Skoda Fabia - Turn off Lane Assistance
StuBee74
Isle Of Wight, UK
C?ID=578097
Hi All,
Son's girlfriend has just got a new (to her) 24 plate Skoda Fabia which has some annoying features switched on by default. Full scan is attached below which I took upon delivery. I'm aware that SFD (2) protection is on some modules but wanting to know before I buy if the below is possible:
1) Switch OFF by default the lane assist feature
2) Switch OFF by default the speed warnings
3) Remember the last driver setting (ECO mode)
I've had a search around but not found anything conclusive.
Thanks in advance,
Stu
Sunday,20,September,2026,18:33:26:30678
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.4
VIN: TMBFR6PJ8R4076816   License Plate:
Chassis Type: PJ-SK27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 44 5F 75 A5
VIN: TMBFR6PJ8R4076816   Mileage: 36569km-22722miles
Address 01: Engine (J623-DUSA)       Labels: Redir Fail!
   Part No SW: 05C 906 012 H    HW: 05C 907 309 F
   Component: R3 1.0l TFS   H80 3593
   Revision: KKH80000    Dataset Number: V03935399CB 0001 CVN: 18A9F5EB
   Coding: 0125003623240D0810000000000000000000000000000000
   Shop #: WSC 31000 074 00130
   ASAM Dataset: EV_ECM10TFS01105C906012H 001003
   ROD: EV_ECM10TFS011_VW27.rod
   VCID: 221D1705B4488C7AD14-8076 SFD+SFD2 [x]
   VINID: 91D49688681A2221001C620118915F2521
   Part No SW: 0CW 906 556 CQ    HW: 0CW 300 028 P
   Component: DQ200G3 CHI   H07 0365
   Serial number: 5ZV02408131293  CVN: 03B5DDE9
   ASAM Dataset: EV_TCMDQ200025 001007
   ROD: EV_TCMDQ200025.rod
   VCID: 1D6724F98D36B382EC6-8048 SFD [x]
10764 - Dual Clutch
          P177D 00 [00101000] - Torque too High
                    Reset counter: 8
                    Mileage: 36083 km
                    Date: 2026.07.16
                    Time: 19:04:11
                    Engine speed: 1435.00 /min
                    Engine torque: 12 Nm
                    Control Module temperature: 20 °C
                    CURRENT pressure: 41.5 bar
                    Clutch: primary stat: Kriechen
                    selected gear: GANG_1
                    Position: d
                    Accelerator pedal position: 14.1 %
                    DTC memory status: 133
                    SCB at a phase W: not active
                    SCG at a phase W: not active
                    OG at a phase W: not active
                    OL at a phase W: not active
                    SCB at a phase U: not active
                    SCG at a phase U: not active
                    OG at a phase U: not active
                    OL at a phase U: not active
                    SCB at a phase V: not active
                    SCG at a phase V: not active
                    OG at a phase V: not active
                    OL at a phase V: not active
                    Error during active shut off: not active
                    BIOS_MASK_EMOT_HW_DRIVER_ERROR: not active
                    BIOS_MASK_EMOT_HW_MANAGER_STUCK: not active
                    BIOS_MASK_EMOT_HW_MOTOR_BLOCKED: not active
                    Overtemperature from Bldc1 driver: not active
                    Overcurrent at the shunts: not active
                    Overvoltage at supply: not active
                    Undervoltage at supply: not active
                    Overvoltage at sensor supply: not active
                    Undervoltage at sensor supply: not active
                    OV or UV at charge pump: not active
                    Communication error SPI: not active
                    Sensor Kurzschluss nach Masse: not active
                    Sensor Kurzschluss nach Plus: not active
                    Sensor offen: not active
