I have air suspension fault that appeared when driving about 85mph . After resetting all DTCs it drove fine with no faults for nearly 1k miles. So yesterday on a long motorway drive, at about 85mph the fault returned. This was the first time since the original fault appeared that I'd done over 60mph for an extended period. I reset this and thought it might be speed related level control. I know at certain speeds the suspension lowers itself. On my return journey I was sat at 75mph with now faults. As soon as i touched 76mph the fault appeared again. It only happens at extended motorway speeds. Anyone had similar problems at high speeds only? I did lower the suspension via VCDS about 4 years ago, no problems with it till now!
Thank you.
Thank you.
Tuesday,29,September,2026,18:47:42:00309
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4713.4
VIN: WAUZZZ4G0BN003847 License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 30 34 36 3B 42 44 46
47 52 53 55 56 5F 62 6C 6D 72 84 85 8B 8E 8F 90
VIN: WAUZZZ4G0BN003847 Mileage: 164653km-102310miles
84-Night Vision -- Status: Malfunction 0010
85-On Board Cam. -- Status: Malfunction 0010
Address 01: Engine (J623-CGWB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 HW: 4H0 907 551
Component: 3.0l V6 TFSI H05 0008
Revision: --H05--- CVN: 96979C0F
Coding: 1A250034056F01020800
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551 002011
ROD: EV_ECM30TFS0214G0907551_002.rod
VCID: 6695B8F0A8E7DE6A55F-8032
VINID: 9D196AAAA1170127800032041C23591381
Readiness: 0110 0000
Part No SW: 4G0 927 156 M HW: 0B5 927 156 F
Component: 0B5 30TFSIRdW H05 0026
Revision: --H05--- Serial number: 0000000311 CVN: 00000B08
ASAM Dataset: EV_TCMDL501 A02206
ROD: EV_TCMDL501.rod
VCID: 363528B0B8C76EEA25F-8062
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 B HW: 4G0 907 379 B
Component: ESP PREMIUM H09 0183
Coding: 44A6C7022265E340DB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_003.rod
VCID: 30391EA85AA340DA7F3-8064
0783 - Function Restriction due to Faults in Other Modules
U1113 00 [00001001] - -
[SCL_LWR_Hoehenwert_HL_Error]
Reset counter: 152
Mileage: 164633 km
Date: 2026.09.29
Time: 18:30:43
VzRef: 73
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 00
F-Type: E3
Uz: A8
0785 - Function Restriction due to Faults in Other Modules
[SCL_LWR_Hoehenwert_VL_Error]
Reset counter: 152
Mileage: 164633 km
Date: 2026.09.29
Time: 18:30:43
VzRef: 73
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 00
F-Type: E5
Uz: A8
Part No SW: 4H0 907 064 AP HW: 4H0 907 064 AP
Component: BCM2 2.0 H23 0208
Coding: 01BA3000000000000000
VCID: 77ABE5B4FFCD57E2FE9-8022
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2310000022275003
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H11 0054
Serial number: 18101000040185
Coding: 6623007804
ASAM Dataset: EV_AirCondiComfoUDS 002027
VCID: 270BF5F46F6D0762AE9-8072
Part No SW: 4H0 907 063 F HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0083
Revision: 20012002 Serial number: 00000000680863
Coding: 0200A09151BC8FE0CF8100C3A0001908CF9DC30A2F080101000008402100
VCID: 2B0309C4730523024A1-807E
Subsystem 1 - Part No SW: 4G8 955 119 E HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS573 091017 H32 0050
Serial number: 100112172407
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11095348
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 F HW: 4G0 941 531 F
Component: E1 - LDS H07 0044
Serial number: 08 10 2010 00000024
Component: AQ_Hum_Sensor H02 0002
Serial number: 6E284F45000000000001
Fault Status: 00101101
Reset counter: 192
Mileage: 164633 km
Date: 2026.09.29
Time: 18:30:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 F HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0020
Revision: 11001001 Serial number: 55931027801474
Coding: 302B03
ASAM Dataset: EV_AU57XParkiAssis2 002005
ROD: EV_AU57XParkiAssis2.rod
VCID: 35372FBCA5C165F22C5-8060
Part No SW: 4G0 907 561 HW: 4G0 907 561
Component: ACC3 H15 0160
Serial number: 00000000000000 Dataset Number: 4G8909863A 0016
Coding: 3C04010201
ASAM Dataset: EV_AdaptCruisContrAU57X 001003
ROD: EV_AdaptCruisContrAU57X_001.rod
VCID: 678BB5F4AFEDC7626E9-8032
