2026 VW Jetta GLI -- Changing Telematics Backup Battery
Marek K
Colorado Springs, CO, USA
C?ID=61888
I'm far from needing to replace the backup telematics module battery yet on my 2026 GLI. I do intend to do it myself in five years or so (not knowing what the unintended consequences might be of just disconnecting the module).
Seems simple enough, according to erWin. Except for the dire warning about first shutting down the module using the "Vehicle Diagnostic Tester":
I assume that's ODIS...?
Does VCDS have that capability somewhere?
Yup.
I don't know exactly what ODIS is doing there, and I can't even begin to guess without seeing exactly what Telematics module is in this car and what ASAM data it uses.
Wait, I found it here and looking at the data... It isn't obvious.
Marek K
C?ID=61888
...I can't even begin to guess without seeing exactly what Telematics module is in this car and what ASAM data it uses.
Where? And what isn't obvious? That was thread about battery registration....
Do I need to do a map of the 75-Telematics Module for you?
If so, with SFD locked or unlocked?
Right. I've looked at the source data for your 75-Telematics Module and I didn't find anything obvious that would shut down the module. I do not think a map would help in this case.
I think the next step would be for one of our people to go digging into ODIS to see what the heck it is doing to shut that module down, but given that your car is a 2026 model and thus covered under warranty for another 3 years or so in case of premature failure of that backup battery, I don't have much sense of urgency about this. ;)
Marek K
C?ID=61888
Well, I don't have any sense of urgency yet. I was just researching future maintenance requirements, to avoid surprises.
I don't have any sense of how often the telematics back-up battery needs to be replaced. I believe VW recommends testing the battery every couple of years during routine maintenance. I'd guess it should last five years or so.
But VWs, to include Jettas, have had telematics modules in them for some years now -- I assume the modules are all similar, with the same batteries. So it's getting to be time for other people to replace their batteries -- unless they want to live with warning messages; or, like I said, other unintended consequences...
Yes. Many of the older ones no longer work at all because they used 3G networks that were "sunset" by the carriers.
Some people consider that a blessing because VW can not longer track their driving. :D
Others consider it a curse because, for example, they can no longer pre-condition the e-Golfs using an app.
That would be a bad assumption. There are many different ones. Even in a single model, they change every model year or two. Here, for example is the one in my daughter's 2023 Jetta. Note that it's a different part number and uses a different ASAM identifier than yours:
   Part No SW: 5WA 035 283 D    HW: 5WA 035 283
   Component: OCUGen3Low    H12 0308
   Serial number: 0000000301NVEY2 Dataset Number: V03935386VR 0001
   Coding: 02371020196828208005461160000607
   ASAM Dataset: EV_OCUGen3Low 003008
   ROD: EV_OCUGen3Low_003_VW27.rod
   VCID: 46C0909FF9B4F2A229-8012
Marek K
C?ID=61888
OK.
I just looked up the telematics module part number that my VCDS scan shows -- 2GA 035 285.
VW shows that it's called Mobile Phone Control Module. But "THIS DOES NOT FIT YOUR 2026 Volkswagen Jetta...":
So what's up with that?
That part number, 2GA 035 285, is supposedly for the 2022-2025 VW Taos. Here's what it looks like:
Similar to what erWin shows for my GLI, but the shape of the module is different.
In any case, I'd still think they'd use the same telematics back-up battery. It would make sense... :rolleyes:
I can't find the exact battery listed for my 2026 GLI, but I suspect it's this one:
VW Part number 3G0 915 089. It seems to be applicable to a whole lot of telematics modules in all sorts of VWs over the past few years.
So if people with five- or six-year-old VWs are needing these batteries replaced by now, then they might be looking at how to do it with VCDS without damaging their module...
NEtech
Denmark
C?ID=56995
Yes it is possible, assuming this Basic Setting is SFD.
BS MAS17566-ENG114972-Resetting the history of the emergency call battery
  • Ignition OFF
  • Wait 20 sec.
  • Ignition ON
  • Wait until the light and the LED on the control unit have turned off.
  • Press [Adv. Meas. Values]
  • Search for and select display: IDE11307 + ENG254564 + IDE01770 + IDE01713 + MAS04394 + IDE03477 > [Save display]
  • Perform this basic setting
  • Wait approx. 30 sec.
  • [Stop]
  • Disconnect VCDS
  • Ignition OFF
  • Ventilate for e.g. 5 min.
  • Check that the SOS indicator light turns green again.
Marek K
C?ID=61888
OK, thanks.
