2017 Q7 activate green menu
teds352
C?ID=261693
I am trying to activate the green menu on my 2017 Audi Q7. I followed the instructions below:
Method 1: Enabling Green Menu via VCDS
VCDS is the gold standard for VW/Audi group diagnostics. Follow these steps to activate the Developer Mode:
  1. Connect your VCDS cable to the OBD-II port and turn the ignition ON.
  2. Open the VCDS software on your laptop.
  3. Click on Select under “Select Control Module”.
  4. Go to 5F – Information Electr.
  5. On the right side, click on Adaptation – 10.
  6. In the “Search” or “Channel” box, look for: IDE02122-Developer mode.
  7. Under “New Value”, select Activated from the drop-down menu.
  8. Click Do It! and confirm the change.
  9. Restart the MMI: Perform a “Three-Finger Reset” (reboot) of the MMI system to apply changes.
but get the message "record out of range". What does that mean and what do I do now?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Mind posting an Auto-Scan? Where did you get these instructions from and why do you believe they apply to your specific car?
teds352
C?ID=261693
My latest scan:
Wednesday,23,September,2026,19:56:11:28349
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.5
VIN: WA1LAAF75HD032932   License Plate:
Chassis Type: F7-AU73 (8W8)
Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 36 39 3C 42 44 46 47
          50 52 5F 69 6C 6D 81 8B A5 BB BC CA CF D6 D7
VIN: WA1LAAF75HD032932   Mileage: 180732km-112301miles
29-Left Light -- Status: Malfunction 0010
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4M0 907 551 A    HW: 06E 907 425
   Component: 3.0l V6 TFSI  H10 0003
   Revision: --H10---    CVN: 8E921FE7
   Coding: 2A2A00320576010D74280000000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TFS0214M0907551A 001005
   ROD: EV_ECM30TFS021_AU73.rod
   VCID: 2D00E9EA3D97D5B27C6-8078
   VINID: 9D105C4515871585000C22430833FD07FE
29229 - Intake Air Switch-Over Valve (N335)
          P1068 00 [00100111] - Open Circuit
                    Mileage: 180732 km
                    Date: 2026.09.23
                    Time: 19:53:06
                    Engine speed: 654.50 /min
                    Normed load value: 16.1 %
                    Coolant temperature: 85  C
                    Intake air temperature: 59  C
                    Voltage terminal 30: 12.324 V
                    FAC_TPS_1_SAE: 12.500000 %
                    FUP_H_SAE: 3870.0 kPa
                    Charge press.: average: 0.334 bar
                    Engine status: Idle
                    Outside temperature: 34.0  C
                    T_AST_SAE: 0 s
                    Oxygen sensor 1 bank 1: raw value: 1.200 counts
20680 - Coolant Pump for Intercooler
          P190D 00 [00100111] - Mechanical Malfunction
                    Mileage: 180732 km
                    Date: 2026.09.23
                    Time: 19:53:05
                    Engine speed: 686.75 /min
                    Normed load value: 15.7 %
                    Engine status: Idle
                    T_AST_SAE: 0 s
                    Calculated oil temperature: 68.0  C
Readiness: 1110 1101
Address 02: Auto Trans        Labels:| 0BK-927-156.clb
   Part No SW: 4M0 927 158 L    HW: 0D5 927 156 H
   Component: 0D5  30TSIUSA H03 1006
   Revision: --H03---    CVN: 228D7428
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 3D20D9AAEDF74532CC6-8068
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
   Component: ESP9 Premium  H09 0657
   Dataset Number: 4M0909504M  0002 CVN: ACFBEF4F
   Coding: 28AA149C30A50A9891A75894007F52A2E6269A14280C50891A004A45676459
   ASAM Dataset: EV_ESP9BOSCHAU536K 012013
   ROD: EV_ESP9BOSCHAU536K_AU73.rod
   VCID: 45D0B14A85270DF2946-8010
   Part No SW: 4M1 959 760     HW: 4M1 959 760
   Component: MEM-BFS       008 0031
   Serial number: 00000221428155 Dataset Number: 4M0909866C  0016
   Coding: 001410000000B0010000010101010000000000000000000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 76B206868841D66ACDC-8022
   Part No SW: 4M0 820 043 AB    HW: 4M0 820 043 AB
   Component: Klima Zone 4  H52 0093
   Coding: 6608090C5548001110680180800000000000000000000000000000000000
   Shop #: WSC 41318 005 1048576
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 659051CA25E72DF2746-8030
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000001075939
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 9D390D4800PAG0MUFU02
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 4M0909514R  0055
   Coding: 07500363E0691CCD050F8715583E1CB911033D01900000000000000020001A010869012B025709