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [00001000] - -
[FAULT_CIS_VIDEO_FAIL]
Reset counter: 192
Mileage: 164633 km
Date: 2026.09.29
Time: 18:30:44
Control Module temperature: 26 C
Voltage terminal 15: 12.810 V
Velocity_vehicle_reference: 32.53 m/s
Longitudinal_acceleration_vehicle_reference: -0.01 m/s
Part No SW: 4H0 959 655 B HW: 4H0 959 655 B
Component: Airbag10.43 H24 0028
Revision: -------- Serial number: 003G1001D9PP Dataset Number: 4G8909602C 0004
Coding: 30314530313230303134554A305234473853
Serial number: 3575HRB405H00BSOC9MZ
Serial number: 3585HRB405100BSO18OA
Serial number: 3515JRB405702CB87198
Serial number: 3525JRB405702CB82OT4
Serial number: 3554VRB404V010DA3HJG
Serial number: 3564VRB4053010DADP3Z
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LFE0000W
Coding: 0000FC
VCID: 372B25B4BF4D97E23E9-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H07 0009
Serial number: 13 08 2010 11036139
Part No SW: 4G8 920 981 H HW: 4G8 920 981 H
Component: TBenGb AccNv H34 0303
Revision: 18100069 Serial number: 658270910593022
Coding: 238F00025F072600010300
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU57.rod
VCID: 38292688B2D3989A373-806C
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 A HW: 4G0 907 468 A
Component: J533--Gateway H08 0183
Revision: -------- Serial number: 00000000050383
Coding: 00CD073000
GVL: FDAFE858FEE3640D40
ASAM Dataset: EV_GatewUDS 001023
ROD: EV_GatewUDS_AU57.rod
VCID: 2E0500D04097562A6DF-807A
Control module for battery monitoring:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650404343
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Serial number: 10284001051011200410
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0054
Serial number: 14101000040022
Coding: 02
ASAM Dataset: EV_ClimaContrUnitRearUDS 002010
VCID: 2F3B1DD4479D5F22669-807A
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000006509
Coding: 01010101000000000000000102
VCID: 6491A2F85E5BAC7A4BB-8030
Part No SW: 4G0 907 553 B HW: 4G0 907 553
Component: LUFE-DAEMPFER H17 0778
Dataset Number: 4G8909553C 0021
Coding: 008002
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_003_AU64.rod
VCID: 2A0D0CC07C7F3A0AB17-807E
455691 - Sensor for Ride-Height
C1048 07 [00001000] - Mechanical Failure
Reset counter: 192
Mileage: 164633 km
Date: 2026.09.29
Time: 18:30:43
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00001002137102
Coding: 0078130000006001000001010101102030303232203232
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA42003B5J0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D0707DC4D912D32545-8078
Part No SW: 4G8 959 793 B HW: 4G8 959 793
Component: TSG FA H04 0209
Coding: 011F46625E21628002080003
Shop #: WSC 02312 785 00200
VCID: 3FDB4D94977DAFA2F69-806A
Part No SW: 4G0 909 144 L HW: 4G0 909 144 E
Component: RCEPS H31 0010
Revision: 00001000 Serial number: 0013012900 Dataset Number: 4G8909852J 0028
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D14A054AF72CA097-8066
Revision: 00002001 Serial number: 0136338646
Coding: 013F062220B9BC8083300A840C0100000000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Component: Dachelektroni H09 0100
Serial number: 0000000AP00000096977
Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H09 0027
Serial number: WA101802000000102902
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007000 Serial number: 00000000005047
Coding: 030000
Shop #: WSC 45964 001 1048576
VCID: 1D67D71C3DB1DDB2C45-8048
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0209
Coding: 011F46625E21628002080002
Part No SW: 4H0 907 801 D HW: 4H0 907 801 A
Component: EPB-4 H03 0010
Revision: -------- Serial number: 00000000014340
ASAM Dataset: EV_ParkiBrake 001021
ROD: EV_ParkiBrake_VW51.rod
VCID: 290FF3CC79793112B8D-807C
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 HW: 4H4 907 357
Component: ....AFS13.... H01 0091
Serial number: 101007-0004-102
Coding: 11236F33F918EB00
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU57.rod
VCID: 6FBBDDD4871D1F22269-803A
H01 0010
Coding: 3A0000
H01 0010
Coding: 3A0000
0061 - Function Restriction due to Implausible Message(s)
U1112 00 [00001000] - -
