key: ticket table-Keyid_key6,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG355091,Virtual radio key: ticket table-Keyid_key7,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG354369,Virtual radio key: ticket table-Keyid_key8,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG357406,Virtual radio key: ticket table-Keyid_key9,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-ENG354071,Virtual radio key: ticket table-Rights_keyid_1,00,
IDE12264-ENG353110,Virtual radio key: ticket table-Rights_keyid_10,00,
IDE12264-ENG356736,Virtual radio key: ticket table-Rights_keyid_11,00,
IDE12264-ENG353247,Virtual radio key: ticket table-Rights_keyid_12,00,
IDE12264-ENG353819,Virtual radio key: ticket table-Rights_keyid_13,00,
IDE12264-ENG355057,Virtual radio key: ticket table-Rights_keyid_14,00,
IDE12264-ENG355542,Virtual radio key: ticket table-Rights_keyid_15,00,
IDE12264-ENG353274,Virtual radio key: ticket table-Rights_keyid_16,00,
IDE12264-ENG355609,Virtual radio key: ticket table-Rights_keyid_2,00,
IDE12264-ENG352140,Virtual radio key: ticket table-Rights_keyid_3,00,
IDE12264-ENG357528,Virtual radio key: ticket table-Rights_keyid_4,00,
IDE12264-ENG353967,Virtual radio key: ticket table-Rights_keyid_5,00,
IDE12264-ENG356100,Virtual radio key: ticket table-Rights_keyid_6,00,
IDE12264-ENG354731,Virtual radio key: ticket table-Rights_keyid_7,00,
IDE12264-ENG353645,Virtual radio key: ticket table-Rights_keyid_8,00,
IDE12264-ENG353373,Virtual radio key: ticket table-Rights_keyid_9,00,
IDE12264-ENG353096,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_1,00,
IDE12264-ENG356792,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_10,00,
IDE12264-ENG357530,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_11,00,
IDE12264-ENG356474,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_12,00,
IDE12264-ENG354593,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_13,00,
IDE12264-ENG354014,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_14,00,
IDE12264-ENG356212,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_15,00,
IDE12264-ENG355285,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_16,00,
IDE12264-ENG357537,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_2,00,
IDE12264-ENG355172,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_3,00,
IDE12264-ENG356714,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_4,00,
IDE12264-ENG355868,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_5,00,
IDE12264-ENG352228,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_6,00,
IDE12264-ENG354057,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_7,00,
IDE12264-ENG355620,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_8,00,
IDE12264-ENG356304,Virtual radio key: ticket table-Sharingkey_password_attempts_keyid_9,00,
IDE12466,Unlocking central locking system history data,|Control-section / cause,Key number
IDE12940-IDE01268,Lever functions of the steering column electronics-Front windshield wiper,not coded / not installed,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,not coded / not installed,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,not coded / not installed,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,NOT-DEFINED,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,NOT-DEFINED,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,NOT-DEFINED,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,not coded / not installed,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,not coded / not installed,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,not coded / not installed,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,not coded / not installed,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,not coded / not installed,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,not coded / not installed,
IDE12940,Lever functions of the steering column electronics,not coded / not installed,
IDE13345-ENG353276,Current Secure Element-Interface_mobile_device,No_connection,
IDE13345-ENG356367,Current Secure Element-Keyid_last_authenticated_key,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13345-ENG354683,Current Secure Element-Length_keyid_last_authenticated_key,00,
IDE13750-IDE01351,Input signals: control of terminal-Terminal 75 status,On,
IDE13750-IDE01715,Input signals: control of terminal-Status terminal S,not coded / not installed,
IDE13750-IDE01716,Input signals: control of terminal-Terminal 50 status,OFF,
IDE13750-IDE02572,Input signals: control of terminal-Starter button: status,not active,
IDE13750-IDE13954,Input signals: control of terminal-Starter button: status redundant,not active,
IDE13750-MAS12787,Input signals: control of terminal-Terminal 15 ignition switch signal 1,not coded / not installed,
IDE13750-MAS12788,Input signals: control of terminal-Terminal 15 ignition switch signal 2,not coded / not installed,
IDE13750-MAS17227,Input signals: control of terminal-Starter button: error status,No malfunction detected,
IDE13750-MAS17233,Input signals: control of terminal-Terminal start command,not coded / not installed,
IDE13751-IDE00020,Output signals: control of terminal-Terminal 15 status,active,
IDE13751-IDE00773,Output signals: control of terminal-Terminal 15 status via CAN,active,
IDE13751-IDE06027,Output signals: control of terminal-Terminal S status via CAN,active,
IDE13751-ENG256402,Output signals: control of terminal-Status_Terminal_Startwunsch_BCM,not active,
IDE13751-ENG255221,Output signals: control of terminal-Terminal_50_CAN,not active,
IDE13752-IDE09059,Electrical Steering Column Lock-Request terminal release,not active,
IDE13752-MAS06711,Electrical Steering Column Lock-Terminal release,not active,
IDE13752-MAS17234,Electrical Steering Column Lock-Steering column lock locked,not active,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,23,
IDE13956-IDE00075,Key position replication: input signals-Vehicle speed,0.00, km/h
IDE13956-IDE01715,Key position replication: input signals-Status terminal S,On,
IDE13956-IDE80258,Key position replication: input signals-Immobilizer status,Electronic steering locking device installed,
IDE13956-MAS01493,Key position replication: input signals-Engine is running,active,
IDE13956-MAS02248,Key position replication: input signals-Signal status,valid,
IDE13956-MAS03607,Key position replication: input signals-Engine stop active in Start/Stop mode,not active,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,On,
IDE13956-MAS05104,Key position replication: input signals-Driver request: start engine,not active,
IDE13956-MAS06711,Key position replication: input signals-Terminal release,not active,
IDE13956-MAS06793,Key position replication: input signals-Number of adapted keys,2,
IDE13956-MAS07719,Key position replication: input signals-Terminal 50 status,OFF,
IDE13956-MAS08136,Key position replication: input signals-Enabling Steering Column Lock,Condition not met,
IDE13956,Key position replication: input signals,0, s
IDE13956-ENG255532,Key position replication: input signals-clampcoordinator_approval,On,
IDE13956-ENG255625,Key position replication: input signals-diag_trigger_clampcoordinator_intern,OFF,
IDE13956-ENG256242,Key position replication: input signals-Powertrain_activation_permitted,Yes,
IDE13956-ENG129033,Key position replication: input signals-s_anf_klemmenfreigabe_wfs,not requested,
IDE13956-ENG126972,Key position replication: input signals-s_klemmenfreigabe_wfs,No enabling,
IDE13956-ENG129036,Key position replication: input signals-To_block_terminal_upshift,not active,
IDE13956-ENG256549,Key position replication: input signals-trigger_clampcoordinator_intern_for_ignition_off,OFF,
IDE13956-ENG256550,Key position replication: input signals-trigger_clampkoordinator_intern_for_ignition_on,OFF,
IDE13956-ENG256551,Key position replication: input signals-Trigger_terminal_15_shutoff,No,
IDE13956-ENG129038,Key position replication: input signals-Valid_time_control_section_diagnostics,0, s
IDE14238-MAS02282,Wiper arm position-Position,0.0, °
IDE14238-MAS19580,Wiper arm position-Alternating park position,Alternating park position 1,
IDE14328-MAS19447,Back flash safety version of software blocks-Versioning,01,
IDE14328,Back flash safety version of software blocks,|Rear flash protection: minimal version,Rear flash protection: current version|0003
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,1,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 7C,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 65 F0 A7 B9 49 24 9B,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,9,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 07,
IDE14958-SFT00002,Recognized actual fitting list: adapt-Transmission Electronics,detected,