   VCID: 025A6A56D489FACAF14-8056
   Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 160816  043 0893
   Serial number: 89555300401622900170
   Coding: 1BC7F7
   Serial number: 62312800
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 29 06 2016  00500326
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0050
   Serial number: 0000009600335Z1RIU02
   Coding: 350000
   Garage door opener control head:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20160912165654 00644
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE109071611520081
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 4M0 947 135 CP    HW: 4M0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B10381781
   Subsystem 8 - Part No SW: 4M0 907 705 A    HW: 4M0 907 705 A
   Component: J866-EVLS-SG  H03 0080
   Serial number: WA125105000024655164
   Coding: 020100
   Subsystem 9 - Part No SW: 4M0 925 301 A    HW: 4M0 925 301 A
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000076623
   Subsystem 10 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V512 LLR1SLvL  H03 0012
   Serial number: L14DG19300972
   Subsystem 11 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V514 LLR1SKvL  H03 0012
   Serial number: L14DG18700732
   Subsystem 12 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V516 LLR1SLvR  H03 0012
   Serial number: L14DG19301046
   Subsystem 13 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V518 LLR1SKvR  H03 0012
   Serial number: L14DG18700728
66951 - Databus
          [Left LCM: side marker faulty]
                    Reset counter: 212
                    Mileage: 180732 km
                    Date: 2026.09.23
                    Time: 19:53:07
                    average_Voltage_terminals: 12.50 V
                    Outside air temperature sensor-Outside air temperature on CAN: 34.00  C
                    interior_temperature: 34.00  C
                    Vehicle speed: 0.00 km/h
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 E    HW: 4M0 907 561
   Component: LRR4          H09 0220
   Dataset Number: 4M0909863L  0027
   Coding: B4779FFA58FFEC09949880A1
   ASAM Dataset: EV_ACCBOSCHAU736 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 323AFA9624A98A4A214-8066
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 212
                    Mileage: 180732 km
                    Date: 2026.09.23
                    Time: 19:53:03
                    Control Module temperature: 53  C
                    Voltage terminal 15: 12.1 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s
Address 15: Airbags (J234)       Labels:| 8W0-959-655-V1.clb
   Part No SW: 4M0 959 655 A    HW: 4M0 959 655 A
   Component: Airbag10.44   H71 0086
   Serial number: 003M50013D59 Dataset Number: 4M0909602T  0001
   Coding: AECCFCC000800000A0F00033C24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005.rod
   VCID: 3928CDBAF9DF7912E0E-806C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705E0277Q00049
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706E0274Q01674
   Coding: 88001B
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J160005URD90R
   Subsystem 4 - Part No SW: -----------    HW: 442 061 609 16
   Serial number: 3577Y00A31FB75D403DC
   Subsystem 5 - Part No SW: -----------    HW: 442 061 609 16
   Serial number: 3587Y00A31FFD13362BB
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 006 16
   Serial number: 3517700A120A0006535M
   Subsystem 7 - Part No SW: -----------    HW: 442 0B2 006 16
   Serial number: 35277009F20A0002F34+
   Subsystem 8 - Part No SW: -----------    HW: 442 0C1 008 16
   Serial number: 3557500A92139CD573AN
   Subsystem 9 - Part No SW: -----------    HW: 442 0C1 008 16
   Serial number: 3567500A92139CD282DO
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 410 201 309 16
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O7800BD20D7DC2924G
   Part No SW: 4M0 907 129 GS    HW: 4M0 907 129 GS
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 074C7B42FFABDFE2A6A-8052
   Part No SW: 4M0 920 890 B    HW: 4M0 920 890 B
   Component: FBenUSA       H15 0302
   Coding: 08C600C16C88CF0502A369601800600008000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 2F3CF3E2379BA7A24EA-807A
   Part No SW: 8W8 907 468 C    HW: 8W8 907 468 C
   Component: Gateway       H27 1298
   Revision: 4Q080005    Serial number: 0584Q273516928 Dataset Number: 4M0909515F  0073
   Coding: 0301000100000E4054070000005900305C120007000000000150000000000000
   GVL: 01503C0408000000C0FCC8000002C800100C2000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 002060
