VCDS stops on a Auto Scan on Address 05: Acc/Start Auth
A6_C6
C?ID=146343
HI all , first post so please be gentle :)
I did a auto scan on my A6 C6 and this ran no problem and had 4 DTCs which I checked and cleaned except for the 05
which had this
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300088598
Coding: 0000019
Shop #: WSC 00482 210 80117
VCID: 63CF847FA2D5442603-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H43 0070
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H36 0040
16347 - Control Module - EEPROM Error
014 - Defective
Fault Status: 01101110
Reset counter: 0
as there was only 1 fault I cleaned and thought I would see if it came back .
I now run the auto scan and it stalls at channel 5 ?
if I try to open the 05 controller it just seems to stall and I have to kill VCDS ??
the gateway reports that it is 05-Acc/Start Auth. -- Status: ok 0000
I have tried key in not running .
key in and engine running
anybody got any Ideas??
many thanks Martin
If I had to guess, I'd say your Kessy (Acc/Start Auth) module in some very unhappy state. "Control Module - EEPROM Error" is never a good sign.
Can you post the scan you ran earlier? Even if you didn't explicitly save it, it should still be in the Scans sub-folder.
A6_C6
C?ID=146343
HI Uwe
this was the original scan , after I cleared the DTC VCDS has failed to communicate with Acc/Start Auth.
what is Kessy ??
the gateways scan reports no error
but if I explicitly go into Acc/Start Auth VCDS hangs and i have to kill the process .
I am not entirley sure what acc/start auth is .
is this the key /ignition ?
I have a key with fob I have to put in the ignition switch and I have a early 2005 A6 c6
Kessy is another name for the Access/Start Authorization Module you're having trouble with at address 05.
Yep, I thought it looks very similar to this one:
Tuesday,15,March,2016,15:37:47:03954
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WAUDG74F35N105658   License Plate: 15.7.4-HUC
Mileage: 54750km-34020mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
          53 55 56 61 62 67 72 77
VIN: WAUDG74F35N105658   Mileage: 54750km-34020miles
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 4F1 910 559 B    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0050
   Revision: --H15---    Serial number:
   Coding: 01050106190F0120
   Shop #: WSC 12345 123 123456
   VCID: 2A5080E285F05B6E00-807E
16730 - Camshaft Position Sensor (G163)
            P0346 - 006 - Implausible Signal - Intermittent
                    Reset counter: 34
                    Mileage: 54576 km
                    Date: 2016.03.11
                    Time: 17:17:24
                    RPM: 192 /min
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 34.5°C
                        Start
                    Bin. Bits: 00001000
   Part No SW: 4F1 910 156 H    HW: 09L 927 156
   Component: AG6 09L 3.2 FSI USA 0020
   Revision: --H01---    Serial number:        4006305
   Coding: 0000002
   Shop #: WSC 02327 785 00200
   VCID: 29527FEE80F6507609-807C
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H03 0090
   Coding: 0020895
   VCID: 2D5A8BFEB41E4C56E5-8078
   Component: FBSAUDIC6 ELV   H30 0210
   Revision: 27120501    Serial number: 10600300127140
   Coding: 0000015
   Shop #: WSC 03743 444 20474
   VCID: 63CE2DC6A25ACA2603-8036
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 KSG   H26 0080
00955 - Key 1
                    Mileage: 53263 km
                    Date: 2015.12.06
                    Time: 11:30:51
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 731 T    HW: 4E0 035 729
   Component: Interfacebox    H43 3360
   Revision: 00000000    Serial number: 360BL057519740
   Coding: 0000003
   Shop #: WSC 02335 785 00200
   VCID: 336E9D86523A1AA6B3-8066
   Subsystem 1 - Part No: 4F0 910 609 B
   Component: Bedienteil MMIC6H07 0010
   Subsystem 2 - Serial number: 00000000114429
   Subsystem 3 - Serial number: 0122.02.050000000100010688я
   Subsystem 4 - Serial number: 010688я
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 J
   Component: KLIMABETAETIGUNGH11 0150
   Revision: 00000026    Serial number: 00000000119115