IDE14958-SFT00005,Recognized actual fitting list: adapt-Access/start authorization,detected,
IDE14958-SFT00006,Recognized actual fitting list: adapt-Seat adjustment: passenger's side,detected,
IDE14958-SFT00008,Recognized actual fitting list: adapt-HVAC electronics,detected,
IDE14958-SFT00022,Recognized actual fitting list: adapt-Steering Column Electronics,detected,
IDE14958-SFT00023,Recognized actual fitting list: adapt-Instrument cluster,detected,
IDE14958-SFT00025,Recognized actual fitting list: adapt-Data Bus OBD Interface,detected,
IDE14958-SFT00038,Recognized actual fitting list: adapt-Convertible top operation,not recognised,
IDE14958-SFT00043,Recognized actual fitting list: adapt-Steering column lock,not recognised,
IDE14958-SFT00054,Recognized actual fitting list: adapt-Seat adjustment: driver side,detected,
IDE14958-SFT00061,Recognized actual fitting list: adapt-Special Function,not recognised,
IDE14958-SFT00105,Recognized actual fitting list: adapt-Trailer Function,not recognised,
IDE14958-SFT00106,Recognized actual fitting list: adapt-Automatic door: rear driver side,not recognised,
IDE14958-SFT00109,Recognized actual fitting list: adapt-Rear lid electronics,detected,
IDE14958-SFT00118,Recognized actual fitting list: adapt-Parking aid,detected,
IDE14958-SFT00122,Recognized actual fitting list: adapt-Automatic door: rear passenger side,not recognised,
IDE14958-SFT00165,Recognized actual fitting list: adapt-Front sensor for driver assistance systems,detected,
IDE14958-SFT00202,Recognized actual fitting list: adapt-Sunroof control module,detected,
IDE14958-SFT00214,Recognized actual fitting list: adapt-Light Control Left 2,not recognised,
IDE14958-SFT00215,Recognized actual fitting list: adapt-Light Control Right 2,not recognised,
IDE14958-SFT00222,Recognized actual fitting list: adapt-charging device 1 for mobile end device,not recognised,
IDE14958-SFT33031,Recognized actual fitting list: adapt-Antenna module,not recognised,
IDE14958-SFT33054,Recognized actual fitting list: adapt-Burglary protection control module 1 VL,not recognised,
IDE14958-SFT33055,Recognized actual fitting list: adapt-Burglary protection control module 2 VR,not recognised,
IDE14958-SFT33056,Recognized actual fitting list: adapt-Burglary protection control module 3 HL,not recognised,
IDE14958-SFT33057,Recognized actual fitting list: adapt-Burglary protection control module 4 HR,not recognised,
IDE14958-SFT33058,Recognized actual fitting list: adapt-Burglary protection control module 5 vehicle interior,not recognised,
IDE14958-SFT33111,Recognized actual fitting list: adapt-Burglary protection control module 6: vehicle interior 2,not recognised,
IDE14958-SFT33112,Recognized actual fitting list: adapt-Burglary protection control module 7: vehicle interior 3,not recognised,
IDE14958-SFT33113,Recognized actual fitting list: adapt-Burglary protection control module 8: vehicle interior 4,not recognised,
IDE14958-SFT271890,Recognized actual fitting list: adapt-Driver door control module,detected,
IDE14958-SFT271891,Recognized actual fitting list: adapt-Front passenger door control module,detected,
IDE14958-SFT271948,Recognized actual fitting list: adapt-Left rear door control module,detected,
IDE14958-SFT271949,Recognized actual fitting list: adapt-Right rear door control module,detected,
IDE14958-SFT272107,Recognized actual fitting list: adapt-Antenna for short-range communication,not recognised,
IDE14958-ENG251481,Recognized actual fitting list: adapt-Klr,detected,
IDE14958-ENG356590,Recognized actual fitting list: adapt-MIK,not recognised,
IDE14958-ENG353028,Recognized actual fitting list: adapt-SBM,detected,
IDE14958-ENG357342,Recognized actual fitting list: adapt-UWB_BT_HR,not recognised,
IDE14958-ENG354330,Recognized actual fitting list: adapt-UWB_BT_IN,not recognised,
IDE14958-ENG356451,Recognized actual fitting list: adapt-UWB_BT_VL,not recognised,
IDE14958-ENG353480,Recognized actual fitting list: adapt-UWB_HL,not recognised,
IDE14958-ENG352338,Recognized actual fitting list: adapt-UWB_VR,not recognised,
IDE14959,Tailgate opening: reason for non-availability,Terminal 15 active,
IDE14993-MAS19447,Software composition list identification data-Versioning,01,
IDE14993-MAS20341,Software composition list identification data-Number of software composition,00 3B,
IDE14993-ENG370721,Software composition list identification data-Field for Iteration,|Software Composition ID,System designation
IDE15048-ENG255825,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_CAN,unrestricted,
IDE15048-ENG255826,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_SR,unrestricted,
IDE15048-ENG255827,Output signals: terminal coordinator-KST_Request_Clamp_15,CL_15_HW_AND_CAN,
IDE15048-ENG255828,Output signals: terminal coordinator-KST_Specialstate_Request_CAN,Initialization,
IDE15048-ENG255829,Output signals: terminal coordinator-KST_Specialstate_Request_SR,Initialization,
IDE15048-ENG255830,Output signals: terminal coordinator-KST_Specialstate_Status_CAN,active,
IDE15048-ENG255831,Output signals: terminal coordinator-KST_Specialstate_Status_SR,active,
IDE15049-IDE09065,Input signals: terminal coordinator-Status: remote start,Initialization,
IDE15049-MAS20292,Input signals: terminal coordinator-Key position reproduction: status,active,
IDE15049-MAS20294,Input signals: terminal coordinator-Key position reproduction: terminal query,Terminal 15: discrete and CAN,
IDE15049-MAS20297,Input signals: terminal coordinator-Key position replication: immobilizer request,unrestricted,
IDE15049-MAS20298,Input signals: terminal coordinator-Terminal 15 via diagnostic: query status,Initialization,
IDE15049-ENG263759,Input signals: terminal coordinator-AAA_Request_Clamp_15,none,
IDE15049-ENG263760,Input signals: terminal coordinator-AAA_Request_Immobiliser_Level,none,
IDE15049-ENG263761,Input signals: terminal coordinator-AAA_Request_Status,Initialization,
IDE15049-ENG263762,Input signals: terminal coordinator-MWS_Request_Clamp_15,none,
IDE15049-ENG263763,Input signals: terminal coordinator-MWS_Request_Immobiliser_Level,none,
IDE15049-ENG263764,Input signals: terminal coordinator-MWS_Request_Status,Initialization,
IDE15049-ENG263765,Input signals: terminal coordinator-PHP_Request_Clamp_15,none,
IDE15049-ENG263766,Input signals: terminal coordinator-PHP_Request_Immobiliser_Level,none,
IDE15049-ENG263767,Input signals: terminal coordinator-PHP_Request_Status,Initialization,
IDE15049-ENG263768,Input signals: terminal coordinator-RPA_Request_Clamp_15,none,
IDE15049-ENG263769,Input signals: terminal coordinator-RPA_Request_Immobiliser_Level,none,
IDE15049-ENG263770,Input signals: terminal coordinator-RPA_Request_Status,Initialization,
IDE15049-ENG263771,Input signals: terminal coordinator-RST_Request_Clamp_15,none,
IDE15049-ENG263772,Input signals: terminal coordinator-RST_Request_Immobiliser_Level,none,
IDE15049-ENG263773,Input signals: terminal coordinator-RWK_Request_Clamp_15,none,
IDE15049-ENG263774,Input signals: terminal coordinator-RWK_Request_Immobiliser_Level,none,
IDE15049-ENG263775,Input signals: terminal coordinator-RWK_Request_Status,Initialization,
IDE15049-ENG263776,Input signals: terminal coordinator-ZAS_Request_Clamp_15,none,
IDE15049-ENG263777,Input signals: terminal coordinator-ZAS_Request_Immobiliser_Level,none,
IDE15049-ENG263778,Input signals: terminal coordinator-ZAS_Request_Status,Initialization,
IDE15176-IDE15177,Remote start function: mobile online services-Remote start function: captcha list of mobile online services,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15176-IDE15178,Remote start function: mobile online services-Remote start function: online service communication key,00 00 00 00 00 00 00 00,
IDE16364-MAS25708,List of identifiers and data record numbers-Number Of Identifiers,00 00,
IDE16364,List of identifiers and data record numbers,|Identifier|00 00|,
IDE17075-MAS06854,Functions that can be enabled: FoD slave enhanced status-Version,11,
IDE17075-MAS27237,Functions that can be enabled: FoD slave enhanced status-Length of reference data,53,
IDE17075-MAS27238,Functions that can be enabled: FoD slave enhanced status-Reference data of enhanced status,00 01 00 D6 03 03 00 02 00 00 03 03 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 C8 00 00 75 30 00 05 7E 40 00 00 03 E8 00 0A 01 05 22 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE19082-MAS04649,Localization information from connected mobile end devices-Cell 1,00000000 ,
IDE19082-MAS04650,Localization information from connected mobile end devices-Cell 2,00000000 ,
IDE19082-MAS04651,Localization information from connected mobile end devices-Cell 3,00000000 ,
