Hi everyone,
I’m having trouble coding a set of refurbished injectors on my VW T5 2.0 BiTDI CFCA
The injectors are refurbished and came with coding/IMA codes from the refurbishment shop. I entered the codes exactly as provided in their PDF, so I don’t believe there are any typing errors.
The problem is that VCDS gives me an “out of range” error when I try to enter the injector codes.
I have already tried:
“WSC was rejected by the control module” picture bellow
Has anyone experienced this with injector coding?
Could this be related to the injectors not having the correct type of calibration/IMA code for this ECU, or is there a specific login/security access procedure or coding method required?
If anyone knows the correct procedure or has dealt with this exact issue, I’d really appreciate some help.
Thanks!
injector codes:
ID27UWE
HL186WE
BB8RV5E
FU3NISE
- Updating VCDS to the latest software
- Different variants of the injector codes
- Clearing all fault codes before attempting the coding
- Security code 27971
Thanks!
injector codes:
ID27UWE
HL186WE
BB8RV5E
FU3NISE
Sunday,20,September,2026,16:00:50:50938
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.5
Workshop Code: 999 12345 012345
VIN: WV1ZZZ7HZEH License Plate:
Mileage: 206560km-128350mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 18 19 22 25 55 56 61 69 6E 77 0B
VIN: WV1ZZZ7HZEH133646 Mileage: 206560km-128350miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 019 HM HW: 03L 907 309 L
Component: R4 2,0L EDC X38 6333
Revision: 22X38--- Serial number: 00000000000000 CVN: DB9C3677
Coding: 0125401A233601080000
Shop #: WSC 26214 051 00000
ASAM Dataset: EV_ECM20BTD01103L906019HM 003004
ROD: EV_ECM20BTD01103L906019HL_003.rod
VCID: 7DA01BBF2D7D01428C6-8028
VINID: 9E606AAAA1D8A956010C318418098AC715
5046 - Fuel Injector #1 (N30)
P0263 00 [10100111] - Contribution/Balance Fault
Mileage: 206557 km
Date: 2026.09.20.
Time: 02:48:21
Engine speed: 0.00 /min
Coolant temperature: 30 C
Intake air temperature: 20 C
Voltage terminal 30: 12.220 V
Allowed number of injections-Bits 0-7: 3
Injection release status-Bits 0-7: 0
Desired injection characteristic-Bits 0-7: 56
Mean injection quantity: 0.00 mg/stroke
Rail pressure regulation: status-Bits 0-7: 0
Fuel high-pressure: actual value: 3000 hPa
Control Module temperature: 38.7 C
5044 - Fuel Injector #3 (N32)
P0269 00 [10100111] - Contribution/Balance Fault
Mileage: 206557 km
Date: 2026.09.20.
Time: 02:48:21
5047 - Fuel Injector #4 (N33)
P0272 00 [10100111] - Contribution/Balance Fault
Mileage: 206557 km
Date: 2026.09.20.
Time: 02:48:21
5043 - Fuel Injector #2 (N31)
P0266 00 [10100111] - Contribution/Balance Fault
Mileage: 206557 km
Date: 2026.09.20.
Time: 02:48:21
Readiness: 0 0 0 0 X
Part No SW: 0BT 300 011 Q HW: 0BH 927 711 C
Component: DSG DQ500-7A H08 2236
Revision: 00H08V01 CVN: C5623FA3
ROD: EV_TCMDQ500021.rod
VCID: 3C26D6BB76E7C84AFB8-8068
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 708724AD91A70E9824A88975696490
Shop #: WSC 02737 790 49152
VCID: 3A2AD0A37C53F67AE94-806E
Fault Status: 01101100
Reset counter: 0
Count: 32896
Count: 257
Count: 64
Count: 760
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 25041404651167
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA21CB3207B1A5A95C-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BJ HW: 7E5 907 047 BJ
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000003
Shop #: WSC 02737 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 78AE0AAB025F246ADF0-802C
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 0571 115141296
Coding: 62A0393A0A21201201280F716CEB8FD40290662F7E857841320000020000
Shop #: WSC 02739 790 00000
VCID: 2D00EBFFBD1D51C27C6-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 300414 05 54 0403
Coding: 02302E
Subsystem 2 - Part No SW: 7E0 959 801 H HW: 7E0 959 801 H Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8653
Serial number: KU0KU008051441281539
Coding: 0400A0
Subsystem 3 - Part No SW: 7E0 959 802 H HW: 7E0 959 802 H Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8653
Serial number: KU0KU008051441280547
Coding: 1400A0
Subsystem 4 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H07 0022
Serial number: 70000000000000742402
Coding: E20000
03431 - Activation of Left Parking Light
006 - Short to Plus - Intermittent
Fault Status: 00100110
Reset counter: 116
Mileage: 206557 km
Date: 2021.02.10.