   Coding: 0524326
   VCID: 5BBE15269A2AF2E64B-800E
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 11
                    Reset counter: 187
                    Mileage: 54486 km
                    Date: 2016.03.07
                    Time: 14:03:10
                    Temperature: 21.0°C
   Part No SW: 4F0 910 279 D    HW: 4F0 907 279
   Component: ILM Fahrer      H14 0190
   Coding: 0013123
   Shop #: WSC 03763 444 58363
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00064784
   Shop #: WSC 03763
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 03763
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE7125079
   VCID: 1C3C563ADFA4B5DE82-8048
Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
   Part No SW: 4E0 910 593 G    HW: 4E0 035 593 C
   Component: SDAR XM         H04 0670
   Revision: 00000000    Serial number: AUZ4Z7D2021085
   VCID: 2B5E85E68A0A4266FB-807E
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
   Component: 56 AIRBAG AUDI8RH29 0230
   Revision: 10H29000    Serial number: 00359D089J1O
   Coding: 0013622
   VCID: 264874D291E87F0E24-8072
   Subsystem 1 - Part No: 4F0 910 339
   Component: BF-Gewichtsens. 002 0040
   Subsystem 2 - Serial number: 6332CSME09146C452
   Subsystem 3 - Serial number: 6342CSME08721227Y
   Subsystem 4 - Serial number: 6351HSME063F0106+
   Subsystem 5 - Serial number: 6361HSME0630676EA
   Subsystem 6 - Serial number: 6371VSME06295631F
   Subsystem 7 - Serial number: 6381VSME06290761F
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksдulenmodul H07 0230
   Revision: 00H07000    Serial number: 90025050480214
   Coding: 0002041
   Shop #: WSC 02323 785 00200
   VCID: 66C834D25168BF0EE4-8032
   Component: Lenkradmodul    H06 0080
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
   Component: KOMBIINSTR. M73 H10 0670
   Revision: 00500000    Serial number: 4R853ZR25
   Coding: 0065201
   Shop #: WSC 06485 067 57207
   VCID: 1E385C32C9B8A7CE6C-804A
Address 19: CAN Gateway        Labels: 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
   Component: Gateway         H09 0030
   Revision: 09          Serial number: 080080521900E6
   Coding: 6CFE73CC1B7904
   VCID: 275679D696E266061F-8072
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082954
   Shop #: WSC 02325 785 00200
   VCID: 61C227CEB846D83611-8034
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
   Component: MNS US          H44 1100
   Revision: 00000000    Serial number: 378BU057517436
   VCID: 3874AAAA4B5CF9FE86-806C
02927 - DVD Read Error
            000 -  -  - Intermittent
                    Fault Frequency: 61
                    Reset counter: 230
                    Mileage: 53214 km
                    Date: 2015.11.30
                    Time: 08:04:57
                    Hex Value: 0x56E8
                    Hex Value: 0x1800
                    Hex Value: 0x0401
                    Hex Value: 0x0000
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H11 0040
   Revision: 00000000    Serial number: V‡G
   Coding: 0051947
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
   Component: Komfortgeraet   H15 0100
   Revision: 01000015    Serial number: 01002940220000
   Coding: 0424253
   VCID: 2C5C86FA8F04455EF2-8078
   Component: LIN BACKUP HORN H02 1301
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F5 910 223 D    HW: 4F5 035 223 E
   Component: DSP-High C6     H14 0310
   Revision: PROD_01     Serial number: 00000000025340
   Coding: 0000026
   VCID: 244C6EDAE7D48D1E3A-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H09 0050
   Revision:             Serial number: 00000000070724
   Coding: 0001114
   VCID: 5EB81C328938E7CE2C-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H11 0040
   Revision: 00000000    Serial number: ѓE
   Coding: 0051947
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005022
   Shop #: WSC 02334 785 00200
   VCID: 5DBA1B3E843EFCD635-8008
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   Coding: 0000016
   Shop #: WSC 03743 444 78366
   VCID: 28547AEA9BFC697E16-807C
   Subsystem 1 - Part No: 4F0 941 329 A
   Component: AFS-Modul links H05 0010
   Subsystem 2 - Part No: 4F0 941 329 A
