2024 Golf R battery died, auto scan log attached
R-squared
C?ID=3845
The battery on my 2024 Golf R died recently. The voltage was around 3 volts, suggesting a parasitic drain. It was the original battery with no previous problems, and the car had been driven within the last 48 hours. I replaced the battery, coded it, did an autoscan, cleared all DTCs, reset the infotainment system by holding the power button down until it shut down and rebooted, then scanned again. Results here. AI suggests infotainment and steering wheel problems which the dealer should fix under warranty. Please let me know if this is correct, or if you suggest something else. Thank you in advance!
Sunday,27,September,2026,14:42:43:28608
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.4
VIN: WVWFB7CD8RW215812   License Plate: 24 GOLF R AFTER DTCS CLEARED
Mileage: 23686km-14717mi   Repair Order:
Chassis Type: CD-VW38 (5WA)
Scan: 01 03 05 08 09 10 13 14 15 17 19 23 2B 36 3C 42 44 47 4B 52
          5F 6C 75 82 A5 A9 CA D6 D7 8126 8127 C002 C003
VIN: WVWFB7CD8RW215812   Mileage: 23686km-14717miles
CA-Sunroof -- Status: OK 0000
8126-Trq distrib RearL axle -- Status: OK 0000
8127-Trq distrib RearR axle -- Status: OK 0000
Address 01: Engine (J623-DSFF)       Labels: Redir Fail!
   Part No SW: 5H0 906 259 J    HW: 06K 907 425 N
   Component: R4 2.0l TFS   H08 0001
   Dataset Number: 06Q909102H  0010 CVN: D72AC06EFCD25DD3
   Coding: 091900322466000E30040000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0205H0906259J 001002
   ROD: EV_ECM20TFS020_VW38.rod
   VCID: 3635DA5CC8C181BA0DC-8062
   VINID: 9E69D64874D42229C2045201087703BE70
23079 - Control unit for information electronics 1
          U1054 00 [00100110] - No Communication
                    Mileage: 23681 km
                    Date: 2026.09.27
                    Time: 14:24:39
                    Engine speed: 800.50 /min
                    Normed load value: 11.8 %
                    Coolant temperature: 94  C
                    Intake air temperature: 30  C
                    Voltage terminal 30: 12.539 V
                    LF_MVB_PDU_INTC_DIAG_8: 0
                    LF_MVB_PDU_INTC_DIAG_9: 0
                    LF_MVB_PDU_INTC_DIAG_10: 0
                    LF_MVB_PDU_INTC_DIAG_11: 8192
                    LF_MVB_PDU_INTC_DIAG_13: 4
                    LF_MVB_BUS_INTC_DIAG: 256
Readiness: 0000 0100
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 CF    HW: 5WA 614 517 N
   Component: ESC           H13 0135
   Serial number: 61084000012042  Dataset Number: V03935397FY 0001 CVN: D77D4621
   Coding: 76FC6E9076216E71527F6E0176C560064A525A55528803C02014B831018FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013058
   ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
   VCID: 0E4552BC90D1997A65C-805A SFD [x]
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 Q    HW: 5WA 959 436 Q
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935341VY 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004.rod
   VCID: 629D560C34C94D1A914-8036
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 007 AC    HW: 5WA 907 007 AC
   Component: AC Automat    H31 3623
   Serial number: --------------- Dataset Number: V03935418JG 0001
   Coding: 002000110210120011101010111111110000131100200100000000000000
   ASAM Dataset: EV_ACClimaPREVW38X 001102
   ROD: EV_ACClimaPREVW38X_VW38.rod
   VCID: 084964A4F2B5C74AAF0-805C
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000010000323627
   Subsystem 2 - Part No SW: 11A 907 049 B    HW: 11A 907 049 B
