- Feb 13, 2026
- 64
- 11
- Michigan, USA
- C?ID=641151
Can not get Module 13 to clear. I can get 8e to clear, but when I try to clear 13 I think it tries to initialize the system and 8e says "nope, 13 is broken.
I had to recode both 13 and 8e from address 19 earlier. it was worse. they had lost their coding.
I will post the current scan first then a scan from earlier showing the need for coding.
Friday,25,September,2026,21:57:12:60745
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.5
VIN: WAUW2AFCXGN074788 License Plate:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 22 28 34 36 3B 3C 42 44
46 47 52 53 55 5F 62 6C 6D 72 84 85 8B 8E 8F 90 A9 BA
VIN: WAUW2AFCXGN074788 Mileage: 197740km-122869miles
17-Instruments -- Status: Cannot be reached 0100
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CTGE) Labels:. 079-907-560-V2.clb
Part No SW: 4G0 906 014 D HW: 4H0 906 014
Component: 4.0l V8TFSI / X63 0002
Revision: NCX63--- CVN: 67F06E17
Coding: 1A2500326546010E3000
ASAM Dataset: EV_ECM40TFS0114G0906014D 001002
ROD: EV_ECM40TFS0114G0906014D.rod
VCID: 23140CEC8B5B2C82DA2-8076
VINID: 9D1967091593A177801C41C820F598DD6B
18740 - Control Module for Exhaust Flap 2
P14AC 00 [01100100] - Mechanical Malfunction
Mileage: 197720 km
Date: 2026.09.25
Time: 20:39:36
Engine speed: 841.50 /min
Normed load value: 10.2 %
Coolant temperature: 96 �C
Intake air temperature: 31 �C
Voltage terminal 30: 13.876 V
Engine status: COENG_RUNNING
Readiness: 0010 0001
Part No SW: 4G0 927 166 F HW: 0B5 927 156 K
Component: 0B5 40TFSINAR H03 0007
Revision: --H03--- CVN: 00006C26
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL501021 001022
ROD: EV_TCMDL501021.rod
VCID: 303EF3A0CAAD871A570-8064
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 65B6D74BA66DEBD21B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41D8A66471071E92A8E-8014
Part No SW: 4H0 907 064 GR HW: 4H0 907 064 GR
Component: BCM2 2.0 H37 0572
Coding: 0DAA6F4E000000000000
VCID: 7F5CE09C47F3A8629EA-802A
Serial number: 3215000117647013
Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
Serial number: 02091500040768
Coding: 680330B84D0000
Shop #: WSC 09281 003 1048576
VCID: 6A8A21C82CF13DCA594-803E
Part No SW: 4H0 907 063 DM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0311
Revision: 21020001 Serial number: 00001148867702
Coding: 01050016043C9FE2E90048C7A0007800CF9CC308AE0802218000089C710017020060002D0B0000
Shop #: WSC 06241 006 1048576
VCID: 76B205B868C9E92ACDC-8022
Component: WWS57X 150629 H38 0080
Serial number: 150805231156
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 20586214
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 AM HW: 4G0 941 531 AM
Component: E1 - LDS H07 0044
Serial number: 15 06 2015 00000795
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA121418000015036359
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 9DC843C7000000000001
Component: ACC3 H21 0053
Serial number: 00000000000000 Dataset Number: 4G8909863D 0036
Coding: 7E01010101
ASAM Dataset: EV_AdaptCruisContrAU57X 002014
VCID: 29081EC4E977F6D290E-807C
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [00001001] - -
[FAULT_CIS_VIDEO_FAIL]
Reset counter: 132
Mileage: 197740 km
Date: 2026.09.25
Time: 21:52:52
Control Module temperature: 31 �C
Voltage terminal 15: 12.002 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s�
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H62 0086
Revision: -------- Serial number: 003G0002FBDH Dataset Number: 4G8909602K 0002
Coding: 303331333131303134334A55304C34473853
VCID: 3436FFB03EB5BB3A338-8060
