- Sep 3, 2026
- 3
- 1
- Red Lion, PA, USA
- C?ID=660912
Long story, but I'll keep it brief...
The front hubs were replaced along with wheel bearings earlier this year to correct bearing wear. Aftermarket hubs with bolt-on tone rings were used in the repair (the shop has been removed from future consideration). Subsequently, the low-speed ABS engagement issue started - under 10 mph the abs kicks on. ABS functions normal in sudden stops over 10 mph. I pursued the issue and discovered the LF tone ring bolts had backed-out and sensor had been damaged from rubbing. I've cleaned-up and trued the tone ring, and replaced both front wheel speed sensors. Along the way, I purchased VCDS to help with diagnosis, which brings me to my question... Should I replace the ABS controller, or replace the hubs again, and which should I do next? (OEM Tone rings can't be removed from the hubs, and the hubs must be removed to replace the aftermarket versions).
I ran an Autoscan this morning. it shows wheel sensor faults which were set as I worked through the truing of the front tone rings with the car raised and freewheeling. I believe those are red-herrings, but didn't want to clear faults just yet. Thanks in advance for the help.
No Code Provided
No Code Provided
Monday,28,September,2026,11:08:27:36004
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.5
VIN: TRUWT28N621029275 License Plate: RR5T81
Mileage: 150172 Repair Order: 092826-01
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine Labels: 06A-906-032-AMU.lbl
Part No: 8N0 906 018 AN
Component: 1.8L R4/5VT G 0004
Coding: 06710
Shop #: WSC 01236
VCID: 7DA01836C4E9A4A28C6-5160
TRUWT28N621029275 AUZ5Z0B3245183
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-10 - Signal too Low - Intermittent
Address 03: ABS Brakes Labels: 8N0-907-379-MK60-A.lbl
Part No: 8N0 907 379 H
Component: ESP ALLRAD MK60 0101
Coding: 0022544
Shop #: WSC 01236 785 00200
VCID: 41D8A4C6FD910042A8E-5160
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
VCID: 280E19627BEBD10A8F0-258E
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
Address 15: Airbags Labels: 8N0-959-655.lbl
Part No: 8N0 959 655 A
Component: Airbag Front+Seite 5000
Coding: 01103
Shop #: WSC 01236
VCID: 3E22DF3A896F7FBAD5C-5160
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N1 920 980
Component: KOMBI+WEGFAHRS. M73 D14
Coding: 07244
Shop #: WSC 05146
VCID: 73B43E0EF2ADE2D2EA2-4B1E
00849 - S-contact at Ignition/Starter Switch (D)
30-00 - Open or Short to Plus
01304 - Radio
49-00 - No Communications
37-00 - Faulty
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 C
Component: HALDEX LSC ECC 0010
VCID: 201E014213DB294AC70-4B1E
Address 35: Centr. Locks Labels:. 8Nx-962-267.clb
Part No: 8N8 962 267 A
Component: Central Lock/Alarm D06
Coding: 15884
Shop #: WSC 05146
VCID: 3FDCA23E8E6576B2DEA-4F26
01374 - Alarm triggered by Terminal 15
35-00 - -
01616 - Signal Wire to Interior Monitor
36-00 - Open Circuit
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
31-00 - Open or Short to Ground
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
VCID: 659050564C790C62746-51AC
End----(Elapsed Time: 02:52, VBatt start/end: 11.2V/11.1V. VIgn 11.2V)-----
------------------------------13 Faults Found------------------------------