   Component: E265 KPH SH    H02 0184
   Serial number: G07S15.04.2400971887
   Interior temperature sensor:
   Subsystem 3 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00001070424042327510
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 BT    HW: 5WA 937 086 BB
   Component: BCM37w_H134 0183
   Serial number: BXJ53F120424940 Dataset Number: V03935400FM 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_VW38.rod
   VCID: 241110146E5D032AA38-8070 SFD [x]
   Subsystem 1 - Part No SW: 5H1 955 119 B    HW: 5H1 955 119
   Component: FWISCHER_MYJT  003 0061
   Serial number: 907453F0402408900081
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS           054 0206
   Serial number: SBY24M04D24H07M05S17
   Subsystem 3 - Part No SW: 5H0 941 193 AL    HW: 5H0 941 193 AL
   Component: LiSi           H06 0008
   Serial number: 92471XBF001T9
   Subsystem 4 - Part No SW: 5H0 925 200 R    HW: 5H0 925 200 R
   Component: DiETa          H07 0008
   Serial number: 92471XDB002E6
   Subsystem 5 - Part No SW: 5H0 959 561 BQ    HW: 5H0 959 561 BQ
   Component: -VW----LINDA-  504 0831
   Serial number: MW3LND22042400011142
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0102
   Serial number: ESE4108358
   Subsystem 7 - Part No SW: 3G0 963 345 A    HW: 3G0 963 345 A
   Component: SysNameFanLin  015 0102
   Serial number: ESE4058403
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE4108445
   Subsystem 9 - Part No SW: 3G0 963 345 A    HW: 3G0 963 345 A
   Serial number: ESE4058389
   Steering Column Switch:
   Subsystem 10 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Serial number: 00000017042408490368
   Part No SW: 5R3 919 298 A    HW: 5R3 919 298
   Component: PLA 12 Kanal  H05 1570
   Serial number: 000995442324114 Dataset Number: V03935394RP 0001
   Coding: 0200026001
   ASAM Dataset: EV_EPHVA2CVW3800000 002036
   ROD: EV_EPHVA2CVW3800000_VW38.rod
   VCID: 41DFB980910F3602A8E-8014
Address 13: Auto Dist. Reg (J428)       Labels:| 5WA-907-572.clb
   Part No SW: 5WA 907 572 C    HW: 5WA 907 572 A
   Component: ACC BOSCH MQB H45 0461
   Dataset Number: V03935392FC 0001
   Coding: 06230094400780451247400000804004AE4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: 4EC592BC5051D97A25C-801A
Address 14: Susp. Elect. (J250)       Labels: 1EA-907-376.clb
   Part No SW: 1EA 907 376 C    HW: 1EA 907 376
   Component: DAEMPFUNGS-SG H05 0457
   Serial number: 2C7673241312122 Dataset Number: V03935344MR 0001
   ASAM Dataset: EV_DCC3CONTITEMIC 002006
   ROD: EV_DCC3CONTITEMIC_002_VW38.rod
   VCID: 3A2DCE6CFCD965DAE94-806E
Address 15: Airbags (J234)       Labels:* 5WA-959-655.clb
   Part No SW: 5WA 959 655 AE    HW: 5WA 959 655 AE
   Component: AirbagVW40    011 0660
   Serial number: 000000003C0RMRB Dataset Number: V03935414HD 0001
   Coding: 8CCC000000FCC00000000000000000005100000000000000000036F800130065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001034
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 1A6D2EEC5C1945DA094-804E SFD [x]
   Component: -------------  H17 0022
   Serial number: IBH00000000000LLUODQ
   Subsystem 2 - Part No SW: -----------    HW: 480 051 504 24
   Component: SideSensor_Dr  000 0149
   Serial number: 3510000AACC722D04724
   Subsystem 3 - Part No SW: -----------    HW: 480 051 504 24
   Component: SideSensor_Pr  000 0149
   Serial number: 3520000B6CE3D558292E
   Subsystem 4 - Part No SW: -----------    HW: 480 000 803 24
   Serial number: 357000000006B99C8E64
   Subsystem 5 - Part No SW: -----------    HW: 480 002 203 24