Seat occupant detection:
Component: BF-Gewichtss. H15 0046
Serial number: 6940000Y150001DW0W08
Serial number: 3575HRB404R3K8CI68BO
Serial number: 3585HRB404R3KGI2E1AN
Serial number: 3515JRB404R3I87IBP0O
Serial number: 3525JRB405R3IB887HGO
Serial number: 3554VRB4004534EG7PTP
Serial number: 3564VRB400I534EG8940
Revision: -------- Serial number: 90372OI3000E3
Coding: 0000FC
VCID: 372CC8BC2F43502216A-8062
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Serial number: 03 08 2015 D0005079
Part No SW: 4G8 920 934 L HW: 4G8 920 934 L
Component: TBenRdwAccNv H11 0104
Revision: 07001088 Serial number: 658250815596034
Coding: 0B8F01079F530008020300
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K_AU57.rod
VCID: 3A2AD1881CD14D4AE94-806E
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000001968105 Dataset Number: 4G8909515H 0017
Coding: C0ED074814
GVL: FD8FE9CCDCA3640D51040000
ASAM Dataset: EV_GatewPkoUDS 001028
VCID: 3B24D48C13EB7442F22-806E
Control module for battery monitoring:
Serial number: 5606707503
Voltage stabilizer:
Serial number: 15060800000000000006
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
Coding: 04018E64747464545425363E00
VCID: 678C58FC3F6300A246A-8032
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H17 0200
Serial number: 003008150001003 Dataset Number: 4G8909104B 0020
VCID: 280E1BC0F27DCFDA8F0-807C
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0112
Serial number: 01091500040382
Coding: 20
VCID: 3E22DD9800F9616AD5C-806A
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Dataset Number: 4G8909553G 0030
Coding: 008002
ROD: EV_AirSuspe_003_AU64.rod
VCID: 2F3CF0DCD79398E24EA-807A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000164760730
VCID: 77AC08BC6FC39022D6A-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E01PG3H Dataset Number: 4G8909573A 0001
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372CC8BC2FC3502216A-8062
Component: SWA Master H06 0060
Serial number: 0378174943 Dataset Number: 4G8909535C 0013
Coding: 040211
VCID: 3928CE8419D74652E0E-806C
Component: SWA Slave H06 0060
Serial number: 0378280574
Coding: 040211
Component: TSG FA H04 0511
Coding: 011F57035E00628002000413
VCID: 45D0B27465AF32B2946-8010
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H56 0202
Revision: 00000001 Serial number: 0000404238 Dataset Number: 4G8909852M 0038
Coding: 101001010001
Shop #: WSC 35379 006 1048576
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
Revision: 00002001 Serial number: 0377332762
Coding: 0126063A20BAF08580B00A8402030D470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000306640
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST000HV95Q00000
Coding: 101F02
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00014849853
Subsystem 5 - Part No SW: 4G8 959 252 A HW: 4G8 959 252
Component: HSP-SG H11 0031
Serial number: WA121581000015179824
Subsystem 6 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93608685
Part No SW: 4G2 035 466 B HW: 4M1 035 466
Component: 8RF H10 0270
Serial number: 2530147581 Dataset Number: 4G9909510E 0007
Coding: 0175530A00A2AAAAAA0000010F00
ASAM Dataset: EV_AMPMst24C1Gen2BAO 001002
ROD: EV_AMPMst24C1Gen2BAO_AU57.rod
VCID: 270C18FCFF63C0A286A-8072
Component: TSG BF H03 0511
Coding: 011F57035E00628002000402
VCID: 46D2B57858A939AA9DC-8012
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001586136 Dataset Number: 4G8909522D 0007
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D00EAD4DD9FEAF27C6-8078
Component: MxB-ECU 001 0100
Revision: -------- Serial number: -------------- Dataset Number: 4G8909865D 0019
