Disable Air Suspension on a Audi A6 C6
SavaBogdan
Romania
C?ID=530945
Hello, i converted a6 c6 3.0tdi quattro, combi from adaptive air suspension to steel springs , please help me to code abs module to steel springs. I did all the other codings necessary and disconnected the 2 modules like in this guide ( i disconnected the 55 module after the full scan)
"Code abs with odis s manual coding trough guided functions in order to have: no air springs.
Choose the engine, brakes and trailer option (best to check the car via vin on etka or partslink.
Code gateway to not have 34 and 55. 55 needs to be decoded because no height sensors were fitted.
Code the 34 from 07 out and enable green menu and go to cardiag and deselect air suspension.
Go to 17 and also code out the 34 from there.
Unplug 34 and 55 modules which are under the passenger glove department.
Disconnect the car battery for 15 mins. After that you will only have a esp fault (termin 30 undervoltage). Drive the car and run the test in odis. Finished."
Thank you
Friday,25,September,2026,17:19:56:54046
VCDS Version: 26.9.0.3 (x64)  HEX-NET2 CB: 0.4713.5
VIN: WAUZZZ4F97N092137   License Plate:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53
          55 56 61 62 69 6D 72 76 77
VIN: WAUZZZ4F97N092137   Mileage: 363730km-226011miles
52-Door Elect, Pass. -- Status: Malfunction 1010
55-Headlight Range -- Status: Not registered 0011
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 4F0 910 402 E    HW: 4F0 907 401 C
   Component: 3.0L V6TDI  G000AG  0030
   Revision: --H03---    Serial number:
   Coding: 0011372
   Shop #: WSC 02334 785 00200
   VCID: 1F108C813BB0ED12FEA-804A
   VINID: 9D196AAAA1162477802420431C37BFCE46
005491 - Left Engine Mount Solenoid Valve (N144)
               P1573 - 001 - Open Circuit
                    Fault Status: 01100001
                    Mileage: 363015 km
                    Date: 2006.05.30
                    Time: 05:40:36
                    RPM: 756 /min
                    Torque: 81.9 Nm
                    Voltage: 13.45 V
                    Bin. Bits:        0
                    Bin. Bits:        0
                    Bin. Bits:        0
               P1653 - 002 -  - Intermittent
                    Mileage: 363015 km
                    Date: 2006.05.30
                    Time: 05:40:37
                    RPM: 756 /min
                    Torque: 81.9 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 13.45 V
                    Bin. Bits: 00101000
                    Torque: 210.6 Nm
008598 - Oxygen (Lambda) Sensor B1 S1
               P2196 - 002 - Signal too High (Rich)
                    Fault Status: 01110010
                    Mileage: 363025 km
                    Date: 2006.05.30
                    Time: 06:34:16
                    RPM: 2016 /min
                    Torque: 0.0 Nm
                    Speed: 68.3 km/h
                    Duty Cycle: 1.0 %
                    Duty Cycle: 72.7 %
                    (no units): 0.0
                    (no units): 16.0
005662 - Glowplug for Cylinder 5 (Q15)
               P161E - 001 - Open Circuit
                    Mileage: 363039 km
                    Date: 2006.06.03
                    Time: 08:16:20
                    RPM: 819 /min
                    Torque: 163.8 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 13.53 V
                    Duty Cycle: 23.3 %
                    Temperature: 22.5°C
009236 - Oxygen (Lambda) Sensor B1 S1 Voltage too Low / Air Leakage / Sample Error
               P2414 - 001 -  - Intermittent
                    Fault Status: 00110001
                    Fault Frequency: 8
                    Mileage: 363084 km
                    Date: 2026.09.06
                    Time: 18:11:40
                    RPM: 1512 /min
                    Torque: 93.6 Nm
                    Speed: 48.2 km/h
                    Duty Cycle: 12.9 %
                    Duty Cycle: 196.2 %
                    (no units): 1.0
                    (no units): 128.0
012597 - Intake Manifold Runner Control
               P3135 - 001 - Lower Stop not Reached - Intermittent
                    Fault Status: 00100001
                    Fault Frequency: 8
                    Mileage: 363294 km
                    Date: 2026.09.12
                    Time: 18:13:01
                    RPM: 756 /min
                    Torque: 81.9 Nm
                    Voltage: 13.45 V