[Fehlerhafter DLC der CAN-Messages Kamera_Status (0x318)]
Reset counter: 192
Mileage: 164633 km
Date: 2026.09.29
Time: 18:30:44
120589 - Function Restriction due to Faults in Other Modules
[Fehlerhaftes Signal in CAN-Message Fahrwerk_01_FR (0x108)]
Reset counter: 192
Mileage: 164633 km
Date: 2026.09.29
Time: 18:30:43
Part No SW: 4F0 035 061 L HW: 4F0 035 061
Component: Radio U DAB H46 0085
Revision: AB001007 Serial number: 006J 0A7509591
Coding: 010103010000000001
VCID: 2517FFFC15E115729C5-8070
Part No SW: 4G0 035 670 Q HW: 4G0 035 670
Component: H-BNT-EU H46 1034
Revision: -------- Serial number: 428J30A7505587
Coding: 090101040303F9EF6D348F3E00000003000001000000000000
VCID: 313F1BAC512949D270D-8064
Subsystem 1 - Part No: 8R0 060 884 JN
Component: EUR 2022 3401
Subsystem 2 - Part No SW: 4G2 919 610 C HW: 4G2 919 612 C
Component: E380 BDT C7 H08 0204
Serial number: 90349JJ900036
Subsystem 3 - Part No: 8R0 060 961
Component: CD-Database 1886
00658 - Control Head
Reset counter: 192
Mileage: 164579 km
Date: 2026.09.29
Time: 13:42:53
Voltage: 12.50 V
02259 - Information Display and Control Head (Front) (J685)
Reset counter: 151
Mileage: 164564 km
Date: 2026.09.29
Time: 13:16:40
Voltage: 11.60 V
03787 - Rotation Mechanism for Display Module Front
Reset counter: 152
Mileage: 164564 km
Date: 2026.09.29
Time: 13:16:36
Voltage: 11.60 V
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0209
Coding: 010F04624021628002080002
VCID: 42DD4460E48FC24A997-8016
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 HW: 4H0 907 441
Component: SG Rueckfahrkamera 0040
Revision: --H03--- Serial number: 525 PA8J09E0VV
Coding: 1020013
VCID: 6491A2F8525BAC7A4BB-8030
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 4G8 959 107 D HW: 4G8 959 107
Component: HDSG-Modul H12 0036
Revision: 11012001 Serial number: 284000119 Dataset Number: 4G8909541B 0012
Coding: 0A3205C000
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571_AU57.rod
Component: TSG HR H03 0209
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 E HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0026
Serial number: 0K84AE40012051
Coding: 1401
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
VCID: 313F1BAC51A949D270D-8064
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H07 0006
Serial number: 00000000001027100422
9986 - Function Restriction due to Faults in Other Modules
[LWR_AFS: Fehlerspeicher auslesen]
Reset counter: 192
Mileage: 164633 km
Date: 2026.09.29
Time: 18:30:43
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H23 0034
Revision: -------- Serial number: 262130025421000 Dataset Number: 4G8909547B 0026
Coding: FE040000
ROD: EV_OnBoardCamerDPC.rod
VCID: 6597BFFC55E1D5725C5-8030
0708 - Function Restriction due to Faults in Other Modules
[EGD_Fahrwerk_01_Signal_Error]
Reset counter: 192
Mileage: 164633 km
Date: 2026.09.29
Time: 18:30:43
Outside temperature: -39.5 C
Voltage terminal 15: 12.9 V
Control Module temperature: 40.0 C
Part No SW: 4G0 907 541 HW: 4G0 907 541
Coding: 3C04010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
ROD: EV_AdaptCruisContr2AU57X_001.rod
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H28 0034
Serial number: 000040180710107
Coding: 03C02B1C1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 2517FFFC156115729C5-8070
0050 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[AAG_Timeout]
Reset counter: 151
Mileage: 164564 km
Date: 2026.09.29
Time: 13:16:37
Outside temperature: 25.0 C
Voltage terminal 15: 12.1 V
Control Module temperature: 35.0 C
0091 - Function Limitation due to Missing Video Data
C1108 00 [00001000] - -
[DPC_SystemError]
Reset counter: 192
Mileage: 164633 km
Date: 2026.09.29
Time: 18:30:44
Outside temperature: 21.5 C
Control Module temperature: 38.0 C
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Dataset Number: 4G0909614A 0010
Coding: 00660600031F037E000308004248D2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
Dataset Number: 4G0909615A 0010
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70B9DEA89A2300DA3F3-8024
End----------(Elapsed Time: 02:39, VBatt start/end: 12.3V/12.3V)-----------
------------------------------14 Faults Found------------------------------