                    Sensorversorgung_elektrischer Fehler: not active
                    Sensor untere Toleranz unterschritten: not active
                    Sensor obere Toleranz überschritten: not active
                    Gradientenfehler: not active
                    Kalibrationsfehler: not active
                    Sensor interner Fehler: not active
Address 03: ABS Brakes (J104)       Labels:. 2Q0-614-517.clb
   Part No SW: 2Q0 614 517 CS    HW: 2Q0 614 517 CB
   Component: ESC_Base_vFGS H20 0130
   Serial number: BPA085080824015 Dataset Number: V03935428MT 0001
   Coding: 0A1A0152B9FE9B
   ASAM Dataset: EV_BrakeBoschMQBA0UNECE 012016
   ROD: EV_BrakeBoschMQBA0UNECE_012_SK27.rod
   VCID: 015F7889118E7762E8E-8054 SFD+SFD2 [x]
0093 - ESC Temporarily Not Available
          C1319 00 [00100000] - -
          [Too long initalization of reference speed calculation in VDC]
0609 - Databus
          U1121 00 [00100000] - Missing Message
          [Frame ACC_10 - Timeout error: the frame has not been received during 500ms]
   Part No SW: 3Q1 959 435 C    HW: 3Q1 959 435 C
   Component: VWKESSYMQB    037 1501
   Revision: 00037000    Serial number: 0649529538 Dataset Number: V03935344BF 0001
   Coding: 032C0C0723
   Shop #: WSC 31000 074 00083
   ASAM Dataset: EV_KessyHellaMQBAB 004056
   ROD: EV_KessyHellaMQBAB_VW27.rod
   VCID: 3B23CA6133E2DDB2F22-806E
   Part No SW: 6VA 820 045 C    HW: 6VA 820 045 C
   Component: SG_AC_Manuell H32 0701
   Serial number: 00000000000000 Dataset Number: V03935400TF 0001
   Coding: 011100000800010001000800020100000010000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001013
   ROD: EV_ACManuePrehMQBA0.rod
   VCID: 43D3B2814B12A572BA2-8016
Address 09: Cent. Elect. (J519)       Labels: 2QX-937-BCM-V2.clb
   Part No SW: 2Q0 937 090 F    HW: 2Q0 937 090 F
   Component: BCM A0 Std+   H15 0983
   Serial number: 02102417800617 Dataset Number: V03935432GC 0001
   ASAM Dataset: EV_BCMA0 209001
   ROD: EV_BCMA0_209_VW27.rod
   VCID: 3537DC5915C60BC2046-8060 SFD+SFD2 [x]
   Driver door control module:
   Front passenger door control module:
204290 - Remote key 1
          B1479 18 [00001000] - Current Too Low
                    Fault Frequency: 35
                    Reset counter: 58
                    Mileage: 35268 km
                    Date: 2026.06.07
                    Time: 14:43:38
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beams: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.5 V
204546 - Remote key 2
          B147A 18 [00001000] - Current Too Low
                    Reset counter: 27
                    Mileage: 36088 km
                    Date: 2026.09.11
                    Time: 08:15:31
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.1 V
   Part No SW: 5QA 919 294 L    HW: 5QA 919 294
   Component: PDC 8 Kanal   H12 0083
   Serial number: 000150058324208 Dataset Number: V03935409BB 0001
   Coding: 8471151051
   ASAM Dataset: EV_EPHVA18AU3700000 010058
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 55F77CD9B5862BC2E46-8000
   Part No SW: 2Q0 907 567 B    HW: 2Q0 907 819
   Component: ACCCONTIMQB   H04 0534
   Dataset Number: V03935428GD 0001
   Coding: 3205608248FF8748949C810D00508700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIUNECEMQB 004021
   ROD: EV_ACCMRRCONTIUNECEMQB_VW27.rod
   VCID: 372BD6510FCAF9D216A-8062 SFD+SFD2 [x]
   Part No SW: 5QF 959 655 BN    HW: 5QF 959 655 BN
   Component: Airbag VW23   003 0117
   Revision: --------    Serial number: 003C0T0PM028FU Dataset Number: V03935432VL 0001
   Coding: 88CCC8C0000000005C5400CF008C40540065
   ASAM Dataset: EV_AirbaVW23TS6VW48X 001010
   ROD: EV_AirbaVW23TS6VW48X_VW27.rod
   VCID: 23131201AB528572DA2-8076 SFD+SFD2 [x]