IDE19082-MAS04652,Localization information from connected mobile end devices-Cell 4,00000000 ,
IDE19082-MAS04653,Localization information from connected mobile end devices-Cell 5,00000000 ,
IDE19082-MAS04654,Localization information from connected mobile end devices-Cell 6,00000000 ,
IDE19082-MAS04655,Localization information from connected mobile end devices-Cell 7,00000000 ,
IDE19082-MAS04656,Localization information from connected mobile end devices-Cell 8,00000000 ,
IDE19082-MAS04657,Localization information from connected mobile end devices-Cell 9,00000000 ,
IDE19082-MAS04658,Localization information from connected mobile end devices-Cell 10,00000000 ,
IDE19082-MAS04659,Localization information from connected mobile end devices-Cell 11,00000000 ,
IDE19082-MAS04660,Localization information from connected mobile end devices-Cell 12,00000000 ,
IDE19082-MAS04661,Localization information from connected mobile end devices-Cell 13,00000000 ,
IDE19082-MAS04662,Localization information from connected mobile end devices-Cell 14,00000000 ,
IDE19082-MAS04663,Localization information from connected mobile end devices-Cell 15,00000000 ,
IDE19082-MAS04664,Localization information from connected mobile end devices-Cell 16,00000000 ,
IDE19082-MAS04665,Localization information from connected mobile end devices-Cell 17,00000000 ,
IDE19082-MAS04666,Localization information from connected mobile end devices-Cell 18,00000000 ,
IDE19082-MAS04667,Localization information from connected mobile end devices-Cell 19,00000000 ,
IDE19082-MAS04668,Localization information from connected mobile end devices-Cell 20,00000000 ,
IDE19082-MAS04669,Localization information from connected mobile end devices-Cell 21,00000000 ,
IDE19082-MAS04670,Localization information from connected mobile end devices-Cell 22,00000000 ,
IDE19082-MAS04671,Localization information from connected mobile end devices-Cell 23,00000000 ,
IDE19082-MAS04672,Localization information from connected mobile end devices-Cell 24,00000000 ,
IDE19082-MAS04673,Localization information from connected mobile end devices-Cell 25,00000000 ,
IDE19082-MAS04674,Localization information from connected mobile end devices-Cell 26,00000000 ,
IDE19082-MAS04675,Localization information from connected mobile end devices-Cell 27,00000000 ,
IDE19082-MAS04676,Localization information from connected mobile end devices-Cell 28,00000000 ,
IDE19082-MAS04677,Localization information from connected mobile end devices-Cell 29,00000000 ,
IDE19082-MAS04678,Localization information from connected mobile end devices-Cell 30,00000000 ,
IDE19082-MAS04679,Localization information from connected mobile end devices-Cell 31,00000000 ,
IDE19082-MAS04680,Localization information from connected mobile end devices-Cell 32,00000000 ,
IDE19082-MAS04681,Localization information from connected mobile end devices-Cell 33,00000000 ,
IDE19082-MAS04682,Localization information from connected mobile end devices-Cell 34,00000000 ,
IDE19082-MAS04683,Localization information from connected mobile end devices-Cell 35,00000000 ,
IDE19082-MAS04684,Localization information from connected mobile end devices-Cell 36,00000000 ,
IDE19082-MAS04685,Localization information from connected mobile end devices-Cell 37,00000000 ,
IDE19082-MAS04686,Localization information from connected mobile end devices-Cell 38,00000000 ,
IDE19082-MAS04687,Localization information from connected mobile end devices-Cell 39,00000000 ,
IDE19082-MAS04688,Localization information from connected mobile end devices-Cell 41,00000000 ,
IDE19082-MAS04689,Localization information from connected mobile end devices-Cell 42,00000000 ,
IDE19082-MAS04690,Localization information from connected mobile end devices-Cell 43,00000000 ,
IDE19082-MAS04691,Localization information from connected mobile end devices-Cell 44,00000000 ,
IDE19082-MAS04692,Localization information from connected mobile end devices-Cell 45,00000000 ,
IDE19082-MAS04693,Localization information from connected mobile end devices-Cell 46,00000000 ,
IDE19082-MAS04694,Localization information from connected mobile end devices-Cell 47,00000000 ,
IDE19082-MAS04695,Localization information from connected mobile end devices-Cell 48,00000000 ,
IDE19082-MAS04696,Localization information from connected mobile end devices-Cell 49,00000000 ,
IDE19082-MAS04697,Localization information from connected mobile end devices-Cell 50,00000000 ,
IDE19082-MAS04698,Localization information from connected mobile end devices-Cell 51,00000000 ,
IDE19082-MAS04699,Localization information from connected mobile end devices-Cell 52,00000000 ,
IDE19082-MAS04700,Localization information from connected mobile end devices-Cell 53,00000000 ,
IDE19082-MAS04701,Localization information from connected mobile end devices-Cell 54,00000000 ,
IDE19082-MAS04702,Localization information from connected mobile end devices-Cell 55,00000000 ,
IDE19082-MAS04703,Localization information from connected mobile end devices-Cell 56,00000000 ,
IDE19082-MAS04704,Localization information from connected mobile end devices-Cell 57,00000000 ,
IDE19082-MAS04705,Localization information from connected mobile end devices-Cell 58,00000000 ,
IDE19082-MAS04706,Localization information from connected mobile end devices-Cell 59,00000000 ,
IDE19082-MAS04707,Localization information from connected mobile end devices-Cell 60,00000000 ,
IDE19082-MAS04708,Localization information from connected mobile end devices-Cell 61,00000000 ,
IDE19082-MAS04709,Localization information from connected mobile end devices-Cell 62,00000000 ,
IDE19082-MAS04710,Localization information from connected mobile end devices-Cell 63,00000000 ,
IDE19082-MAS04711,Localization information from connected mobile end devices-Cell 64,00000000 ,
IDE19082-MAS04720,Localization information from connected mobile end devices-Cell 40,00000000 ,
IDE19082-ENG352135,Localization information from connected mobile end devices-Executed_job,0,
IDE19082-ENG356009,Localization information from connected mobile end devices-Job_1,0,
IDE19082-ENG353431,Localization information from connected mobile end devices-Job_2,0,
IDE19082-ENG355812,Localization information from connected mobile end devices-Job_3,0,
IDE19082-ENG356015,Localization information from connected mobile end devices-Job_4,0,
IDE19082-ENG352311,Localization information from connected mobile end devices-Job_5,0,
IDE19082-ENG353615,Localization information from connected mobile end devices-Job_6,0,
IDE19082-ENG355077,Localization information from connected mobile end devices-Job_7,0,
IDE19082-ENG352675,Localization information from connected mobile end devices-SD1_authentication_last_result,Initialization,
IDE19082-ENG352873,Localization information from connected mobile end devices-SD1_failed_authentication_counter,0,
IDE19082-ENG355345,Localization information from connected mobile end devices-SD1_Lock_authentication_status,not authenticated,
IDE19082-ENG353650,Localization information from connected mobile end devices-SD1_Other_authentication_status,not authenticated,
IDE19082-ENG355980,Localization information from connected mobile end devices-SD1_Unlock_authentication_status,not authenticated,
IDE19082-ENG356501,Localization information from connected mobile end devices-SD2_authentication_last_result,Initialization,
IDE19082-ENG353164,Localization information from connected mobile end devices-SD2_failed_authentication_counter,0,
IDE19082-ENG355729,Localization information from connected mobile end devices-SD2_Lock_authentication_status,not authenticated,
IDE19082-ENG354577,Localization information from connected mobile end devices-SD2_Other_authentication_status,not authenticated,
IDE19082-ENG352820,Localization information from connected mobile end devices-SD2_Unlock_authentication_status,not authenticated,
IDE19082-ENG352946,Localization information from connected mobile end devices-SD3_authentication_last_result,Initialization,
IDE19082-ENG354404,Localization information from connected mobile end devices-SD3_failed_authentication_counter,0,
IDE19082-ENG354733,Localization information from connected mobile end devices-SD3_Lock_authentication_status,not authenticated,
IDE19082-ENG353762,Localization information from connected mobile end devices-SD3_Other_authentication_status,not authenticated,
IDE19082-ENG355910,Localization information from connected mobile end devices-SD3_Unlock_authentication_status,not authenticated,
IDE19082-ENG354140,Localization information from connected mobile end devices-SD4_authentication_last_result,Initialization,
IDE19082-ENG355213,Localization information from connected mobile end devices-SD4_failed_authentication_counter,0,