   Serial number: 358000000006EA69DE68
   Subsystem 6 - Part No SW: -----------    HW: 480 050 712 23
   Component: FrontSensor_D  000 014A
   Serial number: 3550000BACC7B3CB862W
   Subsystem 7 - Part No SW: -----------    HW: 480 050 712 23
   Component: FrontSensor_P  000 014A
   Serial number: 3560000A2CA8D290E5ER
Address 17: Instruments (J285)       Labels:| 5H0-920-KOM-V1.clb-SRI2
   Part No SW: 5H0 920 340 C    HW: 5H0 920 340 C
   Component: KOMBI         310 7380
   Dataset Number: V03935364SX 0001
   Coding: 08BC02027B9CCF050280620B2000000810300000
   ASAM Dataset: EV_DashBoardVDDMQB37W 003035
   ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
   VCID: 221D160C74490D1AD14-8076 SFD [x]
16777020 - Control unit for information electronics 1
          U1054 00 [00001001] - No Communication
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 170
                    Mileage: 23686 km
                    Date: 2026.09.27
                    Time: 14:40:06
   Part No SW: 5WA 907 530 AB    HW: 5WA 907 530 L
   Component: GW2020 High   778 7105
   Revision: --------    Serial number: 771049110024097 Dataset Number: V03935439LN 0001
   Coding: 0000800D0E00000000000000012303307302610902000300030100000001010000000000000000000000000000000000
   GVL: 3D080000020840DC800080824C00104004404002004000300200000000000044
   ASAM Dataset: EV_GatewMQB2020 006012
   ROD: EV_GatewMQB2020_006_VW38.rod
   VCID: 084964A4F2B5C74AAF0-805C SFD [ ]
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 3704774206
   Subsystem 3 - Part No SW: 1EA 959 442 F    HW: 1EA 959 442 F
   Component: MFL            H03 0219
   Serial number: 17038315110962401124
   Subsystem 4 - Part No SW: 5H0 959 542 N    HW: 5H0 959 542 N
   Component: KLR_JSS_1Zone  089 0023
   Serial number: 3136188AA24096179303
2175091 - Control unit for information electronics 1
          U1054 00 [00101110] - No Communication
          [Information_electronics_control_module_1_no_communication]
          B184C 00 [00101111] - -
          [Unlock_protection_of_vehicle_diagnosis_active]
                    Mileage: 23681 km
                    Date: 2026.09.26
                    Time: 16:57:47
   Part No SW: 5WA 909 059 AB    HW: 3Q0 909 059 D
   Component: EBKV          H09 0372
   Serial number: BPA085090424013 Dataset Number: V03935367RC 0001
   Coding: 5003C5409B00009C73CE39E7000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
   VCID: 10794CC48AE58F8A770-8044 SFD [x]
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H10 0040
   Serial number: 24000118623013 Dataset Number: V03935336NF 0001
   Coding: 0000000000000000
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: 323DE64C24A99D9A214-8066
   Part No SW: 5WA 959 760 H    HW: 5WA 959 760 H
   Component: MEM-FS        009 0362
   Serial number: 2441001KA01370 Dataset Number: V03935307MP 0001
   Coding: 01589A40000020408803010101010000000000212100000000000000215000
   VCID: 59EF71E0199F8EC2C0E-800C
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 J    HW: 2Q0 907 686 J
   Component: HRE_Master    H27 0288
   Serial number: 00000643158333  Dataset Number: V03935373GS 0001
   Coding: 569945D0
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001016
   ROD: EV_HREntryHellaGen3Mstr_VW38.rod
   Subsystem 1 - Part No SW: 2Q0 907 685 J    HW: 2Q0 907 685 J
   Component: HRE_Slave      H27 0288
   Serial number: 00000640567943
   Lane change assistance display left:
   Subsystem 2 - Part No SW: 5H1 949 145     HW: 5H1 949 145