   Subsystem 1 - Part No SW: -----------    HW: 654 002 507 24
   Component: SideSensor_Df  010 0887
   Serial number: 35700007558D19EF764N
   Subsystem 2 - Part No SW: -----------    HW: 654 002 607 24
   Component: SideSensor_Pf  010 0887
   Serial number: 35800008558D36438A25
   Subsystem 3 - Part No SW: -----------    HW: 654 000 205 24
   Component: SideSensor_Dr  040 0148
   Serial number: 3510050C2C873554C8FL
   Subsystem 4 - Part No SW: -----------    HW: 654 000 205 24
   Component: SideSensor_Pr  040 0148
   Serial number: 3520050C6C74BF954A9X
   Subsystem 5 - Part No SW: -----------    HW: 654 002 306 24
   Component: FrontSensor_D  0A0 0189
   Serial number: 3550050C4C7C94C6A3BY
   Part No SW: 654 920 790 G    HW: 654 920 790 G
   Component: KOMBI         612 7850
   Dataset Number: V03935432LW 0001
   Coding: 2524191861840600018C62431001000800000020
   ASAM Dataset: EV_DashBoardVDDMQBA0 003060
   ROD: EV_DashBoardVDDMQBA0_003_VW27.rod
   VCID: 211F1809B14E9762C8E-8074 SFD+SFD2 [x]
8667137 - Mileage
          U1679 00 [00001000] - Calculation Faulty
          [Berechnungsgrundlage Wegstrecke fehlerhaft]
                    Mileage: 31827 km
                    Date: 2026.04.29
                    Time: 11:09:10
   Part No SW: 3Q0 907 530 BB    HW: 3Q0 907 530 BA
   Component: GW 2023 CLA   542 5555
   Revision: --------    Serial number: CU5SIB210824109 Dataset Number: V03935418ND 0001
   Coding: 0000808D0F00000000000000000000000000000000000300030000000001000000000000000000000000000000000000
   GVL: 3D0000000600408080000000C800000000000000000000000000000000000044
   ASAM Dataset: EV_GatewMQB2020Class 001001
   ROD: EV_GatewMQB2020Class_VW27.rod
   VCID: 70B92D4D2A246EEA170-8024 SFD+SFD2 [x]
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H03 2012
   Serial number: 1050C45D
   Subsystem 3 - Part No SW: 5E3 919 719 R    HW: 5E3 919 719 R
   Component: E221__MFL-PR6  H02 0110
   Serial number: PR6-0440062180240113
2166903 - No Communication with Transmission Control Module
          U0101 00 [00101000] - -
          [TCM_no_communication]
                    Fault Frequency: 52
                    Reset counter: 30
                    Mileage: 31319 km
                    Date: 2026.04.16
                    Time: 11:49:06
8397571 - LV Energy Management
          B1802 F1 [00100000] - Warning Triggered
                    Fault Frequency: 0
                    Reset counter: 0
1376285 - Generator
          U1053 00 [00100000] - Implausible signal
          [Generator_implausible_frame]
                    Fault Frequency: 0
                    Reset counter: 0
          B184C 00 [00100000] - -
          [Unlock_protection_of_vehicle_diagnosis_active]
                    Fault Frequency: 0
                    Reset counter: 0
8712962 - Attention and Drowsiness Assist
          U1832 00 [00101100] - Function Restriction
          [FAULT_ADA_FUNCTION_ERROR]
                    Mileage: 31319 km
                    Date: 2026.04.16
                    Time: 11:50:35
8417280 - Diagnostic Filter
          U17A0 00 [00101000] - Not Activated
          [Filter_is_not_active]
                    Reset counter: 7
                    Mileage: 36081 km
                    Date: 2026.07.14
                    Time: 09:03:49
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000196071008 Dataset Number: V03935361XC 0001
   Coding: 0808000000000000
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
   VCID: 084965AD32B4462AAF0-805C SFD+SFD2 [x]
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q2 909 144 AM    HW: 2Q2 909 144 AD
   Component: TRW_G4L_MQBA0 623 6064
   Serial number: 04554352CB4R229 Dataset Number: V03935424MV 0001