IDE19082-ENG352955,Localization information from connected mobile end devices-SD4_Lock_authentication_status,not authenticated,
IDE19082-ENG355081,Localization information from connected mobile end devices-SD4_Other_authentication_status,not authenticated,
IDE19082-ENG356728,Localization information from connected mobile end devices-SD4_Unlock_authentication_status,not authenticated,
IDE19082-ENG354761,Localization information from connected mobile end devices-SD5_authentication_last_result,Initialization,
IDE19082-ENG354357,Localization information from connected mobile end devices-SD5_failed_authentication_counter,0,
IDE19082-ENG353084,Localization information from connected mobile end devices-SD5_Lock_authentication_status,not authenticated,
IDE19082-ENG357090,Localization information from connected mobile end devices-SD5_Other_authentication_status,not authenticated,
IDE19082-ENG354764,Localization information from connected mobile end devices-SD5_Unlock_authentication_status,not authenticated,
IDE19082-ENG357385,Localization information from connected mobile end devices-SD6_authentication_last_result,Initialization,
IDE19082-ENG352284,Localization information from connected mobile end devices-SD6_failed_authentication_counter,0,
IDE19082-ENG354691,Localization information from connected mobile end devices-SD6_Lock_authentication_status,not authenticated,
IDE19082-ENG355970,Localization information from connected mobile end devices-SD6_Other_authentication_status,not authenticated,
IDE19082-ENG352927,Localization information from connected mobile end devices-SD6_Unlock_authentication_status,not authenticated,
IDE19082-ENG357550,Localization information from connected mobile end devices-SD7_authentication_last_result,Initialization,
IDE19082-ENG356475,Localization information from connected mobile end devices-SD7_failed_authentication_counter,0,
IDE19082-ENG355735,Localization information from connected mobile end devices-SD7_Lock_authentication_status,not authenticated,
IDE19082-ENG355363,Localization information from connected mobile end devices-SD7_Other_authentication_status,not authenticated,
IDE19082-ENG352685,Localization information from connected mobile end devices-SD7_Unlock_authentication_status,not authenticated,
IDE19082-ENG352978,Localization information from connected mobile end devices-SD8_authentication_last_result,Initialization,
IDE19082-ENG352272,Localization information from connected mobile end devices-SD8_failed_authentication_counter,0,
IDE19082-ENG355483,Localization information from connected mobile end devices-SD8_Lock_authentication_status,not authenticated,
IDE19082-ENG355444,Localization information from connected mobile end devices-SD8_Other_authentication_status,not authenticated,
IDE19082-ENG354344,Localization information from connected mobile end devices-SD8_Unlock_authentication_status,not authenticated,
IDE19082-ENG416579,Localization information from connected mobile end devices-Smartdevice_1,00 00 00 00,
IDE19082-ENG416580,Localization information from connected mobile end devices-Smartdevice_2,00 00 00 00,
IDE19082-ENG416581,Localization information from connected mobile end devices-Smartdevice_3,00 00 00 00,
IDE19082-ENG416582,Localization information from connected mobile end devices-Smartdevice_4,00 00 00 00,
IDE19082-ENG416583,Localization information from connected mobile end devices-Smartdevice_5,00 00 00 00,
IDE19082-ENG416584,Localization information from connected mobile end devices-Smartdevice_6,00 00 00 00,
IDE19082-ENG416585,Localization information from connected mobile end devices-Smartdevice_7,00 00 00 00,
IDE19082-ENG416586,Localization information from connected mobile end devices-Smartdevice_8,00 00 00 00,
IDE19099-ENG370721,Virtual key: deactivation by over-the-air update-Field for Iteration,|Deactivation duration,Year
IDE19126-ENG370721,Lock vehicle history data after automatic closing-Field for Iteration,|Year,Month
IDE19127-ENG370721,Unlock/lock keyless history data-Field for Iteration,|Year,Month
IDE19128-ENG370721,Keyless event search history data-Field for Iteration,|Year,Month
IDE19129,Status of antennas for burglary protection,not active,
IDE19130-MAS07151,Field strength of ultra-wide band antennas-RSSI value,128,
IDE19132-ENG370721,Keyless start authorization for mobile end devices history data-Field for Iteration,|Year,Month
IDE19134-ENG370721,History data of locked mobile end devices-Field for Iteration,|Year,Month
IDE19135-ENG370721,Historical data of assigned identifications of mobile end devices-Field for Iteration,|Year,Month
IDE19136-ENG370721,Historical data of failed search for mobile end devices-Field for Iteration,|Year,Month
IDE19627,Anti-theft alarm system sensor interior monitoring: hash value configuration,{SFD: locked}
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,14.35, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,14.45, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,14.45, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,14.50, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,5.00, V
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P-Class:,AC,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS06797,Immobilizer-Status configuration,15 00,
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-ENG299121,Immobilizer-Configuration_status_(interpreted),|Configuration Kessy coded,Configuration E vehicle
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,30,
MAS00464-MAS00109,Standard - ambient data 1-Hours,12,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,1,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,14,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,8,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,496, km
MAS02101-MAS07806,Child safety-Specified status,not coded / not installed,
MAS07959,Remote start history data,|Stop or cancel cause,Cause for cancellation
MAS12666-SFT271873,SubSystemNodeAddress of sub bus participant-Wiper motor control module,0x0001,
MAS12666-SFT271874,SubSystemNodeAddress of sub bus participant-Rain/Light Recognition Sensor,0x0002,
MAS12666-SFT271875,SubSystemNodeAddress of sub bus participant-Light switch,0x0003,
MAS12666-SFT271876,SubSystemNodeAddress of sub bus participant-Garage door opener control module,0x0004,
MAS12666-SFT271894,SubSystemNodeAddress of sub bus participant-Anti-theft alarm system sensor,0x0016,
MAS12666-SFT271896,SubSystemNodeAddress of sub bus participant-Alarm horn,0x0018,
MAS12666-SFT271909,SubSystemNodeAddress of sub bus participant-Left taillight 1,0x0025,
MAS12666-SFT271910,SubSystemNodeAddress of sub bus participant-Roof electronics control module,0x0026,
MAS12666-SFT271947,SubSystemNodeAddress of sub bus participant-Humidity sensor: interior,0x004B,
MAS12666-SFT271948,SubSystemNodeAddress of sub bus participant-Left rear door control module,0x004C,
MAS12666-SFT271949,SubSystemNodeAddress of sub bus participant-Right rear door control module,0x004D,
MAS12666-SFT271950,SubSystemNodeAddress of sub bus participant-Power rear lid opening control module,0x004E,
MAS12666-SFT271966,SubSystemNodeAddress of sub bus participant-Left neck heater,0x005E,
MAS12666-SFT271967,SubSystemNodeAddress of sub bus participant-Right neck heater,0x005F,
MAS12666-SFT272009,SubSystemNodeAddress of sub bus participant-Steering Column Switch,0x0089,
MAS12666-SFT272014,SubSystemNodeAddress of sub bus participant-Control head for driving and comfort functions,0x008E,
MAS12666-SFT272057,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat driver side,0x00B9,
MAS12666-SFT272061,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat passenger side,0x00BD,
MAS12666-SFT272065,SubSystemNodeAddress of sub bus participant-Blower 1 for left front backrest,Unknown (0)
MAS12666-SFT272067,SubSystemNodeAddress of sub bus participant-Blower 1 for left front seat cushion,Unknown (0)
MAS12666-SFT272069,SubSystemNodeAddress of sub bus participant-Blower 1 for right front backrest,Unknown (0)
MAS12666-SFT272071,SubSystemNodeAddress of sub bus participant-Blower 1 for right front seat cushion,Unknown (0)
MAS12666-SFT272107,SubSystemNodeAddress of sub bus participant-Antenna for short-range communication,0x00EB,
MAS12666-SFT272121,SubSystemNodeAddress of sub bus participant-Control unit 2 for driving and convenience functions,0x00F9,
MAS12666-SFT272142,SubSystemNodeAddress of sub bus participant-Left taillight 2,0x010E,
MAS12666-SFT272143,SubSystemNodeAddress of sub bus participant-Right taillight 1,0x010F,
MAS12666-SFT272144,SubSystemNodeAddress of sub bus participant-Right taillight 2,0x0110,
MAS12666-SFT272221,SubSystemNodeAddress of sub bus participant-Radio receiver for remote start,0x015D,