   Component: AFS-Modul rechtsH05 0010
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 394BM057520850
   Coding: 0000002
   VCID: 2E588CF2B918374EDC-807A
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000024866
   VCID: 234E6DC6E2DA8A2643-8076
   Subsystem 1 - Part No: 000 915 105 DK
   Component: von VA0  020627R0Z5
   Coding: 303030393135313035444B56413030323036323752305A35
   Shop #: WSC 54332 321 22222
02273 - Quiescent Current Stage 2
                    Date: 2016.01.22
                    Time: 13:49:16
02276 - Quiescent Current Stage 5
                    Mileage: 53880 km
                    Date: 2016.01.22
                    Time: 13:53:46
02274 - Quiescent Current Stage 3
                    Mileage: 53880 km
                    Date: 2016.01.22
                    Time: 13:53:56
02277 - Quiescent Current Stage 6
                    Mileage: 53880 km
                    Date: 2016.01.22
                    Time: 13:54:06
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H11 0030
   Coding: 0051754
   VCID: 69D23FEE40769076C9-803C
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000502160018
   Shop #: WSC 12336 024 394758
   VCID: 346C9E9A57341D9EAA-8060
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H11 0030
   Coding: 0051754
   Part No SW: 4F0 910 336 D    HW: 4E0 862 335
   Component: Handyvorb2      H10 0700
   Revision: 00000000    Serial number: 00000007516826
   Coding: 0010900
End-------------------------(Elapsed Time: 02:50)--------------------------
... that I just had my my minion check with current versions, to make sure we hadn't broken anything in VCDS recently.
Gone But Not Forgotten
Check kessy for water damage...........and blown fuses.
A6_C6
C?ID=146343
HI Jack
sorry I have only basic knowledge , can you explain how to check kessy for water damage ?
which bits do i need to check ( sorry kessy is new on me )
I will check all the fuses too
many thanks
Martin
Martin,
RTFB the manual at Erwin........print to PDF.
www.erwin.audi.com
Find the module location using WD and component locations guide in the repair manual.
Remove Kessy and check in area of it for water ingress.
I think the 4F chassis KESSY is sold with the entire steering column and ESCL (Electric Steering Column Lock) but ruling out water/corrosion and voltage drops to it would be best.
P.S. If it is faulty that controller is the Immobilizer. So, if it needs to be replaced - be warned the car will not communicate or start/run/drive until it is matched. We do not have a matching procedure for that particular Immo system so online at the Audi dealer -or- online Independent solutions such as a Pass-Thru running ODIS would be needed to match it.
A6_C6
C?ID=146343
sorry guys
I am a bit confused now?
as the car starts drive and stops without any issues ?? , as I have said before the Gateway reports no Malfunctions including channel 5 ?
the Car is a 2005 Audi A6 c6 /4F 3.0 TDI Sline.
I have checked and reseated all the fused with no effect
the VDS Gateway test works no problems
I can run all tests individually on all channels EXCEPT channel 5 which just seems to stop ( as there seems to be no timeout in the software )
if I run the auto scan it runs through the gateway check starts running the checks on all channels but stalls at channel 5 ?
the car and keyfob seems to work without issue ? but I am confused why the VCDS cannot see channel 5 without throwing up some sort of malfunction ?
thanks
Martin
What happens when you try to access 05 directly?
A6_C6
C?ID=146343
HI Uwe VCDS just seems to hang , although i think it is more there is no time out on the access , I have to kill VCDS using task manager .
update
ok I fully charged the battery for 48 hours and tried the spare key and all seems to work and the auto scan now works .
so looks like it may be the Key at fault .
I will double check the problem over the weekend to check my thoughs are correct .
many thanks for all you help guys :) :)
FWIW, I believe there are conditions where a control module can explicitly tell VCDS, "Stand by, I'm busy" and VCDS will do precisely that...
If you see this again, let us know...
