r8 v10 error message removal
ixotuckeroxi
C?ID=272420
hello all!
I had the pleasant opportunity to speak to uwe about some self inflicted minor annoyances with my r8. the car runs fine but I would like to remove some of the lights that are present due to new wheels and tires and the license plate leds. im getting both errors in my hud which are flat tire and tail lamp outage. upon scanning I also saw some other errors but I believe they are from previous owners and shops working on the car (twin turbo and my battery change). if you guys could view my logs and offer some insight as to how to remove those wonderful, neverending error messages I would greatly appreciate it! also, I think that's the proper tags for the scan
Tuesday,08,March,2016,19:24:58:49161
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WUAANAFG7BN000151   License Plate: R8TEDR
Mileage: 23630km-14683mi   Repair Order:
Chassis Type: FG (1K0)
Scan: 01 02 03 08 09 0F 10 11 31 14 15 16 17 19 25 2E 37 42 46 47
          52 56 65 6C 77
VIN: WUAANAFG7BN000151   Mileage: 23630km-14683miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
Address 01: Engine
Address 02: Auto Trans        Labels: 420-910-156-V2.clb
   Part No SW: 420 910 156 H    HW: 420 927 156
   Component: SL600 5.2L FSI HDZ  0050
   Revision: SBH02001    Serial number: 8I1N45T4K
   Coding: 0000001
   Shop #: WSC 02197 785 00200
   VCID: 1427D01437BB869ECA-8040
   Subsystem 1 - Part No: 420 713 041 C
   Component: A11 C02  27.03.10   0A11
005968 - Supply Voltage
               P1750 - 000 - too Low - Intermittent
                    Mileage: 23468 km
                    Date: 2016.02.27
                    Time: 23:57:59
                    Torque: 0.0 Nm
                    Temperature: 18.0°C
                        0.00 %
Address 03: ABS Brakes        Labels: 420-910-517.lbl
   Part No SW: 420 910 517 B    HW: 420 614 517 B
   Component: ESP8 quattro    H01 0100
   Coding: 0000268
   VCID: 0F2DDF781E9D6546F7-805A
                    Reset counter: 65
                    Mileage: 23366 km
                    Date: 2016.02.17
                    Time: 16:18:40
                    Hex Value: 0x00C0
                    Hex Value: 0x4002
                    Hex Value: 0x0003
                    Hex Value: 0x1657
                    Hex Value: 0x0000
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
                    Fault Frequency: 16
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.20
                    Time: 00:27:04
                    Hex Value: 0x0000
                    Hex Value: 0x6222
                    Hex Value: 0x0027
                    Hex Value: 0x018E
                    Hex Value: 0x0000
            000 -  -  - Intermittent
                    Fault Frequency: 11
                    Reset counter: 75
                    Mileage: 23468 km
                    Date: 2016.02.28
                    Time: 00:00:19
                    Hex Value: 0x0000
                    Hex Value: 0x4222
                    Hex Value: 0x0023
                    Hex Value: 0x018C
                    Hex Value: 0x0000
   Part No SW: 420 820 043 C    HW: 420 820 043 C
   Component: J255  Klima 1 Zone  0080
   Revision: 00H05007    Serial number: 00000001150820
   Coding: 1572906
   VCID: 0A1BCE6C65FF406E20-805E
                    Reset counter: 75
                    Mileage: 23468 km
                    Date: 2016.02.20
                    Time: 00:27:04
                    Mileage: 23468 km
                    Date: 2016.02.27
                    Time: 23:57:05
                    Voltage: 9.60 V
Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
   Part No SW: 8P0 907 063 S    HW: 8P0 907 063 L
   Component: BCM PQ35  H   106 0667
   Revision: 00106 AD
   Coding: 6E000A00A093362420744CE00920004950726A001120C92ADC08081C0040
   Shop #: WSC 47389 001 1048576
   VCID: 44872054C75BD61E1A-8010
   Subsystem 1 - Part No SW: 423 955 113     HW: 423 955 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiR  H22 0040
   Coding: 005912
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 025B32
17 Faults Found:
01259 - Fuel Pump Relay (J17)
                    Fault Status: 00101001
                    Reset counter: 69
                    Mileage: 23467 km
                    Date: 2016.02.20
                    Time: 20:21:25
                        Term 15 Off
                    Voltage: 12.35 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 23467 km
                    Date: 2016.02.20
                    Time: 20:21:25
                        Term 15 Off
                    Voltage: 12.35 V
                        Term 50 Off
                    Fault Status: 00101011
                    Reset counter: 69
                    Mileage: 23467 km
                    Date: 2016.02.20
                    Time: 20:21:53
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 23467 km
                    Date: 2016.02.20