MAS12666-SFT272238,SubSystemNodeAddress of sub bus participant-Wiper motor control unit 2,0x016E,
MAS12666-SFT272272,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear driver's side,0x0190,
MAS12666-SFT272286,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear passenger's side,0x019E,
MAS12667-SFT271873,Specified installation of sub-bus users-Wiper motor control module,Available,
MAS12667-SFT271874,Specified installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12667-SFT271875,Specified installation of sub-bus users-Light switch,Available,
MAS12667-SFT271876,Specified installation of sub-bus users-Garage door opener control module,Not available,
MAS12667-SFT271894,Specified installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12667-SFT271896,Specified installation of sub-bus users-Alarm horn,Not available,
MAS12667-SFT271909,Specified installation of sub-bus users-Left taillight 1,Available,
MAS12667-SFT271910,Specified installation of sub-bus users-Roof electronics control module,Available,
MAS12667-SFT271947,Specified installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12667-SFT271948,Specified installation of sub-bus users-Left rear door control module,Not available,
MAS12667-SFT271949,Specified installation of sub-bus users-Right rear door control module,Not available,
MAS12667-SFT271950,Specified installation of sub-bus users-Power rear lid opening control module,Available,
MAS12667-SFT271966,Specified installation of sub-bus users-Left neck heater,Not available,
MAS12667-SFT271967,Specified installation of sub-bus users-Right neck heater,Not available,
MAS12667-SFT272009,Specified installation of sub-bus users-Steering Column Switch,Not available,
MAS12667-SFT272014,Specified installation of sub-bus users-Control head for driving and comfort functions,Not available,
MAS12667-SFT272057,Specified installation of sub-bus users-Valve block 1 in front seat driver side,Available,
MAS12667-SFT272061,Specified installation of sub-bus users-Valve block 1 in front seat passenger side,Available,
MAS12667-SFT272065,Specified installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12667-SFT272067,Specified installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12667-SFT272069,Specified installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12667-SFT272071,Specified installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12667-SFT272107,Specified installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12667-SFT272121,Specified installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12667-SFT272142,Specified installation of sub-bus users-Left taillight 2,Available,
MAS12667-SFT272143,Specified installation of sub-bus users-Right taillight 1,Available,
MAS12667-SFT272144,Specified installation of sub-bus users-Right taillight 2,Available,
MAS12667-SFT272221,Specified installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12667-SFT272238,Specified installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12667-SFT272272,Specified installation of sub-bus users-Virtual pedal door opening: rear driver's side,Not available,
MAS12667-SFT272286,Specified installation of sub-bus users-Virtual pedal door opening: rear passenger's side,Not available,
MAS12668-SFT271873,Actual installation of sub-bus users-Wiper motor control module,Available,
MAS12668-SFT271874,Actual installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12668-SFT271875,Actual installation of sub-bus users-Light switch,Available,
MAS12668-SFT271876,Actual installation of sub-bus users-Garage door opener control module,Not available,
MAS12668-SFT271894,Actual installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12668-SFT271896,Actual installation of sub-bus users-Alarm horn,Not available,
MAS12668-SFT271909,Actual installation of sub-bus users-Left taillight 1,Available,
MAS12668-SFT271910,Actual installation of sub-bus users-Roof electronics control module,Available,
MAS12668-SFT271947,Actual installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12668-SFT271948,Actual installation of sub-bus users-Left rear door control module,Not available,
MAS12668-SFT271949,Actual installation of sub-bus users-Right rear door control module,Not available,
MAS12668-SFT271950,Actual installation of sub-bus users-Power rear lid opening control module,Available,
MAS12668-SFT271966,Actual installation of sub-bus users-Left neck heater,Not available,
MAS12668-SFT271967,Actual installation of sub-bus users-Right neck heater,Not available,
MAS12668-SFT272009,Actual installation of sub-bus users-Steering Column Switch,Not available,
MAS12668-SFT272014,Actual installation of sub-bus users-Control head for driving and comfort functions,Not available,
MAS12668-SFT272057,Actual installation of sub-bus users-Valve block 1 in front seat driver side,Available,
MAS12668-SFT272061,Actual installation of sub-bus users-Valve block 1 in front seat passenger side,Available,
MAS12668-SFT272065,Actual installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12668-SFT272067,Actual installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12668-SFT272069,Actual installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12668-SFT272071,Actual installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12668-SFT272107,Actual installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12668-SFT272121,Actual installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12668-SFT272142,Actual installation of sub-bus users-Left taillight 2,Available,
MAS12668-SFT272143,Actual installation of sub-bus users-Right taillight 1,Available,
MAS12668-SFT272144,Actual installation of sub-bus users-Right taillight 2,Available,
MAS12668-SFT272221,Actual installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12668-SFT272238,Actual installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12668-SFT272272,Actual installation of sub-bus users-Virtual pedal door opening: rear driver's side,Not available,
MAS12668-SFT272286,Actual installation of sub-bus users-Virtual pedal door opening: rear passenger's side,Not available,
MAS12669-SFT271873,Bus identification of sub-bus users-Wiper motor control module,Local data bus,
MAS12669-SFT271874,Bus identification of sub-bus users-Rain/Light Recognition Sensor,Local data bus,
MAS12669-SFT271875,Bus identification of sub-bus users-Light switch,Local data bus,
MAS12669-SFT271876,Bus identification of sub-bus users-Garage door opener control module,Local data bus 4,
MAS12669-SFT271894,Bus identification of sub-bus users-Anti-theft alarm system sensor,Local data bus 3,
MAS12669-SFT271896,Bus identification of sub-bus users-Alarm horn,Local data bus 2,
MAS12669-SFT271909,Bus identification of sub-bus users-Left taillight 1,Local data bus 8,
MAS12669-SFT271910,Bus identification of sub-bus users-Roof electronics control module,Local data bus 3,
MAS12669-SFT271947,Bus identification of sub-bus users-Humidity sensor: interior,Unknown (0)
MAS12669-SFT271948,Bus identification of sub-bus users-Left rear door control module,Local data bus 12,
MAS12669-SFT271949,Bus identification of sub-bus users-Right rear door control module,Local data bus 12,
MAS12669-SFT271950,Bus identification of sub-bus users-Power rear lid opening control module,Local data bus 8,
MAS12669-SFT271966,Bus identification of sub-bus users-Left neck heater,Local data bus 4,
MAS12669-SFT271967,Bus identification of sub-bus users-Right neck heater,Local data bus 4,
MAS12669-SFT272009,Bus identification of sub-bus users-Steering Column Switch,Local data bus 6,
MAS12669-SFT272014,Bus identification of sub-bus users-Control head for driving and comfort functions,Local data bus,
MAS12669-SFT272057,Bus identification of sub-bus users-Valve block 1 in front seat driver side,Local data bus 4,
MAS12669-SFT272061,Bus identification of sub-bus users-Valve block 1 in front seat passenger side,Local data bus 4,
MAS12669-SFT272065,Bus identification of sub-bus users-Blower 1 for left front backrest,Unknown (0)
MAS12669-SFT272067,Bus identification of sub-bus users-Blower 1 for left front seat cushion,Unknown (0)
MAS12669-SFT272069,Bus identification of sub-bus users-Blower 1 for right front backrest,Unknown (0)
MAS12669-SFT272071,Bus identification of sub-bus users-Blower 1 for right front seat cushion,Unknown (0)
MAS12669-SFT272107,Bus identification of sub-bus users-Antenna for short-range communication,Data bus subCAN 1,
MAS12669-SFT272121,Bus identification of sub-bus users-Control unit 2 for driving and convenience functions,Local data bus 11,
MAS12669-SFT272142,Bus identification of sub-bus users-Left taillight 2,Local data bus 8,