But according to an AI search (:rolleyes:) referencing a vag-coding.net tutorial (https://www.vag-coding.net/tutorials-information/fix-the-sos-error-emergency-call-function-limited/) -- yes, I know that's not a Ross-Tech site -- that function is done only after a new battery is installed; and it's to erase previous fault codes resulting from the old battery.
But the erWin procedure says to shut down the module using the Vehicle Diagnostic Tester before changing the battery. And it's to prevent damage to the module, which old fault codes wouldn't cause...
Also... Wouldn't old fault codes in this module be erasable just like any other fault codes?
Not all fault codes are can be erased. ;)
Marek K
C?ID=61888
Not yelling at you... But... Why the hell not?
What's so sensitive about faults reporting a weak telematics back-up battery?
Or is someone afraid that people would be covering something up after an accident...? :confused:
But again... It doesn't seem that this is the same as what erWin is saying...
"Not all fault codes can be erased" was a general statement. I don't know if it applies the specific fault codes for a weak telematics battery, and whether it does or not may depend on the particular telematics module in question.
Op, if you want to be that prepared, get yourself one of those batteries Used, a eBay special, then cut it open (the shrink wrap) and see what cells are being used. Also see if there is any type of circuit board within the wrap. Then source some cells.
There is a (regarding Li - on) process for fusing the tabs/ cells together and connecting the wires. See YouTube; armamentarium can be found on Amazon.
Marek K
C?ID=61888
That's a great idea. I see batteries like this (at least for some kinds of VW telematics modules) offered on Amazon for less than $40.
Problem is, I haven't found any that are specifically listed for my module's part number.
And that still wouldn't address the issue of shutting down the module first, as erWin warns...
And you won't. You have to cut open the battery wrap and check the number on the battery, that will tell you the Specification of the battery. You can then source that exact spec. Searching the web and that number will give you the data of that cell. The manufacturer is not going to "hand" you the information.
Yes, erWin warns of A-lot of things...... on my 2024 RS5 there are warnings stating (paraphrase) "do not jack up the vehicle" "only use a four post/point lift".
That is certainly a message to take note of , but as the EV forums grow I don't think you will have much difficulty finding out how to do that.
Marek K
C?ID=61888
I meant that I'd expect to be able to find what back-up battery goes to my specific telematics module, for sale on VW dealer parts sites. I don't think I've even been able to find my specific module (2GA 035 285, as shown on VCDS) listed for my 2026 Jetta GLI.
Cutting open my existing battery would be a bit...extreme...
True. Trick is to know what's a CYA warning, and what's an actual warning...
EV, as in electric vehicle? This has nothing to do with just EVs. My 2026 GLI is very-much IC...
But I guess you're right. As time goes on, we'll start seeing more information here (and elsewhere) regarding how to change the telematics back-up battery...
Or maybe not. My 2021 Jeep Renegade Trailhawk is now 5-1/2 years old. And Jeep recommends replacing its telematics battery every five years. I haven't seen anyone posting in the Jeep Renegade forum yet on how to change the battery; though I've got a Mopar Service Manual where it says how to do it.
Hell, my problem is that I can't even find the Renegade's telematics module where the Service Manual says it's supposed to be -- and where other people have found theirs... Just the empty bracket behind the radio where it's supposed to be... :confused:
Right, don't do that.
No, you misunderstand (I think), I meant find the correct battery on ebay (cheap) with the correct PN for your application, but do not trust it is a functioning part (its off of ebay after all and its electronic). You are using it for research and not to use. Once you know what the spec. is, you could build your own. (if you had to). Or, if the factory part was prohibitively expensive.
I think your vehicle is to new and the parts will start showing up in 6 months or so. I did confuse your vehicle for a EV.
Marek K
C?ID=61888
OK, sorry. I did misunderstand. :rolleyes:
Problem is, I can't find the correct telematics back-up battery on eBay at all.
And I've found what may be the correct battery pack on Amazon...
...but I don't see a cross-reference to my 2026 GLI.
Hmmm... An option might be to access the telematics module; loosen it from its mount without unplugging any connectors (the battery seems to be on the bottom); open the battery cover; and see if I can see the VW P/N on it without unplugging the battery (and potentially nuking my module)...
Marek K
C?ID=61888
3G0 915 089 , the web is full of them!
Yes, I know. That's how I found that image above.
What I don't know for sure is whether 3G0 915 089 fits my 2026 GLI. Since as Uwe points out, and as we've seen, there are all sorts of different modules currently.
And no assurance they take the same batteries...