Time: 01:22:12
Fault Status: 00101011
Reset counter: 116
Mileage: 206557 km
Date: 2021.02.10.
Time: 18:44:14
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 32901409304115
Coding: 118101
Shop #: WSC 42500 205 101064
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 3A2AD0A37CD3F67AE94-806E
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag003 H07 0013
Revision: -------- Serial number: 003HL00PERV9 Dataset Number: 7E0003v____ 0465
Coding: 000000000000000000000000000000003033
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3530C39F55CD1902046-8060
Part No SW: 7E0 920 870 J HW: 7E0 920 870 J
Component: KOMBI H04 0710
Coding: 160E01
ROD: EV_Kombi_UDS_VDD_RM09_004_VN75.rod
VCID: 303EF28BAAAF3C2A570-8064
Address 18: Aux. Heat Labels: 7E0-819-008.clb
Part No: 7E0 819 008 F
Component: J737__Standheizung 0605
Revision: 00086000 Serial number: 09024901A00000
Coding: 0020322
Shop #: WSC 48753 002 1048576
VCID: 2C06E6FB8A0758CA6B8-8078
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
Coding: 042200
VCID: 70BE328B6AAF7C2A170-8024
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 09N 907 554 C HW: 09N 907 554 C
Component: Haldex 4Motion 6010
Coding: 0000009
Shop #: WSC 02737 790 00000
VCID: 382ECAAB4E5FE46A1F0-806C
00625 - Vehicle Speed Signal
Fault Status: 01110001
Fault Priority: 14
Fault Frequency: 57
Reset counter: 48
Mileage: 3618101 km
Time Indication: 4
(no units): 765.0
Raw, Form. N/A: 000 000 000
Component: IMMO H04 0710
VCID: 6A8A20E34CF386FA594-803E
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: -------------- Dataset Number: V03600047E0 0001
Coding: 028A000001000000
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
ROD: EV_HeadlRegulVWLWRPt_VW25.rod
VCID: 77AC09970F412B12D6A-8022
5256213 - Front Vehicle Height/Level Sensor
C114D 15 [10001001] - Open or Short to Plus
Fault Frequency: 12
Reset counter: 76
Mileage: 206557 km
Date: 2026.09.20.
Time: 00:57:55
13705985 - Databus
[Fehlerwert im Signal BR3_Rad_kmh_HL]
Reset counter: 116
Mileage: 206557 km
Date: 2026.09.20.
Time: 01:11:53
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 044 0082
Revision: 01000001 Serial number: VWZ1Z2P0171623
Coding: 05000200020014
Shop #: WSC 02734 790 00000
VCID: 3334FD875B3907322A2-8066
Part No SW: 7H0 907 534 HW: 7H0 937 090
Component: Batt.regelung H74 0712
Coding: 330B1A73
Shop #: WSC 23798 002 1048576
VCID: 6B8425E743899FF2222-803E
Subsystem 1 - Part No SW: 7E0 915 181 D HW: 7E0 915 181 D
Component: J367-BDM H08 0182
Serial number: 51104I27151931084685
Part No SW: 1K0 907 383 G HW: 1K0 907 383 G
Component: Towbar module H10 0110
Revision: 3A001001 Serial number: 006789,..')*
Coding: 0100000100000000
VCID: 3138F78FA125352258E-8064
Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-W2.clb
Part No SW: 7E5 919 037 G HW: 7E5 919 037 G
Component: Dachdisplay H15 0185
Revision: 10100011 Serial number: 335078
Coding: 000202
VCID: 3530C39F554D1902046-8060
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H15 4217
Revision: 1B001001 Serial number: 00007666210919 Dataset Number: 7P6035730M 0001
Coding: 0A01010000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002_VW25.rod
End----------(Elapsed Time: 01:58, VBatt start/end: 12.3V/12.3V)-----------
------------------------------10 Faults Found------------------------------