MAS12669-SFT272143,Bus identification of sub-bus users-Right taillight 1,Local data bus 8,
MAS12669-SFT272144,Bus identification of sub-bus users-Right taillight 2,Local data bus 8,
MAS12669-SFT272221,Bus identification of sub-bus users-Radio receiver for remote start,Local data bus 6,
MAS12669-SFT272238,Bus identification of sub-bus users-Wiper motor control unit 2,Local data bus,
MAS12669-SFT272272,Bus identification of sub-bus users-Virtual pedal door opening: rear driver's side,Local data bus 4,
MAS12669-SFT272286,Bus identification of sub-bus users-Virtual pedal door opening: rear passenger's side,Local data bus 4,
MAS13141,Test voltage,0.00, V
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 08 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,not OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,3,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18919-MAS17454,Engine hood contacts-Engine hood contact 2,not active,
MAS18919-MAS18918,Engine hood contacts-Engine hood contact 1,not active,
MAS19775-MAS06430,Status of sliding door rear driver side-Main notch contact of rotary latch,not coded / not installed,
MAS19775-MAS15328,Status of sliding door rear driver side-Interior door handle switch,Not available,
MAS19775-MAS19404,Status of sliding door rear driver side-Rear Driver Side Exterior Door Handle Switch: status,Not available,
MAS19775-MAS21226,Status of sliding door rear driver side-Mechanical separation door inside handle: status,not coded / not installed,
MAS19775-MAS21227,Status of sliding door rear driver side-Motor for safe: child safety: and crash activation,not coded / not installed,
MAS19775-MAS21228,Status of sliding door rear driver side-Rotary motor: activation,not coded / not installed,
MAS19775-MAS21237,Status of sliding door rear driver side-Virtual crash redundancy sensor: sliding door,not coded / not installed,
MAS19777-MAS06430,Status of sliding door passenger side rear-Main notch contact of rotary latch,not coded / not installed,
MAS19777-MAS15328,Status of sliding door passenger side rear-Interior door handle switch,Not available,
MAS19777-MAS19403,Status of sliding door passenger side rear-Rear Passenger Exterior Door Handle Switch: status,Not available,
MAS19777-MAS21226,Status of sliding door passenger side rear-Mechanical separation door inside handle: status,not coded / not installed,
MAS19777-MAS21227,Status of sliding door passenger side rear-Motor for safe: child safety: and crash activation,not coded / not installed,
MAS19777-MAS21228,Status of sliding door passenger side rear-Rotary motor: activation,not coded / not installed,
MAS19777-MAS21237,Status of sliding door passenger side rear-Virtual crash redundancy sensor: sliding door,not coded / not installed,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS23572-ENG423280,AlcoLock interface: internal module signals-AI_data_plausibility,{SFD: locked}
MAS23572-ENG423281,AlcoLock interface: internal module signals-AI_data_plausibility_check_active,{SFD: locked}
MAS23572-ENG423282,AlcoLock interface: internal module signals-AI_data_unplausible_data_received_counter,{SFD: locked}
MAS23572-ENG354512,AlcoLock interface: internal module signals-AI_ECU_breath_test_valid,{SFD: locked}
MAS23572-ENG423285,AlcoLock interface: internal module signals-AI_ECU_error_reason,{SFD: locked}
MAS23572-ENG415652,AlcoLock interface: internal module signals-AI_ECU_IDLE_states,{SFD: locked}
MAS23572-ENG423286,AlcoLock interface: internal module signals-AI_ECU_lockout_reason,{SFD: locked}
MAS23572-ENG356980,AlcoLock interface: internal module signals-AI_ECU_test_request_state,{SFD: locked}
MAS23572-ENG423287,AlcoLock interface: internal module signals-AI_ECU_time_remaining_for_wait_ignition,{SFD: locked}
MAS23572-ENG415653,AlcoLock interface: internal module signals-AI_LIN_data_sent,{SFD: locked}
MAS23572-ENG415654,AlcoLock interface: internal module signals-AI_LIN_Wake,{SFD: locked}
MAS23572-ENG351542,AlcoLock interface: internal module signals-Engine_Runs,{SFD: locked}
MAS23572-ENG351747,AlcoLock interface: internal module signals-LIN_version_AI_ECU,{SFD: locked}
MAS23572-ENG356917,AlcoLock interface: internal module signals-LIN_version_AI_interface,{SFD: locked}
MAS23572-ENG423694,AlcoLock interface: internal module signals-Protocol_plausibilty,{SFD: locked}
MAS23572-ENG423695,AlcoLock interface: internal module signals-Protocol_version_AI_ECU,{SFD: locked}
MAS23572-ENG423696,AlcoLock interface: internal module signals-Protocol_version_AI_interface,{SFD: locked}
MAS23572-ENG423718,AlcoLock interface: internal module signals-Terminal_activation_request_detected,{SFD: locked}
MAS23572-ENG423759,AlcoLock interface: internal module signals-Vehicle_communication_state,{SFD: locked}
MAS23572-ENG109868,AlcoLock interface: internal module signals-vehicle_locked_externally,{SFD: locked}
MAS23572-ENG354758,AlcoLock interface: internal module signals-Vehicle_state,{SFD: locked}
MAS24797-ENG423288,AlcoLock interface: output signals-AI_interface_terminal_release,{SFD: locked}
MAS24798-ENG354120,AlcoLock interface: LIN output signals-AI_interface_LIN_data1,{SFD: locked}
MAS24798-ENG353741,AlcoLock interface: LIN output signals-AI_interface_LIN_data2,{SFD: locked}
MAS24798-ENG357362,AlcoLock interface: LIN output signals-AI_interface_LIN_data3,{SFD: locked}
MAS24798-ENG355675,AlcoLock interface: LIN output signals-AI_interface_LIN_data4,{SFD: locked}
MAS24798-ENG356287,AlcoLock interface: LIN output signals-AI_interface_LIN_data5,{SFD: locked}
MAS24798-ENG357125,AlcoLock interface: LIN output signals-AI_interface_LIN_data6,{SFD: locked}
MAS24798-ENG353930,AlcoLock interface: LIN output signals-AI_interface_LIN_data7,{SFD: locked}
MAS24798-ENG355955,AlcoLock interface: LIN output signals-LIN_AI_interface_vehicle_state,{SFD: locked}
MAS24799-ENG423375,AlcoLock interface: input signals-Central_locking_state_locked,{SFD: locked}
MAS24799-ENG423376,AlcoLock interface: input signals-Central_locking_state_safe,{SFD: locked}
MAS24799-ENG423576,AlcoLock interface: input signals-KBI_Kilometer_mileage,{SFD: locked}
MAS24799-ENG423577,AlcoLock interface: input signals-KBI_unit_tacho,{SFD: locked}
MAS24799-ENG186493,AlcoLock interface: input signals-Status_terminal_15,{SFD: locked}
MAS24799-ENG423716,AlcoLock interface: input signals-Status_terminals,{SFD: locked}
MAS24799-ENG423175,AlcoLock interface: input signals-Terminal_activation_request,{SFD: locked}
MAS24799-ENG423750,AlcoLock interface: input signals-USS_comfort_ready_status,{SFD: locked}
MAS24799-ENG423751,AlcoLock interface: input signals-USS_driver_presence_status,{SFD: locked}
MAS24800-ENG352190,AlcoLock interface: LIN input signals-AI_ECU_blocking_state,{SFD: locked}
MAS24800-ENG423283,AlcoLock interface: LIN input signals-AI_ECU_blocking_state_inverse,{SFD: locked}
MAS24800-ENG423284,AlcoLock interface: LIN input signals-AI_ECU_communication_state,{SFD: locked}
MAS24800-ENG354636,AlcoLock interface: LIN input signals-AI_ECU_LIN_data1,{SFD: locked}
MAS24800-ENG354806,AlcoLock interface: LIN input signals-AI_ECU_LIN_data2,{SFD: locked}
MAS24800-ENG357261,AlcoLock interface: LIN input signals-AI_ECU_LIN_data3,{SFD: locked}
MAS24800-ENG356291,AlcoLock interface: LIN input signals-AI_ECU_LIN_data4,{SFD: locked}
MAS24800-ENG353833,AlcoLock interface: LIN input signals-AI_ECU_LIN_data5,{SFD: locked}
MAS24801-IDE00075,AlcoLock interface: CAN input signals-Vehicle speed,{SFD: locked}
MAS24801-ENG356016,AlcoLock interface: CAN input signals-Driver_door_open,{SFD: locked}
MAS24801-ENG352670,AlcoLock interface: CAN input signals-Driving_enabled_mode,{SFD: locked}
MAS24801-ENG106219,AlcoLock interface: CAN input signals-Engine_Speed,{SFD: locked}
MAS24801-ENG355977,AlcoLock interface: CAN input signals-Engine_speed_not_valid,{SFD: locked}
MAS24801-ENG352728,AlcoLock interface: CAN input signals-Engine_speed_timeout,{SFD: locked}
MAS24801-ENG423590,AlcoLock interface: CAN input signals-Motor_start_stopp_mode,{SFD: locked}
MAS24801-ENG357049,AlcoLock interface: CAN input signals-Motor_start_stopp_status,{SFD: locked}
MAS24801-ENG423173,AlcoLock interface: CAN input signals-status_terminal_50,{SFD: locked}
MAS24802,AlcoLock interface: historical memory,{SFD: locked}
MAS24928-IDE06956,Secure presence detection-Driver-side belt buckle status,Open,
MAS24928-IDE13428,Secure presence detection-Accelerator pedal value,Not operated,
MAS24928-IDE15366,Secure presence detection-Selector lever P button status,Not operated,
MAS24928-MAS00218,Secure presence detection-Driver´s door,Open,
MAS24928-MAS00370,Secure presence detection-Vehicle speed,plausible,
MAS24928-MAS00635,Secure presence detection-Available,Available,
