- Sep 29, 2026
- 5
- 2
- Pittsburgh, PA, USA
- C?ID=665972
I am having a nightmare of a time trying to readapt my keys to my 2012 VW Passat with VCDS.
Both fobs desynced from the car when I disconnected the battery for a long period of time. I followed the manual and that didn't work at all. The thing is that the the panic button works on both fobs, so all the wireless connectivity to the car from the fob works, the lock buttons don't. So with VCDS, I tried following the relearn procedure under the 09 module. So I cleared the learned parameters, power cycled the car, and then set the relearn to 2, because I had 2 fobs. I pressed the unlock button on each one for a few seconds within the 15 second window after hitting test. It didn't work. I tried it quite a few times. As soon as I would hit done, VCDS would freeze, as in unresponsive for 10 minutes. Mind you, the car is still driveable, just keyless entry doesn't work. Both fobs have new batteries. This is my autoscan, and the only faults that show up are not related to keyless entry. I do also have a debug mode log but I am not sure if it was done correctly.
Also something to keep in mind is that this car hasn't seen a dealer in about a decade, barring recall work. I am not sure if it has old firmware on various modules or not. I would assume so?
EDIT:
Basically the reason why the fobs got desynced was that the battery was disconnected due to the ignition cylinder basically eating my key (it was stuck in the on position). It did this 2 days before I could give the car to my mechanic to actually replace it with a new cylinder.
EDIT:
Sunday,27,September,2026,21:49:56:40840
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.5
Mileage: 266680km-165707mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 46 4F 52 56 62 72 77
Mileage: 266680km-165707miles
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 AL HW: 07K 907 309 A
Component: 2,5l R5/4V G01 1100
Revision: T6H02--- Serial number:
Coding: 0000075
Shop #: WSC 09003 957 00200
VCID: 78AE0888FEDAB34ADF0-802C
VINID: 0669D28074432534C01C624014C7CF7CE4
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 000 - Implausible Signal - MIL ON
Fault Status: 11100000
Mileage: 259050 km
Date: 2021.02.17.
Time: 10:45:31
Temperature: 15.0�C
Temperature: 17.0�C
Absolute Pres.: 960.0 mbar
Voltage: 11.938 V
008584 - Bank 1; System too Rich at Idle
P2188 - 000 - - MIL ON
Fault Frequency: 25
Mileage: 259053 km
Date: 2021.02.17.
Time: 11:13:45
RPM: 787 /min
Load: 34.1 %
Speed: 14.0 km/h
Temperature: 84.0�C
Temperature: 34.0�C
Voltage: 13.843 V
008568 - Bank 1; System Too Rich off Idle
P2178 - 000 - - Intermittent
Mileage: 259069 km
Date: 2021.02.17.
Time: 19:31:33
RPM: 703 /min
Load: 48.2 %
Speed: 1.0 km/h
Temperature: 66.0�C
Temperature: 27.0�C
Voltage: 13.843 V
Readiness: 1010 1101
Part No SW: 09G 927 750 LH HW: 09G 927 750 LH
Component: AQ 250 6F 1916
Revision: 00H90000 Serial number:
Coding: 0000840
VCID: 025A6A60A806E99AF14-8056
013 - Check DTC Memory
Fault Status: 00101101
Fault Frequency: 68
Reset counter: 201
Mileage: 82997 km
Date: 2019.06.05.
Time: 17:50:17
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V3.clb
Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
Revision: 00H31001
Coding: C54BC0F549290800A31403E4921E1061A61000
VCID: 7CA61498C6E29F6ABB8-8028
02214 - Tire Pressure Warning
Reset counter: 61
Mileage: 265904 km
Date: 2021.02.17.
Time: 05:35:11
Count: 32768
Count: 13056
Count: 16401
Count: 49664
Fault Status: 01101101
Fault Frequency: 23
Reset counter: 152
Mileage: 249105 km
Date: 2021.02.17.