Coding: 05FA021122680400
Coding: E02000
Coding: E02000
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 4G1 035 047 HW: 4G1 035 047
Component: MU-H-NS-US 042 0143
Serial number: A280H0F7500381 Dataset Number: 4G9909545C 0022
Coding: 017553020000000013220002041A00002F000DE4F1700104FE
VCID: 5F9C401CE7B34862BEA-800A
Subsystem 1 - Part No SW: V03 959 801 GC HW: -----------
Component: NAR 2015 --- 0035
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0006
Serial number: AUZ8Z9FY802TK7
Serial number: 90349OI2000SU
Compact disc data bank:
Component: Gracenote2 --- 3006
Reset counter: 130
Mileage: 197699 km
Date: 2026.09.25
Time: 18:18:00
Voltage terminal 30: 13.0 V
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Component: TSG HL H03 0511
Coding: 010F17024000628002000002
VCID: 49C8BE4449B7D6D270E-801C
Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
Component: TopView H08 0361
Revision: 11001001 Serial number: 82330JG0110001
Coding: 0217000001010100000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 4G8 959 107 T HW: 4G8 959 107 J
Component: HDSG-Modul H14 0049
Revision: 12014001 Serial number: 218500127 Dataset Number: 4G8909541G 0001
Coding: 0A3305C122
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571_AU57.rod
VCID: 46D2B578582939AA9DC-8012
Component: TSG HR H03 0511
Address 84: Night Vision (J853) Labels:| 4G0-907-547.clb
Part No SW: 4G0 907 547 A HW: 4G0 907 547
Component: NV-ECU-Gen3 H08 0107
Serial number: 622352400201522
Coding: 410100
ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
ROD: EV_NightVisioGen3AE4AU64X.rod
VCID: 2C06E7D0E685E3FA6B8-8078
Night vision system camera:
Subsystem 1 - Part No SW: 4G0 980 552 HW: 4G0 980 552
Component: NV-CAM-Gen3 H03 0006
Serial number: 623466500F1523100155
Component: DPC-SG H27 0081
Revision: -------- Serial number: 262130025421000 Dataset Number: 4G8909547E 0006
Coding: EA060000
ROD: EV_OnBoardCamerDPC.rod
Coding: 7E01010101
ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
Component: BV-SG H33 0090
Serial number: 005000620309157 Dataset Number: 4G8909548H 0008
Coding: 03C1BA1A0111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0161 - Video Cable for Image Processing
C1107 02 [00001001] - Signal Failure
[No_camera_found_on_startup]
Reset counter: 132
Mileage: 197740 km
Date: 2026.09.25
Time: 21:53:14
Outside temperature: 23.5 �C
Voltage terminal 15: 12.0 V
Control Module temperature: 29.0 �C
Component: RGS-VL H14 0080
Dataset Number: 4G0909614C 0001
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3138F6A4C1A78E1258E-8064
Component: RGS-VR H14 0080
Dataset Number: 4G0909615C 0001
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323AF9A8C4A1B50A214-8066
Address A9: Struct. Borne Sound Labels: None
Part No: 4G0 907 159 B
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number: 97813005617801 Dataset Number: 4G8909578B 0013
ROD: EV_AEMLearAU64X_AU57.rod
0289 - Signal Line for Sensor 2 for Drivetrain Mounts
C1130 12 [00001001] - Short to Plus
Reset counter: 129
Mileage: 197690 km
Date: 2026.09.25
Time: 13:38:38
0291 - Signal Line for Sensor 1 for Drivetrain Mounts
C112F 11 [00001001] - Short to Ground
Reset counter: 129
Mileage: 197690 km
Date: 2026.09.25
Time: 13:38:38
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [00001001] - Mechanical Failure
Reset counter: 129
Mileage: 197690 km
Date: 2026.09.25
Time: 13:38:40
End----------(Elapsed Time: 03:53, VBatt start/end: 12.1V/12.1V)-----------
------------------------------7 Faults Found-------------------------------