MAS24928-MAS03554,Secure presence detection-Clutch pedal operation,Not operated,
MAS24928-MAS05192,Secure presence detection-Driver braking,Not braking,
MAS24928-MAS07200,Secure presence detection-Multi-function steering wheel,not around,
MAS24928-MAS07652,Secure presence detection-Vehicle movement,Standstill,
MAS24928-MAS17288,Secure presence detection-Driver seat occupant detection,assigned,
MAS24928-MAS22006,Secure presence detection-Start request recognition: status,Not operated,
MAS24928-MAS22963,Secure presence detection-Starter button actuated,Not operated,
MAS24928-MAS25017,Secure presence detection-Selector mechanism,Not operated,
MAS24928-MAS25018,Secure presence detection-Driver request: switch position,Not operated,
MAS24928-MAS25020,Secure presence detection-Presence detection: status,Not available,
MAS24928-SFT33114,Secure presence detection-Multifunction interior camera,not recognised,
MAS24928-ENG357179,Secure presence detection-Clutch_pedal_actuation_plausible,Implausible,
MAS24928-ENG354959,Secure presence detection-Driver_brakes_plausible,plausible,
MAS24928-ENG352344,Secure presence detection-Driver_pedal_value_plausible,plausible,
MAS24928-ENG352881,Secure presence detection-Driver_side_door_plausible,plausible,
MAS24928-ENG355601,Secure presence detection-Epb_switch_position_plausible,plausible,
MAS24928-ENG354436,Secure presence detection-Multifunction_interior_camera_plausible,Implausible,
MAS24928-ENG357466,Secure presence detection-Multifunction_steering_wheel_plausible,Implausible,
MAS24928-ENG353527,Secure presence detection-Seat_belt_driver_plausible,plausible,
MAS24928-ENG352047,Secure presence detection-Seat_occupied_driver_plausible,plausible,
MAS24928-ENG353443,Secure presence detection-Selector_lever_p_button_status_plausible,plausible,
MAS24928-ENG356327,Secure presence detection-Switching_actuation_activated_plausible,plausible,
MAS25221,Virtual remote control vehicle key: online configuration,|Config_profileid,Engine_start_and_driving_unlimited
MAS25221-ENG353386,Virtual remote control vehicle key: online configuration-Config_owner_pairing_passwort_max_attempts,00,
MAS25221-ENG356831,Virtual remote control vehicle key: online configuration-Config_servicecard_activation_mode,simple,
MAS25221-ENG353252,Virtual remote control vehicle key: online configuration-Config_sharing_password_length,00,
MAS25221-ENG356838,Virtual remote control vehicle key: online configuration-Config_sharing_password_required,No,
MAS25221-ENG353410,Virtual remote control vehicle key: online configuration-Config_sharing_passwort_max_attempts,00,
MAS25221-ENG354762,Virtual remote control vehicle key: online configuration-Config_slotid_1,00 00 00 00,
MAS25221-ENG353562,Virtual remote control vehicle key: online configuration-Config_slotid_10,00 00 00 00,
MAS25221-ENG352068,Virtual remote control vehicle key: online configuration-Config_slotid_11,00 00 00 00,
MAS25221-ENG355132,Virtual remote control vehicle key: online configuration-Config_slotid_12,00 00 00 00,
MAS25221-ENG352767,Virtual remote control vehicle key: online configuration-Config_slotid_13,00 00 00 00,
MAS25221-ENG354931,Virtual remote control vehicle key: online configuration-Config_slotid_14,00 00 00 00,
MAS25221-ENG354420,Virtual remote control vehicle key: online configuration-Config_slotid_15,00 00 00 00,
MAS25221-ENG351951,Virtual remote control vehicle key: online configuration-Config_slotid_16,00 00 00 00,
MAS25221-ENG355037,Virtual remote control vehicle key: online configuration-Config_slotid_2,00 00 00 00,
MAS25221-ENG355160,Virtual remote control vehicle key: online configuration-Config_slotid_3,00 00 00 00,
MAS25221-ENG354052,Virtual remote control vehicle key: online configuration-Config_slotid_4,00 00 00 00,
MAS25221-ENG356953,Virtual remote control vehicle key: online configuration-Config_slotid_5,00 00 00 00,
MAS25221-ENG353832,Virtual remote control vehicle key: online configuration-Config_slotid_6,00 00 00 00,
MAS25221-ENG355202,Virtual remote control vehicle key: online configuration-Config_slotid_7,00 00 00 00,
MAS25221-ENG352864,Virtual remote control vehicle key: online configuration-Config_slotid_8,00 00 00 00,
MAS25221-ENG356858,Virtual remote control vehicle key: online configuration-Config_slotid_9,00 00 00 00,
MAS25222-ENG352542,Near-field service card: information-Current_overlying_servicecard_corresponds_to_the_trained_service_card,No,
MAS25222-ENG353668,Near-field service card: information-Electronic_type_label_of_the_trained_servicecard,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS25222-ENG353958,Near-field service card: information-Id_of_the_trained_servicecard,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS25222-ENG352639,Near-field service card: information-Nfc_servicecard_learned,No,
MAS25323,Ambient lighting: error locations,{SFD: locked}
MAS26682,Distance of storage error,00,
MAS26683,Distance of calculation error,00,
MAS27748-IDE02068,Distance data with electronic stabilization program information-Time stamp,00 00 42 00 00,
MAS27748-MAS00106,Distance data with electronic stabilization program information-Year,2000, yr
MAS27748-MAS00107,Distance data with electronic stabilization program information-Month,1, Months
MAS27748-MAS00108,Distance data with electronic stabilization program information-Day,1, d
MAS27748-MAS00109,Distance data with electronic stabilization program information-Hours,0, H
MAS27748-MAS00110,Distance data with electronic stabilization program information-Minutes,0, min
MAS27748-MAS00111,Distance data with electronic stabilization program information-Seconds,0, s
MAS27748-MAS27735,Distance data with electronic stabilization program information-ESC distance pulses,496771, m
MAS27748-MAS27749,Distance data with electronic stabilization program information-Distance pulses: number of jumps,0,
MAS27748-MAS27750,Distance data with electronic stabilization program information-Distance pulses: largest positive jump,0, m
MAS27748-MAS27751,Distance data with electronic stabilization program information-Distance pulses: largest negative jump,0, m
MAS27748-MAS27752,Distance data with electronic stabilization program information-Distance pulses: total jumps,0, m
MAS27748-MAS27753,Distance data with electronic stabilization program information-Distance pulses: jump balance,0, m
MAS27748-MAS27754,Distance data with electronic stabilization program information-Electronic stabilization program communication failures: number,11,
MAS27748-MAS27755,Distance data with electronic stabilization program information-Electronic stabilization program communication failures: total duration,1244, s
MAS27748-MAS27756,Distance data with electronic stabilization program information-Longest electronic stabilization program communication failure,65533, min
MAS28172,Status of automatic cyclical search function,not activated,
ENG277599-MAS18508,ASIL_relevante_RDIDs-Number of nodes,49,
ENG277599-ENG370721,ASIL_relevante_RDIDs-Field for Iteration,|Adapted values/adaptation,Status of adaptation|4384
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,0,
ENG186123-ENG255560,Authentic_time_last_client_response-Current_time_ used,1970-01-01T00:00:00Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,1970-01-01T00:00:00Z,
ENG254556-MAS09527,Control_voltage_actual_value-Activation voltage: act. value,0.0, V
ENG254556-MAS10074,Control_voltage_actual_value-Supply voltage: actual value,14.5, V
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,gueltiges Funktelegramm,
ENG281289-ENG370721,Dataset_download__rdids_changed_by_adaption-Field for Iteration,|ID data set|FF FF|FF FF|FF FF|FF FF|FF FF|FF FF|FF FF|FF FF|FF FF|FF FF|,
ENG286564,Easy_open_HBFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG286565,Easy_open_HFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,8, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,4, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,1.33, H
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,3900,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,5165,
ENG116813-ENG370721,Entwicklermesswerte_CONTI-Field for Iteration,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,02,
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,3,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
ENG254718-ENG370721,Function_On_Demand_Unlock_ID_Status_Dev-Field for Iteration,|ID number,Release code for a SWaP function
ENG310456-IDE10283,key_fob-Key identification: transponder ID,00 00 00 00,
ENG310456-ENG331600,key_fob-key_fob_battery_level,1.00, V
ENG310456-ENG331607,key_fob-key_fob_button,no_button,
ENG310456-ENG331605,key_fob-key_fob_error_state,no_UHF_message,