Time: 09:40:46
Count: 32768
Count: 12800
Count: 8193
Count: 48896
Count: 256
Part No SW: 561 907 044 H HW: 561 907 044 H
Component: Climatronic 043 0202
Revision: 00001001
Coding: 0010001002
VCID: 1C66341826223F6A1B8-8048
9473137 - Motor for Left Temperature Flap
B108C 71 [00001000] - Actuator Stuck
Reset counter: 53
Mileage: 266309 km
Date: 2026.09.27.
Time: 09:41:03
9485831 - Air Blower
B10BE 07 [00001001] - Mechanical Failure
[ZSB Gebl�se/Regler vorne - Gebl�sreglercode (Impuls) Nr.7 - �berlast oder blockierter Motor]
Fault Frequency: 21
Reset counter: 28
Mileage: 266426 km
Date: 2026.09.27.
Time: 07:03:50
Part No SW: 5K0 937 085 S HW: 5K0 937 085 S
Component: BCM PQ35 B+ 021 0064
Revision: BH021001
Coding: 6F200E1B902B08D408880001160004480071008640A00D60648060000C70
VCID: 43D4AF64FB9C2092BA2-8016
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 050312 05 54 0403
Coding: 22300A
00984 - Left Tail Light (M4)
Fault Status: 00101010
Fault Frequency: 28
Reset counter: 71
Mileage: 262392 km
Date: 2021.02.17.
Time: 08:51:04
Voltage: 13.95 V
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 153
Mileage: 171757 km
Date: 2017.08.14.
Time: 00:04:28
Term 15 Off
Voltage: 12.40 V
Fault Status: 01101010
Reset counter: 90
Mileage: 216971 km
Date: 2020.09.18.
Time: 21:33:55
Voltage: 13.75 V
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003ENM01ZZMQ Dataset Number: 560003v__A_ 0124
Coding: 00004D48
Shop #: WSC 63474 003 1048576
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 6FBC33D48714F4F20EA-803A
Seat occupant detection:
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000CZX108
Coding: 303044
Serial number: 3572MSME0E153569ZZZ-
Serial number: 3582MSME11486169ZZZU
Serial number: 3516KSME091A5C17ZZZY
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME50290D18ZZZS
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME21126917ZZZN
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME37152515ZZZO
Part No SW: 1K5 953 501 Q HW: 5K0 953 569 H
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20120223300888
Coding: 098A140000
VCID: 3928CD8C89D06A42E0E-806C
Component: E221__MFL-YVJ H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 B HW: 561 920 970 B
Component: KOMBI H07 0507
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 19682D0C29104A4200E-804C
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 24031201290431
Coding: 461000
VCID: 3D20D99C9D785662CC6-8068
Part No SW: 561 919 965 HW: 561 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 1829227R1FNH06
Coding: 0000002
VCID: 63944FE4575C40929A2-8036
Component: IMMO H07 0507
ROD: EV_Immo_UDS_VDD_RM09_VW41.rod
VCID: 6A8A22C0BCF611DA594-803E
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0004242026
Coding: 0404F5
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BE4770463AC7852D22-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Coding: 800000
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 01030108
VCID: 6FBC33D48794F4F20EA-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011136200654
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0004
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0004215143
Coding: 0404F4
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CE6741866A27F6ADB8-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
67589 - Turn Signal in Exterior Mirror
B11FD 01 [00001001] - Electrical Failure
Reset counter: 246
Mileage: 235200 km
Date: 2026.09.27.
Time: 21:00:36
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7M3272561
Coding: 0500040004000B
VCID: 63944FE45B5C40929A2-8036
Fault Frequency: 29
Reset counter: 175
Mileage: 166755 km
Date: 2017.04.30.
Time: 10:43:58
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007662027160 Dataset Number: 5K0035730E 0001
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270C1BF46F64ECB286A-8072
End----------(Elapsed Time: 01:09, VBatt start/end: 12.8V/12.9V)-----------
------------------------------13 Faults Found------------------------------