                    Time: 20:22:05
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 36
                    Mileage: 20059 km
                    Date: 2015.04.01
                    Time: 18:24:35
                        Term 15 Off
                    Voltage: 12.50 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.20
                    Time: 00:00:43
                        Term 15 Off
                    Voltage: 12.25 V
                        Term 50 Off
02742 - Bulb for Brake/Turn Signal Light; Left
                    Fault Status: 00101010
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.27
                    Time: 23:14:52
                    Voltage: 11.20 V
                        Term 50 On
02743 - Bulb for Brake/Turn Signal Light; Right
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.27
                    Time: 23:14:52
                    Voltage: 11.20 V
                        Term 50 On
                    Fault Frequency: 16
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.27
                    Time: 23:14:52
                    Voltage: 11.25 V
                        Term 50 On
03134 - Motor for Rear Spoiler Movememt (V54)
                    Fault Status: 00101100
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.27
                    Time: 23:15:00
                        Term 15 Off
                    Voltage: 11.45 V
                        Term 50 Off
03132 - Limit Switch for Rear Spoiler Movement (F135/F136)
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.27
                    Time: 23:15:01
                        Term 15 Off
                    Voltage: 11.45 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.27
                    Time: 23:46:47
                    Voltage: 10.85 V
                        Term 50 On
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.28
                    Time: 03:42:00
                    Voltage: 8.50 V
                        Term 50 On
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.28
                    Time: 03:43:26
                    Voltage: 7.90 V
                        Term 50 On
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.28
                    Time: 03:43:30
                        Term 15 Off
                    Voltage: 8.65 V
                        Term 50 Off
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.28
                    Time: 03:43:30
                        Term 15 Off
                    Voltage: 8.65 V
                        Term 50 Off
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.28
                    Time: 03:43:59
                    Voltage: 8.65 V
                        Term 50 On
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7K0576837
   Coding: 0000100
   VCID: 36634A9C4187748E94-8062
            000 -  -
                    Reset counter: 29
                    Mileage: 23468 km
                    Date: 2016.02.27
                    Time: 23:55:37
Address 10: Park/Steer Assist (J446)       Labels: 420-919-475.clb
   Part No SW: 420 919 475     HW: 420 919 475
   Component: PARKHILFE 8K  H07 0130
   Revision: 11001001    Serial number: 79941006702175
   Coding: 30010C
   Shop #: WSC 02391 823 56573
   VCID: 59B9E12050D97BF659-800C
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.27
                    Time: 23:59:15
                    Temperature: 16.0°C
Address 11: Engine II
Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
   Part No SW: 420 910 376 A    HW: 420 907 376 A
   Component: J250 Raddaempfung   0170
   Revision: --H16---    Serial number: 190DPH 0070156
   Coding: 0000052
   VCID: 1129D90008A973B6E1-8044
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.28
                    Time: 03:43:07
                    Voltage: 8.52 V
                    Voltage: 4.99 V
Address 15: Airbags        Labels: 420-959-655.lbl
   Part No SW: 420 959 655     HW: 420 959 655
   Component: SN Airbag 9.43  H02 0020
   Revision: 93H02002    Serial number: 003B8000CKU+
   Coding: 0021326
   VCID: 5DB1F53084F187D635-8008
   Subsystem 1 - Part No: 8J0 910 339 A
   Component: BF-Gewichtsens. H02 0030
   Subsystem 2 - Serial number: 04L52
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†63328RB405728CDF/ÿ†63
   Subsystem 5 - Serial number: 28CDF/ÿ†63428RB40576C842Nÿ†63
   Subsystem 6 - Serial number: 6C842Nÿ†63747RB40582816FSÿ†63
   Subsystem 7 - Serial number: 2816FSÿ†63847RB40582817BQÿ
   Subsystem 8 - Serial number: 2817BQÿ
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Coding: 0004141
   VCID: 418929401849C33631-8014
   Component: E0221           H06 0030
01304 - Radio
01301 - Control Module for Voice Recognition (J507)
Address 17: Instruments        Labels: 420-920-xxx-17.clb
   Part No SW: 420 920 981     HW: 420 920 981
   Component: KOMBIINSTR. VDO H01 0580
   Revision: D0H01002    Serial number: 2244J002000011
   Coding: 0081288