                    Duty Cycle: 88.8 %
                    Duty Cycle: 80.9 %
                    Duty Cycle: 80.9 %
Readiness: 0 1 0 0 0
Address 02: Auto Trans        Labels: 09L-927-760.clb
   Part No SW: 4F2 910 156 F    HW: 09L 927 156 C
   Component: AG6 09L 3,0 TDI RdW 0030
   Revision: --H01---    Serial number:        4261039
   Coding: 0000001
   Shop #: WSC 02325 785 00200
   VCID: 2802975D6EFE2AAA8F0-807C
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AD    HW: 4F0 614 517 AA
   Component: ESP8 quattro    H01 0070
   Coding: 0000392
   VCID: 669ED965A46AFCDA7DC-8032
01310 - Level Control System Control Module (J197)
                    Reset counter: 132
                    Mileage: 363733 km
                    Date: 2026.09.25
                    Time: 17:15:58
                    Hex Value: 0x0000
                    Hex Value: 0x0282
                    Hex Value: 0x0013
                    Hex Value: 0x2A88
                    Hex Value: 0x00FF
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -  - Intermittent
                    Reset counter: 172
                    Mileage: 363733 km
                    Date: 2026.09.25
                    Time: 17:15:58
                    Hex Value: 0x0000
                    Hex Value: 0x0282
                    Hex Value: 0x0014
                    Hex Value: 0x0788
                    Hex Value: 0x00FF
01517 - Control Module for Trailer/Towing Sensor (J345)
                    Reset counter: 172
                    Mileage: 363733 km
                    Date: 2026.09.25
                    Time: 17:15:58
                    Hex Value: 0x0000
                    Hex Value: 0x0282
                    Hex Value: 0x0014
                    Hex Value: 0x0888
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: None
   Part No HW: 4F0 905 852 C
   Revision: 31050601    Serial number: 10601200610184
   VCID: 55FCEEA90D0C6742E46-8000
                    Reset counter: 144
                    Mileage: 363039 km
                    Date: 2006.06.03
                    Time: 10:03:17
01176 - Key
                    Reset counter: 165
                    Mileage: 363445 km
                    Date: 2026.09.16
                    Time: 15:34:21
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 731 R    HW: 4E0 035 729
   Component: Interfacebox    H43 3450
   Revision: 00000000    Serial number: 350K 067739906
   Coding: 0011002
   VCID: 31347A395D246B6258E-8064
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000000592294
   Subsystem 3 - Serial number: 0123.11.060000000100010057ÿ
   Subsystem 4 - Serial number: 010057ÿ
00384 - Optical Databus
                    Fault Status: 00101011
                    Time Indication: 15
02244 - Button in Control Head is Stuck
                    Mileage: 363270 km
                    Date: 2026.09.12
                    Time: 11:21:42
                    Bin. Bits: 00000000
                    Bin. Bits:  0000000
                    Bin. Bits:      100
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 A    HW: 4F1 820 043 AG
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000052    Serial number: 00000000332367
   Coding: 0000278
   VCID: 1C6ABB8D2AA6F60A1B8-8048
                    Fault Status: 01100101
                    Reset counter: 102
                    Mileage: 236860 km
                    Date: 2021.05.19
                    Time: 17:03:57
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 86
                    Reset counter: 132
                    Mileage: 363015 km
                    Date: 2006.05.30
                    Time: 05:42:55
                    Voltage: 13.30 V
                    Temperature: 25.0°C
                    (no units): 220.0
                    (no units): 91.0
                    Temperature: 29.0°C
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
                    Fault Status: 00101010
                    Reset counter: 159
                    Mileage: 363256 km
                    Date: 2026.09.11
                    Time: 18:33:54
                    Voltage: 13.50 V
                    (no units): 236.0
                    (no units): 255.0
   Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Component: ILM Fahrer      H17 0240
   Coding: 0112121
   Shop #: WSC 02335 785 00200
   VCID: 30327F3D562E626A570-8064
   Subsystem 1 - Part No: 4F1 910 113 C  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0210