ENG310456-ENG331606,key_fob-key_fob_number,no_UHF_message,
ENG310456-ENG331603,key_fob-LF_range_limitation,no_UHF_message,
ENG310456-ENG331601,key_fob-number_of_adapted_key_fobs,2,
ENG310456-ENG331602,key_fob-rolling_code_synchronisation,no_UHF_message,
ENG116909-ENG107391,LIN activity-LIN 1,Communication,
ENG116909-ENG256023,LIN activity-LIN 10,Communication,
ENG116909-ENG256024,LIN activity-LIN 11,not coded / not installed,
ENG116909-ENG256025,LIN activity-LIN 12,not coded / not installed,
ENG116909-ENG256026,LIN activity-LIN 13,not coded / not installed,
ENG116909-ENG256027,LIN activity-LIN 14,not coded / not installed,
ENG116909-ENG107392,LIN activity-LIN 2,not coded / not installed,
ENG116909-ENG114948,LIN activity-LIN 3,Communication,
ENG116909-ENG114949,LIN activity-LIN 4,Communication,
ENG116909-ENG114950,LIN activity-LIN 5,Communication,
ENG116909-ENG114951,LIN activity-LIN 6,not coded / not installed,
ENG116909-ENG256030,LIN activity-LIN 7,not coded / not installed,
ENG116909-ENG256031,LIN activity-LIN 8,Communication,
ENG116909-ENG256032,LIN activity-LIN 9,Communication,
ENG122922-ENG121684,misc_wiper_values_1-wiper_counter_block,0,
ENG122922-ENG121680,misc_wiper_values_1-wiper_counter_cycles,3900,
ENG122922-ENG121681,misc_wiper_values_1-wiper_counter_operating_h,21.1709, H
ENG122922-ENG121682,misc_wiper_values_1-wiper_errors,00000000 00000100 ,
ENG122922-ENG121683,misc_wiper_values_1-wiper_speed_real,0, /min
ENG122924-ENG115787,misc_wiper_values_2-wiper_angle,9.14, °
ENG122924-ENG115788,misc_wiper_values_2-wiper_angle_corr_OWL,0.00, °
ENG122924-ENG115789,misc_wiper_values_2-wiper_angle_corr_UWL,0.00, °
ENG122924-ENG115790,misc_wiper_values_2-wiper_power_supply_Ubat,14.60, V
ENG254795,Personalized_Signals_2_0,|Current profile slot number for customization,Customization control command
ENG116792-ENG370721,Power up history-Field for Iteration,|Funktionsanforderung|10|33|0|10|132|132|132|132|10|10|,
ENG122923-ENG115672,shadow_error_table-wiper_error_1_code,59,
ENG122923-ENG115673,shadow_error_table-wiper_error_1_count,1,
ENG122923-ENG115677,shadow_error_table-wiper_error_1_data_ec4,2,
ENG122923-ENG115678,shadow_error_table-wiper_error_1_data_ec5,104,
ENG122923-ENG115676,shadow_error_table-wiper_error_1_power_supply,14.4, V
ENG122923-ENG115675,shadow_error_table-wiper_error_1_temp,49, °C
ENG122923-ENG115674,shadow_error_table-wiper_error_1_timestamp,6.9972, min
ENG122923-ENG256664,shadow_error_table-wiper_error_10_code,0,
ENG122923-ENG256665,shadow_error_table-wiper_error_10_count,0,
ENG122923-ENG256666,shadow_error_table-wiper_error_10_data_ec4,0,
ENG122923-ENG256667,shadow_error_table-wiper_error_10_data_ec5,0,
ENG122923-ENG256668,shadow_error_table-wiper_error_10_power_supply,0.0, V
ENG122923-ENG256669,shadow_error_table-wiper_error_10_temp,0, °C
ENG122923-ENG256671,shadow_error_table-wiper_error_10_timestamp,0.0000, min
ENG122923-ENG115679,shadow_error_table-wiper_error_2_code,34,
ENG122923-ENG115680,shadow_error_table-wiper_error_2_count,2,
ENG122923-ENG115684,shadow_error_table-wiper_error_2_data_ec4,6,
ENG122923-ENG115685,shadow_error_table-wiper_error_2_data_ec5,96,
ENG122923-ENG115683,shadow_error_table-wiper_error_2_power_supply,12.8, V
ENG122923-ENG115682,shadow_error_table-wiper_error_2_temp,34, °C
ENG122923-ENG115681,shadow_error_table-wiper_error_2_timestamp,4.3316, min
ENG122923-ENG115686,shadow_error_table-wiper_error_3_code,58,
ENG122923-ENG115687,shadow_error_table-wiper_error_3_count,19,
ENG122923-ENG115691,shadow_error_table-wiper_error_3_data_ec4,0,
ENG122923-ENG115692,shadow_error_table-wiper_error_3_data_ec5,96,
ENG122923-ENG115690,shadow_error_table-wiper_error_3_power_supply,14.3, V
ENG122923-ENG115689,shadow_error_table-wiper_error_3_temp,29, °C
ENG122923-ENG115688,shadow_error_table-wiper_error_3_timestamp,0.9996, min
ENG122923-ENG115693,shadow_error_table-wiper_error_4_code,21,
ENG122923-ENG115694,shadow_error_table-wiper_error_4_count,19,
ENG122923-ENG115698,shadow_error_table-wiper_error_4_data_ec4,0,
ENG122923-ENG115699,shadow_error_table-wiper_error_4_data_ec5,96,
ENG122923-ENG115697,shadow_error_table-wiper_error_4_power_supply,14.3, V
ENG122923-ENG115695,shadow_error_table-wiper_error_4_temp,29, °C
ENG122923-ENG115696,shadow_error_table-wiper_error_4_timestamp,0.9996, min
ENG122923-ENG115700,shadow_error_table-wiper_error_5_code,31,
ENG122923-ENG115701,shadow_error_table-wiper_error_5_count,255,
ENG122923-ENG115705,shadow_error_table-wiper_error_5_data_ec4,255,
ENG122923-ENG115706,shadow_error_table-wiper_error_5_data_ec5,8,
ENG122923-ENG115704,shadow_error_table-wiper_error_5_power_supply,12.2, V
ENG122923-ENG115703,shadow_error_table-wiper_error_5_temp,37, °C
ENG122923-ENG115702,shadow_error_table-wiper_error_5_timestamp,20.9916, min
ENG122923-ENG256676,shadow_error_table-wiper_error_6_code,0,
ENG122923-ENG256677,shadow_error_table-wiper_error_6_count,0,
ENG122923-ENG256678,shadow_error_table-wiper_error_6_data_ec4,0,
ENG122923-ENG256679,shadow_error_table-wiper_error_6_data_ec5,0,
ENG122923-ENG256680,shadow_error_table-wiper_error_6_power_supply,0.0, V
ENG122923-ENG256681,shadow_error_table-wiper_error_6_temp,0, °C
ENG122923-ENG256683,shadow_error_table-wiper_error_6_timestamp,0.0000, min
ENG122923-ENG256684,shadow_error_table-wiper_error_7_code,0,
ENG122923-ENG256685,shadow_error_table-wiper_error_7_count,0,
ENG122923-ENG256686,shadow_error_table-wiper_error_7_data_ec4,0,
ENG122923-ENG256687,shadow_error_table-wiper_error_7_data_ec5,0,
ENG122923-ENG256688,shadow_error_table-wiper_error_7_power_supply,0.0, V
ENG122923-ENG256689,shadow_error_table-wiper_error_7_temp,0, °C
ENG122923-ENG256691,shadow_error_table-wiper_error_7_timestamp,0.0000, min
ENG122923-ENG256692,shadow_error_table-wiper_error_8_code,0,
ENG122923-ENG256693,shadow_error_table-wiper_error_8_count,0,
ENG122923-ENG256694,shadow_error_table-wiper_error_8_data_ec4,0,
ENG122923-ENG256695,shadow_error_table-wiper_error_8_data_ec5,0,
ENG122923-ENG256696,shadow_error_table-wiper_error_8_power_supply,0.0, V
ENG122923-ENG256697,shadow_error_table-wiper_error_8_temp,0, °C
ENG122923-ENG256699,shadow_error_table-wiper_error_8_timestamp,0.0000, min
ENG122923-ENG256700,shadow_error_table-wiper_error_9_code,0,
ENG122923-ENG256701,shadow_error_table-wiper_error_9_count,0,
ENG122923-ENG256702,shadow_error_table-wiper_error_9_data_ec4,0,
ENG122923-ENG256703,shadow_error_table-wiper_error_9_data_ec5,0,
ENG122923-ENG256704,shadow_error_table-wiper_error_9_power_supply,0.0, V
ENG122923-ENG256705,shadow_error_table-wiper_error_9_temp,0, °C
ENG122923-ENG256707,shadow_error_table-wiper_error_9_timestamp,0.0000, min
ENG254816,Snapshot_DTC_Notlaufpfad,No malfunction,
ENG250298-IDE00104,Specific_ambient_conditions-DTC,00 00 00,
ENG250298-IDE07836,Specific_ambient_conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG370398-ENG370721,State_access_nvram_mdk-Field for Iteration,|Reason for access,kilometer reading|Reading data record
ENG254825,steuergeraetinterne_Messwert,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 02 00 01 10 92 C0 02 00 01 19 8C 1C 02 00 01 3F 24 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 09 00 00 00 20 01 4C 00 00 00 03 18 09 00 00 00 20 01 16 00 00 00 00 49 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0,
ENG116790-MAS00711,Supply voltage history-kilometer reading,490, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.10, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.60, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,5.00, V
ENG370404-ENG370721,Suppression_entry_exit_go-Field for Iteration,|Reason for low pressure,Year
ENG254841-ENG255534,User State Server-Comfort Ready Status,active,
ENG254841-ENG255633,User State Server-Driver Presence Status,driver_present,
ENG254841-ENG255634,User State Server-Driver Presence_Qbit,gueltiger_Wert,
ENG254841-ENG255639,User State Server-DTC OccupantPresenceService Error,no error,
ENG254841-ENG255640,User State Server-DTC OccupantPresenceService Restriction,no restriction,
ENG254841-ENG255787,User State Server-HV_Anwesenheit,No HV request,
ENG254841-ENG256105,User State Server-Occupant Presence Status,occupant_present,
ENG254841-ENG256557,User State Server-USS CAN Nachlauf,inactive,
ENG122921-ENG121628,values_motorloads-mod_temp_fast,37, °C
ENG122921-ENG121627,values_motorloads-mod_temp_slow,37, °C
ENG122921-ENG121629,values_motorloads-temp_pcb,40, °C
ENG122921-ENG121631,values_motorloads-wiper_energymodel_load,0,
ENG122921-ENG121632,values_motorloads-wiper_energymodel_status,2,
ENG122921-ENG121633,values_motorloads-wiper_power_supply_PWM,0, %
ENG122921-ENG121630,values_motorloads-wiper_thermomodel_status,2,
Elapsed Time: 01:46