   Coding: 010000000100000101010201010001000000010101
   ASAM Dataset: EV_SteerAssisTRWG4LClass 016018
   ROD: EV_SteerAssisTRWG4LClass.rod
   VCID: 7EA503756070089A95C-802A SFD+SFD2 [x]
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 657 035 869     HW: 657 035 869
   Component: MU-E-D-EU     061 0480
   Serial number: SKZAZ2C0699781  Dataset Number: V03935428AV 0001
   Coding: 32700008000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUEIGPMQB 001001
   ROD: EV_MUEIGPMQB_VW27.rod
   VCID: 619F5809F1CED76288E-8034 SFD+SFD2 [x]
   Part No SW: 2GA 035 284 B    HW: 2GA 035 284
   Component: OCUClas2023_H H07 0523
   Serial number: 0000000407VIFWC Dataset Number: V03935435AB 0001
   Coding: 03010500000100210000000012000607111112111012100000
   ASAM Dataset: EV_OCUClass2023 001059
   ROD: EV_OCUClass2023.rod
   VCID: 323DE745E4A81CFA214-8066 SFD+SFD2 [x]
1644017 - Online Services
          B1915 F1 [00101000] - Temporary Function Restriction due to Battery Budget
          [Functional restriction due to insufficient power budget]
                    Reset counter: 2
                    Mileage: 36077 km
                    Date: 2026.07.01
                    Time: 06:33:55
                    Voltage terminal 30: 11.5 V
                    Remaining long term energy budget: 622 mAh
                    Remaining short term energy budget: 4 mAh
                    Wake up cycles counter: 3533
   Part No SW: 2Q0 980 653 G    HW: 2Q0 980 653 A
   Component: MQB MFK 3.0   H19 1505
   Serial number: ED3659911242280 Dataset Number: V03935426ZK 0001
   Coding: 0002090801404020409E08001020000001018088600000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007057
   VCID: 392FD06939DEEFA2E0E-806C
0645 - Windscreen Heater for Front Sensors
          B11CE 15 [00001000] - Open or Short to Plus
                    Reset counter: 11
                    Operational_mode: passive
                    Windscreen_heater_state_of_function: ERROR
                    Actuator_Test_Running: OFF
                    heater_request_by_blindness_detection: No
                    heater_request_by_condensation_danger: No
                    Camera_temperature_too_high: No
                    engine_running: Yes
                    Crash_signal_active: No
                    System_or_voltage_error: system_error_active
                    Windscreen_heater_error: Yes
                    idle_time_interval: No
                    Ambient_temperature_too_low: No
                    windscreen_heater_current: 0.00 A
                    windscreen_heater_voltage: 0.00 V
                    windscreen_heater_resistance: 65.25 Ohm
                    windscreen_heater_power: 0.00 W
                    Voltage Terminal: 8.3 V
End----------(Elapsed Time: 01:00, VBatt start/end: 12.0V/12.0V)-----------
------------------------------14 Faults Found------------------------------
Worse, the modules in this car are heavily locked down with SFD2, which is going to preclude many (most?) tweaks.
StuBee74
Isle Of Wight, UK
C?ID=578097
Thanks Uwe, so not going to be possible just yet?
abraco
Croatia
C?ID=505552
hi, A5 module is not SFD locked. Go to coding in A5 and there you have Configuration_for_lane_departure_warning_Kl15 and put it to Last setting. It will store last memory of lane assist.
Speed warnings I succesfully deactivated with OBD11 through APPs. I'm not sure how its done with VCDS through coding.
I did that on Fabia MY2025
Regards.
Nice! It looks to be in Byte 9 in this particular module.
abraco
Croatia
C?ID=505552
UPDATE:
to manually disable speed warning go to A5 coding, byte 19 and in bit 3-5 check for Regulation,No_Regulation
Regards
Remember, technically this invalidates your insurance.