   Coding: 00064784
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00146221
   Shop #: WSC 02335
00908 - Control Module for Wiper Motor
                    Reset counter: 142
                    Mileage: 262136 km
                    Date: 2006.05.30
                    Time: 05:45:00
   Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
   Component: MP3-Changer     H44 0350
   Revision: 00044000    Serial number: AUZ5ZBF3118836
   VCID: 1862A79DDE9E9A2A3F0-804C
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 42 AIRBAG AUDI8RH29 0280
   Revision: 08H29000    Serial number: 0037LD0HYHVE
   Coding: 0013362
   VCID: 2904925975F413A290E-807C
   Subsystem 1 - Serial number: 6332CSME14511A19-
   Subsystem 2 - Serial number: 6342CSME16781C6DG
   Subsystem 3 - Serial number: 6352QSME19091871D
   Subsystem 4 - Serial number: 6362QSME196C4973T
   Subsystem 5 - Serial number: 63734SME1A06206D$
   Subsystem 6 - Serial number: 63834SME183B39497
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H08 0230
   Revision: 00H08000    Serial number: 90054063290389
   Coding: 0012142
   Shop #: WSC 02323 785 00200
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4F0-920-KOM-V1.clb
   Part No SW: 4F0 910 930 C    HW: 4F0 920 932
   Component: KOMBIINSTR. M73 H19 0120
   Revision: 00000000    Serial number: 5HP535MC6
   Coding: 2049008
   Shop #: WSC 11111 111 11111
   VCID: 2318807117D8C9F2DA2-8076
00771 - Fuel Level Sensor (G)
                    Reset counter: 160
                    Mileage: 363270 km
                    Date: 2026.09.12
                    Time: 11:20:44
00438 - Fuel Supply Sensor 2 (G169)
                    Reset counter: 160
                    Mileage: 363270 km
                    Date: 2026.09.12
                    Time: 11:20:44
                    Reset counter: 132
                    Mileage: 363733 km
                    Date: 2026.09.25
                    Time: 16:47:48
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 1300806B258042
   Coding: EDFE53CC1B3106
   Shop #: WSC 46876 133 83672
   VCID: 2700946163E025D286A-8072
                    Reset counter: 144
                    Mileage: 363039 km
                    Date: 2006.06.03
                    Time: 10:03:17
                    Reset counter: 132
                    Mileage: 363733 km
                    Date: 2026.09.25
                    Time: 16:44:34
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082946
   VCID: 6194CA794D449BE288E-8034
                    Reset counter: 144
                    Mileage: 100892 km
                    Date: 2006.06.03
                    Time: 10:03:20
   Part No SW: 4E0 910 887 T    HW: 4E0 919 887 L
   Component: MNS ECE         H48 1030
   Revision: 00000000    Serial number: 364K/067619087
   Shop #: WSC 46876 133 84102
   VCID: 3E2E51059C7A841AD5C-806A
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
   Component: TSG FA          H12 0120
   Revision: 00-00000
   Coding: 0001770
   Shop #: WSC 02327 785 00200
   VCID: 2C0A6B4D7A06068A6B8-8078
                    Reset counter: 144
                    Mileage: 363039 km
                    Date: 2006.06.03
                    Time: 10:03:19
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 B    HW: 4F0 907 289 B
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01025484510000
   Coding: 3547781
                    Reset counter: 144
                    Mileage: 363039 km
                    Date: 2006.06.03
                    Time: 10:03:22
01699 - Motor for Central Locking; Hatch/Trunk (V53)
                    Fault Status: 00101001
                    Reset counter: 171
                    Mileage: 363238 km
                    Date: 2026.09.11
                    Time: 13:11:40
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H10 0240
   Revision: PROD_01     Serial number: 00000000003040
   Coding: 0000112
   Shop #: WSC 02324 785 00200
   VCID: 251C9E6919EC37C2B46-8070
                    Fault Frequency: 0
                    Time Indication: 15
00420 - Front Right DSP Midrange Speaker (R104)
                    Fault Status: 00111011
                    Reset counter: 144
                    Mileage: 363039 km
                    Date: 2006.06.03
                    Time: 10:05:48
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 144
                    Mileage: 363039 km
                    Date: 2006.06.03
                    Time: 10:05:48