   Component: SWA LED VL     H05 0005
   Serial number: 00000000000016909060
   Lane change assistance display right:
   Subsystem 3 - Part No SW: 5H1 949 146     HW: 5H1 949 146
   Component: SWA LED VR     H05 0005
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS004 0350
   Serial number: YE007XD60890D Dataset Number: V03935413UZ 0001
   Coding: 003B13205200040008000000
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 4ACD9EACAC39F55A794-801E
   Subsystem 1 - Part No SW: 5Q0 959 408 G    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000080330784
   Coding: 111000
   Part No SW: 5WA 907 145 G    HW: 5WA 907 145 C
   Component: BASGEN1MQB37  502 1040
   Serial number: 03701514 Dataset Number: V03935358SR 0001
   Coding: 0000000000000001000002010100010000000100010101
   ROD: EV_SteerAssisBASGEN1MQB37_007.rod
   Part No SW: 5H0 035 456 A    HW: 5H0 035 456 A
   Component: AMPeth12CDoIP H06 4319
   Serial number: A1129C00289422  Dataset Number: V03935345SG 0001
   Coding: 23000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_AMPEthMQB37w 001005
   ROD: EV_AMPEthMQB37w_VW38.rod
   VCID: 25170D106567FA22B46-8070 SFD [x]
   Part No SW: 5WA 907 338 B    HW: 5WA 907 338
   Component: FCM2020 Low   H14 1447
   Serial number: 280151224163303 Dataset Number: V03935346BX 0001
   Coding: 000000000900071206112310040003070300000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW38X 004012
   ROD: EV_MultiModulContiVW38X.rod
   VCID: 4DC795B05D57E2625C6-8018 SFD [x]
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS004 0350
   Serial number: YE007XD616881 Dataset Number: V03935413V  0001
   Coding: 003B13205E00040000800000
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 49CFA1A0A93FFE4270E-801C
   Subsystem 1 - Part No SW: 5Q0 959 407 G    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000080241515
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 5H0 035 877 D    HW: 5H0 035 877
   Component: MU-O-NS-US    H67 1990
   Serial number: WG8LGM180424000 Dataset Number: V03935431DH 0001
   Coding: 23800000000100000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_001_VW38.rod
   VCID: 2F3BEF38379BB0724EA-807A SFD [x]
   Subsystem 1 - Part No SW: 5H0 919 605 B    HW: 5H0 919 605 B
   Component: ABT_W_10       H49 2103
   Serial number: APUFP524042400010846
   Subsystem 2 - Part No SW: V03 959 820 GQ    HW: -----------
   Component: NAR 2024       --- 0095
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 D    HW: 5WA 980 556 B
   Component: RV eCompact   H31 0344
   Serial number: FCLK20170224010 Dataset Number: V03935359FC 0001
   Coding: 02030004E43000
   ASAM Dataset: EV_CamSysRVCCompaFicos 010024
   ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
   VCID: 52FD86CC4469BD9A014-8006
   Part No SW: 5WA 035 285 F    HW: 5WA 035 285 A
   Component: OCU3HMQB37W   H14 0026
   Serial number: 0000000310VIEY1 Dataset Number: V03935379BN 0001
   Coding: 023800209068AC209025460070502E07
   ASAM Dataset: EV_OCU3HMQB37W 001051
   ROD: EV_OCU3HMQB37W_001_VW38.rod
   VCID: 4ACD9EACAC39F55A794-801E SFD [x]
Address 82: Head Up Display (J898)       Labels:| 5H1-919-608.clb
   Part No SW: 5H1 919 608     HW: 5H1 919 608
   Component: HeadupDisplay H17 2045
   Dataset Number: V03935332ET 0001
   Coding: 5740A0
   ASAM Dataset: EV_HeadUpDisplMQB37W 001018
   ROD: EV_HeadUpDisplMQB37W.rod
   VCID: 6FBB2F38F71BF0720EA-803A
   Part No SW: 5WA 980 653 D    HW: 5WA 980 653
   Component: MQB MFK 3.0   H12 3405
   Serial number: EB7590903241100 Dataset Number: V03935412E  0001