   Shop #: WSC 25161 444 131251
   VCID: 53A51308F23541A693-8006
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4540K104238466
   Coding: AFA81F07504712004100
   VCID: 69D9D1E040B9EB76C9-803C
   Revision: D0H01002    Serial number: AUX7Z0J4FNB0DT
Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
   Part No SW: 420 035 785     HW: 420 035 785
   Component: SG ext.Player H08 0100
   Revision: 00000000
   Coding: 020302
   VCID: 52AB160C0D2F48AE98-8006
Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
   Part No SW: 423 035 192 H    HW: 423 035 192 H
   Component: RNS-E PU US     H04 0150
   Revision: 0000006S    Serial number: AUZBZ7K7200211
   Coding: 0730645
   VCID: 1521AD103C419F96BD-8040
                    Reset counter: 76
                    Mileage: 23468 km
                    Date: 2016.02.27
                    Time: 23:55:59
                    Voltage: 12.50 V
                    Mileage: 23630 km
                    Count: 203
                    Clock: 00:28
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 420 959 801 D    HW: 420 959 801 D
   Component: Tuer-SG         004 0100
   Coding: 0005245
   VCID: 1A3BBE2CD55FB0EE90-804E
Address 47: Sound System        Labels: 420-035-223.lbl
   Part No SW: 420 035 223 D    HW: 420 035 223 A
   Component: J525 Amp High   H14 0230
   Revision: 00H14001    Serial number: 34844000697803
   Coding: 0246111
   VCID: 0919F16060F94B7629-805C
   Part No SW: 420 959 802 D    HW: 420 959 802 D
   Coding: 0005245
   VCID: 1B35BB28DA65C9E68B-804E
Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
   Coding: 0730645
                    Reset counter: 76
                    Mileage: 23468 km
                    Date: 2016.02.27
                    Time: 23:55:59
                    Voltage: 12.50 V
                    Mileage: 23630 km
                    Count: 203
                    Clock: 00:28
Address 65: Tire Pressure        Labels: None
   Part No SW: 420 910 273     HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0030
   Revision: 00050030    Serial number: 00000700005985
   Coding: 0462426
   VCID: 4C9708742F0B1E5ED2-8018
                    Fault Status: 11100100
                    Reset counter: 204
                    Mileage: 21131 km
                    Date: 2015.05.19
                    Time: 17:53:16
                    (no units): 71.0
                    Voltage: 13.80 V
                    (no units): 61.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
02214 - Tire Pressure Warning
                    Fault Frequency: 206
                    Mileage: 16515 km
                    Date: 2014.10.02
                    Time: 23:22:10
                    (no units): 45.0
                    Temperature: 20.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 6C: Back-up Cam.        Labels: 420-910-441.clb
   Part No SW: 420 910 441 A    HW: 7L6 907 441 C
   Component: J772__Rearview      0010
   Revision: --H13---    Serial number: 525PA8-J04607J
   Coding: 1020412
02203 - Audio / Video Input 1
                    Reset counter: 69
                    Mileage: 22680 km
                    Date: 2015.10.28
                    Time: 14:41:29
                        Reverse OFF
                    Count: 3
                    Reset counter: 69
                        Term 15 Off
                        Reverse OFF
                    Count: 3
00457 - Control Module for Network (J519)
                    Reset counter: 69
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Reset counter: 69
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Reset counter: 69
                    Mileage: 23468 km
                    Date: 2016.02.27
                    Time: 23:59:55
                        Reverse OFF
                    Count: 3
   Part No SW: 8P0 862 335 AB    HW: 8P0 862 335 T
   Component: FSE_256x BT     H38 0600
   Revision: 00000000    Serial number: 00000005033564
   Coding: 0011477
   Shop #: WSC 02556 785 00200
   VCID: 76E38A9C0107348E54-8022
End-------------------------(Elapsed Time: 02:27)--------------------------
This bothers me:
Address 01: Engine
What's up with the ECMs in this car? Given that it's a V10 that's got aftermarket turbos, I wouldn't expect them to have stock software, but I also wouldn't expect them not to communicate at all.
Let's get some basics out of the way. Go to each module that has faults and Clear Fault Codes. Once you've cleared all the fault codes, please post up a fresh scan.
As for one of your issues: You may find a coding bit of interest at address 09, Byte 8; in the first four digits of the (short/conventional) coding in address 17 (a balloon help "chart" should show up if you go there), and of course at address 19 in the Installation List function.
Xpower
C?ID=163029
My only suggestion is that you lend me your R8 V10 for a few weeks and I will look at it for you.
I will be able to lend you my vRS as a courtesy car :-)
