Audi s3 8v Inner tail lamps dont work
kuba0815
Poland
I’m having an issue with the inner tail lights. On Friday, I converted the radio from US to EU spec. I ran into a problem during the process, but someone helped me out via a delink remote connection. After the conversion, I noticed that some coding adaptations weren't working (like the oil temperature display,the start-stop deactivation). Later, I tested the tail lights, which had been modified incorrectly—the turn signal was wired to pin 6 instead of the added pin 4. So, I connected the brake pin in the connector to pin 6, and after i pressed break pedal the turn signal lit up. However, I then noticed that neither of the inner tail lights was working (indicator, fog, reverse lights work). I’m not sure if this is a coding issue or a wiring problem. I only swapped the pins on the left light unit. These are full LED lights with dynamic turn signals. Car audi S3 8v 02/2017. Is there coding only for inner tail lights?
@kuba0815, are you using a genuine Ross-Tech VCDS ? To be clear, copies are not accepted here on the forum.
"VCDS Version: Release 21.9.0" :rolleyes:
Tomorrow I can post complete auto scan.
And off course you did a full car code scan and save BEFORE you started the modifications?