   Coding: 00000A88116CC040109F00001020002000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005055
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
   VCID: 50F98CC44A65CF8A370-8004
1124477 - Databus
          [KLR_01_KLR_Touchauswertung]
                    Mileage: 23686 km
                    Date: 2026.09.27
                    Time: 14:40:03
1124476 - Databus
          [KLR_01_KLR_Touchintensitaet_3]
                    Mileage: 23686 km
                    Date: 2026.09.27
                    Time: 14:40:03
1124475 - Databus
          [KLR_01_KLR_Touchintensitaet_2]
                    Mileage: 23686 km
                    Date: 2026.09.27
                    Time: 14:40:03
1124474 - Databus
          [KLR_01_KLR_Touchintensitaet_1]
                    Mileage: 23686 km
                    Date: 2026.09.27
                    Time: 14:40:03
   Part No SW: 5H0 907 159 A    HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0002
   Serial number: 240329291770
   ROD: EV_SoundActuaGen2AU64X_003_VW27.rod
   VCID: 2D07F5303D97C2627C6-8078
   Part No SW: 4K1 907 594 CB    HW: 4K1 907 594
   Component: SAD_STG_1     006 0040
   Dataset Number: V03935402SS 0001
   Coding: 008000738001
   VCID: 77AB17588F4BB8B2D6A-8022
   Part No SW: 992 941 571 AH    HW: 992 941 571 A
   Component: LED1L         H25 9204
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 68894424D2F5274A4F0-803C
   Component: LED1R         H25 9204
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address 8126: Trq distrib RearL axle (J492)       Labels: 08E-907-554.clb
   Part No SW: 08E 907 554 J    HW: 08E 525 130
   Component: 4Motion       H06 0160
   Serial number: 01GJ8ZG
   Coding: 00010100
   ASAM Dataset: EV_TorquSplitLeftMAGNA 001005
   ROD: EV_TorquSplitLeftMAGNA.rod
   VCID: 3537DD50D5C78AA2046-8060
Address 8127: Trq distrib RearR axle (J492)       Labels: 08E-907-554.clb
   Serial number: 01GJ8O2
   Coding: 00010100
   ASAM Dataset: EV_TorquSplitRightMAGNA 001005
   ROD: EV_TorquSplitRightMAGNA_001.rod
End----------(Elapsed Time: 01:44, VBatt start/end: 12.8V/12.9V)-----------
------------------------------8 Faults Found-------------------------------
Jef
HQ
Have you done any actual parasitic draw testing?
The fault codes that are in Auto-Scan because you rebooted the 5F with the ignition on? Do those codes clear out and stay out or come back?
R-squared
C?ID=3845
I have not done parasitic draw testing but since replacing the battery, clearing codes, resetting MMI, the battery has stayed charged. With the car locked and hood open the voltage after being shut down and locked overnight was 12.67 volts so whatever problem is happening is intermittent.
I am not sure I understand the second question. Is there a way to reboot the 5F with the ignition off?
The codes did not clear after replacing the battery and clearing all DTCs.
Jef
HQ
There are 4 different fault codes for information electronics 1 being off line (no communication). Was that caused by you doing the reset on it? If so, then those codes should clear out and not come back.
R-squared
C?ID=3845
Thank you for your reply. I am not particularly knowledgable in this area so I am not sure if anything was caused by the reset. Could you suggest a next step? Should I drive the car and then clear the codes again? Should I do it with the ignition on or in accessory position? Or something else?
Battery continues to hold charge with car locked. Voltage dropped .01V over last 24 hours.
Jef
HQ