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 4CC6846EA64DFCBA4B8-8018
   Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
   Component: J453 MFL  H06 0002
   Serial number: 20160917024840 00313
   Serial number: 5729961504
6291457 - Control Module Blocked
          B2017 00 [00001001] - -
          [Immobilizer_Locked]
                    Reset counter: 212
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 D    HW: 4M0 919 158 D
   Component: Klima Zone 2  H52 0092
   Coding: 000000000000000100800080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 3632C686C8C1966A0DC-8062
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   ROD: EV_LCMLeftHELLAAU736_AU37.rod
   VCID: 78AE08BE8255A01ADF0-802C
0308 - Bulb for side marker light
          C11A6 15 [00001001] - Open or Short to Plus
                    Reset counter: 212
                    Mileage: 180732 km
                    Date: 2026.09.23
                    Time: 19:53:04
   Component: MEM-FS        008 0031
   Serial number: 00000221428329 Dataset Number: 4M0909856C  0018
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------    Dataset Number: 4M0909535K  0014
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   VCID: 3436FC8EDEBD847A338-8060
   Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
   Component: TSG FS        009 0052
   Serial number: 0000221221441  Dataset Number: 4M0909872F  0027
   Coding: 005F9B005E001080000120B0
   VCID: 42DAAA5694093ACAB14-8016
Address 44: Steering Assist (J500)       Labels:* 4N0-909-144-V1.clb
   Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H20 0004
   Serial number: 0000269514 Dataset Number: 4M0909852L  0025
   Coding: B0000101000101
   ASAM Dataset: EV_EPSVWBSAU736 008020
   ROD: EV_EPSVWBSAU736_008.rod
   VCID: 3334FF92DBB383422A2-8066
   Part No SW: 8W0 907 064 BD    HW: 8W0 907 064 D
   Component: BCM2 MLBevo   018 0328
   Dataset Number: 4M0909501G  0060
   Coding: 01341E00490100C0650B80006E01580003024000010001502F0400000F04803F001E0001000000
   ASAM Dataset: EV_BCM2HellaAU736 011012
   ROD: EV_BCM2HellaAU736_011_AU49.rod
   VCID: 7F5CE3A2A77B97229EA-802A
   ID - sensor:
   Subsystem 1 - Part No SW: 4M0 959 754 AK    HW: 4M0 959 754 AK
   Component: ID-Geber  H40 0105
   Serial number: 3616000191344013
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000036547470
   Power rear lid opening control module:
   Subsystem 3 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94159327
   Part No SW: 4M0 035 223 B    HW: 4M0 035 223
   Component: MIB2_amp_PD   H02 0430
   Serial number: 00000000020415 Dataset Number: 4M1909510D  0010
   Coding: 0135060A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 221A0AD674491ACAD14-8076
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
   Component: MEM-SR3       008 0015
   Serial number: 00000221203546 Dataset Number: 4M0909467B  0014
   Coding: FF041020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   VCID: 3C26D4AEF6ED4C3AFB8-8068
   Part No SW: 4M0 959 792 G    HW: 4M0 959 792 C
   Component: TSG BFS       009 0052
   Serial number: 0000221424480  Dataset Number: 4M0909873F  0027
   VCID: 41D8A55A910F21D2A8E-8014
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M0 035 880 B    HW: 4M0 035 880
   Component: MU-P-LNS-US   052 0692
   Serial number: A289J0G7521481 Dataset Number: 4M0909545J  0036
   Coding: 013706020000000013220002041A00102F001BE501700904BE
   VCID: 2B04E7F20383DB82622-807E
   Subsystem 1 - Part No SW: V03 959 802 DL    HW: -----------
   Component: NAR 2019  --- 0069
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9GJ402Y15
   Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
   Component: ControlUnit_P  H15 0209
   Serial number: 24051600000000000339
   Compact disc data bank:
   Component: Gracenote2---  --- 3009
   Part No SW: 4M0 907 383 C    HW: 4M0 907 383
   Component: Anhaenger     H20 0214
   Revision: 9C001003    Serial number: 0418363316 Dataset Number: 4M0909527C  0024
   Coding: 0210000200000000
   Part No SW: 4M0 907 428 E    HW: 4M0 907 428
   Component: Areaview 2    H13 0315
   Serial number: C854607JG004171 Dataset Number: 4M1909460G  0022
   Coding: 02350602BB0FA10008404004
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: 30964632400000 Dataset Number: 4M0909541G  0025
   Coding: 00B0
   VCID: 48CEB87EB235109A6F0-801C
   Part No SW: 4M1 713 041 F    HW: 4M1 713 041 F
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20160924001406
   ASAM Dataset: EV_GSMWaehlZFAU736 001016