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000297558
   Coding: 0001013
   VCID: 5EEEF1857C3AA41AB5C-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
   Component: TSG BF          H12 0120
   Revision: 00-00000
   Coding: 0001770
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Reset counter: 144
                    Mileage: 363039 km
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0000321
   VCID: 20128F7D06CED2EAC70-8074
   Part No: 8P0 907 357 F
   Coding: 0000003
   VCID: 3D2C5609917C9F02CC6-8068
                    Fault Status: 11100100
                    Reset counter: 132
                    Mileage: 363736 km
                    Date: 2026.09.25
                    Time: 16:49:18
                    Fault Status: 11100101
                    Reset counter: 132
                    Mileage: 363736 km
                    Date: 2026.09.25
                    Time: 16:53:00
00497 - Sensor for Vehicle Leveling; Rear
                    Fault Status: 11101010
                    Reset counter: 132
                    Mileage: 363736 km
                    Date: 2026.09.25
                    Time: 16:53:00
00496 - Sensor for Vehicle Leveling; Front
                    Reset counter: 132
                    Mileage: 363736 km
                    Date: 2026.09.25
                    Time: 16:53:00
   Part No SW: 4E0 910 541 M    HW: 4F0 035 541 H
   Component: TUNER EU/US/RDW H42 0570
   Revision: 00000000    Serial number: 394KN067710030
   Coding: 0000001
   VCID: 2A066D5570F218BA994-807E
Address 61: Battery Regul.        Labels: 4F0-910-181.clb
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000156682
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  2611271169
   Coding: 344630393135313035442056413032363131323731313639
   Shop #: WSC 12345 512 00290
02272 - Quiescent Current Stage 1
                    Mileage: 363733 km
                    Date: 2026.09.25
                    Time: 16:53:34
02273 - Quiescent Current Stage 2
                    Mileage: 363733 km
                    Date: 2026.09.25
                    Time: 17:01:43
02276 - Quiescent Current Stage 5
                    Mileage: 363733 km
                    Date: 2026.09.25
                    Time: 17:01:53
02274 - Quiescent Current Stage 3
                    Mileage: 363733 km
                    Date: 2026.09.25
                    Time: 17:02:12
02277 - Quiescent Current Stage 6
                    Mileage: 363733 km
                    Date: 2026.09.25
                    Time: 17:02:22
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
   Component: TSG HL          H21 0050
   Coding: 0001066
   VCID: 2E0E61454C1A749A45C-807A
Address 69: Trailer        Labels: 4F0-910-383.lbl
   Part No SW: 4F0 910 383 B    HW: 4F0 907 383 B
   Component: ANHAENGERELEKTR 003 0060
   Coding: 0000331
   VCID: 241A836D12D6CECAA38-8070
   Part No SW: 4F9 910 591     HW: 4F9 827 851 E
   Component: ValeoHeckdeckel H21 0280
   Revision: --H21001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C8AAB4DBA86C68A2B8-8038
   Subsystem 1 - Part No: 4F9 910 592
   Subsystem 3 - Serial number: RD25.11.06--H21001001C0195ÿ
   Subsystem 4 - Serial number: 1C0195ÿ
00317 - Rear Lid Control Module (J605)
                    Fault Frequency: 29
                    Reset counter: 172
                    Mileage: 363034 km
                    Date: 2006.05.30
                    Time: 08:14:23
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Component: TSG HR          H21 0050
   Coding: 0001066
                    Reset counter: 144
                    Mileage: 363039 km
                    Date: 2006.06.03
                    Time: 13:20:18
   Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
   Component: Parkhilfe 8-Kan H12 0060
   Revision: 00H12000    Serial number: 06330632701869
   Coding: 0211016
02069 - Front Parking Aid Sensors
                    Reset counter: 102
                    Mileage: 363025 km
                    Date: 2006.05.30
                    Time: 06:33:57
   Part No SW: 4E0 910 336 K    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005138962
   Coding: 0010910
End----(Elapsed Time: 02:59, VBatt start/end: 10.9V/10.9V. VIgn 11.0V)-----
------------------------------42 Faults Found------------------------------
SavaBogdan
Romania
C?ID=530945
Can anyone help me please? Thank you
SavaBogdan
Romania
C?ID=530945
Thank you. It worked