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 280E18FE1275F09A8F0-807C
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 E    HW: 4M0 907 541
   Dataset Number: 4M0909885H  0022
   ASAM Dataset: EV_ACC2BOSCHAU736 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 303EF09E2AA5B85A570-8064
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H14 0042
   Dataset Number: 4M0909466K  0041
   Coding: 0407030600000201022023A7A50000B4B0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 4M0 959 795 G    HW: 4M0 959 795 C
   Component: TSG HFS       009 0052
   Serial number: 0000221183502  Dataset Number: 4M0909897F  0028
   Coding: 004F9B0000001080400020A0
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 44D6AC4E8E1D34FA838-8010
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS      009 0052
   Serial number: 0000221183716  Dataset Number: 4M0909896F  0028
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 4M0 907 594 G    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Dataset Number: 4M0909469F  0014
   Coding: 2A8000053602
   ROD: EV_SunRoofCONTIAU736_006_VW37.rod
   VCID: 3A2AD2B6FCD9720AE94-806E
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 4M0 907 590 B    HW: 4M0 907 590
   Revision: --------
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001015
   VCID: 3138F59A21AFB15258E-8064
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Dataset Number: 4M0909471D  0012
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 16722606A801766A2DC-8042
   Component: LED1R         H09 0003
   Dataset Number: 4M0909472D  0012
End----------(Elapsed Time: 02:44, VBatt start/end: 12.6V/12.7V)-----------
------------------------------6 Faults Found-------------------------------
I wanted to look in the green menu to see if anything there would help with the scan errors, especially address 13, the distance sensor, or address 09 and 29. The light error message appears on the dash only at night, not during daylight.
The instruction were from myaudi.org:
Unlocking Audi MMI MIB2 Developer Mode: The Engineering Menu Guide
Post author:Adam
Post published:March 21, 2026
Post category:Manuals
Post comments:0 Comments
Are you looking to dive deeper into your Audi’s infotainment system? The Engineering Menu (commonly known as the Hidden Green Menu) in the MIB2 units is a treasure trove of technical data and advanced configurations. Whether you want to troubleshoot GPS issues or force a firmware update, unlocking this menu is the first step.
In this tutorial, we’ll show you how to gain access using the industry-standard VCDS and the enthusiast-favorite OBDeleven.
Table of Contents
Why Access the MIB2 Engineering Menu?
Method A: Using OBDeleven (The Mobile Way)
Method B: Using VCDS (The Professional Way)
How to Trigger the Green Menu Screen
Summary
The MIB2 system (Modular Infotainment Platform 2) is the heart of Audi models produced between 2015 and 2020. By enabling Developer Mode, you can:
Perform advanced system diagnostics.
Manage internal storage and logs.
Access the SWDL (Software Download) manual mode for custom updates.
View real-time data from the MOST bus and tuner.
Precautions: This menu is intended for advanced users. Changing values at random can result in a non-responsive MMI unit. Always take a backup or a photo of your original settings before making changes.
OBDeleven makes it incredibly simple to toggle the Developer Mode on MIB2 units.
Connect your OBDeleven device to the vehicle’s diagnostic port.
Open the app and go to Control Units.
Select Unit 5F (Information Electronics).
Tap on Adaptation.
Search for the channel named Developer mode.
Slide the value to On.
Write the changes (hold the green button).
Reboot your MMI: Press and hold the Volume knob and the two toggle switches (NAV + MEDIA) simultaneously.
If you prefer the classic Ross-Tech interface, follow these steps to modify the adaptation channels:
Plug in your VCDS hex-cable and launch the software.
Click Select under Control Modules, then choose 5F-Information Electr.
Choose Adaptation – 10.
In the search field, type Developer mode (or look for channel IDE02122).
Change the “Stored Value” from Not Active to Active.
Click Test, then Save.
Exit the controller and perform a hard reset of the MMI system.
Even after it is “Enabled” via software, the menu remains hidden until you use the secret button sequence.
For Audi MIB2 (A4 B9, A5 F5, Q5 FY, Q7 4M):
Push the NAV/MAP toggle switch UP and the MEDIA toggle switch DOWN at the exact same time.
Hold them for at least 5 seconds.
The screen will change to a green-themed interface.
